[PATCH 1/3] riscv: Start using ldflags-y for 32/64bit LDFLAGS
To prepare to update our Kbuild logic, start switching some of our cases of adding different bit/endian linker flags via ldflags-y
Cc: Rick Chen rick@andestech.com Signed-off-by: Tom Rini trini@konsulko.com --- arch/riscv/config.mk | 7 +++---- 1 file changed, 3 insertions(+), 4 deletions(-)
diff --git a/arch/riscv/config.mk b/arch/riscv/config.mk index 84654eb3ed87..df91a85f677f 100644 --- a/arch/riscv/config.mk +++ b/arch/riscv/config.mk @@ -10,16 +10,14 @@ # Rick Chen, Andes Technology Corporation rick@andestech.com #
-32bit-emul := elf32lriscv -64bit-emul := elf64lriscv +ldflags-$(CONFIG_32BIT) := -m elf32lriscv +ldflags-$(CONFIG_64BIT) := -m elf64lriscv
ifdef CONFIG_32BIT -PLATFORM_LDFLAGS += -m $(32bit-emul) EFI_LDS := elf_riscv32_efi.lds endif
ifdef CONFIG_64BIT -PLATFORM_LDFLAGS += -m $(64bit-emul) EFI_LDS := elf_riscv64_efi.lds endif
@@ -29,6 +27,7 @@ PLATFORM_CPPFLAGS += -ffixed-gp -fpic PLATFORM_RELFLAGS += -fno-common -gdwarf-2 -ffunction-sections \ -fdata-sections LDFLAGS_u-boot += --gc-sections -static -pie +PLATFORM_LDFLAGS += $(ldflags-y)
EFI_CRT0 := crt0_riscv_efi.o EFI_RELOC := reloc_riscv_efi.o
Cc: Daniel Schwierzeck daniel.schwierzeck@gmail.com Signed-off-by: Tom Rini trini@konsulko.com --- arch/mips/config.mk | 12 ++++++------ 1 file changed, 6 insertions(+), 6 deletions(-)
diff --git a/arch/mips/config.mk b/arch/mips/config.mk index 9d3a84539a7d..f8180dcd396c 100644 --- a/arch/mips/config.mk +++ b/arch/mips/config.mk @@ -4,8 +4,8 @@ # Wolfgang Denk, DENX Software Engineering, wd@denx.de.
ifdef CONFIG_SYS_BIG_ENDIAN -32bit-emul := elf32btsmip -64bit-emul := elf64btsmip +ldflags-$(CONFIG_32BIT) += -m elf32btsmip +ldflags-$(CONFIG_64BIT) += -m elf64btsmip 32bit-bfd := elf32-tradbigmips 64bit-bfd := elf64-tradbigmips PLATFORM_CPPFLAGS += -EB @@ -13,8 +13,8 @@ PLATFORM_LDFLAGS += -EB endif
ifdef CONFIG_SYS_LITTLE_ENDIAN -32bit-emul := elf32ltsmip -64bit-emul := elf64ltsmip +ldflags-$(CONFIG_32BIT) += -m elf32btsmip +ldflags-$(CONFIG_64BIT) += -m elf64btsmip 32bit-bfd := elf32-tradlittlemips 64bit-bfd := elf64-tradlittlemips PLATFORM_CPPFLAGS += -EL @@ -23,18 +23,18 @@ endif
ifdef CONFIG_32BIT PLATFORM_CPPFLAGS += -mabi=32 -PLATFORM_LDFLAGS += -m $(32bit-emul) OBJCOPYFLAGS += -O $(32bit-bfd) CONFIG_STANDALONE_LOAD_ADDR ?= 0x80200000 endif
ifdef CONFIG_64BIT PLATFORM_CPPFLAGS += -mabi=64 -PLATFORM_LDFLAGS += -m$(64bit-emul) OBJCOPYFLAGS += -O $(64bit-bfd) CONFIG_STANDALONE_LOAD_ADDR ?= 0xffffffff80200000 endif
+PLATFORM_LDFLAGS += $(ldflags-y) + PLATFORM_CPPFLAGS += -D__MIPS__ PLATFORM_ELFENTRY = "__start" PLATFORM_ELFFLAGS += -B mips $(OBJCOPYFLAGS)
Hi Tom,
Am 27.03.20 um 14:52 schrieb Tom Rini:
is this change really necessary? I'd like to keep that in sync with MIPS Linux. And MIPS Linux simply changed to
KBUILD_LDFLAGS += -m $(ld-emul)
On Fri, Mar 27, 2020 at 04:08:16PM +0100, Daniel Schwierzeck wrote:
Hi Tom,
Pretty sure it was the only way I got ci20 to continue to build. I'll go try a one-off local branch and re-confirm now that I have other issues resolved too. Thanks!
Hi Tom,
OK, looks like this was a side-effect of when I was still debugging other link problems, please disregard this and 1/3 as well. I'll post v2 once I've done a world build of mips/riscv. Thanks!
Align Kconfig and Kbuild logic to Linux 4.19 release with minimal impact on files outside of this scope.
Our previous Kconfig sync was done by commit 5972ff077e0f ("kconfig / kbuild: re-sync with Linux 4.18").
In this particular re-sync in order to keep clang support working a number of related changes needed to be pulled in that had been missed previously. Not all of these changes we easily traceable and so have been omitted from the list below.
The imported Linux commits are: [From prior to v4.18] 9f3f1fd29976 kbuild: Add __cc-option macro d7f14c66c273 kbuild: Enable Large File Support for hostprogs 6d79a7b424a5 kbuild: suppress warnings from 'getconf LFS_*' 24403874316a Shared library support 86a9df597cdd kbuild: fix linker feature test macros when cross compiling with Clang 0294e6f4a000 kbuild: simplify ld-option implementation
[From v4.18 to v4.19] 96f14fe738b6 kbuild: Rename HOSTCFLAGS to KBUILD_HOSTCFLAGS 10844aebf448 kbuild: Rename HOSTCXXFLAGS to KBUILD_HOSTCXXFLAGS b90a368000ab kbuild: Rename HOSTLDFLAGS to KBUILD_HOSTLDFLAGS 8377bd2b9ee1 kbuild: Rename HOST_LOADLIBES to KBUILD_HOSTLDLIBS f92d19e0ef9b kbuild: Use HOST*FLAGS options from the command line 4ab3b80159d4 kconfig: check for pkg-config on make {menu,n,g,x}config 693359f7ac90 kconfig: rename SYMBOL_AUTO to SYMBOL_NO_WRITE f60b992e30ff kbuild: replace $(LDFLAGS) $(ldflags-y) with $(ld_flags) 2fb9279f2c3e kbuild: change ld_flags to contain LDFLAGS_$(@F) c931d34ea085 arm64: build with baremetal linker target instead of Linux when available 5accd7f3360e kconfig: handle format string before calling conf_message_callback() a2ff4040151a kconfig: rename file_write_dep and move it to confdata.c 0608182ad542 kconfig: split out useful helpers in confdata.c adc18acf42a1 kconfig: remove unneeded directory generation from local*config 79123b1389cc kconfig: create directories needed for syncconfig by itself 16952b77d8b5 kconfig: make syncconfig update .config regardless of sym_change_count d6c6ab93e17f kbuild: remove deprecated host-progs variable 56869d45e364 kconfig: fix the rule of mainmenu_stmt symbol c151272d1687 kconfig: remove unused sym_get_env_prop() function 1880861226c1 kconfig: remove P_ENV property type e3fd9b5384f3 scripts/dtc: consolidate include path options in Makefile 4bf6a9af0e91 kconfig: add build-only configurator targets f1575595d156 kconfig: error out when seeing recursive dependency 5e8c5299d315 kconfig: report recursive dependency involving 'imply' f498926c47aa kconfig: improve the recursive dependency report 98a4afbfafd2 kconfig: fix "Can't open ..." in parallel build 9a9ddcf47831 kconfig: suppress "configuration written to .config" for syncconfig 87a32e624037 kbuild: pass LDFLAGS to recordmcount.pl d503ac531a52 kbuild: rename LDFLAGS to KBUILD_LDFLAGS 217c3e019675 disable stringop truncation warnings for now bc8d2e20a3eb kconfig: remove a spurious self-assignment fd65465b7016 kconfig: do not require pkg-config on make {menu,n}config 5a4630aadb9a ftrace: Build with CPPFLAGS to get -Qunused-arguments
Note that this adds new cleanup work to do in that we should adapt the shared library support we have to what is now upstream.
