[U-Boot] [PATCH 00/11] Move some init sequence options to Kconfig
This series moves three common CONFIG options to Kconfig. They are somewhat tricky and I've had a hard time figuring out good Kconfig defaults, particularly for CONFIG_BOARD_EARLY_INIT_F. Hopefully the board maintainers can improve things.
It is build-tested and I've also checked it with 'buildman -sK. The only config changes are:
draco etamin pxm2 rastaban rut thuban : + u-boot-spl.cfg: CONFIG_ARCH_MISC_INIT=1 + all: CONFIG_ARCH_MISC_INIT=1
and this is due to this option being defined in SPL (i.e. harmless).
A few patches are included to tidy up some other things I noticed along the way.
Simon Glass (11): configs: Resync with savedefconfig config: Drop CONFIG_ARCH_DMA_PIO_WORDS Convert CONFIG_ARCH_EARLY_INIT_R to Kconfig Convert CONFIG_BOARD_EARLY_INIT_F to Kconfig Convert CONFIG_ARCH_MISC_INIT to Kconfig powerpc: Drop probecpu() in favour of arch_cpu_init() powerpc: Drop CONFIG_SYS_ALLOC_DPRAM Drop CONFIG_WINBOND_83C553 Drop the static inline print_cpuinfo() Drop prt_mpc5xxx_clks() in favour of print_cpuinfo() Drop CONFIG_CMD_DOC
arch/Kconfig | 2 + arch/arc/include/asm/config.h | 1 - arch/arm/Kconfig | 35 ++++ arch/arm/cpu/armv7/mx6/Kconfig | 4 + arch/arm/cpu/armv8/fsl-layerscape/Kconfig | 8 + arch/arm/include/asm/imx-common/dma.h | 7 +- arch/arm/mach-at91/Kconfig | 18 ++ arch/arm/mach-exynos/Kconfig | 3 + arch/arm/mach-mvebu/Kconfig | 2 + arch/arm/mach-tegra/Kconfig | 1 + arch/blackfin/include/asm/config.h | 2 - arch/powerpc/cpu/mpc5xxx/speed.c | 2 +- arch/powerpc/cpu/mpc8260/spi.c | 7 - arch/powerpc/cpu/mpc83xx/Kconfig | 6 + arch/powerpc/cpu/mpc85xx/Kconfig | 2 + arch/powerpc/cpu/mpc86xx/Kconfig | 2 + arch/powerpc/cpu/mpc8xx/Makefile | 1 - arch/powerpc/cpu/mpc8xx/commproc.c | 69 ------- arch/powerpc/cpu/mpc8xx/fec.c | 10 +- arch/powerpc/cpu/mpc8xx/i2c.c | 10 - arch/powerpc/cpu/mpc8xx/scc.c | 10 +- arch/powerpc/cpu/mpc8xx/serial.c | 17 +- arch/powerpc/cpu/mpc8xx/spi.c | 7 - arch/powerpc/cpu/mpc8xxx/cpu.c | 2 +- arch/powerpc/include/asm/global_data.h | 2 +- board/Arcturus/ucp1020/spl.c | 2 +- board/freescale/b4860qds/spl.c | 2 +- board/freescale/c29xpcie/spl.c | 2 +- board/freescale/p1010rdb/spl.c | 2 +- board/freescale/p1022ds/spl.c | 2 +- board/freescale/p1_p2_rdb_pc/spl.c | 2 +- board/freescale/t102xqds/spl.c | 2 +- board/freescale/t102xrdb/spl.c | 2 +- board/freescale/t104xrdb/spl.c | 2 +- board/freescale/t208xqds/spl.c | 2 +- board/freescale/t208xrdb/spl.c | 2 +- board/freescale/t4qds/spl.c | 2 +- board/freescale/t4rdb/spl.c | 2 +- board/mpl/common/common_util.c | 9 - board/mpl/common/common_util.h | 3 - common/Kconfig | 33 +++- common/board_f.c | 14 +- common/board_r.c | 27 --- configs/B4420QDS_NAND_defconfig | 2 +- configs/B4420QDS_SPIFLASH_defconfig | 2 +- configs/B4420QDS_defconfig | 2 +- configs/B4860QDS_NAND_defconfig | 2 +- configs/B4860QDS_SPIFLASH_defconfig | 2 +- configs/B4860QDS_SRIO_PCIE_BOOT_defconfig | 2 +- configs/B4860QDS_defconfig | 2 +- configs/BSC9131RDB_NAND_SYSCLK100_defconfig | 2 +- configs/BSC9131RDB_NAND_defconfig | 2 +- configs/BSC9131RDB_SPIFLASH_SYSCLK100_defconfig | 2 +- configs/BSC9131RDB_SPIFLASH_defconfig | 2 +- configs/C29XPCIE_NAND_defconfig | 2 +- configs/C29XPCIE_SPIFLASH_defconfig | 2 +- configs/C29XPCIE_defconfig | 2 +- configs/CHIP_defconfig | 2 +- configs/CPCI2DP_defconfig | 3 +- configs/CPCI4052_defconfig | 3 +- configs/Cyrus_P5020_defconfig | 1 + configs/Cyrus_P5040_defconfig | 1 + configs/MIP405T_defconfig | 3 +- configs/MIP405_defconfig | 3 +- configs/MPC8313ERDB_33_defconfig | 2 +- configs/MPC8313ERDB_66_defconfig | 2 +- configs/MPC8313ERDB_NAND_33_defconfig | 2 +- configs/MPC8313ERDB_NAND_66_defconfig | 2 +- configs/MPC8315ERDB_defconfig | 2 +- configs/MPC8323ERDB_defconfig | 2 +- configs/MPC832XEMDS_ATM_defconfig | 2 +- configs/MPC832XEMDS_HOST_33_defconfig | 2 +- configs/MPC832XEMDS_HOST_66_defconfig | 2 +- configs/MPC832XEMDS_SLAVE_defconfig | 2 +- configs/MPC832XEMDS_defconfig | 2 +- configs/MPC8349EMDS_defconfig | 2 +- configs/MPC8349ITXGP_defconfig | 2 +- configs/MPC8349ITX_LOWBOOT_defconfig | 2 +- configs/MPC8349ITX_defconfig | 2 +- configs/MPC8536DS_36BIT_defconfig | 1 + configs/MPC8536DS_SDCARD_defconfig | 1 + configs/MPC8536DS_SPIFLASH_defconfig | 1 + configs/MPC8536DS_defconfig | 1 + configs/MPC8540ADS_defconfig | 2 +- configs/MPC8541CDS_defconfig | 2 +- configs/MPC8541CDS_legacy_defconfig | 2 +- configs/MPC8544DS_defconfig | 2 +- configs/MPC8548CDS_36BIT_defconfig | 2 +- configs/MPC8548CDS_defconfig | 2 +- configs/MPC8548CDS_legacy_defconfig | 2 +- configs/MPC8555CDS_defconfig | 2 +- configs/MPC8555CDS_legacy_defconfig | 2 +- configs/MPC8560ADS_defconfig | 2 +- configs/MPC8568MDS_defconfig | 3 +- configs/MPC8569MDS_ATM_defconfig | 1 + configs/MPC8569MDS_defconfig | 1 + configs/MPC8572DS_36BIT_defconfig | 2 +- configs/MPC8572DS_defconfig | 2 +- configs/MPC8610HPCD_defconfig | 2 +- configs/MPC8641HPCN_36BIT_defconfig | 2 +- configs/MPC8641HPCN_defconfig | 2 +- configs/MiniFAP_defconfig | 2 +- configs/Nintendo_NES_Classic_Edition_defconfig | 2 +- configs/O2D300_defconfig | 2 +- configs/O2DNT2_RAMBOOT_defconfig | 2 +- configs/O2DNT2_defconfig | 2 +- configs/O2D_defconfig | 2 +- configs/O2I_defconfig | 2 +- configs/O2MNT_O2M110_defconfig | 2 +- configs/O2MNT_O2M112_defconfig | 2 +- configs/O2MNT_O2M113_defconfig | 2 +- configs/O2MNT_defconfig | 2 +- configs/O3DNT_defconfig | 2 +- configs/P1010RDB-PA_36BIT_NAND_SECBOOT_defconfig | 1 + configs/P1010RDB-PA_36BIT_NAND_defconfig | 1 + configs/P1010RDB-PA_36BIT_NOR_SECBOOT_defconfig | 1 + configs/P1010RDB-PA_36BIT_NOR_defconfig | 1 + configs/P1010RDB-PA_36BIT_SDCARD_defconfig | 1 + .../P1010RDB-PA_36BIT_SPIFLASH_SECBOOT_defconfig | 1 + configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig | 1 + configs/P1010RDB-PA_NAND_SECBOOT_defconfig | 1 + configs/P1010RDB-PA_NAND_defconfig | 1 + configs/P1010RDB-PA_NOR_SECBOOT_defconfig | 1 + configs/P1010RDB-PA_NOR_defconfig | 1 + configs/P1010RDB-PA_SDCARD_defconfig | 1 + configs/P1010RDB-PA_SPIFLASH_SECBOOT_defconfig | 1 + configs/P1010RDB-PA_SPIFLASH_defconfig | 1 + configs/P1010RDB-PB_36BIT_NAND_SECBOOT_defconfig | 1 + configs/P1010RDB-PB_36BIT_NAND_defconfig | 1 + configs/P1010RDB-PB_36BIT_NOR_SECBOOT_defconfig | 1 + configs/P1010RDB-PB_36BIT_NOR_defconfig | 1 + configs/P1010RDB-PB_36BIT_SDCARD_defconfig | 1 + .../P1010RDB-PB_36BIT_SPIFLASH_SECBOOT_defconfig | 1 + configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig | 1 + configs/P1010RDB-PB_NAND_SECBOOT_defconfig | 1 + configs/P1010RDB-PB_NAND_defconfig | 1 + configs/P1010RDB-PB_NOR_SECBOOT_defconfig | 1 + configs/P1010RDB-PB_NOR_defconfig | 1 + configs/P1010RDB-PB_SDCARD_defconfig | 1 + configs/P1010RDB-PB_SPIFLASH_SECBOOT_defconfig | 1 + configs/P1010RDB-PB_SPIFLASH_defconfig | 1 + configs/P1020MBG-PC_36BIT_SDCARD_defconfig | 1 + configs/P1020MBG-PC_36BIT_defconfig | 1 + configs/P1020MBG-PC_SDCARD_defconfig | 1 + configs/P1020MBG-PC_defconfig | 1 + configs/P1020RDB-PC_36BIT_NAND_defconfig | 1 + configs/P1020RDB-PC_36BIT_SDCARD_defconfig | 1 + configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig | 1 + configs/P1020RDB-PC_36BIT_defconfig | 1 + configs/P1020RDB-PC_NAND_defconfig | 1 + configs/P1020RDB-PC_SDCARD_defconfig | 1 + configs/P1020RDB-PC_SPIFLASH_defconfig | 1 + configs/P1020RDB-PC_defconfig | 1 + configs/P1020RDB-PD_NAND_defconfig | 1 + configs/P1020RDB-PD_SDCARD_defconfig | 1 + configs/P1020RDB-PD_SPIFLASH_defconfig | 1 + configs/P1020RDB-PD_defconfig | 1 + configs/P1020UTM-PC_36BIT_SDCARD_defconfig | 1 + configs/P1020UTM-PC_36BIT_defconfig | 1 + configs/P1020UTM-PC_SDCARD_defconfig | 1 + configs/P1020UTM-PC_defconfig | 1 + configs/P1021RDB-PC_36BIT_NAND_defconfig | 1 + configs/P1021RDB-PC_36BIT_SDCARD_defconfig | 1 + configs/P1021RDB-PC_36BIT_SPIFLASH_defconfig | 1 + configs/P1021RDB-PC_36BIT_defconfig | 1 + configs/P1021RDB-PC_NAND_defconfig | 1 + configs/P1021RDB-PC_SDCARD_defconfig | 1 + configs/P1021RDB-PC_SPIFLASH_defconfig | 1 + configs/P1021RDB-PC_defconfig | 1 + configs/P1022DS_36BIT_NAND_defconfig | 1 + configs/P1022DS_36BIT_SDCARD_defconfig | 1 + configs/P1022DS_36BIT_SPIFLASH_defconfig | 1 + configs/P1022DS_36BIT_defconfig | 1 + configs/P1022DS_NAND_defconfig | 1 + configs/P1022DS_SDCARD_defconfig | 1 + configs/P1022DS_SPIFLASH_defconfig | 1 + configs/P1022DS_defconfig | 1 + configs/P1023RDB_defconfig | 3 +- configs/P1024RDB_36BIT_defconfig | 1 + configs/P1024RDB_NAND_defconfig | 1 + configs/P1024RDB_SDCARD_defconfig | 1 + configs/P1024RDB_SPIFLASH_defconfig | 1 + configs/P1024RDB_defconfig | 1 + configs/P1025RDB_36BIT_defconfig | 1 + configs/P1025RDB_NAND_defconfig | 1 + configs/P1025RDB_SDCARD_defconfig | 1 + configs/P1025RDB_SPIFLASH_defconfig | 1 + configs/P1025RDB_defconfig | 1 + configs/P2020RDB-PC_36BIT_NAND_defconfig | 1 + configs/P2020RDB-PC_36BIT_SDCARD_defconfig | 1 + configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig | 1 + configs/P2020RDB-PC_36BIT_defconfig | 1 + configs/P2020RDB-PC_NAND_defconfig | 1 + configs/P2020RDB-PC_SDCARD_defconfig | 1 + configs/P2020RDB-PC_SPIFLASH_defconfig | 1 + configs/P2020RDB-PC_defconfig | 1 + configs/P2041RDB_NAND_defconfig | 1 + configs/P2041RDB_SDCARD_defconfig | 1 + configs/P2041RDB_SECURE_BOOT_defconfig | 1 + configs/P2041RDB_SPIFLASH_defconfig | 1 + configs/P2041RDB_SRIO_PCIE_BOOT_defconfig | 1 + configs/P2041RDB_defconfig | 1 + configs/P3041DS_NAND_SECURE_BOOT_defconfig | 1 + configs/P3041DS_NAND_defconfig | 1 + configs/P3041DS_SDCARD_defconfig | 1 + configs/P3041DS_SECURE_BOOT_defconfig | 1 + configs/P3041DS_SPIFLASH_defconfig | 1 + configs/P3041DS_SRIO_PCIE_BOOT_defconfig | 1 + configs/P3041DS_defconfig | 1 + configs/P4080DS_SDCARD_defconfig | 1 + configs/P4080DS_SECURE_BOOT_defconfig | 1 + configs/P4080DS_SPIFLASH_defconfig | 1 + configs/P4080DS_SRIO_PCIE_BOOT_defconfig | 1 + configs/P4080DS_defconfig | 1 + configs/P5020DS_NAND_SECURE_BOOT_defconfig | 1 + configs/P5020DS_NAND_defconfig | 1 + configs/P5020DS_SDCARD_defconfig | 1 + configs/P5020DS_SECURE_BOOT_defconfig | 1 + configs/P5020DS_SPIFLASH_defconfig | 1 + configs/P5020DS_SRIO_PCIE_BOOT_defconfig | 1 + configs/P5020DS_defconfig | 1 + configs/P5040DS_NAND_SECURE_BOOT_defconfig | 1 + configs/P5040DS_NAND_defconfig | 1 + configs/P5040DS_SDCARD_defconfig | 1 + configs/P5040DS_SECURE_BOOT_defconfig | 1 + configs/P5040DS_SPIFLASH_defconfig | 1 + configs/P5040DS_defconfig | 1 + configs/PATI_defconfig | 3 +- configs/PIP405_defconfig | 3 +- configs/PLU405_defconfig | 3 +- configs/PMC405DE_defconfig | 3 +- configs/PMC440_defconfig | 3 +- configs/T1024QDS_DDR4_SECURE_BOOT_defconfig | 1 + configs/T1024QDS_DDR4_defconfig | 1 + configs/T1024QDS_NAND_defconfig | 1 + configs/T1024QDS_SDCARD_defconfig | 1 + configs/T1024QDS_SECURE_BOOT_defconfig | 1 + configs/T1024QDS_SPIFLASH_defconfig | 1 + configs/T1024QDS_defconfig | 1 + configs/T1024RDB_NAND_defconfig | 1 + configs/T1024RDB_SDCARD_defconfig | 1 + configs/T1024RDB_SECURE_BOOT_defconfig | 1 + configs/T1024RDB_SPIFLASH_defconfig | 1 + configs/T1024RDB_defconfig | 1 + configs/T1040D4RDB_NAND_defconfig | 1 + configs/T1040D4RDB_SDCARD_defconfig | 1 + configs/T1040D4RDB_SECURE_BOOT_defconfig | 1 + configs/T1040D4RDB_SPIFLASH_defconfig | 1 + configs/T1040D4RDB_defconfig | 1 + configs/T1040QDS_DDR4_defconfig | 1 + configs/T1040QDS_SECURE_BOOT_defconfig | 1 + configs/T1040QDS_defconfig | 1 + configs/T1040RDB_NAND_defconfig | 1 + configs/T1040RDB_SDCARD_defconfig | 1 + configs/T1040RDB_SECURE_BOOT_defconfig | 1 + configs/T1040RDB_SPIFLASH_defconfig | 1 + configs/T1040RDB_defconfig | 1 + configs/T1042D4RDB_NAND_defconfig | 1 + configs/T1042D4RDB_SDCARD_defconfig | 1 + configs/T1042D4RDB_SECURE_BOOT_defconfig | 1 + configs/T1042D4RDB_SPIFLASH_defconfig | 1 + configs/T1042D4RDB_defconfig | 1 + configs/T1042RDB_PI_NAND_SECURE_BOOT_defconfig | 1 + configs/T1042RDB_PI_NAND_defconfig | 1 + configs/T1042RDB_PI_SDCARD_defconfig | 1 + configs/T1042RDB_PI_SPIFLASH_defconfig | 1 + configs/T1042RDB_PI_defconfig | 1 + configs/T1042RDB_SECURE_BOOT_defconfig | 1 + configs/T1042RDB_defconfig | 1 + configs/TQM5200S_HIGHBOOT_defconfig | 2 +- configs/TQM5200S_defconfig | 2 +- configs/TQM5200_B_HIGHBOOT_defconfig | 2 +- configs/TQM5200_B_defconfig | 2 +- configs/TQM5200_STK100_defconfig | 2 +- configs/TQM5200_defconfig | 2 +- configs/TQM823L_LCD_defconfig | 2 +- configs/TQM823L_defconfig | 2 +- configs/TQM823M_defconfig | 2 +- configs/TQM834x_defconfig | 2 +- configs/TQM850L_defconfig | 2 +- configs/TQM850M_defconfig | 2 +- configs/TQM855L_defconfig | 2 +- configs/TQM855M_defconfig | 2 +- configs/TQM860L_defconfig | 2 +- configs/TQM860M_defconfig | 2 +- configs/TQM862L_defconfig | 2 +- configs/TQM862M_defconfig | 2 +- configs/TQM866M_defconfig | 2 +- configs/TQM885D_defconfig | 2 +- configs/TTTech_defconfig | 2 +- configs/TWR-P1025_defconfig | 1 + configs/UCP1020_SPIFLASH_defconfig | 1 + configs/UCP1020_defconfig | 1 + configs/VOM405_defconfig | 3 +- configs/a3m071_defconfig | 2 +- configs/a4m072_defconfig | 2 +- configs/a4m2k_defconfig | 2 +- configs/ac14xx_defconfig | 2 +- configs/acadia_defconfig | 3 +- configs/adp-ag101p_defconfig | 2 +- configs/am335x_baltos_defconfig | 1 + configs/am335x_boneblack_defconfig | 1 + configs/am335x_boneblack_vboot_defconfig | 1 + configs/am335x_evm_defconfig | 1 + configs/am335x_evm_nor_defconfig | 1 + configs/am335x_evm_norboot_defconfig | 2 + configs/am335x_evm_spiboot_defconfig | 1 + configs/am335x_evm_usbspl_defconfig | 1 + configs/am43xx_evm_qspiboot_defconfig | 1 + configs/am57xx_evm_defconfig | 1 + configs/am57xx_evm_nodt_defconfig | 1 + configs/am57xx_hs_evm_defconfig | 1 + configs/ap121_defconfig | 1 + configs/ap143_defconfig | 1 + configs/apalis_imx6_defconfig | 1 + configs/apalis_imx6_nospl_com_defconfig | 1 + configs/apalis_imx6_nospl_it_defconfig | 1 + configs/apalis_t30_defconfig | 1 + configs/apx4devkit_defconfig | 2 + configs/arches_defconfig | 3 +- configs/aria_defconfig | 2 +- configs/aristainetos2_defconfig | 1 + configs/aristainetos2b_defconfig | 1 + configs/aristainetos_defconfig | 1 + configs/armadillo-800eva_defconfig | 2 +- configs/aspenite_defconfig | 3 +- configs/at91rm9200ek_defconfig | 3 +- configs/at91rm9200ek_ram_defconfig | 3 +- configs/at91sam9260ek_dataflash_cs0_defconfig | 2 +- configs/at91sam9260ek_dataflash_cs1_defconfig | 2 +- configs/at91sam9260ek_nandflash_defconfig | 2 +- configs/at91sam9261ek_dataflash_cs0_defconfig | 2 +- configs/at91sam9261ek_dataflash_cs3_defconfig | 2 +- configs/at91sam9261ek_nandflash_defconfig | 2 +- configs/at91sam9g10ek_dataflash_cs0_defconfig | 2 +- configs/at91sam9g10ek_dataflash_cs3_defconfig | 2 +- configs/at91sam9g10ek_nandflash_defconfig | 2 +- configs/at91sam9g20ek_dataflash_cs0_defconfig | 2 +- configs/at91sam9g20ek_dataflash_cs1_defconfig | 2 +- configs/at91sam9g20ek_nandflash_defconfig | 2 +- configs/at91sam9xeek_dataflash_cs0_defconfig | 2 +- configs/at91sam9xeek_dataflash_cs1_defconfig | 2 +- configs/at91sam9xeek_nandflash_defconfig | 2 +- configs/atngw100_defconfig | 3 +- configs/atngw100mkii_defconfig | 3 +- configs/atstk1002_defconfig | 3 +- configs/axm_defconfig | 3 +- configs/axs101_defconfig | 3 +- configs/axs103_defconfig | 3 +- configs/bamboo_defconfig | 3 +- configs/bayleybay_defconfig | 5 +- configs/bcm911360_entphn-ns_defconfig | 2 +- configs/bcm911360_entphn_defconfig | 2 +- configs/bcm911360k_defconfig | 2 +- configs/bcm958300k-ns_defconfig | 2 +- configs/bcm958300k_defconfig | 2 +- configs/bcm958305k_defconfig | 2 +- configs/bcm958622hr_defconfig | 2 +- configs/bf506f-ezkit_defconfig | 1 + configs/bf518f-ezbrd_defconfig | 3 +- configs/bf527-ad7160-eval_defconfig | 2 +- configs/bf537-stamp_defconfig | 2 +- configs/bf548-ezkit_defconfig | 3 +- configs/bf609-ezkit_defconfig | 1 + configs/bg0900_defconfig | 4 +- configs/birdland_bav335a_defconfig | 1 + configs/birdland_bav335b_defconfig | 1 + configs/bk4r1_defconfig | 1 + configs/blanche_defconfig | 2 +- configs/brppt1_mmc_defconfig | 1 + configs/brppt1_nand_defconfig | 1 + configs/brppt1_spi_defconfig | 1 + configs/brxre1_defconfig | 1 + configs/bubinga_defconfig | 3 +- configs/caddy2_defconfig | 2 +- configs/calimain_defconfig | 2 +- configs/cam5200_defconfig | 2 +- configs/cam5200_niosflash_defconfig | 2 +- configs/canmb_defconfig | 2 +- configs/canyonlands_defconfig | 3 +- configs/cgtqmx6eval_defconfig | 1 + configs/charon_defconfig | 2 +- configs/cm-bf537e_defconfig | 2 +- configs/cm-bf537u_defconfig | 2 +- configs/cm-bf548_defconfig | 1 + configs/cm5200_defconfig | 2 +- configs/colibri_imx6_defconfig | 1 + configs/colibri_imx6_nospl_defconfig | 1 + configs/colibri_t20_defconfig | 1 + configs/colibri_t30_defconfig | 1 + configs/colibri_vf_defconfig | 2 + ...conga-qeval20-qa3-e3845-internal-uart_defconfig | 1 + configs/conga-qeval20-qa3-e3845_defconfig | 1 + .../controlcenterd_36BIT_SDCARD_DEVELOP_defconfig | 1 + configs/controlcenterd_36BIT_SDCARD_defconfig | 1 + .../controlcenterd_TRAILBLAZER_DEVELOP_defconfig | 1 + configs/controlcenterd_TRAILBLAZER_defconfig | 1 + configs/coreboot-x86_defconfig | 1 + configs/corvus_defconfig | 3 +- configs/cougarcanyon2_defconfig | 1 + configs/crownbay_defconfig | 2 +- configs/d2net_v2_defconfig | 2 +- configs/da850_am18xxevm_defconfig | 1 + configs/da850evm_defconfig | 1 + configs/da850evm_direct_nor_defconfig | 3 +- configs/db-88f6720_defconfig | 2 +- configs/db-88f6820-amc_defconfig | 2 +- configs/db-mv784mp-gp_defconfig | 2 +- configs/devconcenter_defconfig | 3 +- configs/devkit3250_defconfig | 3 +- configs/dfi-bt700-q7x-151_defconfig | 3 +- configs/digsy_mtc_RAMBOOT_defconfig | 2 +- configs/digsy_mtc_defconfig | 2 +- configs/digsy_mtc_rev5_RAMBOOT_defconfig | 2 +- configs/digsy_mtc_rev5_defconfig | 2 +- configs/dlvision-10g_defconfig | 3 +- configs/dlvision_defconfig | 3 +- configs/dms-ba16-1g_defconfig | 1 + configs/dms-ba16_defconfig | 1 + configs/dns325_defconfig | 2 +- configs/dockstar_defconfig | 2 +- configs/dra7xx_evm_defconfig | 1 + configs/dra7xx_hs_evm_defconfig | 1 + configs/draco_defconfig | 1 + configs/dreamplug_defconfig | 2 +- configs/ds109_defconfig | 2 +- configs/ds414_defconfig | 2 +- configs/ea20_defconfig | 1 + configs/edb9315a_defconfig | 3 +- configs/edminiv2_defconfig | 3 +- configs/efi-x86_defconfig | 2 + configs/espresso7420_defconfig | 2 +- configs/etamin_defconfig | 1 + configs/evb-rk3399_defconfig | 8 - configs/flea3_defconfig | 3 +- configs/fo300_defconfig | 3 +- configs/galileo_defconfig | 3 +- configs/gdppc440etx_defconfig | 3 +- configs/ge_b450v3_defconfig | 1 + configs/ge_b650v3_defconfig | 1 + configs/ge_b850v3_defconfig | 1 + configs/glacier_defconfig | 3 +- configs/glacier_ramboot_defconfig | 3 +- configs/goflexhome_defconfig | 2 +- configs/gplugd_defconfig | 3 +- configs/grasshopper_defconfig | 1 + configs/gurnard_defconfig | 1 + configs/guruplug_defconfig | 2 +- configs/gwventana_defconfig | 1 + configs/h2200_defconfig | 2 +- configs/haleakala_defconfig | 3 +- configs/highbank_defconfig | 2 +- configs/hikey_defconfig | 1 + configs/hrcon_defconfig | 1 + configs/hrcon_dh_defconfig | 1 + configs/ib62x0_defconfig | 2 +- configs/icon_defconfig | 3 +- configs/iconnect_defconfig | 2 +- configs/ids8313_defconfig | 2 +- configs/imx31_phycore_defconfig | 2 +- configs/imx6dl_icore_mmc_defconfig | 6 +- configs/imx6dl_icore_nand_defconfig | 8 +- configs/imx6dl_icore_rqs_mmc_defconfig | 6 +- configs/imx6q_icore_mmc_defconfig | 6 +- configs/imx6q_icore_nand_defconfig | 8 +- configs/imx6q_icore_rqs_mmc_defconfig | 6 +- configs/imx6ul_geam_mmc_defconfig | 6 +- configs/imx6ul_geam_nand_defconfig | 12 +- configs/inetspace_v2_defconfig | 2 +- configs/inka4x0_defconfig | 2 +- configs/integratorap_cm720t_defconfig | 2 +- configs/integratorap_cm920t_defconfig | 2 +- configs/integratorap_cm926ejs_defconfig | 2 +- configs/integratorap_cm946es_defconfig | 2 +- configs/integratorcp_cm1136_defconfig | 2 +- configs/integratorcp_cm920t_defconfig | 2 +- configs/integratorcp_cm926ejs_defconfig | 2 +- configs/integratorcp_cm946es_defconfig | 2 +- configs/intip_defconfig | 3 +- configs/io64_defconfig | 3 +- configs/io_defconfig | 3 +- configs/iocon_defconfig | 3 +- configs/ipam390_defconfig | 3 +- configs/ipek01_defconfig | 2 +- configs/jupiter_defconfig | 3 +- configs/k2e_evm_defconfig | 3 +- configs/k2g_evm_defconfig | 1 + configs/k2hk_evm_defconfig | 3 +- configs/k2l_evm_defconfig | 3 +- configs/katmai_defconfig | 3 +- configs/kilauea_defconfig | 3 +- configs/kmcoge4_defconfig | 3 +- configs/kmcoge5ne_defconfig | 2 +- configs/kmeter1_defconfig | 2 +- configs/kmlion1_defconfig | 3 +- configs/kmopti2_defconfig | 2 +- configs/kmsupx5_defconfig | 2 +- configs/kmtegr1_defconfig | 2 +- configs/kmtepr2_defconfig | 2 +- configs/kmvect1_defconfig | 2 +- configs/kzm9g_defconfig | 2 +- configs/legoev3_defconfig | 1 + configs/liteboard_defconfig | 1 + configs/ls1012afrdm_qspi_defconfig | 10 +- configs/ls1012aqds_qspi_defconfig | 14 +- configs/ls1012ardb_qspi_defconfig | 14 +- configs/ls1021aiot_qspi_defconfig | 9 +- configs/ls1021aiot_sdcard_defconfig | 9 +- configs/ls1021aqds_ddr4_nor_defconfig | 8 +- configs/ls1021aqds_ddr4_nor_lpuart_defconfig | 8 +- configs/ls1021aqds_nand_defconfig | 15 +- configs/ls1021aqds_nor_SECURE_BOOT_defconfig | 13 +- configs/ls1021aqds_nor_defconfig | 8 +- configs/ls1021aqds_nor_lpuart_defconfig | 8 +- configs/ls1021aqds_qspi_defconfig | 8 +- configs/ls1021aqds_sdcard_ifc_defconfig | 8 +- configs/ls1021aqds_sdcard_qspi_defconfig | 8 +- configs/ls1021atwr_nor_SECURE_BOOT_defconfig | 13 +- configs/ls1021atwr_nor_defconfig | 8 +- configs/ls1021atwr_nor_lpuart_defconfig | 8 +- configs/ls1021atwr_qspi_defconfig | 8 +- .../ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig | 13 +- configs/ls1021atwr_sdcard_ifc_defconfig | 13 +- configs/ls1021atwr_sdcard_qspi_defconfig | 8 +- configs/ls1043aqds_defconfig | 12 +- configs/ls1043aqds_lpuart_defconfig | 12 +- configs/ls1043aqds_nand_defconfig | 12 +- configs/ls1043aqds_nor_ddr3_defconfig | 12 +- configs/ls1043aqds_qspi_defconfig | 12 +- configs/ls1043aqds_sdcard_ifc_defconfig | 12 +- configs/ls1043aqds_sdcard_qspi_defconfig | 12 +- configs/ls1043ardb_SECURE_BOOT_defconfig | 12 +- configs/ls1043ardb_defconfig | 15 +- configs/ls1043ardb_nand_defconfig | 12 +- configs/ls1043ardb_sdcard_defconfig | 12 +- configs/ls1046aqds_defconfig | 10 +- configs/ls1046aqds_nand_defconfig | 10 +- configs/ls1046aqds_qspi_defconfig | 12 +- configs/ls1046aqds_sdcard_ifc_defconfig | 10 +- configs/ls1046aqds_sdcard_qspi_defconfig | 12 +- configs/ls1046ardb_emmc_defconfig | 10 +- configs/ls1046ardb_qspi_defconfig | 13 +- configs/ls1046ardb_sdcard_defconfig | 10 +- configs/ls2080a_emu_defconfig | 2 +- configs/ls2080aqds_SECURE_BOOT_defconfig | 8 +- configs/ls2080aqds_defconfig | 8 +- configs/ls2080aqds_nand_defconfig | 8 +- configs/ls2080aqds_qspi_defconfig | 8 +- configs/ls2080ardb_SECURE_BOOT_defconfig | 8 +- configs/ls2080ardb_defconfig | 8 +- configs/ls2080ardb_nand_defconfig | 8 +- configs/lschlv2_defconfig | 2 +- configs/lsxhl_defconfig | 2 +- configs/luan_defconfig | 3 +- configs/lwmon5_defconfig | 3 +- configs/m28evk_defconfig | 2 + configs/ma5d4evk_defconfig | 1 + configs/makalu_defconfig | 3 +- configs/malta64_defconfig | 1 + configs/malta64el_defconfig | 1 + configs/malta_defconfig | 1 + configs/maltael_defconfig | 1 + configs/marsboard_defconfig | 1 + configs/maxbcm_defconfig | 2 +- configs/mecp5123_defconfig | 3 +- configs/meesc_dataflash_defconfig | 3 +- configs/meesc_defconfig | 3 +- configs/mgcoge3ne_defconfig | 2 +- configs/mgcoge_defconfig | 2 +- configs/minnowmax_defconfig | 4 +- configs/motionpro_defconfig | 2 +- configs/mpc5121ads_defconfig | 3 +- configs/mpc5121ads_rev2_defconfig | 3 +- configs/mpc8308_p1m_defconfig | 2 +- configs/munices_defconfig | 2 +- configs/mvebu_db-88f3720_defconfig | 4 +- configs/mvebu_db-88f7040_defconfig | 2 + configs/mvebu_db-88f8040_defconfig | 2 + configs/mx23_olinuxino_defconfig | 1 + configs/mx23evk_defconfig | 1 + configs/mx28evk_auart_console_defconfig | 1 + configs/mx28evk_defconfig | 1 + configs/mx28evk_nand_defconfig | 1 + configs/mx28evk_spi_defconfig | 1 + configs/mx31ads_defconfig | 2 +- configs/mx35pdk_defconfig | 1 + configs/mx6cuboxi_defconfig | 1 + configs/mx6dlarm2_defconfig | 1 + configs/mx6dlarm2_lpddr2_defconfig | 1 + configs/mx6qarm2_defconfig | 1 + configs/mx6qarm2_lpddr2_defconfig | 1 + configs/mx6qsabrelite_defconfig | 1 + configs/mx6slevk_defconfig | 1 + configs/mx6slevk_spinor_defconfig | 1 + configs/mx6slevk_spl_defconfig | 1 + configs/mx6sllevk_defconfig | 1 + configs/mx6sllevk_plugin_defconfig | 1 + configs/mx6ul_14x14_evk_defconfig | 1 + configs/mx6ul_9x9_evk_defconfig | 1 + configs/mx6ull_14x14_evk_defconfig | 1 + configs/mx6ull_14x14_evk_plugin_defconfig | 1 + configs/nas220_defconfig | 2 +- configs/neo_defconfig | 3 +- configs/net2big_v2_defconfig | 2 +- configs/netspace_lite_v2_defconfig | 2 +- configs/netspace_max_v2_defconfig | 2 +- configs/netspace_mini_v2_defconfig | 2 +- configs/netspace_v2_defconfig | 2 +- configs/nitrogen6dl2g_defconfig | 1 + configs/nitrogen6dl_defconfig | 1 + configs/nitrogen6q2g_defconfig | 1 + configs/nitrogen6q_defconfig | 1 + configs/nitrogen6s1g_defconfig | 1 + configs/nitrogen6s_defconfig | 1 + configs/novena_defconfig | 1 + configs/nsa310s_defconfig | 2 +- configs/odroid-c2_defconfig | 3 +- configs/omapl138_lcdk_defconfig | 1 + configs/orangepi_zero_defconfig | 4 +- configs/ot1200_defconfig | 1 + configs/ot1200_spl_defconfig | 1 + configs/pcm030_LOWBOOT_defconfig | 2 +- configs/pcm030_defconfig | 2 +- configs/pcm051_rev1_defconfig | 1 + configs/pcm051_rev3_defconfig | 1 + configs/pcm052_defconfig | 1 + configs/pcm058_defconfig | 1 + configs/pdm360ng_defconfig | 2 +- configs/peach-pi_defconfig | 2 +- configs/peach-pit_defconfig | 2 +- configs/pengwyn_defconfig | 1 + configs/pic32mzdask_defconfig | 2 +- configs/pico-imx6ul_defconfig | 1 + configs/picosam9g45_defconfig | 1 + configs/pine64_plus_defconfig | 2 +- configs/platinum_picon_defconfig | 1 + configs/platinum_titanium_defconfig | 1 + configs/pm9261_defconfig | 3 +- configs/pm9263_defconfig | 3 +- configs/pm9g45_defconfig | 3 +- configs/pogo_e02_defconfig | 2 +- configs/pxm2_defconfig | 1 + configs/qemu-ppce500_defconfig | 3 +- configs/qemu-x86_defconfig | 1 + configs/qemu-x86_efi_payload32_defconfig | 1 + configs/qemu-x86_efi_payload64_defconfig | 1 + configs/rainier_defconfig | 3 +- configs/rainier_ramboot_defconfig | 3 +- configs/rastaban_defconfig | 1 + configs/redwood_defconfig | 3 +- configs/riotboard_defconfig | 1 + configs/rut_defconfig | 2 + configs/s32v234evb_defconfig | 1 + configs/s5p_goni_defconfig | 4 +- configs/s5pc210_universal_defconfig | 2 +- configs/salvator-x_defconfig | 2 +- configs/sama5d2_ptc_nandflash_defconfig | 2 +- configs/sama5d2_ptc_spiflash_defconfig | 2 +- configs/sansa_fuze_plus_defconfig | 2 + configs/sbc8349_PCI_33_defconfig | 2 +- configs/sbc8349_PCI_66_defconfig | 2 +- configs/sbc8349_defconfig | 2 +- configs/sbc8548_PCI_33_PCIE_defconfig | 3 +- configs/sbc8548_PCI_33_defconfig | 3 +- configs/sbc8548_PCI_66_PCIE_defconfig | 3 +- configs/sbc8548_PCI_66_defconfig | 3 +- configs/sbc8548_defconfig | 3 +- configs/sbc8641d_defconfig | 2 +- configs/sc_sps_1_defconfig | 2 + configs/secomx6quq7_defconfig | 1 + configs/sequoia_defconfig | 3 +- configs/sequoia_ramboot_defconfig | 3 +- configs/sh7752evb_defconfig | 2 +- configs/sh7753evb_defconfig | 2 +- configs/sh7757lcr_defconfig | 2 +- configs/smartweb_defconfig | 3 +- configs/smdkc100_defconfig | 2 +- configs/snapper9260_defconfig | 2 +- configs/snapper9g20_defconfig | 2 +- configs/snow_defconfig | 2 +- configs/socfpga_is1_defconfig | 2 +- configs/socfpga_sr1500_defconfig | 1 + configs/socrates_defconfig | 2 +- configs/som-db5800-som-6867_defconfig | 1 + configs/spear300_defconfig | 2 +- configs/spear300_nand_defconfig | 2 +- configs/spear300_usbtty_defconfig | 2 +- configs/spear300_usbtty_nand_defconfig | 2 +- configs/spear310_defconfig | 2 +- configs/spear310_nand_defconfig | 2 +- configs/spear310_pnor_defconfig | 2 +- configs/spear310_usbtty_defconfig | 2 +- configs/spear310_usbtty_nand_defconfig | 2 +- configs/spear310_usbtty_pnor_defconfig | 2 +- configs/spear320_defconfig | 2 +- configs/spear320_nand_defconfig | 2 +- configs/spear320_pnor_defconfig | 2 +- configs/spear320_usbtty_defconfig | 2 +- configs/spear320_usbtty_nand_defconfig | 2 +- configs/spear320_usbtty_pnor_defconfig | 2 +- configs/spear600_defconfig | 2 +- configs/spear600_nand_defconfig | 2 +- configs/spear600_usbtty_defconfig | 2 +- configs/spear600_usbtty_nand_defconfig | 2 +- configs/spring_defconfig | 2 +- configs/stm32f429-discovery_defconfig | 3 +- configs/stm32f746-disco_defconfig | 3 +- configs/strider_con_defconfig | 1 + configs/strider_con_dp_defconfig | 1 + configs/strider_cpu_defconfig | 1 + configs/strider_cpu_dp_defconfig | 1 + configs/stv0991_defconfig | 3 +- configs/suvd3_defconfig | 2 +- configs/sycamore_defconfig | 3 +- configs/t3corp_defconfig | 3 +- configs/taurus_defconfig | 3 +- configs/tbs2910_defconfig | 1 + configs/tcm-bf537_defconfig | 2 +- configs/theadorable-x86-dfi-bt700_defconfig | 3 +- configs/theadorable_debug_defconfig | 2 +- configs/theadorable_defconfig | 2 +- configs/thuban_defconfig | 1 + configs/thunderx_88xx_defconfig | 2 +- configs/titanium_defconfig | 1 + configs/tplink_wdr4300_defconfig | 1 + configs/tqma6q_mba6_mmc_defconfig | 1 + configs/tqma6q_mba6_spi_defconfig | 1 + configs/tqma6s_mba6_mmc_defconfig | 1 + configs/tqma6s_mba6_spi_defconfig | 1 + configs/tqma6s_wru4_mmc_defconfig | 1 + configs/ts4600_defconfig | 2 + configs/ts4800_defconfig | 1 + configs/tuge1_defconfig | 2 +- configs/tuxx1_defconfig | 2 +- configs/udoo_defconfig | 1 + configs/udoo_neo_defconfig | 1 + configs/usb_a9263_dataflash_defconfig | 2 +- configs/v38b_defconfig | 3 +- configs/ve8313_defconfig | 3 +- configs/vexpress_aemv8a_dram_defconfig | 2 +- configs/vexpress_aemv8a_juno_defconfig | 2 +- configs/vexpress_aemv8a_semi_defconfig | 2 +- configs/vf610twr_defconfig | 1 + configs/vf610twr_nand_defconfig | 1 + configs/vinco_defconfig | 1 + configs/vining_2000_defconfig | 1 + configs/vme8349_defconfig | 2 +- configs/walnut_defconfig | 3 +- configs/wandboard_defconfig | 1 + configs/warp_defconfig | 1 + configs/woodburn_defconfig | 1 + configs/work_92105_defconfig | 3 +- configs/wtk_defconfig | 2 +- configs/xfi3_defconfig | 2 + configs/xilinx-ppc405-generic_defconfig | 2 +- configs/xilinx-ppc440-generic_defconfig | 2 +- configs/xpedite1000_defconfig | 3 +- configs/xpedite517x_defconfig | 2 +- configs/xpedite520x_defconfig | 2 +- configs/xpedite537x_defconfig | 2 +- configs/xpedite550x_defconfig | 2 +- configs/xpress_defconfig | 1 + configs/xpress_spl_defconfig | 1 + configs/yellowstone_defconfig | 3 +- configs/yosemite_defconfig | 3 +- configs/yucca_defconfig | 3 +- configs/zc5202_defconfig | 1 + configs/zc5601_defconfig | 1 + drivers/pci/Makefile | 1 - drivers/pci/w83c553f.c | 206 --------------------- include/common.h | 22 +-- include/commproc.h | 16 -- include/config_cmd_all.h | 1 - include/configs/BSC9131RDB.h | 2 - include/configs/BSC9132QDS.h | 1 - include/configs/CPCI2DP.h | 2 - include/configs/CPCI4052.h | 1 - include/configs/MIP405.h | 1 - include/configs/MPC8313ERDB.h | 1 - include/configs/MPC8315ERDB.h | 1 - include/configs/MPC832XEMDS.h | 1 - include/configs/MPC8349EMDS.h | 2 - include/configs/MPC837XEMDS.h | 1 - include/configs/MPC837XERDB.h | 1 - include/configs/MPC8536DS.h | 2 - include/configs/MPC8568MDS.h | 2 - include/configs/MPC8569MDS.h | 1 - include/configs/MPC8610HPCD.h | 1 - include/configs/P1010RDB.h | 1 - include/configs/P1022DS.h | 1 - include/configs/P1023RDB.h | 1 - include/configs/P2041RDB.h | 1 - include/configs/PATI.h | 2 - include/configs/PIP405.h | 3 - include/configs/PLU405.h | 1 - include/configs/PMC405DE.h | 1 - include/configs/PMC440.h | 1 - include/configs/T102xQDS.h | 3 - include/configs/T102xRDB.h | 3 - include/configs/T1040QDS.h | 3 - include/configs/T104xRDB.h | 3 - include/configs/TQM5200.h | 1 - include/configs/TQM834x.h | 1 - include/configs/UCP1020.h | 2 - include/configs/VOM405.h | 1 - include/configs/acadia.h | 1 - include/configs/advantech_dms-ba16.h | 2 - include/configs/am335x_evm.h | 1 - include/configs/am43xx_evm.h | 3 - include/configs/am57xx_evm.h | 2 - include/configs/ap121.h | 2 - include/configs/ap143.h | 2 - include/configs/apalis_imx6.h | 1 - include/configs/apalis_t30.h | 2 - include/configs/aristainetos-common.h | 2 - include/configs/armadillo-800eva.h | 1 - include/configs/aspenite.h | 1 - include/configs/at91-sama5_common.h | 2 - include/configs/at91rm9200ek.h | 2 - include/configs/at91sam9260ek.h | 1 - include/configs/at91sam9263ek.h | 2 - include/configs/at91sam9m10g45ek.h | 1 - include/configs/at91sam9n12ek.h | 1 - include/configs/at91sam9rlek.h | 1 - include/configs/at91sam9x5ek.h | 1 - include/configs/atngw100.h | 1 - include/configs/atngw100mkii.h | 1 - include/configs/atstk1002.h | 1 - include/configs/axs10x.h | 1 - include/configs/baltos.h | 1 - include/configs/bamboo.h | 2 - include/configs/bav335x.h | 1 - include/configs/bayleybay.h | 1 - include/configs/bf506f-ezkit.h | 1 - include/configs/bf518f-ezbrd.h | 1 - include/configs/bf548-ezkit.h | 1 - include/configs/bf609-ezkit.h | 1 - include/configs/brppt1.h | 1 - include/configs/brxre1.h | 1 - include/configs/bubinga.h | 2 - include/configs/canyonlands.h | 1 - include/configs/cgtqmx6eval.h | 1 - include/configs/cm-bf548.h | 1 - include/configs/colibri_imx6.h | 1 - include/configs/colibri_imx7.h | 3 - include/configs/colibri_t20.h | 2 - include/configs/colibri_t30.h | 2 - include/configs/colibri_vf.h | 3 - include/configs/conga-qeval20-qa3-e3845.h | 3 - include/configs/controlcenterd.h | 2 - include/configs/corenet_ds.h | 1 - include/configs/corvus.h | 1 - include/configs/cougarcanyon2.h | 1 - include/configs/crownbay.h | 2 - include/configs/cyrus.h | 1 - include/configs/da850evm.h | 1 - include/configs/devkit3250.h | 1 - include/configs/dfi-bt700.h | 1 - include/configs/dlvision-10g.h | 1 - include/configs/dlvision.h | 1 - include/configs/dra7xx_evm.h | 1 - include/configs/ea20.h | 1 - include/configs/edb93xx.h | 2 - include/configs/edminiv2.h | 1 - include/configs/el6x_common.h | 2 - include/configs/embestmx6boards.h | 2 - include/configs/exynos-common.h | 1 - include/configs/exynos7420-common.h | 1 - include/configs/flea3.h | 1 - include/configs/galileo.h | 3 - include/configs/gdppc440etx.h | 1 - include/configs/ge_bx50v3.h | 2 - include/configs/gplugd.h | 1 - include/configs/grasshopper.h | 1 - include/configs/gw_ventana.h | 1 - include/configs/hikey.h | 2 - include/configs/hrcon.h | 1 - include/configs/icon.h | 1 - include/configs/imx31_phycore.h | 1 - include/configs/intip.h | 1 - include/configs/io.h | 1 - include/configs/io64.h | 1 - include/configs/iocon.h | 1 - include/configs/ipam390.h | 1 - include/configs/jupiter.h | 1 - include/configs/katmai.h | 1 - include/configs/kilauea.h | 1 - include/configs/km/km_arm.h | 2 - include/configs/km/kmp204x-common.h | 1 - include/configs/kzm9g.h | 1 - include/configs/legoev3.h | 1 - include/configs/liteboard.h | 2 - include/configs/ls1012a_common.h | 3 - include/configs/ls1021aiot.h | 2 - include/configs/ls1021aqds.h | 1 - include/configs/ls1021atwr.h | 1 - include/configs/ls1043a_common.h | 2 - include/configs/ls1046a_common.h | 2 - include/configs/ls2080a_common.h | 3 - include/configs/luan.h | 1 - include/configs/lwmon5.h | 1 - include/configs/m53evk.h | 1 - include/configs/makalu.h | 1 - include/configs/malta.h | 1 - include/configs/mecp5123.h | 1 - include/configs/meesc.h | 1 - include/configs/minnowmax.h | 2 - include/configs/mpc5121ads.h | 1 - include/configs/mv-common.h | 2 - include/configs/mvebu_armada-8k.h | 2 - include/configs/mvebu_db-88f3720.h | 2 - include/configs/mx25pdk.h | 2 - include/configs/mx31ads.h | 1 - include/configs/mx31pdk.h | 1 - include/configs/mx35pdk.h | 2 - include/configs/mx51evk.h | 2 - include/configs/mx53ard.h | 1 - include/configs/mx53cx9020.h | 1 - include/configs/mx53evk.h | 1 - include/configs/mx53loco.h | 1 - include/configs/mx53smd.h | 1 - include/configs/mx6cuboxi.h | 1 - include/configs/mx6qarm2.h | 2 - include/configs/mx6sabre_common.h | 2 - include/configs/mx6slevk.h | 2 - include/configs/mx6sllevk.h | 2 - include/configs/mx6sxsabreauto.h | 2 - include/configs/mx6sxsabresd.h | 2 - include/configs/mx6ul_14x14_evk.h | 2 - include/configs/mx6ullevk.h | 2 - include/configs/mx7_common.h | 2 - include/configs/mx7dsabresd.h | 2 - include/configs/mxs.h | 2 - include/configs/neo.h | 1 - include/configs/nitrogen6x.h | 1 - include/configs/novena.h | 1 - include/configs/omapl138_lcdk.h | 1 - include/configs/ot1200.h | 1 - include/configs/p1_p2_rdb_pc.h | 2 - include/configs/p1_twr.h | 2 - include/configs/pcm051.h | 1 - include/configs/pcm052.h | 2 - include/configs/pcm058.h | 1 - include/configs/pengwyn.h | 1 - include/configs/pico-imx6ul.h | 2 - include/configs/picosam9g45.h | 1 - include/configs/platinum.h | 1 - include/configs/pm9261.h | 1 - include/configs/pm9263.h | 1 - include/configs/pm9g45.h | 1 - include/configs/qemu-ppce500.h | 1 - include/configs/qemu-x86.h | 1 - include/configs/rcar-gen2-common.h | 1 - include/configs/rcar-gen3-common.h | 1 - include/configs/redwood.h | 1 - include/configs/rut.h | 1 - include/configs/s32v234evb.h | 1 - include/configs/sama5d2_xplained.h | 2 - include/configs/sbc8349.h | 2 - include/configs/sbc8548.h | 2 - include/configs/sbc8641d.h | 2 - include/configs/secomx6quq7.h | 2 - include/configs/sequoia.h | 1 - include/configs/siemens-am33x-common.h | 1 - include/configs/smartweb.h | 1 - include/configs/snapper9g45.h | 1 - include/configs/socfpga_common.h | 2 - include/configs/socfpga_sr1500.h | 2 - include/configs/som-6896.h | 3 - include/configs/som-db5800-som-6867.h | 3 - include/configs/spear-common.h | 1 - include/configs/stm32f429-discovery.h | 1 - include/configs/stm32f746-disco.h | 2 - include/configs/strider.h | 1 - include/configs/stv0991.h | 1 - include/configs/t3corp.h | 1 - include/configs/taurus.h | 1 - include/configs/tbs2910.h | 2 - include/configs/tegra-common.h | 2 - include/configs/ti_am335x_common.h | 3 - include/configs/ti_armv7_keystone2.h | 1 - include/configs/titanium.h | 1 - include/configs/tplink_wdr4300.h | 2 - include/configs/tqma6.h | 2 - include/configs/ts4800.h | 2 - include/configs/udoo.h | 2 - include/configs/udoo_neo.h | 1 - include/configs/usbarmory.h | 1 - include/configs/v38b.h | 1 - include/configs/ve8313.h | 2 - include/configs/vf610twr.h | 2 - include/configs/vining_2000.h | 2 - include/configs/walnut.h | 2 - include/configs/wandboard.h | 2 - include/configs/warp.h | 2 - include/configs/warp7.h | 2 - include/configs/woodburn.h | 1 - include/configs/work_92105.h | 1 - include/configs/x86-chromebook.h | 3 - include/configs/xpedite1000.h | 1 - include/configs/xpress.h | 2 - include/configs/yosemite.h | 1 - include/configs/yucca.h | 1 - post/cpu/mpc8xx/ether.c | 5 - post/cpu/mpc8xx/uart.c | 13 -- scripts/config_whitelist.txt | 6 - 1006 files changed, 1212 insertions(+), 1434 deletions(-) delete mode 100644 arch/powerpc/cpu/mpc8xx/commproc.c delete mode 100644 drivers/pci/w83c553f.c
Rsync all defconfig files using moveconfig.py
configs/B4420QDS_NAND_defconfig | 2 +- configs/B4420QDS_SPIFLASH_defconfig | 2 +- configs/B4420QDS_defconfig | 2 +- configs/B4860QDS_NAND_defconfig | 2 +- configs/B4860QDS_SPIFLASH_defconfig | 2 +- configs/B4860QDS_SRIO_PCIE_BOOT_defconfig | 2 +- configs/B4860QDS_defconfig | 2 +- configs/BSC9131RDB_NAND_SYSCLK100_defconfig | 2 +- configs/BSC9131RDB_NAND_defconfig | 2 +- configs/BSC9131RDB_SPIFLASH_SYSCLK100_defconfig | 2 +- configs/BSC9131RDB_SPIFLASH_defconfig | 2 +- configs/C29XPCIE_NAND_defconfig | 2 +- configs/C29XPCIE_SPIFLASH_defconfig | 2 +- configs/C29XPCIE_defconfig | 2 +- configs/CHIP_defconfig | 2 +- configs/CPCI2DP_defconfig | 2 +- configs/CPCI4052_defconfig | 2 +- configs/MIP405T_defconfig | 2 +- configs/MIP405_defconfig | 2 +- configs/MPC8313ERDB_33_defconfig | 2 +- configs/MPC8313ERDB_66_defconfig | 2 +- configs/MPC8313ERDB_NAND_33_defconfig | 2 +- configs/MPC8313ERDB_NAND_66_defconfig | 2 +- configs/MPC8315ERDB_defconfig | 2 +- configs/MPC8323ERDB_defconfig | 2 +- configs/MPC832XEMDS_ATM_defconfig | 2 +- configs/MPC832XEMDS_HOST_33_defconfig | 2 +- configs/MPC832XEMDS_HOST_66_defconfig | 2 +- configs/MPC832XEMDS_SLAVE_defconfig | 2 +- configs/MPC832XEMDS_defconfig | 2 +- configs/MPC8349EMDS_defconfig | 2 +- configs/MPC8349ITXGP_defconfig | 2 +- configs/MPC8349ITX_LOWBOOT_defconfig | 2 +- configs/MPC8349ITX_defconfig | 2 +- configs/MPC8540ADS_defconfig | 2 +- configs/MPC8541CDS_defconfig | 2 +- configs/MPC8541CDS_legacy_defconfig | 2 +- configs/MPC8544DS_defconfig | 2 +- configs/MPC8548CDS_36BIT_defconfig | 2 +- configs/MPC8548CDS_defconfig | 2 +- configs/MPC8548CDS_legacy_defconfig | 2 +- configs/MPC8555CDS_defconfig | 2 +- configs/MPC8555CDS_legacy_defconfig | 2 +- configs/MPC8560ADS_defconfig | 2 +- configs/MPC8568MDS_defconfig | 2 +- configs/MPC8572DS_36BIT_defconfig | 2 +- configs/MPC8572DS_defconfig | 2 +- configs/MPC8610HPCD_defconfig | 2 +- configs/MPC8641HPCN_36BIT_defconfig | 2 +- configs/MPC8641HPCN_defconfig | 2 +- configs/MiniFAP_defconfig | 2 +- configs/Nintendo_NES_Classic_Edition_defconfig | 2 +- configs/O2D300_defconfig | 2 +- configs/O2DNT2_RAMBOOT_defconfig | 2 +- configs/O2DNT2_defconfig | 2 +- configs/O2D_defconfig | 2 +- configs/O2I_defconfig | 2 +- configs/O2MNT_O2M110_defconfig | 2 +- configs/O2MNT_O2M112_defconfig | 2 +- configs/O2MNT_O2M113_defconfig | 2 +- configs/O2MNT_defconfig | 2 +- configs/O3DNT_defconfig | 2 +- configs/P1023RDB_defconfig | 2 +- configs/PATI_defconfig | 2 +- configs/PIP405_defconfig | 2 +- configs/PLU405_defconfig | 2 +- configs/PMC405DE_defconfig | 2 +- configs/PMC440_defconfig | 2 +- configs/TQM5200S_HIGHBOOT_defconfig | 2 +- configs/TQM5200S_defconfig | 2 +- configs/TQM5200_B_HIGHBOOT_defconfig | 2 +- configs/TQM5200_B_defconfig | 2 +- configs/TQM5200_STK100_defconfig | 2 +- configs/TQM5200_defconfig | 2 +- configs/TQM823L_LCD_defconfig | 2 +- configs/TQM823L_defconfig | 2 +- configs/TQM823M_defconfig | 2 +- configs/TQM834x_defconfig | 2 +- configs/TQM850L_defconfig | 2 +- configs/TQM850M_defconfig | 2 +- configs/TQM855L_defconfig | 2 +- configs/TQM855M_defconfig | 2 +- configs/TQM860L_defconfig | 2 +- configs/TQM860M_defconfig | 2 +- configs/TQM862L_defconfig | 2 +- configs/TQM862M_defconfig | 2 +- configs/TQM866M_defconfig | 2 +- configs/TQM885D_defconfig | 2 +- configs/TTTech_defconfig | 2 +- configs/VOM405_defconfig | 2 +- configs/a3m071_defconfig | 2 +- configs/a4m072_defconfig | 2 +- configs/a4m2k_defconfig | 2 +- configs/ac14xx_defconfig | 2 +- configs/acadia_defconfig | 2 +- configs/adp-ag101p_defconfig | 2 +- configs/arches_defconfig | 2 +- configs/aria_defconfig | 2 +- configs/armadillo-800eva_defconfig | 2 +- configs/aspenite_defconfig | 2 +- configs/at91rm9200ek_defconfig | 2 +- configs/at91rm9200ek_ram_defconfig | 2 +- configs/at91sam9260ek_dataflash_cs0_defconfig | 2 +- configs/at91sam9260ek_dataflash_cs1_defconfig | 2 +- configs/at91sam9260ek_nandflash_defconfig | 2 +- configs/at91sam9261ek_dataflash_cs0_defconfig | 2 +- configs/at91sam9261ek_dataflash_cs3_defconfig | 2 +- configs/at91sam9261ek_nandflash_defconfig | 2 +- configs/at91sam9g10ek_dataflash_cs0_defconfig | 2 +- configs/at91sam9g10ek_dataflash_cs3_defconfig | 2 +- configs/at91sam9g10ek_nandflash_defconfig | 2 +- configs/at91sam9g20ek_dataflash_cs0_defconfig | 2 +- configs/at91sam9g20ek_dataflash_cs1_defconfig | 2 +- configs/at91sam9g20ek_nandflash_defconfig | 2 +- configs/at91sam9xeek_dataflash_cs0_defconfig | 2 +- configs/at91sam9xeek_dataflash_cs1_defconfig | 2 +- configs/at91sam9xeek_nandflash_defconfig | 2 +- configs/atngw100_defconfig | 2 +- configs/atngw100mkii_defconfig | 2 +- configs/atstk1002_defconfig | 2 +- configs/axm_defconfig | 2 +- configs/axs101_defconfig | 2 +- configs/axs103_defconfig | 2 +- configs/bamboo_defconfig | 2 +- configs/bayleybay_defconfig | 2 +- configs/bcm911360_entphn-ns_defconfig | 2 +- configs/bcm911360_entphn_defconfig | 2 +- configs/bcm911360k_defconfig | 2 +- configs/bcm958300k-ns_defconfig | 2 +- configs/bcm958300k_defconfig | 2 +- configs/bcm958305k_defconfig | 2 +- configs/bcm958622hr_defconfig | 2 +- configs/bf518f-ezbrd_defconfig | 2 +- configs/bf527-ad7160-eval_defconfig | 2 +- configs/bf537-stamp_defconfig | 2 +- configs/bf548-ezkit_defconfig | 2 +- configs/bg0900_defconfig | 2 +- configs/blanche_defconfig | 2 +- configs/bubinga_defconfig | 2 +- configs/caddy2_defconfig | 2 +- configs/calimain_defconfig | 2 +- configs/cam5200_defconfig | 2 +- configs/cam5200_niosflash_defconfig | 2 +- configs/canmb_defconfig | 2 +- configs/canyonlands_defconfig | 2 +- configs/charon_defconfig | 2 +- configs/cm-bf537e_defconfig | 2 +- configs/cm-bf537u_defconfig | 2 +- configs/cm5200_defconfig | 2 +- configs/corvus_defconfig | 2 +- configs/crownbay_defconfig | 2 +- configs/d2net_v2_defconfig | 2 +- configs/da850evm_direct_nor_defconfig | 2 +- configs/db-88f6720_defconfig | 2 +- configs/db-88f6820-amc_defconfig | 2 +- configs/db-mv784mp-gp_defconfig | 2 +- configs/devconcenter_defconfig | 2 +- configs/devkit3250_defconfig | 2 +- configs/dfi-bt700-q7x-151_defconfig | 2 +- configs/digsy_mtc_RAMBOOT_defconfig | 2 +- configs/digsy_mtc_defconfig | 2 +- configs/digsy_mtc_rev5_RAMBOOT_defconfig | 2 +- configs/digsy_mtc_rev5_defconfig | 2 +- configs/dlvision-10g_defconfig | 2 +- configs/dlvision_defconfig | 2 +- configs/dns325_defconfig | 2 +- configs/dockstar_defconfig | 2 +- configs/dreamplug_defconfig | 2 +- configs/ds109_defconfig | 2 +- configs/ds414_defconfig | 2 +- configs/edb9315a_defconfig | 2 +- configs/edminiv2_defconfig | 2 +- configs/espresso7420_defconfig | 2 +- configs/evb-rk3399_defconfig | 8 -------- configs/flea3_defconfig | 2 +- configs/fo300_defconfig | 2 +- configs/galileo_defconfig | 2 +- configs/gdppc440etx_defconfig | 2 +- configs/glacier_defconfig | 2 +- configs/glacier_ramboot_defconfig | 2 +- configs/goflexhome_defconfig | 2 +- configs/gplugd_defconfig | 2 +- configs/guruplug_defconfig | 2 +- configs/h2200_defconfig | 2 +- configs/haleakala_defconfig | 2 +- configs/highbank_defconfig | 2 +- configs/ib62x0_defconfig | 2 +- configs/icon_defconfig | 2 +- configs/iconnect_defconfig | 2 +- configs/ids8313_defconfig | 2 +- configs/imx31_phycore_defconfig | 2 +- configs/imx6dl_icore_mmc_defconfig | 6 +++--- configs/imx6dl_icore_nand_defconfig | 8 ++++---- configs/imx6dl_icore_rqs_mmc_defconfig | 6 +++--- configs/imx6q_icore_mmc_defconfig | 6 +++--- configs/imx6q_icore_nand_defconfig | 8 ++++---- configs/imx6q_icore_rqs_mmc_defconfig | 6 +++--- configs/imx6ul_geam_mmc_defconfig | 6 +++--- configs/imx6ul_geam_nand_defconfig | 12 ++++++------ configs/inetspace_v2_defconfig | 2 +- configs/inka4x0_defconfig | 2 +- configs/integratorap_cm720t_defconfig | 2 +- configs/integratorap_cm920t_defconfig | 2 +- configs/integratorap_cm926ejs_defconfig | 2 +- configs/integratorap_cm946es_defconfig | 2 +- configs/integratorcp_cm1136_defconfig | 2 +- configs/integratorcp_cm920t_defconfig | 2 +- configs/integratorcp_cm926ejs_defconfig | 2 +- configs/integratorcp_cm946es_defconfig | 2 +- configs/intip_defconfig | 2 +- configs/io64_defconfig | 2 +- configs/io_defconfig | 2 +- configs/iocon_defconfig | 2 +- configs/ipam390_defconfig | 2 +- configs/ipek01_defconfig | 2 +- configs/jupiter_defconfig | 2 +- configs/k2e_evm_defconfig | 2 +- configs/k2hk_evm_defconfig | 2 +- configs/k2l_evm_defconfig | 2 +- configs/katmai_defconfig | 2 +- configs/kilauea_defconfig | 2 +- configs/kmcoge4_defconfig | 2 +- configs/kmcoge5ne_defconfig | 2 +- configs/kmeter1_defconfig | 2 +- configs/kmlion1_defconfig | 2 +- configs/kmopti2_defconfig | 2 +- configs/kmsupx5_defconfig | 2 +- configs/kmtegr1_defconfig | 2 +- configs/kmtepr2_defconfig | 2 +- configs/kmvect1_defconfig | 2 +- configs/kzm9g_defconfig | 2 +- configs/ls1012afrdm_qspi_defconfig | 10 +++++----- configs/ls1012aqds_qspi_defconfig | 14 +++++++------- configs/ls1012ardb_qspi_defconfig | 14 +++++++------- configs/ls1021aiot_qspi_defconfig | 8 ++++---- configs/ls1021aiot_sdcard_defconfig | 8 ++++---- configs/ls1021aqds_ddr4_nor_defconfig | 8 ++++---- configs/ls1021aqds_ddr4_nor_lpuart_defconfig | 8 ++++---- configs/ls1021aqds_nand_defconfig | 15 +++++++-------- configs/ls1021aqds_nor_SECURE_BOOT_defconfig | 13 ++++++------- configs/ls1021aqds_nor_defconfig | 8 ++++---- configs/ls1021aqds_nor_lpuart_defconfig | 8 ++++---- configs/ls1021aqds_qspi_defconfig | 8 ++++---- configs/ls1021aqds_sdcard_ifc_defconfig | 8 ++++---- configs/ls1021aqds_sdcard_qspi_defconfig | 8 ++++---- configs/ls1021atwr_nor_SECURE_BOOT_defconfig | 13 ++++++------- configs/ls1021atwr_nor_defconfig | 8 ++++---- configs/ls1021atwr_nor_lpuart_defconfig | 8 ++++---- configs/ls1021atwr_qspi_defconfig | 8 ++++---- configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig | 13 ++++++------- configs/ls1021atwr_sdcard_ifc_defconfig | 13 ++++++------- configs/ls1021atwr_sdcard_qspi_defconfig | 8 ++++---- configs/ls1043aqds_defconfig | 12 ++++++------ configs/ls1043aqds_lpuart_defconfig | 12 ++++++------ configs/ls1043aqds_nand_defconfig | 12 ++++++------ configs/ls1043aqds_nor_ddr3_defconfig | 12 ++++++------ configs/ls1043aqds_qspi_defconfig | 12 ++++++------ configs/ls1043aqds_sdcard_ifc_defconfig | 12 ++++++------ configs/ls1043aqds_sdcard_qspi_defconfig | 12 ++++++------ configs/ls1043ardb_SECURE_BOOT_defconfig | 12 ++++++------ configs/ls1043ardb_defconfig | 15 +++++++-------- configs/ls1043ardb_nand_defconfig | 12 ++++++------ configs/ls1043ardb_sdcard_defconfig | 12 ++++++------ configs/ls1046aqds_defconfig | 10 +++++----- configs/ls1046aqds_nand_defconfig | 10 +++++----- configs/ls1046aqds_qspi_defconfig | 12 ++++++------ configs/ls1046aqds_sdcard_ifc_defconfig | 10 +++++----- configs/ls1046aqds_sdcard_qspi_defconfig | 12 ++++++------ configs/ls1046ardb_emmc_defconfig | 10 +++++----- configs/ls1046ardb_qspi_defconfig | 13 ++++++------- configs/ls1046ardb_sdcard_defconfig | 10 +++++----- configs/ls2080a_emu_defconfig | 2 +- configs/ls2080aqds_SECURE_BOOT_defconfig | 8 ++++---- configs/ls2080aqds_defconfig | 8 ++++---- configs/ls2080aqds_nand_defconfig | 8 ++++---- configs/ls2080aqds_qspi_defconfig | 8 ++++---- configs/ls2080ardb_SECURE_BOOT_defconfig | 8 ++++---- configs/ls2080ardb_defconfig | 8 ++++---- configs/ls2080ardb_nand_defconfig | 8 ++++---- configs/lschlv2_defconfig | 2 +- configs/lsxhl_defconfig | 2 +- configs/luan_defconfig | 2 +- configs/lwmon5_defconfig | 2 +- configs/makalu_defconfig | 2 +- configs/maxbcm_defconfig | 2 +- configs/mecp5123_defconfig | 2 +- configs/meesc_dataflash_defconfig | 2 +- configs/meesc_defconfig | 2 +- configs/mgcoge3ne_defconfig | 2 +- configs/mgcoge_defconfig | 2 +- configs/minnowmax_defconfig | 2 +- configs/motionpro_defconfig | 2 +- configs/mpc5121ads_defconfig | 2 +- configs/mpc5121ads_rev2_defconfig | 2 +- configs/mpc8308_p1m_defconfig | 2 +- configs/munices_defconfig | 2 +- configs/mvebu_db-88f3720_defconfig | 2 +- configs/mx31ads_defconfig | 2 +- configs/nas220_defconfig | 2 +- configs/neo_defconfig | 2 +- configs/net2big_v2_defconfig | 2 +- configs/netspace_lite_v2_defconfig | 2 +- configs/netspace_max_v2_defconfig | 2 +- configs/netspace_mini_v2_defconfig | 2 +- configs/netspace_v2_defconfig | 2 +- configs/nsa310s_defconfig | 2 +- configs/odroid-c2_defconfig | 3 +-- configs/orangepi_zero_defconfig | 4 ++-- configs/pcm030_LOWBOOT_defconfig | 2 +- configs/pcm030_defconfig | 2 +- configs/pdm360ng_defconfig | 2 +- configs/peach-pi_defconfig | 2 +- configs/peach-pit_defconfig | 2 +- configs/pic32mzdask_defconfig | 2 +- configs/pine64_plus_defconfig | 2 +- configs/pm9261_defconfig | 2 +- configs/pm9263_defconfig | 2 +- configs/pm9g45_defconfig | 2 +- configs/pogo_e02_defconfig | 2 +- configs/qemu-ppce500_defconfig | 2 +- configs/rainier_defconfig | 2 +- configs/rainier_ramboot_defconfig | 2 +- configs/redwood_defconfig | 2 +- configs/s5p_goni_defconfig | 4 ++-- configs/s5pc210_universal_defconfig | 2 +- configs/salvator-x_defconfig | 2 +- configs/sama5d2_ptc_nandflash_defconfig | 2 +- configs/sama5d2_ptc_spiflash_defconfig | 2 +- configs/sbc8349_PCI_33_defconfig | 2 +- configs/sbc8349_PCI_66_defconfig | 2 +- configs/sbc8349_defconfig | 2 +- configs/sbc8548_PCI_33_PCIE_defconfig | 2 +- configs/sbc8548_PCI_33_defconfig | 2 +- configs/sbc8548_PCI_66_PCIE_defconfig | 2 +- configs/sbc8548_PCI_66_defconfig | 2 +- configs/sbc8548_defconfig | 2 +- configs/sbc8641d_defconfig | 2 +- configs/sequoia_defconfig | 2 +- configs/sequoia_ramboot_defconfig | 2 +- configs/sh7752evb_defconfig | 2 +- configs/sh7753evb_defconfig | 2 +- configs/sh7757lcr_defconfig | 2 +- configs/smartweb_defconfig | 2 +- configs/smdkc100_defconfig | 2 +- configs/snapper9260_defconfig | 2 +- configs/snapper9g20_defconfig | 2 +- configs/snow_defconfig | 2 +- configs/socfpga_is1_defconfig | 2 +- configs/socrates_defconfig | 2 +- configs/spear300_defconfig | 2 +- configs/spear300_nand_defconfig | 2 +- configs/spear300_usbtty_defconfig | 2 +- configs/spear300_usbtty_nand_defconfig | 2 +- configs/spear310_defconfig | 2 +- configs/spear310_nand_defconfig | 2 +- configs/spear310_pnor_defconfig | 2 +- configs/spear310_usbtty_defconfig | 2 +- configs/spear310_usbtty_nand_defconfig | 2 +- configs/spear310_usbtty_pnor_defconfig | 2 +- configs/spear320_defconfig | 2 +- configs/spear320_nand_defconfig | 2 +- configs/spear320_pnor_defconfig | 2 +- configs/spear320_usbtty_defconfig | 2 +- configs/spear320_usbtty_nand_defconfig | 2 +- configs/spear320_usbtty_pnor_defconfig | 2 +- configs/spear600_defconfig | 2 +- configs/spear600_nand_defconfig | 2 +- configs/spear600_usbtty_defconfig | 2 +- configs/spear600_usbtty_nand_defconfig | 2 +- configs/spring_defconfig | 2 +- configs/stm32f429-discovery_defconfig | 2 +- configs/stm32f746-disco_defconfig | 2 +- configs/stv0991_defconfig | 2 +- configs/suvd3_defconfig | 2 +- configs/sycamore_defconfig | 2 +- configs/t3corp_defconfig | 2 +- configs/taurus_defconfig | 2 +- configs/tcm-bf537_defconfig | 2 +- configs/theadorable-x86-dfi-bt700_defconfig | 2 +- configs/theadorable_debug_defconfig | 2 +- configs/theadorable_defconfig | 2 +- configs/thunderx_88xx_defconfig | 2 +- configs/tuge1_defconfig | 2 +- configs/tuxx1_defconfig | 2 +- configs/usb_a9263_dataflash_defconfig | 2 +- configs/v38b_defconfig | 2 +- configs/ve8313_defconfig | 2 +- configs/vexpress_aemv8a_dram_defconfig | 2 +- configs/vexpress_aemv8a_juno_defconfig | 2 +- configs/vexpress_aemv8a_semi_defconfig | 2 +- configs/vme8349_defconfig | 2 +- configs/walnut_defconfig | 2 +- configs/work_92105_defconfig | 2 +- configs/wtk_defconfig | 2 +- configs/xilinx-ppc405-generic_defconfig | 2 +- configs/xilinx-ppc440-generic_defconfig | 2 +- configs/xpedite1000_defconfig | 2 +- configs/xpedite517x_defconfig | 2 +- configs/xpedite520x_defconfig | 2 +- configs/xpedite537x_defconfig | 2 +- configs/xpedite550x_defconfig | 2 +- configs/yellowstone_defconfig | 2 +- configs/yosemite_defconfig | 2 +- configs/yucca_defconfig | 2 +- 404 files changed, 619 insertions(+), 635 deletions(-)
