[U-Boot] [PATCH] x86: make X86IRQ per Kconfig switchable
This commit creates the freedom for boards to do nothing with the whole IRQ stuff on x86 during u-boot.
This is especially important on older systems which have many legacy irq and no ACPI support within BIOS, they get in trouble if, for example, u-boot does mask all the interrupts on a PIC.
Signed-off-by: Hannes Schmelzer oe5hpm@oevsv.at
arch/x86/Kconfig | 8 ++++++++ arch/x86/lib/Makefile | 2 +- include/_exports.h | 2 +- 3 files changed, 10 insertions(+), 2 deletions(-)
diff --git a/arch/x86/Kconfig b/arch/x86/Kconfig index 00b69c6..d2b691f 100644 --- a/arch/x86/Kconfig +++ b/arch/x86/Kconfig @@ -736,6 +736,14 @@ config I8259_PIC slave) interrupt controllers. Include this to have U-Boot set up the interrupt correctly.
+config X86IRQ + bool + default y + help + Provide basic IRQ initialization with dummy handlers and spurious IRQ + catching. Provide also some exported high-level API for standalone + applications (see doc/README.standalone). + config APIC bool default y diff --git a/arch/x86/lib/Makefile b/arch/x86/lib/Makefile index 1e8efcc..57cb87d 100644 --- a/arch/x86/lib/Makefile +++ b/arch/x86/lib/Makefile @@ -16,7 +16,7 @@ obj-$(CONFIG_SEABIOS) += coreboot_table.o obj-y += early_cmos.o obj-y += e820.o obj-y += init_helpers.o -obj-y += interrupts.o +obj-$(CONFIG_X86IRQ) += interrupts.o obj-y += lpc-uclass.o obj-y += mpspec.o obj-$(CONFIG_ENABLE_MRC_CACHE) += mrccache.o diff --git a/include/_exports.h b/include/_exports.h index 5416041..39e3e32 100644 --- a/include/_exports.h +++ b/include/_exports.h @@ -13,7 +13,7 @@ EXPORT_FUNC(putc, void, putc, const char) EXPORT_FUNC(puts, void, puts, const char *) EXPORT_FUNC(printf, int, printf, const char*, ...) -#if (defined(CONFIG_X86) && !defined(CONFIG_X86_64)) || defined(CONFIG_PPC) +#if (defined(CONFIG_X86IRQ) && !defined(CONFIG_X86_64)) || defined(CONFIG_PPC) EXPORT_FUNC(irq_install_handler, void, install_hdlr, int, interrupt_handler_t, void*)
Hi Hannes,
Can you elaborate more on what specific issues are here? x86 interrupt was designed to keep backward compatible and I don't think current codes will break anything.
Regards, Bin
On 10/23/2018 05:24 AM, Bin Meng wrote:
Hi Hannes,
Hi Bing, thanks for your response.
I'm actually porting coreboot + u-boot as payload for a quite old board. Having here some AMD Geode LX800 with companion chip CS5536 as southbridge. I went into trouble during bringing up ATA (whis no pci device) within linux after u-boot did run on the machine, the driver didn't get any interrupts from the device. The combination coreboot+seabios for example worked fine. So i've searched for differences.
The difference is, that seabios leaves the irq stuff untouched and u-boot not.
Further thinking about all this brought me to the point that the OS has no real chance to setup things correctly without an ACPI or MP Table from the boot-loader where the hardware may be described. PCI devices are working correctly, because the configuration space of the pci device describes the situation and OS can setup the things correctly. In my case coreboot doesn't provide none of these tables, instead it did setup the PIC and maybe many other things in the southbridge to a basically working state. So my idea was to instruct u-boot to leave the irq stuff untouched. Further i think there is no need for manipulating the PIC during u-boot, unless we don't use any interrupt there.
But maybe i'm thinking here completely weird and another way would bring me faster to the goal of a working system. Please let me know.
cheers, Hannes
Hi Hannes,
On Tue, Oct 23, 2018 at 3:08 PM Hannes Schmelzer hannes@schmelzer.or.at wrote:
Hi Hannes,
I see you changed the "EXPORT_FUNC(irq_install_handler..)". Is there any codes in your board support that calls such? Isn't not calling interrupt_init() sufficient to fix your problem?