Cc: Masahiro Yamada masahiroy@kernel.org Signed-off-by: Tom Rini trini@konsulko.com --- Makefile | 66 ++++++-- arch/arc/config.mk | 4 +- arch/m68k/Makefile | 2 +- arch/m68k/config.mk | 2 +- arch/mips/config.mk | 8 +- arch/powerpc/config.mk | 2 +- arch/riscv/config.mk | 2 +- arch/x86/config.mk | 8 +- config.mk | 4 +- examples/standalone/Makefile | 2 +- scripts/Kbuild.include | 22 ++- scripts/Makefile.build | 15 +- scripts/Makefile.clean | 5 +- scripts/Makefile.host | 64 +++++++- scripts/Makefile.lib | 5 +- scripts/Makefile.spl | 2 +- scripts/dtc/Makefile | 18 +-- scripts/kconfig/Makefile | 36 +++-- scripts/kconfig/conf.c | 15 +- scripts/kconfig/confdata.c | 147 ++++++++++++++---- scripts/kconfig/expr.h | 3 +- scripts/kconfig/gconf-cfg.sh | 7 + scripts/kconfig/gconf.c | 4 +- scripts/kconfig/lkc.h | 2 - scripts/kconfig/lkc_proto.h | 2 +- scripts/kconfig/mconf-cfg.sh | 25 +-- scripts/kconfig/mconf.c | 10 +- scripts/kconfig/menu.c | 2 +- scripts/kconfig/nconf-cfg.sh | 25 +-- scripts/kconfig/nconf.c | 7 +- scripts/kconfig/qconf-cfg.sh | 7 + scripts/kconfig/qconf.cc | 1 - scripts/kconfig/symbol.c | 71 +++++---- .../Kconfig | 3 +- .../tests/err_recursive_dep/__init__.py | 10 ++ .../tests/err_recursive_dep/expected_stderr | 38 +++++ .../tests/warn_recursive_dep/__init__.py | 9 -- .../tests/warn_recursive_dep/expected_stderr | 30 ---- scripts/kconfig/util.c | 30 ---- scripts/kconfig/zconf.y | 6 +- tools/Makefile | 8 +- 41 files changed, 456 insertions(+), 273 deletions(-) rename scripts/kconfig/tests/{warn_recursive_dep => err_recursive_dep}/Kconfig (93%) create mode 100644 scripts/kconfig/tests/err_recursive_dep/__init__.py create mode 100644 scripts/kconfig/tests/err_recursive_dep/expected_stderr delete mode 100644 scripts/kconfig/tests/warn_recursive_dep/__init__.py delete mode 100644 scripts/kconfig/tests/warn_recursive_dep/expected_stderr
diff --git a/Makefile b/Makefile index 84ab6803c93f..3f371e38cd32 100644 --- a/Makefile +++ b/Makefile @@ -271,11 +271,17 @@ CONFIG_SHELL := $(shell if [ -x "$$BASH" ]; then echo $$BASH; \ else if [ -x /bin/bash ]; then echo /bin/bash; \ else echo sh; fi ; fi)
+HOST_LFS_CFLAGS := $(shell getconf LFS_CFLAGS 2>/dev/null) +HOST_LFS_LDFLAGS := $(shell getconf LFS_LDFLAGS 2>/dev/null) +HOST_LFS_LIBS := $(shell getconf LFS_LIBS 2>/dev/null) + HOSTCC = cc HOSTCXX = c++ -HOSTCFLAGS = -Wall -Wstrict-prototypes -O2 -fomit-frame-pointer \ - $(if $(CONFIG_TOOLS_DEBUG),-g) -HOSTCXXFLAGS = -O2 +KBUILD_HOSTCFLAGS := -Wall -Wstrict-prototypes -O2 -fomit-frame-pointer \ + $(if $(CONFIG_TOOLS_DEBUG),-g) $(HOST_LFS_CFLAGS) $(HOSTCFLAGS) +KBUILD_HOSTCXXFLAGS := -O2 $(HOST_LFS_CFLAGS) $(HOSTCXXFLAGS) +KBUILD_HOSTLDFLAGS := $(HOST_LFS_LDFLAGS) $(HOSTLDFLAGS) +KBUILD_HOSTLDLIBS := $(HOST_LFS_LIBS) $(HOSTLDLIBS)
# With the move to GCC 6, we have implicitly upgraded our language # standard to GNU11 (see https://gcc.gnu.org/gcc-5/porting_to.html). @@ -284,11 +290,11 @@ HOSTCXXFLAGS = -O2 # these that our host tools are GNU11 (i.e. C11 w/ GNU extensions). CSTD_FLAG := -std=gnu11 ifeq ($(HOSTOS),linux) -HOSTCFLAGS += $(CSTD_FLAG) +KBUILD_HOSTCFLAGS += $(CSTD_FLAG) endif
ifeq ($(HOSTOS),cygwin) -HOSTCFLAGS += -ansi +KBUILD_HOSTCFLAGS += -ansi endif
# Mac OS X / Darwin's C preprocessor is Apple specific. It @@ -315,17 +321,17 @@ os_x_after = $(shell if [ $(DARWIN_MAJOR_VERSION) -ge $(1) -a \
# Snow Leopards build environment has no longer restrictions as described above HOSTCC = $(call os_x_before, 10, 5, "cc", "gcc") -HOSTCFLAGS += $(call os_x_before, 10, 4, "-traditional-cpp") -HOSTLDFLAGS += $(call os_x_before, 10, 5, "-multiply_defined suppress") +KBUILD_HOSTCFLAGS += $(call os_x_before, 10, 4, "-traditional-cpp") +KBUILD_HOSTLDFLAGS += $(call os_x_before, 10, 5, "-multiply_defined suppress")
# since Lion (10.7) ASLR is on by default, but we use linker generated lists # in some host tools which is a problem then ... so disable ASLR for these # tools -HOSTLDFLAGS += $(call os_x_before, 10, 7, "", "-Xlinker -no_pie") +KBUILD_HOSTLDFLAGS += $(call os_x_before, 10, 7, "", "-Xlinker -no_pie")
# macOS Mojave (10.14.X) # Undefined symbols for architecture x86_64: "_PyArg_ParseTuple" -HOSTLDFLAGS += $(call os_x_after, 10, 14, "-lpython -dynamclib", "") +KBUILD_HOSTLDFLAGS += $(call os_x_after, 10, 14, "-lpython -dynamclib", "") endif
# Decide whether to build built-in, modular, or both. @@ -417,6 +423,23 @@ KBUILD_CFLAGS := -Wall -Wstrict-prototypes \ -fno-builtin -ffreestanding $(CSTD_FLAG) KBUILD_CFLAGS += -fshort-wchar -fno-strict-aliasing KBUILD_AFLAGS := -D__ASSEMBLY__ +KBUILD_LDFLAGS := + +ifeq ($(cc-name),clang) +ifneq ($(CROSS_COMPILE),) +CLANG_TARGET := --target=$(notdir $(CROSS_COMPILE:%-=%)) +GCC_TOOLCHAIN_DIR := $(dir $(shell which $(LD))) +CLANG_PREFIX := --prefix=$(GCC_TOOLCHAIN_DIR) +GCC_TOOLCHAIN := $(realpath $(GCC_TOOLCHAIN_DIR)/..) +endif +ifneq ($(GCC_TOOLCHAIN),) +CLANG_GCC_TC := --gcc-toolchain=$(GCC_TOOLCHAIN) +endif +KBUILD_CFLAGS += $(CLANG_TARGET) $(CLANG_GCC_TC) $(CLANG_PREFIX) +KBUILD_AFLAGS += $(CLANG_TARGET) $(CLANG_GCC_TC) $(CLANG_PREFIX) +KBUILD_CFLAGS += $(call cc-option, -no-integrated-as) +KBUILD_AFLAGS += $(call cc-option, -no-integrated-as) +endif
# Don't generate position independent code KBUILD_CFLAGS += $(call cc-option,-fno-PIE) @@ -428,12 +451,12 @@ UBOOTVERSION = $(VERSION)$(if $(PATCHLEVEL),.$(PATCHLEVEL)$(if $(SUBLEVEL),.$(SU
export VERSION PATCHLEVEL SUBLEVEL UBOOTRELEASE UBOOTVERSION export ARCH CPU BOARD VENDOR SOC CPUDIR BOARDDIR -export CONFIG_SHELL HOSTCC HOSTCFLAGS HOSTLDFLAGS CROSS_COMPILE AS LD CC -export CPP AR NM LDR STRIP OBJCOPY OBJDUMP +export CONFIG_SHELL HOSTCC KBUILD_HOSTCFLAGS CROSS_COMPILE AS LD CC +export CPP AR NM LDR STRIP OBJCOPY OBJDUMP KBUILD_HOSTLDFLAGS KBUILD_HOSTLDLIBS export MAKE LEX YACC AWK PERL PYTHON PYTHON2 PYTHON3 -export HOSTCXX HOSTCXXFLAGS CHECK CHECKFLAGS DTC DTC_FLAGS +export HOSTCXX KBUILD_HOSTCXXFLAGS CHECK CHECKFLAGS DTC DTC_FLAGS
-export KBUILD_CPPFLAGS NOSTDINC_FLAGS UBOOTINCLUDE OBJCOPYFLAGS LDFLAGS +export KBUILD_CPPFLAGS NOSTDINC_FLAGS UBOOTINCLUDE OBJCOPYFLAGS KBUILD_LDFLAGS export KBUILD_CFLAGS KBUILD_AFLAGS
export CC_VERSION_TEXT := $(shell $(CC) --version | head -n 1) @@ -656,6 +679,9 @@ endif KBUILD_CFLAGS += $(call cc-option,-fno-stack-protector) KBUILD_CFLAGS += $(call cc-option,-fno-delete-null-pointer-checks)
+# disable stringop warnings in gcc 8+ +KBUILD_CFLAGS += $(call cc-disable-warning, stringop-truncation) + # change __FILE__ to the relative path from the srctree KBUILD_CFLAGS += $(call cc-option,-fmacro-prefix-map=$(srctree)/=)
@@ -680,7 +706,19 @@ ifeq ($(cc-name),clang) KBUILD_CPPFLAGS += $(call cc-option,-Qunused-arguments,) KBUILD_CFLAGS += $(call cc-disable-warning, format-invalid-specifier) KBUILD_CFLAGS += $(call cc-disable-warning, gnu) +KBUILD_CFLAGS += $(call cc-disable-warning, address-of-packed-member) +# Quiet clang warning: comparison of unsigned expression < 0 is always false +KBUILD_CFLAGS += $(call cc-disable-warning, tautological-compare) +# CLANG uses a _MergedGlobals as optimization, but this breaks modpost, as the +# source of a reference will be _MergedGlobals and not on of the whitelisted names. +# See modpost pattern 2 +KBUILD_CFLAGS += $(call cc-option, -mno-global-merge,) KBUILD_CFLAGS += $(call cc-option, -fcatch-undefined-behavior) +else + +# These warnings generated too much noise in a regular build. +# Use make W=1 to enable them (see scripts/Makefile.extrawarn) +KBUILD_CFLAGS += $(call cc-disable-warning, unused-but-set-variable) endif
# turn jbsr into jsr for m68k @@ -1691,7 +1729,7 @@ ARCH_POSTLINK := $(wildcard $(srctree)/arch/$(ARCH)/Makefile.postlink) # Rule to link u-boot # May be overridden by arch/$(ARCH)/config.mk quiet_cmd_u-boot__ ?= LD $@ - cmd_u-boot__ ?= $(LD) $(LDFLAGS) $(LDFLAGS_u-boot) -o $@ \ + cmd_u-boot__ ?= $(LD) $(KBUILD_LDFLAGS) $(LDFLAGS_u-boot) -o $@ \ -T u-boot.lds $(u-boot-init) \ --start-group $(u-boot-main) --end-group \ $(PLATFORM_LIBS) -Map u-boot.map; \ diff --git a/arch/arc/config.mk b/arch/arc/config.mk index 6fa29adae81f..118472b2d0ba 100644 --- a/arch/arc/config.mk +++ b/arch/arc/config.mk @@ -9,12 +9,12 @@ CONFIG_SYS_BIG_ENDIAN = 1 endif
ifdef CONFIG_SYS_LITTLE_ENDIAN -PLATFORM_LDFLAGS += -EL +KBUILD_LDFLAGS += -EL PLATFORM_CPPFLAGS += -mlittle-endian endif