diff --git a/configs/B4420QDS_NAND_defconfig b/configs/B4420QDS_NAND_defconfig index 5ee32b861e..5e6ff21718 100644 --- a/configs/B4420QDS_NAND_defconfig +++ b/configs/B4420QDS_NAND_defconfig @@ -6,7 +6,6 @@ CONFIG_SPL_NAND_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y -# CONFIG_MMC is not set CONFIG_MPC85xx=y CONFIG_TARGET_B4420QDS=y CONFIG_FIT=y @@ -27,6 +26,7 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y +# CONFIG_MMC is not set CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y CONFIG_NETDEVICES=y diff --git a/configs/B4420QDS_SPIFLASH_defconfig b/configs/B4420QDS_SPIFLASH_defconfig index 69e47a2226..0f3ab5bcf8 100644 --- a/configs/B4420QDS_SPIFLASH_defconfig +++ b/configs/B4420QDS_SPIFLASH_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_MPC85xx=y CONFIG_TARGET_B4420QDS=y CONFIG_FIT=y @@ -18,6 +17,7 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y +# CONFIG_MMC is not set CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y CONFIG_NETDEVICES=y diff --git a/configs/B4420QDS_defconfig b/configs/B4420QDS_defconfig index abc6a7c8de..cab6569ccb 100644 --- a/configs/B4420QDS_defconfig +++ b/configs/B4420QDS_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_MPC85xx=y CONFIG_TARGET_B4420QDS=y CONFIG_FIT=y @@ -17,6 +16,7 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y +# CONFIG_MMC is not set CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y CONFIG_NETDEVICES=y diff --git a/configs/B4860QDS_NAND_defconfig b/configs/B4860QDS_NAND_defconfig index 56e7318eb8..2376287ac1 100644 --- a/configs/B4860QDS_NAND_defconfig +++ b/configs/B4860QDS_NAND_defconfig @@ -6,7 +6,6 @@ CONFIG_SPL_NAND_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y -# CONFIG_MMC is not set CONFIG_MPC85xx=y CONFIG_TARGET_B4860QDS=y CONFIG_FIT=y @@ -27,6 +26,7 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y +# CONFIG_MMC is not set CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y CONFIG_NETDEVICES=y diff --git a/configs/B4860QDS_SPIFLASH_defconfig b/configs/B4860QDS_SPIFLASH_defconfig index 9bebdf7f04..6d7ed6b6ae 100644 --- a/configs/B4860QDS_SPIFLASH_defconfig +++ b/configs/B4860QDS_SPIFLASH_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_MPC85xx=y CONFIG_TARGET_B4860QDS=y CONFIG_FIT=y @@ -18,6 +17,7 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y +# CONFIG_MMC is not set CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y CONFIG_NETDEVICES=y diff --git a/configs/B4860QDS_SRIO_PCIE_BOOT_defconfig b/configs/B4860QDS_SRIO_PCIE_BOOT_defconfig index d832455449..28a081a600 100644 --- a/configs/B4860QDS_SRIO_PCIE_BOOT_defconfig +++ b/configs/B4860QDS_SRIO_PCIE_BOOT_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_MPC85xx=y CONFIG_TARGET_B4860QDS=y CONFIG_FIT=y @@ -20,6 +19,7 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y +# CONFIG_MMC is not set CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y CONFIG_NETDEVICES=y diff --git a/configs/B4860QDS_defconfig b/configs/B4860QDS_defconfig index fd00b60e2c..3b8164cf8a 100644 --- a/configs/B4860QDS_defconfig +++ b/configs/B4860QDS_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_MPC85xx=y CONFIG_TARGET_B4860QDS=y CONFIG_FIT=y @@ -17,6 +16,7 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y +# CONFIG_MMC is not set CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y CONFIG_NETDEVICES=y diff --git a/configs/BSC9131RDB_NAND_SYSCLK100_defconfig b/configs/BSC9131RDB_NAND_SYSCLK100_defconfig index 8c1ab70d44..be3b400836 100644 --- a/configs/BSC9131RDB_NAND_SYSCLK100_defconfig +++ b/configs/BSC9131RDB_NAND_SYSCLK100_defconfig @@ -1,7 +1,6 @@ CONFIG_PPC=y CONFIG_SPL_NAND_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y -# CONFIG_MMC is not set CONFIG_MPC85xx=y CONFIG_TARGET_BSC9131RDB=y CONFIG_FIT=y @@ -23,6 +22,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +# CONFIG_MMC is not set CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y # CONFIG_PCI is not set diff --git a/configs/BSC9131RDB_NAND_defconfig b/configs/BSC9131RDB_NAND_defconfig index f8de2e6dc6..7f34c3e6dc 100644 --- a/configs/BSC9131RDB_NAND_defconfig +++ b/configs/BSC9131RDB_NAND_defconfig @@ -1,7 +1,6 @@ CONFIG_PPC=y CONFIG_SPL_NAND_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y -# CONFIG_MMC is not set CONFIG_MPC85xx=y CONFIG_TARGET_BSC9131RDB=y CONFIG_FIT=y @@ -23,6 +22,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +# CONFIG_MMC is not set CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y # CONFIG_PCI is not set diff --git a/configs/BSC9131RDB_SPIFLASH_SYSCLK100_defconfig b/configs/BSC9131RDB_SPIFLASH_SYSCLK100_defconfig index 940b5363b5..97da915c41 100644 --- a/configs/BSC9131RDB_SPIFLASH_SYSCLK100_defconfig +++ b/configs/BSC9131RDB_SPIFLASH_SYSCLK100_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_MPC85xx=y CONFIG_TARGET_BSC9131RDB=y CONFIG_FIT=y @@ -20,6 +19,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +# CONFIG_MMC is not set CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y # CONFIG_PCI is not set diff --git a/configs/BSC9131RDB_SPIFLASH_defconfig b/configs/BSC9131RDB_SPIFLASH_defconfig index 481fd9285d..3dd8e439de 100644 --- a/configs/BSC9131RDB_SPIFLASH_defconfig +++ b/configs/BSC9131RDB_SPIFLASH_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_MPC85xx=y CONFIG_TARGET_BSC9131RDB=y CONFIG_FIT=y @@ -20,6 +19,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +# CONFIG_MMC is not set CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y # CONFIG_PCI is not set diff --git a/configs/C29XPCIE_NAND_defconfig b/configs/C29XPCIE_NAND_defconfig index e2490dc134..9a9e0cae23 100644 --- a/configs/C29XPCIE_NAND_defconfig +++ b/configs/C29XPCIE_NAND_defconfig @@ -2,7 +2,6 @@ CONFIG_PPC=y CONFIG_SPL_NAND_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y -# CONFIG_MMC is not set CONFIG_MPC85xx=y CONFIG_TARGET_C29XPCIE=y CONFIG_FIT=y @@ -25,6 +24,7 @@ CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y +# CONFIG_MMC is not set CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_EON=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/C29XPCIE_SPIFLASH_defconfig b/configs/C29XPCIE_SPIFLASH_defconfig index dc536a71ea..83c60f04b1 100644 --- a/configs/C29XPCIE_SPIFLASH_defconfig +++ b/configs/C29XPCIE_SPIFLASH_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_MPC85xx=y CONFIG_TARGET_C29XPCIE=y CONFIG_FIT=y @@ -14,6 +13,7 @@ CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y +# CONFIG_MMC is not set CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_EON=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/C29XPCIE_defconfig b/configs/C29XPCIE_defconfig index 5d7f03e9df..257bad3986 100644 --- a/configs/C29XPCIE_defconfig +++ b/configs/C29XPCIE_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_MPC85xx=y CONFIG_TARGET_C29XPCIE=y CONFIG_FIT=y @@ -13,6 +12,7 @@ CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y +# CONFIG_MMC is not set CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_EON=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/CHIP_defconfig b/configs/CHIP_defconfig index 65d0c9847a..762efd0d65 100644 --- a/configs/CHIP_defconfig +++ b/configs/CHIP_defconfig @@ -4,7 +4,6 @@ CONFIG_SPL_I2C_SUPPORT=y # CONFIG_SPL_MMC_SUPPORT is not set CONFIG_MACH_SUN5I=y CONFIG_DRAM_TIMINGS_DDR3_800E_1066G_1333J=y -# CONFIG_MMC is not set CONFIG_USB0_VBUS_PIN="PB10" CONFIG_VIDEO_COMPOSITE=y CONFIG_DEFAULT_DEVICE_TREE="sun5i-r8-chip" @@ -14,6 +13,7 @@ CONFIG_SPL=y CONFIG_CMD_DFU=y CONFIG_CMD_USB_MASS_STORAGE=y CONFIG_DFU_RAM=y +# CONFIG_MMC is not set CONFIG_AXP_ALDO3_VOLT=3300 CONFIG_AXP_ALDO4_VOLT=3300 CONFIG_USB_EHCI_HCD=y diff --git a/configs/CPCI2DP_defconfig b/configs/CPCI2DP_defconfig index 2dfd63c09a..ea7c899c9d 100644 --- a/configs/CPCI2DP_defconfig +++ b/configs/CPCI2DP_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_4xx=y CONFIG_TARGET_CPCI2DP=y CONFIG_BOOTDELAY=3 @@ -10,4 +9,5 @@ CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NET is not set # CONFIG_CMD_NFS is not set +# CONFIG_MMC is not set CONFIG_SYS_NS16550=y diff --git a/configs/CPCI4052_defconfig b/configs/CPCI4052_defconfig index b5135f7023..15f1370168 100644 --- a/configs/CPCI4052_defconfig +++ b/configs/CPCI4052_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_4xx=y CONFIG_TARGET_CPCI4052=y CONFIG_OF_BOARD_SETUP=y @@ -16,5 +15,6 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y +# CONFIG_MMC is not set CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/MIP405T_defconfig b/configs/MIP405T_defconfig index 76d0ef4d9a..57b3c12568 100644 --- a/configs/MIP405T_defconfig +++ b/configs/MIP405T_defconfig @@ -1,6 +1,5 @@ CONFIG_PPC=y CONFIG_IDENT_STRING="\n(c) 2003 by MPL AG Switzerland, MEV-10082-001 released" -# CONFIG_MMC is not set CONFIG_VIDEO=y CONFIG_4xx=y CONFIG_TARGET_MIP405T=y @@ -18,6 +17,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_CMD_FAT=y +# CONFIG_MMC is not set CONFIG_SYS_NS16550=y CONFIG_CONSOLE_EXTRA_INFO=y CONFIG_VIDEO_CT69000=y diff --git a/configs/MIP405_defconfig b/configs/MIP405_defconfig index 0c358f98b8..a6acd51936 100644 --- a/configs/MIP405_defconfig +++ b/configs/MIP405_defconfig @@ -1,6 +1,5 @@ CONFIG_PPC=y CONFIG_IDENT_STRING="\n(c) 2003 by MPL AG Switzerland, MEV-10072-001 released" -# CONFIG_MMC is not set CONFIG_VIDEO=y CONFIG_4xx=y CONFIG_TARGET_MIP405=y @@ -19,6 +18,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_CMD_FAT=y +# CONFIG_MMC is not set CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/MPC8313ERDB_33_defconfig b/configs/MPC8313ERDB_33_defconfig index 2513632178..340934748e 100644 --- a/configs/MPC8313ERDB_33_defconfig +++ b/configs/MPC8313ERDB_33_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_MPC83xx=y CONFIG_TARGET_MPC8313ERDB=y CONFIG_OF_BOARD_SETUP=y @@ -13,5 +12,6 @@ CONFIG_CMD_GPIO=y CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y +# CONFIG_MMC is not set CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/MPC8313ERDB_66_defconfig b/configs/MPC8313ERDB_66_defconfig index 9d611fcdc8..f832087072 100644 --- a/configs/MPC8313ERDB_66_defconfig +++ b/configs/MPC8313ERDB_66_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_MPC83xx=y CONFIG_TARGET_MPC8313ERDB=y CONFIG_OF_BOARD_SETUP=y @@ -13,5 +12,6 @@ CONFIG_CMD_GPIO=y CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y +# CONFIG_MMC is not set CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/MPC8313ERDB_NAND_33_defconfig b/configs/MPC8313ERDB_NAND_33_defconfig index 79a9c27205..7fb8b5bebe 100644 --- a/configs/MPC8313ERDB_NAND_33_defconfig +++ b/configs/MPC8313ERDB_NAND_33_defconfig @@ -1,7 +1,6 @@ CONFIG_PPC=y CONFIG_SPL_NAND_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y -# CONFIG_MMC is not set CONFIG_MPC83xx=y CONFIG_TARGET_MPC8313ERDB=y CONFIG_OF_BOARD_SETUP=y @@ -16,5 +15,6 @@ CONFIG_CMD_GPIO=y CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y +# CONFIG_MMC is not set CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/MPC8313ERDB_NAND_66_defconfig b/configs/MPC8313ERDB_NAND_66_defconfig index aa4a1c4300..b7ce47a874 100644 --- a/configs/MPC8313ERDB_NAND_66_defconfig +++ b/configs/MPC8313ERDB_NAND_66_defconfig @@ -1,7 +1,6 @@ CONFIG_PPC=y CONFIG_SPL_NAND_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y -# CONFIG_MMC is not set CONFIG_MPC83xx=y CONFIG_TARGET_MPC8313ERDB=y CONFIG_OF_BOARD_SETUP=y @@ -16,5 +15,6 @@ CONFIG_CMD_GPIO=y CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y +# CONFIG_MMC is not set CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/MPC8315ERDB_defconfig b/configs/MPC8315ERDB_defconfig index 4e2b705fcf..08b3759b8c 100644 --- a/configs/MPC8315ERDB_defconfig +++ b/configs/MPC8315ERDB_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_MPC83xx=y CONFIG_TARGET_MPC8315ERDB=y CONFIG_OF_BOARD_SETUP=y @@ -12,6 +11,7 @@ CONFIG_CMD_USB=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y +# CONFIG_MMC is not set CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/MPC8323ERDB_defconfig b/configs/MPC8323ERDB_defconfig index 043ab9b01a..0f7cf8175a 100644 --- a/configs/MPC8323ERDB_defconfig +++ b/configs/MPC8323ERDB_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_MPC83xx=y CONFIG_TARGET_MPC8323ERDB=y CONFIG_OF_BOARD_SETUP=y @@ -10,5 +9,6 @@ CONFIG_CMD_ASKENV=y CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_PING=y +# CONFIG_MMC is not set CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/MPC832XEMDS_ATM_defconfig b/configs/MPC832XEMDS_ATM_defconfig index 7d5914918d..c3643ecdd8 100644 --- a/configs/MPC832XEMDS_ATM_defconfig +++ b/configs/MPC832XEMDS_ATM_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_MPC83xx=y CONFIG_TARGET_MPC832XEMDS=y CONFIG_OF_BOARD_SETUP=y @@ -11,6 +10,7 @@ CONFIG_CMD_ASKENV=y CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_PING=y +# CONFIG_MMC is not set # CONFIG_PCI is not set CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/MPC832XEMDS_HOST_33_defconfig b/configs/MPC832XEMDS_HOST_33_defconfig index 5a53b1d204..6c26716cfe 100644 --- a/configs/MPC832XEMDS_HOST_33_defconfig +++ b/configs/MPC832XEMDS_HOST_33_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_MPC83xx=y CONFIG_TARGET_MPC832XEMDS=y CONFIG_OF_BOARD_SETUP=y @@ -11,5 +10,6 @@ CONFIG_CMD_ASKENV=y CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_PING=y +# CONFIG_MMC is not set CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/MPC832XEMDS_HOST_66_defconfig b/configs/MPC832XEMDS_HOST_66_defconfig index 9a47c62367..deb9bde103 100644 --- a/configs/MPC832XEMDS_HOST_66_defconfig +++ b/configs/MPC832XEMDS_HOST_66_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_MPC83xx=y CONFIG_TARGET_MPC832XEMDS=y CONFIG_OF_BOARD_SETUP=y @@ -11,5 +10,6 @@ CONFIG_CMD_ASKENV=y CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_PING=y +# CONFIG_MMC is not set CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/MPC832XEMDS_SLAVE_defconfig b/configs/MPC832XEMDS_SLAVE_defconfig index cdd3d77100..c62e665ff6 100644 --- a/configs/MPC832XEMDS_SLAVE_defconfig +++ b/configs/MPC832XEMDS_SLAVE_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_MPC83xx=y CONFIG_TARGET_MPC832XEMDS=y CONFIG_OF_BOARD_SETUP=y @@ -11,5 +10,6 @@ CONFIG_CMD_ASKENV=y CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_PING=y +# CONFIG_MMC is not set CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/MPC832XEMDS_defconfig b/configs/MPC832XEMDS_defconfig index af617e61da..4bd24ba70a 100644 --- a/configs/MPC832XEMDS_defconfig +++ b/configs/MPC832XEMDS_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_MPC83xx=y CONFIG_TARGET_MPC832XEMDS=y CONFIG_OF_BOARD_SETUP=y @@ -10,6 +9,7 @@ CONFIG_CMD_ASKENV=y CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_PING=y +# CONFIG_MMC is not set # CONFIG_PCI is not set CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/MPC8349EMDS_defconfig b/configs/MPC8349EMDS_defconfig index 3a8844e51b..4074c09d90 100644 --- a/configs/MPC8349EMDS_defconfig +++ b/configs/MPC8349EMDS_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_MPC83xx=y CONFIG_TARGET_MPC8349EMDS=y CONFIG_OF_BOARD_SETUP=y @@ -10,6 +9,7 @@ CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_MII=y CONFIG_CMD_PING=y +# CONFIG_MMC is not set # CONFIG_PCI is not set CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/MPC8349ITXGP_defconfig b/configs/MPC8349ITXGP_defconfig index e85ec166f5..d49de1a45f 100644 --- a/configs/MPC8349ITXGP_defconfig +++ b/configs/MPC8349ITXGP_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_MPC83xx=y CONFIG_TARGET_MPC8349ITX=y CONFIG_OF_BOARD_SETUP=y @@ -13,5 +12,6 @@ CONFIG_CMD_I2C=y CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y +# CONFIG_MMC is not set CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/MPC8349ITX_LOWBOOT_defconfig b/configs/MPC8349ITX_LOWBOOT_defconfig index 56e9607cdc..f179c72bdc 100644 --- a/configs/MPC8349ITX_LOWBOOT_defconfig +++ b/configs/MPC8349ITX_LOWBOOT_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_MPC83xx=y CONFIG_TARGET_MPC8349ITX=y CONFIG_OF_BOARD_SETUP=y @@ -16,6 +15,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +# CONFIG_MMC is not set CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/MPC8349ITX_defconfig b/configs/MPC8349ITX_defconfig index 8cdcf2b15e..c44fd02713 100644 --- a/configs/MPC8349ITX_defconfig +++ b/configs/MPC8349ITX_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_MPC83xx=y CONFIG_TARGET_MPC8349ITX=y CONFIG_OF_BOARD_SETUP=y @@ -16,6 +15,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +# CONFIG_MMC is not set CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/MPC8540ADS_defconfig b/configs/MPC8540ADS_defconfig index 629111162b..23b3114b4c 100644 --- a/configs/MPC8540ADS_defconfig +++ b/configs/MPC8540ADS_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_MPC85xx=y CONFIG_TARGET_MPC8540ADS=y CONFIG_OF_BOARD_SETUP=y @@ -8,5 +7,6 @@ CONFIG_BOOTDELAY=10 CONFIG_HUSH_PARSER=y CONFIG_CMD_I2C=y CONFIG_CMD_PING=y +# CONFIG_MMC is not set CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/MPC8541CDS_defconfig b/configs/MPC8541CDS_defconfig index fc0aa99580..856889124f 100644 --- a/configs/MPC8541CDS_defconfig +++ b/configs/MPC8541CDS_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_MPC85xx=y CONFIG_TARGET_MPC8541CDS=y CONFIG_OF_BOARD_SETUP=y @@ -9,5 +8,6 @@ CONFIG_HUSH_PARSER=y CONFIG_CMD_I2C=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y +# CONFIG_MMC is not set CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/MPC8541CDS_legacy_defconfig b/configs/MPC8541CDS_legacy_defconfig index 61eed37185..39a4f2a68b 100644 --- a/configs/MPC8541CDS_legacy_defconfig +++ b/configs/MPC8541CDS_legacy_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_MPC85xx=y CONFIG_TARGET_MPC8541CDS=y CONFIG_OF_BOARD_SETUP=y @@ -10,5 +9,6 @@ CONFIG_HUSH_PARSER=y CONFIG_CMD_I2C=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y +# CONFIG_MMC is not set CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/MPC8544DS_defconfig b/configs/MPC8544DS_defconfig index d160f045e3..9f0dcd47a6 100644 --- a/configs/MPC8544DS_defconfig +++ b/configs/MPC8544DS_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_VIDEO=y CONFIG_MPC85xx=y CONFIG_TARGET_MPC8544DS=y @@ -13,6 +12,7 @@ CONFIG_CMD_USB=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y +# CONFIG_MMC is not set CONFIG_NETDEVICES=y CONFIG_E1000=y CONFIG_RTL8139=y diff --git a/configs/MPC8548CDS_36BIT_defconfig b/configs/MPC8548CDS_36BIT_defconfig index 65e937f769..02e2ff2526 100644 --- a/configs/MPC8548CDS_36BIT_defconfig +++ b/configs/MPC8548CDS_36BIT_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_MPC85xx=y CONFIG_TARGET_MPC8548CDS=y CONFIG_PHYS_64BIT=y @@ -10,6 +9,7 @@ CONFIG_HUSH_PARSER=y CONFIG_CMD_I2C=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y +# CONFIG_MMC is not set CONFIG_NETDEVICES=y CONFIG_E1000=y CONFIG_SYS_NS16550=y diff --git a/configs/MPC8548CDS_defconfig b/configs/MPC8548CDS_defconfig index 684217003a..9ea163459c 100644 --- a/configs/MPC8548CDS_defconfig +++ b/configs/MPC8548CDS_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_MPC85xx=y CONFIG_TARGET_MPC8548CDS=y CONFIG_OF_BOARD_SETUP=y @@ -9,6 +8,7 @@ CONFIG_HUSH_PARSER=y CONFIG_CMD_I2C=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y +# CONFIG_MMC is not set CONFIG_NETDEVICES=y CONFIG_E1000=y CONFIG_SYS_NS16550=y diff --git a/configs/MPC8548CDS_legacy_defconfig b/configs/MPC8548CDS_legacy_defconfig index defdfc0ff8..3398f46468 100644 --- a/configs/MPC8548CDS_legacy_defconfig +++ b/configs/MPC8548CDS_legacy_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_MPC85xx=y CONFIG_TARGET_MPC8548CDS=y CONFIG_OF_BOARD_SETUP=y @@ -10,6 +9,7 @@ CONFIG_HUSH_PARSER=y CONFIG_CMD_I2C=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y +# CONFIG_MMC is not set CONFIG_NETDEVICES=y CONFIG_E1000=y CONFIG_SYS_NS16550=y diff --git a/configs/MPC8555CDS_defconfig b/configs/MPC8555CDS_defconfig index 9f9168ae35..413c8f0bae 100644 --- a/configs/MPC8555CDS_defconfig +++ b/configs/MPC8555CDS_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_MPC85xx=y CONFIG_TARGET_MPC8555CDS=y CONFIG_OF_BOARD_SETUP=y @@ -9,5 +8,6 @@ CONFIG_HUSH_PARSER=y CONFIG_CMD_I2C=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y +# CONFIG_MMC is not set CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/MPC8555CDS_legacy_defconfig b/configs/MPC8555CDS_legacy_defconfig index 51d17ad4eb..76a5abe502 100644 --- a/configs/MPC8555CDS_legacy_defconfig +++ b/configs/MPC8555CDS_legacy_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_MPC85xx=y CONFIG_TARGET_MPC8555CDS=y CONFIG_OF_BOARD_SETUP=y @@ -10,5 +9,6 @@ CONFIG_HUSH_PARSER=y CONFIG_CMD_I2C=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y +# CONFIG_MMC is not set CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/MPC8560ADS_defconfig b/configs/MPC8560ADS_defconfig index 5a8cc2697a..28c65d6920 100644 --- a/configs/MPC8560ADS_defconfig +++ b/configs/MPC8560ADS_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_MPC85xx=y CONFIG_TARGET_MPC8560ADS=y CONFIG_OF_BOARD_SETUP=y @@ -8,4 +7,5 @@ CONFIG_BOOTDELAY=10 CONFIG_HUSH_PARSER=y CONFIG_CMD_I2C=y CONFIG_CMD_PING=y +# CONFIG_MMC is not set CONFIG_OF_LIBFDT=y diff --git a/configs/MPC8568MDS_defconfig b/configs/MPC8568MDS_defconfig index c6bc814ae0..21424ffa4d 100644 --- a/configs/MPC8568MDS_defconfig +++ b/configs/MPC8568MDS_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_MPC85xx=y CONFIG_TARGET_MPC8568MDS=y CONFIG_OF_BOARD_SETUP=y @@ -9,5 +8,6 @@ CONFIG_HUSH_PARSER=y CONFIG_CMD_I2C=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y +# CONFIG_MMC is not set CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/MPC8572DS_36BIT_defconfig b/configs/MPC8572DS_36BIT_defconfig index 64210eb12a..7f52737336 100644 --- a/configs/MPC8572DS_36BIT_defconfig +++ b/configs/MPC8572DS_36BIT_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_VIDEO=y CONFIG_MPC85xx=y CONFIG_TARGET_MPC8572DS=y @@ -17,6 +16,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_SYS_FSL_DDR2=y +# CONFIG_MMC is not set CONFIG_NETDEVICES=y CONFIG_E1000=y CONFIG_SYS_NS16550=y diff --git a/configs/MPC8572DS_defconfig b/configs/MPC8572DS_defconfig index 1c6765de07..0ae985e0e9 100644 --- a/configs/MPC8572DS_defconfig +++ b/configs/MPC8572DS_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_VIDEO=y CONFIG_MPC85xx=y CONFIG_TARGET_MPC8572DS=y @@ -16,6 +15,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_SYS_FSL_DDR2=y +# CONFIG_MMC is not set CONFIG_NETDEVICES=y CONFIG_E1000=y CONFIG_SYS_NS16550=y diff --git a/configs/MPC8610HPCD_defconfig b/configs/MPC8610HPCD_defconfig index 563896d303..b84bfeb01a 100644 --- a/configs/MPC8610HPCD_defconfig +++ b/configs/MPC8610HPCD_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_VIDEO=y CONFIG_MPC86xx=y CONFIG_TARGET_MPC8610HPCD=y @@ -14,6 +13,7 @@ CONFIG_CMD_USB=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y +# CONFIG_MMC is not set CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_KEYBOARD=y diff --git a/configs/MPC8641HPCN_36BIT_defconfig b/configs/MPC8641HPCN_36BIT_defconfig index 9bd0e3d5db..11211747f6 100644 --- a/configs/MPC8641HPCN_36BIT_defconfig +++ b/configs/MPC8641HPCN_36BIT_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_VIDEO=y CONFIG_MPC86xx=y CONFIG_TARGET_MPC8641HPCN=y @@ -14,6 +13,7 @@ CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y +# CONFIG_MMC is not set CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_KEYBOARD=y diff --git a/configs/MPC8641HPCN_defconfig b/configs/MPC8641HPCN_defconfig index 43a5290359..39d9bffca1 100644 --- a/configs/MPC8641HPCN_defconfig +++ b/configs/MPC8641HPCN_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_VIDEO=y CONFIG_MPC86xx=y CONFIG_TARGET_MPC8641HPCN=y @@ -13,6 +12,7 @@ CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y +# CONFIG_MMC is not set CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_KEYBOARD=y diff --git a/configs/MiniFAP_defconfig b/configs/MiniFAP_defconfig index ff79c12853..8a929fc63f 100644 --- a/configs/MiniFAP_defconfig +++ b/configs/MiniFAP_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_VIDEO=y CONFIG_MPC5xxx=y CONFIG_TARGET_TQM5200=y @@ -20,6 +19,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_SNTP=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +# CONFIG_MMC is not set CONFIG_USB=y CONFIG_USB_STORAGE=y CONFIG_CONSOLE_EXTRA_INFO=y diff --git a/configs/Nintendo_NES_Classic_Edition_defconfig b/configs/Nintendo_NES_Classic_Edition_defconfig index fcda1be031..1c704b4539 100644 --- a/configs/Nintendo_NES_Classic_Edition_defconfig +++ b/configs/Nintendo_NES_Classic_Edition_defconfig @@ -5,7 +5,6 @@ CONFIG_MACH_SUN8I_A33=y CONFIG_DRAM_CLK=600 CONFIG_DRAM_ZQ=15291 CONFIG_DRAM_ODT_EN=y -# CONFIG_MMC is not set CONFIG_USB0_VBUS_DET="AXP0-VBUS-DETECT" CONFIG_AXP_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="sun8i-r16-nintendo-nes-classic-edition" @@ -14,6 +13,7 @@ CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +# CONFIG_MMC is not set CONFIG_AXP_DLDO1_VOLT=3300 CONFIG_AXP_ELDO2_VOLT=1800 CONFIG_USB_MUSB_GADGET=y diff --git a/configs/O2D300_defconfig b/configs/O2D300_defconfig index 36c55b6627..7c3479e1c4 100644 --- a/configs/O2D300_defconfig +++ b/configs/O2D300_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_MPC5xxx=y CONFIG_TARGET_O2D300=y CONFIG_OF_BOARD_SETUP=y @@ -11,5 +10,6 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y +# CONFIG_MMC is not set # CONFIG_PCI is not set CONFIG_OF_LIBFDT=y diff --git a/configs/O2DNT2_RAMBOOT_defconfig b/configs/O2DNT2_RAMBOOT_defconfig index b374c281da..9868e9eb14 100644 --- a/configs/O2DNT2_RAMBOOT_defconfig +++ b/configs/O2DNT2_RAMBOOT_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_MPC5xxx=y CONFIG_TARGET_O2DNT2=y CONFIG_OF_BOARD_SETUP=y @@ -15,5 +14,6 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y +# CONFIG_MMC is not set # CONFIG_PCI is not set CONFIG_OF_LIBFDT=y diff --git a/configs/O2DNT2_defconfig b/configs/O2DNT2_defconfig index 00a713b95f..36000d988c 100644 --- a/configs/O2DNT2_defconfig +++ b/configs/O2DNT2_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_MPC5xxx=y CONFIG_TARGET_O2DNT2=y CONFIG_OF_BOARD_SETUP=y @@ -14,5 +13,6 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y +# CONFIG_MMC is not set # CONFIG_PCI is not set CONFIG_OF_LIBFDT=y diff --git a/configs/O2D_defconfig b/configs/O2D_defconfig index 9bc2342b40..4099d20532 100644 --- a/configs/O2D_defconfig +++ b/configs/O2D_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_MPC5xxx=y CONFIG_TARGET_O2D=y CONFIG_OF_BOARD_SETUP=y @@ -11,5 +10,6 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y +# CONFIG_MMC is not set # CONFIG_PCI is not set CONFIG_OF_LIBFDT=y diff --git a/configs/O2I_defconfig b/configs/O2I_defconfig index 2f3276ccf1..85343b93f5 100644 --- a/configs/O2I_defconfig +++ b/configs/O2I_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_MPC5xxx=y CONFIG_TARGET_O2I=y CONFIG_OF_BOARD_SETUP=y @@ -11,5 +10,6 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y +# CONFIG_MMC is not set # CONFIG_PCI is not set CONFIG_OF_LIBFDT=y diff --git a/configs/O2MNT_O2M110_defconfig b/configs/O2MNT_O2M110_defconfig index 57c9f7bfa6..cdf0f70021 100644 --- a/configs/O2MNT_O2M110_defconfig +++ b/configs/O2MNT_O2M110_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_MPC5xxx=y CONFIG_TARGET_O2MNT=y CONFIG_OF_BOARD_SETUP=y @@ -12,5 +11,6 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y +# CONFIG_MMC is not set # CONFIG_PCI is not set CONFIG_OF_LIBFDT=y diff --git a/configs/O2MNT_O2M112_defconfig b/configs/O2MNT_O2M112_defconfig index 3afa43bd45..c7530a8f0e 100644 --- a/configs/O2MNT_O2M112_defconfig +++ b/configs/O2MNT_O2M112_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_MPC5xxx=y CONFIG_TARGET_O2MNT=y CONFIG_OF_BOARD_SETUP=y @@ -12,5 +11,6 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y +# CONFIG_MMC is not set # CONFIG_PCI is not set CONFIG_OF_LIBFDT=y diff --git a/configs/O2MNT_O2M113_defconfig b/configs/O2MNT_O2M113_defconfig index a543a3bde5..82df62e10c 100644 --- a/configs/O2MNT_O2M113_defconfig +++ b/configs/O2MNT_O2M113_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_MPC5xxx=y CONFIG_TARGET_O2MNT=y CONFIG_OF_BOARD_SETUP=y @@ -12,5 +11,6 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y +# CONFIG_MMC is not set # CONFIG_PCI is not set CONFIG_OF_LIBFDT=y diff --git a/configs/O2MNT_defconfig b/configs/O2MNT_defconfig index 859ba732ce..09fac6ad66 100644 --- a/configs/O2MNT_defconfig +++ b/configs/O2MNT_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_MPC5xxx=y CONFIG_TARGET_O2MNT=y CONFIG_OF_BOARD_SETUP=y @@ -11,5 +10,6 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y +# CONFIG_MMC is not set # CONFIG_PCI is not set CONFIG_OF_LIBFDT=y diff --git a/configs/O3DNT_defconfig b/configs/O3DNT_defconfig index c4f2f69dbf..2db767856f 100644 --- a/configs/O3DNT_defconfig +++ b/configs/O3DNT_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_MPC5xxx=y CONFIG_TARGET_O3DNT=y CONFIG_OF_BOARD_SETUP=y @@ -11,5 +10,6 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y +# CONFIG_MMC is not set # CONFIG_PCI is not set CONFIG_OF_LIBFDT=y diff --git a/configs/P1023RDB_defconfig b/configs/P1023RDB_defconfig index 3001575aa0..728130437c 100644 --- a/configs/P1023RDB_defconfig +++ b/configs/P1023RDB_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_MPC85xx=y CONFIG_TARGET_P1023RDB=y CONFIG_FIT=y @@ -14,6 +13,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +# CONFIG_MMC is not set CONFIG_NETDEVICES=y CONFIG_E1000=y CONFIG_SYS_NS16550=y diff --git a/configs/PATI_defconfig b/configs/PATI_defconfig index ae1c1b6af0..fe0b0b8dd2 100644 --- a/configs/PATI_defconfig +++ b/configs/PATI_defconfig @@ -1,6 +1,5 @@ CONFIG_PPC=y CONFIG_IDENT_STRING="\n(c) 2003 by MPL AG Switzerland, MEV-10084-001 released" -# CONFIG_MMC is not set CONFIG_5xx=y CONFIG_TARGET_PATI=y CONFIG_BOOTDELAY=5 @@ -19,4 +18,5 @@ CONFIG_SYS_PROMPT="pati=> " # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NET is not set # CONFIG_CMD_NFS is not set +# CONFIG_MMC is not set # CONFIG_PCI is not set diff --git a/configs/PIP405_defconfig b/configs/PIP405_defconfig index 229448f9c4..5e54e75667 100644 --- a/configs/PIP405_defconfig +++ b/configs/PIP405_defconfig @@ -1,6 +1,5 @@ CONFIG_PPC=y CONFIG_IDENT_STRING="\n(c) 2002 by MPL AG Switzerland, MEV-10066-001 released" -# CONFIG_MMC is not set CONFIG_VIDEO=y CONFIG_4xx=y CONFIG_TARGET_PIP405=y @@ -19,6 +18,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_CMD_FAT=y +# CONFIG_MMC is not set CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/PLU405_defconfig b/configs/PLU405_defconfig index fe26fed896..f4802b6d99 100644 --- a/configs/PLU405_defconfig +++ b/configs/PLU405_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_4xx=y CONFIG_TARGET_PLU405=y CONFIG_OF_BOARD_SETUP=y @@ -17,6 +16,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y CONFIG_CMD_UBI=y +# CONFIG_MMC is not set CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/PMC405DE_defconfig b/configs/PMC405DE_defconfig index fe96b07616..8f8a357855 100644 --- a/configs/PMC405DE_defconfig +++ b/configs/PMC405DE_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_4xx=y CONFIG_TARGET_PMC405DE=y CONFIG_OF_BOARD_SETUP=y @@ -15,5 +14,6 @@ CONFIG_CMD_I2C=y CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y +# CONFIG_MMC is not set CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/PMC440_defconfig b/configs/PMC440_defconfig index 8c4454eab5..bc974f9586 100644 --- a/configs/PMC440_defconfig +++ b/configs/PMC440_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_4xx=y CONFIG_TARGET_PMC440=y CONFIG_OF_BOARD_SETUP=y @@ -17,6 +16,7 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y +# CONFIG_MMC is not set CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/TQM5200S_HIGHBOOT_defconfig b/configs/TQM5200S_HIGHBOOT_defconfig index df873ee459..4892501c31 100644 --- a/configs/TQM5200S_HIGHBOOT_defconfig +++ b/configs/TQM5200S_HIGHBOOT_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_MPC5xxx=y CONFIG_TARGET_TQM5200=y CONFIG_OF_BOARD_SETUP=y @@ -17,6 +16,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_SNTP=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +# CONFIG_MMC is not set CONFIG_USB=y CONFIG_USB_STORAGE=y CONFIG_OF_LIBFDT=y diff --git a/configs/TQM5200S_defconfig b/configs/TQM5200S_defconfig index 2a59758526..cb722cb664 100644 --- a/configs/TQM5200S_defconfig +++ b/configs/TQM5200S_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_MPC5xxx=y CONFIG_TARGET_TQM5200=y CONFIG_OF_BOARD_SETUP=y @@ -17,6 +16,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_SNTP=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +# CONFIG_MMC is not set CONFIG_USB=y CONFIG_USB_STORAGE=y CONFIG_OF_LIBFDT=y diff --git a/configs/TQM5200_B_HIGHBOOT_defconfig b/configs/TQM5200_B_HIGHBOOT_defconfig index 73ff1612da..e18bda0a6e 100644 --- a/configs/TQM5200_B_HIGHBOOT_defconfig +++ b/configs/TQM5200_B_HIGHBOOT_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_VIDEO=y CONFIG_MPC5xxx=y CONFIG_TARGET_TQM5200=y @@ -20,6 +19,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_SNTP=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +# CONFIG_MMC is not set CONFIG_USB=y CONFIG_USB_STORAGE=y CONFIG_CONSOLE_EXTRA_INFO=y diff --git a/configs/TQM5200_B_defconfig b/configs/TQM5200_B_defconfig index c0d5c4bc88..c6e472b67b 100644 --- a/configs/TQM5200_B_defconfig +++ b/configs/TQM5200_B_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_VIDEO=y CONFIG_MPC5xxx=y CONFIG_TARGET_TQM5200=y @@ -20,6 +19,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_SNTP=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +# CONFIG_MMC is not set CONFIG_USB=y CONFIG_USB_STORAGE=y CONFIG_CONSOLE_EXTRA_INFO=y diff --git a/configs/TQM5200_STK100_defconfig b/configs/TQM5200_STK100_defconfig index 58689123ef..bd1e0eda67 100644 --- a/configs/TQM5200_STK100_defconfig +++ b/configs/TQM5200_STK100_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_VIDEO=y CONFIG_MPC5xxx=y CONFIG_TARGET_TQM5200=y @@ -20,6 +19,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_SNTP=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +# CONFIG_MMC is not set CONFIG_USB=y CONFIG_USB_STORAGE=y CONFIG_CONSOLE_EXTRA_INFO=y diff --git a/configs/TQM5200_defconfig b/configs/TQM5200_defconfig index 9d0e915108..c1d8d72dc1 100644 --- a/configs/TQM5200_defconfig +++ b/configs/TQM5200_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_VIDEO=y CONFIG_MPC5xxx=y CONFIG_TARGET_TQM5200=y @@ -19,6 +18,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_SNTP=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +# CONFIG_MMC is not set CONFIG_USB=y CONFIG_USB_STORAGE=y CONFIG_CONSOLE_EXTRA_INFO=y diff --git a/configs/TQM823L_LCD_defconfig b/configs/TQM823L_LCD_defconfig index 0c6b2d9f4b..8b8ff47c23 100644 --- a/configs/TQM823L_LCD_defconfig +++ b/configs/TQM823L_LCD_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_8xx=y CONFIG_TARGET_TQM823L=y CONFIG_OF_BOARD_SETUP=y @@ -12,6 +11,7 @@ CONFIG_CMD_ASKENV=y CONFIG_CMD_DHCP=y CONFIG_CMD_SNTP=y CONFIG_CMD_EXT2=y +# CONFIG_MMC is not set # CONFIG_PCI is not set CONFIG_LCD=y CONFIG_OF_LIBFDT=y diff --git a/configs/TQM823L_defconfig b/configs/TQM823L_defconfig index 86451938f1..473d872493 100644 --- a/configs/TQM823L_defconfig +++ b/configs/TQM823L_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_8xx=y CONFIG_TARGET_TQM823L=y CONFIG_OF_BOARD_SETUP=y @@ -17,5 +16,6 @@ CONFIG_LED_STATUS_BIT=1 CONFIG_LED_STATUS_STATE=1 CONFIG_LED_STATUS_BOOT_ENABLE=y CONFIG_LED_STATUS_BOOT=0 +# CONFIG_MMC is not set # CONFIG_PCI is not set CONFIG_OF_LIBFDT=y diff --git a/configs/TQM823M_defconfig b/configs/TQM823M_defconfig index 08bf1492ca..56868565f4 100644 --- a/configs/TQM823M_defconfig +++ b/configs/TQM823M_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_8xx=y CONFIG_TARGET_TQM823M=y CONFIG_OF_BOARD_SETUP=y @@ -17,5 +16,6 @@ CONFIG_LED_STATUS_BIT=1 CONFIG_LED_STATUS_STATE=1 CONFIG_LED_STATUS_BOOT_ENABLE=y CONFIG_LED_STATUS_BOOT=0 +# CONFIG_MMC is not set # CONFIG_PCI is not set CONFIG_OF_LIBFDT=y diff --git a/configs/TQM834x_defconfig b/configs/TQM834x_defconfig index 8b24dfb930..b6257853f5 100644 --- a/configs/TQM834x_defconfig +++ b/configs/TQM834x_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_MPC83xx=y CONFIG_TARGET_TQM834X=y CONFIG_OF_BOARD_SETUP=y @@ -13,5 +12,6 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_SNTP=y +# CONFIG_MMC is not set CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/TQM850L_defconfig b/configs/TQM850L_defconfig index 1b87bcb801..21692a4054 100644 --- a/configs/TQM850L_defconfig +++ b/configs/TQM850L_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_8xx=y CONFIG_TARGET_TQM850L=y CONFIG_OF_BOARD_SETUP=y @@ -17,5 +16,6 @@ CONFIG_LED_STATUS_BIT=1 CONFIG_LED_STATUS_STATE=1 CONFIG_LED_STATUS_BOOT_ENABLE=y CONFIG_LED_STATUS_BOOT=0 +# CONFIG_MMC is not set # CONFIG_PCI is not set CONFIG_OF_LIBFDT=y diff --git a/configs/TQM850M_defconfig b/configs/TQM850M_defconfig index 15aa30b1da..58e08e947d 100644 --- a/configs/TQM850M_defconfig +++ b/configs/TQM850M_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_8xx=y CONFIG_TARGET_TQM850M=y CONFIG_OF_BOARD_SETUP=y @@ -17,5 +16,6 @@ CONFIG_LED_STATUS_BIT=1 CONFIG_LED_STATUS_STATE=1 CONFIG_LED_STATUS_BOOT_ENABLE=y CONFIG_LED_STATUS_BOOT=0 +# CONFIG_MMC is not set # CONFIG_PCI is not set CONFIG_OF_LIBFDT=y diff --git a/configs/TQM855L_defconfig b/configs/TQM855L_defconfig index aa8b4a09d1..ce9a8d1ee2 100644 --- a/configs/TQM855L_defconfig +++ b/configs/TQM855L_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_8xx=y CONFIG_TARGET_TQM855L=y CONFIG_OF_BOARD_SETUP=y @@ -17,5 +16,6 @@ CONFIG_LED_STATUS_BIT=1 CONFIG_LED_STATUS_STATE=1 CONFIG_LED_STATUS_BOOT_ENABLE=y CONFIG_LED_STATUS_BOOT=0 +# CONFIG_MMC is not set # CONFIG_PCI is not set CONFIG_OF_LIBFDT=y diff --git a/configs/TQM855M_defconfig b/configs/TQM855M_defconfig index 3a80d5ae5e..7e990c8811 100644 --- a/configs/TQM855M_defconfig +++ b/configs/TQM855M_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_8xx=y CONFIG_TARGET_TQM855M=y CONFIG_OF_BOARD_SETUP=y @@ -17,5 +16,6 @@ CONFIG_LED_STATUS_BIT=1 CONFIG_LED_STATUS_STATE=1 CONFIG_LED_STATUS_BOOT_ENABLE=y CONFIG_LED_STATUS_BOOT=0 +# CONFIG_MMC is not set # CONFIG_PCI is not set CONFIG_OF_LIBFDT=y diff --git a/configs/TQM860L_defconfig b/configs/TQM860L_defconfig index 888516449a..e322ba73cd 100644 --- a/configs/TQM860L_defconfig +++ b/configs/TQM860L_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_8xx=y CONFIG_TARGET_TQM860L=y CONFIG_OF_BOARD_SETUP=y @@ -17,5 +16,6 @@ CONFIG_LED_STATUS_BIT=1 CONFIG_LED_STATUS_STATE=1 CONFIG_LED_STATUS_BOOT_ENABLE=y CONFIG_LED_STATUS_BOOT=0 +# CONFIG_MMC is not set # CONFIG_PCI is not set CONFIG_OF_LIBFDT=y diff --git a/configs/TQM860M_defconfig b/configs/TQM860M_defconfig index 00196f71eb..7e99c33cfa 100644 --- a/configs/TQM860M_defconfig +++ b/configs/TQM860M_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_8xx=y CONFIG_TARGET_TQM860M=y CONFIG_OF_BOARD_SETUP=y @@ -17,5 +16,6 @@ CONFIG_LED_STATUS_BIT=1 CONFIG_LED_STATUS_STATE=1 CONFIG_LED_STATUS_BOOT_ENABLE=y CONFIG_LED_STATUS_BOOT=0 +# CONFIG_MMC is not set # CONFIG_PCI is not set CONFIG_OF_LIBFDT=y diff --git a/configs/TQM862L_defconfig b/configs/TQM862L_defconfig index 1fff2b4782..9b36d6204b 100644 --- a/configs/TQM862L_defconfig +++ b/configs/TQM862L_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_8xx=y CONFIG_TARGET_TQM862L=y CONFIG_OF_BOARD_SETUP=y @@ -17,5 +16,6 @@ CONFIG_LED_STATUS_BIT=1 CONFIG_LED_STATUS_STATE=1 CONFIG_LED_STATUS_BOOT_ENABLE=y CONFIG_LED_STATUS_BOOT=0 +# CONFIG_MMC is not set # CONFIG_PCI is not set CONFIG_OF_LIBFDT=y diff --git a/configs/TQM862M_defconfig b/configs/TQM862M_defconfig index afd6d6e537..7b5a549b3f 100644 --- a/configs/TQM862M_defconfig +++ b/configs/TQM862M_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_8xx=y CONFIG_TARGET_TQM862M=y CONFIG_OF_BOARD_SETUP=y @@ -17,5 +16,6 @@ CONFIG_LED_STATUS_BIT=1 CONFIG_LED_STATUS_STATE=1 CONFIG_LED_STATUS_BOOT_ENABLE=y CONFIG_LED_STATUS_BOOT=0 +# CONFIG_MMC is not set # CONFIG_PCI is not set CONFIG_OF_LIBFDT=y diff --git a/configs/TQM866M_defconfig b/configs/TQM866M_defconfig index cb2c8696b0..46dbdfe5f3 100644 --- a/configs/TQM866M_defconfig +++ b/configs/TQM866M_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_8xx=y CONFIG_TARGET_TQM866M=y CONFIG_OF_BOARD_SETUP=y @@ -17,5 +16,6 @@ CONFIG_LED_STATUS_BIT=1 CONFIG_LED_STATUS_STATE=1 CONFIG_LED_STATUS_BOOT_ENABLE=y CONFIG_LED_STATUS_BOOT=0 +# CONFIG_MMC is not set # CONFIG_PCI is not set CONFIG_OF_LIBFDT=y diff --git a/configs/TQM885D_defconfig b/configs/TQM885D_defconfig index 89bc2428b5..1a2dcb437e 100644 --- a/configs/TQM885D_defconfig +++ b/configs/TQM885D_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_8xx=y CONFIG_TARGET_TQM885D=y CONFIG_OF_BOARD_SETUP=y @@ -20,5 +19,6 @@ CONFIG_LED_STATUS_BIT=1 CONFIG_LED_STATUS_STATE=1 CONFIG_LED_STATUS_BOOT_ENABLE=y CONFIG_LED_STATUS_BOOT=0 +# CONFIG_MMC is not set # CONFIG_PCI is not set CONFIG_OF_LIBFDT=y diff --git a/configs/TTTech_defconfig b/configs/TTTech_defconfig index 97e4330db0..2dfbfb76a0 100644 --- a/configs/TTTech_defconfig +++ b/configs/TTTech_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_8xx=y CONFIG_TARGET_TQM823L=y CONFIG_OF_BOARD_SETUP=y @@ -12,6 +11,7 @@ CONFIG_CMD_ASKENV=y CONFIG_CMD_DHCP=y CONFIG_CMD_SNTP=y CONFIG_CMD_EXT2=y +# CONFIG_MMC is not set # CONFIG_PCI is not set CONFIG_LCD=y CONFIG_OF_LIBFDT=y diff --git a/configs/VOM405_defconfig b/configs/VOM405_defconfig index aaaf31aaba..a826dada83 100644 --- a/configs/VOM405_defconfig +++ b/configs/VOM405_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_4xx=y CONFIG_TARGET_VOM405=y CONFIG_OF_BOARD_SETUP=y @@ -11,6 +10,7 @@ CONFIG_CMD_I2C=y CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y +# CONFIG_MMC is not set # CONFIG_PCI is not set CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/a3m071_defconfig b/configs/a3m071_defconfig index 0cfdd984e5..a05d53522d 100644 --- a/configs/a3m071_defconfig +++ b/configs/a3m071_defconfig @@ -3,7 +3,6 @@ CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_ENV_SUPPORT=y -# CONFIG_MMC is not set CONFIG_MPC5xxx=y CONFIG_TARGET_A3M071=y CONFIG_FIT=y @@ -24,6 +23,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_LINK_LOCAL=y CONFIG_CMD_CACHE=y CONFIG_CMD_UBI=y +# CONFIG_MMC is not set # CONFIG_PCI is not set CONFIG_LIB_RAND=y CONFIG_OF_LIBFDT=y diff --git a/configs/a4m072_defconfig b/configs/a4m072_defconfig index f68b966bbc..65a158fe89 100644 --- a/configs/a4m072_defconfig +++ b/configs/a4m072_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_MPC5xxx=y CONFIG_TARGET_A4M072=y CONFIG_OF_BOARD_SETUP=y @@ -16,6 +15,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_SNTP=y CONFIG_CMD_FAT=y +# CONFIG_MMC is not set CONFIG_USB=y CONFIG_USB_STORAGE=y CONFIG_OF_LIBFDT=y diff --git a/configs/a4m2k_defconfig b/configs/a4m2k_defconfig index da7719c019..fd156487e1 100644 --- a/configs/a4m2k_defconfig +++ b/configs/a4m2k_defconfig @@ -3,7 +3,6 @@ CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_ENV_SUPPORT=y -# CONFIG_MMC is not set CONFIG_MPC5xxx=y CONFIG_TARGET_A3M071=y CONFIG_FIT=y @@ -25,6 +24,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_LINK_LOCAL=y CONFIG_CMD_CACHE=y CONFIG_CMD_UBI=y +# CONFIG_MMC is not set # CONFIG_PCI is not set CONFIG_LIB_RAND=y CONFIG_OF_LIBFDT=y diff --git a/configs/ac14xx_defconfig b/configs/ac14xx_defconfig index 6c84fc692b..b0179008ec 100644 --- a/configs/ac14xx_defconfig +++ b/configs/ac14xx_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_MPC512X=y CONFIG_TARGET_AC14XX=y CONFIG_FIT=y @@ -11,5 +10,6 @@ CONFIG_CMD_I2C=y CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y +# CONFIG_MMC is not set # CONFIG_PCI is not set CONFIG_OF_LIBFDT=y diff --git a/configs/acadia_defconfig b/configs/acadia_defconfig index 790d8a91e8..1c9c173ed3 100644 --- a/configs/acadia_defconfig +++ b/configs/acadia_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_4xx=y CONFIG_TARGET_ACADIA=y CONFIG_OF_BOARD_SETUP=y @@ -15,6 +14,7 @@ CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y +# CONFIG_MMC is not set # CONFIG_PCI is not set CONFIG_SYS_NS16550=y CONFIG_USB=y diff --git a/configs/adp-ag101p_defconfig b/configs/adp-ag101p_defconfig index 23ca68b147..8ed04e0b6c 100644 --- a/configs/adp-ag101p_defconfig +++ b/configs/adp-ag101p_defconfig @@ -1,5 +1,4 @@ CONFIG_NDS32=y -CONFIG_MMC=y CONFIG_TARGET_ADP_AG101P=y CONFIG_BOOTDELAY=3 CONFIG_SYS_PROMPT="NDS32 # " @@ -9,4 +8,5 @@ CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_MMC=y CONFIG_SYS_NS16550=y diff --git a/configs/arches_defconfig b/configs/arches_defconfig index 88bf4df43e..2eb776b01b 100644 --- a/configs/arches_defconfig +++ b/configs/arches_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_4xx=y CONFIG_TARGET_CANYONLANDS=y CONFIG_ARCHES=y @@ -18,4 +17,5 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_OF_CONTROL=y +# CONFIG_MMC is not set CONFIG_SYS_NS16550=y diff --git a/configs/aria_defconfig b/configs/aria_defconfig index d54708ee8e..e472f14da0 100644 --- a/configs/aria_defconfig +++ b/configs/aria_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_MPC512X=y CONFIG_TARGET_ARIA=y CONFIG_OF_BOARD_SETUP=y @@ -11,5 +10,6 @@ CONFIG_CMD_I2C=y CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y +# CONFIG_MMC is not set # CONFIG_PCI is not set CONFIG_OF_LIBFDT=y diff --git a/configs/armadillo-800eva_defconfig b/configs/armadillo-800eva_defconfig index 9409b8a6e6..b850efe5a7 100644 --- a/configs/armadillo-800eva_defconfig +++ b/configs/armadillo-800eva_defconfig @@ -1,7 +1,6 @@ CONFIG_ARM=y CONFIG_ARCH_RMOBILE=y CONFIG_TARGET_ARMADILLO_800EVA=y -# CONFIG_MMC is not set CONFIG_BOOTDELAY=3 CONFIG_VERSION_VARIABLE=y # CONFIG_CMD_BDI is not set @@ -25,4 +24,5 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y # CONFIG_CMD_MISC is not set +# CONFIG_MMC is not set CONFIG_OF_LIBFDT=y diff --git a/configs/aspenite_defconfig b/configs/aspenite_defconfig index b4260a1cb1..620017bca3 100644 --- a/configs/aspenite_defconfig +++ b/configs/aspenite_defconfig @@ -1,7 +1,6 @@ CONFIG_ARM=y CONFIG_TARGET_ASPENITE=y CONFIG_IDENT_STRING="\nMarvell-Aspenite DB" -# CONFIG_MMC is not set CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_BOARDINFO is not set # CONFIG_CMD_IMLS is not set @@ -10,5 +9,6 @@ CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NET is not set # CONFIG_CMD_NFS is not set +# CONFIG_MMC is not set CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/at91rm9200ek_defconfig b/configs/at91rm9200ek_defconfig index 9674a04d08..7b3c520657 100644 --- a/configs/at91rm9200ek_defconfig +++ b/configs/at91rm9200ek_defconfig @@ -1,7 +1,6 @@ CONFIG_ARM=y CONFIG_ARCH_AT91=y CONFIG_TARGET_AT91RM9200EK=y -# CONFIG_MMC is not set CONFIG_BOOTDELAY=3 # CONFIG_SYS_STDIO_DEREGISTER is not set # CONFIG_DISPLAY_CPUINFO is not set @@ -16,6 +15,7 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y +# CONFIG_MMC is not set CONFIG_USB=y CONFIG_USB_STORAGE=y CONFIG_USB_KEYBOARD=y diff --git a/configs/at91rm9200ek_ram_defconfig b/configs/at91rm9200ek_ram_defconfig index 39c1afe93a..849ef69a28 100644 --- a/configs/at91rm9200ek_ram_defconfig +++ b/configs/at91rm9200ek_ram_defconfig @@ -1,7 +1,6 @@ CONFIG_ARM=y CONFIG_ARCH_AT91=y CONFIG_TARGET_AT91RM9200EK=y -# CONFIG_MMC is not set CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT" CONFIG_BOOTDELAY=3 # CONFIG_SYS_STDIO_DEREGISTER is not set @@ -17,6 +16,7 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y +# CONFIG_MMC is not set CONFIG_USB=y CONFIG_USB_STORAGE=y CONFIG_USB_KEYBOARD=y diff --git a/configs/at91sam9260ek_dataflash_cs0_defconfig b/configs/at91sam9260ek_dataflash_cs0_defconfig index 36423b2c73..e00c4c4c1f 100644 --- a/configs/at91sam9260ek_dataflash_cs0_defconfig +++ b/configs/at91sam9260ek_dataflash_cs0_defconfig @@ -1,7 +1,6 @@ CONFIG_ARM=y CONFIG_ARCH_AT91=y CONFIG_TARGET_AT91SAM9260EK=y -# CONFIG_MMC is not set CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9260,SYS_USE_DATAFLASH_CS0" CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_BOARDINFO is not set @@ -18,6 +17,7 @@ CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y +# CONFIG_MMC is not set CONFIG_USB=y CONFIG_USB_STORAGE=y CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9260ek_dataflash_cs1_defconfig b/configs/at91sam9260ek_dataflash_cs1_defconfig index 3b2817205e..7b81775255 100644 --- a/configs/at91sam9260ek_dataflash_cs1_defconfig +++ b/configs/at91sam9260ek_dataflash_cs1_defconfig @@ -1,7 +1,6 @@ CONFIG_ARM=y CONFIG_ARCH_AT91=y CONFIG_TARGET_AT91SAM9260EK=y -# CONFIG_MMC is not set CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9260,SYS_USE_DATAFLASH_CS1" CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_BOARDINFO is not set @@ -18,6 +17,7 @@ CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y +# CONFIG_MMC is not set CONFIG_USB=y CONFIG_USB_STORAGE=y CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9260ek_nandflash_defconfig b/configs/at91sam9260ek_nandflash_defconfig index 4f88507b35..ca71891f35 100644 --- a/configs/at91sam9260ek_nandflash_defconfig +++ b/configs/at91sam9260ek_nandflash_defconfig @@ -1,7 +1,6 @@ CONFIG_ARM=y CONFIG_ARCH_AT91=y CONFIG_TARGET_AT91SAM9260EK=y -# CONFIG_MMC is not set CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9260,SYS_USE_NANDFLASH" CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_BOARDINFO is not set @@ -18,6 +17,7 @@ CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y +# CONFIG_MMC is not set CONFIG_USB=y CONFIG_USB_STORAGE=y CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9261ek_dataflash_cs0_defconfig b/configs/at91sam9261ek_dataflash_cs0_defconfig index 6b26c78368..15adf43c42 100644 --- a/configs/at91sam9261ek_dataflash_cs0_defconfig +++ b/configs/at91sam9261ek_dataflash_cs0_defconfig @@ -1,7 +1,6 @@ CONFIG_ARM=y CONFIG_ARCH_AT91=y CONFIG_TARGET_AT91SAM9261EK=y -# CONFIG_MMC is not set CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9261,SYS_USE_DATAFLASH_CS0" CONFIG_BOOTDELAY=3 # CONFIG_CONSOLE_MUX is not set @@ -19,6 +18,7 @@ CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y +# CONFIG_MMC is not set CONFIG_USB=y CONFIG_USB_STORAGE=y CONFIG_LCD=y diff --git a/configs/at91sam9261ek_dataflash_cs3_defconfig b/configs/at91sam9261ek_dataflash_cs3_defconfig index 293009d663..05113b9805 100644 --- a/configs/at91sam9261ek_dataflash_cs3_defconfig +++ b/configs/at91sam9261ek_dataflash_cs3_defconfig @@ -1,7 +1,6 @@ CONFIG_ARM=y CONFIG_ARCH_AT91=y CONFIG_TARGET_AT91SAM9261EK=y -# CONFIG_MMC is not set CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9261,SYS_USE_DATAFLASH_CS3" CONFIG_BOOTDELAY=3 # CONFIG_CONSOLE_MUX is not set @@ -19,6 +18,7 @@ CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y +# CONFIG_MMC is not set CONFIG_USB=y CONFIG_USB_STORAGE=y CONFIG_LCD=y diff --git a/configs/at91sam9261ek_nandflash_defconfig b/configs/at91sam9261ek_nandflash_defconfig index 4760c4e07b..16f5defa43 100644 --- a/configs/at91sam9261ek_nandflash_defconfig +++ b/configs/at91sam9261ek_nandflash_defconfig @@ -1,7 +1,6 @@ CONFIG_ARM=y CONFIG_ARCH_AT91=y CONFIG_TARGET_AT91SAM9261EK=y -# CONFIG_MMC is not set CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9261,SYS_USE_NANDFLASH" CONFIG_BOOTDELAY=3 # CONFIG_CONSOLE_MUX is not set @@ -19,6 +18,7 @@ CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y +# CONFIG_MMC is not set CONFIG_USB=y CONFIG_USB_STORAGE=y CONFIG_LCD=y diff --git a/configs/at91sam9g10ek_dataflash_cs0_defconfig b/configs/at91sam9g10ek_dataflash_cs0_defconfig index 02cd5fa6a5..70e526a5cf 100644 --- a/configs/at91sam9g10ek_dataflash_cs0_defconfig +++ b/configs/at91sam9g10ek_dataflash_cs0_defconfig @@ -1,7 +1,6 @@ CONFIG_ARM=y CONFIG_ARCH_AT91=y CONFIG_TARGET_AT91SAM9261EK=y -# CONFIG_MMC is not set CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9G10,SYS_USE_DATAFLASH_CS0" CONFIG_BOOTDELAY=3 # CONFIG_CONSOLE_MUX is not set @@ -19,6 +18,7 @@ CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y +# CONFIG_MMC is not set CONFIG_USB=y CONFIG_USB_STORAGE=y CONFIG_LCD=y diff --git a/configs/at91sam9g10ek_dataflash_cs3_defconfig b/configs/at91sam9g10ek_dataflash_cs3_defconfig index 453a75ddf2..8da1bfe5cd 100644 --- a/configs/at91sam9g10ek_dataflash_cs3_defconfig +++ b/configs/at91sam9g10ek_dataflash_cs3_defconfig @@ -1,7 +1,6 @@ CONFIG_ARM=y CONFIG_ARCH_AT91=y CONFIG_TARGET_AT91SAM9261EK=y -# CONFIG_MMC is not set CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9G10,SYS_USE_DATAFLASH_CS3" CONFIG_BOOTDELAY=3 # CONFIG_CONSOLE_MUX is not set @@ -19,6 +18,7 @@ CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y +# CONFIG_MMC is not set CONFIG_USB=y CONFIG_USB_STORAGE=y CONFIG_LCD=y diff --git a/configs/at91sam9g10ek_nandflash_defconfig b/configs/at91sam9g10ek_nandflash_defconfig index 0c8297884a..46217efb39 100644 --- a/configs/at91sam9g10ek_nandflash_defconfig +++ b/configs/at91sam9g10ek_nandflash_defconfig @@ -1,7 +1,6 @@ CONFIG_ARM=y CONFIG_ARCH_AT91=y CONFIG_TARGET_AT91SAM9261EK=y -# CONFIG_MMC is not set CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9G10,SYS_USE_NANDFLASH" CONFIG_BOOTDELAY=3 # CONFIG_CONSOLE_MUX is not set @@ -19,6 +18,7 @@ CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y +# CONFIG_MMC is not set CONFIG_USB=y CONFIG_USB_STORAGE=y CONFIG_LCD=y diff --git a/configs/at91sam9g20ek_dataflash_cs0_defconfig b/configs/at91sam9g20ek_dataflash_cs0_defconfig index 4d94b84bd6..5bb0cb210e 100644 --- a/configs/at91sam9g20ek_dataflash_cs0_defconfig +++ b/configs/at91sam9g20ek_dataflash_cs0_defconfig @@ -1,7 +1,6 @@ CONFIG_ARM=y CONFIG_ARCH_AT91=y CONFIG_TARGET_AT91SAM9260EK=y -# CONFIG_MMC is not set CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9G20,SYS_USE_DATAFLASH_CS0" CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_BOARDINFO is not set @@ -18,6 +17,7 @@ CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y +# CONFIG_MMC is not set CONFIG_USB=y CONFIG_USB_STORAGE=y CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9g20ek_dataflash_cs1_defconfig b/configs/at91sam9g20ek_dataflash_cs1_defconfig index cbe0376b30..fb6a0ac829 100644 --- a/configs/at91sam9g20ek_dataflash_cs1_defconfig +++ b/configs/at91sam9g20ek_dataflash_cs1_defconfig @@ -1,7 +1,6 @@ CONFIG_ARM=y CONFIG_ARCH_AT91=y CONFIG_TARGET_AT91SAM9260EK=y -# CONFIG_MMC is not set CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9G20,SYS_USE_DATAFLASH_CS1" CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_BOARDINFO is not set @@ -18,6 +17,7 @@ CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y +# CONFIG_MMC is not set CONFIG_USB=y CONFIG_USB_STORAGE=y CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9g20ek_nandflash_defconfig b/configs/at91sam9g20ek_nandflash_defconfig index 1b53332759..79ec2e446b 100644 --- a/configs/at91sam9g20ek_nandflash_defconfig +++ b/configs/at91sam9g20ek_nandflash_defconfig @@ -1,7 +1,6 @@ CONFIG_ARM=y CONFIG_ARCH_AT91=y CONFIG_TARGET_AT91SAM9260EK=y -# CONFIG_MMC is not set CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9G20,SYS_USE_NANDFLASH" CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_BOARDINFO is not set @@ -18,6 +17,7 @@ CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y +# CONFIG_MMC is not set CONFIG_USB=y CONFIG_USB_STORAGE=y CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9xeek_dataflash_cs0_defconfig b/configs/at91sam9xeek_dataflash_cs0_defconfig index 4092bfa7cb..e29b3cdfe5 100644 --- a/configs/at91sam9xeek_dataflash_cs0_defconfig +++ b/configs/at91sam9xeek_dataflash_cs0_defconfig @@ -1,7 +1,6 @@ CONFIG_ARM=y CONFIG_ARCH_AT91=y CONFIG_TARGET_AT91SAM9260EK=y -# CONFIG_MMC is not set CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9XE,SYS_USE_DATAFLASH_CS0" CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_BOARDINFO is not set @@ -18,6 +17,7 @@ CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y +# CONFIG_MMC is not set CONFIG_USB=y CONFIG_USB_STORAGE=y CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9xeek_dataflash_cs1_defconfig b/configs/at91sam9xeek_dataflash_cs1_defconfig index 5ff6902351..2e32ca8e17 100644 --- a/configs/at91sam9xeek_dataflash_cs1_defconfig +++ b/configs/at91sam9xeek_dataflash_cs1_defconfig @@ -1,7 +1,6 @@ CONFIG_ARM=y CONFIG_ARCH_AT91=y CONFIG_TARGET_AT91SAM9260EK=y -# CONFIG_MMC is not set CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9XE,SYS_USE_DATAFLASH_CS1" CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_BOARDINFO is not set @@ -18,6 +17,7 @@ CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y +# CONFIG_MMC is not set CONFIG_USB=y CONFIG_USB_STORAGE=y CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9xeek_nandflash_defconfig b/configs/at91sam9xeek_nandflash_defconfig index fea620c476..2ef459bb64 100644 --- a/configs/at91sam9xeek_nandflash_defconfig +++ b/configs/at91sam9xeek_nandflash_defconfig @@ -1,7 +1,6 @@ CONFIG_ARM=y CONFIG_ARCH_AT91=y CONFIG_TARGET_AT91SAM9260EK=y -# CONFIG_MMC is not set CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9XE,SYS_USE_NANDFLASH" CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_BOARDINFO is not set @@ -18,6 +17,7 @@ CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y +# CONFIG_MMC is not set CONFIG_USB=y CONFIG_USB_STORAGE=y CONFIG_OF_LIBFDT=y diff --git a/configs/atngw100_defconfig b/configs/atngw100_defconfig index be48af1168..5f991fcc7f 100644 --- a/configs/atngw100_defconfig +++ b/configs/atngw100_defconfig @@ -1,5 +1,4 @@ CONFIG_AVR32=y -CONFIG_MMC=y CONFIG_TARGET_ATNGW100=y CONFIG_BOOTDELAY=1 CONFIG_SYS_PROMPT="U-Boot> " @@ -19,5 +18,6 @@ CONFIG_CMD_SPI=y CONFIG_CMD_DHCP=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_MMC=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_ATMEL=y diff --git a/configs/atngw100mkii_defconfig b/configs/atngw100mkii_defconfig index 9c1ee73a0b..55bb5569de 100644 --- a/configs/atngw100mkii_defconfig +++ b/configs/atngw100mkii_defconfig @@ -1,5 +1,4 @@ CONFIG_AVR32=y -CONFIG_MMC=y CONFIG_TARGET_ATNGW100MKII=y CONFIG_BOOTDELAY=1 CONFIG_SYS_PROMPT="U-Boot> " @@ -19,5 +18,6 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_MMC=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_ATMEL=y diff --git a/configs/atstk1002_defconfig b/configs/atstk1002_defconfig index 1a5c97d613..58189d4097 100644 --- a/configs/atstk1002_defconfig +++ b/configs/atstk1002_defconfig @@ -1,5 +1,4 @@ CONFIG_AVR32=y -CONFIG_MMC=y CONFIG_TARGET_ATSTK1002=y CONFIG_BOOTDELAY=1 CONFIG_SYS_PROMPT="U-Boot> " @@ -17,3 +16,4 @@ CONFIG_CMD_MMC=y CONFIG_CMD_DHCP=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_MMC=y diff --git a/configs/axm_defconfig b/configs/axm_defconfig index 539e776592..a8b566917d 100644 --- a/configs/axm_defconfig +++ b/configs/axm_defconfig @@ -10,7 +10,6 @@ CONFIG_SPL_NAND_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y -# CONFIG_MMC is not set CONFIG_DEFAULT_DEVICE_TREE="at91sam9g20-taurus" CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9G20,MACH_TYPE=2068,BOARD_AXM" CONFIG_BOOTDELAY=3 @@ -31,6 +30,7 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_OF_CONTROL=y CONFIG_OF_EMBED=y +# CONFIG_MMC is not set CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_USE_TINY_PRINTF=y diff --git a/configs/axs101_defconfig b/configs/axs101_defconfig index 3793c4255d..317c6fb0c9 100644 --- a/configs/axs101_defconfig +++ b/configs/axs101_defconfig @@ -1,7 +1,6 @@ CONFIG_ARC=y CONFIG_SYS_DCACHE_OFF=y CONFIG_SYS_CLK_FREQ=750000000 -CONFIG_MMC=y CONFIG_SYS_TEXT_BASE=0x81000000 CONFIG_DEFAULT_DEVICE_TREE="axs10x" CONFIG_BOOTDELAY=3 @@ -20,6 +19,7 @@ CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y CONFIG_CLK=y CONFIG_SYS_I2C_DW=y +CONFIG_MMC=y CONFIG_MMC_DW=y CONFIG_DM_ETH=y CONFIG_ETH_DESIGNWARE=y diff --git a/configs/axs103_defconfig b/configs/axs103_defconfig index 30a4021d79..39aa29fec8 100644 --- a/configs/axs103_defconfig +++ b/configs/axs103_defconfig @@ -1,7 +1,6 @@ CONFIG_ARC=y CONFIG_ISA_ARCV2=y CONFIG_SYS_CLK_FREQ=100000000 -CONFIG_MMC=y CONFIG_SYS_TEXT_BASE=0x81000000 CONFIG_DEFAULT_DEVICE_TREE="axs10x" CONFIG_BOOTDELAY=3 @@ -20,6 +19,7 @@ CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y CONFIG_CLK=y CONFIG_SYS_I2C_DW=y +CONFIG_MMC=y CONFIG_MMC_DW=y CONFIG_DM_ETH=y CONFIG_ETH_DESIGNWARE=y diff --git a/configs/bamboo_defconfig b/configs/bamboo_defconfig index 54b8380890..614b06a30c 100644 --- a/configs/bamboo_defconfig +++ b/configs/bamboo_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_4xx=y CONFIG_TARGET_BAMBOO=y CONFIG_OF_BOARD_SETUP=y @@ -19,6 +18,7 @@ CONFIG_CMD_SNTP=y CONFIG_CMD_CACHE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +# CONFIG_MMC is not set # CONFIG_PCI_PNP is not set CONFIG_SYS_NS16550=y CONFIG_USB=y diff --git a/configs/bayleybay_defconfig b/configs/bayleybay_defconfig index 63d17b19f0..9f7c2f4e58 100644 --- a/configs/bayleybay_defconfig +++ b/configs/bayleybay_defconfig @@ -1,5 +1,4 @@ CONFIG_X86=y -CONFIG_MMC=y CONFIG_VENDOR_INTEL=y CONFIG_DEFAULT_DEVICE_TREE="bayleybay" CONFIG_TARGET_BAYLEYBAY=y @@ -41,6 +40,7 @@ CONFIG_OF_CONTROL=y CONFIG_REGMAP=y CONFIG_SYSCON=y CONFIG_CPU=y +CONFIG_MMC=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_SDMA=y CONFIG_SPI_FLASH=y diff --git a/configs/bcm911360_entphn-ns_defconfig b/configs/bcm911360_entphn-ns_defconfig index adcc152cbf..4f045903bf 100644 --- a/configs/bcm911360_entphn-ns_defconfig +++ b/configs/bcm911360_entphn-ns_defconfig @@ -1,6 +1,5 @@ CONFIG_ARM=y CONFIG_TARGET_BCMCYGNUS=y -# CONFIG_MMC is not set CONFIG_SYS_EXTRA_OPTIONS="SYS_SDRAM_SIZE=0x20000000,ARMV7_NONSEC" CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_CPUINFO is not set @@ -17,5 +16,6 @@ CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y CONFIG_CMD_FAT=y +# CONFIG_MMC is not set CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/bcm911360_entphn_defconfig b/configs/bcm911360_entphn_defconfig index e49071d5b9..2469792f68 100644 --- a/configs/bcm911360_entphn_defconfig +++ b/configs/bcm911360_entphn_defconfig @@ -1,6 +1,5 @@ CONFIG_ARM=y CONFIG_TARGET_BCMCYGNUS=y -# CONFIG_MMC is not set CONFIG_SYS_EXTRA_OPTIONS="SYS_SDRAM_SIZE=0x20000000" CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_CPUINFO is not set @@ -17,5 +16,6 @@ CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y CONFIG_CMD_FAT=y +# CONFIG_MMC is not set CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/bcm911360k_defconfig b/configs/bcm911360k_defconfig index 8077c4ae02..83afce41d6 100644 --- a/configs/bcm911360k_defconfig +++ b/configs/bcm911360k_defconfig @@ -1,6 +1,5 @@ CONFIG_ARM=y CONFIG_TARGET_BCMCYGNUS=y -# CONFIG_MMC is not set CONFIG_SYS_EXTRA_OPTIONS="SYS_SDRAM_SIZE=0x40000000" CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_CPUINFO is not set @@ -17,5 +16,6 @@ CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y CONFIG_CMD_FAT=y +# CONFIG_MMC is not set CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/bcm958300k-ns_defconfig b/configs/bcm958300k-ns_defconfig index 26d0b0b080..b21fea4331 100644 --- a/configs/bcm958300k-ns_defconfig +++ b/configs/bcm958300k-ns_defconfig @@ -1,6 +1,5 @@ CONFIG_ARM=y CONFIG_TARGET_BCMCYGNUS=y -# CONFIG_MMC is not set CONFIG_SYS_EXTRA_OPTIONS="SYS_SDRAM_SIZE=0x40000000,ARMV7_NONSEC" CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_CPUINFO is not set @@ -17,5 +16,6 @@ CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y CONFIG_CMD_FAT=y +# CONFIG_MMC is not set CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/bcm958300k_defconfig b/configs/bcm958300k_defconfig index 8077c4ae02..83afce41d6 100644 --- a/configs/bcm958300k_defconfig +++ b/configs/bcm958300k_defconfig @@ -1,6 +1,5 @@ CONFIG_ARM=y CONFIG_TARGET_BCMCYGNUS=y -# CONFIG_MMC is not set CONFIG_SYS_EXTRA_OPTIONS="SYS_SDRAM_SIZE=0x40000000" CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_CPUINFO is not set @@ -17,5 +16,6 @@ CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y CONFIG_CMD_FAT=y +# CONFIG_MMC is not set CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/bcm958305k_defconfig b/configs/bcm958305k_defconfig index 8077c4ae02..83afce41d6 100644 --- a/configs/bcm958305k_defconfig +++ b/configs/bcm958305k_defconfig @@ -1,6 +1,5 @@ CONFIG_ARM=y CONFIG_TARGET_BCMCYGNUS=y -# CONFIG_MMC is not set CONFIG_SYS_EXTRA_OPTIONS="SYS_SDRAM_SIZE=0x40000000" CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_CPUINFO is not set @@ -17,5 +16,6 @@ CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y CONFIG_CMD_FAT=y +# CONFIG_MMC is not set CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/bcm958622hr_defconfig b/configs/bcm958622hr_defconfig index c8679ace1b..a639336d94 100644 --- a/configs/bcm958622hr_defconfig +++ b/configs/bcm958622hr_defconfig @@ -1,6 +1,5 @@ CONFIG_ARM=y CONFIG_TARGET_BCMNSP=y -# CONFIG_MMC is not set CONFIG_SYS_EXTRA_OPTIONS="SYS_SDRAM_SIZE=0x01000000" CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_CPUINFO is not set @@ -15,5 +14,6 @@ CONFIG_CMD_ASKENV=y CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y CONFIG_CMD_FAT=y +# CONFIG_MMC is not set CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/bf518f-ezbrd_defconfig b/configs/bf518f-ezbrd_defconfig index d5b6e6e468..73a7ee29c4 100644 --- a/configs/bf518f-ezbrd_defconfig +++ b/configs/bf518f-ezbrd_defconfig @@ -1,5 +1,4 @@ CONFIG_BLACKFIN=y -CONFIG_MMC=y CONFIG_TARGET_BF518F_EZBRD=y CONFIG_BOOTDELAY=5 CONFIG_SILENT_CONSOLE=y @@ -18,6 +17,7 @@ CONFIG_CMD_CACHE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_MMC=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_SPI_FLASH_SST=y diff --git a/configs/bf527-ad7160-eval_defconfig b/configs/bf527-ad7160-eval_defconfig index d26bd271fc..aa0e5b3653 100644 --- a/configs/bf527-ad7160-eval_defconfig +++ b/configs/bf527-ad7160-eval_defconfig @@ -1,5 +1,4 @@ CONFIG_BLACKFIN=y -CONFIG_MMC=y CONFIG_TARGET_BF527_AD7160_EVAL=y CONFIG_BOOTDELAY=5 CONFIG_SILENT_CONSOLE=y @@ -15,6 +14,7 @@ CONFIG_CMD_GPIO=y CONFIG_CMD_CACHE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_MMC=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_CC_OPTIMIZE_LIBS_FOR_SPEED=y diff --git a/configs/bf537-stamp_defconfig b/configs/bf537-stamp_defconfig index d06ed7eb2c..4651c199d1 100644 --- a/configs/bf537-stamp_defconfig +++ b/configs/bf537-stamp_defconfig @@ -1,5 +1,4 @@ CONFIG_BLACKFIN=y -CONFIG_MMC=y CONFIG_TARGET_BF537_STAMP=y CONFIG_BOOTDELAY=5 CONFIG_SILENT_CONSOLE=y @@ -18,6 +17,7 @@ CONFIG_CMD_CACHE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_MMC=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_ATMEL=y CONFIG_SPI_FLASH_EON=y diff --git a/configs/bf548-ezkit_defconfig b/configs/bf548-ezkit_defconfig index 166b21a99a..4d9602132c 100644 --- a/configs/bf548-ezkit_defconfig +++ b/configs/bf548-ezkit_defconfig @@ -1,5 +1,4 @@ CONFIG_BLACKFIN=y -CONFIG_MMC=y CONFIG_TARGET_BF548_EZKIT=y CONFIG_BOOTDELAY=5 CONFIG_SILENT_CONSOLE=y @@ -17,6 +16,7 @@ CONFIG_CMD_DNS=y CONFIG_CMD_CACHE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_MMC=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_USB=y diff --git a/configs/bg0900_defconfig b/configs/bg0900_defconfig index 319c3e232b..6caf2e3571 100644 --- a/configs/bg0900_defconfig +++ b/configs/bg0900_defconfig @@ -4,7 +4,6 @@ CONFIG_SPL_GPIO_SUPPORT=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y -# CONFIG_MMC is not set CONFIG_BOOTDELAY=3 CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set @@ -20,6 +19,7 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y +# CONFIG_MMC is not set CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_BAR=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/blanche_defconfig b/configs/blanche_defconfig index 8dcbdd27ec..a7299229a5 100644 --- a/configs/blanche_defconfig +++ b/configs/blanche_defconfig @@ -2,7 +2,6 @@ CONFIG_ARM=y CONFIG_ARCH_RMOBILE=y CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_TARGET_BLANCHE=y -# CONFIG_MMC is not set CONFIG_BOOTSTAGE_USER_COUNT=0x20 CONFIG_BOOTSTAGE_STASH_ADDR=0x0 CONFIG_BOOTSTAGE_STASH_SIZE=0x4096 @@ -19,6 +18,7 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y +# CONFIG_MMC is not set CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_BAR=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/bubinga_defconfig b/configs/bubinga_defconfig index 8a72e44893..f1f3d584b4 100644 --- a/configs/bubinga_defconfig +++ b/configs/bubinga_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_4xx=y CONFIG_TARGET_BUBINGA=y CONFIG_OF_BOARD_SETUP=y @@ -15,5 +14,6 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_SNTP=y +# CONFIG_MMC is not set CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/caddy2_defconfig b/configs/caddy2_defconfig index 78dc4e1c20..e4fc32295b 100644 --- a/configs/caddy2_defconfig +++ b/configs/caddy2_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_MPC83xx=y CONFIG_TARGET_VME8349=y CONFIG_OF_BOARD_SETUP=y @@ -11,6 +10,7 @@ CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_MII=y CONFIG_CMD_PING=y +# CONFIG_MMC is not set CONFIG_NETDEVICES=y CONFIG_E1000=y CONFIG_SYS_NS16550=y diff --git a/configs/calimain_defconfig b/configs/calimain_defconfig index 33a221a03b..736f186816 100644 --- a/configs/calimain_defconfig +++ b/configs/calimain_defconfig @@ -1,7 +1,6 @@ CONFIG_ARM=y CONFIG_ARCH_DAVINCI=y CONFIG_TARGET_CALIMAIN=y -# CONFIG_MMC is not set CONFIG_BOOTDELAY=0 CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_CPUINFO is not set @@ -16,4 +15,5 @@ CONFIG_CMD_GPIO=y CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y +# CONFIG_MMC is not set CONFIG_SYS_NS16550=y diff --git a/configs/cam5200_defconfig b/configs/cam5200_defconfig index 3bf1aa7046..5ee1f1b5fa 100644 --- a/configs/cam5200_defconfig +++ b/configs/cam5200_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_MPC5xxx=y CONFIG_TARGET_TQM5200=y CONFIG_OF_BOARD_SETUP=y @@ -14,5 +13,6 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_SNTP=y +# CONFIG_MMC is not set # CONFIG_PCI is not set CONFIG_OF_LIBFDT=y diff --git a/configs/cam5200_niosflash_defconfig b/configs/cam5200_niosflash_defconfig index 602988e8ee..0ea8c0beac 100644 --- a/configs/cam5200_niosflash_defconfig +++ b/configs/cam5200_niosflash_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_MPC5xxx=y CONFIG_TARGET_TQM5200=y CONFIG_OF_BOARD_SETUP=y @@ -14,5 +13,6 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_SNTP=y +# CONFIG_MMC is not set # CONFIG_PCI is not set CONFIG_OF_LIBFDT=y diff --git a/configs/canmb_defconfig b/configs/canmb_defconfig index f4cf5c33c4..14ba1cfe3d 100644 --- a/configs/canmb_defconfig +++ b/configs/canmb_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_MPC5xxx=y CONFIG_TARGET_CANMB=y CONFIG_BOOTDELAY=5 @@ -8,4 +7,5 @@ CONFIG_CMD_ASKENV=y CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_SNTP=y +# CONFIG_MMC is not set # CONFIG_PCI is not set diff --git a/configs/canyonlands_defconfig b/configs/canyonlands_defconfig index fb1f9ec45a..5bd935fa3c 100644 --- a/configs/canyonlands_defconfig +++ b/configs/canyonlands_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_4xx=y CONFIG_TARGET_CANYONLANDS=y CONFIG_CANYONLANDS=y @@ -23,6 +22,7 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_OF_EMBED=y +# CONFIG_MMC is not set CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/charon_defconfig b/configs/charon_defconfig index 67d22b68a9..ce191a4588 100644 --- a/configs/charon_defconfig +++ b/configs/charon_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_VIDEO=y CONFIG_MPC5xxx=y CONFIG_TARGET_CHARON=y @@ -19,6 +18,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_SNTP=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +# CONFIG_MMC is not set CONFIG_USB=y CONFIG_USB_STORAGE=y CONFIG_CONSOLE_EXTRA_INFO=y diff --git a/configs/cm-bf537e_defconfig b/configs/cm-bf537e_defconfig index d687c43c11..36b2849a67 100644 --- a/configs/cm-bf537e_defconfig +++ b/configs/cm-bf537e_defconfig @@ -1,5 +1,4 @@ CONFIG_BLACKFIN=y -CONFIG_MMC=y CONFIG_TARGET_CM_BF537E=y CONFIG_BOOTDELAY=5 CONFIG_SILENT_CONSOLE=y @@ -17,4 +16,5 @@ CONFIG_CMD_CACHE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_MMC=y CONFIG_CC_OPTIMIZE_LIBS_FOR_SPEED=y diff --git a/configs/cm-bf537u_defconfig b/configs/cm-bf537u_defconfig index 38c6d4212c..8329e1ce60 100644 --- a/configs/cm-bf537u_defconfig +++ b/configs/cm-bf537u_defconfig @@ -1,5 +1,4 @@ CONFIG_BLACKFIN=y -CONFIG_MMC=y CONFIG_TARGET_CM_BF537U=y CONFIG_BOOTDELAY=5 CONFIG_SILENT_CONSOLE=y @@ -16,4 +15,5 @@ CONFIG_CMD_CACHE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_MMC=y CONFIG_CC_OPTIMIZE_LIBS_FOR_SPEED=y diff --git a/configs/cm5200_defconfig b/configs/cm5200_defconfig index b09f31fd94..1e42b6393a 100644 --- a/configs/cm5200_defconfig +++ b/configs/cm5200_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_MPC5xxx=y CONFIG_TARGET_CM5200=y CONFIG_OF_BOARD_SETUP=y @@ -15,6 +14,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_SNTP=y CONFIG_CMD_FAT=y +# CONFIG_MMC is not set # CONFIG_PCI is not set CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/corvus_defconfig b/configs/corvus_defconfig index fc10399844..e0ea3f3c99 100644 --- a/configs/corvus_defconfig +++ b/configs/corvus_defconfig @@ -8,7 +8,6 @@ CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_NAND_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y -# CONFIG_MMC is not set CONFIG_DEFAULT_DEVICE_TREE="at91sam9g45-corvus" CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9M10G45,MACH_TYPE=2066,SYS_USE_NANDFLASH" CONFIG_BOOTDELAY=3 @@ -32,6 +31,7 @@ CONFIG_CMD_PING=y CONFIG_OF_CONTROL=y CONFIG_OF_EMBED=y CONFIG_DFU_NAND=y +# CONFIG_MMC is not set CONFIG_USB=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y diff --git a/configs/crownbay_defconfig b/configs/crownbay_defconfig index 784c1b3337..6f1c7dae80 100644 --- a/configs/crownbay_defconfig +++ b/configs/crownbay_defconfig @@ -1,6 +1,5 @@ CONFIG_X86=y CONFIG_MAX_CPUS=2 -CONFIG_MMC=y CONFIG_VENDOR_INTEL=y CONFIG_DEFAULT_DEVICE_TREE="crownbay" CONFIG_TARGET_CROWNBAY=y @@ -33,6 +32,7 @@ CONFIG_OF_CONTROL=y CONFIG_REGMAP=y CONFIG_SYSCON=y CONFIG_CPU=y +CONFIG_MMC=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_SDMA=y CONFIG_SPI_FLASH=y diff --git a/configs/d2net_v2_defconfig b/configs/d2net_v2_defconfig index 87686aa644..b578591f9c 100644 --- a/configs/d2net_v2_defconfig +++ b/configs/d2net_v2_defconfig @@ -2,7 +2,6 @@ CONFIG_ARM=y CONFIG_KIRKWOOD=y CONFIG_TARGET_NET2BIG_V2=y CONFIG_IDENT_STRING=" D2 v2" -# CONFIG_MMC is not set CONFIG_SYS_EXTRA_OPTIONS="D2NET_V2" CONFIG_BOOTDELAY=3 CONFIG_CONSOLE_MUX=y @@ -20,6 +19,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +# CONFIG_MMC is not set CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SYS_NS16550=y diff --git a/configs/da850evm_direct_nor_defconfig b/configs/da850evm_direct_nor_defconfig index 8120b9d5d6..8aa5f167f0 100644 --- a/configs/da850evm_direct_nor_defconfig +++ b/configs/da850evm_direct_nor_defconfig @@ -1,7 +1,6 @@ CONFIG_ARM=y CONFIG_ARCH_DAVINCI=y CONFIG_TARGET_DA850EVM=y -# CONFIG_MMC is not set CONFIG_SYS_EXTRA_OPTIONS="MAC_ADDR_IN_SPIFLASH,USE_NOR,DIRECT_NOR_BOOT" CONFIG_BOOTDELAY=3 CONFIG_VERSION_VARIABLE=y @@ -15,6 +14,7 @@ CONFIG_CMD_SF=y CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y +# CONFIG_MMC is not set CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_SPI_FLASH_WINBOND=y diff --git a/configs/db-88f6720_defconfig b/configs/db-88f6720_defconfig index 20539d172c..26df95ae23 100644 --- a/configs/db-88f6720_defconfig +++ b/configs/db-88f6720_defconfig @@ -8,7 +8,6 @@ CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y -# CONFIG_MMC is not set CONFIG_DEFAULT_DEVICE_TREE="armada-375-db" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_BOOTDELAY=3 @@ -35,6 +34,7 @@ CONFIG_CMD_FS_GENERIC=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPL_OF_TRANSLATE=y CONFIG_MISC=y +# CONFIG_MMC is not set CONFIG_NAND_PXA3XX=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_MACRONIX=y diff --git a/configs/db-88f6820-amc_defconfig b/configs/db-88f6820-amc_defconfig index 5543be88d4..0f1a1f8632 100644 --- a/configs/db-88f6820-amc_defconfig +++ b/configs/db-88f6820-amc_defconfig @@ -7,7 +7,6 @@ CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y -# CONFIG_MMC is not set CONFIG_DEFAULT_DEVICE_TREE="armada-385-amc" CONFIG_FIT=y CONFIG_FIT_VERBOSE=y @@ -34,6 +33,7 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_SPL_OF_TRANSLATE=y +# CONFIG_MMC is not set CONFIG_NAND_PXA3XX=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_BAR=y diff --git a/configs/db-mv784mp-gp_defconfig b/configs/db-mv784mp-gp_defconfig index ffd9c5030b..dd0bf7582f 100644 --- a/configs/db-mv784mp-gp_defconfig +++ b/configs/db-mv784mp-gp_defconfig @@ -8,7 +8,6 @@ CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y -# CONFIG_MMC is not set CONFIG_DEFAULT_DEVICE_TREE="armada-xp-gp" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_BOOTDELAY=3 @@ -33,6 +32,7 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_SPL_OF_TRANSLATE=y +# CONFIG_MMC is not set CONFIG_NAND_PXA3XX=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_MACRONIX=y diff --git a/configs/devconcenter_defconfig b/configs/devconcenter_defconfig index 6ce8786d17..59722ac840 100644 --- a/configs/devconcenter_defconfig +++ b/configs/devconcenter_defconfig @@ -1,6 +1,5 @@ CONFIG_PPC=y CONFIG_IDENT_STRING=" devconcenter 0.06" -# CONFIG_MMC is not set CONFIG_4xx=y CONFIG_TARGET_INTIP=y CONFIG_FIT=y @@ -23,6 +22,7 @@ CONFIG_CMD_SNTP=y CONFIG_CMD_CACHE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +# CONFIG_MMC is not set CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/devkit3250_defconfig b/configs/devkit3250_defconfig index 2bbea13f7f..539834eed3 100644 --- a/configs/devkit3250_defconfig +++ b/configs/devkit3250_defconfig @@ -4,7 +4,6 @@ CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_NAND_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y -# CONFIG_MMC is not set CONFIG_BOOTDELAY=1 CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set @@ -24,6 +23,7 @@ CONFIG_CMD_FAT=y CONFIG_DM=y CONFIG_SPL_DM=y CONFIG_DM_GPIO=y +# CONFIG_MMC is not set CONFIG_DM_SERIAL=y CONFIG_SYS_NS16550=y CONFIG_USB=y diff --git a/configs/dfi-bt700-q7x-151_defconfig b/configs/dfi-bt700-q7x-151_defconfig index b7eb0061da..fc9c4f0b03 100644 --- a/configs/dfi-bt700-q7x-151_defconfig +++ b/configs/dfi-bt700-q7x-151_defconfig @@ -1,5 +1,4 @@ CONFIG_X86=y -CONFIG_MMC=y CONFIG_VENDOR_DFI=y CONFIG_DEFAULT_DEVICE_TREE="dfi-bt700-q7x-151" CONFIG_TARGET_DFI_BT700=y @@ -42,6 +41,7 @@ CONFIG_SYSCON=y CONFIG_CPU=y CONFIG_DM_I2C=y CONFIG_NUVOTON_NCT6102D=y +CONFIG_MMC=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_SDMA=y CONFIG_SPI_FLASH=y diff --git a/configs/digsy_mtc_RAMBOOT_defconfig b/configs/digsy_mtc_RAMBOOT_defconfig index d4b9628895..61ba49df1e 100644 --- a/configs/digsy_mtc_RAMBOOT_defconfig +++ b/configs/digsy_mtc_RAMBOOT_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_VIDEO=y CONFIG_MPC5xxx=y CONFIG_TARGET_DIGSY_MTC=y @@ -23,6 +22,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +# CONFIG_MMC is not set CONFIG_USB=y CONFIG_USB_STORAGE=y CONFIG_OF_LIBFDT=y diff --git a/configs/digsy_mtc_defconfig b/configs/digsy_mtc_defconfig index f8be655bd7..89276eb8b0 100644 --- a/configs/digsy_mtc_defconfig +++ b/configs/digsy_mtc_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_VIDEO=y CONFIG_MPC5xxx=y CONFIG_TARGET_DIGSY_MTC=y @@ -21,6 +20,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +# CONFIG_MMC is not set CONFIG_USB=y CONFIG_USB_STORAGE=y CONFIG_OF_LIBFDT=y diff --git a/configs/digsy_mtc_rev5_RAMBOOT_defconfig b/configs/digsy_mtc_rev5_RAMBOOT_defconfig index 46a4d107be..e43cac7555 100644 --- a/configs/digsy_mtc_rev5_RAMBOOT_defconfig +++ b/configs/digsy_mtc_rev5_RAMBOOT_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_VIDEO=y CONFIG_MPC5xxx=y CONFIG_TARGET_DIGSY_MTC=y @@ -23,6 +22,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +# CONFIG_MMC is not set CONFIG_USB=y CONFIG_USB_STORAGE=y CONFIG_OF_LIBFDT=y diff --git a/configs/digsy_mtc_rev5_defconfig b/configs/digsy_mtc_rev5_defconfig index 6bb8e08d9f..5ac58fb8c7 100644 --- a/configs/digsy_mtc_rev5_defconfig +++ b/configs/digsy_mtc_rev5_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_VIDEO=y CONFIG_MPC5xxx=y CONFIG_TARGET_DIGSY_MTC=y @@ -23,6 +22,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +# CONFIG_MMC is not set CONFIG_USB=y CONFIG_USB_STORAGE=y CONFIG_OF_LIBFDT=y diff --git a/configs/dlvision-10g_defconfig b/configs/dlvision-10g_defconfig index 2a5af4b52e..29032f11da 100644 --- a/configs/dlvision-10g_defconfig +++ b/configs/dlvision-10g_defconfig @@ -1,6 +1,5 @@ CONFIG_PPC=y CONFIG_IDENT_STRING=" dlvision-10g 0.06" -# CONFIG_MMC is not set CONFIG_4xx=y CONFIG_TARGET_DLVISION_10G=y CONFIG_FIT=y @@ -21,6 +20,7 @@ CONFIG_CMD_I2C=y # CONFIG_CMD_NFS is not set CONFIG_CMD_MII=y CONFIG_CMD_PING=y +# CONFIG_MMC is not set # CONFIG_PCI is not set CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/dlvision_defconfig b/configs/dlvision_defconfig index f8e96ac03a..e18923ce78 100644 --- a/configs/dlvision_defconfig +++ b/configs/dlvision_defconfig @@ -1,6 +1,5 @@ CONFIG_PPC=y CONFIG_IDENT_STRING=" dlvision 0.02" -# CONFIG_MMC is not set CONFIG_4xx=y CONFIG_TARGET_DLVISION=y CONFIG_FIT=y @@ -18,6 +17,7 @@ CONFIG_LOOPW=y # CONFIG_CMD_NFS is not set CONFIG_CMD_MII=y CONFIG_CMD_PING=y +# CONFIG_MMC is not set # CONFIG_PCI is not set CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/dns325_defconfig b/configs/dns325_defconfig index 3a31a66ab1..4f02f01dd9 100644 --- a/configs/dns325_defconfig +++ b/configs/dns325_defconfig @@ -2,7 +2,6 @@ CONFIG_ARM=y CONFIG_KIRKWOOD=y CONFIG_TARGET_DNS325=y CONFIG_IDENT_STRING="\nD-Link DNS-325" -# CONFIG_MMC is not set CONFIG_BOOTDELAY=3 CONFIG_CONSOLE_MUX=y # CONFIG_DISPLAY_BOARDINFO is not set @@ -17,6 +16,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_CMD_UBI=y +# CONFIG_MMC is not set CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/dockstar_defconfig b/configs/dockstar_defconfig index 2b13f00cfb..110133cea3 100644 --- a/configs/dockstar_defconfig +++ b/configs/dockstar_defconfig @@ -2,7 +2,6 @@ CONFIG_ARM=y CONFIG_KIRKWOOD=y CONFIG_TARGET_DOCKSTAR=y CONFIG_IDENT_STRING="\nSeagate FreeAgent DockStar" -# CONFIG_MMC is not set CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_SYS_PROMPT="DockStar> " @@ -16,6 +15,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_CMD_UBI=y +# CONFIG_MMC is not set CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/dreamplug_defconfig b/configs/dreamplug_defconfig index cb15755489..7281234cc1 100644 --- a/configs/dreamplug_defconfig +++ b/configs/dreamplug_defconfig @@ -2,7 +2,6 @@ CONFIG_ARM=y CONFIG_KIRKWOOD=y CONFIG_TARGET_DREAMPLUG=y CONFIG_IDENT_STRING="\nMarvell-DreamPlug" -# CONFIG_MMC is not set CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_HUSH_PARSER=y @@ -17,6 +16,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_EXT4=y CONFIG_CMD_FAT=y +# CONFIG_MMC is not set CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SYS_NS16550=y diff --git a/configs/ds109_defconfig b/configs/ds109_defconfig index 94d3c7440b..efb33e76b7 100644 --- a/configs/ds109_defconfig +++ b/configs/ds109_defconfig @@ -1,7 +1,6 @@ CONFIG_ARM=y CONFIG_KIRKWOOD=y CONFIG_TARGET_DS109=y -# CONFIG_MMC is not set CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set @@ -11,6 +10,7 @@ CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y +# CONFIG_MMC is not set CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_BAR=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/ds414_defconfig b/configs/ds414_defconfig index 502d6f8c33..89a9eed35b 100644 --- a/configs/ds414_defconfig +++ b/configs/ds414_defconfig @@ -8,7 +8,6 @@ CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y -# CONFIG_MMC is not set CONFIG_DEFAULT_DEVICE_TREE="armada-xp-synology-ds414" CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_BOARDINFO is not set @@ -29,6 +28,7 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_CMD_UBI=y CONFIG_SPL_OF_TRANSLATE=y +# CONFIG_MMC is not set CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_BAR=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/edb9315a_defconfig b/configs/edb9315a_defconfig index 86ae479796..0d24e8fb51 100644 --- a/configs/edb9315a_defconfig +++ b/configs/edb9315a_defconfig @@ -1,6 +1,5 @@ CONFIG_ARM=y CONFIG_TARGET_EDB93XX=y -# CONFIG_MMC is not set CONFIG_SYS_EXTRA_OPTIONS="MK_edb9315a" # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_DISPLAY_BOARDINFO is not set @@ -27,5 +26,6 @@ CONFIG_LED_STATUS_RED_ENABLE=y CONFIG_LED_STATUS_RED=1 CONFIG_LED_STATUS_GREEN_ENABLE=y CONFIG_LED_STATUS_GREEN=0 +# CONFIG_MMC is not set CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/edminiv2_defconfig b/configs/edminiv2_defconfig index df054d698d..ebd76238c3 100644 --- a/configs/edminiv2_defconfig +++ b/configs/edminiv2_defconfig @@ -5,7 +5,6 @@ CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_TARGET_EDMINIV2=y CONFIG_IDENT_STRING=" EDMiniV2" -# CONFIG_MMC is not set CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_SPL=y @@ -16,6 +15,7 @@ CONFIG_CMD_I2C=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_EXT2=y +# CONFIG_MMC is not set CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/espresso7420_defconfig b/configs/espresso7420_defconfig index 39837e9621..66f0d63a35 100644 --- a/configs/espresso7420_defconfig +++ b/configs/espresso7420_defconfig @@ -3,7 +3,6 @@ CONFIG_ARCH_EXYNOS=y CONFIG_ARCH_EXYNOS7=y CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_IDENT_STRING=" for ESPRESSO7420" -# CONFIG_MMC is not set CONFIG_DEFAULT_DEVICE_TREE="exynos7420-espresso7420" CONFIG_SILENT_CONSOLE=y CONFIG_CONSOLE_MUX=y @@ -12,3 +11,4 @@ CONFIG_SYS_PROMPT="ESPRESSO7420 # " # CONFIG_AUTOBOOT is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_SETEXPR is not set +# CONFIG_MMC is not set diff --git a/configs/evb-rk3399_defconfig b/configs/evb-rk3399_defconfig index 02d91a7561..1187940651 100644 --- a/configs/evb-rk3399_defconfig +++ b/configs/evb-rk3399_defconfig @@ -4,21 +4,13 @@ CONFIG_ROCKCHIP_RK3399=y CONFIG_DEFAULT_DEVICE_TREE="rk3399-evb" CONFIG_FIT=y # CONFIG_DISPLAY_CPUINFO is not set -CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set -CONFIG_CMD_DHCP=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y CONFIG_CMD_TIME=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_EXT4=y -CONFIG_CMD_FAT=y -CONFIG_CMD_FS_GENERIC=y CONFIG_REGMAP=y CONFIG_SYSCON=y CONFIG_CLK=y diff --git a/configs/flea3_defconfig b/configs/flea3_defconfig index 1dec625a80..47dfc0c349 100644 --- a/configs/flea3_defconfig +++ b/configs/flea3_defconfig @@ -1,6 +1,5 @@ CONFIG_ARM=y CONFIG_TARGET_FLEA3=y -# CONFIG_MMC is not set CONFIG_FIT=y CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTDELAY=3 @@ -14,6 +13,7 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y +# CONFIG_MMC is not set CONFIG_OF_LIBFDT=y CONFIG_FDT_FIXUP_PARTITIONS=y # CONFIG_EFI_LOADER is not set diff --git a/configs/fo300_defconfig b/configs/fo300_defconfig index dd2f965b20..81ecbd4700 100644 --- a/configs/fo300_defconfig +++ b/configs/fo300_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_VIDEO=y CONFIG_MPC5xxx=y CONFIG_TARGET_TQM5200=y @@ -21,6 +20,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_SNTP=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +# CONFIG_MMC is not set # CONFIG_PCI is not set CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/galileo_defconfig b/configs/galileo_defconfig index 7da870f03b..e25556be38 100644 --- a/configs/galileo_defconfig +++ b/configs/galileo_defconfig @@ -1,5 +1,4 @@ CONFIG_X86=y -CONFIG_MMC=y CONFIG_VENDOR_INTEL=y CONFIG_DEFAULT_DEVICE_TREE="galileo" CONFIG_TARGET_GALILEO=y @@ -37,6 +36,7 @@ CONFIG_NET_RANDOM_ETHADDR=y CONFIG_REGMAP=y CONFIG_SYSCON=y CONFIG_CPU=y +CONFIG_MMC=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_SDMA=y CONFIG_SPI_FLASH=y diff --git a/configs/gdppc440etx_defconfig b/configs/gdppc440etx_defconfig index 2a5a484432..8c10383b0d 100644 --- a/configs/gdppc440etx_defconfig +++ b/configs/gdppc440etx_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_4xx=y CONFIG_TARGET_GDPPC440ETX=y CONFIG_OF_BOARD_SETUP=y @@ -18,6 +17,7 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y +# CONFIG_MMC is not set # CONFIG_PCI_PNP is not set CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/glacier_defconfig b/configs/glacier_defconfig index 0343128bd8..e19cb7e602 100644 --- a/configs/glacier_defconfig +++ b/configs/glacier_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_4xx=y CONFIG_TARGET_CANYONLANDS=y CONFIG_GLACIER=y @@ -20,4 +19,5 @@ CONFIG_CMD_SNTP=y CONFIG_CMD_CACHE=y CONFIG_OF_CONTROL=y CONFIG_OF_EMBED=y +# CONFIG_MMC is not set CONFIG_SYS_NS16550=y diff --git a/configs/glacier_ramboot_defconfig b/configs/glacier_ramboot_defconfig index 31c9d0b8d3..9911729db3 100644 --- a/configs/glacier_ramboot_defconfig +++ b/configs/glacier_ramboot_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_4xx=y CONFIG_TARGET_CANYONLANDS=y CONFIG_GLACIER=y @@ -21,4 +20,5 @@ CONFIG_CMD_SNTP=y CONFIG_CMD_CACHE=y CONFIG_OF_CONTROL=y CONFIG_OF_EMBED=y +# CONFIG_MMC is not set CONFIG_SYS_NS16550=y diff --git a/configs/goflexhome_defconfig b/configs/goflexhome_defconfig index 57a4c78864..434705dae6 100644 --- a/configs/goflexhome_defconfig +++ b/configs/goflexhome_defconfig @@ -2,7 +2,6 @@ CONFIG_ARM=y CONFIG_KIRKWOOD=y CONFIG_TARGET_GOFLEXHOME=y CONFIG_IDENT_STRING="\nSeagate GoFlex Home" -# CONFIG_MMC is not set CONFIG_BOOTDELAY=3 CONFIG_CONSOLE_MUX=y # CONFIG_DISPLAY_BOARDINFO is not set @@ -18,6 +17,7 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_EXT4=y CONFIG_CMD_FAT=y CONFIG_CMD_UBI=y +# CONFIG_MMC is not set CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/gplugd_defconfig b/configs/gplugd_defconfig index 3b22e6c2df..286c0b050e 100644 --- a/configs/gplugd_defconfig +++ b/configs/gplugd_defconfig @@ -1,7 +1,6 @@ CONFIG_ARM=y CONFIG_TARGET_GPLUGD=y CONFIG_IDENT_STRING="\nMarvell-gplugD" -# CONFIG_MMC is not set CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_BOARDINFO is not set # CONFIG_CMD_IMLS is not set @@ -15,6 +14,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +# CONFIG_MMC is not set CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/guruplug_defconfig b/configs/guruplug_defconfig index 73a1213d5f..f80961c84c 100644 --- a/configs/guruplug_defconfig +++ b/configs/guruplug_defconfig @@ -2,7 +2,6 @@ CONFIG_ARM=y CONFIG_KIRKWOOD=y CONFIG_TARGET_GURUPLUG=y CONFIG_IDENT_STRING="\nMarvell-GuruPlug" -# CONFIG_MMC is not set CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_HUSH_PARSER=y @@ -19,6 +18,7 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_EXT4=y CONFIG_CMD_FAT=y CONFIG_CMD_UBI=y +# CONFIG_MMC is not set CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/h2200_defconfig b/configs/h2200_defconfig index e7afd81007..b85ed59806 100644 --- a/configs/h2200_defconfig +++ b/configs/h2200_defconfig @@ -1,6 +1,5 @@ CONFIG_ARM=y CONFIG_TARGET_H2200=y -# CONFIG_MMC is not set CONFIG_FIT=y CONFIG_SYS_CONSOLE_IS_IN_ENV=y # CONFIG_DISPLAY_CPUINFO is not set @@ -25,4 +24,5 @@ CONFIG_SYS_PROMPT="> " # CONFIG_CMD_NFS is not set CONFIG_CMD_PING=y # CONFIG_CMD_MISC is not set +# CONFIG_MMC is not set CONFIG_PXA_SERIAL=y diff --git a/configs/haleakala_defconfig b/configs/haleakala_defconfig index 2447cdd9b4..8a195581f4 100644 --- a/configs/haleakala_defconfig +++ b/configs/haleakala_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_4xx=y CONFIG_TARGET_KILAUEA=y CONFIG_OF_BOARD_SETUP=y @@ -17,5 +16,6 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_SNTP=y +# CONFIG_MMC is not set CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/highbank_defconfig b/configs/highbank_defconfig index b1c8afdd49..caa739ace8 100644 --- a/configs/highbank_defconfig +++ b/configs/highbank_defconfig @@ -1,6 +1,5 @@ CONFIG_ARM=y CONFIG_ARCH_HIGHBANK=y -# CONFIG_MMC is not set CONFIG_FIT=y CONFIG_OF_BOARD_SETUP=y # CONFIG_DISPLAY_CPUINFO is not set @@ -20,4 +19,5 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_EXT4=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +# CONFIG_MMC is not set CONFIG_OF_LIBFDT=y diff --git a/configs/ib62x0_defconfig b/configs/ib62x0_defconfig index 9c95b47828..68aa327525 100644 --- a/configs/ib62x0_defconfig +++ b/configs/ib62x0_defconfig @@ -2,7 +2,6 @@ CONFIG_ARM=y CONFIG_KIRKWOOD=y CONFIG_TARGET_IB62X0=y CONFIG_IDENT_STRING=" RaidSonic ICY BOX IB-NAS62x0" -# CONFIG_MMC is not set CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_HUSH_PARSER=y @@ -19,6 +18,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_CMD_UBI=y +# CONFIG_MMC is not set CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/icon_defconfig b/configs/icon_defconfig index 39ae1f3f41..19080d7c3f 100644 --- a/configs/icon_defconfig +++ b/configs/icon_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_VIDEO=y CONFIG_4xx=y CONFIG_TARGET_ICON=y @@ -21,6 +20,7 @@ CONFIG_CMD_SNTP=y CONFIG_CMD_CACHE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +# CONFIG_MMC is not set CONFIG_SYS_NS16550=y CONFIG_CONSOLE_EXTRA_INFO=y CONFIG_OF_LIBFDT=y diff --git a/configs/iconnect_defconfig b/configs/iconnect_defconfig index d869628dda..a546d49f1c 100644 --- a/configs/iconnect_defconfig +++ b/configs/iconnect_defconfig @@ -2,7 +2,6 @@ CONFIG_ARM=y CONFIG_KIRKWOOD=y CONFIG_TARGET_ICONNECT=y CONFIG_IDENT_STRING=" Iomega iConnect" -# CONFIG_MMC is not set CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_SYS_PROMPT="iconnect => " @@ -15,6 +14,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_CMD_UBI=y +# CONFIG_MMC is not set CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/ids8313_defconfig b/configs/ids8313_defconfig index fd43503214..fa8819a9ba 100644 --- a/configs/ids8313_defconfig +++ b/configs/ids8313_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_MPC83xx=y CONFIG_TARGET_IDS8313=y CONFIG_FIT=y @@ -22,6 +21,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_SNTP=y CONFIG_CMD_UBI=y +# CONFIG_MMC is not set # CONFIG_PCI is not set CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/imx31_phycore_defconfig b/configs/imx31_phycore_defconfig index d555c8acb8..5943fc413d 100644 --- a/configs/imx31_phycore_defconfig +++ b/configs/imx31_phycore_defconfig @@ -1,8 +1,8 @@ CONFIG_ARM=y CONFIG_TARGET_IMX31_PHYCORE=y -# CONFIG_MMC is not set CONFIG_BOOTDELAY=3 CONFIG_SYS_PROMPT="uboot> " CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_PING=y +# CONFIG_MMC is not set diff --git a/configs/imx6dl_icore_mmc_defconfig b/configs/imx6dl_icore_mmc_defconfig index 9e8af0a13c..a74ae8bb55 100644 --- a/configs/imx6dl_icore_mmc_defconfig +++ b/configs/imx6dl_icore_mmc_defconfig @@ -10,15 +10,15 @@ CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y CONFIG_VIDEO=y CONFIG_DEFAULT_DEVICE_TREE="imx6dl-icore" +CONFIG_FIT=y +CONFIG_FIT_SIGNATURE=y +CONFIG_FIT_VERBOSE=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,ENV_IS_IN_MMC" CONFIG_BOOTDELAY=3 CONFIG_DEFAULT_FDT_FILE="imx6dl-icore.dtb" CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="icorem6qdl> " -CONFIG_FIT=y -CONFIG_FIT_VERBOSE=y -CONFIG_FIT_SIGNATURE=y # CONFIG_CMD_IMLS is not set CONFIG_CMD_MEMTEST=y CONFIG_CMD_MMC=y diff --git a/configs/imx6dl_icore_nand_defconfig b/configs/imx6dl_icore_nand_defconfig index da1f6f6b4b..69d6b56cb1 100644 --- a/configs/imx6dl_icore_nand_defconfig +++ b/configs/imx6dl_icore_nand_defconfig @@ -8,6 +8,9 @@ CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y CONFIG_VIDEO=y CONFIG_DEFAULT_DEVICE_TREE="imx6dl-icore" +CONFIG_FIT=y +CONFIG_FIT_SIGNATURE=y +CONFIG_FIT_VERBOSE=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,ENV_IS_IN_NAND" CONFIG_BOOTDELAY=3 CONFIG_DEFAULT_FDT_FILE="imx6dl-icore.dtb" @@ -15,14 +18,10 @@ CONFIG_SPL=y CONFIG_SPL_DMA_SUPPORT=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="icorem6qdl> " -CONFIG_FIT=y -CONFIG_FIT_VERBOSE=y -CONFIG_FIT_SIGNATURE=y # CONFIG_CMD_IMLS is not set CONFIG_CMD_MEMTEST=y CONFIG_CMD_MMC=y CONFIG_CMD_NAND=y -CONFIG_CMD_UBI=y CONFIG_CMD_I2C=y CONFIG_CMD_GPIO=y CONFIG_CMD_MII=y @@ -32,6 +31,7 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_CMD_UBI=y # CONFIG_BLK is not set CONFIG_SYS_I2C_MXC=y # CONFIG_DM_MMC_OPS is not set diff --git a/configs/imx6dl_icore_rqs_mmc_defconfig b/configs/imx6dl_icore_rqs_mmc_defconfig index 3b10e99aca..d9d4a0e155 100644 --- a/configs/imx6dl_icore_rqs_mmc_defconfig +++ b/configs/imx6dl_icore_rqs_mmc_defconfig @@ -9,14 +9,14 @@ CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y CONFIG_DEFAULT_DEVICE_TREE="imx6dl-icore-rqs" +CONFIG_FIT=y +CONFIG_FIT_SIGNATURE=y +CONFIG_FIT_VERBOSE=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,ENV_IS_IN_MMC" CONFIG_BOOTDELAY=3 CONFIG_DEFAULT_FDT_FILE="imx6dl-icore-rqs.dtb" CONFIG_SPL=y CONFIG_HUSH_PARSER=y -CONFIG_FIT=y -CONFIG_FIT_VERBOSE=y -CONFIG_FIT_SIGNATURE=y CONFIG_SYS_PROMPT="icorem6qdl-rqs> " # CONFIG_CMD_IMLS is not set CONFIG_CMD_MEMTEST=y diff --git a/configs/imx6q_icore_mmc_defconfig b/configs/imx6q_icore_mmc_defconfig index 370768e0c8..9957e928ff 100644 --- a/configs/imx6q_icore_mmc_defconfig +++ b/configs/imx6q_icore_mmc_defconfig @@ -10,14 +10,14 @@ CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y CONFIG_VIDEO=y CONFIG_DEFAULT_DEVICE_TREE="imx6q-icore" +CONFIG_FIT=y +CONFIG_FIT_SIGNATURE=y +CONFIG_FIT_VERBOSE=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,ENV_IS_IN_MMC" CONFIG_BOOTDELAY=3 CONFIG_DEFAULT_FDT_FILE="imx6q-icore.dtb" CONFIG_SPL=y CONFIG_HUSH_PARSER=y -CONFIG_FIT=y -CONFIG_FIT_VERBOSE=y -CONFIG_FIT_SIGNATURE=y CONFIG_SYS_PROMPT="icorem6qdl> " # CONFIG_CMD_IMLS is not set CONFIG_CMD_MEMTEST=y diff --git a/configs/imx6q_icore_nand_defconfig b/configs/imx6q_icore_nand_defconfig index a5a3fc4c99..e9e41a0a2b 100644 --- a/configs/imx6q_icore_nand_defconfig +++ b/configs/imx6q_icore_nand_defconfig @@ -8,21 +8,20 @@ CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y CONFIG_VIDEO=y CONFIG_DEFAULT_DEVICE_TREE="imx6q-icore" +CONFIG_FIT=y +CONFIG_FIT_SIGNATURE=y +CONFIG_FIT_VERBOSE=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,ENV_IS_IN_NAND" CONFIG_BOOTDELAY=3 CONFIG_DEFAULT_FDT_FILE="imx6q-icore.dtb" CONFIG_SPL=y CONFIG_SPL_DMA_SUPPORT=y CONFIG_HUSH_PARSER=y -CONFIG_FIT=y -CONFIG_FIT_VERBOSE=y -CONFIG_FIT_SIGNATURE=y CONFIG_SYS_PROMPT="icorem6qdl> " # CONFIG_CMD_IMLS is not set CONFIG_CMD_MEMTEST=y CONFIG_CMD_MMC=y CONFIG_CMD_NAND=y -CONFIG_CMD_UBI=y CONFIG_CMD_I2C=y CONFIG_CMD_GPIO=y CONFIG_CMD_MII=y @@ -32,6 +31,7 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_CMD_UBI=y # CONFIG_BLK is not set CONFIG_SYS_I2C_MXC=y # CONFIG_DM_MMC_OPS is not set diff --git a/configs/imx6q_icore_rqs_mmc_defconfig b/configs/imx6q_icore_rqs_mmc_defconfig index 8df4ef0ca8..480a2a3495 100644 --- a/configs/imx6q_icore_rqs_mmc_defconfig +++ b/configs/imx6q_icore_rqs_mmc_defconfig @@ -9,14 +9,14 @@ CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y CONFIG_DEFAULT_DEVICE_TREE="imx6q-icore-rqs" +CONFIG_FIT=y +CONFIG_FIT_SIGNATURE=y +CONFIG_FIT_VERBOSE=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,ENV_IS_IN_MMC" CONFIG_BOOTDELAY=3 CONFIG_DEFAULT_FDT_FILE="imx6q-icore-rqs.dtb" CONFIG_SPL=y CONFIG_HUSH_PARSER=y -CONFIG_FIT=y -CONFIG_FIT_VERBOSE=y -CONFIG_FIT_SIGNATURE=y CONFIG_SYS_PROMPT="icorem6qdl-rqs> " # CONFIG_CMD_IMLS is not set CONFIG_CMD_MEMTEST=y diff --git a/configs/imx6ul_geam_mmc_defconfig b/configs/imx6ul_geam_mmc_defconfig index 2b53b418b3..1d224607f6 100644 --- a/configs/imx6ul_geam_mmc_defconfig +++ b/configs/imx6ul_geam_mmc_defconfig @@ -9,14 +9,14 @@ CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y CONFIG_DEFAULT_DEVICE_TREE="imx6ul-geam-kit" +CONFIG_FIT=y +CONFIG_FIT_SIGNATURE=y +CONFIG_FIT_VERBOSE=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,ENV_IS_IN_MMC" CONFIG_BOOTDELAY=3 CONFIG_DEFAULT_FDT_FILE="imx6ul-geam-kit.dtb" CONFIG_SPL=y CONFIG_HUSH_PARSER=y -CONFIG_FIT=y -CONFIG_FIT_VERBOSE=y -CONFIG_FIT_SIGNATURE=y CONFIG_SYS_PROMPT="geam6ul> " # CONFIG_CMD_IMLS is not set CONFIG_CMD_MEMTEST=y diff --git a/configs/imx6ul_geam_nand_defconfig b/configs/imx6ul_geam_nand_defconfig index 448529a920..a4512c525c 100644 --- a/configs/imx6ul_geam_nand_defconfig +++ b/configs/imx6ul_geam_nand_defconfig @@ -7,36 +7,36 @@ CONFIG_TARGET_MX6UL_GEAM=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y CONFIG_DEFAULT_DEVICE_TREE="imx6ul-geam-kit" +CONFIG_FIT=y +CONFIG_FIT_SIGNATURE=y +CONFIG_FIT_VERBOSE=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,ENV_IS_IN_NAND" CONFIG_BOOTDELAY=3 CONFIG_DEFAULT_FDT_FILE="imx6ul-geam-kit.dtb" CONFIG_SPL=y CONFIG_SPL_DMA_SUPPORT=y CONFIG_HUSH_PARSER=y -CONFIG_FIT=y -CONFIG_FIT_VERBOSE=y -CONFIG_FIT_SIGNATURE=y CONFIG_SYS_PROMPT="geam6ul> " # CONFIG_CMD_IMLS is not set CONFIG_CMD_MEMTEST=y CONFIG_CMD_MMC=y CONFIG_CMD_NAND=y -CONFIG_CMD_UBI=y +CONFIG_CMD_I2C=y CONFIG_CMD_GPIO=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y -CONFIG_CMD_I2C=y CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_CMD_UBI=y # CONFIG_BLK is not set +CONFIG_SYS_I2C_MXC=y # CONFIG_DM_MMC_OPS is not set CONFIG_NAND_MXS=y CONFIG_FEC_MXC=y CONFIG_PINCTRL=y CONFIG_PINCTRL_IMX6=y -CONFIG_SYS_I2C_MXC=y CONFIG_MXC_UART=y CONFIG_IMX_THERMAL=y diff --git a/configs/inetspace_v2_defconfig b/configs/inetspace_v2_defconfig index bbe20a153a..9d50c3189d 100644 --- a/configs/inetspace_v2_defconfig +++ b/configs/inetspace_v2_defconfig @@ -2,7 +2,6 @@ CONFIG_ARM=y CONFIG_KIRKWOOD=y CONFIG_TARGET_NETSPACE_V2=y CONFIG_IDENT_STRING=" IS v2" -# CONFIG_MMC is not set CONFIG_SYS_EXTRA_OPTIONS="INETSPACE_V2" CONFIG_BOOTDELAY=3 CONFIG_CONSOLE_MUX=y @@ -20,6 +19,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +# CONFIG_MMC is not set CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SYS_NS16550=y diff --git a/configs/inka4x0_defconfig b/configs/inka4x0_defconfig index cf21cfbbaa..36a4cf01b7 100644 --- a/configs/inka4x0_defconfig +++ b/configs/inka4x0_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_MPC5xxx=y CONFIG_TARGET_INKA4X0=y CONFIG_BOOTDELAY=1 @@ -11,5 +10,6 @@ CONFIG_CMD_PING=y CONFIG_CMD_SNTP=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +# CONFIG_MMC is not set CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/integratorap_cm720t_defconfig b/configs/integratorap_cm720t_defconfig index acef43776c..b572861d7c 100644 --- a/configs/integratorap_cm720t_defconfig +++ b/configs/integratorap_cm720t_defconfig @@ -2,12 +2,12 @@ CONFIG_ARM=y CONFIG_ARCH_INTEGRATOR=y CONFIG_ARCH_INTEGRATOR_AP=y CONFIG_CM720T=y -# CONFIG_MMC is not set # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Integrator-AP # " CONFIG_CMD_ARMFLASH=y # CONFIG_CMD_SETEXPR is not set +# CONFIG_MMC is not set CONFIG_PCI=y CONFIG_OF_LIBFDT=y diff --git a/configs/integratorap_cm920t_defconfig b/configs/integratorap_cm920t_defconfig index fe084db8cb..a999b81d59 100644 --- a/configs/integratorap_cm920t_defconfig +++ b/configs/integratorap_cm920t_defconfig @@ -2,12 +2,12 @@ CONFIG_ARM=y CONFIG_ARCH_INTEGRATOR=y CONFIG_ARCH_INTEGRATOR_AP=y CONFIG_CM920T=y -# CONFIG_MMC is not set # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Integrator-AP # " CONFIG_CMD_ARMFLASH=y # CONFIG_CMD_SETEXPR is not set +# CONFIG_MMC is not set CONFIG_PCI=y CONFIG_OF_LIBFDT=y diff --git a/configs/integratorap_cm926ejs_defconfig b/configs/integratorap_cm926ejs_defconfig index b4bfa6ad15..574d4260b7 100644 --- a/configs/integratorap_cm926ejs_defconfig +++ b/configs/integratorap_cm926ejs_defconfig @@ -2,12 +2,12 @@ CONFIG_ARM=y CONFIG_ARCH_INTEGRATOR=y CONFIG_ARCH_INTEGRATOR_AP=y CONFIG_CM926EJ_S=y -# CONFIG_MMC is not set # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Integrator-AP # " CONFIG_CMD_ARMFLASH=y # CONFIG_CMD_SETEXPR is not set +# CONFIG_MMC is not set CONFIG_PCI=y CONFIG_OF_LIBFDT=y diff --git a/configs/integratorap_cm946es_defconfig b/configs/integratorap_cm946es_defconfig index 4ada1f5e57..c1e9e222b0 100644 --- a/configs/integratorap_cm946es_defconfig +++ b/configs/integratorap_cm946es_defconfig @@ -2,12 +2,12 @@ CONFIG_ARM=y CONFIG_ARCH_INTEGRATOR=y CONFIG_ARCH_INTEGRATOR_AP=y CONFIG_CM946ES=y -# CONFIG_MMC is not set # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Integrator-AP # " CONFIG_CMD_ARMFLASH=y # CONFIG_CMD_SETEXPR is not set +# CONFIG_MMC is not set CONFIG_PCI=y CONFIG_OF_LIBFDT=y diff --git a/configs/integratorcp_cm1136_defconfig b/configs/integratorcp_cm1136_defconfig index be082599f0..ebbe82ba3f 100644 --- a/configs/integratorcp_cm1136_defconfig +++ b/configs/integratorcp_cm1136_defconfig @@ -2,11 +2,11 @@ CONFIG_ARM=y CONFIG_ARCH_INTEGRATOR=y CONFIG_ARCH_INTEGRATOR_CP=y CONFIG_CM1136=y -# CONFIG_MMC is not set # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Integrator-CP # " CONFIG_CMD_ARMFLASH=y # CONFIG_CMD_SETEXPR is not set +# CONFIG_MMC is not set CONFIG_OF_LIBFDT=y diff --git a/configs/integratorcp_cm920t_defconfig b/configs/integratorcp_cm920t_defconfig index ef4bbb5390..d09f16b3cc 100644 --- a/configs/integratorcp_cm920t_defconfig +++ b/configs/integratorcp_cm920t_defconfig @@ -2,11 +2,11 @@ CONFIG_ARM=y CONFIG_ARCH_INTEGRATOR=y CONFIG_ARCH_INTEGRATOR_CP=y CONFIG_CM920T=y -# CONFIG_MMC is not set # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Integrator-CP # " CONFIG_CMD_ARMFLASH=y # CONFIG_CMD_SETEXPR is not set +# CONFIG_MMC is not set CONFIG_OF_LIBFDT=y diff --git a/configs/integratorcp_cm926ejs_defconfig b/configs/integratorcp_cm926ejs_defconfig index 3641279906..d1245d6d0d 100644 --- a/configs/integratorcp_cm926ejs_defconfig +++ b/configs/integratorcp_cm926ejs_defconfig @@ -2,11 +2,11 @@ CONFIG_ARM=y CONFIG_ARCH_INTEGRATOR=y CONFIG_ARCH_INTEGRATOR_CP=y CONFIG_CM926EJ_S=y -# CONFIG_MMC is not set # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Integrator-CP # " CONFIG_CMD_ARMFLASH=y # CONFIG_CMD_SETEXPR is not set +# CONFIG_MMC is not set CONFIG_OF_LIBFDT=y diff --git a/configs/integratorcp_cm946es_defconfig b/configs/integratorcp_cm946es_defconfig index 8964a09655..b496568625 100644 --- a/configs/integratorcp_cm946es_defconfig +++ b/configs/integratorcp_cm946es_defconfig @@ -2,11 +2,11 @@ CONFIG_ARM=y CONFIG_ARCH_INTEGRATOR=y CONFIG_ARCH_INTEGRATOR_CP=y CONFIG_CM946ES=y -# CONFIG_MMC is not set # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Integrator-CP # " CONFIG_CMD_ARMFLASH=y # CONFIG_CMD_SETEXPR is not set +# CONFIG_MMC is not set CONFIG_OF_LIBFDT=y diff --git a/configs/intip_defconfig b/configs/intip_defconfig index c929277d83..3ce0ec8259 100644 --- a/configs/intip_defconfig +++ b/configs/intip_defconfig @@ -1,6 +1,5 @@ CONFIG_PPC=y CONFIG_IDENT_STRING=" intip 0.06" -# CONFIG_MMC is not set CONFIG_4xx=y CONFIG_TARGET_INTIP=y CONFIG_FIT=y @@ -25,6 +24,7 @@ CONFIG_CMD_SNTP=y CONFIG_CMD_CACHE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +# CONFIG_MMC is not set CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/io64_defconfig b/configs/io64_defconfig index 2791557c33..6b22ab6a02 100644 --- a/configs/io64_defconfig +++ b/configs/io64_defconfig @@ -1,6 +1,5 @@ CONFIG_PPC=y CONFIG_IDENT_STRING=" io64 0.02" -# CONFIG_MMC is not set CONFIG_4xx=y CONFIG_TARGET_IO64=y CONFIG_FIT=y @@ -21,6 +20,7 @@ CONFIG_CMD_I2C=y CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y +# CONFIG_MMC is not set # CONFIG_PCI is not set CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/io_defconfig b/configs/io_defconfig index 1c9323a613..6c5ebc3a5b 100644 --- a/configs/io_defconfig +++ b/configs/io_defconfig @@ -1,6 +1,5 @@ CONFIG_PPC=y CONFIG_IDENT_STRING=" io 0.06" -# CONFIG_MMC is not set CONFIG_4xx=y CONFIG_TARGET_IO=y CONFIG_FIT=y @@ -20,6 +19,7 @@ CONFIG_LOOPW=y # CONFIG_CMD_NFS is not set CONFIG_CMD_MII=y CONFIG_CMD_PING=y +# CONFIG_MMC is not set # CONFIG_PCI is not set CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/iocon_defconfig b/configs/iocon_defconfig index 175979d531..cb36cd8d79 100644 --- a/configs/iocon_defconfig +++ b/configs/iocon_defconfig @@ -1,6 +1,5 @@ CONFIG_PPC=y CONFIG_IDENT_STRING=" iocon 0.06" -# CONFIG_MMC is not set CONFIG_4xx=y CONFIG_TARGET_IOCON=y CONFIG_FIT=y @@ -21,6 +20,7 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y +# CONFIG_MMC is not set # CONFIG_PCI is not set CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/ipam390_defconfig b/configs/ipam390_defconfig index 258ffe69e4..faa9709370 100644 --- a/configs/ipam390_defconfig +++ b/configs/ipam390_defconfig @@ -6,7 +6,6 @@ CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_NAND_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y -# CONFIG_MMC is not set CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_DISPLAY_BOARDINFO is not set @@ -22,4 +21,5 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_UBI=y +# CONFIG_MMC is not set CONFIG_SYS_NS16550=y diff --git a/configs/ipek01_defconfig b/configs/ipek01_defconfig index a4a637f26e..c3afc70ddb 100644 --- a/configs/ipek01_defconfig +++ b/configs/ipek01_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_VIDEO=y CONFIG_MPC5xxx=y CONFIG_TARGET_IPEK01=y @@ -14,6 +13,7 @@ CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_FAT=y +# CONFIG_MMC is not set CONFIG_USB=y CONFIG_USB_STORAGE=y CONFIG_CONSOLE_EXTRA_INFO=y diff --git a/configs/jupiter_defconfig b/configs/jupiter_defconfig index 1558ab1794..7c9186e2aa 100644 --- a/configs/jupiter_defconfig +++ b/configs/jupiter_defconfig @@ -1,9 +1,9 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_MPC5xxx=y CONFIG_TARGET_JUPITER=y CONFIG_BOOTDELAY=5 CONFIG_HUSH_PARSER=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_SNTP=y +# CONFIG_MMC is not set # CONFIG_PCI is not set diff --git a/configs/k2e_evm_defconfig b/configs/k2e_evm_defconfig index 835d0c9cc2..5fb3e71fb4 100644 --- a/configs/k2e_evm_defconfig +++ b/configs/k2e_evm_defconfig @@ -8,7 +8,6 @@ CONFIG_SPL_POWER_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y -# CONFIG_MMC is not set CONFIG_DEFAULT_DEVICE_TREE="k2e-evm" CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_CONSOLE_INFO_QUIET=y @@ -39,6 +38,7 @@ CONFIG_OF_CONTROL=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y CONFIG_TI_AEMIF=y +# CONFIG_MMC is not set CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/k2hk_evm_defconfig b/configs/k2hk_evm_defconfig index 34defa81d0..fd2da4b65d 100644 --- a/configs/k2hk_evm_defconfig +++ b/configs/k2hk_evm_defconfig @@ -8,7 +8,6 @@ CONFIG_SPL_POWER_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y -# CONFIG_MMC is not set CONFIG_DEFAULT_DEVICE_TREE="k2hk-evm" CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_CONSOLE_INFO_QUIET=y @@ -39,6 +38,7 @@ CONFIG_OF_CONTROL=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y CONFIG_TI_AEMIF=y +# CONFIG_MMC is not set CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/k2l_evm_defconfig b/configs/k2l_evm_defconfig index 75bcd9f9b3..95152b5e28 100644 --- a/configs/k2l_evm_defconfig +++ b/configs/k2l_evm_defconfig @@ -8,7 +8,6 @@ CONFIG_SPL_POWER_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y -# CONFIG_MMC is not set CONFIG_DEFAULT_DEVICE_TREE="k2l-evm" CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_CONSOLE_INFO_QUIET=y @@ -39,6 +38,7 @@ CONFIG_OF_CONTROL=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y CONFIG_TI_AEMIF=y +# CONFIG_MMC is not set CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/katmai_defconfig b/configs/katmai_defconfig index 703347e2f3..816d1b3202 100644 --- a/configs/katmai_defconfig +++ b/configs/katmai_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_4xx=y CONFIG_TARGET_KATMAI=y CONFIG_OF_BOARD_SETUP=y @@ -18,5 +17,6 @@ CONFIG_CMD_SNTP=y CONFIG_CMD_CACHE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +# CONFIG_MMC is not set CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/kilauea_defconfig b/configs/kilauea_defconfig index c57dc1bac5..8d4978ebed 100644 --- a/configs/kilauea_defconfig +++ b/configs/kilauea_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_4xx=y CONFIG_TARGET_KILAUEA=y CONFIG_OF_BOARD_SETUP=y @@ -17,5 +16,6 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_SNTP=y +# CONFIG_MMC is not set CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/kmcoge4_defconfig b/configs/kmcoge4_defconfig index 9b3061cc89..d4b403bb08 100644 --- a/configs/kmcoge4_defconfig +++ b/configs/kmcoge4_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_MPC85xx=y CONFIG_TARGET_KMP204X=y CONFIG_FIT=y @@ -22,6 +21,7 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_UBI=y +# CONFIG_MMC is not set CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/kmcoge5ne_defconfig b/configs/kmcoge5ne_defconfig index 82ba9c1a64..953eea56fd 100644 --- a/configs/kmcoge5ne_defconfig +++ b/configs/kmcoge5ne_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_MPC83xx=y CONFIG_TARGET_KM8360=y CONFIG_OF_BOARD_SETUP=y @@ -17,6 +16,7 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_UBI=y +# CONFIG_MMC is not set # CONFIG_PCI is not set CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/kmeter1_defconfig b/configs/kmeter1_defconfig index c4e20f41fb..d6a5427210 100644 --- a/configs/kmeter1_defconfig +++ b/configs/kmeter1_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_MPC83xx=y CONFIG_TARGET_KM8360=y CONFIG_OF_BOARD_SETUP=y @@ -17,6 +16,7 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_UBI=y +# CONFIG_MMC is not set # CONFIG_PCI is not set CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/kmlion1_defconfig b/configs/kmlion1_defconfig index 6f18dbc91f..a6a4db3eae 100644 --- a/configs/kmlion1_defconfig +++ b/configs/kmlion1_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_MPC85xx=y CONFIG_TARGET_KMP204X=y CONFIG_FIT=y @@ -22,6 +21,7 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_UBI=y +# CONFIG_MMC is not set CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/kmopti2_defconfig b/configs/kmopti2_defconfig index cc8083455e..a41360cea8 100644 --- a/configs/kmopti2_defconfig +++ b/configs/kmopti2_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_MPC83xx=y CONFIG_TARGET_TUXX1=y CONFIG_OF_BOARD_SETUP=y @@ -17,6 +16,7 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_UBI=y +# CONFIG_MMC is not set # CONFIG_PCI is not set CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/kmsupx5_defconfig b/configs/kmsupx5_defconfig index 400601bce7..036e43c37b 100644 --- a/configs/kmsupx5_defconfig +++ b/configs/kmsupx5_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_MPC83xx=y CONFIG_TARGET_TUXX1=y CONFIG_OF_BOARD_SETUP=y @@ -17,6 +16,7 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_UBI=y +# CONFIG_MMC is not set # CONFIG_PCI is not set CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/kmtegr1_defconfig b/configs/kmtegr1_defconfig index 8082a22add..27e4fbf77d 100644 --- a/configs/kmtegr1_defconfig +++ b/configs/kmtegr1_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_MPC83xx=y CONFIG_TARGET_SUVD3=y CONFIG_OF_BOARD_SETUP=y @@ -17,6 +16,7 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_UBI=y +# CONFIG_MMC is not set # CONFIG_PCI is not set CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/kmtepr2_defconfig b/configs/kmtepr2_defconfig index a51db853b2..e11dadb548 100644 --- a/configs/kmtepr2_defconfig +++ b/configs/kmtepr2_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_MPC83xx=y CONFIG_TARGET_TUXX1=y CONFIG_OF_BOARD_SETUP=y @@ -17,6 +16,7 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_UBI=y +# CONFIG_MMC is not set # CONFIG_PCI is not set CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/kmvect1_defconfig b/configs/kmvect1_defconfig index 2013350b78..a05a6367e8 100644 --- a/configs/kmvect1_defconfig +++ b/configs/kmvect1_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_MPC83xx=y CONFIG_TARGET_SUVD3=y CONFIG_OF_BOARD_SETUP=y @@ -17,6 +16,7 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_UBI=y +# CONFIG_MMC is not set # CONFIG_PCI is not set CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/kzm9g_defconfig b/configs/kzm9g_defconfig index f76496278f..c07bffeb5c 100644 --- a/configs/kzm9g_defconfig +++ b/configs/kzm9g_defconfig @@ -1,7 +1,6 @@ CONFIG_ARM=y CONFIG_ARCH_RMOBILE=y CONFIG_TARGET_KZM9G=y -# CONFIG_MMC is not set CONFIG_BOOTDELAY=3 CONFIG_VERSION_VARIABLE=y CONFIG_SYS_PROMPT="KZM-A9-GT# " @@ -11,4 +10,5 @@ CONFIG_CMD_I2C=y CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y +# CONFIG_MMC is not set CONFIG_OF_LIBFDT=y diff --git a/configs/ls1012afrdm_qspi_defconfig b/configs/ls1012afrdm_qspi_defconfig index 89326501cb..2af5a61cd7 100644 --- a/configs/ls1012afrdm_qspi_defconfig +++ b/configs/ls1012afrdm_qspi_defconfig @@ -1,7 +1,6 @@ CONFIG_ARM=y CONFIG_TARGET_LS1012AFRDM=y CONFIG_QSPI_AHB_INIT=y -# CONFIG_MMC is not set CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1012a-frdm" # CONFIG_SYS_MALLOC_F is not set CONFIG_FIT=y @@ -27,10 +26,15 @@ CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y +# CONFIG_MMC is not set CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_NETDEVICES=y CONFIG_E1000=y +CONFIG_PCI=y +CONFIG_DM_PCI=y +CONFIG_DM_PCI_COMPAT=y +CONFIG_PCIE_LAYERSCAPE=y CONFIG_SYS_NS16550=y CONFIG_DM_SPI=y CONFIG_USB=y @@ -38,7 +42,3 @@ CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_STORAGE=y -CONFIG_PCI=y -CONFIG_DM_PCI=y -CONFIG_DM_PCI_COMPAT=y -CONFIG_PCIE_LAYERSCAPE=y diff --git a/configs/ls1012aqds_qspi_defconfig b/configs/ls1012aqds_qspi_defconfig index 79b7bad6ea..11e161bf46 100644 --- a/configs/ls1012aqds_qspi_defconfig +++ b/configs/ls1012aqds_qspi_defconfig @@ -28,22 +28,22 @@ CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y +# CONFIG_BLK is not set +CONFIG_DM_MMC=y +# CONFIG_DM_MMC_OPS is not set CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_NETDEVICES=y CONFIG_E1000=y +CONFIG_PCI=y +CONFIG_DM_PCI=y +CONFIG_DM_PCI_COMPAT=y +CONFIG_PCIE_LAYERSCAPE=y CONFIG_SYS_NS16550=y CONFIG_DM_SPI=y CONFIG_FSL_DSPI=y -CONFIG_DM_MMC=y -CONFIG_DM_MMC_OPS=n -CONFIG_BLK=n CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_STORAGE=y -CONFIG_PCI=y -CONFIG_DM_PCI=y -CONFIG_DM_PCI_COMPAT=y -CONFIG_PCIE_LAYERSCAPE=y diff --git a/configs/ls1012ardb_qspi_defconfig b/configs/ls1012ardb_qspi_defconfig index b25aa6437d..617e061308 100644 --- a/configs/ls1012ardb_qspi_defconfig +++ b/configs/ls1012ardb_qspi_defconfig @@ -28,22 +28,22 @@ CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y +# CONFIG_BLK is not set +CONFIG_DM_MMC=y +# CONFIG_DM_MMC_OPS is not set CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_NETDEVICES=y CONFIG_E1000=y +CONFIG_PCI=y +CONFIG_DM_PCI=y +CONFIG_DM_PCI_COMPAT=y +CONFIG_PCIE_LAYERSCAPE=y CONFIG_SYS_NS16550=y CONFIG_DM_SPI=y CONFIG_FSL_DSPI=y -CONFIG_DM_MMC=y -CONFIG_DM_MMC_OPS=n -CONFIG_BLK=n CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_STORAGE=y -CONFIG_PCI=y -CONFIG_DM_PCI=y -CONFIG_DM_PCI_COMPAT=y -CONFIG_PCIE_LAYERSCAPE=y diff --git a/configs/ls1021aiot_qspi_defconfig b/configs/ls1021aiot_qspi_defconfig index 6b4e9c050f..a526476b36 100644 --- a/configs/ls1021aiot_qspi_defconfig +++ b/configs/ls1021aiot_qspi_defconfig @@ -10,11 +10,11 @@ CONFIG_SPI_FLASH_ATMEL=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_NETDEVICES=y CONFIG_E1000=y -CONFIG_SYS_NS16550=y -CONFIG_DM_SPI=y -CONFIG_FSL_DSPI=y -CONFIG_FSL_QSPI=y CONFIG_PCI=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE=y +CONFIG_SYS_NS16550=y +CONFIG_DM_SPI=y +CONFIG_FSL_DSPI=y +CONFIG_FSL_QSPI=y diff --git a/configs/ls1021aiot_sdcard_defconfig b/configs/ls1021aiot_sdcard_defconfig index aa69547911..5c3c23ca5e 100644 --- a/configs/ls1021aiot_sdcard_defconfig +++ b/configs/ls1021aiot_sdcard_defconfig @@ -13,11 +13,11 @@ CONFIG_SPI_FLASH_ATMEL=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_NETDEVICES=y CONFIG_E1000=y -CONFIG_SYS_NS16550=y -CONFIG_DM_SPI=y -CONFIG_FSL_DSPI=y -CONFIG_FSL_QSPI=y CONFIG_PCI=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE=y +CONFIG_SYS_NS16550=y +CONFIG_DM_SPI=y +CONFIG_FSL_DSPI=y +CONFIG_FSL_QSPI=y diff --git a/configs/ls1021aqds_ddr4_nor_defconfig b/configs/ls1021aqds_ddr4_nor_defconfig index 1b3cd2793a..2963a62b9d 100644 --- a/configs/ls1021aqds_ddr4_nor_defconfig +++ b/configs/ls1021aqds_ddr4_nor_defconfig @@ -29,6 +29,10 @@ CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_NETDEVICES=y CONFIG_E1000=y +CONFIG_PCI=y +CONFIG_DM_PCI=y +CONFIG_DM_PCI_COMPAT=y +CONFIG_PCIE_LAYERSCAPE=y CONFIG_DM_SERIAL=y CONFIG_SYS_NS16550=y CONFIG_USB=y @@ -37,7 +41,3 @@ CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_STORAGE=y # CONFIG_VIDEO_SW_CURSOR is not set -CONFIG_PCI=y -CONFIG_DM_PCI=y -CONFIG_DM_PCI_COMPAT=y -CONFIG_PCIE_LAYERSCAPE=y diff --git a/configs/ls1021aqds_ddr4_nor_lpuart_defconfig b/configs/ls1021aqds_ddr4_nor_lpuart_defconfig index 6fdbc3555f..284bb830e1 100644 --- a/configs/ls1021aqds_ddr4_nor_lpuart_defconfig +++ b/configs/ls1021aqds_ddr4_nor_lpuart_defconfig @@ -30,6 +30,10 @@ CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_NETDEVICES=y CONFIG_E1000=y +CONFIG_PCI=y +CONFIG_DM_PCI=y +CONFIG_DM_PCI_COMPAT=y +CONFIG_PCIE_LAYERSCAPE=y CONFIG_DM_SERIAL=y CONFIG_FSL_LPUART=y CONFIG_USB=y @@ -38,7 +42,3 @@ CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_STORAGE=y # CONFIG_VIDEO_SW_CURSOR is not set -CONFIG_PCI=y -CONFIG_DM_PCI=y -CONFIG_DM_PCI_COMPAT=y -CONFIG_PCIE_LAYERSCAPE=y diff --git a/configs/ls1021aqds_nand_defconfig b/configs/ls1021aqds_nand_defconfig index e7c211f7cc..56dbd31fbc 100644 --- a/configs/ls1021aqds_nand_defconfig +++ b/configs/ls1021aqds_nand_defconfig @@ -1,6 +1,5 @@ CONFIG_ARM=y CONFIG_TARGET_LS1021AQDS=y -CONFIG_DEFAULT_DEVICE_TREE="ls1021a-qds-duart" CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y @@ -10,10 +9,10 @@ CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y CONFIG_VIDEO=y +CONFIG_DEFAULT_DEVICE_TREE="ls1021a-qds-duart" CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y -CONFIG_OF_CONTROL=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SPL_FSL_PBL,NAND_BOOT" CONFIG_NAND_BOOT=y @@ -40,18 +39,18 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y -CONFIG_SYS_FSL_DDR3=y +CONFIG_OF_CONTROL=y CONFIG_DM=y +CONFIG_SYS_FSL_DDR3=y CONFIG_NETDEVICES=y CONFIG_E1000=y +CONFIG_PCI=y +CONFIG_DM_PCI=y +CONFIG_DM_PCI_COMPAT=y +CONFIG_PCIE_LAYERSCAPE=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_STORAGE=y # CONFIG_VIDEO_SW_CURSOR is not set -CONFIG_OF_LIBFDT=y -CONFIG_PCI=y -CONFIG_DM_PCI=y -CONFIG_DM_PCI_COMPAT=y -CONFIG_PCIE_LAYERSCAPE=y diff --git a/configs/ls1021aqds_nor_SECURE_BOOT_defconfig b/configs/ls1021aqds_nor_SECURE_BOOT_defconfig index c1233f5a41..bb251bd996 100644 --- a/configs/ls1021aqds_nor_SECURE_BOOT_defconfig +++ b/configs/ls1021aqds_nor_SECURE_BOOT_defconfig @@ -1,13 +1,12 @@ CONFIG_ARM=y CONFIG_TARGET_LS1021AQDS=y CONFIG_SECURE_BOOT=y -CONFIG_DEFAULT_DEVICE_TREE="ls1021a-qds-duart" CONFIG_VIDEO=y +CONFIG_DEFAULT_DEVICE_TREE="ls1021a-qds-duart" # CONFIG_SYS_MALLOC_F is not set CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y -CONFIG_OF_CONTROL=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_BOOTDELAY=3 CONFIG_SILENT_CONSOLE=y @@ -28,10 +27,15 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_SYS_FSL_DDR3=y CONFIG_NETDEVICES=y CONFIG_E1000=y +CONFIG_PCI=y +CONFIG_DM_PCI=y +CONFIG_DM_PCI_COMPAT=y +CONFIG_PCIE_LAYERSCAPE=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_XHCI_HCD=y @@ -40,8 +44,3 @@ CONFIG_USB_STORAGE=y # CONFIG_VIDEO_SW_CURSOR is not set CONFIG_RSA=y CONFIG_SPL_RSA=y -CONFIG_OF_LIBFDT=y -CONFIG_PCI=y -CONFIG_DM_PCI=y -CONFIG_DM_PCI_COMPAT=y -CONFIG_PCIE_LAYERSCAPE=y diff --git a/configs/ls1021aqds_nor_defconfig b/configs/ls1021aqds_nor_defconfig index 873f8d563c..983bb26046 100644 --- a/configs/ls1021aqds_nor_defconfig +++ b/configs/ls1021aqds_nor_defconfig @@ -30,6 +30,10 @@ CONFIG_DM=y CONFIG_SYS_FSL_DDR3=y CONFIG_NETDEVICES=y CONFIG_E1000=y +CONFIG_PCI=y +CONFIG_DM_PCI=y +CONFIG_DM_PCI_COMPAT=y +CONFIG_PCIE_LAYERSCAPE=y CONFIG_DM_SERIAL=y CONFIG_SYS_NS16550=y CONFIG_USB=y @@ -38,7 +42,3 @@ CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_STORAGE=y # CONFIG_VIDEO_SW_CURSOR is not set -CONFIG_PCI=y -CONFIG_DM_PCI=y -CONFIG_DM_PCI_COMPAT=y -CONFIG_PCIE_LAYERSCAPE=y diff --git a/configs/ls1021aqds_nor_lpuart_defconfig b/configs/ls1021aqds_nor_lpuart_defconfig index 407cf4a8c7..57511f8d78 100644 --- a/configs/ls1021aqds_nor_lpuart_defconfig +++ b/configs/ls1021aqds_nor_lpuart_defconfig @@ -31,6 +31,10 @@ CONFIG_DM=y CONFIG_SYS_FSL_DDR3=y CONFIG_NETDEVICES=y CONFIG_E1000=y +CONFIG_PCI=y +CONFIG_DM_PCI=y +CONFIG_DM_PCI_COMPAT=y +CONFIG_PCIE_LAYERSCAPE=y CONFIG_DM_SERIAL=y CONFIG_FSL_LPUART=y CONFIG_USB=y @@ -39,7 +43,3 @@ CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_STORAGE=y # CONFIG_VIDEO_SW_CURSOR is not set -CONFIG_PCI=y -CONFIG_DM_PCI=y -CONFIG_DM_PCI_COMPAT=y -CONFIG_PCIE_LAYERSCAPE=y diff --git a/configs/ls1021aqds_qspi_defconfig b/configs/ls1021aqds_qspi_defconfig index b42b6eca4c..7a2c208724 100644 --- a/configs/ls1021aqds_qspi_defconfig +++ b/configs/ls1021aqds_qspi_defconfig @@ -36,6 +36,10 @@ CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y CONFIG_E1000=y +CONFIG_PCI=y +CONFIG_DM_PCI=y +CONFIG_DM_PCI_COMPAT=y +CONFIG_PCIE_LAYERSCAPE=y CONFIG_SYS_NS16550=y CONFIG_DM_SPI=y CONFIG_FSL_DSPI=y @@ -45,7 +49,3 @@ CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_STORAGE=y # CONFIG_VIDEO_SW_CURSOR is not set -CONFIG_PCI=y -CONFIG_DM_PCI=y -CONFIG_DM_PCI_COMPAT=y -CONFIG_PCIE_LAYERSCAPE=y diff --git a/configs/ls1021aqds_sdcard_ifc_defconfig b/configs/ls1021aqds_sdcard_ifc_defconfig index 085ed18101..4320b8a0b5 100644 --- a/configs/ls1021aqds_sdcard_ifc_defconfig +++ b/configs/ls1021aqds_sdcard_ifc_defconfig @@ -42,13 +42,13 @@ CONFIG_DM=y CONFIG_SYS_FSL_DDR3=y CONFIG_NETDEVICES=y CONFIG_E1000=y +CONFIG_PCI=y +CONFIG_DM_PCI=y +CONFIG_DM_PCI_COMPAT=y +CONFIG_PCIE_LAYERSCAPE=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_STORAGE=y # CONFIG_VIDEO_SW_CURSOR is not set -CONFIG_PCI=y -CONFIG_DM_PCI=y -CONFIG_DM_PCI_COMPAT=y -CONFIG_PCIE_LAYERSCAPE=y diff --git a/configs/ls1021aqds_sdcard_qspi_defconfig b/configs/ls1021aqds_sdcard_qspi_defconfig index 3fdd4d83e9..996986bccc 100644 --- a/configs/ls1021aqds_sdcard_qspi_defconfig +++ b/configs/ls1021aqds_sdcard_qspi_defconfig @@ -46,6 +46,10 @@ CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y CONFIG_E1000=y +CONFIG_PCI=y +CONFIG_DM_PCI=y +CONFIG_DM_PCI_COMPAT=y +CONFIG_PCIE_LAYERSCAPE=y CONFIG_SYS_NS16550=y CONFIG_DM_SPI=y CONFIG_FSL_DSPI=y @@ -55,7 +59,3 @@ CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_STORAGE=y # CONFIG_VIDEO_SW_CURSOR is not set -CONFIG_PCI=y -CONFIG_DM_PCI=y -CONFIG_DM_PCI_COMPAT=y -CONFIG_PCIE_LAYERSCAPE=y diff --git a/configs/ls1021atwr_nor_SECURE_BOOT_defconfig b/configs/ls1021atwr_nor_SECURE_BOOT_defconfig index 13a5866df3..096e303ce0 100644 --- a/configs/ls1021atwr_nor_SECURE_BOOT_defconfig +++ b/configs/ls1021atwr_nor_SECURE_BOOT_defconfig @@ -1,14 +1,13 @@ CONFIG_ARM=y CONFIG_TARGET_LS1021ATWR=y CONFIG_SECURE_BOOT=y -CONFIG_DEFAULT_DEVICE_TREE="ls1021a-twr-duart" CONFIG_VIDEO=y +CONFIG_DEFAULT_DEVICE_TREE="ls1021a-twr-duart" # CONFIG_SYS_MALLOC_F is not set CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y -CONFIG_OF_CONTROL=y CONFIG_BOOTDELAY=3 CONFIG_SILENT_CONSOLE=y # CONFIG_CONSOLE_MUX is not set @@ -28,9 +27,14 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_NETDEVICES=y CONFIG_E1000=y +CONFIG_PCI=y +CONFIG_DM_PCI=y +CONFIG_DM_PCI_COMPAT=y +CONFIG_PCIE_LAYERSCAPE=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_XHCI_HCD=y @@ -39,8 +43,3 @@ CONFIG_USB_STORAGE=y # CONFIG_VIDEO_SW_CURSOR is not set CONFIG_RSA=y CONFIG_SPL_RSA=y -CONFIG_OF_LIBFDT=y -CONFIG_PCI=y -CONFIG_DM_PCI=y -CONFIG_DM_PCI_COMPAT=y -CONFIG_PCIE_LAYERSCAPE=y diff --git a/configs/ls1021atwr_nor_defconfig b/configs/ls1021atwr_nor_defconfig index e993240e8b..dfdd0fd3cd 100644 --- a/configs/ls1021atwr_nor_defconfig +++ b/configs/ls1021atwr_nor_defconfig @@ -29,6 +29,10 @@ CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_NETDEVICES=y CONFIG_E1000=y +CONFIG_PCI=y +CONFIG_DM_PCI=y +CONFIG_DM_PCI_COMPAT=y +CONFIG_PCIE_LAYERSCAPE=y CONFIG_DM_SERIAL=y CONFIG_SYS_NS16550=y CONFIG_USB=y @@ -36,7 +40,3 @@ CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_STORAGE=y # CONFIG_VIDEO_SW_CURSOR is not set -CONFIG_PCI=y -CONFIG_DM_PCI=y -CONFIG_DM_PCI_COMPAT=y -CONFIG_PCIE_LAYERSCAPE=y diff --git a/configs/ls1021atwr_nor_lpuart_defconfig b/configs/ls1021atwr_nor_lpuart_defconfig index b6601f7d8c..61fa04fa2c 100644 --- a/configs/ls1021atwr_nor_lpuart_defconfig +++ b/configs/ls1021atwr_nor_lpuart_defconfig @@ -30,6 +30,10 @@ CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_NETDEVICES=y CONFIG_E1000=y +CONFIG_PCI=y +CONFIG_DM_PCI=y +CONFIG_DM_PCI_COMPAT=y +CONFIG_PCIE_LAYERSCAPE=y CONFIG_DM_SERIAL=y CONFIG_FSL_LPUART=y CONFIG_USB=y @@ -37,7 +41,3 @@ CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_STORAGE=y # CONFIG_VIDEO_SW_CURSOR is not set -CONFIG_PCI=y -CONFIG_DM_PCI=y -CONFIG_DM_PCI_COMPAT=y -CONFIG_PCIE_LAYERSCAPE=y diff --git a/configs/ls1021atwr_qspi_defconfig b/configs/ls1021atwr_qspi_defconfig index 476a750cec..29770990cc 100644 --- a/configs/ls1021atwr_qspi_defconfig +++ b/configs/ls1021atwr_qspi_defconfig @@ -36,6 +36,10 @@ CONFIG_SPI_FLASH_ATMEL=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_NETDEVICES=y CONFIG_E1000=y +CONFIG_PCI=y +CONFIG_DM_PCI=y +CONFIG_DM_PCI_COMPAT=y +CONFIG_PCIE_LAYERSCAPE=y CONFIG_SYS_NS16550=y CONFIG_DM_SPI=y CONFIG_FSL_DSPI=y @@ -45,7 +49,3 @@ CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_STORAGE=y # CONFIG_VIDEO_SW_CURSOR is not set -CONFIG_PCI=y -CONFIG_DM_PCI=y -CONFIG_DM_PCI_COMPAT=y -CONFIG_PCIE_LAYERSCAPE=y diff --git a/configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig b/configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig index e4411ad0f5..6e60a8f3da 100644 --- a/configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig +++ b/configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig @@ -1,6 +1,5 @@ CONFIG_ARM=y CONFIG_TARGET_LS1021ATWR=y -CONFIG_DEFAULT_DEVICE_TREE="ls1021a-twr-duart" CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SECURE_BOOT=y @@ -11,10 +10,10 @@ CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y CONFIG_VIDEO=y +CONFIG_DEFAULT_DEVICE_TREE="ls1021a-twr-duart" CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y -CONFIG_OF_CONTROL=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SPL_FSL_PBL,SD_BOOT" CONFIG_BOOTDELAY=0 @@ -41,10 +40,15 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_SPL_DM=y CONFIG_NETDEVICES=y CONFIG_E1000=y +CONFIG_PCI=y +CONFIG_DM_PCI=y +CONFIG_DM_PCI_COMPAT=y +CONFIG_PCIE_LAYERSCAPE=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_XHCI_HCD=y @@ -53,8 +57,3 @@ CONFIG_USB_STORAGE=y # CONFIG_VIDEO_SW_CURSOR is not set CONFIG_RSA=y CONFIG_SPL_RSA=y -CONFIG_OF_LIBFDT=y -CONFIG_PCI=y -CONFIG_DM_PCI=y -CONFIG_DM_PCI_COMPAT=y -CONFIG_PCIE_LAYERSCAPE=y diff --git a/configs/ls1021atwr_sdcard_ifc_defconfig b/configs/ls1021atwr_sdcard_ifc_defconfig index 9ea055c786..c319fca080 100644 --- a/configs/ls1021atwr_sdcard_ifc_defconfig +++ b/configs/ls1021atwr_sdcard_ifc_defconfig @@ -1,6 +1,5 @@ CONFIG_ARM=y CONFIG_TARGET_LS1021ATWR=y -CONFIG_DEFAULT_DEVICE_TREE="ls1021a-twr-duart" CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y @@ -9,10 +8,10 @@ CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y CONFIG_VIDEO=y +CONFIG_DEFAULT_DEVICE_TREE="ls1021a-twr-duart" CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y -CONFIG_OF_CONTROL=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SPL_FSL_PBL,SD_BOOT" CONFIG_SD_BOOT=y @@ -38,17 +37,17 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_NETDEVICES=y CONFIG_E1000=y +CONFIG_PCI=y +CONFIG_DM_PCI=y +CONFIG_DM_PCI_COMPAT=y +CONFIG_PCIE_LAYERSCAPE=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_STORAGE=y # CONFIG_VIDEO_SW_CURSOR is not set -CONFIG_OF_LIBFDT=y -CONFIG_PCI=y -CONFIG_DM_PCI=y -CONFIG_DM_PCI_COMPAT=y -CONFIG_PCIE_LAYERSCAPE=y diff --git a/configs/ls1021atwr_sdcard_qspi_defconfig b/configs/ls1021atwr_sdcard_qspi_defconfig index 882727be12..f30cee9960 100644 --- a/configs/ls1021atwr_sdcard_qspi_defconfig +++ b/configs/ls1021atwr_sdcard_qspi_defconfig @@ -46,6 +46,10 @@ CONFIG_SPI_FLASH_ATMEL=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_NETDEVICES=y CONFIG_E1000=y +CONFIG_PCI=y +CONFIG_DM_PCI=y +CONFIG_DM_PCI_COMPAT=y +CONFIG_PCIE_LAYERSCAPE=y CONFIG_SYS_NS16550=y CONFIG_DM_SPI=y CONFIG_FSL_DSPI=y @@ -55,7 +59,3 @@ CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_STORAGE=y # CONFIG_VIDEO_SW_CURSOR is not set -CONFIG_PCI=y -CONFIG_DM_PCI=y -CONFIG_DM_PCI_COMPAT=y -CONFIG_PCIE_LAYERSCAPE=y diff --git a/configs/ls1043aqds_defconfig b/configs/ls1043aqds_defconfig index 88cb15440d..9beba144ac 100644 --- a/configs/ls1043aqds_defconfig +++ b/configs/ls1043aqds_defconfig @@ -25,6 +25,12 @@ CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_SPI_FLASH=y +CONFIG_NETDEVICES=y +CONFIG_E1000=y +CONFIG_PCI=y +CONFIG_DM_PCI=y +CONFIG_DM_PCI_COMPAT=y +CONFIG_PCIE_LAYERSCAPE=y CONFIG_SYS_NS16550=y CONFIG_DM_SPI=y CONFIG_USB=y @@ -32,9 +38,3 @@ CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_STORAGE=y -CONFIG_PCI=y -CONFIG_DM_PCI=y -CONFIG_DM_PCI_COMPAT=y -CONFIG_PCIE_LAYERSCAPE=y -CONFIG_NETDEVICES=y -CONFIG_E1000=y diff --git a/configs/ls1043aqds_lpuart_defconfig b/configs/ls1043aqds_lpuart_defconfig index 9801dc61aa..8c9b2c2a57 100644 --- a/configs/ls1043aqds_lpuart_defconfig +++ b/configs/ls1043aqds_lpuart_defconfig @@ -26,6 +26,12 @@ CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_SPI_FLASH=y +CONFIG_NETDEVICES=y +CONFIG_E1000=y +CONFIG_PCI=y +CONFIG_DM_PCI=y +CONFIG_DM_PCI_COMPAT=y +CONFIG_PCIE_LAYERSCAPE=y CONFIG_DM_SERIAL=y CONFIG_FSL_LPUART=y CONFIG_DM_SPI=y @@ -34,9 +40,3 @@ CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_STORAGE=y -CONFIG_PCI=y -CONFIG_DM_PCI=y -CONFIG_DM_PCI_COMPAT=y -CONFIG_PCIE_LAYERSCAPE=y -CONFIG_NETDEVICES=y -CONFIG_E1000=y diff --git a/configs/ls1043aqds_nand_defconfig b/configs/ls1043aqds_nand_defconfig index 669da50ef3..e71bca1d60 100644 --- a/configs/ls1043aqds_nand_defconfig +++ b/configs/ls1043aqds_nand_defconfig @@ -39,6 +39,12 @@ CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_SPI_FLASH=y +CONFIG_NETDEVICES=y +CONFIG_E1000=y +CONFIG_PCI=y +CONFIG_DM_PCI=y +CONFIG_DM_PCI_COMPAT=y +CONFIG_PCIE_LAYERSCAPE=y CONFIG_SYS_NS16550=y CONFIG_DM_SPI=y CONFIG_USB=y @@ -46,9 +52,3 @@ CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_STORAGE=y -CONFIG_PCI=y -CONFIG_DM_PCI=y -CONFIG_DM_PCI_COMPAT=y -CONFIG_PCIE_LAYERSCAPE=y -CONFIG_NETDEVICES=y -CONFIG_E1000=y diff --git a/configs/ls1043aqds_nor_ddr3_defconfig b/configs/ls1043aqds_nor_ddr3_defconfig index 6fc78cf69a..0ffde6741a 100644 --- a/configs/ls1043aqds_nor_ddr3_defconfig +++ b/configs/ls1043aqds_nor_ddr3_defconfig @@ -26,6 +26,12 @@ CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_SYS_FSL_DDR3=y CONFIG_SPI_FLASH=y +CONFIG_NETDEVICES=y +CONFIG_E1000=y +CONFIG_PCI=y +CONFIG_DM_PCI=y +CONFIG_DM_PCI_COMPAT=y +CONFIG_PCIE_LAYERSCAPE=y CONFIG_SYS_NS16550=y CONFIG_DM_SPI=y CONFIG_USB=y @@ -33,9 +39,3 @@ CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_STORAGE=y -CONFIG_PCI=y -CONFIG_DM_PCI=y -CONFIG_DM_PCI_COMPAT=y -CONFIG_PCIE_LAYERSCAPE=y -CONFIG_NETDEVICES=y -CONFIG_E1000=y diff --git a/configs/ls1043aqds_qspi_defconfig b/configs/ls1043aqds_qspi_defconfig index 5421c22ed3..a3c708da6b 100644 --- a/configs/ls1043aqds_qspi_defconfig +++ b/configs/ls1043aqds_qspi_defconfig @@ -28,6 +28,12 @@ CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_SPI_FLASH=y +CONFIG_NETDEVICES=y +CONFIG_E1000=y +CONFIG_PCI=y +CONFIG_DM_PCI=y +CONFIG_DM_PCI_COMPAT=y +CONFIG_PCIE_LAYERSCAPE=y CONFIG_SYS_NS16550=y CONFIG_DM_SPI=y CONFIG_USB=y @@ -35,9 +41,3 @@ CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_STORAGE=y -CONFIG_PCI=y -CONFIG_DM_PCI=y -CONFIG_DM_PCI_COMPAT=y -CONFIG_PCIE_LAYERSCAPE=y -CONFIG_NETDEVICES=y -CONFIG_E1000=y diff --git a/configs/ls1043aqds_sdcard_ifc_defconfig b/configs/ls1043aqds_sdcard_ifc_defconfig index e93a5f37dd..5c448d8e68 100644 --- a/configs/ls1043aqds_sdcard_ifc_defconfig +++ b/configs/ls1043aqds_sdcard_ifc_defconfig @@ -39,6 +39,12 @@ CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_SPI_FLASH=y +CONFIG_NETDEVICES=y +CONFIG_E1000=y +CONFIG_PCI=y +CONFIG_DM_PCI=y +CONFIG_DM_PCI_COMPAT=y +CONFIG_PCIE_LAYERSCAPE=y CONFIG_SYS_NS16550=y CONFIG_DM_SPI=y CONFIG_USB=y @@ -46,9 +52,3 @@ CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_STORAGE=y -CONFIG_PCI=y -CONFIG_DM_PCI=y -CONFIG_DM_PCI_COMPAT=y -CONFIG_PCIE_LAYERSCAPE=y -CONFIG_NETDEVICES=y -CONFIG_E1000=y diff --git a/configs/ls1043aqds_sdcard_qspi_defconfig b/configs/ls1043aqds_sdcard_qspi_defconfig index 698ae42032..e042cd92cd 100644 --- a/configs/ls1043aqds_sdcard_qspi_defconfig +++ b/configs/ls1043aqds_sdcard_qspi_defconfig @@ -40,6 +40,12 @@ CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_SPI_FLASH=y +CONFIG_NETDEVICES=y +CONFIG_E1000=y +CONFIG_PCI=y +CONFIG_DM_PCI=y +CONFIG_DM_PCI_COMPAT=y +CONFIG_PCIE_LAYERSCAPE=y CONFIG_SYS_NS16550=y CONFIG_DM_SPI=y CONFIG_USB=y @@ -47,9 +53,3 @@ CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_STORAGE=y -CONFIG_PCI=y -CONFIG_DM_PCI=y -CONFIG_DM_PCI_COMPAT=y -CONFIG_PCIE_LAYERSCAPE=y -CONFIG_NETDEVICES=y -CONFIG_E1000=y diff --git a/configs/ls1043ardb_SECURE_BOOT_defconfig b/configs/ls1043ardb_SECURE_BOOT_defconfig index 2f12e641e0..d46ff8cbc5 100644 --- a/configs/ls1043ardb_SECURE_BOOT_defconfig +++ b/configs/ls1043ardb_SECURE_BOOT_defconfig @@ -22,6 +22,12 @@ CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_SPI_FLASH=y +CONFIG_NETDEVICES=y +CONFIG_E1000=y +CONFIG_PCI=y +CONFIG_DM_PCI=y +CONFIG_DM_PCI_COMPAT=y +CONFIG_PCIE_LAYERSCAPE=y CONFIG_SYS_NS16550=y CONFIG_DM_SPI=y CONFIG_USB=y @@ -31,9 +37,3 @@ CONFIG_USB_XHCI_DWC3=y CONFIG_USB_STORAGE=y CONFIG_RSA=y CONFIG_SPL_RSA=y -CONFIG_PCI=y -CONFIG_DM_PCI=y -CONFIG_DM_PCI_COMPAT=y -CONFIG_PCIE_LAYERSCAPE=y -CONFIG_NETDEVICES=y -CONFIG_E1000=y diff --git a/configs/ls1043ardb_defconfig b/configs/ls1043ardb_defconfig index 0be7769eb3..20c9bb1dc9 100644 --- a/configs/ls1043ardb_defconfig +++ b/configs/ls1043ardb_defconfig @@ -1,9 +1,8 @@ CONFIG_ARM=y CONFIG_TARGET_LS1043ARDB=y +CONFIG_FSL_LS_PPA=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1043a-rdb" -CONFIG_FIT=y CONFIG_FIT_VERBOSE=y -CONFIG_FSL_LS_PPA=y CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTDELAY=10 CONFIG_BOARD_LATE_INIT=y @@ -22,6 +21,12 @@ CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_SPI_FLASH=y +CONFIG_NETDEVICES=y +CONFIG_E1000=y +CONFIG_PCI=y +CONFIG_DM_PCI=y +CONFIG_DM_PCI_COMPAT=y +CONFIG_PCIE_LAYERSCAPE=y CONFIG_SYS_NS16550=y CONFIG_DM_SPI=y CONFIG_USB=y @@ -29,9 +34,3 @@ CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_STORAGE=y -CONFIG_PCI=y -CONFIG_DM_PCI=y -CONFIG_DM_PCI_COMPAT=y -CONFIG_PCIE_LAYERSCAPE=y -CONFIG_NETDEVICES=y -CONFIG_E1000=y diff --git a/configs/ls1043ardb_nand_defconfig b/configs/ls1043ardb_nand_defconfig index 769753c52f..1bd852e41c 100644 --- a/configs/ls1043ardb_nand_defconfig +++ b/configs/ls1043ardb_nand_defconfig @@ -35,6 +35,12 @@ CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_SPI_FLASH=y +CONFIG_NETDEVICES=y +CONFIG_E1000=y +CONFIG_PCI=y +CONFIG_DM_PCI=y +CONFIG_DM_PCI_COMPAT=y +CONFIG_PCIE_LAYERSCAPE=y CONFIG_SYS_NS16550=y CONFIG_DM_SPI=y CONFIG_USB=y @@ -42,9 +48,3 @@ CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_STORAGE=y -CONFIG_PCI=y -CONFIG_DM_PCI=y -CONFIG_DM_PCI_COMPAT=y -CONFIG_PCIE_LAYERSCAPE=y -CONFIG_NETDEVICES=y -CONFIG_E1000=y diff --git a/configs/ls1043ardb_sdcard_defconfig b/configs/ls1043ardb_sdcard_defconfig index 52794a27ef..a9f719baa9 100644 --- a/configs/ls1043ardb_sdcard_defconfig +++ b/configs/ls1043ardb_sdcard_defconfig @@ -35,6 +35,12 @@ CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_SPI_FLASH=y +CONFIG_NETDEVICES=y +CONFIG_E1000=y +CONFIG_PCI=y +CONFIG_DM_PCI=y +CONFIG_DM_PCI_COMPAT=y +CONFIG_PCIE_LAYERSCAPE=y CONFIG_SYS_NS16550=y CONFIG_DM_SPI=y CONFIG_USB=y @@ -42,9 +48,3 @@ CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_STORAGE=y -CONFIG_PCI=y -CONFIG_DM_PCI=y -CONFIG_DM_PCI_COMPAT=y -CONFIG_PCIE_LAYERSCAPE=y -CONFIG_NETDEVICES=y -CONFIG_E1000=y diff --git a/configs/ls1046aqds_defconfig b/configs/ls1046aqds_defconfig index b122523242..bbcea73fbb 100644 --- a/configs/ls1046aqds_defconfig +++ b/configs/ls1046aqds_defconfig @@ -23,12 +23,12 @@ CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_SPI_FLASH=y -CONFIG_SYS_NS16550=y -CONFIG_DM_SPI=y -CONFIG_FSL_DSPI=y +CONFIG_NETDEVICES=y +CONFIG_E1000=y CONFIG_PCI=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE=y -CONFIG_NETDEVICES=y -CONFIG_E1000=y +CONFIG_SYS_NS16550=y +CONFIG_DM_SPI=y +CONFIG_FSL_DSPI=y diff --git a/configs/ls1046aqds_nand_defconfig b/configs/ls1046aqds_nand_defconfig index 3e0f89fe5e..ade43e3d18 100644 --- a/configs/ls1046aqds_nand_defconfig +++ b/configs/ls1046aqds_nand_defconfig @@ -28,12 +28,12 @@ CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_SPI_FLASH=y -CONFIG_SYS_NS16550=y -CONFIG_DM_SPI=y -CONFIG_FSL_DSPI=y +CONFIG_NETDEVICES=y +CONFIG_E1000=y CONFIG_PCI=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE=y -CONFIG_NETDEVICES=y -CONFIG_E1000=y +CONFIG_SYS_NS16550=y +CONFIG_DM_SPI=y +CONFIG_FSL_DSPI=y diff --git a/configs/ls1046aqds_qspi_defconfig b/configs/ls1046aqds_qspi_defconfig index 66c8bff0b5..cfd1fef95e 100644 --- a/configs/ls1046aqds_qspi_defconfig +++ b/configs/ls1046aqds_qspi_defconfig @@ -25,13 +25,13 @@ CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_SPI_FLASH=y -CONFIG_SYS_NS16550=y -CONFIG_DM_SPI=y -CONFIG_FSL_DSPI=y -CONFIG_FSL_QSPI=y +CONFIG_NETDEVICES=y +CONFIG_E1000=y CONFIG_PCI=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE=y -CONFIG_NETDEVICES=y -CONFIG_E1000=y +CONFIG_SYS_NS16550=y +CONFIG_DM_SPI=y +CONFIG_FSL_DSPI=y +CONFIG_FSL_QSPI=y diff --git a/configs/ls1046aqds_sdcard_ifc_defconfig b/configs/ls1046aqds_sdcard_ifc_defconfig index 69a66d2357..1ad94d7c90 100644 --- a/configs/ls1046aqds_sdcard_ifc_defconfig +++ b/configs/ls1046aqds_sdcard_ifc_defconfig @@ -28,12 +28,12 @@ CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_SPI_FLASH=y -CONFIG_SYS_NS16550=y -CONFIG_DM_SPI=y -CONFIG_FSL_DSPI=y +CONFIG_NETDEVICES=y +CONFIG_E1000=y CONFIG_PCI=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE=y -CONFIG_NETDEVICES=y -CONFIG_E1000=y +CONFIG_SYS_NS16550=y +CONFIG_DM_SPI=y +CONFIG_FSL_DSPI=y diff --git a/configs/ls1046aqds_sdcard_qspi_defconfig b/configs/ls1046aqds_sdcard_qspi_defconfig index ef79680083..1f0bf1afde 100644 --- a/configs/ls1046aqds_sdcard_qspi_defconfig +++ b/configs/ls1046aqds_sdcard_qspi_defconfig @@ -29,13 +29,13 @@ CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_SPI_FLASH=y -CONFIG_SYS_NS16550=y -CONFIG_DM_SPI=y -CONFIG_FSL_DSPI=y -CONFIG_FSL_QSPI=y +CONFIG_NETDEVICES=y +CONFIG_E1000=y CONFIG_PCI=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE=y -CONFIG_NETDEVICES=y -CONFIG_E1000=y +CONFIG_SYS_NS16550=y +CONFIG_DM_SPI=y +CONFIG_FSL_DSPI=y +CONFIG_FSL_QSPI=y diff --git a/configs/ls1046ardb_emmc_defconfig b/configs/ls1046ardb_emmc_defconfig index d43cd4e6ec..9beeb27575 100644 --- a/configs/ls1046ardb_emmc_defconfig +++ b/configs/ls1046ardb_emmc_defconfig @@ -25,12 +25,12 @@ CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_SPI_FLASH=y -CONFIG_SYS_NS16550=y -CONFIG_DM_SPI=y -CONFIG_FSL_QSPI=y +CONFIG_NETDEVICES=y +CONFIG_E1000=y CONFIG_PCI=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE=y -CONFIG_NETDEVICES=y -CONFIG_E1000=y +CONFIG_SYS_NS16550=y +CONFIG_DM_SPI=y +CONFIG_FSL_QSPI=y diff --git a/configs/ls1046ardb_qspi_defconfig b/configs/ls1046ardb_qspi_defconfig index c0f2b31b08..e96a504f6b 100644 --- a/configs/ls1046ardb_qspi_defconfig +++ b/configs/ls1046ardb_qspi_defconfig @@ -1,10 +1,9 @@ CONFIG_ARM=y CONFIG_TARGET_LS1046ARDB=y +CONFIG_FSL_LS_PPA=y CONFIG_QSPI_AHB_INIT=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1046a-rdb" -CONFIG_FIT=y CONFIG_FIT_VERBOSE=y -CONFIG_FSL_LS_PPA=y CONFIG_OF_BOARD_SETUP=y CONFIG_QSPI_BOOT=y CONFIG_BOOTDELAY=10 @@ -23,12 +22,12 @@ CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_SPI_FLASH=y -CONFIG_SYS_NS16550=y -CONFIG_DM_SPI=y -CONFIG_FSL_QSPI=y +CONFIG_NETDEVICES=y +CONFIG_E1000=y CONFIG_PCI=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE=y -CONFIG_NETDEVICES=y -CONFIG_E1000=y +CONFIG_SYS_NS16550=y +CONFIG_DM_SPI=y +CONFIG_FSL_QSPI=y diff --git a/configs/ls1046ardb_sdcard_defconfig b/configs/ls1046ardb_sdcard_defconfig index 81b80a8a96..4abbc36d00 100644 --- a/configs/ls1046ardb_sdcard_defconfig +++ b/configs/ls1046ardb_sdcard_defconfig @@ -25,12 +25,12 @@ CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_SPI_FLASH=y -CONFIG_SYS_NS16550=y -CONFIG_DM_SPI=y -CONFIG_FSL_QSPI=y +CONFIG_NETDEVICES=y +CONFIG_E1000=y CONFIG_PCI=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE=y -CONFIG_NETDEVICES=y -CONFIG_E1000=y +CONFIG_SYS_NS16550=y +CONFIG_DM_SPI=y +CONFIG_FSL_QSPI=y diff --git a/configs/ls2080a_emu_defconfig b/configs/ls2080a_emu_defconfig index 2d20c28b8d..1ed158f4ba 100644 --- a/configs/ls2080a_emu_defconfig +++ b/configs/ls2080a_emu_defconfig @@ -1,7 +1,6 @@ CONFIG_ARM=y CONFIG_TARGET_LS2080A_EMU=y CONFIG_IDENT_STRING=" LS2080A-EMU" -# CONFIG_MMC is not set CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y @@ -23,6 +22,7 @@ CONFIG_CMD_I2C=y # CONFIG_CMD_NFS is not set CONFIG_CMD_CACHE=y # CONFIG_CMD_MISC is not set +# CONFIG_MMC is not set CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y CONFIG_EFI_LOADER_BOUNCE_BUFFER=y diff --git a/configs/ls2080aqds_SECURE_BOOT_defconfig b/configs/ls2080aqds_SECURE_BOOT_defconfig index 86032fa92b..b21332274a 100644 --- a/configs/ls2080aqds_SECURE_BOOT_defconfig +++ b/configs/ls2080aqds_SECURE_BOOT_defconfig @@ -23,6 +23,10 @@ CONFIG_DM=y CONFIG_DM_SPI_FLASH=y CONFIG_NETDEVICES=y CONFIG_E1000=y +CONFIG_PCI=y +CONFIG_DM_PCI=y +CONFIG_DM_PCI_COMPAT=y +CONFIG_PCIE_LAYERSCAPE=y CONFIG_SYS_NS16550=y CONFIG_DM_SPI=y CONFIG_FSL_DSPI=y @@ -34,7 +38,3 @@ CONFIG_USB_STORAGE=y CONFIG_RSA=y CONFIG_SPL_RSA=y CONFIG_EFI_LOADER_BOUNCE_BUFFER=y -CONFIG_PCI=y -CONFIG_DM_PCI=y -CONFIG_DM_PCI_COMPAT=y -CONFIG_PCIE_LAYERSCAPE=y diff --git a/configs/ls2080aqds_defconfig b/configs/ls2080aqds_defconfig index ec578fff59..020d32ea7e 100644 --- a/configs/ls2080aqds_defconfig +++ b/configs/ls2080aqds_defconfig @@ -22,6 +22,10 @@ CONFIG_DM=y CONFIG_DM_SPI_FLASH=y CONFIG_NETDEVICES=y CONFIG_E1000=y +CONFIG_PCI=y +CONFIG_DM_PCI=y +CONFIG_DM_PCI_COMPAT=y +CONFIG_PCIE_LAYERSCAPE=y CONFIG_SYS_NS16550=y CONFIG_DM_SPI=y CONFIG_FSL_DSPI=y @@ -31,7 +35,3 @@ CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_STORAGE=y CONFIG_EFI_LOADER_BOUNCE_BUFFER=y -CONFIG_PCI=y -CONFIG_DM_PCI=y -CONFIG_DM_PCI_COMPAT=y -CONFIG_PCIE_LAYERSCAPE=y diff --git a/configs/ls2080aqds_nand_defconfig b/configs/ls2080aqds_nand_defconfig index 0c3e1513e2..014f14faa1 100644 --- a/configs/ls2080aqds_nand_defconfig +++ b/configs/ls2080aqds_nand_defconfig @@ -31,6 +31,10 @@ CONFIG_DM=y CONFIG_DM_SPI_FLASH=y CONFIG_NETDEVICES=y CONFIG_E1000=y +CONFIG_PCI=y +CONFIG_DM_PCI=y +CONFIG_DM_PCI_COMPAT=y +CONFIG_PCIE_LAYERSCAPE=y CONFIG_SYS_NS16550=y CONFIG_DM_SPI=y CONFIG_FSL_QSPI=y @@ -40,7 +44,3 @@ CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_STORAGE=y CONFIG_EFI_LOADER_BOUNCE_BUFFER=y -CONFIG_PCI=y -CONFIG_DM_PCI=y -CONFIG_DM_PCI_COMPAT=y -CONFIG_PCIE_LAYERSCAPE=y diff --git a/configs/ls2080aqds_qspi_defconfig b/configs/ls2080aqds_qspi_defconfig index 3dfe3b3e56..6fcd96e056 100644 --- a/configs/ls2080aqds_qspi_defconfig +++ b/configs/ls2080aqds_qspi_defconfig @@ -23,6 +23,10 @@ CONFIG_DM=y CONFIG_DM_SPI_FLASH=y CONFIG_NETDEVICES=y CONFIG_E1000=y +CONFIG_PCI=y +CONFIG_DM_PCI=y +CONFIG_DM_PCI_COMPAT=y +CONFIG_PCIE_LAYERSCAPE=y CONFIG_SYS_NS16550=y CONFIG_DM_SPI=y CONFIG_FSL_QSPI=y @@ -32,7 +36,3 @@ CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_STORAGE=y CONFIG_EFI_LOADER_BOUNCE_BUFFER=y -CONFIG_PCI=y -CONFIG_DM_PCI=y -CONFIG_DM_PCI_COMPAT=y -CONFIG_PCIE_LAYERSCAPE=y diff --git a/configs/ls2080ardb_SECURE_BOOT_defconfig b/configs/ls2080ardb_SECURE_BOOT_defconfig index 4b840cf8b7..6db1078c52 100644 --- a/configs/ls2080ardb_SECURE_BOOT_defconfig +++ b/configs/ls2080ardb_SECURE_BOOT_defconfig @@ -23,6 +23,10 @@ CONFIG_DM=y CONFIG_DM_SPI_FLASH=y CONFIG_NETDEVICES=y CONFIG_E1000=y +CONFIG_PCI=y +CONFIG_DM_PCI=y +CONFIG_DM_PCI_COMPAT=y +CONFIG_PCIE_LAYERSCAPE=y CONFIG_SYS_NS16550=y CONFIG_DM_SPI=y CONFIG_FSL_DSPI=y @@ -34,7 +38,3 @@ CONFIG_USB_STORAGE=y CONFIG_RSA=y CONFIG_SPL_RSA=y CONFIG_EFI_LOADER_BOUNCE_BUFFER=y -CONFIG_PCI=y -CONFIG_DM_PCI=y -CONFIG_DM_PCI_COMPAT=y -CONFIG_PCIE_LAYERSCAPE=y diff --git a/configs/ls2080ardb_defconfig b/configs/ls2080ardb_defconfig index 2410011dff..9bb4a5b179 100644 --- a/configs/ls2080ardb_defconfig +++ b/configs/ls2080ardb_defconfig @@ -22,6 +22,10 @@ CONFIG_DM=y CONFIG_DM_SPI_FLASH=y CONFIG_NETDEVICES=y CONFIG_E1000=y +CONFIG_PCI=y +CONFIG_DM_PCI=y +CONFIG_DM_PCI_COMPAT=y +CONFIG_PCIE_LAYERSCAPE=y CONFIG_SYS_NS16550=y CONFIG_DM_SPI=y CONFIG_FSL_DSPI=y @@ -31,7 +35,3 @@ CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_STORAGE=y CONFIG_EFI_LOADER_BOUNCE_BUFFER=y -CONFIG_PCI=y -CONFIG_DM_PCI=y -CONFIG_DM_PCI_COMPAT=y -CONFIG_PCIE_LAYERSCAPE=y diff --git a/configs/ls2080ardb_nand_defconfig b/configs/ls2080ardb_nand_defconfig index ee734703c5..74dc636e0e 100644 --- a/configs/ls2080ardb_nand_defconfig +++ b/configs/ls2080ardb_nand_defconfig @@ -28,6 +28,10 @@ CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y CONFIG_NETDEVICES=y CONFIG_E1000=y +CONFIG_PCI=y +CONFIG_DM_PCI=y +CONFIG_DM_PCI_COMPAT=y +CONFIG_PCIE_LAYERSCAPE=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_DM_USB=y @@ -35,7 +39,3 @@ CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_STORAGE=y CONFIG_EFI_LOADER_BOUNCE_BUFFER=y -CONFIG_PCI=y -CONFIG_DM_PCI=y -CONFIG_DM_PCI_COMPAT=y -CONFIG_PCIE_LAYERSCAPE=y diff --git a/configs/lschlv2_defconfig b/configs/lschlv2_defconfig index b6d95e949d..65567d7ce2 100644 --- a/configs/lschlv2_defconfig +++ b/configs/lschlv2_defconfig @@ -2,7 +2,6 @@ CONFIG_ARM=y CONFIG_KIRKWOOD=y CONFIG_TARGET_LSXL=y CONFIG_IDENT_STRING=" LS-CHLv2" -# CONFIG_MMC is not set CONFIG_SYS_EXTRA_OPTIONS="LSCHLV2" CONFIG_BOOTDELAY=3 CONFIG_SYS_CONSOLE_IS_IN_ENV=y @@ -23,6 +22,7 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_NET_RANDOM_ETHADDR=y +# CONFIG_MMC is not set CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_SYS_NS16550=y diff --git a/configs/lsxhl_defconfig b/configs/lsxhl_defconfig index 1da81b9232..99c6db23ef 100644 --- a/configs/lsxhl_defconfig +++ b/configs/lsxhl_defconfig @@ -2,7 +2,6 @@ CONFIG_ARM=y CONFIG_KIRKWOOD=y CONFIG_TARGET_LSXL=y CONFIG_IDENT_STRING=" LS-XHL" -# CONFIG_MMC is not set CONFIG_DISTRO_DEFAULTS=y CONFIG_SYS_EXTRA_OPTIONS="LSXHL" CONFIG_BOOTDELAY=3 @@ -16,6 +15,7 @@ CONFIG_CMD_SPI=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_NET_RANDOM_ETHADDR=y +# CONFIG_MMC is not set CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_SYS_NS16550=y diff --git a/configs/luan_defconfig b/configs/luan_defconfig index 8e01f68b5f..5abcf3ad98 100644 --- a/configs/luan_defconfig +++ b/configs/luan_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_4xx=y CONFIG_TARGET_LUAN=y CONFIG_OF_BOARD_SETUP=y @@ -15,5 +14,6 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y +# CONFIG_MMC is not set CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/lwmon5_defconfig b/configs/lwmon5_defconfig index dab49e784a..735e25fa20 100644 --- a/configs/lwmon5_defconfig +++ b/configs/lwmon5_defconfig @@ -1,6 +1,5 @@ CONFIG_PPC=y CONFIG_IDENT_STRING=" - v2.0" -# CONFIG_MMC is not set CONFIG_VIDEO=y CONFIG_4xx=y CONFIG_TARGET_LWMON5=y @@ -21,6 +20,7 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y +# CONFIG_MMC is not set # CONFIG_PCI is not set CONFIG_SYS_NS16550=y CONFIG_USB=y diff --git a/configs/makalu_defconfig b/configs/makalu_defconfig index a04a93471a..966c3077de 100644 --- a/configs/makalu_defconfig +++ b/configs/makalu_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_4xx=y CONFIG_TARGET_MAKALU=y CONFIG_OF_BOARD_SETUP=y @@ -16,5 +15,6 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_SNTP=y +# CONFIG_MMC is not set CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/maxbcm_defconfig b/configs/maxbcm_defconfig index 