Regards, Bin
On 11/18/18 3:07 PM, Bin Meng wrote:
Hi Hannes,
Hi Bin,
Hi Hannes,
I agree, that would also fix my problem. But on the other hand it would leftover dead code in case if the interrupt stuff isn't needed.
Would it be better to have 'config X86IRQ_SKIPINIT' (default no) for example instead my 'config X86IRQ' with default yes and make some #ifdef within interrupt.c?
Regards, Bin
cheers, Hannes
Hi Hannes,
On Mon, Nov 19, 2018 at 6:29 AM Hannes Schmelzer hannes@schmelzer.or.at wrote:
Hi Hannes,
Hi Bin,
Hi Hannes,
I checked the interrupt.c. Isn't turning off CONFIG_I8259_PIC and CONFIG_APIC already done the trick for your board? I don't think initializing the IRQ vectors stuff will break your ATA driver in Linux.
Regards, Bin
On 11/19/18 2:59 AM, Bin Meng wrote:
Hi Hannes,
Hi Bin,
Hi Hannes,
Hi Bin,
Hi Hannes,
No. Have a look to the function interrupt.c
int i8259_init(void) { u8 i;
/* Mask all interrupts */ outb(0xff, MASTER_PIC + IMR); outb(0xff, SLAVE_PIC + IMR); ..... }
This has nothing todo with some APIC, the i8259 is the legacy XT-PIC. And here all interrupts get masked, so the ATA irq doesn't come through anymore.
Regards, Bin
cheers, Hannes
Hi Hannes,
On Mon, Nov 19, 2018 at 5:31 PM Hannes Schmelzer hannes@schmelzer.or.at wrote:
Hi Hannes,
Hi Bin,
Hi Hannes,
Hi Bin,
Hi Hannes,
I don't understand. If you disable CONFIG_I8259_PIC in your board config, it will not touch 8259.
Regards, Bin
On 11/19/18 10:35 AM, Bin Meng wrote:
Hi Hannes,
Hi Bin,
Hi Hannes,
Hi Bin,
Hi Hannes,
Hi Bin,
Hi Hannes,
Basically yes. But if i disable the CONFIG_I8259_PIC the reset of the interrupt stuff gets into trouble:
arch/x86/lib/built-in.o: In function `irq_install_handler': /home/schmelzerh/work/u-boot/arch/x86/lib/interrupts.c:67: undefined reference to `unmask_irq' arch/x86/lib/built-in.o: In function `irq_free_handler': /home/schmelzerh/work/u-boot/arch/x86/lib/interrupts.c:86: undefined reference to `mask_irq' arch/x86/lib/built-in.o: In function `do_irq': /home/schmelzerh/work/u-boot/arch/x86/lib/interrupts.c:107: undefined reference to `mask_irq' /home/schmelzerh/work/u-boot/arch/x86/lib/interrupts.c:112: undefined reference to `unmask_irq' /home/schmelzerh/work/u-boot/arch/x86/lib/interrupts.c:113: undefined reference to `specific_eoi'
This is because after disabling APIC and PIC no function for enable/disable interrupt is left. Or with other words, without APIC nor PIC the rest of the irq stuff doesn't make sense on x86.