ifdef CONFIG_SYS_BIG_ENDIAN -PLATFORM_LDFLAGS += -EB +KBUILD_LDFLAGS += -EB PLATFORM_CPPFLAGS += -mbig-endian endif
diff --git a/arch/m68k/Makefile b/arch/m68k/Makefile index d36d9f063199..7f23ff45887a 100644 --- a/arch/m68k/Makefile +++ b/arch/m68k/Makefile @@ -30,6 +30,6 @@ ldflags-$(CONFIG_MCF547x_8x) := --got=single
ifneq (,$(findstring -linux-,$(shell $(CC) --version))) ifneq (,$(findstring GOT,$(shell $(LD) --help))) -PLATFORM_LDFLAGS += $(ldflags-y) +KBUILD_LDFLAGS += $(ldflags-y) endif endif diff --git a/arch/m68k/config.mk b/arch/m68k/config.mk index a27a5245fe89..88b1a409f260 100644 --- a/arch/m68k/config.mk +++ b/arch/m68k/config.mk @@ -10,7 +10,7 @@ endif CONFIG_STANDALONE_LOAD_ADDR ?= 0x20000
PLATFORM_CPPFLAGS += -D__M68K__ -PLATFORM_LDFLAGS += -n +KBUILD_LDFLAGS += -n PLATFORM_RELFLAGS += -ffunction-sections -fdata-sections PLATFORM_RELFLAGS += -ffixed-d7 -msep-data LDFLAGS_FINAL += --gc-sections diff --git a/arch/mips/config.mk b/arch/mips/config.mk index f8180dcd396c..a9d75eae61cc 100644 --- a/arch/mips/config.mk +++ b/arch/mips/config.mk @@ -9,7 +9,7 @@ ldflags-$(CONFIG_64BIT) += -m elf64btsmip 32bit-bfd := elf32-tradbigmips 64bit-bfd := elf64-tradbigmips PLATFORM_CPPFLAGS += -EB -PLATFORM_LDFLAGS += -EB +KBUILD_LDFLAGS += -EB endif
ifdef CONFIG_SYS_LITTLE_ENDIAN @@ -18,7 +18,7 @@ ldflags-$(CONFIG_64BIT) += -m elf64btsmip 32bit-bfd := elf32-tradlittlemips 64bit-bfd := elf64-tradlittlemips PLATFORM_CPPFLAGS += -EL -PLATFORM_LDFLAGS += -EL +KBUILD_LDFLAGS += -EL endif
ifdef CONFIG_32BIT @@ -33,7 +33,7 @@ OBJCOPYFLAGS += -O $(64bit-bfd) CONFIG_STANDALONE_LOAD_ADDR ?= 0xffffffff80200000 endif
PLATFORM_CPPFLAGS += -D__MIPS__ PLATFORM_ELFENTRY = "__start" @@ -63,7 +63,7 @@ endif
PLATFORM_CPPFLAGS += -G 0 -mno-abicalls -fno-pic PLATFORM_CPPFLAGS += -msoft-float -PLATFORM_LDFLAGS += -G 0 -static -n -nostdlib +KBUILD_LDFLAGS += -G 0 -static -n -nostdlib PLATFORM_RELFLAGS += -ffunction-sections -fdata-sections LDFLAGS_FINAL += --gc-sections OBJCOPYFLAGS += -j .text -j .rodata -j .data -j .u_boot_list diff --git a/arch/powerpc/config.mk b/arch/powerpc/config.mk index f5d21c837a47..88e2c58cb44a 100644 --- a/arch/powerpc/config.mk +++ b/arch/powerpc/config.mk @@ -15,7 +15,7 @@ PLATFORM_RELFLAGS += -fpic -mrelocatable -ffunction-sections \
PF_CPPFLAGS_POWERPC := $(call cc-option,-fno-ira-hoist-pressure,) PLATFORM_CPPFLAGS += -D__powerpc__ -ffixed-r2 -m32 $(PF_CPPFLAGS_POWERPC) -PLATFORM_LDFLAGS += -m32 -melf32ppclinux +KBUILD_LDFLAGS += -m32 -melf32ppclinux
# # When cross-compiling on NetBSD, we have to define __PPC__ or else we diff --git a/arch/riscv/config.mk b/arch/riscv/config.mk index df91a85f677f..1c0f14a8dada 100644 --- a/arch/riscv/config.mk +++ b/arch/riscv/config.mk @@ -27,7 +27,7 @@ PLATFORM_CPPFLAGS += -ffixed-gp -fpic PLATFORM_RELFLAGS += -fno-common -gdwarf-2 -ffunction-sections \ -fdata-sections LDFLAGS_u-boot += --gc-sections -static -pie -PLATFORM_LDFLAGS += $(ldflags-y) +KBUILD_LDFLAGS += $(ldflags-y)
EFI_CRT0 := crt0_riscv_efi.o EFI_RELOC := reloc_riscv_efi.o diff --git a/arch/x86/config.mk b/arch/x86/config.mk index b5e8f4629791..27d8412661ff 100644 --- a/arch/x86/config.mk +++ b/arch/x86/config.mk @@ -29,11 +29,11 @@ endif
PLATFORM_RELFLAGS += -fdata-sections -ffunction-sections -fvisibility=hidden
-PLATFORM_LDFLAGS += -Bsymbolic -Bsymbolic-functions -PLATFORM_LDFLAGS += -m $(if $(IS_32BIT),elf_i386,elf_x86_64) +KBUILD_LDFLAGS += -Bsymbolic -Bsymbolic-functions +KBUILD_LDFLAGS += -m $(if $(IS_32BIT),elf_i386,elf_x86_64)
# This is used in the top-level Makefile which does not include -# PLATFORM_LDFLAGS +# KBUILD_LDFLAGS LDFLAGS_EFI_PAYLOAD := -Bsymbolic -Bsymbolic-functions -shared --no-undefined -s
OBJCOPYFLAGS_EFI := -j .text -j .sdata -j .data -j .dynamic -j .dynsym \ @@ -71,7 +71,7 @@ LDSCRIPT := $(LDSCRIPT_EFI) else
PLATFORM_CPPFLAGS += $(CFLAGS_NON_EFI) -PLATFORM_LDFLAGS += --emit-relocs +KBUILD_LDFLAGS += --emit-relocs LDFLAGS_FINAL += --gc-sections $(if $(CONFIG_SPL_BUILD),,-pie)
endif diff --git a/config.mk b/config.mk index caf0dd9b8182..097d1f67d24e 100644 --- a/config.mk +++ b/config.mk @@ -12,8 +12,7 @@ # If we did not have Tegra SoCs, build system would be much simpler...) PLATFORM_RELFLAGS := PLATFORM_CPPFLAGS := -PLATFORM_LDFLAGS := -LDFLAGS := +KBUILD_LDFLAGS := LDFLAGS_FINAL := LDFLAGS_STANDALONE := OBJCOPYFLAGS := @@ -70,7 +69,6 @@ RELFLAGS := $(PLATFORM_RELFLAGS) PLATFORM_CPPFLAGS += $(RELFLAGS) PLATFORM_CPPFLAGS += -pipe
-LDFLAGS += $(PLATFORM_LDFLAGS) LDFLAGS_FINAL += -Bstatic
export PLATFORM_CPPFLAGS diff --git a/examples/standalone/Makefile b/examples/standalone/Makefile index 0b17a91804cf..779e2528b77e 100644 --- a/examples/standalone/Makefile +++ b/examples/standalone/Makefile @@ -55,7 +55,7 @@ $(LIB): $(LIBOBJS) FORCE $(call if_changed,link_lib)
quiet_cmd_link_elf = LD $@ - cmd_link_elf = $(LD) $(LDFLAGS) $(LDFLAGS_STANDALONE) -g \ + cmd_link_elf = $(LD) $(KBUILD_LDFLAGS) $(LDFLAGS_STANDALONE) -g \ -o $@ -e $(SYM_PREFIX)$(@F) $< $(LIB) $(PLATFORM_LIBGCC)
$(ELF): $(obj)/%: $(obj)/%.o $(LIB) FORCE diff --git a/scripts/Kbuild.include b/scripts/Kbuild.include index c7ad18777787..cad3b6e76c62 100644 --- a/scripts/Kbuild.include +++ b/scripts/Kbuild.include @@ -109,11 +109,20 @@ as-option = $(call try-run,\ as-instr = $(call try-run,\ printf "%b\n" "$(1)" | $(CC) $(KBUILD_AFLAGS) -c -x assembler -o "$$TMP" -,$(2),$(3))
+# __cc-option +# Usage: MY_CFLAGS += $(call __cc-option,$(CC),$(MY_CFLAGS),-march=winchip-c6,-march=i586) +__cc-option = $(call try-run,\ + $(1) -Werror $(2) $(3) -c -x c /dev/null -o "$$TMP",$(3),$(4)) + # cc-option # Usage: cflags-y += $(call cc-option,-march=winchip-c6,-march=i586) +cc-option = $(call __cc-option, $(CC),\ + $(KBUILD_CPPFLAGS) $(KBUILD_CFLAGS),$(1),$(2))
-cc-option = $(call try-run,\ - $(CC) -Werror $(KBUILD_CPPFLAGS) $(KBUILD_CFLAGS) $(1) -c -x c /dev/null -o "$$TMP",$(1),$(2)) +# hostcc-option +# Usage: cflags-y += $(call hostcc-option,-march=winchip-c6,-march=i586) +hostcc-option = $(call __cc-option, $(HOSTCC),\ + $(HOSTCFLAGS) $(HOST_EXTRACFLAGS),$(1),$(2))
# cc-option-yn # Usage: flag := $(call cc-option-yn,-march=winchip-c6) @@ -123,7 +132,7 @@ cc-option-yn = $(call try-run,\ # cc-disable-warning # Usage: cflags-y += $(call cc-disable-warning,unused-but-set-variable) cc-disable-warning = $(call try-run,\ - $(CC) $(KBUILD_CPPFLAGS) $(KBUILD_CFLAGS) -W$(strip $(1)) -c -x c /dev/null -o "$$TMP",-Wno-$(strip $(1))) + $(CC) -Werror $(KBUILD_CPPFLAGS) $(KBUILD_CFLAGS) -W$(strip $(1)) -c -x c /dev/null -o "$$TMP",-Wno-$(strip $(1)))
# cc-name # Expands to either gcc or clang @@ -146,12 +155,11 @@ binutils-version = $(shell $(CONFIG_SHELL) $(srctree)/scripts/binutils-version.s # cc-ldoption # Usage: ldflags += $(call cc-ldoption, -Wl$(comma)--hash-style=both) cc-ldoption = $(call try-run,\ - $(CC) $(1) -nostdlib -x c /dev/null -o "$$TMP",$(1),$(2)) + $(CC) $(1) $(KBUILD_CPPFLAGS) $(CC_OPTION_CFLAGS) -nostdlib -x c /dev/null -o "$$TMP",$(1),$(2))
# ld-option -# Usage: LDFLAGS += $(call ld-option, -X) -ld-option = $(call try-run,\ - $(CC) -x c /dev/null -c -o "$$TMPO" ; $(LD) $(1) "$$TMPO" -o "$$TMP",$(1),$(2)) +# Usage: KBUILD_LDFLAGS += $(call ld-option, -X, -Y) +ld-option = $(call try-run, $(LD) $(KBUILD_LDFLAGS) $(1) -v,$(1),$(2),$(3))
# ar-option # Usage: KBUILD_ARFLAGS := $(call ar-option,D) diff --git a/scripts/Makefile.build b/scripts/Makefile.build index f8362fbd89d9..5e5f1682c902 100644 --- a/scripts/Makefile.build +++ b/scripts/Makefile.build @@ -70,15 +70,8 @@ endif
include scripts/Makefile.lib
-ifdef host-progs -ifneq ($(hostprogs-y),$(host-progs)) -$(warning kbuild: $(obj)/Makefile - Usage of host-progs is deprecated. Please replace with hostprogs-y!) -hostprogs-y += $(host-progs) -endif -endif - # Do not include host rules unless needed -ifneq ($(hostprogs-y)$(hostprogs-m),) +ifneq ($(hostprogs-y)$(hostprogs-m)$(hostlibs-y)$(hostlibs-m)$(hostcxxlibs-y)$(hostcxxlibs-m),) include scripts/Makefile.host endif