39992e8f36..23add78e52 100644 --- a/configs/maxbcm_defconfig +++ b/configs/maxbcm_defconfig @@ -8,7 +8,6 @@ CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y -# CONFIG_MMC is not set CONFIG_DEFAULT_DEVICE_TREE="armada-xp-maxbcm" CONFIG_BOOTDELAY=3 CONFIG_SYS_CONSOLE_INFO_QUIET=y @@ -26,6 +25,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_TIME=y CONFIG_SPL_OF_TRANSLATE=y +# CONFIG_MMC is not set CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_BAR=y CONFIG_SPI_FLASH_MACRONIX=y diff --git a/configs/mecp5123_defconfig b/configs/mecp5123_defconfig index 3612416e7a..ca56b64f5b 100644 --- a/configs/mecp5123_defconfig +++ b/configs/mecp5123_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_MPC512X=y CONFIG_TARGET_MECP5123=y CONFIG_OF_BOARD_SETUP=y @@ -12,5 +11,6 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y +# CONFIG_MMC is not set # CONFIG_PCI is not set CONFIG_OF_LIBFDT=y diff --git a/configs/meesc_dataflash_defconfig b/configs/meesc_dataflash_defconfig index 5c25eeb698..8f2c834f3a 100644 --- a/configs/meesc_dataflash_defconfig +++ b/configs/meesc_dataflash_defconfig @@ -1,7 +1,6 @@ CONFIG_ARM=y CONFIG_ARCH_AT91=y CONFIG_TARGET_MEESC=y -# CONFIG_MMC is not set CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9263,SYS_USE_DATAFLASH" CONFIG_BOOTDELAY=3 @@ -14,4 +13,5 @@ CONFIG_CMD_BOOTZ=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y +# CONFIG_MMC is not set CONFIG_OF_LIBFDT=y diff --git a/configs/meesc_defconfig b/configs/meesc_defconfig index 8b42500bed..0b162e8809 100644 --- a/configs/meesc_defconfig +++ b/configs/meesc_defconfig @@ -1,7 +1,6 @@ CONFIG_ARM=y CONFIG_ARCH_AT91=y CONFIG_TARGET_MEESC=y -# CONFIG_MMC is not set CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9263,SYS_USE_NANDFLASH" CONFIG_BOOTDELAY=3 @@ -14,4 +13,5 @@ CONFIG_CMD_BOOTZ=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y +# CONFIG_MMC is not set CONFIG_OF_LIBFDT=y diff --git a/configs/mgcoge3ne_defconfig b/configs/mgcoge3ne_defconfig index 779a9c5a17..1625f6c056 100644 --- a/configs/mgcoge3ne_defconfig +++ b/configs/mgcoge3ne_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_MPC8260=y CONFIG_TARGET_KM82XX=y CONFIG_FIT=y @@ -17,5 +16,6 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_UBI=y +# CONFIG_MMC is not set # CONFIG_PCI is not set CONFIG_OF_LIBFDT=y diff --git a/configs/mgcoge_defconfig b/configs/mgcoge_defconfig index 8004d7832f..fcd8598f62 100644 --- a/configs/mgcoge_defconfig +++ b/configs/mgcoge_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_MPC8260=y CONFIG_TARGET_KM82XX=y CONFIG_FIT=y @@ -17,5 +16,6 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_UBI=y +# CONFIG_MMC is not set # CONFIG_PCI is not set CONFIG_OF_LIBFDT=y diff --git a/configs/minnowmax_defconfig b/configs/minnowmax_defconfig index f7ac94d389..b69e0fdae5 100644 --- a/configs/minnowmax_defconfig +++ b/configs/minnowmax_defconfig @@ -1,5 +1,4 @@ CONFIG_X86=y -CONFIG_MMC=y CONFIG_VENDOR_INTEL=y CONFIG_DEFAULT_DEVICE_TREE="minnowmax" CONFIG_TARGET_MINNOWMAX=y @@ -41,6 +40,7 @@ CONFIG_OF_CONTROL=y CONFIG_REGMAP=y CONFIG_SYSCON=y CONFIG_CPU=y +CONFIG_MMC=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_SDMA=y CONFIG_SPI_FLASH=y diff --git a/configs/motionpro_defconfig b/configs/motionpro_defconfig index 371ee2e26e..26962f8229 100644 --- a/configs/motionpro_defconfig +++ b/configs/motionpro_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_MPC5xxx=y CONFIG_TARGET_MOTIONPRO=y CONFIG_OF_BOARD_SETUP=y @@ -25,5 +24,6 @@ CONFIG_LED_STATUS_BIT1=1 CONFIG_LED_STATUS_FREQ1=10 CONFIG_LED_STATUS_BOOT_ENABLE=y CONFIG_LED_STATUS_BOOT=0 +# CONFIG_MMC is not set # CONFIG_PCI is not set CONFIG_OF_LIBFDT=y diff --git a/configs/mpc5121ads_defconfig b/configs/mpc5121ads_defconfig index fff0e9b379..f09f2e9d5e 100644 --- a/configs/mpc5121ads_defconfig +++ b/configs/mpc5121ads_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_MPC512X=y CONFIG_TARGET_MPC5121ADS=y CONFIG_OF_BOARD_SETUP=y @@ -14,6 +13,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +# CONFIG_MMC is not set CONFIG_USB=y CONFIG_USB_STORAGE=y CONFIG_OF_LIBFDT=y diff --git a/configs/mpc5121ads_rev2_defconfig b/configs/mpc5121ads_rev2_defconfig index 4007351b45..4e1c9840b3 100644 --- a/configs/mpc5121ads_rev2_defconfig +++ b/configs/mpc5121ads_rev2_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_MPC512X=y CONFIG_TARGET_MPC5121ADS=y CONFIG_OF_BOARD_SETUP=y @@ -15,6 +14,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +# CONFIG_MMC is not set # CONFIG_PCI is not set CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/mpc8308_p1m_defconfig b/configs/mpc8308_p1m_defconfig index a45c9b770b..7264f6c873 100644 --- a/configs/mpc8308_p1m_defconfig +++ b/configs/mpc8308_p1m_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_MPC83xx=y CONFIG_TARGET_MPC8308_P1M=y CONFIG_OF_BOARD_SETUP=y @@ -11,5 +10,6 @@ CONFIG_CMD_I2C=y CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y +# CONFIG_MMC is not set CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/munices_defconfig b/configs/munices_defconfig index b47c2b3a98..07e74cabd0 100644 --- a/configs/munices_defconfig +++ b/configs/munices_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_MPC5xxx=y CONFIG_TARGET_MUNICES=y CONFIG_OF_BOARD_SETUP=y @@ -7,5 +6,6 @@ CONFIG_BOOTDELAY=5 CONFIG_CMD_ASKENV=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_PING=y +# CONFIG_MMC is not set # CONFIG_PCI is not set CONFIG_OF_LIBFDT=y diff --git a/configs/mvebu_db-88f3720_defconfig b/configs/mvebu_db-88f3720_defconfig index 0605174026..a0665c5c09 100644 --- a/configs/mvebu_db-88f3720_defconfig +++ b/configs/mvebu_db-88f3720_defconfig @@ -2,7 +2,6 @@ CONFIG_ARM=y CONFIG_ARCH_MVEBU=y CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_TARGET_MVEBU_DB_88F3720=y -# CONFIG_MMC is not set CONFIG_DEFAULT_DEVICE_TREE="armada-3720-db" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set @@ -31,6 +30,7 @@ CONFIG_BLOCK_CACHE=y CONFIG_DM_I2C=y CONFIG_DM_I2C_COMPAT=y CONFIG_MISC=y +# CONFIG_MMC is not set CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/mx31ads_defconfig b/configs/mx31ads_defconfig index 2a098ee9ff..5badb13473 100644 --- a/configs/mx31ads_defconfig +++ b/configs/mx31ads_defconfig @@ -1,8 +1,8 @@ CONFIG_ARM=y CONFIG_TARGET_MX31ADS=y -# CONFIG_MMC is not set CONFIG_BOOTDELAY=3 CONFIG_CMD_SPI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y +# CONFIG_MMC is not set diff --git a/configs/nas220_defconfig b/configs/nas220_defconfig index 9d42a0384f..b4cdaf84f1 100644 --- a/configs/nas220_defconfig +++ b/configs/nas220_defconfig @@ -2,7 +2,6 @@ CONFIG_ARM=y CONFIG_KIRKWOOD=y CONFIG_TARGET_NAS220=y CONFIG_IDENT_STRING="\nNAS 220" -# CONFIG_MMC is not set CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_HUSH_PARSER=y @@ -18,6 +17,7 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_EXT4=y CONFIG_CMD_FAT=y CONFIG_CMD_UBI=y +# CONFIG_MMC is not set CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/neo_defconfig b/configs/neo_defconfig index 2dd2f6e364..955f29270f 100644 --- a/configs/neo_defconfig +++ b/configs/neo_defconfig @@ -1,6 +1,5 @@ CONFIG_PPC=y CONFIG_IDENT_STRING=" neo 0.02" -# CONFIG_MMC is not set CONFIG_4xx=y CONFIG_TARGET_NEO=y CONFIG_FIT=y @@ -18,6 +17,7 @@ CONFIG_LOOPW=y # CONFIG_CMD_NFS is not set CONFIG_CMD_MII=y CONFIG_CMD_PING=y +# CONFIG_MMC is not set # CONFIG_PCI is not set CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/net2big_v2_defconfig b/configs/net2big_v2_defconfig index 0fb0cde444..4ff9dc8397 100644 --- a/configs/net2big_v2_defconfig +++ b/configs/net2big_v2_defconfig @@ -2,7 +2,6 @@ CONFIG_ARM=y CONFIG_KIRKWOOD=y CONFIG_TARGET_NET2BIG_V2=y CONFIG_IDENT_STRING=" 2Big v2" -# CONFIG_MMC is not set CONFIG_SYS_EXTRA_OPTIONS="NET2BIG_V2" CONFIG_BOOTDELAY=3 CONFIG_CONSOLE_MUX=y @@ -20,6 +19,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +# CONFIG_MMC is not set CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SYS_NS16550=y diff --git a/configs/netspace_lite_v2_defconfig b/configs/netspace_lite_v2_defconfig index 72f761aa60..f966871cb9 100644 --- a/configs/netspace_lite_v2_defconfig +++ b/configs/netspace_lite_v2_defconfig @@ -2,7 +2,6 @@ CONFIG_ARM=y CONFIG_KIRKWOOD=y CONFIG_TARGET_NETSPACE_V2=y CONFIG_IDENT_STRING=" NS v2 Lite" -# CONFIG_MMC is not set CONFIG_SYS_EXTRA_OPTIONS="NETSPACE_LITE_V2" CONFIG_BOOTDELAY=3 CONFIG_CONSOLE_MUX=y @@ -20,6 +19,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +# CONFIG_MMC is not set CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SYS_NS16550=y diff --git a/configs/netspace_max_v2_defconfig b/configs/netspace_max_v2_defconfig index 3eb1188913..fd1263a40a 100644 --- a/configs/netspace_max_v2_defconfig +++ b/configs/netspace_max_v2_defconfig @@ -2,7 +2,6 @@ CONFIG_ARM=y CONFIG_KIRKWOOD=y CONFIG_TARGET_NETSPACE_V2=y CONFIG_IDENT_STRING=" NS Max v2" -# CONFIG_MMC is not set CONFIG_SYS_EXTRA_OPTIONS="NETSPACE_MAX_V2" CONFIG_BOOTDELAY=3 CONFIG_CONSOLE_MUX=y @@ -20,6 +19,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +# CONFIG_MMC is not set CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SYS_NS16550=y diff --git a/configs/netspace_mini_v2_defconfig b/configs/netspace_mini_v2_defconfig index 16f544c5db..798da9dadf 100644 --- a/configs/netspace_mini_v2_defconfig +++ b/configs/netspace_mini_v2_defconfig @@ -2,7 +2,6 @@ CONFIG_ARM=y CONFIG_KIRKWOOD=y CONFIG_TARGET_NETSPACE_V2=y CONFIG_IDENT_STRING=" NS v2 Mini" -# CONFIG_MMC is not set CONFIG_SYS_EXTRA_OPTIONS="NETSPACE_MINI_V2" CONFIG_BOOTDELAY=3 CONFIG_CONSOLE_MUX=y @@ -19,6 +18,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +# CONFIG_MMC is not set CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SYS_NS16550=y diff --git a/configs/netspace_v2_defconfig b/configs/netspace_v2_defconfig index 5b5954b785..e5ca25137d 100644 --- a/configs/netspace_v2_defconfig +++ b/configs/netspace_v2_defconfig @@ -2,7 +2,6 @@ CONFIG_ARM=y CONFIG_KIRKWOOD=y CONFIG_TARGET_NETSPACE_V2=y CONFIG_IDENT_STRING=" NS v2" -# CONFIG_MMC is not set CONFIG_SYS_EXTRA_OPTIONS="NETSPACE_V2" CONFIG_BOOTDELAY=3 CONFIG_CONSOLE_MUX=y @@ -20,6 +19,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +# CONFIG_MMC is not set CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SYS_NS16550=y diff --git a/configs/nsa310s_defconfig b/configs/nsa310s_defconfig index 72333543e1..194c12c8f4 100644 --- a/configs/nsa310s_defconfig +++ b/configs/nsa310s_defconfig @@ -1,7 +1,6 @@ CONFIG_ARM=y CONFIG_KIRKWOOD=y CONFIG_TARGET_NSA310S=y -# CONFIG_MMC is not set CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_HUSH_PARSER=y @@ -18,6 +17,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_CMD_UBI=y +# CONFIG_MMC is not set CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/odroid-c2_defconfig b/configs/odroid-c2_defconfig index 119ab07038..2cf5011f46 100644 --- a/configs/odroid-c2_defconfig +++ b/configs/odroid-c2_defconfig @@ -3,11 +3,9 @@ CONFIG_ARCH_MESON=y CONFIG_MESON_GXBB=y CONFIG_TARGET_ODROID_C2=y CONFIG_IDENT_STRING=" odroid-c2" -# CONFIG_MMC is not set CONFIG_DEFAULT_DEVICE_TREE="meson-gxbb-odroidc2" # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_DISPLAY_BOARDINFO is not set -CONFIG_HUSH_PARSER=y # CONFIG_CMD_BDI is not set # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set @@ -16,6 +14,7 @@ CONFIG_HUSH_PARSER=y # CONFIG_CMD_SETEXPR is not set CONFIG_OF_CONTROL=y CONFIG_NET_RANDOM_ETHADDR=y +# CONFIG_MMC is not set CONFIG_DM_ETH=y CONFIG_ETH_DESIGNWARE=y CONFIG_PINCTRL=y diff --git a/configs/orangepi_zero_defconfig b/configs/orangepi_zero_defconfig index abb3fcf307..ac44937b16 100644 --- a/configs/orangepi_zero_defconfig +++ b/configs/orangepi_zero_defconfig @@ -1,5 +1,6 @@ CONFIG_ARM=y CONFIG_ARCH_SUNXI=y +CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_MACH_SUN8I_H3=y CONFIG_DRAM_CLK=672 CONFIG_DRAM_ZQ=3881979 @@ -11,7 +12,6 @@ CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +CONFIG_SPL_SPI_SUNXI=y CONFIG_SUN8I_EMAC=y CONFIG_USB_EHCI_HCD=y -CONFIG_SPL_SPI_SUNXI=y -CONFIG_SPL_SPI_FLASH_SUPPORT=y diff --git a/configs/pcm030_LOWBOOT_defconfig b/configs/pcm030_LOWBOOT_defconfig index 3e39dc0ef4..986883d717 100644 --- a/configs/pcm030_LOWBOOT_defconfig +++ b/configs/pcm030_LOWBOOT_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_MPC5xxx=y CONFIG_TARGET_PCM030=y CONFIG_OF_BOARD_SETUP=y @@ -9,6 +8,7 @@ CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y +# CONFIG_MMC is not set CONFIG_USB=y CONFIG_USB_STORAGE=y CONFIG_OF_LIBFDT=y diff --git a/configs/pcm030_defconfig b/configs/pcm030_defconfig index fdb0d1b715..fc8cb48b13 100644 --- a/configs/pcm030_defconfig +++ b/configs/pcm030_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_MPC5xxx=y CONFIG_TARGET_PCM030=y CONFIG_OF_BOARD_SETUP=y @@ -9,6 +8,7 @@ CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y +# CONFIG_MMC is not set CONFIG_USB=y CONFIG_USB_STORAGE=y CONFIG_OF_LIBFDT=y diff --git a/configs/pdm360ng_defconfig b/configs/pdm360ng_defconfig index 52b5d6fc64..08856d8e8c 100644 --- a/configs/pdm360ng_defconfig +++ b/configs/pdm360ng_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_VIDEO=y CONFIG_MPC512X=y CONFIG_TARGET_PDM360NG=y @@ -16,6 +15,7 @@ CONFIG_CMD_I2C=y CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y +# CONFIG_MMC is not set # CONFIG_PCI is not set # CONFIG_VIDEO_SW_CURSOR is not set CONFIG_OF_LIBFDT=y diff --git a/configs/peach-pi_defconfig b/configs/peach-pi_defconfig index 440cbcca0c..0b53af833e 100644 --- a/configs/peach-pi_defconfig +++ b/configs/peach-pi_defconfig @@ -57,10 +57,10 @@ CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_STORAGE=y CONFIG_DM_VIDEO=y +CONFIG_VIDCONSOLE_AS_LCD=y CONFIG_DISPLAY=y CONFIG_VIDEO_BRIDGE=y CONFIG_VIDEO_BRIDGE_PARADE_PS862X=y CONFIG_LCD=y -CONFIG_VIDCONSOLE_AS_LCD=y CONFIG_TPM=y CONFIG_ERRNO_STR=y diff --git a/configs/peach-pit_defconfig b/configs/peach-pit_defconfig index d12e1a9d5e..1e93856f71 100644 --- a/configs/peach-pit_defconfig +++ b/configs/peach-pit_defconfig @@ -57,10 +57,10 @@ CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_STORAGE=y CONFIG_DM_VIDEO=y +CONFIG_VIDCONSOLE_AS_LCD=y CONFIG_DISPLAY=y CONFIG_VIDEO_BRIDGE=y CONFIG_VIDEO_BRIDGE_PARADE_PS862X=y CONFIG_LCD=y -CONFIG_VIDCONSOLE_AS_LCD=y CONFIG_TPM=y CONFIG_ERRNO_STR=y diff --git a/configs/pic32mzdask_defconfig b/configs/pic32mzdask_defconfig index 852eb0a8e7..51c6c809df 100644 --- a/configs/pic32mzdask_defconfig +++ b/configs/pic32mzdask_defconfig @@ -1,6 +1,5 @@ CONFIG_MIPS=y CONFIG_SYS_MALLOC_F_LEN=0x600 -CONFIG_MMC=y CONFIG_MACH_PIC32=y # CONFIG_MIPS_BOOT_ENV_LEGACY is not set CONFIG_MIPS_BOOT_FDT=y @@ -26,6 +25,7 @@ CONFIG_NET_RANDOM_ETHADDR=y # CONFIG_BLK is not set CONFIG_CLK=y CONFIG_DM_GPIO=y +CONFIG_MMC=y CONFIG_DM_MMC=y CONFIG_PIC32_SDHCI=y CONFIG_MMC_SDHCI=y diff --git a/configs/pine64_plus_defconfig b/configs/pine64_plus_defconfig index 2374170ed1..e4bd6f47c8 100644 --- a/configs/pine64_plus_defconfig +++ b/configs/pine64_plus_defconfig @@ -1,7 +1,7 @@ CONFIG_ARM=y -CONFIG_RESERVE_ALLWINNER_BOOT0_HEADER=y CONFIG_ARCH_SUNXI=y CONFIG_MACH_SUN50I=y +CONFIG_RESERVE_ALLWINNER_BOOT0_HEADER=y CONFIG_DEFAULT_DEVICE_TREE="sun50i-a64-pine64-plus" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_CONSOLE_MUX=y diff --git a/configs/pm9261_defconfig b/configs/pm9261_defconfig index 6bc5f6fdfc..0defe059e7 100644 --- a/configs/pm9261_defconfig +++ b/configs/pm9261_defconfig @@ -1,7 +1,6 @@ CONFIG_ARM=y CONFIG_ARCH_AT91=y CONFIG_TARGET_PM9261=y -# CONFIG_MMC is not set CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9261" CONFIG_BOOTDELAY=3 # CONFIG_CONSOLE_MUX is not set @@ -18,6 +17,7 @@ CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y +# CONFIG_MMC is not set CONFIG_USB=y CONFIG_USB_STORAGE=y CONFIG_LCD=y diff --git a/configs/pm9263_defconfig b/configs/pm9263_defconfig index 1a3de43a00..76ef7ac3b1 100644 --- a/configs/pm9263_defconfig +++ b/configs/pm9263_defconfig @@ -1,7 +1,6 @@ CONFIG_ARM=y CONFIG_ARCH_AT91=y CONFIG_TARGET_PM9263=y -# CONFIG_MMC is not set CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9263" CONFIG_BOOTDELAY=3 # CONFIG_CONSOLE_MUX is not set @@ -17,6 +16,7 @@ CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y +# CONFIG_MMC is not set CONFIG_USB=y CONFIG_USB_STORAGE=y CONFIG_LCD=y diff --git a/configs/pm9g45_defconfig b/configs/pm9g45_defconfig index 8561097674..6cf628808e 100644 --- a/configs/pm9g45_defconfig +++ b/configs/pm9g45_defconfig @@ -1,7 +1,6 @@ CONFIG_ARM=y CONFIG_ARCH_AT91=y CONFIG_TARGET_PM9G45=y -# CONFIG_MMC is not set CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9G45" CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_CPUINFO is not set @@ -16,5 +15,6 @@ CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y +# CONFIG_MMC is not set CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/pogo_e02_defconfig b/configs/pogo_e02_defconfig index b98093ec8c..5c816428e2 100644 --- a/configs/pogo_e02_defconfig +++ b/configs/pogo_e02_defconfig @@ -2,7 +2,6 @@ CONFIG_ARM=y CONFIG_KIRKWOOD=y CONFIG_TARGET_POGO_E02=y CONFIG_IDENT_STRING="\nPogo E02" -# CONFIG_MMC is not set CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_SYS_PROMPT="PogoE02> " @@ -16,6 +15,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_CMD_UBI=y +# CONFIG_MMC is not set CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/qemu-ppce500_defconfig b/configs/qemu-ppce500_defconfig index 64135670ff..4cc4e03f12 100644 --- a/configs/qemu-ppce500_defconfig +++ b/configs/qemu-ppce500_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_MPC85xx=y CONFIG_TARGET_QEMU_PPCE500=y CONFIG_FIT=y @@ -16,6 +15,7 @@ CONFIG_CMD_GREPENV=y CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y +# CONFIG_MMC is not set CONFIG_NETDEVICES=y CONFIG_E1000=y CONFIG_SYS_NS16550=y diff --git a/configs/rainier_defconfig b/configs/rainier_defconfig index c76b7b9937..ebb1b1a8b8 100644 --- a/configs/rainier_defconfig +++ b/configs/rainier_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_4xx=y CONFIG_TARGET_SEQUOIA=y CONFIG_OF_BOARD_SETUP=y @@ -18,5 +17,6 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_CMD_FAT=y +# CONFIG_MMC is not set CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/rainier_ramboot_defconfig b/configs/rainier_ramboot_defconfig index 7bb948dc06..f3fcd2c773 100644 --- a/configs/rainier_ramboot_defconfig +++ b/configs/rainier_ramboot_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_4xx=y CONFIG_TARGET_SEQUOIA=y CONFIG_OF_BOARD_SETUP=y @@ -18,5 +17,6 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_CMD_FAT=y +# CONFIG_MMC is not set CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/redwood_defconfig b/configs/redwood_defconfig index 9fdfd7d71a..5c9085c12a 100644 --- a/configs/redwood_defconfig +++ b/configs/redwood_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_4xx=y CONFIG_TARGET_REDWOOD=y CONFIG_OF_BOARD_SETUP=y @@ -15,6 +14,7 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y +# CONFIG_MMC is not set # CONFIG_PCI is not set CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/s5p_goni_defconfig b/configs/s5p_goni_defconfig index f716c385a1..cb04a3f1f5 100644 --- a/configs/s5p_goni_defconfig +++ b/configs/s5p_goni_defconfig @@ -23,10 +23,10 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_DFU_MMC=y CONFIG_DM_I2C_GPIO=y -CONFIG_DM_PMIC=y -CONFIG_DM_PMIC_MAX8998=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_S5P=y +CONFIG_DM_PMIC=y +CONFIG_DM_PMIC_MAX8998=y CONFIG_USB=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_DWC2_OTG=y diff --git a/configs/s5pc210_universal_defconfig b/configs/s5pc210_universal_defconfig index d9dfcba83d..4223c4a802 100644 --- a/configs/s5pc210_universal_defconfig +++ b/configs/s5pc210_universal_defconfig @@ -29,13 +29,13 @@ CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_OF_CONTROL=y CONFIG_DFU_MMC=y +CONFIG_SYS_I2C_S3C24X0=y CONFIG_MMC_DW=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_SDMA=y CONFIG_MMC_SDHCI_S5P=y CONFIG_DM_PMIC=y CONFIG_DM_PMIC_MAX8998=y -CONFIG_SYS_I2C_S3C24X0=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_GADGET=y diff --git a/configs/salvator-x_defconfig b/configs/salvator-x_defconfig index bf8f7c7a53..90287c4fdf 100644 --- a/configs/salvator-x_defconfig +++ b/configs/salvator-x_defconfig @@ -3,7 +3,6 @@ CONFIG_ARCH_RMOBILE=y CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_RCAR_GEN3=y CONFIG_TARGET_SALVATOR_X=y -# CONFIG_MMC is not set CONFIG_BOOTSTAGE_USER_COUNT=0x20 CONFIG_BOOTSTAGE_STASH_ADDR=0x0 CONFIG_BOOTSTAGE_STASH_SIZE=0x4096 @@ -12,3 +11,4 @@ CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_XIMG is not set +# CONFIG_MMC is not set diff --git a/configs/sama5d2_ptc_nandflash_defconfig b/configs/sama5d2_ptc_nandflash_defconfig index 5d977bd583..df6d32c595 100644 --- a/configs/sama5d2_ptc_nandflash_defconfig +++ b/configs/sama5d2_ptc_nandflash_defconfig @@ -6,7 +6,6 @@ CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_NAND_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y -# CONFIG_MMC is not set CONFIG_SYS_EXTRA_OPTIONS="SAMA5D2,SYS_USE_NANDFLASH" CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_BOARDINFO is not set @@ -17,6 +16,7 @@ CONFIG_SPL=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_SF=y # CONFIG_CMD_FPGA is not set +# CONFIG_MMC is not set CONFIG_SPI_FLASH=y CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/sama5d2_ptc_spiflash_defconfig b/configs/sama5d2_ptc_spiflash_defconfig index 29238a3615..30e8500edf 100644 --- a/configs/sama5d2_ptc_spiflash_defconfig +++ b/configs/sama5d2_ptc_spiflash_defconfig @@ -7,7 +7,6 @@ CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y -# CONFIG_MMC is not set CONFIG_SYS_EXTRA_OPTIONS="SAMA5D2,SYS_USE_SERIALFLASH" CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_BOARDINFO is not set @@ -18,6 +17,7 @@ CONFIG_SPL=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_SF=y # CONFIG_CMD_FPGA is not set +# CONFIG_MMC is not set CONFIG_SPI_FLASH=y CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/sbc8349_PCI_33_defconfig b/configs/sbc8349_PCI_33_defconfig index 201c9edbee..cc9bc7a9f2 100644 --- a/configs/sbc8349_PCI_33_defconfig +++ b/configs/sbc8349_PCI_33_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_MPC83xx=y CONFIG_TARGET_SBC8349=y CONFIG_OF_BOARD_SETUP=y @@ -11,5 +10,6 @@ CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_MII=y CONFIG_CMD_PING=y +# CONFIG_MMC is not set CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/sbc8349_PCI_66_defconfig b/configs/sbc8349_PCI_66_defconfig index afc4d1080c..2343864409 100644 --- a/configs/sbc8349_PCI_66_defconfig +++ b/configs/sbc8349_PCI_66_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_MPC83xx=y CONFIG_TARGET_SBC8349=y CONFIG_OF_BOARD_SETUP=y @@ -11,5 +10,6 @@ CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_MII=y CONFIG_CMD_PING=y +# CONFIG_MMC is not set CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/sbc8349_defconfig b/configs/sbc8349_defconfig index cafc16dfe0..62510e589c 100644 --- a/configs/sbc8349_defconfig +++ b/configs/sbc8349_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_MPC83xx=y CONFIG_TARGET_SBC8349=y CONFIG_OF_BOARD_SETUP=y @@ -10,6 +9,7 @@ CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_MII=y CONFIG_CMD_PING=y +# CONFIG_MMC is not set # CONFIG_PCI is not set CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/sbc8548_PCI_33_PCIE_defconfig b/configs/sbc8548_PCI_33_PCIE_defconfig index 3af5c70d47..790ebdc372 100644 --- a/configs/sbc8548_PCI_33_PCIE_defconfig +++ b/configs/sbc8548_PCI_33_PCIE_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_MPC85xx=y CONFIG_TARGET_SBC8548=y CONFIG_OF_BOARD_SETUP=y @@ -12,5 +11,6 @@ CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_MII=y CONFIG_CMD_PING=y +# CONFIG_MMC is not set CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/sbc8548_PCI_33_defconfig b/configs/sbc8548_PCI_33_defconfig index 671b35d699..24a443a729 100644 --- a/configs/sbc8548_PCI_33_defconfig +++ b/configs/sbc8548_PCI_33_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_MPC85xx=y CONFIG_TARGET_SBC8548=y CONFIG_OF_BOARD_SETUP=y @@ -12,5 +11,6 @@ CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_MII=y CONFIG_CMD_PING=y +# CONFIG_MMC is not set CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/sbc8548_PCI_66_PCIE_defconfig b/configs/sbc8548_PCI_66_PCIE_defconfig index 61b74705a1..f484bcab45 100644 --- a/configs/sbc8548_PCI_66_PCIE_defconfig +++ b/configs/sbc8548_PCI_66_PCIE_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_MPC85xx=y CONFIG_TARGET_SBC8548=y CONFIG_OF_BOARD_SETUP=y @@ -12,5 +11,6 @@ CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_MII=y CONFIG_CMD_PING=y +# CONFIG_MMC is not set CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/sbc8548_PCI_66_defconfig b/configs/sbc8548_PCI_66_defconfig index 8c8b38dfc5..d600055c72 100644 --- a/configs/sbc8548_PCI_66_defconfig +++ b/configs/sbc8548_PCI_66_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_MPC85xx=y CONFIG_TARGET_SBC8548=y CONFIG_OF_BOARD_SETUP=y @@ -12,5 +11,6 @@ CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_MII=y CONFIG_CMD_PING=y +# CONFIG_MMC is not set CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/sbc8548_defconfig b/configs/sbc8548_defconfig index fe2a6b97b4..47ac2f80f0 100644 --- a/configs/sbc8548_defconfig +++ b/configs/sbc8548_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_MPC85xx=y CONFIG_TARGET_SBC8548=y CONFIG_OF_BOARD_SETUP=y @@ -11,6 +10,7 @@ CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_MII=y CONFIG_CMD_PING=y +# CONFIG_MMC is not set # CONFIG_PCI is not set CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/sbc8641d_defconfig b/configs/sbc8641d_defconfig index 24305daf37..797775f360 100644 --- a/configs/sbc8641d_defconfig +++ b/configs/sbc8641d_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_MPC86xx=y CONFIG_TARGET_SBC8641D=y CONFIG_OF_BOARD_SETUP=y @@ -10,5 +9,6 @@ CONFIG_HUSH_PARSER=y CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_PING=y +# CONFIG_MMC is not set CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/sequoia_defconfig b/configs/sequoia_defconfig index 33261b871e..9479ac55a0 100644 --- a/configs/sequoia_defconfig +++ b/configs/sequoia_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_4xx=y CONFIG_TARGET_SEQUOIA=y CONFIG_OF_BOARD_SETUP=y @@ -19,6 +18,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_CMD_FAT=y +# CONFIG_MMC is not set CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/sequoia_ramboot_defconfig b/configs/sequoia_ramboot_defconfig index 000be91650..a589d748ff 100644 --- a/configs/sequoia_ramboot_defconfig +++ b/configs/sequoia_ramboot_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_4xx=y CONFIG_TARGET_SEQUOIA=y CONFIG_OF_BOARD_SETUP=y @@ -19,6 +18,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_CMD_FAT=y +# CONFIG_MMC is not set CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/sh7752evb_defconfig b/configs/sh7752evb_defconfig index ae5e038dde..d6ebfee736 100644 --- a/configs/sh7752evb_defconfig +++ b/configs/sh7752evb_defconfig @@ -1,5 +1,4 @@ CONFIG_SH=y -CONFIG_MMC=y CONFIG_SH_32BIT=y CONFIG_TARGET_SH7752EVB=y CONFIG_BOOTDELAY=3 @@ -25,6 +24,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y # CONFIG_CMD_MISC is not set CONFIG_CMD_EXT2=y +CONFIG_MMC=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/sh7753evb_defconfig b/configs/sh7753evb_defconfig index f8b9d86ae3..76c66cac18 100644 --- a/configs/sh7753evb_defconfig +++ b/configs/sh7753evb_defconfig @@ -1,5 +1,4 @@ CONFIG_SH=y -CONFIG_MMC=y CONFIG_TARGET_SH7753EVB=y CONFIG_BOOTDELAY=3 CONFIG_VERSION_VARIABLE=y @@ -24,6 +23,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y # CONFIG_CMD_MISC is not set CONFIG_CMD_EXT2=y +CONFIG_MMC=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/sh7757lcr_defconfig b/configs/sh7757lcr_defconfig index b12c11e6ee..a10cc75c97 100644 --- a/configs/sh7757lcr_defconfig +++ b/configs/sh7757lcr_defconfig @@ -1,5 +1,4 @@ CONFIG_SH=y -CONFIG_MMC=y CONFIG_SH_32BIT=y CONFIG_TARGET_SH7757LCR=y CONFIG_BOOTDELAY=3 @@ -25,6 +24,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y # CONFIG_CMD_MISC is not set CONFIG_CMD_EXT2=y +CONFIG_MMC=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/smartweb_defconfig b/configs/smartweb_defconfig index a0d31666e8..bd69b6a066 100644 --- a/configs/smartweb_defconfig +++ b/configs/smartweb_defconfig @@ -7,7 +7,6 @@ CONFIG_SPL_GPIO_SUPPORT=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_NAND_SUPPORT=y -# CONFIG_MMC is not set CONFIG_DEFAULT_DEVICE_TREE="at91sam9260-smartweb" CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9260" @@ -32,6 +31,7 @@ CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_OF_EMBED=y CONFIG_DFU_NAND=y +# CONFIG_MMC is not set CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_GADGET=y diff --git a/configs/smdkc100_defconfig b/configs/smdkc100_defconfig index b69f5d40cc..edaf73a72c 100644 --- a/configs/smdkc100_defconfig +++ b/configs/smdkc100_defconfig @@ -2,7 +2,6 @@ CONFIG_ARM=y CONFIG_ARCH_S5PC1XX=y CONFIG_TARGET_SMDKC100=y CONFIG_IDENT_STRING=" for SMDKC100" -# CONFIG_MMC is not set CONFIG_DEFAULT_DEVICE_TREE="s5pc1xx-smdkc100" CONFIG_BOOTDELAY=3 CONFIG_HUSH_PARSER=y @@ -12,3 +11,4 @@ CONFIG_SYS_PROMPT="SMDKC100 # " # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_CACHE=y CONFIG_CMD_FAT=y +# CONFIG_MMC is not set diff --git a/configs/snapper9260_defconfig b/configs/snapper9260_defconfig index d66635d4d7..2fbd7d2a8d 100644 --- a/configs/snapper9260_defconfig +++ b/configs/snapper9260_defconfig @@ -1,7 +1,6 @@ CONFIG_ARM=y CONFIG_ARCH_AT91=y CONFIG_TARGET_SNAPPER9260=y -# CONFIG_MMC is not set CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9260" CONFIG_BOOTDELAY=3 @@ -23,5 +22,6 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y +# CONFIG_MMC is not set CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/snapper9g20_defconfig b/configs/snapper9g20_defconfig index 416f543194..12cafd9815 100644 --- a/configs/snapper9g20_defconfig +++ b/configs/snapper9g20_defconfig @@ -1,7 +1,6 @@ CONFIG_ARM=y CONFIG_ARCH_AT91=y CONFIG_TARGET_SNAPPER9260=y -# CONFIG_MMC is not set CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9G20" CONFIG_BOOTDELAY=3 @@ -22,5 +21,6 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y +# CONFIG_MMC is not set CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/snow_defconfig b/configs/snow_defconfig index d6a48cb12c..0ea2393bf6 100644 --- a/configs/snow_defconfig +++ b/configs/snow_defconfig @@ -68,11 +68,11 @@ CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_STORAGE=y CONFIG_DM_VIDEO=y +CONFIG_VIDCONSOLE_AS_LCD=y CONFIG_DISPLAY=y CONFIG_VIDEO_BRIDGE=y CONFIG_VIDEO_BRIDGE_PARADE_PS862X=y CONFIG_VIDEO_BRIDGE_NXP_PTN3460=y CONFIG_LCD=y -CONFIG_VIDCONSOLE_AS_LCD=y CONFIG_TPM=y CONFIG_ERRNO_STR=y diff --git a/configs/socfpga_is1_defconfig b/configs/socfpga_is1_defconfig index 5ac6c496d1..058791e968 100644 --- a/configs/socfpga_is1_defconfig +++ b/configs/socfpga_is1_defconfig @@ -2,7 +2,6 @@ CONFIG_ARM=y CONFIG_ARCH_SOCFPGA=y CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_TARGET_SOCFPGA_IS1=y -# CONFIG_MMC is not set CONFIG_SPL_STACK_R_ADDR=0x00800000 CONFIG_DEFAULT_DEVICE_TREE="socfpga_cyclone5_is1" CONFIG_FIT=y @@ -38,6 +37,7 @@ CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_DM_GPIO=y CONFIG_DWAPB_GPIO=y CONFIG_SYS_I2C_DW=y +# CONFIG_MMC is not set CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_BAR=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/socrates_defconfig b/configs/socrates_defconfig index 078a797d3c..499a901269 100644 --- a/configs/socrates_defconfig +++ b/configs/socrates_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_VIDEO=y CONFIG_MPC85xx=y CONFIG_TARGET_SOCRATES=y @@ -19,6 +18,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_SNTP=y CONFIG_CMD_EXT2=y +# CONFIG_MMC is not set CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/spear300_defconfig b/configs/spear300_defconfig index 30a00c6379..5d16ef1c92 100644 --- a/configs/spear300_defconfig +++ b/configs/spear300_defconfig @@ -1,7 +1,6 @@ CONFIG_ARM=y CONFIG_TARGET_SPEAR300=y CONFIG_IDENT_STRING="-SPEAr" -# CONFIG_MMC is not set CONFIG_SYS_EXTRA_OPTIONS="SPEAR300" CONFIG_BOOTDELAY=1 CONFIG_SYS_CONSOLE_INFO_QUIET=y @@ -12,5 +11,6 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_SYS_I2C_DW=y +# CONFIG_MMC is not set CONFIG_NETDEVICES=y CONFIG_ETH_DESIGNWARE=y diff --git a/configs/spear300_nand_defconfig b/configs/spear300_nand_defconfig index 0af3a45e2b..b76d676f84 100644 --- a/configs/spear300_nand_defconfig +++ b/configs/spear300_nand_defconfig @@ -1,7 +1,6 @@ CONFIG_ARM=y CONFIG_TARGET_SPEAR300=y CONFIG_IDENT_STRING="-SPEAr" -# CONFIG_MMC is not set CONFIG_SYS_EXTRA_OPTIONS="SPEAR300,NAND" CONFIG_BOOTDELAY=1 CONFIG_SYS_CONSOLE_INFO_QUIET=y @@ -12,5 +11,6 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_SYS_I2C_DW=y +# CONFIG_MMC is not set CONFIG_NETDEVICES=y CONFIG_ETH_DESIGNWARE=y diff --git a/configs/spear300_usbtty_defconfig b/configs/spear300_usbtty_defconfig index b517b1bdb2..47eb0127f9 100644 --- a/configs/spear300_usbtty_defconfig +++ b/configs/spear300_usbtty_defconfig @@ -1,7 +1,6 @@ CONFIG_ARM=y CONFIG_TARGET_SPEAR300=y CONFIG_IDENT_STRING="-SPEAr" -# CONFIG_MMC is not set CONFIG_SYS_EXTRA_OPTIONS="SPEAR300,USBTTY" CONFIG_BOOTDELAY=-1 CONFIG_SYS_CONSOLE_INFO_QUIET=y @@ -12,5 +11,6 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_SYS_I2C_DW=y +# CONFIG_MMC is not set CONFIG_NETDEVICES=y CONFIG_ETH_DESIGNWARE=y diff --git a/configs/spear300_usbtty_nand_defconfig b/configs/spear300_usbtty_nand_defconfig index a33459aa0a..c76789f45b 100644 --- a/configs/spear300_usbtty_nand_defconfig +++ b/configs/spear300_usbtty_nand_defconfig @@ -1,7 +1,6 @@ CONFIG_ARM=y CONFIG_TARGET_SPEAR300=y CONFIG_IDENT_STRING="-SPEAr" -# CONFIG_MMC is not set CONFIG_SYS_EXTRA_OPTIONS="SPEAR300,USBTTY,NAND" CONFIG_BOOTDELAY=-1 CONFIG_SYS_CONSOLE_INFO_QUIET=y @@ -12,5 +11,6 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_SYS_I2C_DW=y +# CONFIG_MMC is not set CONFIG_NETDEVICES=y CONFIG_ETH_DESIGNWARE=y diff --git a/configs/spear310_defconfig b/configs/spear310_defconfig index 9c9a8abf65..2f70fc07f1 100644 --- a/configs/spear310_defconfig +++ b/configs/spear310_defconfig @@ -1,7 +1,6 @@ CONFIG_ARM=y CONFIG_TARGET_SPEAR310=y CONFIG_IDENT_STRING="-SPEAr" -# CONFIG_MMC is not set CONFIG_SYS_EXTRA_OPTIONS="SPEAR310" CONFIG_BOOTDELAY=1 CONFIG_SYS_CONSOLE_INFO_QUIET=y @@ -12,5 +11,6 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_SYS_I2C_DW=y +# CONFIG_MMC is not set CONFIG_NETDEVICES=y CONFIG_ETH_DESIGNWARE=y diff --git a/configs/spear310_nand_defconfig b/configs/spear310_nand_defconfig index 8da365eedb..954301b4ac 100644 --- a/configs/spear310_nand_defconfig +++ b/configs/spear310_nand_defconfig @@ -1,7 +1,6 @@ CONFIG_ARM=y CONFIG_TARGET_SPEAR310=y CONFIG_IDENT_STRING="-SPEAr" -# CONFIG_MMC is not set CONFIG_SYS_EXTRA_OPTIONS="SPEAR310,NAND" CONFIG_BOOTDELAY=1 CONFIG_SYS_CONSOLE_INFO_QUIET=y @@ -12,5 +11,6 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_SYS_I2C_DW=y +# CONFIG_MMC is not set CONFIG_NETDEVICES=y CONFIG_ETH_DESIGNWARE=y diff --git a/configs/spear310_pnor_defconfig b/configs/spear310_pnor_defconfig index 1ff5feabf6..8207232625 100644 --- a/configs/spear310_pnor_defconfig +++ b/configs/spear310_pnor_defconfig @@ -1,7 +1,6 @@ CONFIG_ARM=y CONFIG_TARGET_SPEAR310=y CONFIG_IDENT_STRING="-SPEAr" -# CONFIG_MMC is not set CONFIG_SYS_EXTRA_OPTIONS="SPEAR310,FLASH_PNOR" CONFIG_BOOTDELAY=1 CONFIG_SYS_CONSOLE_INFO_QUIET=y @@ -12,5 +11,6 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_SYS_I2C_DW=y +# CONFIG_MMC is not set CONFIG_NETDEVICES=y CONFIG_ETH_DESIGNWARE=y diff --git a/configs/spear310_usbtty_defconfig b/configs/spear310_usbtty_defconfig index 1f20e45059..53e9156c25 100644 --- a/configs/spear310_usbtty_defconfig +++ b/configs/spear310_usbtty_defconfig @@ -1,7 +1,6 @@ CONFIG_ARM=y CONFIG_TARGET_SPEAR310=y CONFIG_IDENT_STRING="-SPEAr" -# CONFIG_MMC is not set CONFIG_SYS_EXTRA_OPTIONS="SPEAR310,USBTTY" CONFIG_BOOTDELAY=-1 CONFIG_SYS_CONSOLE_INFO_QUIET=y @@ -12,5 +11,6 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_SYS_I2C_DW=y +# CONFIG_MMC is not set CONFIG_NETDEVICES=y CONFIG_ETH_DESIGNWARE=y diff --git a/configs/spear310_usbtty_nand_defconfig b/configs/spear310_usbtty_nand_defconfig index 2490ac3666..3d73182df1 100644 --- a/configs/spear310_usbtty_nand_defconfig +++ b/configs/spear310_usbtty_nand_defconfig @@ -1,7 +1,6 @@ CONFIG_ARM=y CONFIG_TARGET_SPEAR310=y CONFIG_IDENT_STRING="-SPEAr" -# CONFIG_MMC is not set CONFIG_SYS_EXTRA_OPTIONS="SPEAR310,USBTTY,NAND" CONFIG_BOOTDELAY=-1 CONFIG_SYS_CONSOLE_INFO_QUIET=y @@ -12,5 +11,6 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_SYS_I2C_DW=y +# CONFIG_MMC is not set CONFIG_NETDEVICES=y CONFIG_ETH_DESIGNWARE=y diff --git a/configs/spear310_usbtty_pnor_defconfig b/configs/spear310_usbtty_pnor_defconfig index 3ebae7b3c1..3f1fd3d11e 100644 --- a/configs/spear310_usbtty_pnor_defconfig +++ b/configs/spear310_usbtty_pnor_defconfig @@ -1,7 +1,6 @@ CONFIG_ARM=y CONFIG_TARGET_SPEAR310=y CONFIG_IDENT_STRING="-SPEAr" -# CONFIG_MMC is not set CONFIG_SYS_EXTRA_OPTIONS="SPEAR310,USBTTY,FLASH_PNOR" CONFIG_BOOTDELAY=-1 CONFIG_SYS_CONSOLE_INFO_QUIET=y @@ -12,5 +11,6 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_SYS_I2C_DW=y +# CONFIG_MMC is not set CONFIG_NETDEVICES=y CONFIG_ETH_DESIGNWARE=y diff --git a/configs/spear320_defconfig b/configs/spear320_defconfig index 60feb7e747..1cf1d235eb 100644 --- a/configs/spear320_defconfig +++ b/configs/spear320_defconfig @@ -1,7 +1,6 @@ CONFIG_ARM=y CONFIG_TARGET_SPEAR320=y CONFIG_IDENT_STRING="-SPEAr" -# CONFIG_MMC is not set CONFIG_SYS_EXTRA_OPTIONS="SPEAR320" CONFIG_BOOTDELAY=1 CONFIG_SYS_CONSOLE_INFO_QUIET=y @@ -12,5 +11,6 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_SYS_I2C_DW=y +# CONFIG_MMC is not set CONFIG_NETDEVICES=y CONFIG_ETH_DESIGNWARE=y diff --git a/configs/spear320_nand_defconfig b/configs/spear320_nand_defconfig index 0a481e4336..09739b4cb9 100644 --- a/configs/spear320_nand_defconfig +++ b/configs/spear320_nand_defconfig @@ -1,7 +1,6 @@ CONFIG_ARM=y CONFIG_TARGET_SPEAR320=y CONFIG_IDENT_STRING="-SPEAr" -# CONFIG_MMC is not set CONFIG_SYS_EXTRA_OPTIONS="SPEAR320,NAND" CONFIG_BOOTDELAY=1 CONFIG_SYS_CONSOLE_INFO_QUIET=y @@ -12,5 +11,6 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_SYS_I2C_DW=y +# CONFIG_MMC is not set CONFIG_NETDEVICES=y CONFIG_ETH_DESIGNWARE=y diff --git a/configs/spear320_pnor_defconfig b/configs/spear320_pnor_defconfig index b3e2725ee9..a2da5a3154 100644 --- a/configs/spear320_pnor_defconfig +++ b/configs/spear320_pnor_defconfig @@ -1,7 +1,6 @@ CONFIG_ARM=y CONFIG_TARGET_SPEAR320=y CONFIG_IDENT_STRING="-SPEAr" -# CONFIG_MMC is not set CONFIG_SYS_EXTRA_OPTIONS="SPEAR320,FLASH_PNOR" CONFIG_BOOTDELAY=1 CONFIG_SYS_CONSOLE_INFO_QUIET=y @@ -12,5 +11,6 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_SYS_I2C_DW=y +# CONFIG_MMC is not set CONFIG_NETDEVICES=y CONFIG_ETH_DESIGNWARE=y diff --git a/configs/spear320_usbtty_defconfig b/configs/spear320_usbtty_defconfig index a72998065c..5027b1b0e1 100644 --- a/configs/spear320_usbtty_defconfig +++ b/configs/spear320_usbtty_defconfig @@ -1,7 +1,6 @@ CONFIG_ARM=y CONFIG_TARGET_SPEAR320=y CONFIG_IDENT_STRING="-SPEAr" -# CONFIG_MMC is not set CONFIG_SYS_EXTRA_OPTIONS="SPEAR320,USBTTY" CONFIG_BOOTDELAY=-1 CONFIG_SYS_CONSOLE_INFO_QUIET=y @@ -12,5 +11,6 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_SYS_I2C_DW=y +# CONFIG_MMC is not set CONFIG_NETDEVICES=y CONFIG_ETH_DESIGNWARE=y diff --git a/configs/spear320_usbtty_nand_defconfig b/configs/spear320_usbtty_nand_defconfig index 858ee65900..bfc42757f6 100644 --- a/configs/spear320_usbtty_nand_defconfig +++ b/configs/spear320_usbtty_nand_defconfig @@ -1,7 +1,6 @@ CONFIG_ARM=y CONFIG_TARGET_SPEAR320=y CONFIG_IDENT_STRING="-SPEAr" -# CONFIG_MMC is not set CONFIG_SYS_EXTRA_OPTIONS="SPEAR320,USBTTY,NAND" CONFIG_BOOTDELAY=-1 CONFIG_SYS_CONSOLE_INFO_QUIET=y @@ -12,5 +11,6 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_SYS_I2C_DW=y +# CONFIG_MMC is not set CONFIG_NETDEVICES=y CONFIG_ETH_DESIGNWARE=y diff --git a/configs/spear320_usbtty_pnor_defconfig b/configs/spear320_usbtty_pnor_defconfig index fea30279fe..8bcf8c8e95 100644 --- a/configs/spear320_usbtty_pnor_defconfig +++ b/configs/spear320_usbtty_pnor_defconfig @@ -1,7 +1,6 @@ CONFIG_ARM=y CONFIG_TARGET_SPEAR320=y CONFIG_IDENT_STRING="-SPEAr" -# CONFIG_MMC is not set CONFIG_SYS_EXTRA_OPTIONS="SPEAR320,USBTTY,FLASH_PNOR" CONFIG_BOOTDELAY=-1 CONFIG_SYS_CONSOLE_INFO_QUIET=y @@ -12,5 +11,6 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_SYS_I2C_DW=y +# CONFIG_MMC is not set CONFIG_NETDEVICES=y CONFIG_ETH_DESIGNWARE=y diff --git a/configs/spear600_defconfig b/configs/spear600_defconfig index acd1542b52..487c64a266 100644 --- a/configs/spear600_defconfig +++ b/configs/spear600_defconfig @@ -1,7 +1,6 @@ CONFIG_ARM=y CONFIG_TARGET_SPEAR600=y CONFIG_IDENT_STRING="-SPEAr" -# CONFIG_MMC is not set CONFIG_SYS_EXTRA_OPTIONS="SPEAR600" CONFIG_BOOTDELAY=1 CONFIG_SYS_CONSOLE_INFO_QUIET=y @@ -15,5 +14,6 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_SYS_I2C_DW=y +# CONFIG_MMC is not set CONFIG_NETDEVICES=y CONFIG_ETH_DESIGNWARE=y diff --git a/configs/spear600_nand_defconfig b/configs/spear600_nand_defconfig index 6e0a912ec1..3369418c2c 100644 --- a/configs/spear600_nand_defconfig +++ b/configs/spear600_nand_defconfig @@ -1,7 +1,6 @@ CONFIG_ARM=y CONFIG_TARGET_SPEAR600=y CONFIG_IDENT_STRING="-SPEAr" -# CONFIG_MMC is not set CONFIG_SYS_EXTRA_OPTIONS="SPEAR600,NAND" CONFIG_BOOTDELAY=1 CONFIG_SYS_CONSOLE_INFO_QUIET=y @@ -12,5 +11,6 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_SYS_I2C_DW=y +# CONFIG_MMC is not set CONFIG_NETDEVICES=y CONFIG_ETH_DESIGNWARE=y diff --git a/configs/spear600_usbtty_defconfig b/configs/spear600_usbtty_defconfig index f42f1a8948..264ad15cfa 100644 --- a/configs/spear600_usbtty_defconfig +++ b/configs/spear600_usbtty_defconfig @@ -1,7 +1,6 @@ CONFIG_ARM=y CONFIG_TARGET_SPEAR600=y CONFIG_IDENT_STRING="-SPEAr" -# CONFIG_MMC is not set CONFIG_SYS_EXTRA_OPTIONS="SPEAR600,USBTTY" CONFIG_BOOTDELAY=-1 CONFIG_SYS_CONSOLE_INFO_QUIET=y @@ -12,5 +11,6 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_SYS_I2C_DW=y +# CONFIG_MMC is not set CONFIG_NETDEVICES=y CONFIG_ETH_DESIGNWARE=y diff --git a/configs/spear600_usbtty_nand_defconfig b/configs/spear600_usbtty_nand_defconfig index b736dc83c4..c264170490 100644 --- a/configs/spear600_usbtty_nand_defconfig +++ b/configs/spear600_usbtty_nand_defconfig @@ -1,7 +1,6 @@ CONFIG_ARM=y CONFIG_TARGET_SPEAR600=y CONFIG_IDENT_STRING="-SPEAr" -# CONFIG_MMC is not set CONFIG_SYS_EXTRA_OPTIONS="SPEAR600,USBTTY,NAND" CONFIG_BOOTDELAY=-1 CONFIG_SYS_CONSOLE_INFO_QUIET=y @@ -12,5 +11,6 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_SYS_I2C_DW=y +# CONFIG_MMC is not set CONFIG_NETDEVICES=y CONFIG_ETH_DESIGNWARE=y diff --git a/configs/spring_defconfig b/configs/spring_defconfig index a64e648b67..d9fd8ca362 100644 --- a/configs/spring_defconfig +++ b/configs/spring_defconfig @@ -68,10 +68,10 @@ CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_STORAGE=y CONFIG_DM_VIDEO=y +CONFIG_VIDCONSOLE_AS_LCD=y CONFIG_DISPLAY=y CONFIG_VIDEO_BRIDGE=y CONFIG_VIDEO_BRIDGE_PARADE_PS862X=y CONFIG_LCD=y -CONFIG_VIDCONSOLE_AS_LCD=y CONFIG_TPM=y CONFIG_ERRNO_STR=y diff --git a/configs/stm32f429-discovery_defconfig b/configs/stm32f429-discovery_defconfig index c554d2dfbe..b5b04180de 100644 --- a/configs/stm32f429-discovery_defconfig +++ b/configs/stm32f429-discovery_defconfig @@ -2,7 +2,6 @@ CONFIG_ARM=y CONFIG_STM32=y CONFIG_STM32F4=y CONFIG_TARGET_STM32F429_DISCOVERY=y -# CONFIG_MMC is not set CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_DISPLAY_BOARDINFO is not set @@ -11,4 +10,5 @@ CONFIG_SYS_PROMPT="U-Boot > " # CONFIG_CMD_BOOTEFI_HELLO_COMPILE is not set # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_TIMER=y +# CONFIG_MMC is not set CONFIG_OF_LIBFDT=y diff --git a/configs/stm32f746-disco_defconfig b/configs/stm32f746-disco_defconfig index 55b9eba5c0..10d9120237 100644 --- a/configs/stm32f746-disco_defconfig +++ b/configs/stm32f746-disco_defconfig @@ -2,7 +2,6 @@ CONFIG_ARM=y CONFIG_STM32=y CONFIG_STM32F7=y CONFIG_TARGET_STM32F746_DISCO=y -# CONFIG_MMC is not set CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_DISPLAY_BOARDINFO is not set @@ -14,5 +13,6 @@ CONFIG_AUTOBOOT_STOP_STR=" " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_TIMER=y +# CONFIG_MMC is not set CONFIG_OF_LIBFDT=y # CONFIG_EFI_LOADER is not set diff --git a/configs/stv0991_defconfig b/configs/stv0991_defconfig index f808ce2214..2c80a5e64b 100644 --- a/configs/stv0991_defconfig +++ b/configs/stv0991_defconfig @@ -1,7 +1,6 @@ CONFIG_ARM=y CONFIG_TARGET_STV0991=y CONFIG_SYS_MALLOC_F_LEN=0x2000 -# CONFIG_MMC is not set CONFIG_DEFAULT_DEVICE_TREE="stv0991" CONFIG_SYS_EXTRA_OPTIONS="STV0991" CONFIG_BOOTDELAY=3 @@ -19,6 +18,7 @@ CONFIG_CMD_SPI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_PING=y CONFIG_OF_CONTROL=y +# CONFIG_MMC is not set CONFIG_SPI_FLASH_STMICRO=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_NETDEVICES=y diff --git a/configs/suvd3_defconfig b/configs/suvd3_defconfig index cd5e1cb97e..cbfd9df390 100644 --- a/configs/suvd3_defconfig +++ b/configs/suvd3_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_MPC83xx=y CONFIG_TARGET_SUVD3=y CONFIG_OF_BOARD_SETUP=y @@ -17,6 +16,7 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_UBI=y +# CONFIG_MMC is not set # CONFIG_PCI is not set CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/sycamore_defconfig b/configs/sycamore_defconfig index b19146bd68..530dc6ba76 100644 --- a/configs/sycamore_defconfig +++ b/configs/sycamore_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_4xx=y CONFIG_TARGET_WALNUT=y CONFIG_OF_BOARD_SETUP=y @@ -15,5 +14,6 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_SNTP=y +# CONFIG_MMC is not set CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/t3corp_defconfig b/configs/t3corp_defconfig index 84372a9481..7c64986dd5 100644 --- a/configs/t3corp_defconfig +++ b/configs/t3corp_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_4xx=y CONFIG_TARGET_T3CORP=y CONFIG_FIT=y @@ -17,5 +16,6 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y +# CONFIG_MMC is not set CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/taurus_defconfig b/configs/taurus_defconfig index 0f6841b21f..c2eeb52c1f 100644 --- a/configs/taurus_defconfig +++ b/configs/taurus_defconfig @@ -10,7 +10,6 @@ CONFIG_SPL_NAND_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y -# CONFIG_MMC is not set CONFIG_DEFAULT_DEVICE_TREE="at91sam9g20-taurus" CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9G20,MACH_TYPE=2067,BOARD_TAURUS" CONFIG_BOOTDELAY=3 @@ -35,6 +34,7 @@ CONFIG_CMD_PING=y CONFIG_OF_CONTROL=y CONFIG_OF_EMBED=y CONFIG_DFU_NAND=y +# CONFIG_MMC is not set CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_USB=y diff --git a/configs/tcm-bf537_defconfig b/configs/tcm-bf537_defconfig index fd2e76e801..123d55d3a5 100644 --- a/configs/tcm-bf537_defconfig +++ b/configs/tcm-bf537_defconfig @@ -1,5 +1,4 @@ CONFIG_BLACKFIN=y -CONFIG_MMC=y CONFIG_TARGET_TCM_BF537=y CONFIG_BOOTDELAY=5 CONFIG_SILENT_CONSOLE=y @@ -17,4 +16,5 @@ CONFIG_CMD_CACHE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_MMC=y CONFIG_CC_OPTIMIZE_LIBS_FOR_SPEED=y diff --git a/configs/theadorable-x86-dfi-bt700_defconfig b/configs/theadorable-x86-dfi-bt700_defconfig index f3c2c86367..ed0b277b27 100644 --- a/configs/theadorable-x86-dfi-bt700_defconfig +++ b/configs/theadorable-x86-dfi-bt700_defconfig @@ -1,5 +1,4 @@ CONFIG_X86=y -CONFIG_MMC=y CONFIG_VENDOR_DFI=y CONFIG_DEFAULT_DEVICE_TREE="theadorable-x86-dfi-bt700" CONFIG_TARGET_DFI_BT700=y @@ -42,6 +41,7 @@ CONFIG_SYSCON=y CONFIG_CPU=y CONFIG_DM_I2C=y CONFIG_NUVOTON_NCT6102D=y +CONFIG_MMC=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_SDMA=y CONFIG_SPI_FLASH=y diff --git a/configs/theadorable_debug_defconfig b/configs/theadorable_debug_defconfig index eab167b2f8..58bcbab5f0 100644 --- a/configs/theadorable_debug_defconfig +++ b/configs/theadorable_debug_defconfig @@ -8,7 +8,6 @@ CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y -# CONFIG_MMC is not set CONFIG_VIDEO=y CONFIG_DEFAULT_DEVICE_TREE="armada-xp-theadorable" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set @@ -42,6 +41,7 @@ CONFIG_CMD_FS_GENERIC=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPL_OF_TRANSLATE=y CONFIG_DM_GPIO=y +# CONFIG_MMC is not set CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/theadorable_defconfig b/configs/theadorable_defconfig index 3c2e140abe..c5faa8b431 100644 --- a/configs/theadorable_defconfig +++ b/configs/theadorable_defconfig @@ -8,7 +8,6 @@ CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y -# CONFIG_MMC is not set CONFIG_VIDEO=y CONFIG_DEFAULT_DEVICE_TREE="armada-xp-theadorable" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set @@ -35,6 +34,7 @@ CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_SPL_OF_TRANSLATE=y CONFIG_DM_GPIO=y +# CONFIG_MMC is not set CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/thunderx_88xx_defconfig b/configs/thunderx_88xx_defconfig index 196bf6fdd5..6d6bf67b86 100644 --- a/configs/thunderx_88xx_defconfig +++ b/configs/thunderx_88xx_defconfig @@ -1,7 +1,6 @@ CONFIG_ARM=y CONFIG_TARGET_THUNDERX_88XX=y CONFIG_IDENT_STRING=" for Cavium Thunder CN88XX ARM v8 Multi-Core" -# CONFIG_MMC is not set CONFIG_DEFAULT_DEVICE_TREE="thunderx-88xx" CONFIG_BOOTDELAY=5 # CONFIG_DISPLAY_CPUINFO is not set @@ -19,6 +18,7 @@ CONFIG_SYS_PROMPT="ThunderX_88XX> " # CONFIG_CMD_NET is not set # CONFIG_CMD_NFS is not set CONFIG_DM=y +# CONFIG_MMC is not set CONFIG_DM_SERIAL=y CONFIG_DEBUG_UART=y CONFIG_DEBUG_UART_PL011=y diff --git a/configs/tuge1_defconfig b/configs/tuge1_defconfig index c2b8ba8ed8..df3160de59 100644 --- a/configs/tuge1_defconfig +++ b/configs/tuge1_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_MPC83xx=y CONFIG_TARGET_TUXX1=y CONFIG_OF_BOARD_SETUP=y @@ -17,6 +16,7 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_UBI=y +# CONFIG_MMC is not set # CONFIG_PCI is not set CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/tuxx1_defconfig b/configs/tuxx1_defconfig index 83fb28e5c5..ac4f70007a 100644 --- a/configs/tuxx1_defconfig +++ b/configs/tuxx1_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_MPC83xx=y CONFIG_TARGET_TUXX1=y CONFIG_OF_BOARD_SETUP=y @@ -17,6 +16,7 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_UBI=y +# CONFIG_MMC is not set # CONFIG_PCI is not set CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/usb_a9263_dataflash_defconfig b/configs/usb_a9263_dataflash_defconfig index 8ec623bdf8..7a8005b6db 100644 --- a/configs/usb_a9263_dataflash_defconfig +++ b/configs/usb_a9263_dataflash_defconfig @@ -1,7 +1,6 @@ CONFIG_ARM=y CONFIG_ARCH_AT91=y CONFIG_TARGET_USB_A9263=y -# CONFIG_MMC is not set CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9263,SYS_USE_DATAFLASH" CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_BOARDINFO is not set @@ -17,4 +16,5 @@ CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y +# CONFIG_MMC is not set CONFIG_OF_LIBFDT=y diff --git a/configs/v38b_defconfig b/configs/v38b_defconfig index e5dd07afac..6ffdfdd6da 100644 --- a/configs/v38b_defconfig +++ b/configs/v38b_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_MPC5xxx=y CONFIG_TARGET_V38B=y CONFIG_BOOTDELAY=3 @@ -16,6 +15,7 @@ CONFIG_LED_STATUS_BIT=16 CONFIG_LED_STATUS_STATE=1 CONFIG_LED_STATUS_BOOT_ENABLE=y CONFIG_LED_STATUS_BOOT=0 +# CONFIG_MMC is not set # CONFIG_PCI is not set CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/ve8313_defconfig b/configs/ve8313_defconfig index 9d1090b21c..86ba0c1e45 100644 --- a/configs/ve8313_defconfig +++ b/configs/ve8313_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_MPC83xx=y CONFIG_TARGET_VE8313=y CONFIG_OF_BOARD_SETUP=y @@ -10,5 +9,6 @@ CONFIG_HUSH_PARSER=y CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y +# CONFIG_MMC is not set CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/vexpress_aemv8a_dram_defconfig b/configs/vexpress_aemv8a_dram_defconfig index 9fa1095a83..3b22dd4ece 100644 --- a/configs/vexpress_aemv8a_dram_defconfig +++ b/configs/vexpress_aemv8a_dram_defconfig @@ -2,7 +2,6 @@ CONFIG_ARM=y CONFIG_TARGET_VEXPRESS64_BASE_FVP_DRAM=y CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_IDENT_STRING=" vexpress_aemv8a" -# CONFIG_MMC is not set CONFIG_DISTRO_DEFAULTS=y CONFIG_BOOTDELAY=1 # CONFIG_DISPLAY_CPUINFO is not set @@ -23,5 +22,6 @@ CONFIG_CMD_ARMFLASH=y CONFIG_CMD_CACHE=y # CONFIG_CMD_MISC is not set CONFIG_DM=y +# CONFIG_MMC is not set CONFIG_DM_SERIAL=y CONFIG_OF_LIBFDT=y diff --git a/configs/vexpress_aemv8a_juno_defconfig b/configs/vexpress_aemv8a_juno_defconfig index ae0a69137f..128a1e357b 100644 --- a/configs/vexpress_aemv8a_juno_defconfig +++ b/configs/vexpress_aemv8a_juno_defconfig @@ -2,7 +2,6 @@ CONFIG_ARM=y CONFIG_TARGET_VEXPRESS64_JUNO=y CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_IDENT_STRING=" vexpress_aemv8a" -# CONFIG_MMC is not set CONFIG_DISTRO_DEFAULTS=y CONFIG_BOOTDELAY=1 # CONFIG_DISPLAY_CPUINFO is not set @@ -23,5 +22,6 @@ CONFIG_CMD_ARMFLASH=y CONFIG_CMD_CACHE=y # CONFIG_CMD_MISC is not set CONFIG_DM=y +# CONFIG_MMC is not set CONFIG_DM_SERIAL=y CONFIG_OF_LIBFDT=y diff --git a/configs/vexpress_aemv8a_semi_defconfig b/configs/vexpress_aemv8a_semi_defconfig index 97505daf51..20594a7ef1 100644 --- a/configs/vexpress_aemv8a_semi_defconfig +++ b/configs/vexpress_aemv8a_semi_defconfig @@ -2,7 +2,6 @@ CONFIG_ARM=y CONFIG_TARGET_VEXPRESS64_BASE_FVP=y CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_IDENT_STRING=" vexpress_aemv8a" -# CONFIG_MMC is not set CONFIG_DISTRO_DEFAULTS=y CONFIG_BOOTDELAY=1 # CONFIG_DISPLAY_CPUINFO is not set @@ -23,5 +22,6 @@ CONFIG_CMD_ARMFLASH=y CONFIG_CMD_CACHE=y # CONFIG_CMD_MISC is not set CONFIG_DM=y +# CONFIG_MMC is not set CONFIG_DM_SERIAL=y CONFIG_OF_LIBFDT=y diff --git a/configs/vme8349_defconfig b/configs/vme8349_defconfig index 4213e8aac4..0024bc14ff 100644 --- a/configs/vme8349_defconfig +++ b/configs/vme8349_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_MPC83xx=y CONFIG_TARGET_VME8349=y CONFIG_OF_BOARD_SETUP=y @@ -10,5 +9,6 @@ CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_MII=y CONFIG_CMD_PING=y +# CONFIG_MMC is not set CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/walnut_defconfig b/configs/walnut_defconfig index b19146bd68..530dc6ba76 100644 --- a/configs/walnut_defconfig +++ b/configs/walnut_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_4xx=y CONFIG_TARGET_WALNUT=y CONFIG_OF_BOARD_SETUP=y @@ -15,5 +14,6 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_SNTP=y +# CONFIG_MMC is not set CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/work_92105_defconfig b/configs/work_92105_defconfig index a705e8b83c..d3b739f93d 100644 --- a/configs/work_92105_defconfig +++ b/configs/work_92105_defconfig @@ -4,7 +4,6 @@ CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_NAND_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y -# CONFIG_MMC is not set CONFIG_BOOTDELAY=3 CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set @@ -23,5 +22,6 @@ CONFIG_CMD_PING=y CONFIG_DM=y CONFIG_SPL_DM=y CONFIG_DM_GPIO=y +# CONFIG_MMC is not set CONFIG_DM_SERIAL=y CONFIG_SYS_NS16550=y diff --git a/configs/wtk_defconfig b/configs/wtk_defconfig index fa2eea02f6..01c9fe822c 100644 --- a/configs/wtk_defconfig +++ b/configs/wtk_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_8xx=y CONFIG_TARGET_TQM823L=y CONFIG_OF_BOARD_SETUP=y @@ -12,6 +11,7 @@ CONFIG_CMD_ASKENV=y CONFIG_CMD_DHCP=y CONFIG_CMD_SNTP=y CONFIG_CMD_EXT2=y +# CONFIG_MMC is not set # CONFIG_PCI is not set CONFIG_LCD=y CONFIG_OF_LIBFDT=y diff --git a/configs/xilinx-ppc405-generic_defconfig b/configs/xilinx-ppc405-generic_defconfig index f686fe99bb..37faa2ebc8 100644 --- a/configs/xilinx-ppc405-generic_defconfig +++ b/configs/xilinx-ppc405-generic_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_4xx=y CONFIG_TARGET_XILINX_PPC405_GENERIC=y CONFIG_DEFAULT_DEVICE_TREE="xilinx-ppc405-generic" @@ -20,6 +19,7 @@ CONFIG_LOOPW=y # CONFIG_CMD_NFS is not set CONFIG_CMD_CACHE=y CONFIG_OF_EMBED=y +# CONFIG_MMC is not set # CONFIG_PCI is not set CONFIG_SYS_NS16550=y CONFIG_XILINX_UARTLITE=y diff --git a/configs/xilinx-ppc440-generic_defconfig b/configs/xilinx-ppc440-generic_defconfig index ef2822236b..609ac9a7c0 100644 --- a/configs/xilinx-ppc440-generic_defconfig +++ b/configs/xilinx-ppc440-generic_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_4xx=y CONFIG_TARGET_XILINX_PPC440_GENERIC=y CONFIG_DEFAULT_DEVICE_TREE="xilinx-ppc440-generic" @@ -20,6 +19,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_OF_EMBED=y CONFIG_NETCONSOLE=y +# CONFIG_MMC is not set # CONFIG_PCI is not set CONFIG_SYS_NS16550=y CONFIG_XILINX_UARTLITE=y diff --git a/configs/xpedite1000_defconfig b/configs/xpedite1000_defconfig index ee98fc5fdf..2b6a8e7bde 100644 --- a/configs/xpedite1000_defconfig +++ b/configs/xpedite1000_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_4xx=y CONFIG_TARGET_XPEDITE1000=y CONFIG_FIT=y @@ -13,4 +12,5 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_SNTP=y +# CONFIG_MMC is not set CONFIG_SYS_NS16550=y diff --git a/configs/xpedite517x_defconfig b/configs/xpedite517x_defconfig index 731466ead8..d368795d7c 100644 --- a/configs/xpedite517x_defconfig +++ b/configs/xpedite517x_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_MPC86xx=y CONFIG_TARGET_XPEDITE517X=y CONFIG_FIT=y @@ -15,5 +14,6 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_SNTP=y +# CONFIG_MMC is not set CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/xpedite520x_defconfig b/configs/xpedite520x_defconfig index 8763be8881..d7f890e24f 100644 --- a/configs/xpedite520x_defconfig +++ b/configs/xpedite520x_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_MPC85xx=y CONFIG_TARGET_XPEDITE520X=y CONFIG_FIT=y @@ -15,5 +14,6 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_SNTP=y +# CONFIG_MMC is not set CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/xpedite537x_defconfig b/configs/xpedite537x_defconfig index 8e86a3306e..654cf7c09e 100644 --- a/configs/xpedite537x_defconfig +++ b/configs/xpedite537x_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_MPC85xx=y CONFIG_TARGET_XPEDITE537X=y CONFIG_FIT=y @@ -16,5 +15,6 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_SNTP=y CONFIG_SYS_FSL_DDR2=y +# CONFIG_MMC is not set CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/xpedite550x_defconfig b/configs/xpedite550x_defconfig index e186c7e945..c1c60b1ff0 100644 --- a/configs/xpedite550x_defconfig +++ b/configs/xpedite550x_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_MPC85xx=y CONFIG_TARGET_XPEDITE550X=y CONFIG_FIT=y @@ -16,6 +15,7 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_SNTP=y +# CONFIG_MMC is not set CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/yellowstone_defconfig b/configs/yellowstone_defconfig index c26c844206..aa02381de7 100644 --- a/configs/yellowstone_defconfig +++ b/configs/yellowstone_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_4xx=y CONFIG_TARGET_YOSEMITE=y CONFIG_OF_BOARD_SETUP=y @@ -16,6 +15,7 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y +# CONFIG_MMC is not set # CONFIG_PCI_PNP is not set CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/yosemite_defconfig b/configs/yosemite_defconfig index c77cd22ee1..b81e57d390 100644 --- a/configs/yosemite_defconfig +++ b/configs/yosemite_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_4xx=y CONFIG_TARGET_YOSEMITE=y CONFIG_OF_BOARD_SETUP=y @@ -19,6 +18,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +# CONFIG_MMC is not set # CONFIG_PCI_PNP is not set CONFIG_SYS_NS16550=y CONFIG_USB=y diff --git a/configs/yucca_defconfig b/configs/yucca_defconfig index ee04b008f6..2033610522 100644 --- a/configs/yucca_defconfig +++ b/configs/yucca_defconfig @@ -1,5 +1,4 @@ CONFIG_PPC=y -# CONFIG_MMC is not set CONFIG_4xx=y CONFIG_TARGET_YUCCA=y CONFIG_OF_BOARD_SETUP=y @@ -15,5 +14,6 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y +# CONFIG_MMC is not set CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y
This is not defined by any board in U-Boot.
arch/arm/include/asm/imx-common/dma.h | 7 +------ scripts/config_whitelist.txt | 1 - 2 files changed, 1 insertion(+), 7 deletions(-)
diff --git a/arch/arm/include/asm/imx-common/dma.h b/arch/arm/include/asm/imx-common/dma.h index 1aec4f9d5a..0244947b6e 100644 --- a/arch/arm/include/asm/imx-common/dma.h +++ b/arch/arm/include/asm/imx-common/dma.h @@ -16,12 +16,7 @@ #include <linux/list.h> #include <linux/compiler.h>
-#ifndef CONFIG_ARCH_DMA_PIO_WORDS -#define DMA_PIO_WORDS 15 -#else -#define DMA_PIO_WORDS CONFIG_ARCH_DMA_PIO_WORDS -#endif - +#define DMA_PIO_WORDS 15 #define MXS_DMA_ALIGNMENT ARCH_DMA_MINALIGN
/* diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index fb9fb3472c..a927e5019c 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -109,7 +109,6 @@ CONFIG_AP_SH4A_4A CONFIG_ARCH_ADPAG101P CONFIG_ARCH_CPU_INIT CONFIG_ARCH_CSB226 -CONFIG_ARCH_DMA_PIO_WORDS CONFIG_ARCH_EARLY_INIT_R CONFIG_ARCH_HAS_ILOG2_U32 CONFIG_ARCH_HAS_ILOG2_U64
This converts the following to Kconfig: CONFIG_ARCH_EARLY_INIT_R
arch/Kconfig | 1 + arch/arc/include/asm/config.h | 1 - arch/arm/Kconfig | 1 + arch/arm/cpu/armv8/fsl-layerscape/Kconfig | 4 ++++ common/Kconfig | 13 +++++++++++++ configs/bayleybay_defconfig | 1 + configs/cougarcanyon2_defconfig | 1 + configs/dfi-bt700-q7x-151_defconfig | 1 + configs/efi-x86_defconfig | 1 + configs/minnowmax_defconfig | 1 + configs/mvebu_db-88f3720_defconfig | 1 + configs/mvebu_db-88f7040_defconfig | 1 + configs/mvebu_db-88f8040_defconfig | 1 + configs/qemu-x86_efi_payload32_defconfig | 1 + configs/qemu-x86_efi_payload64_defconfig | 1 + configs/rut_defconfig | 1 + configs/theadorable-x86-dfi-bt700_defconfig | 1 + include/configs/conga-qeval20-qa3-e3845.h | 1 - include/configs/crownbay.h | 1 - include/configs/galileo.h | 1 - include/configs/ls1012a_common.h | 2 -- include/configs/ls1043a_common.h | 1 - include/configs/ls1046a_common.h | 1 - include/configs/ls2080a_common.h | 1 - include/configs/minnowmax.h | 1 - include/configs/mvebu_armada-8k.h | 1 - include/configs/mvebu_db-88f3720.h | 1 - include/configs/qemu-x86.h | 1 - include/configs/rut.h | 1 - include/configs/socfpga_common.h | 1 - include/configs/som-6896.h | 2 -- include/configs/som-db5800-som-6867.h | 1 - include/configs/x86-chromebook.h | 2 -- scripts/config_whitelist.txt | 1 - 34 files changed, 31 insertions(+), 21 deletions(-)
diff --git a/arch/Kconfig b/arch/Kconfig index ffc7b45379..692610b2ff 100644 --- a/arch/Kconfig +++ b/arch/Kconfig @@ -12,6 +12,7 @@ config ARC bool "ARC architecture" select HAVE_PRIVATE_LIBGCC select SUPPORT_OF_CONTROL + select ARCH_EARLY_INIT_R
config ARM bool "ARM architecture" diff --git a/arch/arc/include/asm/config.h b/arch/arc/include/asm/config.h index d2d791988e..7aaa5c2912 100644 --- a/arch/arc/include/asm/config.h +++ b/arch/arc/include/asm/config.h @@ -8,7 +8,6 @@ #define __ASM_ARC_CONFIG_H_
#define CONFIG_SYS_BOOT_RAMDISK_HIGH -#define CONFIG_ARCH_EARLY_INIT_R
#define CONFIG_LMB
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 855871c64f..1538140301 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -586,6 +586,7 @@ config ARCH_SOCFPGA select DM_SPI_FLASH select DM_SPI select ENABLE_ARM_SOC_BOOT0_HOOK + select ARCH_EARLY_INIT_R
config TARGET_CM_T43 bool "Support cm_t43" diff --git a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig index ba411e2af8..d93a61d00f 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig +++ b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig @@ -5,6 +5,7 @@ config ARCH_LS1012A select SYS_FSL_DDR_BE select SYS_FSL_MMDC select SYS_FSL_ERRATUM_A010315 + select ARCH_EARLY_INIT_R
config ARCH_LS1043A bool @@ -22,6 +23,7 @@ config ARCH_LS1043A select SYS_FSL_ERRATUM_A010539 select SYS_FSL_HAS_DDR3 select SYS_FSL_HAS_DDR4 + select ARCH_EARLY_INIT_R
config ARCH_LS1046A bool @@ -38,6 +40,7 @@ config ARCH_LS1046A select SYS_FSL_ERRATUM_A010539 select SYS_FSL_HAS_DDR4 select SYS_FSL_SRDS_2 + select ARCH_EARLY_INIT_R
config ARCH_LS2080A bool @@ -62,6 +65,7 @@ config ARCH_LS2080A select SYS_FSL_ERRATUM_A009803 select SYS_FSL_ERRATUM_A009942 select SYS_FSL_ERRATUM_A010165 + select ARCH_EARLY_INIT_R
config FSL_LSCH2 bool diff --git a/common/Kconfig b/common/Kconfig index bb47ee4341..6c8a856d40 100644 --- a/common/Kconfig +++ b/common/Kconfig @@ -399,4 +399,17 @@ config DISPLAY_BOARDINFO when U-Boot starts up. The board function checkboard() is called to do this.
+menu "Start-up hooks" + +config ARCH_EARLY_INIT_R + bool "Call arch-specific init soon after relocation" + default y if X86 + help + With this option U-Boot will call arch_early_init_r() soon after + relocation. Driver model is running by this point, and the cache + is on. Note that board_early_init_r() is called first, if + enabled. This can be used to set up architecture-specific devices. + +endmenu + source "common/spl/Kconfig" diff --git a/configs/bayleybay_defconfig b/configs/bayleybay_defconfig index 9f7c2f4e58..8799194f52 100644 --- a/configs/bayleybay_defconfig +++ b/configs/bayleybay_defconfig @@ -16,6 +16,7 @@ CONFIG_FIT=y CONFIG_BOOTSTAGE=y CONFIG_BOOTSTAGE_REPORT=y CONFIG_SYS_CONSOLE_INFO_QUIET=y +# CONFIG_ARCH_EARLY_INIT_R is not set CONFIG_HUSH_PARSER=y CONFIG_CMD_CPU=y # CONFIG_CMD_IMLS is not set diff --git a/configs/cougarcanyon2_defconfig b/configs/cougarcanyon2_defconfig index 233fe09a8e..ddd33a44f3 100644 --- a/configs/cougarcanyon2_defconfig +++ b/configs/cougarcanyon2_defconfig @@ -4,6 +4,7 @@ CONFIG_DEFAULT_DEVICE_TREE="cougarcanyon2" CONFIG_TARGET_COUGARCANYON2=y CONFIG_CONSOLE_MUX=y CONFIG_SYS_CONSOLE_INFO_QUIET=y +# CONFIG_ARCH_EARLY_INIT_R is not set CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/dfi-bt700-q7x-151_defconfig b/configs/dfi-bt700-q7x-151_defconfig index fc9c4f0b03..47e9f860e7 100644 --- a/configs/dfi-bt700-q7x-151_defconfig +++ b/configs/dfi-bt700-q7x-151_defconfig @@ -15,6 +15,7 @@ CONFIG_FIT_SIGNATURE=y CONFIG_BOOTSTAGE=y CONFIG_BOOTSTAGE_REPORT=y CONFIG_SYS_CONSOLE_INFO_QUIET=y +# CONFIG_ARCH_EARLY_INIT_R is not set CONFIG_HUSH_PARSER=y CONFIG_CMD_CPU=y # CONFIG_CMD_IMLS is not set diff --git a/configs/efi-x86_defconfig b/configs/efi-x86_defconfig index 1fe6142864..79f4df2a62 100644 --- a/configs/efi-x86_defconfig +++ b/configs/efi-x86_defconfig @@ -5,6 +5,7 @@ CONFIG_TARGET_EFI=y CONFIG_FIT=y CONFIG_CONSOLE_MUX=y CONFIG_SYS_CONSOLE_INFO_QUIET=y +# CONFIG_ARCH_EARLY_INIT_R is not set CONFIG_HUSH_PARSER=y # CONFIG_CMD_BOOTM is not set # CONFIG_CMD_IMLS is not set diff --git a/configs/minnowmax_defconfig b/configs/minnowmax_defconfig index b69e0fdae5..2589050b0a 100644 --- a/configs/minnowmax_defconfig +++ b/configs/minnowmax_defconfig @@ -16,6 +16,7 @@ CONFIG_FIT_SIGNATURE=y CONFIG_BOOTSTAGE=y CONFIG_BOOTSTAGE_REPORT=y CONFIG_SYS_CONSOLE_INFO_QUIET=y +CONFIG_ARCH_EARLY_INIT_R=y CONFIG_HUSH_PARSER=y CONFIG_CMD_CPU=y # CONFIG_CMD_IMLS is not set diff --git a/configs/mvebu_db-88f3720_defconfig b/configs/mvebu_db-88f3720_defconfig index a0665c5c09..337c4512c9 100644 --- a/configs/mvebu_db-88f3720_defconfig +++ b/configs/mvebu_db-88f3720_defconfig @@ -8,6 +8,7 @@ CONFIG_AHCI=y CONFIG_SYS_CONSOLE_INFO_QUIET=y # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_ARCH_EARLY_INIT_R=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_SF=y diff --git a/configs/mvebu_db-88f7040_defconfig b/configs/mvebu_db-88f7040_defconfig index 186923de6c..0ba00c2adf 100644 --- a/configs/mvebu_db-88f7040_defconfig +++ b/configs/mvebu_db-88f7040_defconfig @@ -10,6 +10,7 @@ CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_BOARD_LATE_INIT=y # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_ARCH_EARLY_INIT_R=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/mvebu_db-88f8040_defconfig b/configs/mvebu_db-88f8040_defconfig index 43e54ee978..f375f2c725 100644 --- a/configs/mvebu_db-88f8040_defconfig +++ b/configs/mvebu_db-88f8040_defconfig @@ -10,6 +10,7 @@ CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_BOARD_LATE_INIT=y # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_ARCH_EARLY_INIT_R=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/qemu-x86_efi_payload32_defconfig b/configs/qemu-x86_efi_payload32_defconfig index f580d4518d..0968689302 100644 --- a/configs/qemu-x86_efi_payload32_defconfig +++ b/configs/qemu-x86_efi_payload32_defconfig @@ -6,6 +6,7 @@ CONFIG_FIT=y CONFIG_BOOTSTAGE=y CONFIG_BOOTSTAGE_REPORT=y CONFIG_SYS_CONSOLE_INFO_QUIET=y +CONFIG_ARCH_EARLY_INIT_R=y CONFIG_HUSH_PARSER=y CONFIG_CMD_CPU=y # CONFIG_CMD_IMLS is not set diff --git a/configs/qemu-x86_efi_payload64_defconfig b/configs/qemu-x86_efi_payload64_defconfig index 975714b2fb..399bbdf6ee 100644 --- a/configs/qemu-x86_efi_payload64_defconfig +++ b/configs/qemu-x86_efi_payload64_defconfig @@ -6,6 +6,7 @@ CONFIG_FIT=y CONFIG_BOOTSTAGE=y CONFIG_BOOTSTAGE_REPORT=y CONFIG_SYS_CONSOLE_INFO_QUIET=y +CONFIG_ARCH_EARLY_INIT_R=y CONFIG_HUSH_PARSER=y CONFIG_CMD_CPU=y # CONFIG_CMD_BOOTEFI_HELLO_COMPILE is not set diff --git a/configs/rut_defconfig b/configs/rut_defconfig index b903ee4efb..7c9590f7d0 100644 --- a/configs/rut_defconfig +++ b/configs/rut_defconfig @@ -23,6 +23,7 @@ CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_BOARD_LATE_INIT=y # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_ARCH_EARLY_INIT_R=y CONFIG_SPL=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 diff --git a/configs/theadorable-x86-dfi-bt700_defconfig b/configs/theadorable-x86-dfi-bt700_defconfig index ed0b277b27..959b2f5d19 100644 --- a/configs/theadorable-x86-dfi-bt700_defconfig +++ b/configs/theadorable-x86-dfi-bt700_defconfig @@ -15,6 +15,7 @@ CONFIG_FIT_SIGNATURE=y CONFIG_BOOTSTAGE=y CONFIG_BOOTSTAGE_REPORT=y CONFIG_SYS_CONSOLE_INFO_QUIET=y +# CONFIG_ARCH_EARLY_INIT_R is not set CONFIG_HUSH_PARSER=y CONFIG_CMD_CPU=y # CONFIG_CMD_IMLS is not set diff --git a/include/configs/conga-qeval20-qa3-e3845.h b/include/configs/conga-qeval20-qa3-e3845.h index 309ff4f8c6..9a71dda54c 100644 --- a/include/configs/conga-qeval20-qa3-e3845.h +++ b/include/configs/conga-qeval20-qa3-e3845.h @@ -15,7 +15,6 @@
#define CONFIG_SYS_MONITOR_LEN (1 << 20) #define CONFIG_BOARD_EARLY_INIT_F -#define CONFIG_ARCH_EARLY_INIT_R #define CONFIG_ARCH_MISC_INIT
#define CONFIG_STD_DEVICES_SETTINGS "stdin=serial\0" \ diff --git a/include/configs/crownbay.h b/include/configs/crownbay.h index cef2fd72db..506b22790e 100644 --- a/include/configs/crownbay.h +++ b/include/configs/crownbay.h @@ -15,7 +15,6 @@
#define CONFIG_SMSC_LPC47M
diff --git a/include/configs/galileo.h b/include/configs/galileo.h index 26eb12774c..360f379728 100644 --- a/include/configs/galileo.h +++ b/include/configs/galileo.h @@ -15,7 +15,6 @@
/* ns16550 UART is memory-mapped in Quark SoC */ diff --git a/include/configs/ls1012a_common.h b/include/configs/ls1012a_common.h index 910835e03f..eddfa1493e 100644 --- a/include/configs/ls1012a_common.h +++ b/include/configs/ls1012a_common.h @@ -89,8 +89,6 @@ #define CONFIG_CMD_ENV #undef CONFIG_CMD_IMLS
-#define CONFIG_ARCH_EARLY_INIT_R - #define CONFIG_SYS_HZ 1000
#define CONFIG_HWCONFIG diff --git a/include/configs/ls1043a_common.h b/include/configs/ls1043a_common.h index 0d744eea92..66805c2d7a 100644 --- a/include/configs/ls1043a_common.h +++ b/include/configs/ls1043a_common.h @@ -185,7 +185,6 @@
/* Miscellaneous configurable options */ #define CONFIG_SYS_LOAD_ADDR (CONFIG_SYS_DDR_SDRAM_BASE + 0x10000000) -#define CONFIG_ARCH_EARLY_INIT_R
#define CONFIG_HWCONFIG #define HWCONFIG_BUFFER_SIZE 128 diff --git a/include/configs/ls1046a_common.h b/include/configs/ls1046a_common.h index 7c8a2467ce..5ac89380e5 100644 --- a/include/configs/ls1046a_common.h +++ b/include/configs/ls1046a_common.h @@ -158,7 +158,6 @@
#define CONFIG_HWCONFIG #define HWCONFIG_BUFFER_SIZE 128 diff --git a/include/configs/ls2080a_common.h b/include/configs/ls2080a_common.h index 32d56aede2..99c0661b90 100644 --- a/include/configs/ls2080a_common.h +++ b/include/configs/ls2080a_common.h @@ -175,7 +175,6 @@ unsigned long long get_qixis_addr(void);
/* Physical Memory Map */ /* fixme: these need to be checked against the board */ diff --git a/include/configs/minnowmax.h b/include/configs/minnowmax.h index 5b17fd7f2c..3507cc8996 100644 --- a/include/configs/minnowmax.h +++ b/include/configs/minnowmax.h @@ -14,7 +14,6 @@ #include <configs/x86-common.h>
#define CONFIG_SYS_MONITOR_LEN (1 << 20) -#define CONFIG_ARCH_EARLY_INIT_R #define CONFIG_ARCH_MISC_INIT
#define CONFIG_SMSC_LPC47M diff --git a/include/configs/mvebu_armada-8k.h b/include/configs/mvebu_armada-8k.h index 0055cb02d3..fd185321d1 100644 --- a/include/configs/mvebu_armada-8k.h +++ b/include/configs/mvebu_armada-8k.h @@ -13,7 +13,6 @@ #define CONFIG_SYS_TCLK 250000000 /* 250MHz */
#define CONFIG_DISPLAY_BOARDINFO_LATE -#define CONFIG_ARCH_EARLY_INIT_R
#define CONFIG_SYS_TEXT_BASE 0x00000000
diff --git a/include/configs/mvebu_db-88f3720.h b/include/configs/mvebu_db-88f3720.h index 7ddde8cb71..7fc3dcc790 100644 --- a/include/configs/mvebu_db-88f3720.h +++ b/include/configs/mvebu_db-88f3720.h @@ -11,7 +11,6 @@ * High Level Configuration Options (easy to change) */ #define CONFIG_DISPLAY_BOARDINFO_LATE -#define CONFIG_ARCH_EARLY_INIT_R
diff --git a/include/configs/qemu-x86.h b/include/configs/qemu-x86.h index 4783563fc7..affe712e04 100644 --- a/include/configs/qemu-x86.h +++ b/include/configs/qemu-x86.h @@ -14,7 +14,6 @@ #include <configs/x86-common.h>
#define CONFIG_STD_DEVICES_SETTINGS "stdin=serial,i8042-kbd\0" \ "stdout=serial,vidconsole\0" \ diff --git a/include/configs/rut.h b/include/configs/rut.h index e5933b85ee..36de45453f 100644 --- a/include/configs/rut.h +++ b/include/configs/rut.h @@ -130,7 +130,6 @@ #define CONFIG_OMAP3_SPI
#define BOARD_LCD_RESET 115 /* Bank 3 pin 19 */ -#define CONFIG_ARCH_EARLY_INIT_R #define CONFIG_FORMIKE #define DISPL_PLL_SPREAD_SPECTRUM #endif diff --git a/include/configs/socfpga_common.h b/include/configs/socfpga_common.h index 6285266a1b..4559138f60 100644 --- a/include/configs/socfpga_common.h +++ b/include/configs/socfpga_common.h @@ -16,7 +16,6 @@ */ #define CONFIG_DISPLAY_BOARDINFO_LATE #define CONFIG_ARCH_MISC_INIT -#define CONFIG_ARCH_EARLY_INIT_R #define CONFIG_SYS_NO_FLASH #define CONFIG_CLOCKS
diff --git a/include/configs/som-6896.h b/include/configs/som-6896.h index b4a4fb01d4..ba11b2061a 100644 --- a/include/configs/som-6896.h +++ b/include/configs/som-6896.h @@ -23,8 +23,6 @@ #define VIDEO_IO_OFFSET 0 #define CONFIG_X86EMU_RAW_IO
-#define CONFIG_ARCH_EARLY_INIT_R - #define CONFIG_STD_DEVICES_SETTINGS "stdin=serial,usbkbd\0" \ "stdout=serial,vidconsole\0" \ "stderr=serial,vidconsole\0" diff --git a/include/configs/som-db5800-som-6867.h b/include/configs/som-db5800-som-6867.h index 6235518bed..e13f343751 100644 --- a/include/configs/som-db5800-som-6867.h +++ b/include/configs/som-db5800-som-6867.h @@ -15,7 +15,6 @@
#define CONFIG_STD_DEVICES_SETTINGS "stdin=serial,usbkbd\0" \ diff --git a/include/configs/x86-chromebook.h b/include/configs/x86-chromebook.h index 46a11ef7e4..545cffbfaa 100644 --- a/include/configs/x86-chromebook.h +++ b/include/configs/x86-chromebook.h @@ -40,8 +40,6 @@ #define VIDEO_IO_OFFSET 0 #define CONFIG_X86EMU_RAW_IO
-#define CONFIG_ARCH_EARLY_INIT_R - #undef CONFIG_ENV_IS_NOWHERE #undef CONFIG_ENV_SIZE #define CONFIG_ENV_SIZE 0x1000 diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index a927e5019c..23ebcc63c4 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -109,7 +109,6 @@ CONFIG_AP_SH4A_4A CONFIG_ARCH_ADPAG101P CONFIG_ARCH_CPU_INIT CONFIG_ARCH_CSB226 -CONFIG_ARCH_EARLY_INIT_R CONFIG_ARCH_HAS_ILOG2_U32 CONFIG_ARCH_HAS_ILOG2_U64 CONFIG_ARCH_INNOKOM
Hi Simon, Tom.
2017-01-24 5:31 GMT+09:00 Simon Glass sjg@chromium.org:
I have some questions
[1] Is this a user-configurable symbol?
You use "select" in some places, but add it in defconfig in others.
This is controlling whether arch_early_init_r() is called from common/board_r.c or not, right?
Does it make sense to skip the init function if users want to?
Maybe, Tom will end up with converting all of them to "select" like this? http://patchwork.ozlabs.org/patch/718315/
[2] How painful is it to use __weak function instead of CONFIG_ARCH_EARLY_INIT_R
[3] We have board_early_init_r() for board-specific init procedure.
From its function name, I thought arch_early_init_r() is
called for arch-specific (ARC, ARM, x86) init. In fact, it is not. ARC is good. For ARM, x86, it is abused for board specific init.
For example,
board/siemens/rut/board.c
int arch_early_init_r(void) { enable_lcd(); return 0; }
This is apparently board_init, not arch_init.
On Tue, Jan 24, 2017 at 11:36:11AM +0900, Masahiro Yamada wrote:
Hi Simon, Tom.
I will probably end up moving this to all select iff it ends up with no size change.
For something that's only in U-Boot proper? Probably not bad, but a follow-up.
[3] We have board_early_init_r() for board-specific init procedure. From its function name, I thought arch_early_init_r() is called for arch-specific (ARC, ARM, x86) init. In fact, it is not. ARC is good. For ARM, x86, it is abused for board specific init.
For example,
This is indeed problematic and partly why moving this to 'select' isn't trivial as some of the locations of the functions make it unclear enough if the right answer isn't instead to move this elsewhere. My first guess is that on 'rut' the LCD needs to be visible asap for the "it's alive!" factor.
This converts the following to Kconfig: CONFIG_BOARD_EARLY_INIT_F
arch/arm/Kconfig | 27 ++++++++++++++++++++++ arch/arm/cpu/armv7/mx6/Kconfig | 4 ++++ arch/arm/cpu/armv8/fsl-layerscape/Kconfig | 4 ++++ arch/arm/mach-at91/Kconfig | 18 +++++++++++++++ arch/arm/mach-exynos/Kconfig | 3 +++ arch/arm/mach-mvebu/Kconfig | 1 + arch/arm/mach-tegra/Kconfig | 1 + arch/powerpc/cpu/mpc83xx/Kconfig | 6 +++++ arch/powerpc/cpu/mpc85xx/Kconfig | 2 ++ arch/powerpc/cpu/mpc86xx/Kconfig | 2 ++ common/Kconfig | 10 ++++++++ configs/CPCI2DP_defconfig | 1 + configs/CPCI4052_defconfig | 1 + configs/Cyrus_P5020_defconfig | 1 + configs/Cyrus_P5040_defconfig | 1 + configs/MIP405T_defconfig | 1 + configs/MIP405_defconfig | 1 + configs/MPC8536DS_36BIT_defconfig | 1 + configs/MPC8536DS_SDCARD_defconfig | 1 + configs/MPC8536DS_SPIFLASH_defconfig | 1 + configs/MPC8536DS_defconfig | 1 + configs/MPC8568MDS_defconfig | 1 + configs/MPC8569MDS_ATM_defconfig | 1 + configs/MPC8569MDS_defconfig | 1 + configs/P1010RDB-PA_36BIT_NAND_SECBOOT_defconfig | 1 + configs/P1010RDB-PA_36BIT_NAND_defconfig | 1 + configs/P1010RDB-PA_36BIT_NOR_SECBOOT_defconfig | 1 + configs/P1010RDB-PA_36BIT_NOR_defconfig | 1 + configs/P1010RDB-PA_36BIT_SDCARD_defconfig | 1 + .../P1010RDB-PA_36BIT_SPIFLASH_SECBOOT_defconfig | 1 + configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig | 1 + configs/P1010RDB-PA_NAND_SECBOOT_defconfig | 1 + configs/P1010RDB-PA_NAND_defconfig | 1 + configs/P1010RDB-PA_NOR_SECBOOT_defconfig | 1 + configs/P1010RDB-PA_NOR_defconfig | 1 + configs/P1010RDB-PA_SDCARD_defconfig | 1 + configs/P1010RDB-PA_SPIFLASH_SECBOOT_defconfig | 1 + configs/P1010RDB-PA_SPIFLASH_defconfig | 1 + configs/P1010RDB-PB_36BIT_NAND_SECBOOT_defconfig | 1 + configs/P1010RDB-PB_36BIT_NAND_defconfig | 1 + configs/P1010RDB-PB_36BIT_NOR_SECBOOT_defconfig | 1 + configs/P1010RDB-PB_36BIT_NOR_defconfig | 1 + configs/P1010RDB-PB_36BIT_SDCARD_defconfig | 1 + .../P1010RDB-PB_36BIT_SPIFLASH_SECBOOT_defconfig | 1 + configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig | 1 + configs/P1010RDB-PB_NAND_SECBOOT_defconfig | 1 + configs/P1010RDB-PB_NAND_defconfig | 1 + configs/P1010RDB-PB_NOR_SECBOOT_defconfig | 1 + configs/P1010RDB-PB_NOR_defconfig | 1 + configs/P1010RDB-PB_SDCARD_defconfig | 1 + configs/P1010RDB-PB_SPIFLASH_SECBOOT_defconfig | 1 + configs/P1010RDB-PB_SPIFLASH_defconfig | 1 + configs/P1020MBG-PC_36BIT_SDCARD_defconfig | 1 + configs/P1020MBG-PC_36BIT_defconfig | 1 + configs/P1020MBG-PC_SDCARD_defconfig | 1 + configs/P1020MBG-PC_defconfig | 1 + configs/P1020RDB-PC_36BIT_NAND_defconfig | 1 + configs/P1020RDB-PC_36BIT_SDCARD_defconfig | 1 + configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig | 1 + configs/P1020RDB-PC_36BIT_defconfig | 1 + configs/P1020RDB-PC_NAND_defconfig | 1 + configs/P1020RDB-PC_SDCARD_defconfig | 1 + configs/P1020RDB-PC_SPIFLASH_defconfig | 1 + configs/P1020RDB-PC_defconfig | 1 + configs/P1020RDB-PD_NAND_defconfig | 1 + configs/P1020RDB-PD_SDCARD_defconfig | 1 + configs/P1020RDB-PD_SPIFLASH_defconfig | 1 + configs/P1020RDB-PD_defconfig | 1 + configs/P1020UTM-PC_36BIT_SDCARD_defconfig | 1 + configs/P1020UTM-PC_36BIT_defconfig | 1 + configs/P1020UTM-PC_SDCARD_defconfig | 1 + configs/P1020UTM-PC_defconfig | 1 + configs/P1021RDB-PC_36BIT_NAND_defconfig | 1 + configs/P1021RDB-PC_36BIT_SDCARD_defconfig | 1 + configs/P1021RDB-PC_36BIT_SPIFLASH_defconfig | 1 + configs/P1021RDB-PC_36BIT_defconfig | 1 + configs/P1021RDB-PC_NAND_defconfig | 1 + configs/P1021RDB-PC_SDCARD_defconfig | 1 + configs/P1021RDB-PC_SPIFLASH_defconfig | 1 + configs/P1021RDB-PC_defconfig | 1 + configs/P1022DS_36BIT_NAND_defconfig | 1 + configs/P1022DS_36BIT_SDCARD_defconfig | 1 + configs/P1022DS_36BIT_SPIFLASH_defconfig | 1 + configs/P1022DS_36BIT_defconfig | 1 + configs/P1022DS_NAND_defconfig | 1 + configs/P1022DS_SDCARD_defconfig | 1 + configs/P1022DS_SPIFLASH_defconfig | 1 + configs/P1022DS_defconfig | 1 + configs/P1023RDB_defconfig | 1 + configs/P1024RDB_36BIT_defconfig | 1 + configs/P1024RDB_NAND_defconfig | 1 + configs/P1024RDB_SDCARD_defconfig | 1 + configs/P1024RDB_SPIFLASH_defconfig | 1 + configs/P1024RDB_defconfig | 1 + configs/P1025RDB_36BIT_defconfig | 1 + configs/P1025RDB_NAND_defconfig | 1 + configs/P1025RDB_SDCARD_defconfig | 1 + configs/P1025RDB_SPIFLASH_defconfig | 1 + configs/P1025RDB_defconfig | 1 + configs/P2020RDB-PC_36BIT_NAND_defconfig | 1 + configs/P2020RDB-PC_36BIT_SDCARD_defconfig | 1 + configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig | 1 + configs/P2020RDB-PC_36BIT_defconfig | 1 + configs/P2020RDB-PC_NAND_defconfig | 1 + configs/P2020RDB-PC_SDCARD_defconfig | 1 + configs/P2020RDB-PC_SPIFLASH_defconfig | 1 + configs/P2020RDB-PC_defconfig | 1 + configs/P2041RDB_NAND_defconfig | 1 + configs/P2041RDB_SDCARD_defconfig | 1 + configs/P2041RDB_SECURE_BOOT_defconfig | 1 + configs/P2041RDB_SPIFLASH_defconfig | 1 + configs/P2041RDB_SRIO_PCIE_BOOT_defconfig | 1 + configs/P2041RDB_defconfig | 1 + configs/P3041DS_NAND_SECURE_BOOT_defconfig | 1 + configs/P3041DS_NAND_defconfig | 1 + configs/P3041DS_SDCARD_defconfig | 1 + configs/P3041DS_SECURE_BOOT_defconfig | 1 + configs/P3041DS_SPIFLASH_defconfig | 1 + configs/P3041DS_SRIO_PCIE_BOOT_defconfig | 1 + configs/P3041DS_defconfig | 1 + configs/P4080DS_SDCARD_defconfig | 1 + configs/P4080DS_SECURE_BOOT_defconfig | 1 + configs/P4080DS_SPIFLASH_defconfig | 1 + configs/P4080DS_SRIO_PCIE_BOOT_defconfig | 1 + configs/P4080DS_defconfig | 1 + configs/P5020DS_NAND_SECURE_BOOT_defconfig | 1 + configs/P5020DS_NAND_defconfig | 1 + configs/P5020DS_SDCARD_defconfig | 1 + configs/P5020DS_SECURE_BOOT_defconfig | 1 + configs/P5020DS_SPIFLASH_defconfig | 1 + configs/P5020DS_SRIO_PCIE_BOOT_defconfig | 1 + configs/P5020DS_defconfig | 1 + configs/P5040DS_NAND_SECURE_BOOT_defconfig | 1 + configs/P5040DS_NAND_defconfig | 1 + configs/P5040DS_SDCARD_defconfig | 1 + configs/P5040DS_SECURE_BOOT_defconfig | 1 + configs/P5040DS_SPIFLASH_defconfig | 1 + configs/P5040DS_defconfig | 1 + configs/PATI_defconfig | 1 + configs/PIP405_defconfig | 1 + configs/PLU405_defconfig | 1 + configs/PMC405DE_defconfig | 1 + configs/PMC440_defconfig | 1 + configs/T1024QDS_DDR4_SECURE_BOOT_defconfig | 1 + configs/T1024QDS_DDR4_defconfig | 1 + configs/T1024QDS_NAND_defconfig | 1 + configs/T1024QDS_SDCARD_defconfig | 1 + configs/T1024QDS_SECURE_BOOT_defconfig | 1 + configs/T1024QDS_SPIFLASH_defconfig | 1 + configs/T1024QDS_defconfig | 1 + configs/T1024RDB_NAND_defconfig | 1 + configs/T1024RDB_SDCARD_defconfig | 1 + configs/T1024RDB_SECURE_BOOT_defconfig | 1 + configs/T1024RDB_SPIFLASH_defconfig | 1 + configs/T1024RDB_defconfig | 1 + configs/T1040D4RDB_NAND_defconfig | 1 + configs/T1040D4RDB_SDCARD_defconfig | 1 + configs/T1040D4RDB_SECURE_BOOT_defconfig | 1 + configs/T1040D4RDB_SPIFLASH_defconfig | 1 + configs/T1040D4RDB_defconfig | 1 + configs/T1040QDS_DDR4_defconfig | 1 + configs/T1040QDS_SECURE_BOOT_defconfig | 1 + configs/T1040QDS_defconfig | 1 + configs/T1040RDB_NAND_defconfig | 1 + configs/T1040RDB_SDCARD_defconfig | 1 + configs/T1040RDB_SECURE_BOOT_defconfig | 1 + configs/T1040RDB_SPIFLASH_defconfig | 1 + configs/T1040RDB_defconfig | 1 + configs/T1042D4RDB_NAND_defconfig | 1 + configs/T1042D4RDB_SDCARD_defconfig | 1 + configs/T1042D4RDB_SECURE_BOOT_defconfig | 1 + configs/T1042D4RDB_SPIFLASH_defconfig | 1 + configs/T1042D4RDB_defconfig | 1 + configs/T1042RDB_PI_NAND_SECURE_BOOT_defconfig | 1 + configs/T1042RDB_PI_NAND_defconfig | 1 + configs/T1042RDB_PI_SDCARD_defconfig | 1 + configs/T1042RDB_PI_SPIFLASH_defconfig | 1 + configs/T1042RDB_PI_defconfig | 1 + configs/T1042RDB_SECURE_BOOT_defconfig | 1 + configs/T1042RDB_defconfig | 1 + configs/TWR-P1025_defconfig | 1 + configs/UCP1020_SPIFLASH_defconfig | 1 + configs/UCP1020_defconfig | 1 + configs/VOM405_defconfig | 1 + configs/acadia_defconfig | 1 + configs/am335x_evm_norboot_defconfig | 1 + configs/am43xx_evm_qspiboot_defconfig | 1 + configs/am57xx_evm_defconfig | 1 + configs/am57xx_evm_nodt_defconfig | 1 + configs/am57xx_hs_evm_defconfig | 1 + configs/ap121_defconfig | 1 + configs/ap143_defconfig | 1 + configs/apalis_imx6_defconfig | 1 + configs/apalis_imx6_nospl_com_defconfig | 1 + configs/apalis_imx6_nospl_it_defconfig | 1 + configs/apx4devkit_defconfig | 1 + configs/arches_defconfig | 1 + configs/aristainetos2_defconfig | 1 + configs/aristainetos2b_defconfig | 1 + configs/aristainetos_defconfig | 1 + configs/aspenite_defconfig | 1 + configs/at91rm9200ek_defconfig | 1 + configs/at91rm9200ek_ram_defconfig | 1 + configs/atngw100_defconfig | 1 + configs/atngw100mkii_defconfig | 1 + configs/atstk1002_defconfig | 1 + configs/axm_defconfig | 1 + configs/axs101_defconfig | 1 + configs/axs103_defconfig | 1 + configs/bamboo_defconfig | 1 + configs/bayleybay_defconfig | 1 + configs/bf506f-ezkit_defconfig | 1 + configs/bf518f-ezbrd_defconfig | 1 + configs/bf548-ezkit_defconfig | 1 + configs/bf609-ezkit_defconfig | 1 + configs/bg0900_defconfig | 1 + configs/bk4r1_defconfig | 1 + configs/bubinga_defconfig | 1 + configs/canyonlands_defconfig | 1 + configs/cgtqmx6eval_defconfig | 1 + configs/cm-bf548_defconfig | 1 + configs/colibri_imx6_defconfig | 1 + configs/colibri_imx6_nospl_defconfig | 1 + configs/colibri_vf_defconfig | 1 + .../controlcenterd_36BIT_SDCARD_DEVELOP_defconfig | 1 + configs/controlcenterd_36BIT_SDCARD_defconfig | 1 + .../controlcenterd_TRAILBLAZER_DEVELOP_defconfig | 1 + configs/controlcenterd_TRAILBLAZER_defconfig | 1 + configs/coreboot-x86_defconfig | 1 + configs/corvus_defconfig | 1 + configs/da850_am18xxevm_defconfig | 1 + configs/da850evm_defconfig | 1 + configs/da850evm_direct_nor_defconfig | 1 + configs/devconcenter_defconfig | 1 + configs/devkit3250_defconfig | 1 + configs/dlvision-10g_defconfig | 1 + configs/dlvision_defconfig | 1 + configs/dms-ba16-1g_defconfig | 1 + configs/dms-ba16_defconfig | 1 + configs/dra7xx_evm_defconfig | 1 + configs/dra7xx_hs_evm_defconfig | 1 + configs/ea20_defconfig | 1 + configs/edb9315a_defconfig | 1 + configs/efi-x86_defconfig | 1 + configs/flea3_defconfig | 1 + configs/fo300_defconfig | 1 + configs/gdppc440etx_defconfig | 1 + configs/ge_b450v3_defconfig | 1 + configs/ge_b650v3_defconfig | 1 + configs/ge_b850v3_defconfig | 1 + configs/glacier_defconfig | 1 + configs/glacier_ramboot_defconfig | 1 + configs/gplugd_defconfig | 1 + configs/grasshopper_defconfig | 1 + configs/gurnard_defconfig | 1 + configs/gwventana_defconfig | 1 + configs/haleakala_defconfig | 1 + configs/hikey_defconfig | 1 + configs/hrcon_defconfig | 1 + configs/hrcon_dh_defconfig | 1 + configs/icon_defconfig | 1 + configs/intip_defconfig | 1 + configs/io64_defconfig | 1 + configs/io_defconfig | 1 + configs/iocon_defconfig | 1 + configs/ipam390_defconfig | 1 + configs/jupiter_defconfig | 1 + configs/k2e_evm_defconfig | 1 + configs/k2g_evm_defconfig | 1 + configs/k2hk_evm_defconfig | 1 + configs/k2l_evm_defconfig | 1 + configs/katmai_defconfig | 1 + configs/kilauea_defconfig | 1 + configs/kmcoge4_defconfig | 1 + configs/kmlion1_defconfig | 1 + configs/legoev3_defconfig | 1 + configs/liteboard_defconfig | 1 + configs/ls1021aiot_qspi_defconfig | 1 + configs/ls1021aiot_sdcard_defconfig | 1 + configs/luan_defconfig | 1 + configs/lwmon5_defconfig | 1 + configs/m28evk_defconfig | 1 + configs/ma5d4evk_defconfig | 1 + configs/makalu_defconfig | 1 + configs/malta64_defconfig | 1 + configs/malta64el_defconfig | 1 + configs/malta_defconfig | 1 + configs/maltael_defconfig | 1 + configs/marsboard_defconfig | 1 + configs/mecp5123_defconfig | 1 + configs/meesc_dataflash_defconfig | 1 + configs/meesc_defconfig | 1 + configs/minnowmax_defconfig | 2 +- configs/mpc5121ads_defconfig | 1 + configs/mpc5121ads_rev2_defconfig | 1 + configs/mvebu_db-88f3720_defconfig | 1 + configs/mvebu_db-88f7040_defconfig | 1 + configs/mvebu_db-88f8040_defconfig | 1 + configs/mx35pdk_defconfig | 1 + configs/mx6cuboxi_defconfig | 1 + configs/mx6dlarm2_defconfig | 1 + configs/mx6dlarm2_lpddr2_defconfig | 1 + configs/mx6qarm2_defconfig | 1 + configs/mx6qarm2_lpddr2_defconfig | 1 + configs/mx6qsabrelite_defconfig | 1 + configs/mx6slevk_defconfig | 1 + configs/mx6slevk_spinor_defconfig | 1 + configs/mx6slevk_spl_defconfig | 1 + configs/mx6sllevk_defconfig | 1 + configs/mx6sllevk_plugin_defconfig | 1 + configs/mx6ul_14x14_evk_defconfig | 1 + configs/mx6ul_9x9_evk_defconfig | 1 + configs/mx6ull_14x14_evk_defconfig | 1 + configs/mx6ull_14x14_evk_plugin_defconfig | 1 + configs/neo_defconfig | 1 + configs/nitrogen6dl2g_defconfig | 1 + configs/nitrogen6dl_defconfig | 1 + configs/nitrogen6q2g_defconfig | 1 + configs/nitrogen6q_defconfig | 1 + configs/nitrogen6s1g_defconfig | 1 + configs/nitrogen6s_defconfig | 1 + configs/novena_defconfig | 1 + configs/omapl138_lcdk_defconfig | 1 + configs/ot1200_defconfig | 1 + configs/ot1200_spl_defconfig | 1 + configs/pcm052_defconfig | 1 + configs/pcm058_defconfig | 1 + configs/pico-imx6ul_defconfig | 1 + configs/picosam9g45_defconfig | 1 + configs/platinum_picon_defconfig | 1 + configs/platinum_titanium_defconfig | 1 + configs/pm9261_defconfig | 1 + configs/pm9263_defconfig | 1 + configs/pm9g45_defconfig | 1 + configs/qemu-ppce500_defconfig | 1 + configs/qemu-x86_defconfig | 1 + configs/qemu-x86_efi_payload32_defconfig | 2 +- configs/qemu-x86_efi_payload64_defconfig | 2 +- configs/rainier_defconfig | 1 + configs/rainier_ramboot_defconfig | 1 + configs/redwood_defconfig | 1 + configs/riotboard_defconfig | 1 + configs/s32v234evb_defconfig | 1 + configs/sansa_fuze_plus_defconfig | 1 + configs/sbc8548_PCI_33_PCIE_defconfig | 1 + configs/sbc8548_PCI_33_defconfig | 1 + configs/sbc8548_PCI_66_PCIE_defconfig | 1 + configs/sbc8548_PCI_66_defconfig | 1 + configs/sbc8548_defconfig | 1 + configs/sc_sps_1_defconfig | 1 + configs/secomx6quq7_defconfig | 1 + configs/sequoia_defconfig | 1 + configs/sequoia_ramboot_defconfig | 1 + configs/smartweb_defconfig | 1 + configs/socfpga_sr1500_defconfig | 1 + configs/stm32f429-discovery_defconfig | 1 + configs/stm32f746-disco_defconfig | 1 + configs/strider_con_defconfig | 1 + configs/strider_con_dp_defconfig | 1 + configs/strider_cpu_defconfig | 1 + configs/strider_cpu_dp_defconfig | 1 + configs/stv0991_defconfig | 1 + configs/sycamore_defconfig | 1 + configs/t3corp_defconfig | 1 + configs/taurus_defconfig | 1 + configs/tbs2910_defconfig | 1 + configs/titanium_defconfig | 1 + configs/tplink_wdr4300_defconfig | 1 + configs/tqma6q_mba6_mmc_defconfig | 1 + configs/tqma6q_mba6_spi_defconfig | 1 + configs/tqma6s_mba6_mmc_defconfig | 1 + configs/tqma6s_mba6_spi_defconfig | 1 + configs/tqma6s_wru4_mmc_defconfig | 1 + configs/ts4600_defconfig | 1 + configs/ts4800_defconfig | 1 + configs/udoo_defconfig | 1 + configs/udoo_neo_defconfig | 1 + configs/v38b_defconfig | 1 + configs/ve8313_defconfig | 1 + configs/vf610twr_defconfig | 1 + configs/vf610twr_nand_defconfig | 1 + configs/vinco_defconfig | 1 + configs/vining_2000_defconfig | 1 + configs/walnut_defconfig | 1 + configs/wandboard_defconfig | 1 + configs/warp_defconfig | 1 + configs/woodburn_defconfig | 1 + configs/work_92105_defconfig | 1 + configs/xfi3_defconfig | 1 + configs/xpedite1000_defconfig | 1 + configs/xpress_defconfig | 1 + configs/xpress_spl_defconfig | 1 + configs/yellowstone_defconfig | 1 + configs/yosemite_defconfig | 1 + configs/yucca_defconfig | 1 + configs/zc5202_defconfig | 1 + configs/zc5601_defconfig | 1 + include/configs/BSC9131RDB.h | 2 -- include/configs/BSC9132QDS.h | 1 - include/configs/CPCI2DP.h | 2 -- include/configs/CPCI4052.h | 1 - include/configs/MIP405.h | 1 - include/configs/MPC8313ERDB.h | 1 - include/configs/MPC8315ERDB.h | 1 - include/configs/MPC832XEMDS.h | 1 - include/configs/MPC8349EMDS.h | 2 -- include/configs/MPC837XEMDS.h | 1 - include/configs/MPC837XERDB.h | 1 - include/configs/MPC8536DS.h | 2 -- include/configs/MPC8568MDS.h | 2 -- include/configs/MPC8569MDS.h | 1 - include/configs/MPC8610HPCD.h | 1 - include/configs/P1010RDB.h | 1 - include/configs/P1022DS.h | 1 - include/configs/P1023RDB.h | 1 - include/configs/P2041RDB.h | 1 - include/configs/PATI.h | 2 -- include/configs/PIP405.h | 3 --- include/configs/PLU405.h | 1 - include/configs/PMC405DE.h | 1 - include/configs/PMC440.h | 1 - include/configs/T102xQDS.h | 3 --- include/configs/T102xRDB.h | 3 --- include/configs/T1040QDS.h | 3 --- include/configs/T104xRDB.h | 3 --- include/configs/TQM5200.h | 1 - include/configs/TQM834x.h | 1 - include/configs/UCP1020.h | 2 -- include/configs/VOM405.h | 1 - include/configs/acadia.h | 1 - include/configs/advantech_dms-ba16.h | 2 -- include/configs/am43xx_evm.h | 3 --- include/configs/am57xx_evm.h | 2 -- include/configs/ap121.h | 2 -- include/configs/ap143.h | 2 -- include/configs/apalis_imx6.h | 1 - include/configs/aristainetos-common.h | 2 -- include/configs/armadillo-800eva.h | 1 - include/configs/at91-sama5_common.h | 2 -- include/configs/at91rm9200ek.h | 2 -- include/configs/at91sam9260ek.h | 1 - include/configs/at91sam9263ek.h | 2 -- include/configs/at91sam9m10g45ek.h | 1 - include/configs/at91sam9n12ek.h | 1 - include/configs/at91sam9rlek.h | 1 - include/configs/at91sam9x5ek.h | 1 - include/configs/atngw100.h | 1 - include/configs/atngw100mkii.h | 1 - include/configs/atstk1002.h | 1 - include/configs/axs10x.h | 1 - include/configs/bamboo.h | 2 -- include/configs/bf506f-ezkit.h | 1 - include/configs/bf518f-ezbrd.h | 1 - include/configs/bf548-ezkit.h | 1 - include/configs/bf609-ezkit.h | 1 - include/configs/bubinga.h | 2 -- include/configs/canyonlands.h | 1 - include/configs/cgtqmx6eval.h | 1 - include/configs/cm-bf548.h | 1 - include/configs/colibri_imx6.h | 1 - include/configs/colibri_imx7.h | 1 - include/configs/colibri_vf.h | 2 -- include/configs/conga-qeval20-qa3-e3845.h | 1 - include/configs/controlcenterd.h | 2 -- include/configs/corenet_ds.h | 1 - include/configs/corvus.h | 1 - include/configs/cougarcanyon2.h | 1 - include/configs/crownbay.h | 1 - include/configs/cyrus.h | 1 - include/configs/da850evm.h | 1 - include/configs/devkit3250.h | 1 - include/configs/dfi-bt700.h | 1 - include/configs/dlvision-10g.h | 1 - include/configs/dlvision.h | 1 - include/configs/dra7xx_evm.h | 1 - include/configs/ea20.h | 1 - include/configs/edb93xx.h | 2 -- include/configs/el6x_common.h | 2 -- include/configs/embestmx6boards.h | 2 -- include/configs/exynos-common.h | 1 - include/configs/exynos7420-common.h | 1 - include/configs/flea3.h | 1 - include/configs/galileo.h | 1 - include/configs/gdppc440etx.h | 1 - include/configs/ge_bx50v3.h | 2 -- include/configs/grasshopper.h | 1 - include/configs/gw_ventana.h | 1 - include/configs/hikey.h | 2 -- include/configs/hrcon.h | 1 - include/configs/icon.h | 1 - include/configs/imx31_phycore.h | 1 - include/configs/intip.h | 1 - include/configs/io.h | 1 - include/configs/io64.h | 1 - include/configs/iocon.h | 1 - include/configs/ipam390.h | 1 - include/configs/jupiter.h | 1 - include/configs/katmai.h | 1 - include/configs/kilauea.h | 1 - include/configs/km/km_arm.h | 1 - include/configs/km/kmp204x-common.h | 1 - include/configs/kzm9g.h | 1 - include/configs/legoev3.h | 1 - include/configs/liteboard.h | 2 -- include/configs/ls1012a_common.h | 1 - include/configs/ls1021aiot.h | 2 -- include/configs/ls1021aqds.h | 1 - include/configs/ls1021atwr.h | 1 - include/configs/ls1043a_common.h | 1 - include/configs/ls1046a_common.h | 1 - include/configs/ls2080a_common.h | 1 - include/configs/luan.h | 1 - include/configs/lwmon5.h | 1 - include/configs/m53evk.h | 1 - include/configs/makalu.h | 1 - include/configs/malta.h | 1 - include/configs/mecp5123.h | 1 - include/configs/meesc.h | 1 - include/configs/mpc5121ads.h | 1 - include/configs/mv-common.h | 1 - include/configs/mvebu_armada-8k.h | 1 - include/configs/mvebu_db-88f3720.h | 1 - include/configs/mx25pdk.h | 2 -- include/configs/mx31ads.h | 1 - include/configs/mx31pdk.h | 1 - include/configs/mx35pdk.h | 2 -- include/configs/mx51evk.h | 2 -- include/configs/mx53ard.h | 1 - include/configs/mx53cx9020.h | 1 - include/configs/mx53evk.h | 1 - include/configs/mx53loco.h | 1 - include/configs/mx53smd.h | 1 - include/configs/mx6cuboxi.h | 1 - include/configs/mx6qarm2.h | 2 -- include/configs/mx6sabre_common.h | 2 -- include/configs/mx6slevk.h | 2 -- include/configs/mx6sllevk.h | 2 -- include/configs/mx6sxsabreauto.h | 2 -- include/configs/mx6sxsabresd.h | 2 -- include/configs/mx6ul_14x14_evk.h | 2 -- include/configs/mx6ullevk.h | 2 -- include/configs/mx7dsabresd.h | 2 -- include/configs/mxs.h | 1 - include/configs/neo.h | 1 - include/configs/nitrogen6x.h | 1 - include/configs/novena.h | 1 - include/configs/omapl138_lcdk.h | 1 - include/configs/ot1200.h | 1 - include/configs/p1_p2_rdb_pc.h | 2 -- include/configs/p1_twr.h | 2 -- include/configs/pcm052.h | 2 -- include/configs/pcm058.h | 1 - include/configs/pico-imx6ul.h | 2 -- include/configs/picosam9g45.h | 1 - include/configs/platinum.h | 1 - include/configs/pm9261.h | 1 - include/configs/pm9263.h | 1 - include/configs/pm9g45.h | 1 - include/configs/qemu-ppce500.h | 1 - include/configs/rcar-gen2-common.h | 1 - include/configs/rcar-gen3-common.h | 1 - include/configs/redwood.h | 1 - include/configs/s32v234evb.h | 1 - include/configs/sama5d2_xplained.h | 2 -- include/configs/sbc8349.h | 2 -- include/configs/sbc8548.h | 2 -- include/configs/sbc8641d.h | 2 -- include/configs/secomx6quq7.h | 2 -- include/configs/sequoia.h | 1 - include/configs/smartweb.h | 1 - include/configs/snapper9g45.h | 1 - include/configs/socfpga_sr1500.h | 2 -- include/configs/som-6896.h | 1 - include/configs/som-db5800-som-6867.h | 1 - include/configs/spear-common.h | 1 - include/configs/stm32f429-discovery.h | 1 - include/configs/stm32f746-disco.h | 2 -- include/configs/strider.h | 1 - include/configs/stv0991.h | 1 - include/configs/t3corp.h | 1 - include/configs/taurus.h | 1 - include/configs/tbs2910.h | 2 -- include/configs/tegra-common.h | 2 -- include/configs/ti_am335x_common.h | 3 --- include/configs/ti_armv7_keystone2.h | 1 - include/configs/titanium.h | 1 - include/configs/tplink_wdr4300.h | 2 -- include/configs/tqma6.h | 2 -- include/configs/ts4800.h | 2 -- include/configs/udoo.h | 2 -- include/configs/udoo_neo.h | 1 - include/configs/usbarmory.h | 1 - include/configs/v38b.h | 1 - include/configs/ve8313.h | 2 -- include/configs/vf610twr.h | 2 -- include/configs/vining_2000.h | 2 -- include/configs/walnut.h | 2 -- include/configs/wandboard.h | 2 -- include/configs/warp.h | 2 -- include/configs/warp7.h | 2 -- include/configs/woodburn.h | 1 - include/configs/work_92105.h | 1 - include/configs/x86-chromebook.h | 1 - include/configs/xpedite1000.h | 1 - include/configs/xpress.h | 2 -- include/configs/yosemite.h | 1 - include/configs/yucca.h | 1 - 607 files changed, 464 insertions(+), 290 deletions(-)
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 1538140301..4085a9a731 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -201,6 +201,7 @@ config ARCH_DAVINCI config KIRKWOOD bool "Marvell Kirkwood" select CPU_ARM926EJS + select BOARD_EARLY_INIT_F
config ARCH_MVEBU bool "Marvell MVEBU family (Armada XP/375/38x/3700/7K/8K)" @@ -225,6 +226,7 @@ config TARGET_WORK_92105 config TARGET_MX25PDK bool "Support mx25pdk" select CPU_ARM926EJS + select BOARD_EARLY_INIT_F
config TARGET_ZMX25 bool "Support zmx25" @@ -254,16 +256,19 @@ config TARGET_MX23EVK bool "Support mx23evk" select CPU_ARM926EJS select SUPPORT_SPL + select BOARD_EARLY_INIT_F
config TARGET_MX28EVK bool "Support mx28evk" select CPU_ARM926EJS select SUPPORT_SPL + select BOARD_EARLY_INIT_F
config TARGET_MX23_OLINUXINO bool "Support mx23_olinuxino" select CPU_ARM926EJS select SUPPORT_SPL + select BOARD_EARLY_INIT_F
config TARGET_BG0900 bool "Support bg0900" @@ -287,18 +292,22 @@ config ORION5X config TARGET_SPEAR300 bool "Support spear300" select CPU_ARM926EJS + select BOARD_EARLY_INIT_F
config TARGET_SPEAR310 bool "Support spear310" select CPU_ARM926EJS + select BOARD_EARLY_INIT_F
config TARGET_SPEAR320 bool "Support spear320" select CPU_ARM926EJS + select BOARD_EARLY_INIT_F
config TARGET_SPEAR600 bool "Support spear600" select CPU_ARM926EJS + select BOARD_EARLY_INIT_F
config TARGET_STV0991 bool "Support stv0991" @@ -317,15 +326,18 @@ config TARGET_X600 config TARGET_IMX31_PHYCORE bool "Support imx31_phycore" select CPU_ARM1136 + select BOARD_EARLY_INIT_F
config TARGET_MX31ADS bool "Support mx31ads" select CPU_ARM1136 + select BOARD_EARLY_INIT_F
config TARGET_MX31PDK bool "Support mx31pdk" select CPU_ARM1136 select SUPPORT_SPL + select BOARD_EARLY_INIT_F
config TARGET_WOODBURN bool "Support woodburn" @@ -485,6 +497,7 @@ config ARCH_MX7 select SYS_FSL_HAS_SEC if SECURE_BOOT select SYS_FSL_SEC_COMPAT_4 select SYS_FSL_SEC_LE + select BOARD_EARLY_INIT_F
config ARCH_MX6 bool "Freescale MX6" @@ -496,31 +509,38 @@ config ARCH_MX6 config ARCH_MX5 bool "Freescale MX5" select CPU_V7 + select BOARD_EARLY_INIT_F
config TARGET_M53EVK bool "Support m53evk" select CPU_V7 select SUPPORT_SPL + select BOARD_EARLY_INIT_F
config TARGET_MX51EVK bool "Support mx51evk" select CPU_V7 + select BOARD_EARLY_INIT_F
config TARGET_MX53ARD bool "Support mx53ard" select CPU_V7 + select BOARD_EARLY_INIT_F
config TARGET_MX53EVK bool "Support mx53evk" select CPU_V7 + select BOARD_EARLY_INIT_F
config TARGET_MX53LOCO bool "Support mx53loco" select CPU_V7 + select BOARD_EARLY_INIT_F
config TARGET_MX53SMD bool "Support mx53smd" select CPU_V7 + select BOARD_EARLY_INIT_F
config OMAP34XX bool "OMAP34XX SoC" @@ -560,6 +580,7 @@ config ARCH_RMOBILE bool "Renesas ARM SoCs" select DM select DM_SERIAL + select BOARD_EARLY_INIT_F
config TARGET_S32V234EVB bool "Support s32v234evb" @@ -800,6 +821,7 @@ config TARGET_LS1021AQDS select ARCH_SUPPORT_PSCI select LS1_DEEP_SLEEP select SYS_FSL_DDR + select BOARD_EARLY_INIT_F
config TARGET_LS1021ATWR bool "Support ls1021atwr" @@ -810,6 +832,7 @@ config TARGET_LS1021ATWR select ARCH_LS1021A select ARCH_SUPPORT_PSCI select LS1_DEEP_SLEEP + select BOARD_EARLY_INIT_F
config TARGET_LS1021AIOT bool "Support ls1021aiot" @@ -831,6 +854,7 @@ config TARGET_LS1043AQDS select ARM64 select ARMV8_MULTIENTRY select SUPPORT_SPL + select BOARD_EARLY_INIT_F help Support for Freescale LS1043AQDS platform.