Regards, Bin
cheers, Hannes
Hi Hannes,
On Mon, Nov 19, 2018 at 5:45 PM Hannes Schmelzer hannes@schmelzer.or.at wrote:
Hi Hannes,
Hi Bin,
Hi Hannes,
Hi Bin,
Hi Hannes,
Hi Bin,
On Tue, Oct 23, 2018 at 3:08 PM Hannes Schmelzer hannes@schmelzer.or.at wrote: > On 10/23/2018 05:24 AM, Bin Meng wrote: > > Hi Hannes, > > Hi Bing, > thanks for your response. > > On Tue, Oct 23, 2018 at 5:12 AM Hannes Schmelzer oe5hpm@oevsv.at wrote: > > This commit creates the freedom for boards to do nothing with the whole > IRQ stuff on x86 during u-boot. > > This is especially important on older systems which have many legacy irq > and no ACPI support within BIOS, they get in trouble if, for example, > u-boot does mask all the interrupts on a PIC. > > Can you elaborate more on what specific issues are here? x86 interrupt > was designed to keep backward compatible and I don't think current > codes will break anything. > > I'm actually porting coreboot + u-boot as payload for a quite old board. > Having here some AMD Geode LX800 with companion chip CS5536 as southbridge. > I went into trouble during bringing up ATA (whis no pci device) within linux after u-boot did run on the machine, the driver didn't get any interrupts from the device. > The combination coreboot+seabios for example worked fine. So i've searched for differences. > > The difference is, that seabios leaves the irq stuff untouched and u-boot not. > > Further thinking about all this brought me to the point that the OS has no real chance to setup things correctly without an ACPI or MP Table from the boot-loader where the hardware may be described. PCI devices are working correctly, because the configuration space of the pci device describes the situation and OS can setup the things correctly. In my case coreboot doesn't provide none of these tables, instead it did setup the PIC and maybe many other things in the southbridge to a basically working state. So my idea was to instruct u-boot to leave the irq stuff untouched. > Further i think there is no need for manipulating the PIC during u-boot, unless we don't use any interrupt there. > > But maybe i'm thinking here completely weird and another way would bring me faster to the goal of a working system. Please let me know. I see you changed the "EXPORT_FUNC(irq_install_handler..)". Is there any codes in your board support that calls such? Isn't not calling interrupt_init() sufficient to fix your problem?
Thanks for the trying. So the root cause for your board is now clear. I think we should fix the build dependency when turning off CONFIG_I8259_PIC instead.
Regards, Bin
Hi Hannes,
On Mon, Nov 19, 2018 at 6:28 PM Bin Meng bmeng.cn@gmail.com wrote:
Hi Hannes,
Hi Hannes,
Hi Bin,
Hi Hannes,
Hi Bin,
On 11/18/18 3:07 PM, Bin Meng wrote: > Hi Hannes, Hi Bin, > On Tue, Oct 23, 2018 at 3:08 PM Hannes Schmelzer hannes@schmelzer.or.at wrote: >> On 10/23/2018 05:24 AM, Bin Meng wrote: >> >> Hi Hannes, >> >> Hi Bing, >> thanks for your response. >> >> On Tue, Oct 23, 2018 at 5:12 AM Hannes Schmelzer oe5hpm@oevsv.at wrote: >> >> This commit creates the freedom for boards to do nothing with the whole >> IRQ stuff on x86 during u-boot. >> >> This is especially important on older systems which have many legacy irq >> and no ACPI support within BIOS, they get in trouble if, for example, >> u-boot does mask all the interrupts on a PIC. >> >> Can you elaborate more on what specific issues are here? x86 interrupt >> was designed to keep backward compatible and I don't think current >> codes will break anything. >> >> I'm actually porting coreboot + u-boot as payload for a quite old board. >> Having here some AMD Geode LX800 with companion chip CS5536 as southbridge. >> I went into trouble during bringing up ATA (whis no pci device) within linux after u-boot did run on the machine, the driver didn't get any interrupts from the device. >> The combination coreboot+seabios for example worked fine. So i've searched for differences. >> >> The difference is, that seabios leaves the irq stuff untouched and u-boot not. >> >> Further thinking about all this brought me to the point that the OS has no real chance to setup things correctly without an ACPI or MP Table from the boot-loader where the hardware may be described. PCI devices are working correctly, because the configuration space of the pci device describes the situation and OS can setup the things correctly. In my case coreboot doesn't provide none of these tables, instead it did setup the PIC and maybe many other things in the southbridge to a basically working state. So my idea was to instruct u-boot to leave the irq stuff untouched. >> Further i think there is no need for manipulating the PIC during u-boot, unless we don't use any interrupt there. >> >> But maybe i'm thinking here completely weird and another way would bring me faster to the goal of a working system. Please let me know. > I see you changed the "EXPORT_FUNC(irq_install_handler..)". Is there > any codes in your board support that calls such? Isn't not calling > interrupt_init() sufficient to fix your problem? I agree, that would also fix my problem. But on the other hand it would leftover dead code in case if the interrupt stuff isn't needed.
Could you please take a look and testing http://patchwork.ozlabs.org/project/uboot/list/?series=76752?
Regards, Bin
Bin Meng
Hannes Schmelzer
Hannes Schmelzer