@@ -221,7 +214,7 @@ cmd_modversions = \ $(call cmd_gensymtypes,$(KBUILD_SYMTYPES),$(@:.o=.symtypes)) \ > $(@D)/.tmp_$(@F:.o=.ver); \ \ - $(LD) $(LDFLAGS) -r -o $@ $(@D)/.tmp_$(@F) \ + $(LD) $(KBUILD_LDFLAGS) -r -o $@ $(@D)/.tmp_$(@F) \ -T $(@D)/.tmp_$(@F:.o=.ver); \ rm -f $(@D)/.tmp_$(@F) $(@D)/.tmp_$(@F:.o=.ver); \ else \ @@ -253,8 +246,8 @@ else sub_cmd_record_mcount = set -e ; perl $(srctree)/scripts/recordmcount.pl "$(ARCH)" \ "$(if $(CONFIG_CPU_BIG_ENDIAN),big,little)" \ "$(if $(CONFIG_64BIT),64,32)" \ - "$(OBJDUMP)" "$(OBJCOPY)" "$(CC) $(KBUILD_CFLAGS)" \ - "$(LD)" "$(NM)" "$(RM)" "$(MV)" \ + "$(OBJDUMP)" "$(OBJCOPY)" "$(CC) $(KBUILD_CPPFLAGS) $(KBUILD_CFLAGS)" \ + "$(LD) $(KBUILD_LDFLAGS)" "$(NM)" "$(RM)" "$(MV)" \ "$(if $(part-of-module),1,0)" "$(@)"; recordmcount_source := $(srctree)/scripts/recordmcount.pl endif diff --git a/scripts/Makefile.clean b/scripts/Makefile.clean index 8fe9e05a14a9..d5922e915def 100644 --- a/scripts/Makefile.clean +++ b/scripts/Makefile.clean @@ -43,8 +43,9 @@ subdir-ymn := $(foreach f, $(subdir-ymn), \
__clean-files := $(extra-y) $(extra-m) $(extra-) \ $(always) $(targets) $(clean-files) \ - $(host-progs) \ - $(hostprogs-y) $(hostprogs-m) $(hostprogs-) + $(hostprogs-y) $(hostprogs-m) $(hostprogs-) \ + $(hostlibs-y) $(hostlibs-m) $(hostlibs-) \ + $(hostcxxlibs-y) $(hostcxxlibs-m)
__clean-files := $(filter-out $(no-clean-files), $(__clean-files))
diff --git a/scripts/Makefile.host b/scripts/Makefile.host index e3379a3c51a1..da2f4d5bfd37 100644 --- a/scripts/Makefile.host +++ b/scripts/Makefile.host @@ -22,6 +22,8 @@ # They are linked as C++ code to the executable qconf
__hostprogs := $(sort $(hostprogs-y) $(hostprogs-m)) +host-cshlib := $(sort $(hostlibs-y) $(hostlibs-m)) +host-cxxshlib := $(sort $(hostcxxlibs-y) $(hostcxxlibs-m))
# C code # Executables compiled from a single .c file @@ -47,6 +49,10 @@ host-cxxmulti := $(foreach m,$(__hostprogs),$(if $($(m)-cxxobjs),$(m))) # C++ Object (.o) files compiled from .cc files host-cxxobjs := $(sort $(foreach m,$(host-cxxmulti),$($(m)-cxxobjs)))
+# Object (.o) files used by the shared libaries +host-cshobjs := $(sort $(foreach m,$(host-cshlib),$($(m:.so=-objs)))) +host-cxxshobjs := $(sort $(foreach m,$(host-cxxshlib),$($(m:.so=-objs)))) + # output directory for programs/.o files # hostprogs-y := tools/build may have been specified. # Retrieve also directory of .o files from prog-objs or prog-cxxobjs notation @@ -61,6 +67,10 @@ host-cmulti := $(addprefix $(obj)/,$(host-cmulti)) host-cobjs := $(addprefix $(obj)/,$(host-cobjs)) host-cxxmulti := $(addprefix $(obj)/,$(host-cxxmulti)) host-cxxobjs := $(addprefix $(obj)/,$(host-cxxobjs)) +host-cshlib := $(addprefix $(obj)/,$(host-cshlib)) +host-cxxshlib := $(addprefix $(obj)/,$(host-cxxshlib)) +host-cshobjs := $(addprefix $(obj)/,$(host-cshobjs)) +host-cxxshobjs := $(addprefix $(obj)/,$(host-cxxshobjs)) host-shared := $(addprefix $(obj)/,$(host-shared)) host-objdirs := $(addprefix $(obj)/,$(host-objdirs))
@@ -69,9 +79,9 @@ obj-dirs += $(host-objdirs) ##### # Handle options to gcc. Support building with separate output directory
-_hostc_flags = $(HOSTCFLAGS) $(HOST_EXTRACFLAGS) \ +_hostc_flags = $(KBUILD_HOSTCFLAGS) $(HOST_EXTRACFLAGS) \ $(HOSTCFLAGS_$(basetarget).o) -_hostcxx_flags = $(HOSTCXXFLAGS) $(HOST_EXTRACXXFLAGS) \ +_hostcxx_flags = $(KBUILD_HOSTCXXFLAGS) $(HOST_EXTRACXXFLAGS) \ $(HOSTCXXFLAGS_$(basetarget).o)
ifeq ($(KBUILD_SRC),) @@ -92,16 +102,16 @@ hostcxx_flags = -Wp,-MD,$(depfile) $(__hostcxx_flags) # host-csingle -> Executable quiet_cmd_host-csingle = HOSTCC $@ cmd_host-csingle = $(HOSTCC) $(hostc_flags) -o $@ $< \ - $(HOST_LOADLIBES) $(HOSTLOADLIBES_$(@F)) + $(KBUILD_HOSTLDLIBS) $(HOSTLDLIBS_$(@F)) $(host-csingle): $(obj)/%: $(src)/%.c FORCE $(call if_changed_dep,host-csingle)
# Link an executable based on list of .o files, all plain c # host-cmulti -> executable quiet_cmd_host-cmulti = HOSTLD $@ - cmd_host-cmulti = $(HOSTCC) $(HOSTLDFLAGS) -o $@ \ + cmd_host-cmulti = $(HOSTCC) $(KBUILD_HOSTLDFLAGS) -o $@ \ $(addprefix $(obj)/,$($(@F)-objs)) \ - $(HOST_LOADLIBES) $(HOSTLOADLIBES_$(@F)) + $(KBUILD_HOSTLDLIBS) $(HOSTLDLIBS_$(@F)) $(host-cmulti): FORCE $(call if_changed,host-cmulti) $(call multi_depend, $(host-cmulti), , -objs) @@ -116,10 +126,10 @@ $(host-cobjs): $(obj)/%.o: $(src)/%.c FORCE # Link an executable based on list of .o files, a mixture of .c and .cc # host-cxxmulti -> executable quiet_cmd_host-cxxmulti = HOSTLD $@ - cmd_host-cxxmulti = $(HOSTCXX) $(HOSTLDFLAGS) -o $@ \ + cmd_host-cxxmulti = $(HOSTCXX) $(KBUILD_HOSTLDFLAGS) -o $@ \ $(foreach o,objs cxxobjs,\ $(addprefix $(obj)/,$($(@F)-$(o)))) \ - $(HOST_LOADLIBES) $(HOSTLOADLIBES_$(@F)) + $(KBUILD_HOSTLDLIBS) $(HOSTLDLIBS_$(@F)) $(host-cxxmulti): FORCE $(call if_changed,host-cxxmulti) $(call multi_depend, $(host-cxxmulti), , -objs -cxxobjs) @@ -130,5 +140,43 @@ quiet_cmd_host-cxxobjs = HOSTCXX $@ $(host-cxxobjs): $(obj)/%.o: $(src)/%.cc FORCE $(call if_changed_dep,host-cxxobjs)
+# Compile .c file, create position independent .o file +# host-cshobjs -> .o +quiet_cmd_host-cshobjs = HOSTCC -fPIC $@ + cmd_host-cshobjs = $(HOSTCC) $(hostc_flags) -fPIC -c -o $@ $< +$(host-cshobjs): $(obj)/%.o: $(src)/%.c FORCE + $(call if_changed_dep,host-cshobjs) + +# Compile .c file, create position independent .o file +# Note that plugin capable gcc versions can be either C or C++ based +# therefore plugin source files have to be compilable in both C and C++ mode. +# This is why a C++ compiler is invoked on a .c file. +# host-cxxshobjs -> .o +quiet_cmd_host-cxxshobjs = HOSTCXX -fPIC $@ + cmd_host-cxxshobjs = $(HOSTCXX) $(hostcxx_flags) -fPIC -c -o $@ $< +$(host-cxxshobjs): $(obj)/%.o: $(src)/%.c FORCE + $(call if_changed_dep,host-cxxshobjs) + +# Link a shared library, based on position independent .o files +# *.o -> .so shared library (host-cshlib) +quiet_cmd_host-cshlib = HOSTLLD -shared $@ + cmd_host-cshlib = $(HOSTCC) $(HOSTLDFLAGS) -shared -o $@ \ + $(addprefix $(obj)/,$($(@F:.so=-objs))) \ + $(HOST_LOADLIBES) $(HOSTLDLIBS_$(@F)) +$(host-cshlib): FORCE + $(call if_changed,host-cshlib) +$(call multi_depend, $(host-cshlib), .so, -objs) + +# Link a shared library, based on position independent .o files +# *.o -> .so shared library (host-cxxshlib) +quiet_cmd_host-cxxshlib = HOSTLLD -shared $@ + cmd_host-cxxshlib = $(HOSTCXX) $(HOSTLDFLAGS) -shared -o $@ \ + $(addprefix $(obj)/,$($(@F:.so=-objs))) \ + $(HOST_LOADLIBES) $(HOSTLDLIBS_$(@F)) +$(host-cxxshlib): FORCE + $(call if_changed,host-cxxshlib) +$(call multi_depend, $(host-cxxshlib), .so, -objs) + targets += $(host-csingle) $(host-cmulti) $(host-cobjs)\ - $(host-cxxmulti) $(host-cxxobjs) $(host-shared) + $(host-cxxmulti) $(host-cxxobjs) $(host-shared) \ + $(host-cshlib) $(host-cshobjs) $(host-cxxshlib) $(host-cxxshobjs) diff --git a/scripts/Makefile.lib b/scripts/Makefile.lib index 8c77eaaa4eed..8decb0e451d4 100644 --- a/scripts/Makefile.lib +++ b/scripts/Makefile.lib @@ -161,7 +161,7 @@ a_flags = -Wp,-MD,$(depfile) $(NOSTDINC_FLAGS) $(UBOOTINCLUDE) \ cpp_flags = -Wp,-MD,$(depfile) $(NOSTDINC_FLAGS) $(UBOOTINCLUDE) \ $(__cpp_flags)
-ld_flags = $(LDFLAGS) $(ldflags-y) +ld_flags = $(KBUILD_LDFLAGS) $(ldflags-y) $(LDFLAGS_$(@F))
# Try these files in order to find the U-Boot-specific .dtsi include file u_boot_dtsi_options = $(strip $(wildcard $(dir $<)$(basename $(notdir $<))-u-boot.dtsi) \ @@ -256,8 +256,7 @@ $(obj)/%: $(src)/%_shipped # ---------------------------------------------------------------------------
quiet_cmd_ld = LD $@ -cmd_ld = $(LD) $(LDFLAGS) $(ldflags-y) $(LDFLAGS_$(@F)) \ - $(filter-out FORCE,$^) -o $@ +cmd_ld = $(LD) $(ld_flags) $(filter-out FORCE,$^) -o $@