@@ -840,6 +864,7 @@ config TARGET_LS1043ARDB select ARM64 select ARMV8_MULTIENTRY select SUPPORT_SPL + select BOARD_EARLY_INIT_F help Support for Freescale LS1043ARDB platform.
@@ -850,6 +875,7 @@ config TARGET_LS1046AQDS select ARMV8_MULTIENTRY select SUPPORT_SPL select DM_SPI_FLASH if DM_SPI + select BOARD_EARLY_INIT_F help Support for Freescale LS1046AQDS platform. The LS1046A Development System (QDS) is a high-performance @@ -864,6 +890,7 @@ config TARGET_LS1046ARDB select SUPPORT_SPL select DM_SPI_FLASH if DM_SPI select POWER_MC34VR500 + select BOARD_EARLY_INIT_F help Support for Freescale LS1046ARDB platform. The LS1046A Reference Design Board (RDB) is a high-performance diff --git a/arch/arm/cpu/armv7/mx6/Kconfig b/arch/arm/cpu/armv7/mx6/Kconfig index c646966f75..82b15e8a4f 100644 --- a/arch/arm/cpu/armv7/mx6/Kconfig +++ b/arch/arm/cpu/armv7/mx6/Kconfig @@ -149,12 +149,14 @@ config TARGET_MX6QSABREAUTO bool "mx6qsabreauto" select DM select DM_THERMAL + select BOARD_EARLY_INIT_F
config TARGET_MX6SABRESD bool "mx6sabresd" select SUPPORT_SPL select DM select DM_THERMAL + select BOARD_EARLY_INIT_F
config TARGET_MX6SLEVK bool "mx6slevk" @@ -172,12 +174,14 @@ config TARGET_MX6SXSABRESD select SUPPORT_SPL select DM select DM_THERMAL + select BOARD_EARLY_INIT_F
config TARGET_MX6SXSABREAUTO bool "mx6sxsabreauto" select MX6SX select DM select DM_THERMAL + select BOARD_EARLY_INIT_F
config TARGET_MX6UL_9X9_EVK bool "mx6ul_9x9_evk" diff --git a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig index d93a61d00f..47897f4c90 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig +++ b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig @@ -6,6 +6,7 @@ config ARCH_LS1012A select SYS_FSL_MMDC select SYS_FSL_ERRATUM_A010315 select ARCH_EARLY_INIT_R + select BOARD_EARLY_INIT_F
config ARCH_LS1043A bool @@ -24,6 +25,7 @@ config ARCH_LS1043A select SYS_FSL_HAS_DDR3 select SYS_FSL_HAS_DDR4 select ARCH_EARLY_INIT_R + select BOARD_EARLY_INIT_F
config ARCH_LS1046A bool @@ -41,6 +43,7 @@ config ARCH_LS1046A select SYS_FSL_HAS_DDR4 select SYS_FSL_SRDS_2 select ARCH_EARLY_INIT_R + select BOARD_EARLY_INIT_F
config ARCH_LS2080A bool @@ -66,6 +69,7 @@ config ARCH_LS2080A select SYS_FSL_ERRATUM_A009942 select SYS_FSL_ERRATUM_A010165 select ARCH_EARLY_INIT_R + select BOARD_EARLY_INIT_F
config FSL_LSCH2 bool diff --git a/arch/arm/mach-at91/Kconfig b/arch/arm/mach-at91/Kconfig index 13e19ba2fe..68b60af32c 100644 --- a/arch/arm/mach-at91/Kconfig +++ b/arch/arm/mach-at91/Kconfig @@ -11,6 +11,7 @@ config TARGET_AT91RM9200EK config TARGET_AT91SAM9260EK bool "Atmel at91sam9260 reference board" select CPU_ARM926EJS + select BOARD_EARLY_INIT_F
config TARGET_ETHERNUT5 bool "Ethernut5 board" @@ -42,6 +43,7 @@ config TARGET_PM9261 config TARGET_AT91SAM9263EK bool "Atmel at91sam9263 reference board" select CPU_ARM926EJS + select BOARD_EARLY_INIT_F
config TARGET_USB_A9263 bool "Caloa USB A9260 board" @@ -55,6 +57,7 @@ config TARGET_AT91SAM9M10G45EK bool "Atmel AT91SAM9M10G45-EK board" select CPU_ARM926EJS select SUPPORT_SPL + select BOARD_EARLY_INIT_F
config TARGET_PM9G45 bool "Ronetix pm9g45 board" @@ -69,45 +72,60 @@ config TARGET_AT91SAM9N12EK bool "Atmel AT91SAM9N12-EK board" select CPU_ARM926EJS select SUPPORT_SPL + select BOARD_EARLY_INIT_F
config TARGET_AT91SAM9RLEK bool "Atmel at91sam9rl reference board" select CPU_ARM926EJS + select BOARD_EARLY_INIT_F
config TARGET_AT91SAM9X5EK bool "Atmel AT91SAM9X5-EK board" select CPU_ARM926EJS select SUPPORT_SPL + select BOARD_EARLY_INIT_F
config TARGET_SAMA5D2_PTC bool "SAMA5D2 PTC board" select CPU_V7 select SUPPORT_SPL + select BOARD_EARLY_INIT_F + select BOARD_EARLY_INIT_F
config TARGET_SAMA5D2_XPLAINED bool "SAMA5D2 Xplained board" select CPU_V7 select SUPPORT_SPL + select BOARD_EARLY_INIT_F + select BOARD_EARLY_INIT_F
config TARGET_SAMA5D3_XPLAINED bool "SAMA5D3 Xplained board" select CPU_V7 select SUPPORT_SPL + select BOARD_EARLY_INIT_F + select BOARD_EARLY_INIT_F
config TARGET_SAMA5D3XEK bool "SAMA5D3X-EK board" select CPU_V7 select SUPPORT_SPL + select BOARD_EARLY_INIT_F + select BOARD_EARLY_INIT_F
config TARGET_SAMA5D4_XPLAINED bool "SAMA5D4 Xplained board" select CPU_V7 select SUPPORT_SPL + select BOARD_EARLY_INIT_F + select BOARD_EARLY_INIT_F
config TARGET_SAMA5D4EK bool "SAMA5D4 Evaluation Kit" select CPU_V7 select SUPPORT_SPL + select BOARD_EARLY_INIT_F + select BOARD_EARLY_INIT_F
config TARGET_MA5D4EVK bool "DENX MA5D4EVK Evaluation Kit" diff --git a/arch/arm/mach-exynos/Kconfig b/arch/arm/mach-exynos/Kconfig index 07118fc3df..9bd8ba5eea 100644 --- a/arch/arm/mach-exynos/Kconfig +++ b/arch/arm/mach-exynos/Kconfig @@ -7,6 +7,7 @@ choice config ARCH_EXYNOS4 bool "Exynos4 SoC family" select CPU_V7 + select BOARD_EARLY_INIT_F help Samsung Exynos4 SoC family are based on ARM Cortex-A9 CPU. There are multiple SoCs in this family including Exynos4210, Exynos4412, @@ -15,6 +16,7 @@ config ARCH_EXYNOS4 config ARCH_EXYNOS5 bool "Exynos5 SoC family" select CPU_V7 + select BOARD_EARLY_INIT_F help Samsung Exynos5 SoC family are based on ARM Cortex-A15 CPU (and Cortex-A7 CPU in big.LITTLE configuration). There are multiple SoCs @@ -23,6 +25,7 @@ config ARCH_EXYNOS5 config ARCH_EXYNOS7 bool "Exynos7 SoC family" select ARM64 + select BOARD_EARLY_INIT_F help Samsung Exynos7 SoC family are based on ARM Cortex-A57 CPU or Cortex-A53 CPU (and some in a big.LITTLE configuration). There are diff --git a/arch/arm/mach-mvebu/Kconfig b/arch/arm/mach-mvebu/Kconfig index 40476dc421..06dc82a8d2 100644 --- a/arch/arm/mach-mvebu/Kconfig +++ b/arch/arm/mach-mvebu/Kconfig @@ -8,6 +8,7 @@ config ARMADA_32BIT select SPL_DM_SEQ_ALIAS select SPL_OF_CONTROL select SPL_SIMPLE_BUS + select BOARD_EARLY_INIT_F
config ARMADA_64BIT bool diff --git a/arch/arm/mach-tegra/Kconfig b/arch/arm/mach-tegra/Kconfig index 5bdbc700a4..c9f2380f4d 100644 --- a/arch/arm/mach-tegra/Kconfig +++ b/arch/arm/mach-tegra/Kconfig @@ -37,6 +37,7 @@ config TEGRA_COMMON select MISC select OF_CONTROL select VIDCONSOLE_AS_LCD if DM_VIDEO + select BOARD_EARLY_INIT_F
config TEGRA_NO_BPMP bool "Tegra common options for SoCs without BPMP" diff --git a/arch/powerpc/cpu/mpc83xx/Kconfig b/arch/powerpc/cpu/mpc83xx/Kconfig index 184063c40b..bf3be50c48 100644 --- a/arch/powerpc/cpu/mpc83xx/Kconfig +++ b/arch/powerpc/cpu/mpc83xx/Kconfig @@ -27,30 +27,36 @@ config TARGET_MPC8308RDB config TARGET_MPC8313ERDB bool "Support MPC8313ERDB" select SUPPORT_SPL + select BOARD_EARLY_INIT_F
config TARGET_MPC8315ERDB bool "Support MPC8315ERDB" + select BOARD_EARLY_INIT_F
config TARGET_MPC8323ERDB bool "Support MPC8323ERDB"
config TARGET_MPC832XEMDS bool "Support MPC832XEMDS" + select BOARD_EARLY_INIT_F
config TARGET_MPC8349EMDS bool "Support MPC8349EMDS" select SYS_FSL_DDR select SYS_FSL_HAS_DDR2 select SYS_FSL_DDR_BE + select BOARD_EARLY_INIT_F
config TARGET_MPC8349ITX bool "Support MPC8349ITX"
config TARGET_MPC837XEMDS bool "Support MPC837XEMDS" + select BOARD_EARLY_INIT_F
config TARGET_MPC837XERDB bool "Support MPC837XERDB" + select BOARD_EARLY_INIT_F
config TARGET_IDS8313 bool "Support ids8313" diff --git a/arch/powerpc/cpu/mpc85xx/Kconfig b/arch/powerpc/cpu/mpc85xx/Kconfig index 704f65b093..d49d3e42b9 100644 --- a/arch/powerpc/cpu/mpc85xx/Kconfig +++ b/arch/powerpc/cpu/mpc85xx/Kconfig @@ -32,11 +32,13 @@ config TARGET_BSC9131RDB bool "Support BSC9131RDB" select ARCH_BSC9131 select SUPPORT_SPL + select BOARD_EARLY_INIT_F
config TARGET_BSC9132QDS bool "Support BSC9132QDS" select ARCH_BSC9132 select SUPPORT_SPL + select BOARD_EARLY_INIT_F
config TARGET_C29XPCIE bool "Support C29XPCIE" diff --git a/arch/powerpc/cpu/mpc86xx/Kconfig b/arch/powerpc/cpu/mpc86xx/Kconfig index ff21c4823b..fcac6584e8 100644 --- a/arch/powerpc/cpu/mpc86xx/Kconfig +++ b/arch/powerpc/cpu/mpc86xx/Kconfig @@ -11,10 +11,12 @@ choice config TARGET_SBC8641D bool "Support sbc8641d" select ARCH_MPC8641 + select BOARD_EARLY_INIT_F
config TARGET_MPC8610HPCD bool "Support MPC8610HPCD" select ARCH_MPC8610 + select BOARD_EARLY_INIT_F
config TARGET_MPC8641HPCN bool "Support MPC8641HPCN" diff --git a/common/Kconfig b/common/Kconfig index 6c8a856d40..fa90076a70 100644 --- a/common/Kconfig +++ b/common/Kconfig @@ -410,6 +410,16 @@ config ARCH_EARLY_INIT_R is on. Note that board_early_init_r() is called first, if enabled. This can be used to set up architecture-specific devices.
+config BOARD_EARLY_INIT_F + bool "Call board-specific init before relocation" + default y if X86 + help + Some boards need to perform initialisation as soon as possible + after boot. With this option, U-Boot calls board_early_init_f() + after driver model is ready in the pre-relocation init sequence. + Note that the normal serial console is not yet set up, but the + debug UART will be available if enabled. + endmenu
source "common/spl/Kconfig" diff --git a/configs/CPCI2DP_defconfig b/configs/CPCI2DP_defconfig index ea7c899c9d..23cb9f75e5 100644 --- a/configs/CPCI2DP_defconfig +++ b/configs/CPCI2DP_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_CPCI2DP=y CONFIG_BOOTDELAY=3 CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_LOOPW=y CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set diff --git a/configs/CPCI4052_defconfig b/configs/CPCI4052_defconfig index 15f1370168..09d760346e 100644 --- a/configs/CPCI4052_defconfig +++ b/configs/CPCI4052_defconfig @@ -5,6 +5,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTDELAY=3 CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Press SPACE to abort autoboot in %d seconds\n" CONFIG_AUTOBOOT_STOP_STR=" " diff --git a/configs/Cyrus_P5020_defconfig b/configs/Cyrus_P5020_defconfig index 4c124d9fb2..2307a6dd1b 100644 --- a/configs/Cyrus_P5020_defconfig +++ b/configs/Cyrus_P5020_defconfig @@ -8,6 +8,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SYS_TEXT_BASE=0xFFF40000" CONFIG_BOOTDELAY=10 CONFIG_CONSOLE_MUX=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set CONFIG_CMD_GREPENV=y diff --git a/configs/Cyrus_P5040_defconfig b/configs/Cyrus_P5040_defconfig index aa683227bd..768f495d18 100644 --- a/configs/Cyrus_P5040_defconfig +++ b/configs/Cyrus_P5040_defconfig @@ -8,6 +8,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SYS_TEXT_BASE=0xFFF40000" CONFIG_BOOTDELAY=10 CONFIG_CONSOLE_MUX=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set CONFIG_CMD_GREPENV=y diff --git a/configs/MIP405T_defconfig b/configs/MIP405T_defconfig index 57b3c12568..93e38c255a 100644 --- a/configs/MIP405T_defconfig +++ b/configs/MIP405T_defconfig @@ -9,6 +9,7 @@ CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_SYS_CONSOLE_INFO_QUIET=y # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set diff --git a/configs/MIP405_defconfig b/configs/MIP405_defconfig index a6acd51936..890dc58b95 100644 --- a/configs/MIP405_defconfig +++ b/configs/MIP405_defconfig @@ -9,6 +9,7 @@ CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_SYS_CONSOLE_INFO_QUIET=y # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y diff --git a/configs/MPC8536DS_36BIT_defconfig b/configs/MPC8536DS_36BIT_defconfig index bb975d24a7..935183ea55 100644 --- a/configs/MPC8536DS_36BIT_defconfig +++ b/configs/MPC8536DS_36BIT_defconfig @@ -7,6 +7,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_BOOTDELAY=10 # CONFIG_CONSOLE_MUX is not set +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_MMC=y CONFIG_CMD_SF=y diff --git a/configs/MPC8536DS_SDCARD_defconfig b/configs/MPC8536DS_SDCARD_defconfig index 59986aecf6..7257bc8cd9 100644 --- a/configs/MPC8536DS_SDCARD_defconfig +++ b/configs/MPC8536DS_SDCARD_defconfig @@ -7,6 +7,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SDCARD" CONFIG_BOOTDELAY=10 # CONFIG_CONSOLE_MUX is not set +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_MMC=y CONFIG_CMD_SF=y diff --git a/configs/MPC8536DS_SPIFLASH_defconfig b/configs/MPC8536DS_SPIFLASH_defconfig index 83eb24dde7..7bb7087742 100644 --- a/configs/MPC8536DS_SPIFLASH_defconfig +++ b/configs/MPC8536DS_SPIFLASH_defconfig @@ -7,6 +7,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SPIFLASH" CONFIG_BOOTDELAY=10 # CONFIG_CONSOLE_MUX is not set +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_MMC=y CONFIG_CMD_SF=y diff --git a/configs/MPC8536DS_defconfig b/configs/MPC8536DS_defconfig index 9661a818d3..900f754b09 100644 --- a/configs/MPC8536DS_defconfig +++ b/configs/MPC8536DS_defconfig @@ -6,6 +6,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_BOOTDELAY=10 # CONFIG_CONSOLE_MUX is not set +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_MMC=y CONFIG_CMD_SF=y diff --git a/configs/MPC8568MDS_defconfig b/configs/MPC8568MDS_defconfig index 21424ffa4d..8d64ce52dc 100644 --- a/configs/MPC8568MDS_defconfig +++ b/configs/MPC8568MDS_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_MPC8568MDS=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_BOOTDELAY=10 +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_I2C=y CONFIG_CMD_MII=y diff --git a/configs/MPC8569MDS_ATM_defconfig b/configs/MPC8569MDS_ATM_defconfig index 505a8536aa..03e6fd87b7 100644 --- a/configs/MPC8569MDS_ATM_defconfig +++ b/configs/MPC8569MDS_ATM_defconfig @@ -5,6 +5,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="ATM" CONFIG_BOOTDELAY=10 +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y diff --git a/configs/MPC8569MDS_defconfig b/configs/MPC8569MDS_defconfig index 0f9cc2fb92..5f7dde4ae8 100644 --- a/configs/MPC8569MDS_defconfig +++ b/configs/MPC8569MDS_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_MPC8569MDS=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_BOOTDELAY=10 +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y diff --git a/configs/P1010RDB-PA_36BIT_NAND_SECBOOT_defconfig b/configs/P1010RDB-PA_36BIT_NAND_SECBOOT_defconfig index 204e7b9262..6e62e4fead 100644 --- a/configs/P1010RDB-PA_36BIT_NAND_SECBOOT_defconfig +++ b/configs/P1010RDB-PA_36BIT_NAND_SECBOOT_defconfig @@ -12,6 +12,7 @@ CONFIG_SYS_EXTRA_OPTIONS="NAND_SECBOOT" CONFIG_BOOTDELAY=10 CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_BOARD_LATE_INIT=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_MMC=y CONFIG_CMD_SF=y diff --git a/configs/P1010RDB-PA_36BIT_NAND_defconfig b/configs/P1010RDB-PA_36BIT_NAND_defconfig index f769d58b44..ee386f3ce6 100644 --- a/configs/P1010RDB-PA_36BIT_NAND_defconfig +++ b/configs/P1010RDB-PA_36BIT_NAND_defconfig @@ -12,6 +12,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="NAND" CONFIG_BOOTDELAY=10 CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y CONFIG_TPL=y CONFIG_TPL_ENV_SUPPORT=y diff --git a/configs/P1010RDB-PA_36BIT_NOR_SECBOOT_defconfig b/configs/P1010RDB-PA_36BIT_NOR_SECBOOT_defconfig index 174ea38203..8776a2d182 100644 --- a/configs/P1010RDB-PA_36BIT_NOR_SECBOOT_defconfig +++ b/configs/P1010RDB-PA_36BIT_NOR_SECBOOT_defconfig @@ -11,6 +11,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_BOOTDELAY=10 CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_BOARD_LATE_INIT=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_MMC=y CONFIG_CMD_SF=y diff --git a/configs/P1010RDB-PA_36BIT_NOR_defconfig b/configs/P1010RDB-PA_36BIT_NOR_defconfig index 3b6f420227..4477a58570 100644 --- a/configs/P1010RDB-PA_36BIT_NOR_defconfig +++ b/configs/P1010RDB-PA_36BIT_NOR_defconfig @@ -8,6 +8,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_BOOTDELAY=10 CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_MMC=y CONFIG_CMD_SF=y diff --git a/configs/P1010RDB-PA_36BIT_SDCARD_defconfig b/configs/P1010RDB-PA_36BIT_SDCARD_defconfig index 45021e90b0..54606aea04 100644 --- a/configs/P1010RDB-PA_36BIT_SDCARD_defconfig +++ b/configs/P1010RDB-PA_36BIT_SDCARD_defconfig @@ -16,6 +16,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SDCARD" CONFIG_BOOTDELAY=10 CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/P1010RDB-PA_36BIT_SPIFLASH_SECBOOT_defconfig b/configs/P1010RDB-PA_36BIT_SPIFLASH_SECBOOT_defconfig index c9d44c6d57..5e58db6b67 100644 --- a/configs/P1010RDB-PA_36BIT_SPIFLASH_SECBOOT_defconfig +++ b/configs/P1010RDB-PA_36BIT_SPIFLASH_SECBOOT_defconfig @@ -12,6 +12,7 @@ CONFIG_SYS_EXTRA_OPTIONS="SPIFLASH" CONFIG_BOOTDELAY=10 CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_BOARD_LATE_INIT=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_MMC=y CONFIG_CMD_SF=y diff --git a/configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig b/configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig index 1d512de95f..f55701ba69 100644 --- a/configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig +++ b/configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig @@ -17,6 +17,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SPIFLASH" CONFIG_BOOTDELAY=10 CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/P1010RDB-PA_NAND_SECBOOT_defconfig b/configs/P1010RDB-PA_NAND_SECBOOT_defconfig index 11c4e02905..93c04a5af7 100644 --- a/configs/P1010RDB-PA_NAND_SECBOOT_defconfig +++ b/configs/P1010RDB-PA_NAND_SECBOOT_defconfig @@ -11,6 +11,7 @@ CONFIG_SYS_EXTRA_OPTIONS="NAND_SECBOOT" CONFIG_BOOTDELAY=10 CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_BOARD_LATE_INIT=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_MMC=y CONFIG_CMD_SF=y diff --git a/configs/P1010RDB-PA_NAND_defconfig b/configs/P1010RDB-PA_NAND_defconfig index 09a97ad8c8..dfb0f42751 100644 --- a/configs/P1010RDB-PA_NAND_defconfig +++ b/configs/P1010RDB-PA_NAND_defconfig @@ -11,6 +11,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="NAND" CONFIG_BOOTDELAY=10 CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y CONFIG_TPL=y CONFIG_TPL_ENV_SUPPORT=y diff --git a/configs/P1010RDB-PA_NOR_SECBOOT_defconfig b/configs/P1010RDB-PA_NOR_SECBOOT_defconfig index e9aa8f1686..46ad78e2cb 100644 --- a/configs/P1010RDB-PA_NOR_SECBOOT_defconfig +++ b/configs/P1010RDB-PA_NOR_SECBOOT_defconfig @@ -10,6 +10,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_BOOTDELAY=10 CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_BOARD_LATE_INIT=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_MMC=y CONFIG_CMD_SF=y diff --git a/configs/P1010RDB-PA_NOR_defconfig b/configs/P1010RDB-PA_NOR_defconfig index f7312f9bd8..a50d9c1336 100644 --- a/configs/P1010RDB-PA_NOR_defconfig +++ b/configs/P1010RDB-PA_NOR_defconfig @@ -7,6 +7,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_BOOTDELAY=10 CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_MMC=y CONFIG_CMD_SF=y diff --git a/configs/P1010RDB-PA_SDCARD_defconfig b/configs/P1010RDB-PA_SDCARD_defconfig index d63f4d86f9..03f54ffc74 100644 --- a/configs/P1010RDB-PA_SDCARD_defconfig +++ b/configs/P1010RDB-PA_SDCARD_defconfig @@ -15,6 +15,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SDCARD" CONFIG_BOOTDELAY=10 CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/P1010RDB-PA_SPIFLASH_SECBOOT_defconfig b/configs/P1010RDB-PA_SPIFLASH_SECBOOT_defconfig index cc8497fbc8..5f6bf26e8d 100644 --- a/configs/P1010RDB-PA_SPIFLASH_SECBOOT_defconfig +++ b/configs/P1010RDB-PA_SPIFLASH_SECBOOT_defconfig @@ -11,6 +11,7 @@ CONFIG_SYS_EXTRA_OPTIONS="SPIFLASH" CONFIG_BOOTDELAY=10 CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_BOARD_LATE_INIT=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_MMC=y CONFIG_CMD_SF=y diff --git a/configs/P1010RDB-PA_SPIFLASH_defconfig b/configs/P1010RDB-PA_SPIFLASH_defconfig index ace10776d5..6c4bf3ddea 100644 --- a/configs/P1010RDB-PA_SPIFLASH_defconfig +++ b/configs/P1010RDB-PA_SPIFLASH_defconfig @@ -16,6 +16,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SPIFLASH" CONFIG_BOOTDELAY=10 CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/P1010RDB-PB_36BIT_NAND_SECBOOT_defconfig b/configs/P1010RDB-PB_36BIT_NAND_SECBOOT_defconfig index 32586ffca6..e9c2d4d827 100644 --- a/configs/P1010RDB-PB_36BIT_NAND_SECBOOT_defconfig +++ b/configs/P1010RDB-PB_36BIT_NAND_SECBOOT_defconfig @@ -12,6 +12,7 @@ CONFIG_SYS_EXTRA_OPTIONS="NAND_SECBOOT" CONFIG_BOOTDELAY=10 CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_BOARD_LATE_INIT=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_MMC=y CONFIG_CMD_SF=y diff --git a/configs/P1010RDB-PB_36BIT_NAND_defconfig b/configs/P1010RDB-PB_36BIT_NAND_defconfig index b7e29e30b4..20cf797a36 100644 --- a/configs/P1010RDB-PB_36BIT_NAND_defconfig +++ b/configs/P1010RDB-PB_36BIT_NAND_defconfig @@ -12,6 +12,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="NAND" CONFIG_BOOTDELAY=10 CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y CONFIG_TPL=y CONFIG_TPL_ENV_SUPPORT=y diff --git a/configs/P1010RDB-PB_36BIT_NOR_SECBOOT_defconfig b/configs/P1010RDB-PB_36BIT_NOR_SECBOOT_defconfig index 8bee6132e0..1d05fddfe4 100644 --- a/configs/P1010RDB-PB_36BIT_NOR_SECBOOT_defconfig +++ b/configs/P1010RDB-PB_36BIT_NOR_SECBOOT_defconfig @@ -11,6 +11,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_BOOTDELAY=10 CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_BOARD_LATE_INIT=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_MMC=y CONFIG_CMD_SF=y diff --git a/configs/P1010RDB-PB_36BIT_NOR_defconfig b/configs/P1010RDB-PB_36BIT_NOR_defconfig index 091f578593..dcbc725815 100644 --- a/configs/P1010RDB-PB_36BIT_NOR_defconfig +++ b/configs/P1010RDB-PB_36BIT_NOR_defconfig @@ -8,6 +8,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_BOOTDELAY=10 CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_MMC=y CONFIG_CMD_SF=y diff --git a/configs/P1010RDB-PB_36BIT_SDCARD_defconfig b/configs/P1010RDB-PB_36BIT_SDCARD_defconfig index 089082d5d3..6689c65d93 100644 --- a/configs/P1010RDB-PB_36BIT_SDCARD_defconfig +++ b/configs/P1010RDB-PB_36BIT_SDCARD_defconfig @@ -16,6 +16,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SDCARD" CONFIG_BOOTDELAY=10 CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/P1010RDB-PB_36BIT_SPIFLASH_SECBOOT_defconfig b/configs/P1010RDB-PB_36BIT_SPIFLASH_SECBOOT_defconfig index c9cd39e353..dcf012485e 100644 --- a/configs/P1010RDB-PB_36BIT_SPIFLASH_SECBOOT_defconfig +++ b/configs/P1010RDB-PB_36BIT_SPIFLASH_SECBOOT_defconfig @@ -12,6 +12,7 @@ CONFIG_SYS_EXTRA_OPTIONS="SPIFLASH" CONFIG_BOOTDELAY=10 CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_BOARD_LATE_INIT=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_MMC=y CONFIG_CMD_SF=y diff --git a/configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig b/configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig index 2d356aead7..a5c3d744ca 100644 --- a/configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig +++ b/configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig @@ -17,6 +17,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SPIFLASH" CONFIG_BOOTDELAY=10 CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/P1010RDB-PB_NAND_SECBOOT_defconfig b/configs/P1010RDB-PB_NAND_SECBOOT_defconfig index a11bbac8db..8b4faf5ec4 100644 --- a/configs/P1010RDB-PB_NAND_SECBOOT_defconfig +++ b/configs/P1010RDB-PB_NAND_SECBOOT_defconfig @@ -11,6 +11,7 @@ CONFIG_SYS_EXTRA_OPTIONS="NAND_SECBOOT" CONFIG_BOOTDELAY=10 CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_BOARD_LATE_INIT=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_MMC=y CONFIG_CMD_SF=y diff --git a/configs/P1010RDB-PB_NAND_defconfig b/configs/P1010RDB-PB_NAND_defconfig index 6310512017..5616a2a4b1 100644 --- a/configs/P1010RDB-PB_NAND_defconfig +++ b/configs/P1010RDB-PB_NAND_defconfig @@ -11,6 +11,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="NAND" CONFIG_BOOTDELAY=10 CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y CONFIG_TPL=y CONFIG_TPL_ENV_SUPPORT=y diff --git a/configs/P1010RDB-PB_NOR_SECBOOT_defconfig b/configs/P1010RDB-PB_NOR_SECBOOT_defconfig index 2145a0f0ef..c59dc2beea 100644 --- a/configs/P1010RDB-PB_NOR_SECBOOT_defconfig +++ b/configs/P1010RDB-PB_NOR_SECBOOT_defconfig @@ -10,6 +10,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_BOOTDELAY=10 CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_BOARD_LATE_INIT=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_MMC=y CONFIG_CMD_SF=y diff --git a/configs/P1010RDB-PB_NOR_defconfig b/configs/P1010RDB-PB_NOR_defconfig index ec27153b91..301add8a3a 100644 --- a/configs/P1010RDB-PB_NOR_defconfig +++ b/configs/P1010RDB-PB_NOR_defconfig @@ -7,6 +7,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_BOOTDELAY=10 CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_MMC=y CONFIG_CMD_SF=y diff --git a/configs/P1010RDB-PB_SDCARD_defconfig b/configs/P1010RDB-PB_SDCARD_defconfig index 5770ae946d..25e5993f02 100644 --- a/configs/P1010RDB-PB_SDCARD_defconfig +++ b/configs/P1010RDB-PB_SDCARD_defconfig @@ -15,6 +15,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SDCARD" CONFIG_BOOTDELAY=10 CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/P1010RDB-PB_SPIFLASH_SECBOOT_defconfig b/configs/P1010RDB-PB_SPIFLASH_SECBOOT_defconfig index 2589939341..a7d492bd3e 100644 --- a/configs/P1010RDB-PB_SPIFLASH_SECBOOT_defconfig +++ b/configs/P1010RDB-PB_SPIFLASH_SECBOOT_defconfig @@ -11,6 +11,7 @@ CONFIG_SYS_EXTRA_OPTIONS="SPIFLASH" CONFIG_BOOTDELAY=10 CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_BOARD_LATE_INIT=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_MMC=y CONFIG_CMD_SF=y diff --git a/configs/P1010RDB-PB_SPIFLASH_defconfig b/configs/P1010RDB-PB_SPIFLASH_defconfig index f63c0dca8c..de01d4c06a 100644 --- a/configs/P1010RDB-PB_SPIFLASH_defconfig +++ b/configs/P1010RDB-PB_SPIFLASH_defconfig @@ -16,6 +16,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SPIFLASH" CONFIG_BOOTDELAY=10 CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/P1020MBG-PC_36BIT_SDCARD_defconfig b/configs/P1020MBG-PC_36BIT_SDCARD_defconfig index d3fb861e6e..f147e78766 100644 --- a/configs/P1020MBG-PC_36BIT_SDCARD_defconfig +++ b/configs/P1020MBG-PC_36BIT_SDCARD_defconfig @@ -14,6 +14,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SDCARD" CONFIG_BOOTDELAY=10 +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/P1020MBG-PC_36BIT_defconfig b/configs/P1020MBG-PC_36BIT_defconfig index ccf8398e50..2bd646af48 100644 --- a/configs/P1020MBG-PC_36BIT_defconfig +++ b/configs/P1020MBG-PC_36BIT_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_BOOTDELAY=10 +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y diff --git a/configs/P1020MBG-PC_SDCARD_defconfig b/configs/P1020MBG-PC_SDCARD_defconfig index c9fdcc5030..01d55bf331 100644 --- a/configs/P1020MBG-PC_SDCARD_defconfig +++ b/configs/P1020MBG-PC_SDCARD_defconfig @@ -13,6 +13,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SDCARD" CONFIG_BOOTDELAY=10 +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/P1020MBG-PC_defconfig b/configs/P1020MBG-PC_defconfig index c83299358f..2ca7d51d9b 100644 --- a/configs/P1020MBG-PC_defconfig +++ b/configs/P1020MBG-PC_defconfig @@ -6,6 +6,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_BOOTDELAY=10 +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y diff --git a/configs/P1020RDB-PC_36BIT_NAND_defconfig b/configs/P1020RDB-PC_36BIT_NAND_defconfig index a31690753f..9cac48900f 100644 --- a/configs/P1020RDB-PC_36BIT_NAND_defconfig +++ b/configs/P1020RDB-PC_36BIT_NAND_defconfig @@ -10,6 +10,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="NAND" CONFIG_BOOTDELAY=10 +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y CONFIG_TPL=y CONFIG_TPL_ENV_SUPPORT=y diff --git a/configs/P1020RDB-PC_36BIT_SDCARD_defconfig b/configs/P1020RDB-PC_36BIT_SDCARD_defconfig index ce9d293e54..db42f76869 100644 --- a/configs/P1020RDB-PC_36BIT_SDCARD_defconfig +++ b/configs/P1020RDB-PC_36BIT_SDCARD_defconfig @@ -14,6 +14,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SDCARD" CONFIG_BOOTDELAY=10 +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig b/configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig index d6c06fe2ac..da5d19b8db 100644 --- a/configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig +++ b/configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig @@ -15,6 +15,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SPIFLASH" CONFIG_BOOTDELAY=10 +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/P1020RDB-PC_36BIT_defconfig b/configs/P1020RDB-PC_36BIT_defconfig index 2598e15b4d..20c29ff264 100644 --- a/configs/P1020RDB-PC_36BIT_defconfig +++ b/configs/P1020RDB-PC_36BIT_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_BOOTDELAY=10 +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_MMC=y CONFIG_CMD_SF=y diff --git a/configs/P1020RDB-PC_NAND_defconfig b/configs/P1020RDB-PC_NAND_defconfig index 7ed4d97534..eb4c2ef616 100644 --- a/configs/P1020RDB-PC_NAND_defconfig +++ b/configs/P1020RDB-PC_NAND_defconfig @@ -9,6 +9,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="NAND" CONFIG_BOOTDELAY=10 +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y CONFIG_TPL=y CONFIG_TPL_ENV_SUPPORT=y diff --git a/configs/P1020RDB-PC_SDCARD_defconfig b/configs/P1020RDB-PC_SDCARD_defconfig index b75aa5ea8f..4aa337c11f 100644 --- a/configs/P1020RDB-PC_SDCARD_defconfig +++ b/configs/P1020RDB-PC_SDCARD_defconfig @@ -13,6 +13,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SDCARD" CONFIG_BOOTDELAY=10 +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/P1020RDB-PC_SPIFLASH_defconfig b/configs/P1020RDB-PC_SPIFLASH_defconfig index 7134a1961a..7c88e6609b 100644 --- a/configs/P1020RDB-PC_SPIFLASH_defconfig +++ b/configs/P1020RDB-PC_SPIFLASH_defconfig @@ -14,6 +14,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SPIFLASH" CONFIG_BOOTDELAY=10 +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/P1020RDB-PC_defconfig b/configs/P1020RDB-PC_defconfig index 99bc59c411..6551c0a46e 100644 --- a/configs/P1020RDB-PC_defconfig +++ b/configs/P1020RDB-PC_defconfig @@ -6,6 +6,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_BOOTDELAY=10 +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_MMC=y CONFIG_CMD_SF=y diff --git a/configs/P1020RDB-PD_NAND_defconfig b/configs/P1020RDB-PD_NAND_defconfig index 86cf952762..4e928f722d 100644 --- a/configs/P1020RDB-PD_NAND_defconfig +++ b/configs/P1020RDB-PD_NAND_defconfig @@ -9,6 +9,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="NAND" CONFIG_BOOTDELAY=10 +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y CONFIG_TPL=y CONFIG_TPL_ENV_SUPPORT=y diff --git a/configs/P1020RDB-PD_SDCARD_defconfig b/configs/P1020RDB-PD_SDCARD_defconfig index 7131bceb28..121a61fc59 100644 --- a/configs/P1020RDB-PD_SDCARD_defconfig +++ b/configs/P1020RDB-PD_SDCARD_defconfig @@ -13,6 +13,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SDCARD" CONFIG_BOOTDELAY=10 +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/P1020RDB-PD_SPIFLASH_defconfig b/configs/P1020RDB-PD_SPIFLASH_defconfig index 3bc9afdddf..306e1cd988 100644 --- a/configs/P1020RDB-PD_SPIFLASH_defconfig +++ b/configs/P1020RDB-PD_SPIFLASH_defconfig @@ -14,6 +14,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SPIFLASH" CONFIG_BOOTDELAY=10 +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/P1020RDB-PD_defconfig b/configs/P1020RDB-PD_defconfig index 1cae066425..9e6bc1ecbb 100644 --- a/configs/P1020RDB-PD_defconfig +++ b/configs/P1020RDB-PD_defconfig @@ -6,6 +6,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_BOOTDELAY=10 +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_MMC=y CONFIG_CMD_SF=y diff --git a/configs/P1020UTM-PC_36BIT_SDCARD_defconfig b/configs/P1020UTM-PC_36BIT_SDCARD_defconfig index 19e448d330..598a390ecd 100644 --- a/configs/P1020UTM-PC_36BIT_SDCARD_defconfig +++ b/configs/P1020UTM-PC_36BIT_SDCARD_defconfig @@ -14,6 +14,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SDCARD" CONFIG_BOOTDELAY=10 +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/P1020UTM-PC_36BIT_defconfig b/configs/P1020UTM-PC_36BIT_defconfig index aa266f96d5..88e5a54c57 100644 --- a/configs/P1020UTM-PC_36BIT_defconfig +++ b/configs/P1020UTM-PC_36BIT_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_BOOTDELAY=10 +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y diff --git a/configs/P1020UTM-PC_SDCARD_defconfig b/configs/P1020UTM-PC_SDCARD_defconfig index c03c7c576b..c609e6f150 100644 --- a/configs/P1020UTM-PC_SDCARD_defconfig +++ b/configs/P1020UTM-PC_SDCARD_defconfig @@ -13,6 +13,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SDCARD" CONFIG_BOOTDELAY=10 +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/P1020UTM-PC_defconfig b/configs/P1020UTM-PC_defconfig index c47d5143d3..86426f9849 100644 --- a/configs/P1020UTM-PC_defconfig +++ b/configs/P1020UTM-PC_defconfig @@ -6,6 +6,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_BOOTDELAY=10 +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y diff --git a/configs/P1021RDB-PC_36BIT_NAND_defconfig b/configs/P1021RDB-PC_36BIT_NAND_defconfig index 82dcec5409..d72fc8a741 100644 --- a/configs/P1021RDB-PC_36BIT_NAND_defconfig +++ b/configs/P1021RDB-PC_36BIT_NAND_defconfig @@ -10,6 +10,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="NAND" CONFIG_BOOTDELAY=10 +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y CONFIG_TPL=y CONFIG_TPL_ENV_SUPPORT=y diff --git a/configs/P1021RDB-PC_36BIT_SDCARD_defconfig b/configs/P1021RDB-PC_36BIT_SDCARD_defconfig index 2ef2edae54..09f299c52b 100644 --- a/configs/P1021RDB-PC_36BIT_SDCARD_defconfig +++ b/configs/P1021RDB-PC_36BIT_SDCARD_defconfig @@ -14,6 +14,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SDCARD" CONFIG_BOOTDELAY=10 +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/P1021RDB-PC_36BIT_SPIFLASH_defconfig b/configs/P1021RDB-PC_36BIT_SPIFLASH_defconfig index f7910b6c5d..2b8623e70e 100644 --- a/configs/P1021RDB-PC_36BIT_SPIFLASH_defconfig +++ b/configs/P1021RDB-PC_36BIT_SPIFLASH_defconfig @@ -15,6 +15,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SPIFLASH" CONFIG_BOOTDELAY=10 +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/P1021RDB-PC_36BIT_defconfig b/configs/P1021RDB-PC_36BIT_defconfig index 87d45b2919..0af788759c 100644 --- a/configs/P1021RDB-PC_36BIT_defconfig +++ b/configs/P1021RDB-PC_36BIT_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_BOOTDELAY=10 +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_MMC=y CONFIG_CMD_SF=y diff --git a/configs/P1021RDB-PC_NAND_defconfig b/configs/P1021RDB-PC_NAND_defconfig index 29335b13af..dcbbec83f1 100644 --- a/configs/P1021RDB-PC_NAND_defconfig +++ b/configs/P1021RDB-PC_NAND_defconfig @@ -9,6 +9,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="NAND" CONFIG_BOOTDELAY=10 +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y CONFIG_TPL=y CONFIG_TPL_ENV_SUPPORT=y diff --git a/configs/P1021RDB-PC_SDCARD_defconfig b/configs/P1021RDB-PC_SDCARD_defconfig index bde4d3d8f1..89d971afef 100644 --- a/configs/P1021RDB-PC_SDCARD_defconfig +++ b/configs/P1021RDB-PC_SDCARD_defconfig @@ -13,6 +13,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SDCARD" CONFIG_BOOTDELAY=10 +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/P1021RDB-PC_SPIFLASH_defconfig b/configs/P1021RDB-PC_SPIFLASH_defconfig index 4f1db4f244..c144fe96ad 100644 --- a/configs/P1021RDB-PC_SPIFLASH_defconfig +++ b/configs/P1021RDB-PC_SPIFLASH_defconfig @@ -14,6 +14,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SPIFLASH" CONFIG_BOOTDELAY=10 +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/P1021RDB-PC_defconfig b/configs/P1021RDB-PC_defconfig index e26967b854..bb695b9d9b 100644 --- a/configs/P1021RDB-PC_defconfig +++ b/configs/P1021RDB-PC_defconfig @@ -6,6 +6,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_BOOTDELAY=10 +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_MMC=y CONFIG_CMD_SF=y diff --git a/configs/P1022DS_36BIT_NAND_defconfig b/configs/P1022DS_36BIT_NAND_defconfig index 3d63c8e19c..27c25527b4 100644 --- a/configs/P1022DS_36BIT_NAND_defconfig +++ b/configs/P1022DS_36BIT_NAND_defconfig @@ -10,6 +10,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="NAND" CONFIG_BOOTDELAY=10 +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y CONFIG_TPL=y CONFIG_TPL_ENV_SUPPORT=y diff --git a/configs/P1022DS_36BIT_SDCARD_defconfig b/configs/P1022DS_36BIT_SDCARD_defconfig index 19f0b0df82..8a9e77ea98 100644 --- a/configs/P1022DS_36BIT_SDCARD_defconfig +++ b/configs/P1022DS_36BIT_SDCARD_defconfig @@ -14,6 +14,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SDCARD" CONFIG_BOOTDELAY=10 +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/P1022DS_36BIT_SPIFLASH_defconfig b/configs/P1022DS_36BIT_SPIFLASH_defconfig index fdf969dbf9..5759e31a9d 100644 --- a/configs/P1022DS_36BIT_SPIFLASH_defconfig +++ b/configs/P1022DS_36BIT_SPIFLASH_defconfig @@ -15,6 +15,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SPIFLASH" CONFIG_BOOTDELAY=10 +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/P1022DS_36BIT_defconfig b/configs/P1022DS_36BIT_defconfig index 3cbbf6f15e..3f6a59003a 100644 --- a/configs/P1022DS_36BIT_defconfig +++ b/configs/P1022DS_36BIT_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_BOOTDELAY=10 +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_MMC=y CONFIG_CMD_SF=y diff --git a/configs/P1022DS_NAND_defconfig b/configs/P1022DS_NAND_defconfig index 11efa4812b..3e27424b95 100644 --- a/configs/P1022DS_NAND_defconfig +++ b/configs/P1022DS_NAND_defconfig @@ -9,6 +9,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="NAND" CONFIG_BOOTDELAY=10 +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y CONFIG_TPL=y CONFIG_TPL_ENV_SUPPORT=y diff --git a/configs/P1022DS_SDCARD_defconfig b/configs/P1022DS_SDCARD_defconfig index 1f1f62120c..a48708e742 100644 --- a/configs/P1022DS_SDCARD_defconfig +++ b/configs/P1022DS_SDCARD_defconfig @@ -13,6 +13,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SDCARD" CONFIG_BOOTDELAY=10 +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/P1022DS_SPIFLASH_defconfig b/configs/P1022DS_SPIFLASH_defconfig index 60b4981b7e..e92c271d0e 100644 --- a/configs/P1022DS_SPIFLASH_defconfig +++ b/configs/P1022DS_SPIFLASH_defconfig @@ -14,6 +14,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SPIFLASH" CONFIG_BOOTDELAY=10 +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/P1022DS_defconfig b/configs/P1022DS_defconfig index ee8a45ab53..5f4ad07675 100644 --- a/configs/P1022DS_defconfig +++ b/configs/P1022DS_defconfig @@ -6,6 +6,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_BOOTDELAY=10 +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_MMC=y CONFIG_CMD_SF=y diff --git a/configs/P1023RDB_defconfig b/configs/P1023RDB_defconfig index 728130437c..49644391dd 100644 --- a/configs/P1023RDB_defconfig +++ b/configs/P1023RDB_defconfig @@ -6,6 +6,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_BOOTDELAY=-1 +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y diff --git a/configs/P1024RDB_36BIT_defconfig b/configs/P1024RDB_36BIT_defconfig index 76724649c6..b3597b7770 100644 --- a/configs/P1024RDB_36BIT_defconfig +++ b/configs/P1024RDB_36BIT_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_BOOTDELAY=10 +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_MMC=y CONFIG_CMD_SF=y diff --git a/configs/P1024RDB_NAND_defconfig b/configs/P1024RDB_NAND_defconfig index f4d5485182..e21d35d893 100644 --- a/configs/P1024RDB_NAND_defconfig +++ b/configs/P1024RDB_NAND_defconfig @@ -9,6 +9,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="NAND" CONFIG_BOOTDELAY=10 +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y CONFIG_TPL=y CONFIG_TPL_ENV_SUPPORT=y diff --git a/configs/P1024RDB_SDCARD_defconfig b/configs/P1024RDB_SDCARD_defconfig index 101647f53b..5f0c5a148a 100644 --- a/configs/P1024RDB_SDCARD_defconfig +++ b/configs/P1024RDB_SDCARD_defconfig @@ -13,6 +13,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SDCARD" CONFIG_BOOTDELAY=10 +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/P1024RDB_SPIFLASH_defconfig b/configs/P1024RDB_SPIFLASH_defconfig index 94c45c0d1a..d2e508a6c2 100644 --- a/configs/P1024RDB_SPIFLASH_defconfig +++ b/configs/P1024RDB_SPIFLASH_defconfig @@ -14,6 +14,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SPIFLASH" CONFIG_BOOTDELAY=10 +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/P1024RDB_defconfig b/configs/P1024RDB_defconfig index 0d204753a6..b7da5ff637 100644 --- a/configs/P1024RDB_defconfig +++ b/configs/P1024RDB_defconfig @@ -6,6 +6,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_BOOTDELAY=10 +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_MMC=y CONFIG_CMD_SF=y diff --git a/configs/P1025RDB_36BIT_defconfig b/configs/P1025RDB_36BIT_defconfig index 27151820cc..9175d6f503 100644 --- a/configs/P1025RDB_36BIT_defconfig +++ b/configs/P1025RDB_36BIT_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_BOOTDELAY=10 +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_MMC=y CONFIG_CMD_SF=y diff --git a/configs/P1025RDB_NAND_defconfig b/configs/P1025RDB_NAND_defconfig index 90e83679ad..ebea986d2c 100644 --- a/configs/P1025RDB_NAND_defconfig +++ b/configs/P1025RDB_NAND_defconfig @@ -9,6 +9,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="NAND" CONFIG_BOOTDELAY=10 +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y CONFIG_TPL=y CONFIG_TPL_ENV_SUPPORT=y diff --git a/configs/P1025RDB_SDCARD_defconfig b/configs/P1025RDB_SDCARD_defconfig index 90b005a920..58a1233e80 100644 --- a/configs/P1025RDB_SDCARD_defconfig +++ b/configs/P1025RDB_SDCARD_defconfig @@ -13,6 +13,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SDCARD" CONFIG_BOOTDELAY=10 +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/P1025RDB_SPIFLASH_defconfig b/configs/P1025RDB_SPIFLASH_defconfig index 0e5335da32..68589b2b1c 100644 --- a/configs/P1025RDB_SPIFLASH_defconfig +++ b/configs/P1025RDB_SPIFLASH_defconfig @@ -14,6 +14,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SPIFLASH" CONFIG_BOOTDELAY=10 +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/P1025RDB_defconfig b/configs/P1025RDB_defconfig index 7094db49b5..ce0f8a62b8 100644 --- a/configs/P1025RDB_defconfig +++ b/configs/P1025RDB_defconfig @@ -6,6 +6,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_BOOTDELAY=10 +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_MMC=y CONFIG_CMD_SF=y diff --git a/configs/P2020RDB-PC_36BIT_NAND_defconfig b/configs/P2020RDB-PC_36BIT_NAND_defconfig index d8f375bcf7..5d370d13b7 100644 --- a/configs/P2020RDB-PC_36BIT_NAND_defconfig +++ b/configs/P2020RDB-PC_36BIT_NAND_defconfig @@ -10,6 +10,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="NAND" CONFIG_BOOTDELAY=10 +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y CONFIG_TPL=y CONFIG_TPL_ENV_SUPPORT=y diff --git a/configs/P2020RDB-PC_36BIT_SDCARD_defconfig b/configs/P2020RDB-PC_36BIT_SDCARD_defconfig index d5e44a0e1c..bcfc17bbfd 100644 --- a/configs/P2020RDB-PC_36BIT_SDCARD_defconfig +++ b/configs/P2020RDB-PC_36BIT_SDCARD_defconfig @@ -14,6 +14,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SDCARD" CONFIG_BOOTDELAY=10 +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig b/configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig index 7112255aac..df5054e7a7 100644 --- a/configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig +++ b/configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig @@ -15,6 +15,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SPIFLASH" CONFIG_BOOTDELAY=10 +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/P2020RDB-PC_36BIT_defconfig b/configs/P2020RDB-PC_36BIT_defconfig index a2af2d7fbd..a8c0663e8c 100644 --- a/configs/P2020RDB-PC_36BIT_defconfig +++ b/configs/P2020RDB-PC_36BIT_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_BOOTDELAY=10 +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_MMC=y CONFIG_CMD_SF=y diff --git a/configs/P2020RDB-PC_NAND_defconfig b/configs/P2020RDB-PC_NAND_defconfig index fd36351c1d..e803151543 100644 --- a/configs/P2020RDB-PC_NAND_defconfig +++ b/configs/P2020RDB-PC_NAND_defconfig @@ -9,6 +9,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="NAND" CONFIG_BOOTDELAY=10 +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y CONFIG_TPL=y CONFIG_TPL_ENV_SUPPORT=y diff --git a/configs/P2020RDB-PC_SDCARD_defconfig b/configs/P2020RDB-PC_SDCARD_defconfig index 7330926c04..73b9b482da 100644 --- a/configs/P2020RDB-PC_SDCARD_defconfig +++ b/configs/P2020RDB-PC_SDCARD_defconfig @@ -13,6 +13,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SDCARD" CONFIG_BOOTDELAY=10 +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/P2020RDB-PC_SPIFLASH_defconfig b/configs/P2020RDB-PC_SPIFLASH_defconfig index 2d380d5e93..7f60da06d9 100644 --- a/configs/P2020RDB-PC_SPIFLASH_defconfig +++ b/configs/P2020RDB-PC_SPIFLASH_defconfig @@ -14,6 +14,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SPIFLASH" CONFIG_BOOTDELAY=10 +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/P2020RDB-PC_defconfig b/configs/P2020RDB-PC_defconfig index 7fc2dcd648..c5f5d8ff62 100644 --- a/configs/P2020RDB-PC_defconfig +++ b/configs/P2020RDB-PC_defconfig @@ -6,6 +6,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_BOOTDELAY=10 +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_MMC=y CONFIG_CMD_SF=y diff --git a/configs/P2041RDB_NAND_defconfig b/configs/P2041RDB_NAND_defconfig index 2a849cbb47..a97615dabd 100644 --- a/configs/P2041RDB_NAND_defconfig +++ b/configs/P2041RDB_NAND_defconfig @@ -7,6 +7,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,NAND,SYS_TEXT_BASE=0xFFF40000" CONFIG_BOOTDELAY=10 +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GREPENV=y CONFIG_CMD_MMC=y diff --git a/configs/P2041RDB_SDCARD_defconfig b/configs/P2041RDB_SDCARD_defconfig index 94eaca2480..c247af073e 100644 --- a/configs/P2041RDB_SDCARD_defconfig +++ b/configs/P2041RDB_SDCARD_defconfig @@ -7,6 +7,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SDCARD,SYS_TEXT_BASE=0xFFF40000" CONFIG_BOOTDELAY=10 +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GREPENV=y CONFIG_CMD_MMC=y diff --git a/configs/P2041RDB_SECURE_BOOT_defconfig b/configs/P2041RDB_SECURE_BOOT_defconfig index 1e4dac74b9..e0862e68c3 100644 --- a/configs/P2041RDB_SECURE_BOOT_defconfig +++ b/configs/P2041RDB_SECURE_BOOT_defconfig @@ -9,6 +9,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_BOOTDELAY=10 CONFIG_BOARD_LATE_INIT=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GREPENV=y CONFIG_CMD_MMC=y diff --git a/configs/P2041RDB_SPIFLASH_defconfig b/configs/P2041RDB_SPIFLASH_defconfig index 5c3f2e4707..8336548a3c 100644 --- a/configs/P2041RDB_SPIFLASH_defconfig +++ b/configs/P2041RDB_SPIFLASH_defconfig @@ -7,6 +7,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SPIFLASH,SYS_TEXT_BASE=0xFFF40000" CONFIG_BOOTDELAY=10 +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GREPENV=y CONFIG_CMD_MMC=y diff --git a/configs/P2041RDB_SRIO_PCIE_BOOT_defconfig b/configs/P2041RDB_SRIO_PCIE_BOOT_defconfig index 8080522b5c..afe6df4e7d 100644 --- a/configs/P2041RDB_SRIO_PCIE_BOOT_defconfig +++ b/configs/P2041RDB_SRIO_PCIE_BOOT_defconfig @@ -7,6 +7,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SRIO_PCIE_BOOT_SLAVE,SYS_TEXT_BASE=0xFFF40000" CONFIG_BOOTDELAY=10 +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set CONFIG_CMD_GREPENV=y diff --git a/configs/P2041RDB_defconfig b/configs/P2041RDB_defconfig index 1149124153..aea25743a0 100644 --- a/configs/P2041RDB_defconfig +++ b/configs/P2041RDB_defconfig @@ -6,6 +6,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_BOOTDELAY=10 +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GREPENV=y CONFIG_CMD_MMC=y diff --git a/configs/P3041DS_NAND_SECURE_BOOT_defconfig b/configs/P3041DS_NAND_SECURE_BOOT_defconfig index 4e90aba2a5..6937fce45c 100644 --- a/configs/P3041DS_NAND_SECURE_BOOT_defconfig +++ b/configs/P3041DS_NAND_SECURE_BOOT_defconfig @@ -10,6 +10,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,NAND,SYS_TEXT_BASE=0xFFF40000" CONFIG_BOOTDELAY=10 