Re: [U-Boot-Users] Can I write to flash using mw command
On Thu, 2006-10-05 at 14:03 -0700, bilahari akkiraju wrote:
Hi Ben,
Stuff works fine using U-boot's cfi. I can protect and erase using appropriate commands (protect and erase ) provided by the u-boot. I do not know if there is a u-boot command to write to flash.
My flinfo command shows this :
bank # 1: CFI conformant FLASH (32 x 16) Size: 16 MB in 128 Sectors Erase timeout 16384 ms, write timeout 0 ms, buffer write timeout 4096 ms, buffe2 Sector Start Addresses:
FF000000 FF020000 FF040000 FF060000 FF080000 FF0A0000 FF0C0000 FF0E0000 FF100000 FF120000
This is odd. The GL064 is either 32x8 or 16x16, and has either 128x64kB or 127x64kB + 8x8kB sector layout. Yours appears to have 128 uniform sectors of 128kB each. Either you're not using the part you think you are or my documentation is out of date.
I am trying low level access because I am writing my own flash utilities which are independent of U-boot and hence have to directly deal with right command sequences.
If your utilities are independent of U-boot then your request is off-topic. Since the CFI driver is working, you're missing something in the sequence of commands being written to flash. I've done it before manually via BDI-2000, and although the Spansion documentation is cryptic, it's technically correct. Sorry I can't help more right now but work beckons...
Also, please copy the U-boot mailing list when corresponding.
regards, Ben
RTFM: http://www.denx.de/wiki/view/DULG/UBootCmdGroupFlash
Ben Warren