# Objcopy # --------------------------------------------------------------------------- diff --git a/scripts/Makefile.spl b/scripts/Makefile.spl index 314b02ba07db..5384f2127830 100644 --- a/scripts/Makefile.spl +++ b/scripts/Makefile.spl @@ -407,7 +407,7 @@ $(obj)/u-boot-spl-mtk.bin: $(obj)/u-boot-spl.bin FORCE # Rule to link u-boot-spl # May be overridden by arch/$(ARCH)/config.mk quiet_cmd_u-boot-spl ?= LD $@ - cmd_u-boot-spl ?= (cd $(obj) && $(LD) $(LDFLAGS) $(LDFLAGS_$(@F)) \ + cmd_u-boot-spl ?= (cd $(obj) && $(LD) $(KBUILD_LDFLAGS) $(LDFLAGS_$(@F)) \ $(patsubst $(obj)/%,%,$(u-boot-spl-init)) --start-group \ $(patsubst $(obj)/%,%,$(u-boot-spl-main)) \ $(patsubst $(obj)/%,%,$(u-boot-spl-platdata)) \ diff --git a/scripts/dtc/Makefile b/scripts/dtc/Makefile index e999be939831..58d879dd11f5 100644 --- a/scripts/dtc/Makefile +++ b/scripts/dtc/Makefile @@ -9,21 +9,11 @@ dtc-objs := dtc.o flattree.o fstree.o data.o livetree.o treesource.o \ dtc-objs += dtc-lexer.lex.o dtc-parser.tab.o
# Source files need to get at the userspace version of libfdt_env.h to compile +HOST_EXTRACFLAGS := -I$(src)/libfdt
-HOSTCFLAGS_DTC := -I$(src) -I$(src)/libfdt - -HOSTCFLAGS_checks.o := $(HOSTCFLAGS_DTC) -HOSTCFLAGS_data.o := $(HOSTCFLAGS_DTC) -HOSTCFLAGS_dtc.o := $(HOSTCFLAGS_DTC) -HOSTCFLAGS_flattree.o := $(HOSTCFLAGS_DTC) -HOSTCFLAGS_fstree.o := $(HOSTCFLAGS_DTC) -HOSTCFLAGS_livetree.o := $(HOSTCFLAGS_DTC) -HOSTCFLAGS_srcpos.o := $(HOSTCFLAGS_DTC) -HOSTCFLAGS_treesource.o := $(HOSTCFLAGS_DTC) -HOSTCFLAGS_util.o := $(HOSTCFLAGS_DTC) - -HOSTCFLAGS_dtc-lexer.lex.o := $(HOSTCFLAGS_DTC) -HOSTCFLAGS_dtc-parser.tab.o := $(HOSTCFLAGS_DTC) +# Generated files need one more search path to include headers in source tree +HOSTCFLAGS_dtc-lexer.lex.o := -I$(src) +HOSTCFLAGS_dtc-parser.tab.o := -I$(src)
# dependencies on generated files need to be listed explicitly $(obj)/dtc-lexer.lex.o: $(obj)/dtc-parser.tab.h diff --git a/scripts/kconfig/Makefile b/scripts/kconfig/Makefile index 30b90cfde238..559bb88264c3 100644 --- a/scripts/kconfig/Makefile +++ b/scripts/kconfig/Makefile @@ -3,8 +3,8 @@ # Kernel configuration targets # These targets are used from top-level makefile
-PHONY += xconfig gconfig menuconfig config syncconfig \ - localmodconfig localyesconfig +PHONY += xconfig gconfig menuconfig config localmodconfig localyesconfig \ + build_menuconfig build_nconfig build_gconfig build_xconfig
# Added for U-Boot # Linux has defconfig files in arch/$(SRCARCH)/configs/, @@ -40,14 +40,15 @@ config: $(obj)/conf nconfig: $(obj)/nconf $< $(silent) $(Kconfig)
-# This has become an internal implementation detail and is now deprecated -# for external use. -syncconfig: $(obj)/conf - $(Q)mkdir -p include/config include/generated - $< $(silent) --$@ $(Kconfig) +build_menuconfig: $(obj)/mconf + +build_nconfig: $(obj)/nconf + +build_gconfig: $(obj)/gconf + +build_xconfig: $(obj)/qconf
localyesconfig localmodconfig: $(obj)/conf - $(Q)mkdir -p include/config include/generated $(Q)perl $(srctree)/$(src)/streamline_config.pl --$@ $(srctree) $(Kconfig) > .tmp.config $(Q)if [ -f .config ]; then \ cmp -s .tmp.config .config || \ @@ -62,8 +63,12 @@ localyesconfig localmodconfig: $(obj)/conf $(Q)rm -f .tmp.config
# These targets map 1:1 to the commandline options of 'conf' +# +# Note: +# syncconfig has become an internal implementation detail and is now +# deprecated for external use simple-targets := oldconfig allnoconfig allyesconfig allmodconfig \ - alldefconfig randconfig listnewconfig olddefconfig + alldefconfig randconfig listnewconfig olddefconfig syncconfig PHONY += $(simple-targets)
$(simple-targets): $(obj)/conf @@ -179,29 +184,30 @@ HOSTCFLAGS_zconf.tab.o := -I$(src) hostprogs-y += nconf nconf-objs := nconf.o zconf.tab.o nconf.gui.o
-HOSTLOADLIBES_nconf = $(shell . $(obj)/.nconf-cfg && echo $$libs) +HOSTLDLIBS_nconf = $(shell . $(obj)/.nconf-cfg && echo $$libs) HOSTCFLAGS_nconf.o = $(shell . $(obj)/.nconf-cfg && echo $$cflags) HOSTCFLAGS_nconf.gui.o = $(shell . $(obj)/.nconf-cfg && echo $$cflags)
-$(obj)/nconf.o: $(obj)/.nconf-cfg +$(obj)/nconf.o $(obj)/nconf.gui.o: $(obj)/.nconf-cfg
# mconf: Used for the menuconfig target based on lxdialog hostprogs-y += mconf lxdialog := checklist.o inputbox.o menubox.o textbox.o util.o yesno.o mconf-objs := mconf.o zconf.tab.o $(addprefix lxdialog/, $(lxdialog))
-HOSTLOADLIBES_mconf = $(shell . $(obj)/.mconf-cfg && echo $$libs) +HOSTLDLIBS_mconf = $(shell . $(obj)/.mconf-cfg && echo $$libs) $(foreach f, mconf.o $(lxdialog), \ $(eval HOSTCFLAGS_$f = $$(shell . $(obj)/.mconf-cfg && echo $$$$cflags)))
-$(addprefix $(obj)/, mconf.o $(lxdialog)): $(obj)/.mconf-cfg +$(obj)/mconf.o: $(obj)/.mconf-cfg +$(addprefix $(obj)/lxdialog/, $(lxdialog)): $(obj)/.mconf-cfg
# qconf: Used for the xconfig target based on Qt hostprogs-y += qconf qconf-cxxobjs := qconf.o qconf-objs := zconf.tab.o
-HOSTLOADLIBES_qconf = $(shell . $(obj)/.qconf-cfg && echo $$libs) +HOSTLDLIBS_qconf = $(shell . $(obj)/.qconf-cfg && echo $$libs) HOSTCXXFLAGS_qconf.o = $(shell . $(obj)/.qconf-cfg && echo $$cflags)
$(obj)/qconf.o: $(obj)/.qconf-cfg $(obj)/qconf.moc @@ -216,7 +222,7 @@ $(obj)/%.moc: $(src)/%.h $(obj)/.qconf-cfg hostprogs-y += gconf gconf-objs := gconf.o zconf.tab.o
-HOSTLOADLIBES_gconf = $(shell . $(obj)/.gconf-cfg && echo $$libs) +HOSTLDLIBS_gconf = $(shell . $(obj)/.gconf-cfg && echo $$libs) HOSTCFLAGS_gconf.o = $(shell . $(obj)/.gconf-cfg && echo $$cflags)
$(obj)/gconf.o: $(obj)/.gconf-cfg diff --git a/scripts/kconfig/conf.c b/scripts/kconfig/conf.c index 671ff5364497..c54ff0453c34 100644 --- a/scripts/kconfig/conf.c +++ b/scripts/kconfig/conf.c @@ -496,6 +496,7 @@ int main(int ac, char **av) int opt; const char *name, *defconfig_file = NULL /* gcc uninit */; struct stat tmpstat; + int no_conf_write = 0;
tty_stdio = isatty(0) && isatty(1);
@@ -507,6 +508,11 @@ int main(int ac, char **av) input_mode = (enum input_mode)opt; switch (opt) { case syncconfig: + /* + * syncconfig is invoked during the build stage. + * Suppress distracting "configuration written to ..." + */ + conf_set_message_callback(NULL); sync_kconfig = 1; break; case defconfig: @@ -633,13 +639,14 @@ int main(int ac, char **av) }
if (sync_kconfig) { - if (conf_get_changed()) { - name = getenv("KCONFIG_NOSILENTUPDATE"); - if (name && *name) { + name = getenv("KCONFIG_NOSILENTUPDATE"); + if (name && *name) { + if (conf_get_changed()) { fprintf(stderr, "\n*** The configuration requires explicit update.\n\n"); return 1; } + no_conf_write = 1; } }
@@ -688,7 +695,7 @@ int main(int ac, char **av) /* syncconfig is used during the build so we shall update autoconf. * All other commands are only used to generate a config. */ - if (conf_get_changed() && conf_write(NULL)) { + if (!no_conf_write && conf_write(NULL)) { fprintf(stderr, "\n*** Error during writing of the configuration.\n\n"); exit(1); } diff --git a/scripts/kconfig/confdata.c b/scripts/kconfig/confdata.c index 1abf849bf543..d587b10d7f8e 100644 --- a/scripts/kconfig/confdata.c +++ b/scripts/kconfig/confdata.c @@ -16,6 +16,64 @@
#include "lkc.h"
+/* return true if 'path' exists, false otherwise */ +static bool is_present(const char *path) +{ + struct stat st; + + return !stat(path, &st); +} + +/* return true if 'path' exists and it is a directory, false otherwise */ +static bool is_dir(const char *path) +{ + struct stat st; + + if (stat(path, &st)) + return 0; + + return S_ISDIR(st.st_mode); +} + +/* + * Create the parent directory of the given path. + * + * For example, if 'include/config/auto.conf' is given, create 'include/config'. + */ +static int make_parent_dir(const char *path) +{ + char tmp[PATH_MAX + 1]; + char *p; + + strncpy(tmp, path, sizeof(tmp)); + tmp[sizeof(tmp) - 1] = 0; + + /* Remove the base name. Just return if nothing is left */ + p = strrchr(tmp, '/'); + if (!p) + return 0; + *(p + 1) = 0; + + /* Just in case it is an absolute path */ + p = tmp; + while (*p == '/') + p++; + + while ((p = strchr(p, '/'))) { + *p = 0; + + /* skip if the directory exists */ + if (!is_dir(tmp) && mkdir(tmp, 0755)) + return -1; + + *p = '/'; + while (*p == '/') + p++; + } + + return 0; +} + struct conf_printer { void (*print_symbol)(FILE *, struct symbol *, const char *, void *); void (*print_comment)(FILE *, const char *, void *); @@ -43,16 +101,16 @@ static void conf_warning(const char *fmt, ...) conf_warnings++; }
-static void conf_default_message_callback(const char *fmt, va_list ap) +static void conf_default_message_callback(const char *s) { printf("#\n# "); - vprintf(fmt, ap); + printf("%s", s); printf("\n#\n"); }
-static void (*conf_message_callback) (const char *fmt, va_list ap) = +static void (*conf_message_callback)(const char *s) = conf_default_message_callback; -void conf_set_message_callback(void (*fn) (const char *fmt, va_list ap)) +void conf_set_message_callback(void (*fn)(const char *s)) { conf_message_callback = fn; } @@ -60,10 +118,15 @@ void conf_set_message_callback(void (*fn) (const char *fmt, va_list ap)) static void conf_message(const char *fmt, ...) { va_list ap; + char buf[4096]; + + if (!conf_message_callback) + return;
va_start(ap, fmt); - if (conf_message_callback) - conf_message_callback(fmt, ap); + + vsnprintf(buf, sizeof(buf), fmt, ap); + conf_message_callback(buf); va_end(ap); }
@@ -83,7 +146,6 @@ const char *conf_get_autoconfig_name(void)
char *conf_get_default_confname(void) { - struct stat buf; static char fullname[PATH_MAX+1]; char *env, *name;
@@ -91,7 +153,7 @@ char *conf_get_default_confname(void) env = getenv(SRCTREE); if (env) { sprintf(fullname, "%s/%s", env, name); - if (!stat(fullname, &buf)) + if (is_present(fullname)) return fullname; } return name; @@ -393,7 +455,7 @@ int conf_read(const char *name)
for_all_symbols(i, sym) { sym_calc_value(sym); - if (sym_is_choice(sym) || (sym->flags & SYMBOL_AUTO)) + if (sym_is_choice(sym) || (sym->flags & SYMBOL_NO_WRITE)) continue; if (sym_has_value(sym) && (sym->flags & SYMBOL_WRITE)) { /* check that calculated value agrees with saved value */ @@ -723,10 +785,9 @@ int conf_write(const char *name)
dirname[0] = 0; if (name && name[0]) { - struct stat st; char *slash;
- if (!stat(name, &st) && S_ISDIR(st.st_mode)) { + if (is_dir(name)) { strcpy(dirname, name); strcat(dirname, "/"); basename = conf_get_configname(); @@ -811,26 +872,59 @@ next: return 0; }
+/* write a dependency file as used by kbuild to track dependencies */ +static int conf_write_dep(const char *name) +{ + struct file *file; + FILE *out; + + if (!name) + name = ".kconfig.d"; + out = fopen("..config.tmp", "w"); + if (!out) + return 1; + fprintf(out, "deps_config := \\n"); + for (file = file_list; file; file = file->next) { + if (file->next) + fprintf(out, "\t%s \\n", file->name); + else + fprintf(out, "\t%s\n", file->name); + } + fprintf(out, "\n%s: \\n" + "\t$(deps_config)\n\n", conf_get_autoconfig_name()); + + env_write_dep(out, conf_get_autoconfig_name()); + + fprintf(out, "\n$(deps_config): ;\n"); + fclose(out); + + if (make_parent_dir(name)) + return 1; + rename("..config.tmp", name); + return 0; +} + static int conf_split_config(void) { const char *name; char path[PATH_MAX+1]; char *s, *d, c; struct symbol *sym; - struct stat sb; int res, i, fd;
name = conf_get_autoconfig_name(); conf_read_simple(name, S_DEF_AUTO); sym_calc_value(modules_sym);
+ if (make_parent_dir("include/config/foo.h")) + return 1; if (chdir("include/config")) return 1;
res = 0; for_all_symbols(i, sym) { sym_calc_value(sym); - if ((sym->flags & SYMBOL_AUTO) || !sym->name) + if ((sym->flags & SYMBOL_NO_WRITE) || !sym->name) continue; if (sym->flags & SYMBOL_WRITE) { if (sym->flags & SYMBOL_DEF_AUTO) { @@ -895,19 +989,12 @@ static int conf_split_config(void) res = 1; break; } - /* - * Create directory components, - * unless they exist already. - */ - d = path; - while ((d = strchr(d, '/'))) { - *d = 0; - if (stat(path, &sb) && mkdir(path, 0755)) { - res = 1; - goto out; - } - *d++ = '/'; + + if (make_parent_dir(path)) { + res = 1; + goto out; } + /* Try it again. */ fd = open(path, O_WRONLY | O_CREAT | O_TRUNC, 0644); if (fd == -1) { @@ -933,7 +1020,7 @@ int conf_write_autoconf(void)
sym_clear_all_valid();
- file_write_dep("include/config/auto.conf.cmd"); + conf_write_dep("include/config/auto.conf.cmd");
if (conf_split_config()) return 1; @@ -980,14 +1067,22 @@ int conf_write_autoconf(void) name = getenv("KCONFIG_AUTOHEADER"); if (!name) name = "include/generated/autoconf.h"; + if (make_parent_dir(name)) + return 1; if (rename(".tmpconfig.h", name)) return 1; + name = getenv("KCONFIG_TRISTATE"); if (!name) name = "include/config/tristate.conf"; + if (make_parent_dir(name)) + return 1; if (rename(".tmpconfig_tristate", name)) return 1; + name = conf_get_autoconfig_name(); + if (make_parent_dir(name)) + return 1; /* * This must be the last step, kbuild has a dependency on auto.conf * and this marks the successful completion of the previous steps. diff --git a/scripts/kconfig/expr.h b/scripts/kconfig/expr.h index f63b41b0dd49..7c329e179007 100644 --- a/scripts/kconfig/expr.h +++ b/scripts/kconfig/expr.h @@ -141,7 +141,7 @@ struct symbol { #define SYMBOL_OPTIONAL 0x0100 /* choice is optional - values can be 'n' */ #define SYMBOL_WRITE 0x0200 /* write symbol to file (KCONFIG_CONFIG) */ #define SYMBOL_CHANGED 0x0400 /* ? */ -#define SYMBOL_AUTO 0x1000 /* value from environment variable */ +#define SYMBOL_NO_WRITE 0x1000 /* Symbol for internal use only; it will not be written */ #define SYMBOL_CHECKED 0x2000 /* used during dependency checking */ #define SYMBOL_WARNED 0x8000 /* warning has been issued */
@@ -185,7 +185,6 @@ enum prop_type { P_SELECT, /* select BAR */ P_IMPLY, /* imply BAR */ P_RANGE, /* range 7..100 (for a symbol) */ - P_ENV, /* value from environment variable */ P_SYMBOL, /* where a symbol is defined */ };
diff --git a/scripts/kconfig/gconf-cfg.sh b/scripts/kconfig/gconf-cfg.sh index 533b3d8f8f08..480ecd8b9f41 100755 --- a/scripts/kconfig/gconf-cfg.sh +++ b/scripts/kconfig/gconf-cfg.sh @@ -3,6 +3,13 @@
PKG="gtk+-2.0 gmodule-2.0 libglade-2.0"
+if [ -z "$(command -v pkg-config)" ]; then + echo >&2 "*" + echo >&2 "* 'make gconfig' requires 'pkg-config'. Please install it." + echo >&2 "*" + exit 1 +fi + if ! pkg-config --exists $PKG; then echo >&2 "*" echo >&2 "* Unable to find the GTK+ installation. Please make sure that" diff --git a/scripts/kconfig/gconf.c b/scripts/kconfig/gconf.c index 610c4ab54d76..a9e48cc7b50a 100644 --- a/scripts/kconfig/gconf.c +++ b/scripts/kconfig/gconf.c @@ -101,8 +101,8 @@ const char *dbg_sym_flags(int val) strcat(buf, "write/"); if (val & SYMBOL_CHANGED) strcat(buf, "changed/"); - if (val & SYMBOL_AUTO) - strcat(buf, "auto/"); + if (val & SYMBOL_NO_WRITE) + strcat(buf, "no_write/");
buf[strlen(buf) - 1] = '\0';
diff --git a/scripts/kconfig/lkc.h b/scripts/kconfig/lkc.h index ed3ff88e60ba..9eb7c837cd8f 100644 --- a/scripts/kconfig/lkc.h +++ b/scripts/kconfig/lkc.h @@ -97,7 +97,6 @@ void menu_set_type(int type);
/* util.c */ struct file *file_lookup(const char *name); -int file_write_dep(const char *name); void *xmalloc(size_t size); void *xcalloc(size_t nmemb, size_t size); void *xrealloc(void *p, size_t size); @@ -126,7 +125,6 @@ const char *sym_get_string_default(struct symbol *sym); struct symbol *sym_check_deps(struct symbol *sym); struct property *prop_alloc(enum prop_type type, struct symbol *sym); struct symbol *prop_get_symbol(struct property *prop); -struct property *sym_get_env_prop(struct symbol *sym);
static inline tristate sym_get_tristate_value(struct symbol *sym) { diff --git a/scripts/kconfig/lkc_proto.h b/scripts/kconfig/lkc_proto.h index a8b7a330587e..cf4510a2bdc7 100644 --- a/scripts/kconfig/lkc_proto.h +++ b/scripts/kconfig/lkc_proto.h @@ -10,7 +10,7 @@ int conf_write(const char *name); int conf_write_autoconf(void); bool conf_get_changed(void); void conf_set_changed_callback(void (*fn)(void)); -void conf_set_message_callback(void (*fn)(const char *fmt, va_list ap)); +void conf_set_message_callback(void (*fn)(const char *s));
/* menu.c */ extern struct menu rootmenu; diff --git a/scripts/kconfig/mconf-cfg.sh b/scripts/kconfig/mconf-cfg.sh index e6f9facd0077..c812872d7f9d 100755 --- a/scripts/kconfig/mconf-cfg.sh +++ b/scripts/kconfig/mconf-cfg.sh @@ -4,20 +4,23 @@ PKG="ncursesw" PKG2="ncurses"
-if pkg-config --exists $PKG; then - echo cflags="$(pkg-config --cflags $PKG)" - echo libs="$(pkg-config --libs $PKG)" - exit 0 -fi +if [ -n "$(command -v pkg-config)" ]; then + if pkg-config --exists $PKG; then + echo cflags="$(pkg-config --cflags $PKG)" + echo libs="$(pkg-config --libs $PKG)" + exit 0 + fi
-if pkg-config --exists $PKG2; then - echo cflags="$(pkg-config --cflags $PKG2)" - echo libs="$(pkg-config --libs $PKG2)" - exit 0 + if pkg-config --exists $PKG2; then + echo cflags="$(pkg-config --cflags $PKG2)" + echo libs="$(pkg-config --libs $PKG2)" + exit 0 + fi fi
-# Unfortunately, some distributions (e.g. openSUSE) cannot find ncurses -# by pkg-config. +# Check the default paths in case pkg-config is not installed. +# (Even if it is installed, some distributions such as openSUSE cannot +# find ncurses by pkg-config.) if [ -f /usr/include/ncursesw/ncurses.h ]; then echo cflags="-D_GNU_SOURCE -I/usr/include/ncursesw" echo libs="-lncursesw" diff --git a/scripts/kconfig/mconf.c b/scripts/kconfig/mconf.c index 5294ed159b98..c1b38747c147 100644 --- a/scripts/kconfig/mconf.c +++ b/scripts/kconfig/mconf.c @@ -490,7 +490,6 @@ static void build_conf(struct menu *menu) switch (prop->type) { case P_MENU: child_count++; - prompt = prompt; if (single_menu_mode) { item_make("%s%*c%s", menu->data ? "-->" : "++>", @@ -772,16 +771,13 @@ static void show_helptext(const char *title, const char *text) show_textbox(title, text, 0, 0); }
-static void conf_message_callback(const char *fmt, va_list ap) +static void conf_message_callback(const char *s) { - char buf[PATH_MAX+1]; - - vsnprintf(buf, sizeof(buf), fmt, ap); if (save_and_exit) { if (!silent) - printf("%s", buf); + printf("%s", s); } else { - show_textbox(NULL, buf, 6, 60); + show_textbox(NULL, s, 6, 60); } }
diff --git a/scripts/kconfig/menu.c b/scripts/kconfig/menu.c index 379a119dcd1e..4cf15d449c05 100644 --- a/scripts/kconfig/menu.c +++ b/scripts/kconfig/menu.c @@ -212,7 +212,7 @@ void menu_add_option(int token, char *arg) sym_defconfig_list = current_entry->sym; else if (sym_defconfig_list != current_entry->sym) zconf_error("trying to redefine defconfig symbol"); - sym_defconfig_list->flags |= SYMBOL_AUTO; + sym_defconfig_list->flags |= SYMBOL_NO_WRITE; break; case T_OPT_ALLNOCONFIG_Y: current_entry->sym->flags |= SYMBOL_ALLNOCONFIG_Y; diff --git a/scripts/kconfig/nconf-cfg.sh b/scripts/kconfig/nconf-cfg.sh index 42f5ac73548e..001559ef0a60 100644 --- a/scripts/kconfig/nconf-cfg.sh +++ b/scripts/kconfig/nconf-cfg.sh @@ -4,20 +4,23 @@ PKG="ncursesw menuw panelw" PKG2="ncurses menu panel"
-# Unfortunately, some distributions (e.g. openSUSE) cannot find ncurses -# by pkg-config. +# Check the default paths in case pkg-config is not installed. +# (Even if it is installed, some distributions such as openSUSE cannot +# find ncurses by pkg-config.) if [ -f /usr/include/ncursesw/ncurses.h ]; then echo cflags="-D_GNU_SOURCE -I/usr/include/ncursesw" echo libs="-lncursesw -lmenuw -lpanelw" diff --git a/scripts/kconfig/nconf.c b/scripts/kconfig/nconf.c index 97b78445584b..5cbdb92e11b3 100644 --- a/scripts/kconfig/nconf.c +++ b/scripts/kconfig/nconf.c @@ -1210,12 +1210,9 @@ static void conf(struct menu *menu) } }
-static void conf_message_callback(const char *fmt, va_list ap) +static void conf_message_callback(const char *s) { - char buf[1024]; - - vsnprintf(buf, sizeof(buf), fmt, ap); - btn_dialog(main_window, buf, 1, "<OK>"); + btn_dialog(main_window, s, 1, "<OK>"); }
static void show_help(struct menu *menu) diff --git a/scripts/kconfig/qconf-cfg.sh b/scripts/kconfig/qconf-cfg.sh index 0862e1562536..02ccc0ae1031 100755 --- a/scripts/kconfig/qconf-cfg.sh +++ b/scripts/kconfig/qconf-cfg.sh @@ -4,6 +4,13 @@ PKG="Qt5Core Qt5Gui Qt5Widgets" PKG2="QtCore QtGui"
+if [ -z "$(command -v pkg-config)" ]; then + echo >&2 "*" + echo >&2 "* 'make xconfig' requires 'pkg-config'. Please install it." + echo >&2 "*" + exit 1 +fi + if pkg-config --exists $PKG; then echo cflags="-std=c++11 -fPIC $(pkg-config --cflags Qt5Core Qt5Gui Qt5Widgets)" echo libs="$(pkg-config --libs $PKG)" diff --git a/scripts/kconfig/qconf.cc b/scripts/kconfig/qconf.cc index ad9c22dd04f5..0c3fa9405684 100644 --- a/scripts/kconfig/qconf.cc +++ b/scripts/kconfig/qconf.cc @@ -1149,7 +1149,6 @@ QString ConfigInfoView::debug_info(struct symbol *sym) case P_DEFAULT: case P_SELECT: case P_RANGE: - case P_ENV: debug += prop_get_type_name(prop->type); debug += ": "; expr_print(prop->expr, expr_print_help, &debug, E_NONE); diff --git a/scripts/kconfig/symbol.c b/scripts/kconfig/symbol.c index 7c9a88e91cfa..703b9b899ee9 100644 --- a/scripts/kconfig/symbol.c +++ b/scripts/kconfig/symbol.c @@ -76,15 +76,6 @@ struct property *sym_get_choice_prop(struct symbol *sym) return NULL; }
-struct property *sym_get_env_prop(struct symbol *sym) -{ - struct property *prop; - - for_all_properties(sym, prop, P_ENV) - return prop; - return NULL; -} - static struct property *sym_get_default_prop(struct symbol *sym) { struct property *prop; @@ -463,7 +454,7 @@ void sym_calc_value(struct symbol *sym) } }
- if (sym->flags & SYMBOL_AUTO) + if (sym->flags & SYMBOL_NO_WRITE) sym->flags &= ~SYMBOL_WRITE;
if (sym->flags & SYMBOL_NEED_SET_CHOICE_VALUES) @@ -1020,7 +1011,7 @@ static struct dep_stack { struct dep_stack *prev, *next; struct symbol *sym; struct property *prop; - struct expr *expr; + struct expr **expr; } *check_top;
static void dep_stack_insert(struct dep_stack *stack, struct symbol *sym) @@ -1085,31 +1076,42 @@ static void sym_check_print_recursive(struct symbol *last_sym) fprintf(stderr, "%s:%d:error: recursive dependency detected!\n", prop->file->name, prop->lineno);
- if (stack->expr) { - fprintf(stderr, "%s:%d:\tsymbol %s %s value contains %s\n", - prop->file->name, prop->lineno, + if (sym_is_choice(sym)) { + fprintf(stderr, "%s:%d:\tchoice %s contains symbol %s\n", + menu->file->name, menu->lineno, + sym->name ? sym->name : "<choice>", + next_sym->name ? next_sym->name : "<choice>"); + } else if (sym_is_choice_value(sym)) { + fprintf(stderr, "%s:%d:\tsymbol %s is part of choice %s\n", + menu->file->name, menu->lineno, sym->name ? sym->name : "<choice>", - prop_get_type_name(prop->type), next_sym->name ? next_sym->name : "<choice>"); - } else if (stack->prop) { + } else if (stack->expr == &sym->dir_dep.expr) { fprintf(stderr, "%s:%d:\tsymbol %s depends on %s\n", prop->file->name, prop->lineno, sym->name ? sym->name : "<choice>", next_sym->name ? next_sym->name : "<choice>"); - } else if (sym_is_choice(sym)) { - fprintf(stderr, "%s:%d:\tchoice %s contains symbol %s\n", - menu->file->name, menu->lineno, + } else if (stack->expr == &sym->rev_dep.expr) { + fprintf(stderr, "%s:%d:\tsymbol %s is selected by %s\n", + prop->file->name, prop->lineno, sym->name ? sym->name : "<choice>", next_sym->name ? next_sym->name : "<choice>"); - } else if (sym_is_choice_value(sym)) { - fprintf(stderr, "%s:%d:\tsymbol %s is part of choice %s\n", - menu->file->name, menu->lineno, + } else if (stack->expr == &sym->implied.expr) { + fprintf(stderr, "%s:%d:\tsymbol %s is implied by %s\n", + prop->file->name, prop->lineno, sym->name ? sym->name : "<choice>", next_sym->name ? next_sym->name : "<choice>"); + } else if (stack->expr) { + fprintf(stderr, "%s:%d:\tsymbol %s %s value contains %s\n", + prop->file->name, prop->lineno, + sym->name ? sym->name : "<choice>", + prop_get_type_name(prop->type), + next_sym->name ? next_sym->name : "<choice>"); } else { - fprintf(stderr, "%s:%d:\tsymbol %s is selected by %s\n", + fprintf(stderr, "%s:%d:\tsymbol %s %s is visible depending on %s\n", prop->file->name, prop->lineno, sym->name ? sym->name : "<choice>", + prop_get_type_name(prop->type), next_sym->name ? next_sym->name : "<choice>"); } } @@ -1166,12 +1168,26 @@ static struct symbol *sym_check_sym_deps(struct symbol *sym)
dep_stack_insert(&stack, sym);
+ stack.expr = &sym->dir_dep.expr; + sym2 = sym_check_expr_deps(sym->dir_dep.expr); + if (sym2) + goto out; + + stack.expr = &sym->rev_dep.expr; sym2 = sym_check_expr_deps(sym->rev_dep.expr); if (sym2) goto out;
+ stack.expr = &sym->implied.expr; + sym2 = sym_check_expr_deps(sym->implied.expr); + if (sym2) + goto out; + + stack.expr = NULL; + for (prop = sym->prop; prop; prop = prop->next) { - if (prop->type == P_CHOICE || prop->type == P_SELECT) + if (prop->type == P_CHOICE || prop->type == P_SELECT || + prop->type == P_IMPLY) continue; stack.prop = prop; sym2 = sym_check_expr_deps(prop->visible.expr); @@ -1179,7 +1195,7 @@ static struct symbol *sym_check_sym_deps(struct symbol *sym) break; if (prop->type != P_DEFAULT || sym_is_choice(sym)) continue; - stack.expr = prop->expr; + stack.expr = &prop->expr; sym2 = sym_check_expr_deps(prop->expr); if (sym2) break; @@ -1257,9 +1273,6 @@ struct symbol *sym_check_deps(struct symbol *sym) sym->flags &= ~SYMBOL_CHECK; }
- if (sym2 && sym2 == sym) - sym2 = NULL; - return sym2; }
@@ -1298,8 +1311,6 @@ const char *prop_get_type_name(enum prop_type type) switch (type) { case P_PROMPT: return "prompt"; - case P_ENV: - return "env"; case P_COMMENT: return "comment"; case P_MENU: diff --git a/scripts/kconfig/tests/warn_recursive_dep/Kconfig b/scripts/kconfig/tests/err_recursive_dep/Kconfig similarity index 93% rename from scripts/kconfig/tests/warn_recursive_dep/Kconfig rename to scripts/kconfig/tests/err_recursive_dep/Kconfig index a65bfcb7137e..ebdb3ffd8717 100644 --- a/scripts/kconfig/tests/warn_recursive_dep/Kconfig +++ b/scripts/kconfig/tests/err_recursive_dep/Kconfig @@ -1,3 +1,5 @@ +# SPDX-License-Identifier: GPL-2.0 + # depends on itself
config A @@ -31,7 +33,6 @@ config D2 bool
# depends on and imply -# This is not recursive dependency
config E1 bool "E1" diff --git a/scripts/kconfig/tests/err_recursive_dep/__init__.py b/scripts/kconfig/tests/err_recursive_dep/__init__.py new file mode 100644 index 000000000000..5f3821b43ce6 --- /dev/null +++ b/scripts/kconfig/tests/err_recursive_dep/__init__.py @@ -0,0 +1,10 @@ +# SPDX-License-Identifier: GPL-2.0 +""" +Detect recursive dependency error. + +Recursive dependency should be treated as an error. +""" + +def test(conf): + assert conf.oldaskconfig() == 1 + assert conf.stderr_contains('expected_stderr') diff --git a/scripts/kconfig/tests/err_recursive_dep/expected_stderr b/scripts/kconfig/tests/err_recursive_dep/expected_stderr new file mode 100644 index 000000000000..84679b104655 --- /dev/null +++ b/scripts/kconfig/tests/err_recursive_dep/expected_stderr @@ -0,0 +1,38 @@ +Kconfig:11:error: recursive dependency detected! +Kconfig:11: symbol B is selected by B +For a resolution refer to Documentation/kbuild/kconfig-language.txt +subsection "Kconfig recursive dependency limitations" + +Kconfig:5:error: recursive dependency detected! +Kconfig:5: symbol A depends on A +For a resolution refer to Documentation/kbuild/kconfig-language.txt +subsection "Kconfig recursive dependency limitations" + +Kconfig:17:error: recursive dependency detected! +Kconfig:17: symbol C1 depends on C2 +Kconfig:21: symbol C2 depends on C1 +For a resolution refer to Documentation/kbuild/kconfig-language.txt +subsection "Kconfig recursive dependency limitations" + +Kconfig:32:error: recursive dependency detected! +Kconfig:32: symbol D2 is selected by D1 +Kconfig:27: symbol D1 depends on D2 +For a resolution refer to Documentation/kbuild/kconfig-language.txt +subsection "Kconfig recursive dependency limitations" + +Kconfig:37:error: recursive dependency detected! +Kconfig:37: symbol E1 depends on E2 +Kconfig:42: symbol E2 is implied by E1 +For a resolution refer to Documentation/kbuild/kconfig-language.txt +subsection "Kconfig recursive dependency limitations" + +Kconfig:60:error: recursive dependency detected! +Kconfig:60: symbol G depends on G +For a resolution refer to Documentation/kbuild/kconfig-language.txt +subsection "Kconfig recursive dependency limitations" + +Kconfig:51:error: recursive dependency detected! +Kconfig:51: symbol F2 depends on F1 +Kconfig:49: symbol F1 default value contains F2 +For a resolution refer to Documentation/kbuild/kconfig-language.txt +subsection "Kconfig recursive dependency limitations" diff --git a/scripts/kconfig/tests/warn_recursive_dep/__init__.py b/scripts/kconfig/tests/warn_recursive_dep/__init__.py deleted file mode 100644 index adb21951ba41..000000000000 --- a/scripts/kconfig/tests/warn_recursive_dep/__init__.py +++ /dev/null @@ -1,9 +0,0 @@ -""" -Warn recursive inclusion. - -Recursive dependency should be warned. -""" - -def test(conf): - assert conf.oldaskconfig() == 0 - assert conf.stderr_contains('expected_stderr') diff --git a/scripts/kconfig/tests/warn_recursive_dep/expected_stderr b/scripts/kconfig/tests/warn_recursive_dep/expected_stderr deleted file mode 100644 index 3de807dd9cb2..000000000000 --- a/scripts/kconfig/tests/warn_recursive_dep/expected_stderr +++ /dev/null @@ -1,30 +0,0 @@ -Kconfig:9:error: recursive dependency detected! -Kconfig:9: symbol B is selected by B -For a resolution refer to Documentation/kbuild/kconfig-language.txt -subsection "Kconfig recursive dependency limitations" - -Kconfig:3:error: recursive dependency detected! -Kconfig:3: symbol A depends on A -For a resolution refer to Documentation/kbuild/kconfig-language.txt -subsection "Kconfig recursive dependency limitations" - -Kconfig:15:error: recursive dependency detected! -Kconfig:15: symbol C1 depends on C2 -Kconfig:19: symbol C2 depends on C1 -For a resolution refer to Documentation/kbuild/kconfig-language.txt -subsection "Kconfig recursive dependency limitations" - -Kconfig:30:error: recursive dependency detected! -Kconfig:30: symbol D2 is selected by D1 -Kconfig:25: symbol D1 depends on D2 -For a resolution refer to Documentation/kbuild/kconfig-language.txt -subsection "Kconfig recursive dependency limitations" - -Kconfig:59:error: recursive dependency detected! -Kconfig:59: symbol G depends on G -For a resolution refer to Documentation/kbuild/kconfig-language.txt -subsection "Kconfig recursive dependency limitations" - -Kconfig:50:error: recursive dependency detected! -Kconfig:50: symbol F2 depends on F1 -Kconfig:48: symbol F1 default value contains F2 diff --git a/scripts/kconfig/util.c b/scripts/kconfig/util.c index a365594770d9..d999683bb2a7 100644 --- a/scripts/kconfig/util.c +++ b/scripts/kconfig/util.c @@ -29,36 +29,6 @@ struct file *file_lookup(const char *name) return file; }
-/* write a dependency file as used by kbuild to track dependencies */ -int file_write_dep(const char *name) -{ - struct file *file; - FILE *out; - - if (!name) - name = ".kconfig.d"; - out = fopen("..config.tmp", "w"); - if (!out) - return 1; - fprintf(out, "deps_config := \\n"); - for (file = file_list; file; file = file->next) { - if (file->next) - fprintf(out, "\t%s \\n", file->name); - else - fprintf(out, "\t%s\n", file->name); - } - fprintf(out, "\n%s: \\n" - "\t$(deps_config)\n\n", conf_get_autoconfig_name()); - - env_write_dep(out, conf_get_autoconfig_name()); - - fprintf(out, "\n$(deps_config): ;\n"); - fclose(out); - rename("..config.tmp", name); - return 0; -} - - /* Allocate initial growable string */ struct gstr str_new(void) { diff --git a/scripts/kconfig/zconf.y b/scripts/kconfig/zconf.y index 4b68272ebdb9..22fceb264cf5 100644 --- a/scripts/kconfig/zconf.y +++ b/scripts/kconfig/zconf.y @@ -31,7 +31,7 @@ struct symbol *symbol_hash[SYMBOL_HASHSIZE]; static struct menu *current_menu, *current_entry;
%} -%expect 31 +%expect 30
%union { @@ -117,7 +117,7 @@ start: mainmenu_stmt stmt_list | stmt_list;
/* mainmenu entry */
-mainmenu_stmt: T_MAINMENU prompt nl +mainmenu_stmt: T_MAINMENU prompt T_EOL { menu_add_prompt(P_MENU, $2, NULL); }; @@ -265,7 +265,7 @@ symbol_option_arg: choice: T_CHOICE word_opt T_EOL { struct symbol *sym = sym_lookup($2, SYMBOL_CHOICE); - sym->flags |= SYMBOL_AUTO; + sym->flags |= SYMBOL_NO_WRITE; menu_add_entry(sym); menu_add_expr(P_CHOICE, NULL, NULL); free($2); diff --git a/tools/Makefile b/tools/Makefile index 3b9ae90369a8..c2b26340047a 100644 --- a/tools/Makefile +++ b/tools/Makefile @@ -161,7 +161,7 @@ endif ifneq ($(CONFIG_MX23)$(CONFIG_MX28)$(CONFIG_ARMADA_38X)$(CONFIG_ARMADA_39X)$(CONFIG_FIT_SIGNATURE),) HOSTCFLAGS_kwbimage.o += \ $(shell pkg-config --cflags libssl libcrypto 2> /dev/null || echo "") -HOSTLOADLIBES_mkimage += \ +HOSTLDLIBS_mkimage += \ $(shell pkg-config --libs libssl libcrypto 2> /dev/null || echo "-lssl -lcrypto")
# OS X deprecate openssl in favour of CommonCrypto, supress deprecation @@ -175,9 +175,9 @@ endif
HOSTCFLAGS_fit_image.o += -DMKIMAGE_DTC="$(CONFIG_MKIMAGE_DTC_PATH)"
-HOSTLOADLIBES_dumpimage := $(HOSTLOADLIBES_mkimage) -HOSTLOADLIBES_fit_info := $(HOSTLOADLIBES_mkimage) -HOSTLOADLIBES_fit_check_sign := $(HOSTLOADLIBES_mkimage) +HOSTLDLIBS_dumpimage := $(HOSTLDLIBS_mkimage) +HOSTLDLIBS_fit_info := $(HOSTLDLIBS_mkimage) +HOSTLDLIBS_fit_check_sign := $(HOSTLDLIBS_mkimage)
hostprogs-$(CONFIG_EXYNOS5250) += mkexynosspl hostprogs-$(CONFIG_EXYNOS5420) += mkexynosspl
Daniel Schwierzeck