CONFIG_BOARD_LATE_INIT=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GREPENV=y CONFIG_CMD_MMC=y diff --git a/configs/P3041DS_NAND_defconfig b/configs/P3041DS_NAND_defconfig index 80949f4f03..24081e26de 100644 --- a/configs/P3041DS_NAND_defconfig +++ b/configs/P3041DS_NAND_defconfig @@ -7,6 +7,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,NAND,SYS_TEXT_BASE=0xFFF40000" CONFIG_BOOTDELAY=10 +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GREPENV=y CONFIG_CMD_MMC=y diff --git a/configs/P3041DS_SDCARD_defconfig b/configs/P3041DS_SDCARD_defconfig index ec36a56d18..e37dd74fe6 100644 --- a/configs/P3041DS_SDCARD_defconfig +++ b/configs/P3041DS_SDCARD_defconfig @@ -7,6 +7,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SDCARD,SYS_TEXT_BASE=0xFFF40000" CONFIG_BOOTDELAY=10 +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GREPENV=y CONFIG_CMD_MMC=y diff --git a/configs/P3041DS_SECURE_BOOT_defconfig b/configs/P3041DS_SECURE_BOOT_defconfig index 312a15bad4..f316c53e4c 100644 --- a/configs/P3041DS_SECURE_BOOT_defconfig +++ b/configs/P3041DS_SECURE_BOOT_defconfig @@ -9,6 +9,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_BOOTDELAY=10 CONFIG_BOARD_LATE_INIT=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GREPENV=y CONFIG_CMD_MMC=y diff --git a/configs/P3041DS_SPIFLASH_defconfig b/configs/P3041DS_SPIFLASH_defconfig index 26a0ceca5c..4ab5f4de91 100644 --- a/configs/P3041DS_SPIFLASH_defconfig +++ b/configs/P3041DS_SPIFLASH_defconfig @@ -7,6 +7,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SPIFLASH,SYS_TEXT_BASE=0xFFF40000" CONFIG_BOOTDELAY=10 +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GREPENV=y CONFIG_CMD_MMC=y diff --git a/configs/P3041DS_SRIO_PCIE_BOOT_defconfig b/configs/P3041DS_SRIO_PCIE_BOOT_defconfig index 984274d618..0df2c36d93 100644 --- a/configs/P3041DS_SRIO_PCIE_BOOT_defconfig +++ b/configs/P3041DS_SRIO_PCIE_BOOT_defconfig @@ -7,6 +7,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SRIO_PCIE_BOOT_SLAVE,SYS_TEXT_BASE=0xFFF40000" CONFIG_BOOTDELAY=10 +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set CONFIG_CMD_GREPENV=y diff --git a/configs/P3041DS_defconfig b/configs/P3041DS_defconfig index bf246866bb..c44235f6ae 100644 --- a/configs/P3041DS_defconfig +++ b/configs/P3041DS_defconfig @@ -6,6 +6,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_BOOTDELAY=10 +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GREPENV=y CONFIG_CMD_MMC=y diff --git a/configs/P4080DS_SDCARD_defconfig b/configs/P4080DS_SDCARD_defconfig index b7ccbd9eae..72776cbeda 100644 --- a/configs/P4080DS_SDCARD_defconfig +++ b/configs/P4080DS_SDCARD_defconfig @@ -7,6 +7,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SDCARD,SYS_TEXT_BASE=0xFFF40000" CONFIG_BOOTDELAY=10 +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GREPENV=y CONFIG_CMD_MMC=y diff --git a/configs/P4080DS_SECURE_BOOT_defconfig b/configs/P4080DS_SECURE_BOOT_defconfig index 7e679f77de..19e5294790 100644 --- a/configs/P4080DS_SECURE_BOOT_defconfig +++ b/configs/P4080DS_SECURE_BOOT_defconfig @@ -9,6 +9,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_BOOTDELAY=10 CONFIG_BOARD_LATE_INIT=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GREPENV=y CONFIG_CMD_MMC=y diff --git a/configs/P4080DS_SPIFLASH_defconfig b/configs/P4080DS_SPIFLASH_defconfig index ecad9a77be..f908790e87 100644 --- a/configs/P4080DS_SPIFLASH_defconfig +++ b/configs/P4080DS_SPIFLASH_defconfig @@ -7,6 +7,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SPIFLASH,SYS_TEXT_BASE=0xFFF40000" CONFIG_BOOTDELAY=10 +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GREPENV=y CONFIG_CMD_MMC=y diff --git a/configs/P4080DS_SRIO_PCIE_BOOT_defconfig b/configs/P4080DS_SRIO_PCIE_BOOT_defconfig index 14ca2d8ef9..d0b4f79102 100644 --- a/configs/P4080DS_SRIO_PCIE_BOOT_defconfig +++ b/configs/P4080DS_SRIO_PCIE_BOOT_defconfig @@ -7,6 +7,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SRIO_PCIE_BOOT_SLAVE,SYS_TEXT_BASE=0xFFF40000" CONFIG_BOOTDELAY=10 +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set CONFIG_CMD_GREPENV=y diff --git a/configs/P4080DS_defconfig b/configs/P4080DS_defconfig index b9d89b5339..8bce849606 100644 --- a/configs/P4080DS_defconfig +++ b/configs/P4080DS_defconfig @@ -6,6 +6,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_BOOTDELAY=10 +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GREPENV=y CONFIG_CMD_MMC=y diff --git a/configs/P5020DS_NAND_SECURE_BOOT_defconfig b/configs/P5020DS_NAND_SECURE_BOOT_defconfig index 58290c252e..d5d04d2b74 100644 --- a/configs/P5020DS_NAND_SECURE_BOOT_defconfig +++ b/configs/P5020DS_NAND_SECURE_BOOT_defconfig @@ -10,6 +10,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,NAND,SYS_TEXT_BASE=0xFFF40000" CONFIG_BOOTDELAY=10 CONFIG_BOARD_LATE_INIT=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GREPENV=y CONFIG_CMD_MMC=y diff --git a/configs/P5020DS_NAND_defconfig b/configs/P5020DS_NAND_defconfig index 47da0c0c7f..bf9f2633e8 100644 --- a/configs/P5020DS_NAND_defconfig +++ b/configs/P5020DS_NAND_defconfig @@ -7,6 +7,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,NAND,SYS_TEXT_BASE=0xFFF40000" CONFIG_BOOTDELAY=10 +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GREPENV=y CONFIG_CMD_MMC=y diff --git a/configs/P5020DS_SDCARD_defconfig b/configs/P5020DS_SDCARD_defconfig index a34b35cc16..a97cbbf6a5 100644 --- a/configs/P5020DS_SDCARD_defconfig +++ b/configs/P5020DS_SDCARD_defconfig @@ -7,6 +7,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SDCARD,SYS_TEXT_BASE=0xFFF40000" CONFIG_BOOTDELAY=10 +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GREPENV=y CONFIG_CMD_MMC=y diff --git a/configs/P5020DS_SECURE_BOOT_defconfig b/configs/P5020DS_SECURE_BOOT_defconfig index fe5e987286..36f69d87d0 100644 --- a/configs/P5020DS_SECURE_BOOT_defconfig +++ b/configs/P5020DS_SECURE_BOOT_defconfig @@ -9,6 +9,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_BOOTDELAY=10 CONFIG_BOARD_LATE_INIT=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GREPENV=y CONFIG_CMD_MMC=y diff --git a/configs/P5020DS_SPIFLASH_defconfig b/configs/P5020DS_SPIFLASH_defconfig index fff209aa0a..7f819ed9f5 100644 --- a/configs/P5020DS_SPIFLASH_defconfig +++ b/configs/P5020DS_SPIFLASH_defconfig @@ -7,6 +7,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SPIFLASH,SYS_TEXT_BASE=0xFFF40000" CONFIG_BOOTDELAY=10 +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GREPENV=y CONFIG_CMD_MMC=y diff --git a/configs/P5020DS_SRIO_PCIE_BOOT_defconfig b/configs/P5020DS_SRIO_PCIE_BOOT_defconfig index 286682975a..48e4183252 100644 --- a/configs/P5020DS_SRIO_PCIE_BOOT_defconfig +++ b/configs/P5020DS_SRIO_PCIE_BOOT_defconfig @@ -7,6 +7,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SRIO_PCIE_BOOT_SLAVE,SYS_TEXT_BASE=0xFFF40000" CONFIG_BOOTDELAY=10 +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set CONFIG_CMD_GREPENV=y diff --git a/configs/P5020DS_defconfig b/configs/P5020DS_defconfig index a5f9ba1e02..bf0bc5d77e 100644 --- a/configs/P5020DS_defconfig +++ b/configs/P5020DS_defconfig @@ -6,6 +6,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_BOOTDELAY=10 +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GREPENV=y CONFIG_CMD_MMC=y diff --git a/configs/P5040DS_NAND_SECURE_BOOT_defconfig b/configs/P5040DS_NAND_SECURE_BOOT_defconfig index ec52050244..d46b04dd9d 100644 --- a/configs/P5040DS_NAND_SECURE_BOOT_defconfig +++ b/configs/P5040DS_NAND_SECURE_BOOT_defconfig @@ -10,6 +10,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,NAND,SYS_TEXT_BASE=0xFFF40000" CONFIG_BOOTDELAY=10 CONFIG_BOARD_LATE_INIT=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GREPENV=y CONFIG_CMD_MMC=y diff --git a/configs/P5040DS_NAND_defconfig b/configs/P5040DS_NAND_defconfig index f957701e11..150759dc3b 100644 --- a/configs/P5040DS_NAND_defconfig +++ b/configs/P5040DS_NAND_defconfig @@ -7,6 +7,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,NAND,SYS_TEXT_BASE=0xFFF40000" CONFIG_BOOTDELAY=10 +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GREPENV=y CONFIG_CMD_MMC=y diff --git a/configs/P5040DS_SDCARD_defconfig b/configs/P5040DS_SDCARD_defconfig index c8119c2709..ddf73ed017 100644 --- a/configs/P5040DS_SDCARD_defconfig +++ b/configs/P5040DS_SDCARD_defconfig @@ -7,6 +7,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SDCARD,SYS_TEXT_BASE=0xFFF40000" CONFIG_BOOTDELAY=10 +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GREPENV=y CONFIG_CMD_MMC=y diff --git a/configs/P5040DS_SECURE_BOOT_defconfig b/configs/P5040DS_SECURE_BOOT_defconfig index c0742c764b..9a5ff92514 100644 --- a/configs/P5040DS_SECURE_BOOT_defconfig +++ b/configs/P5040DS_SECURE_BOOT_defconfig @@ -9,6 +9,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_BOOTDELAY=10 CONFIG_BOARD_LATE_INIT=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GREPENV=y CONFIG_CMD_MMC=y diff --git a/configs/P5040DS_SPIFLASH_defconfig b/configs/P5040DS_SPIFLASH_defconfig index 76a68307dc..7743db7faa 100644 --- a/configs/P5040DS_SPIFLASH_defconfig +++ b/configs/P5040DS_SPIFLASH_defconfig @@ -7,6 +7,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SPIFLASH,SYS_TEXT_BASE=0xFFF40000" CONFIG_BOOTDELAY=10 +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GREPENV=y CONFIG_CMD_MMC=y diff --git a/configs/P5040DS_defconfig b/configs/P5040DS_defconfig index 1e5d2a2fbb..fe76c55547 100644 --- a/configs/P5040DS_defconfig +++ b/configs/P5040DS_defconfig @@ -6,6 +6,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_BOOTDELAY=10 +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GREPENV=y CONFIG_CMD_MMC=y diff --git a/configs/PATI_defconfig b/configs/PATI_defconfig index fe0b0b8dd2..d1e5a5e806 100644 --- a/configs/PATI_defconfig +++ b/configs/PATI_defconfig @@ -5,6 +5,7 @@ CONFIG_TARGET_PATI=y CONFIG_BOOTDELAY=5 CONFIG_SYS_CONSOLE_IS_IN_ENV=y # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SYS_PROMPT="pati=> " # CONFIG_CMD_BOOTD is not set # CONFIG_CMD_IMLS is not set diff --git a/configs/PIP405_defconfig b/configs/PIP405_defconfig index 5e54e75667..6a30ac46e5 100644 --- a/configs/PIP405_defconfig +++ b/configs/PIP405_defconfig @@ -9,6 +9,7 @@ CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_SYS_CONSOLE_INFO_QUIET=y # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y diff --git a/configs/PLU405_defconfig b/configs/PLU405_defconfig index f4802b6d99..7b81e7f29b 100644 --- a/configs/PLU405_defconfig +++ b/configs/PLU405_defconfig @@ -5,6 +5,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTDELAY=3 CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Press SPACE to abort autoboot in %d seconds\n" CONFIG_AUTOBOOT_STOP_STR=" " diff --git a/configs/PMC405DE_defconfig b/configs/PMC405DE_defconfig index 8f8a357855..131f447ef4 100644 --- a/configs/PMC405DE_defconfig +++ b/configs/PMC405DE_defconfig @@ -5,6 +5,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTDELAY=3 CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Press SPACE to abort autoboot in %d seconds\n" CONFIG_AUTOBOOT_STOP_STR=" " diff --git a/configs/PMC440_defconfig b/configs/PMC440_defconfig index bc974f9586..90de2b2770 100644 --- a/configs/PMC440_defconfig +++ b/configs/PMC440_defconfig @@ -5,6 +5,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTDELAY=3 CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_VERSION_VARIABLE=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Press SPACE to abort autoboot in %d seconds\n" CONFIG_AUTOBOOT_STOP_STR=" " diff --git a/configs/T1024QDS_DDR4_SECURE_BOOT_defconfig b/configs/T1024QDS_DDR4_SECURE_BOOT_defconfig index c67ecc4134..d660c1a174 100644 --- a/configs/T1024QDS_DDR4_SECURE_BOOT_defconfig +++ b/configs/T1024QDS_DDR4_SECURE_BOOT_defconfig @@ -13,6 +13,7 @@ CONFIG_SILENT_CONSOLE=y # CONFIG_CONSOLE_MUX is not set CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_BOARD_LATE_INIT=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GREPENV=y CONFIG_CMD_MMC=y diff --git a/configs/T1024QDS_DDR4_defconfig b/configs/T1024QDS_DDR4_defconfig index b717fd7ada..ff0375bbed 100644 --- a/configs/T1024QDS_DDR4_defconfig +++ b/configs/T1024QDS_DDR4_defconfig @@ -10,6 +10,7 @@ CONFIG_BOOTDELAY=10 CONFIG_SILENT_CONSOLE=y # CONFIG_CONSOLE_MUX is not set CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GREPENV=y CONFIG_CMD_MMC=y diff --git a/configs/T1024QDS_NAND_defconfig b/configs/T1024QDS_NAND_defconfig index 861025b590..1a5516723a 100644 --- a/configs/T1024QDS_NAND_defconfig +++ b/configs/T1024QDS_NAND_defconfig @@ -18,6 +18,7 @@ CONFIG_BOOTDELAY=10 CONFIG_SILENT_CONSOLE=y # CONFIG_CONSOLE_MUX is not set CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/T1024QDS_SDCARD_defconfig b/configs/T1024QDS_SDCARD_defconfig index cda5f5cda3..0cea32c77f 100644 --- a/configs/T1024QDS_SDCARD_defconfig +++ b/configs/T1024QDS_SDCARD_defconfig @@ -18,6 +18,7 @@ CONFIG_BOOTDELAY=10 CONFIG_SILENT_CONSOLE=y # CONFIG_CONSOLE_MUX is not set CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/T1024QDS_SECURE_BOOT_defconfig b/configs/T1024QDS_SECURE_BOOT_defconfig index dd4b8ab60a..c0c4163339 100644 --- a/configs/T1024QDS_SECURE_BOOT_defconfig +++ b/configs/T1024QDS_SECURE_BOOT_defconfig @@ -13,6 +13,7 @@ CONFIG_SILENT_CONSOLE=y # CONFIG_CONSOLE_MUX is not set CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_BOARD_LATE_INIT=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GREPENV=y CONFIG_CMD_MMC=y diff --git a/configs/T1024QDS_SPIFLASH_defconfig b/configs/T1024QDS_SPIFLASH_defconfig index c4545533d8..4d6b069ea2 100644 --- a/configs/T1024QDS_SPIFLASH_defconfig +++ b/configs/T1024QDS_SPIFLASH_defconfig @@ -19,6 +19,7 @@ CONFIG_BOOTDELAY=10 CONFIG_SILENT_CONSOLE=y # CONFIG_CONSOLE_MUX is not set CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/T1024QDS_defconfig b/configs/T1024QDS_defconfig index 0a9e20cab6..4d80d6a8aa 100644 --- a/configs/T1024QDS_defconfig +++ b/configs/T1024QDS_defconfig @@ -10,6 +10,7 @@ CONFIG_BOOTDELAY=10 CONFIG_SILENT_CONSOLE=y # CONFIG_CONSOLE_MUX is not set CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GREPENV=y CONFIG_CMD_MMC=y diff --git a/configs/T1024RDB_NAND_defconfig b/configs/T1024RDB_NAND_defconfig index bf3f46f5ed..2b29bd2b8f 100644 --- a/configs/T1024RDB_NAND_defconfig +++ b/configs/T1024RDB_NAND_defconfig @@ -16,6 +16,7 @@ CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SPL_FSL_PBL,NAND" CONFIG_BOOTDELAY=10 CONFIG_SILENT_CONSOLE=y CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/T1024RDB_SDCARD_defconfig b/configs/T1024RDB_SDCARD_defconfig index 1c2b362856..0589a3eb62 100644 --- a/configs/T1024RDB_SDCARD_defconfig +++ b/configs/T1024RDB_SDCARD_defconfig @@ -16,6 +16,7 @@ CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SPL_FSL_PBL,SDCARD" CONFIG_BOOTDELAY=10 CONFIG_SILENT_CONSOLE=y CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/T1024RDB_SECURE_BOOT_defconfig b/configs/T1024RDB_SECURE_BOOT_defconfig index 2c574e1db0..c8ec8b7431 100644 --- a/configs/T1024RDB_SECURE_BOOT_defconfig +++ b/configs/T1024RDB_SECURE_BOOT_defconfig @@ -11,6 +11,7 @@ CONFIG_BOOTDELAY=10 CONFIG_SILENT_CONSOLE=y CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_BOARD_LATE_INIT=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GREPENV=y CONFIG_CMD_MEMTEST=y diff --git a/configs/T1024RDB_SPIFLASH_defconfig b/configs/T1024RDB_SPIFLASH_defconfig index 785578085b..1d6532eb98 100644 --- a/configs/T1024RDB_SPIFLASH_defconfig +++ b/configs/T1024RDB_SPIFLASH_defconfig @@ -17,6 +17,7 @@ CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SPL_FSL_PBL,SPIFLASH" CONFIG_BOOTDELAY=10 CONFIG_SILENT_CONSOLE=y CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/T1024RDB_defconfig b/configs/T1024RDB_defconfig index 86eaccc66b..d40f19bdac 100644 --- a/configs/T1024RDB_defconfig +++ b/configs/T1024RDB_defconfig @@ -8,6 +8,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_BOOTDELAY=10 CONFIG_SILENT_CONSOLE=y CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GREPENV=y CONFIG_CMD_MEMTEST=y diff --git a/configs/T1040D4RDB_NAND_defconfig b/configs/T1040D4RDB_NAND_defconfig index f807077742..b43430d1da 100644 --- a/configs/T1040D4RDB_NAND_defconfig +++ b/configs/T1040D4RDB_NAND_defconfig @@ -16,6 +16,7 @@ CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SPL_FSL_PBL,NAND" CONFIG_BOOTDELAY=10 CONFIG_SILENT_CONSOLE=y CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/T1040D4RDB_SDCARD_defconfig b/configs/T1040D4RDB_SDCARD_defconfig index ebba63d3de..ee65197659 100644 --- a/configs/T1040D4RDB_SDCARD_defconfig +++ b/configs/T1040D4RDB_SDCARD_defconfig @@ -16,6 +16,7 @@ CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SPL_FSL_PBL,SDCARD" CONFIG_BOOTDELAY=10 CONFIG_SILENT_CONSOLE=y CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/T1040D4RDB_SECURE_BOOT_defconfig b/configs/T1040D4RDB_SECURE_BOOT_defconfig index 30b0fd25b2..a2f69ad866 100644 --- a/configs/T1040D4RDB_SECURE_BOOT_defconfig +++ b/configs/T1040D4RDB_SECURE_BOOT_defconfig @@ -11,6 +11,7 @@ CONFIG_BOOTDELAY=10 CONFIG_SILENT_CONSOLE=y CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_BOARD_LATE_INIT=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GREPENV=y CONFIG_CMD_MMC=y diff --git a/configs/T1040D4RDB_SPIFLASH_defconfig b/configs/T1040D4RDB_SPIFLASH_defconfig index d0b05b896c..80c6a02c1e 100644 --- a/configs/T1040D4RDB_SPIFLASH_defconfig +++ b/configs/T1040D4RDB_SPIFLASH_defconfig @@ -17,6 +17,7 @@ CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SPL_FSL_PBL,SPIFLASH" CONFIG_BOOTDELAY=10 CONFIG_SILENT_CONSOLE=y CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/T1040D4RDB_defconfig b/configs/T1040D4RDB_defconfig index a0ea45877b..ef7eedad00 100644 --- a/configs/T1040D4RDB_defconfig +++ b/configs/T1040D4RDB_defconfig @@ -8,6 +8,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_BOOTDELAY=10 CONFIG_SILENT_CONSOLE=y CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GREPENV=y CONFIG_CMD_MMC=y diff --git a/configs/T1040QDS_DDR4_defconfig b/configs/T1040QDS_DDR4_defconfig index 1c183f4be3..bd97ae0d1c 100644 --- a/configs/T1040QDS_DDR4_defconfig +++ b/configs/T1040QDS_DDR4_defconfig @@ -10,6 +10,7 @@ CONFIG_BOOTDELAY=10 CONFIG_SILENT_CONSOLE=y # CONFIG_CONSOLE_MUX is not set CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GREPENV=y CONFIG_CMD_MMC=y diff --git a/configs/T1040QDS_SECURE_BOOT_defconfig b/configs/T1040QDS_SECURE_BOOT_defconfig index d64e52de6e..78c36a8ef5 100644 --- a/configs/T1040QDS_SECURE_BOOT_defconfig +++ b/configs/T1040QDS_SECURE_BOOT_defconfig @@ -13,6 +13,7 @@ CONFIG_SILENT_CONSOLE=y # CONFIG_CONSOLE_MUX is not set CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_BOARD_LATE_INIT=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GREPENV=y CONFIG_CMD_MMC=y diff --git a/configs/T1040QDS_defconfig b/configs/T1040QDS_defconfig index 30b0701bda..f15ae68075 100644 --- a/configs/T1040QDS_defconfig +++ b/configs/T1040QDS_defconfig @@ -10,6 +10,7 @@ CONFIG_BOOTDELAY=10 CONFIG_SILENT_CONSOLE=y # CONFIG_CONSOLE_MUX is not set CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GREPENV=y CONFIG_CMD_MMC=y diff --git a/configs/T1040RDB_NAND_defconfig b/configs/T1040RDB_NAND_defconfig index 85b0a4af57..6ec9dad319 100644 --- a/configs/T1040RDB_NAND_defconfig +++ b/configs/T1040RDB_NAND_defconfig @@ -16,6 +16,7 @@ CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SPL_FSL_PBL,NAND" CONFIG_BOOTDELAY=10 CONFIG_SILENT_CONSOLE=y CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/T1040RDB_SDCARD_defconfig b/configs/T1040RDB_SDCARD_defconfig index 1b926c320b..fb190ebb5b 100644 --- a/configs/T1040RDB_SDCARD_defconfig +++ b/configs/T1040RDB_SDCARD_defconfig @@ -16,6 +16,7 @@ CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SPL_FSL_PBL,SDCARD" CONFIG_BOOTDELAY=10 CONFIG_SILENT_CONSOLE=y CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/T1040RDB_SECURE_BOOT_defconfig b/configs/T1040RDB_SECURE_BOOT_defconfig index dff43d413b..85b0297483 100644 --- a/configs/T1040RDB_SECURE_BOOT_defconfig +++ b/configs/T1040RDB_SECURE_BOOT_defconfig @@ -11,6 +11,7 @@ CONFIG_BOOTDELAY=10 CONFIG_SILENT_CONSOLE=y CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_BOARD_LATE_INIT=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GREPENV=y CONFIG_CMD_MMC=y diff --git a/configs/T1040RDB_SPIFLASH_defconfig b/configs/T1040RDB_SPIFLASH_defconfig index 257df4b72e..4cf28eec63 100644 --- a/configs/T1040RDB_SPIFLASH_defconfig +++ b/configs/T1040RDB_SPIFLASH_defconfig @@ -17,6 +17,7 @@ CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SPL_FSL_PBL,SPIFLASH" CONFIG_BOOTDELAY=10 CONFIG_SILENT_CONSOLE=y CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/T1040RDB_defconfig b/configs/T1040RDB_defconfig index 7929c99247..2c84efeaef 100644 --- a/configs/T1040RDB_defconfig +++ b/configs/T1040RDB_defconfig @@ -8,6 +8,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_BOOTDELAY=10 CONFIG_SILENT_CONSOLE=y CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GREPENV=y CONFIG_CMD_MMC=y diff --git a/configs/T1042D4RDB_NAND_defconfig b/configs/T1042D4RDB_NAND_defconfig index 6dcafb1919..fd36b2aa0f 100644 --- a/configs/T1042D4RDB_NAND_defconfig +++ b/configs/T1042D4RDB_NAND_defconfig @@ -18,6 +18,7 @@ CONFIG_BOOTDELAY=10 CONFIG_SILENT_CONSOLE=y # CONFIG_CONSOLE_MUX is not set CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/T1042D4RDB_SDCARD_defconfig b/configs/T1042D4RDB_SDCARD_defconfig index db2b220236..d8e4cef5ef 100644 --- a/configs/T1042D4RDB_SDCARD_defconfig +++ b/configs/T1042D4RDB_SDCARD_defconfig @@ -18,6 +18,7 @@ CONFIG_BOOTDELAY=10 CONFIG_SILENT_CONSOLE=y # CONFIG_CONSOLE_MUX is not set CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/T1042D4RDB_SECURE_BOOT_defconfig b/configs/T1042D4RDB_SECURE_BOOT_defconfig index 71705950bd..d687b47a40 100644 --- a/configs/T1042D4RDB_SECURE_BOOT_defconfig +++ b/configs/T1042D4RDB_SECURE_BOOT_defconfig @@ -13,6 +13,7 @@ CONFIG_SILENT_CONSOLE=y # CONFIG_CONSOLE_MUX is not set CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_BOARD_LATE_INIT=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GREPENV=y CONFIG_CMD_MMC=y diff --git a/configs/T1042D4RDB_SPIFLASH_defconfig b/configs/T1042D4RDB_SPIFLASH_defconfig index 78b036abf8..f962491a9b 100644 --- a/configs/T1042D4RDB_SPIFLASH_defconfig +++ b/configs/T1042D4RDB_SPIFLASH_defconfig @@ -19,6 +19,7 @@ CONFIG_BOOTDELAY=10 CONFIG_SILENT_CONSOLE=y # CONFIG_CONSOLE_MUX is not set CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/T1042D4RDB_defconfig b/configs/T1042D4RDB_defconfig index 5992559f38..1058f3b43a 100644 --- a/configs/T1042D4RDB_defconfig +++ b/configs/T1042D4RDB_defconfig @@ -10,6 +10,7 @@ CONFIG_BOOTDELAY=10 CONFIG_SILENT_CONSOLE=y # CONFIG_CONSOLE_MUX is not set CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GREPENV=y CONFIG_CMD_MMC=y diff --git a/configs/T1042RDB_PI_NAND_SECURE_BOOT_defconfig b/configs/T1042RDB_PI_NAND_SECURE_BOOT_defconfig index 37eb4b0e24..5e94aac3ee 100644 --- a/configs/T1042RDB_PI_NAND_SECURE_BOOT_defconfig +++ b/configs/T1042RDB_PI_NAND_SECURE_BOOT_defconfig @@ -20,6 +20,7 @@ CONFIG_SILENT_CONSOLE=y # CONFIG_CONSOLE_MUX is not set CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_BOARD_LATE_INIT=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y CONFIG_SPL_CRYPTO_SUPPORT=y CONFIG_SPL_HASH_SUPPORT=y diff --git a/configs/T1042RDB_PI_NAND_defconfig b/configs/T1042RDB_PI_NAND_defconfig index 5ea696c588..616cd52984 100644 --- a/configs/T1042RDB_PI_NAND_defconfig +++ b/configs/T1042RDB_PI_NAND_defconfig @@ -18,6 +18,7 @@ CONFIG_BOOTDELAY=10 CONFIG_SILENT_CONSOLE=y # CONFIG_CONSOLE_MUX is not set CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/T1042RDB_PI_SDCARD_defconfig b/configs/T1042RDB_PI_SDCARD_defconfig index f36e0ec5e7..e92edb719c 100644 --- a/configs/T1042RDB_PI_SDCARD_defconfig +++ b/configs/T1042RDB_PI_SDCARD_defconfig @@ -18,6 +18,7 @@ CONFIG_BOOTDELAY=10 CONFIG_SILENT_CONSOLE=y # CONFIG_CONSOLE_MUX is not set CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/T1042RDB_PI_SPIFLASH_defconfig b/configs/T1042RDB_PI_SPIFLASH_defconfig index 39d9fad406..a077a9ad62 100644 --- a/configs/T1042RDB_PI_SPIFLASH_defconfig +++ b/configs/T1042RDB_PI_SPIFLASH_defconfig @@ -19,6 +19,7 @@ CONFIG_BOOTDELAY=10 CONFIG_SILENT_CONSOLE=y # CONFIG_CONSOLE_MUX is not set CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/T1042RDB_PI_defconfig b/configs/T1042RDB_PI_defconfig index 0eee7a5e14..07f67239b3 100644 --- a/configs/T1042RDB_PI_defconfig +++ b/configs/T1042RDB_PI_defconfig @@ -10,6 +10,7 @@ CONFIG_BOOTDELAY=10 CONFIG_SILENT_CONSOLE=y # CONFIG_CONSOLE_MUX is not set CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GREPENV=y CONFIG_CMD_MMC=y diff --git a/configs/T1042RDB_SECURE_BOOT_defconfig b/configs/T1042RDB_SECURE_BOOT_defconfig index 05b8e70788..6fa24068e1 100644 --- a/configs/T1042RDB_SECURE_BOOT_defconfig +++ b/configs/T1042RDB_SECURE_BOOT_defconfig @@ -11,6 +11,7 @@ CONFIG_BOOTDELAY=10 CONFIG_SILENT_CONSOLE=y CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_BOARD_LATE_INIT=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GREPENV=y CONFIG_CMD_MMC=y diff --git a/configs/T1042RDB_defconfig b/configs/T1042RDB_defconfig index 19230e5549..ebf51cd4b0 100644 --- a/configs/T1042RDB_defconfig +++ b/configs/T1042RDB_defconfig @@ -8,6 +8,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_BOOTDELAY=10 CONFIG_SILENT_CONSOLE=y CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GREPENV=y CONFIG_CMD_MMC=y diff --git a/configs/TWR-P1025_defconfig b/configs/TWR-P1025_defconfig index c0ff5d4978..8d2077e3f3 100644 --- a/configs/TWR-P1025_defconfig +++ b/configs/TWR-P1025_defconfig @@ -7,6 +7,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="TWR_P1025" CONFIG_BOOTDELAY=10 +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y diff --git a/configs/UCP1020_SPIFLASH_defconfig b/configs/UCP1020_SPIFLASH_defconfig index 952c0c6aba..fe3d0460b2 100644 --- a/configs/UCP1020_SPIFLASH_defconfig +++ b/configs/UCP1020_SPIFLASH_defconfig @@ -6,6 +6,7 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Autobooting in %d seconds, press "<Esc>" to stop\n" diff --git a/configs/UCP1020_defconfig b/configs/UCP1020_defconfig index 1939f83f7c..5b378d25b7 100644 --- a/configs/UCP1020_defconfig +++ b/configs/UCP1020_defconfig @@ -5,6 +5,7 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="B$ " CONFIG_AUTOBOOT_KEYED=y diff --git a/configs/VOM405_defconfig b/configs/VOM405_defconfig index a826dada83..8bf4648bd5 100644 --- a/configs/VOM405_defconfig +++ b/configs/VOM405_defconfig @@ -5,6 +5,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTDELAY=3 CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y diff --git a/configs/acadia_defconfig b/configs/acadia_defconfig index 1c9c173ed3..269ed2e52b 100644 --- a/configs/acadia_defconfig +++ b/configs/acadia_defconfig @@ -5,6 +5,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTDELAY=5 CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_ASKENV=y CONFIG_CMD_GREPENV=y diff --git a/configs/am335x_evm_norboot_defconfig b/configs/am335x_evm_norboot_defconfig index f408edc885..3eb73f0238 100644 --- a/configs/am335x_evm_norboot_defconfig +++ b/configs/am335x_evm_norboot_defconfig @@ -8,6 +8,7 @@ CONFIG_NOR_BOOT=y CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y CONFIG_BOARD_LATE_INIT=y +CONFIG_BOARD_EARLY_INIT_F=y # CONFIG_CMD_IMLS is not set CONFIG_CMD_ASKENV=y CONFIG_CMD_MMC=y diff --git a/configs/am43xx_evm_qspiboot_defconfig b/configs/am43xx_evm_qspiboot_defconfig index 5fc73fe1e9..24f76256aa 100644 --- a/configs/am43xx_evm_qspiboot_defconfig +++ b/configs/am43xx_evm_qspiboot_defconfig @@ -7,6 +7,7 @@ CONFIG_QSPI_BOOT=y CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y CONFIG_BOARD_LATE_INIT=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/am57xx_evm_defconfig b/configs/am57xx_evm_defconfig index a400b8c2d3..a6d5fa6f5b 100644 --- a/configs/am57xx_evm_defconfig +++ b/configs/am57xx_evm_defconfig @@ -13,6 +13,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y CONFIG_BOARD_LATE_INIT=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y CONFIG_SPL_STACK_R=y CONFIG_SPL_DMA_SUPPORT=y diff --git a/configs/am57xx_evm_nodt_defconfig b/configs/am57xx_evm_nodt_defconfig index be20d6d85c..d732481e52 100644 --- a/configs/am57xx_evm_nodt_defconfig +++ b/configs/am57xx_evm_nodt_defconfig @@ -7,6 +7,7 @@ CONFIG_SPL_SPI_SUPPORT=y CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y CONFIG_BOARD_LATE_INIT=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y CONFIG_SPL_DMA_SUPPORT=y CONFIG_SPL_OS_BOOT=y diff --git a/configs/am57xx_hs_evm_defconfig b/configs/am57xx_hs_evm_defconfig index 4eada9e966..4080204227 100644 --- a/configs/am57xx_hs_evm_defconfig +++ b/configs/am57xx_hs_evm_defconfig @@ -18,6 +18,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y CONFIG_BOARD_LATE_INIT=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y CONFIG_SPL_STACK_R=y CONFIG_SPL_DMA_SUPPORT=y diff --git a/configs/ap121_defconfig b/configs/ap121_defconfig index d21fa04fe6..91ebb3b272 100644 --- a/configs/ap121_defconfig +++ b/configs/ap121_defconfig @@ -4,6 +4,7 @@ CONFIG_ARCH_ATH79=y CONFIG_DEFAULT_DEVICE_TREE="ap121" CONFIG_BOOTDELAY=3 CONFIG_DISPLAY_CPUINFO=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SYS_PROMPT="ap121 # " # CONFIG_CMD_BDI is not set # CONFIG_CMD_CONSOLE is not set diff --git a/configs/ap143_defconfig b/configs/ap143_defconfig index 5bb93508b6..d087c190a8 100644 --- a/configs/ap143_defconfig +++ b/configs/ap143_defconfig @@ -5,6 +5,7 @@ CONFIG_TARGET_AP143=y CONFIG_DEFAULT_DEVICE_TREE="ap143" CONFIG_BOOTDELAY=3 CONFIG_DISPLAY_CPUINFO=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SYS_PROMPT="ap143 # " # CONFIG_CMD_BDI is not set # CONFIG_CMD_CONSOLE is not set diff --git a/configs/apalis_imx6_defconfig b/configs/apalis_imx6_defconfig index 039c9e71c9..7cf59c751d 100644 --- a/configs/apalis_imx6_defconfig +++ b/configs/apalis_imx6_defconfig @@ -13,6 +13,7 @@ CONFIG_BOOTDELAY=1 # CONFIG_CONSOLE_MUX is not set CONFIG_BOARD_LATE_INIT=y # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y CONFIG_SPL_DMA_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/apalis_imx6_nospl_com_defconfig b/configs/apalis_imx6_nospl_com_defconfig index 14957b8dc6..9375cdb1fd 100644 --- a/configs/apalis_imx6_nospl_com_defconfig +++ b/configs/apalis_imx6_nospl_com_defconfig @@ -7,6 +7,7 @@ CONFIG_BOOTDELAY=1 # CONFIG_CONSOLE_MUX is not set CONFIG_BOARD_LATE_INIT=y # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Apalis iMX6 # " CONFIG_CMD_BOOTZ=y diff --git a/configs/apalis_imx6_nospl_it_defconfig b/configs/apalis_imx6_nospl_it_defconfig index b6e0e417cd..94ebb329af 100644 --- a/configs/apalis_imx6_nospl_it_defconfig +++ b/configs/apalis_imx6_nospl_it_defconfig @@ -7,6 +7,7 @@ CONFIG_BOOTDELAY=1 # CONFIG_CONSOLE_MUX is not set CONFIG_BOARD_LATE_INIT=y # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Apalis iMX6 # " CONFIG_CMD_BOOTZ=y diff --git a/configs/apx4devkit_defconfig b/configs/apx4devkit_defconfig index 53d03e16dd..b7d7b50337 100644 --- a/configs/apx4devkit_defconfig +++ b/configs/apx4devkit_defconfig @@ -7,6 +7,7 @@ CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_BOOTDELAY=1 CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set diff --git a/configs/arches_defconfig b/configs/arches_defconfig index 2eb776b01b..7446ca3bac 100644 --- a/configs/arches_defconfig +++ b/configs/arches_defconfig @@ -7,6 +7,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTDELAY=5 CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_ASKENV=y CONFIG_CMD_GREPENV=y diff --git a/configs/aristainetos2_defconfig b/configs/aristainetos2_defconfig index 0ea8708d35..497ddb2335 100644 --- a/configs/aristainetos2_defconfig +++ b/configs/aristainetos2_defconfig @@ -9,6 +9,7 @@ CONFIG_BOOTDELAY=3 CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_BOARD_LATE_INIT=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/aristainetos2b_defconfig b/configs/aristainetos2b_defconfig index b180c0411d..36091475f2 100644 --- a/configs/aristainetos2b_defconfig +++ b/configs/aristainetos2b_defconfig @@ -9,6 +9,7 @@ CONFIG_BOOTDELAY=3 CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_BOARD_LATE_INIT=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/aristainetos_defconfig b/configs/aristainetos_defconfig index 175054c1a3..d8b1afeeae 100644 --- a/configs/aristainetos_defconfig +++ b/configs/aristainetos_defconfig @@ -8,6 +8,7 @@ CONFIG_BOOTDELAY=3 # CONFIG_CONSOLE_MUX is not set CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/aspenite_defconfig b/configs/aspenite_defconfig index 620017bca3..26654426ed 100644 --- a/configs/aspenite_defconfig +++ b/configs/aspenite_defconfig @@ -3,6 +3,7 @@ CONFIG_TARGET_ASPENITE=y CONFIG_IDENT_STRING="\nMarvell-Aspenite DB" CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_BOARD_EARLY_INIT_F=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_I2C=y diff --git a/configs/at91rm9200ek_defconfig b/configs/at91rm9200ek_defconfig index 7b3c520657..05896425d5 100644 --- a/configs/at91rm9200ek_defconfig +++ b/configs/at91rm9200ek_defconfig @@ -5,6 +5,7 @@ CONFIG_BOOTDELAY=3 # CONFIG_SYS_STDIO_DEREGISTER is not set # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " CONFIG_CMD_BOOTZ=y diff --git a/configs/at91rm9200ek_ram_defconfig b/configs/at91rm9200ek_ram_defconfig index 849ef69a28..400127f20b 100644 --- a/configs/at91rm9200ek_ram_defconfig +++ b/configs/at91rm9200ek_ram_defconfig @@ -6,6 +6,7 @@ CONFIG_BOOTDELAY=3 # CONFIG_SYS_STDIO_DEREGISTER is not set # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " CONFIG_CMD_BOOTZ=y diff --git a/configs/atngw100_defconfig b/configs/atngw100_defconfig index 5f991fcc7f..ac7afe184e 100644 --- a/configs/atngw100_defconfig +++ b/configs/atngw100_defconfig @@ -1,6 +1,7 @@ CONFIG_AVR32=y CONFIG_TARGET_ATNGW100=y CONFIG_BOOTDELAY=1 +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SYS_PROMPT="U-Boot> " CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Press SPACE to abort autoboot in %d seconds\n" diff --git a/configs/atngw100mkii_defconfig b/configs/atngw100mkii_defconfig index 55bb5569de..f71b3627b5 100644 --- a/configs/atngw100mkii_defconfig +++ b/configs/atngw100mkii_defconfig @@ -1,6 +1,7 @@ CONFIG_AVR32=y CONFIG_TARGET_ATNGW100MKII=y CONFIG_BOOTDELAY=1 +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SYS_PROMPT="U-Boot> " CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Press SPACE to abort autoboot in %d seconds\n" diff --git a/configs/atstk1002_defconfig b/configs/atstk1002_defconfig index 58189d4097..8f847e1430 100644 --- a/configs/atstk1002_defconfig +++ b/configs/atstk1002_defconfig @@ -1,6 +1,7 @@ CONFIG_AVR32=y CONFIG_TARGET_ATSTK1002=y CONFIG_BOOTDELAY=1 +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SYS_PROMPT="U-Boot> " CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Press SPACE to abort autoboot in %d seconds\n" diff --git a/configs/axm_defconfig b/configs/axm_defconfig index a8b566917d..5b596a2c3f 100644 --- a/configs/axm_defconfig +++ b/configs/axm_defconfig @@ -14,6 +14,7 @@ CONFIG_DEFAULT_DEVICE_TREE="at91sam9g20-taurus" CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9G20,MACH_TYPE=2068,BOARD_AXM" CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_BDI is not set diff --git a/configs/axs101_defconfig b/configs/axs101_defconfig index 317c6fb0c9..1fe9be7942 100644 --- a/configs/axs101_defconfig +++ b/configs/axs101_defconfig @@ -4,6 +4,7 @@ CONFIG_SYS_CLK_FREQ=750000000 CONFIG_SYS_TEXT_BASE=0x81000000 CONFIG_DEFAULT_DEVICE_TREE="axs10x" CONFIG_BOOTDELAY=3 +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SYS_PROMPT="AXS# " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/axs103_defconfig b/configs/axs103_defconfig index 39aa29fec8..4283697321 100644 --- a/configs/axs103_defconfig +++ b/configs/axs103_defconfig @@ -4,6 +4,7 @@ CONFIG_SYS_CLK_FREQ=100000000 CONFIG_SYS_TEXT_BASE=0x81000000 CONFIG_DEFAULT_DEVICE_TREE="axs10x" CONFIG_BOOTDELAY=3 +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SYS_PROMPT="AXS# " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/bamboo_defconfig b/configs/bamboo_defconfig index 614b06a30c..44c398d481 100644 --- a/configs/bamboo_defconfig +++ b/configs/bamboo_defconfig @@ -5,6 +5,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTDELAY=5 CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_ASKENV=y CONFIG_CMD_GREPENV=y diff --git a/configs/bayleybay_defconfig b/configs/bayleybay_defconfig index 8799194f52..0ad2a88720 100644 --- a/configs/bayleybay_defconfig +++ b/configs/bayleybay_defconfig @@ -17,6 +17,7 @@ CONFIG_BOOTSTAGE=y CONFIG_BOOTSTAGE_REPORT=y CONFIG_SYS_CONSOLE_INFO_QUIET=y # CONFIG_ARCH_EARLY_INIT_R is not set +# CONFIG_BOARD_EARLY_INIT_F is not set CONFIG_HUSH_PARSER=y CONFIG_CMD_CPU=y # CONFIG_CMD_IMLS is not set diff --git a/configs/bf506f-ezkit_defconfig b/configs/bf506f-ezkit_defconfig index c36fc5f650..942d50cdb4 100644 --- a/configs/bf506f-ezkit_defconfig +++ b/configs/bf506f-ezkit_defconfig @@ -1,5 +1,6 @@ CONFIG_BLACKFIN=y CONFIG_TARGET_BF506F_EZKIT=y +CONFIG_BOARD_EARLY_INIT_F=y # CONFIG_AUTOBOOT is not set # CONFIG_CMD_BDI is not set # CONFIG_CMD_CONSOLE is not set diff --git a/configs/bf518f-ezbrd_defconfig b/configs/bf518f-ezbrd_defconfig index 73a7ee29c4..72eef2145a 100644 --- a/configs/bf518f-ezbrd_defconfig +++ b/configs/bf518f-ezbrd_defconfig @@ -2,6 +2,7 @@ CONFIG_BLACKFIN=y CONFIG_TARGET_BF518F_EZBRD=y CONFIG_BOOTDELAY=5 CONFIG_SILENT_CONSOLE=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y diff --git a/configs/bf548-ezkit_defconfig b/configs/bf548-ezkit_defconfig index 4d9602132c..f079557c4f 100644 --- a/configs/bf548-ezkit_defconfig +++ b/configs/bf548-ezkit_defconfig @@ -2,6 +2,7 @@ CONFIG_BLACKFIN=y CONFIG_TARGET_BF548_EZKIT=y CONFIG_BOOTDELAY=5 CONFIG_SILENT_CONSOLE=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y diff --git a/configs/bf609-ezkit_defconfig b/configs/bf609-ezkit_defconfig index 8fc0bf9cf3..0b4129ee25 100644 --- a/configs/bf609-ezkit_defconfig +++ b/configs/bf609-ezkit_defconfig @@ -14,6 +14,7 @@ CONFIG_CMD_DNS=y CONFIG_CMD_CACHE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_ATMEL=y CONFIG_SPI_FLASH_EON=y diff --git a/configs/bg0900_defconfig b/configs/bg0900_defconfig index 6caf2e3571..f8e8aa0aee 100644 --- a/configs/bg0900_defconfig +++ b/configs/bg0900_defconfig @@ -7,6 +7,7 @@ CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_BOOTDELAY=3 CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y diff --git a/configs/bk4r1_defconfig b/configs/bk4r1_defconfig index 39a47eafab..964cfed2a7 100644 --- a/configs/bk4r1_defconfig +++ b/configs/bk4r1_defconfig @@ -3,6 +3,7 @@ CONFIG_TARGET_BK4R1=y CONFIG_DEFAULT_DEVICE_TREE="bk4r1" CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/phytec/pcm052/imximage.cfg,ENV_IS_IN_NAND" CONFIG_BOOTDELAY=3 +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/bubinga_defconfig b/configs/bubinga_defconfig index f1f3d584b4..0f9ed19ce7 100644 --- a/configs/bubinga_defconfig +++ b/configs/bubinga_defconfig @@ -5,6 +5,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTDELAY=5 CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_ASKENV=y CONFIG_CMD_GREPENV=y diff --git a/configs/canyonlands_defconfig b/configs/canyonlands_defconfig index 5bd935fa3c..405fd146e0 100644 --- a/configs/canyonlands_defconfig +++ b/configs/canyonlands_defconfig @@ -7,6 +7,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTDELAY=5 CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_ASKENV=y CONFIG_CMD_GREPENV=y diff --git a/configs/cgtqmx6eval_defconfig b/configs/cgtqmx6eval_defconfig index 5d98614a19..2c455461ba 100644 --- a/configs/cgtqmx6eval_defconfig +++ b/configs/cgtqmx6eval_defconfig @@ -20,6 +20,7 @@ CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y # CONFIG_SYS_STDIO_DEREGISTER is not set CONFIG_BOARD_LATE_INIT=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="CGT-QMX6-Quad U-Boot > " diff --git a/configs/cm-bf548_defconfig b/configs/cm-bf548_defconfig index bcf6d8fd05..bafce4539e 100644 --- a/configs/cm-bf548_defconfig +++ b/configs/cm-bf548_defconfig @@ -2,6 +2,7 @@ CONFIG_BLACKFIN=y CONFIG_TARGET_CM_BF548=y CONFIG_BOOTDELAY=5 CONFIG_SILENT_CONSOLE=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_CMD_I2C=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set diff --git a/configs/colibri_imx6_defconfig b/configs/colibri_imx6_defconfig index f8e2a6d91c..f769fa14ab 100644 --- a/configs/colibri_imx6_defconfig +++ b/configs/colibri_imx6_defconfig @@ -13,6 +13,7 @@ CONFIG_BOOTDELAY=1 # CONFIG_CONSOLE_MUX is not set CONFIG_BOARD_LATE_INIT=y # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y CONFIG_SPL_DMA_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/colibri_imx6_nospl_defconfig b/configs/colibri_imx6_nospl_defconfig index f75eaaec4e..1aa5bd13b6 100644 --- a/configs/colibri_imx6_nospl_defconfig +++ b/configs/colibri_imx6_nospl_defconfig @@ -7,6 +7,7 @@ CONFIG_BOOTDELAY=1 # CONFIG_CONSOLE_MUX is not set CONFIG_BOARD_LATE_INIT=y # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Colibri iMX6 # " CONFIG_CMD_BOOTZ=y diff --git a/configs/colibri_vf_defconfig b/configs/colibri_vf_defconfig index 68616df38e..9862b76eef 100644 --- a/configs/colibri_vf_defconfig +++ b/configs/colibri_vf_defconfig @@ -6,6 +6,7 @@ CONFIG_BOOTDELAY=1 CONFIG_VERSION_VARIABLE=y CONFIG_BOARD_LATE_INIT=y # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Colibri VFxx # " CONFIG_CMD_BOOTZ=y diff --git a/configs/controlcenterd_36BIT_SDCARD_DEVELOP_defconfig b/configs/controlcenterd_36BIT_SDCARD_DEVELOP_defconfig index 4b4a905c7b..504de212fa 100644 --- a/configs/controlcenterd_36BIT_SDCARD_DEVELOP_defconfig +++ b/configs/controlcenterd_36BIT_SDCARD_DEVELOP_defconfig @@ -13,6 +13,7 @@ CONFIG_BOOTDELAY=10 # CONFIG_CONSOLE_MUX is not set CONFIG_SYS_CONSOLE_IS_IN_ENV=y # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/controlcenterd_36BIT_SDCARD_defconfig b/configs/controlcenterd_36BIT_SDCARD_defconfig index cc9f40ce4d..fd21c1de7b 100644 --- a/configs/controlcenterd_36BIT_SDCARD_defconfig +++ b/configs/controlcenterd_36BIT_SDCARD_defconfig @@ -13,6 +13,7 @@ CONFIG_BOOTDELAY=10 # CONFIG_CONSOLE_MUX is not set CONFIG_SYS_CONSOLE_IS_IN_ENV=y # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/controlcenterd_TRAILBLAZER_DEVELOP_defconfig b/configs/controlcenterd_TRAILBLAZER_DEVELOP_defconfig index d71e6af603..715282f5ba 100644 --- a/configs/controlcenterd_TRAILBLAZER_DEVELOP_defconfig +++ b/configs/controlcenterd_TRAILBLAZER_DEVELOP_defconfig @@ -6,6 +6,7 @@ CONFIG_SYS_EXTRA_OPTIONS="TRAILBLAZER,SPIFLASH,DEVELOP" CONFIG_BOOTDELAY=-2 CONFIG_SYS_CONSOLE_IS_IN_ENV=y # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_BOARD_EARLY_INIT_F=y # CONFIG_CMD_BOOTM is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/controlcenterd_TRAILBLAZER_defconfig b/configs/controlcenterd_TRAILBLAZER_defconfig index 5c7f2c9f74..051cf82b20 100644 --- a/configs/controlcenterd_TRAILBLAZER_defconfig +++ b/configs/controlcenterd_TRAILBLAZER_defconfig @@ -6,6 +6,7 @@ CONFIG_SYS_EXTRA_OPTIONS="TRAILBLAZER,SPIFLASH" CONFIG_BOOTDELAY=-2 CONFIG_SYS_CONSOLE_IS_IN_ENV=y # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_BOARD_EARLY_INIT_F=y # CONFIG_CMD_BOOTM is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/coreboot-x86_defconfig b/configs/coreboot-x86_defconfig index 2195fc6f24..b03c867032 100644 --- a/configs/coreboot-x86_defconfig +++ b/configs/coreboot-x86_defconfig @@ -5,6 +5,7 @@ CONFIG_FIT=y CONFIG_BOOTSTAGE=y CONFIG_BOOTSTAGE_REPORT=y CONFIG_SYS_CONSOLE_INFO_QUIET=y +# CONFIG_BOARD_EARLY_INIT_F is not set CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/corvus_defconfig b/configs/corvus_defconfig index e0ea3f3c99..29fde62cfd 100644 --- a/configs/corvus_defconfig +++ b/configs/corvus_defconfig @@ -12,6 +12,7 @@ CONFIG_DEFAULT_DEVICE_TREE="at91sam9g45-corvus" CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9M10G45,MACH_TYPE=2066,SYS_USE_NANDFLASH" CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " diff --git a/configs/da850_am18xxevm_defconfig b/configs/da850_am18xxevm_defconfig index 25fcff1829..9fd9a8a891 100644 --- a/configs/da850_am18xxevm_defconfig +++ b/configs/da850_am18xxevm_defconfig @@ -11,6 +11,7 @@ CONFIG_BOOTDELAY=3 CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set diff --git a/configs/da850evm_defconfig b/configs/da850evm_defconfig index e2512ff4e1..aa792a144c 100644 --- a/configs/da850evm_defconfig +++ b/configs/da850evm_defconfig @@ -11,6 +11,7 @@ CONFIG_BOOTDELAY=3 CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot > " diff --git a/configs/da850evm_direct_nor_defconfig b/configs/da850evm_direct_nor_defconfig index 8aa5f167f0..bbae2e4618 100644 --- a/configs/da850evm_direct_nor_defconfig +++ b/configs/da850evm_direct_nor_defconfig @@ -6,6 +6,7 @@ CONFIG_BOOTDELAY=3 CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot > " CONFIG_CMD_ASKENV=y diff --git a/configs/devconcenter_defconfig b/configs/devconcenter_defconfig index 59722ac840..f093f9b9e4 100644 --- a/configs/devconcenter_defconfig +++ b/configs/devconcenter_defconfig @@ -9,6 +9,7 @@ CONFIG_BOOTDELAY=5 CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_ASKENV=y CONFIG_CMD_GREPENV=y diff --git a/configs/devkit3250_defconfig b/configs/devkit3250_defconfig index 539834eed3..45bda5b090 100644 --- a/configs/devkit3250_defconfig +++ b/configs/devkit3250_defconfig @@ -7,6 +7,7 @@ CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_BOOTDELAY=1 CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_CMD_SPI=y diff --git a/configs/dlvision-10g_defconfig b/configs/dlvision-10g_defconfig index 29032f11da..b881a7925a 100644 --- a/configs/dlvision-10g_defconfig +++ b/configs/dlvision-10g_defconfig @@ -9,6 +9,7 @@ CONFIG_BOOTDELAY=5 CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_STOP_STR=" " diff --git a/configs/dlvision_defconfig b/configs/dlvision_defconfig index e18923ce78..d045a9f5eb 100644 --- a/configs/dlvision_defconfig +++ b/configs/dlvision_defconfig @@ -9,6 +9,7 @@ CONFIG_BOOTDELAY=5 CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_ELF is not set CONFIG_CMD_ASKENV=y diff --git a/configs/dms-ba16-1g_defconfig b/configs/dms-ba16-1g_defconfig index 38ee78dba7..92f7303476 100644 --- a/configs/dms-ba16-1g_defconfig +++ b/configs/dms-ba16-1g_defconfig @@ -10,6 +10,7 @@ CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y # CONFIG_SYS_STDIO_DEREGISTER is not set CONFIG_DEFAULT_FDT_FILE="imx6q-dms-ba16.dtb" CONFIG_BOARD_LATE_INIT=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/dms-ba16_defconfig b/configs/dms-ba16_defconfig index 2a0ba5bef7..51307062b9 100644 --- a/configs/dms-ba16_defconfig +++ b/configs/dms-ba16_defconfig @@ -9,6 +9,7 @@ CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y # CONFIG_SYS_STDIO_DEREGISTER is not set CONFIG_DEFAULT_FDT_FILE="imx6q-dms-ba16.dtb" CONFIG_BOARD_LATE_INIT=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/dra7xx_evm_defconfig b/configs/dra7xx_evm_defconfig index 150ef0a3f9..06da7b11c3 100644 --- a/configs/dra7xx_evm_defconfig +++ b/configs/dra7xx_evm_defconfig @@ -13,6 +13,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y CONFIG_BOARD_LATE_INIT=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y CONFIG_SPL_STACK_R=y CONFIG_SPL_DMA_SUPPORT=y diff --git a/configs/dra7xx_hs_evm_defconfig b/configs/dra7xx_hs_evm_defconfig index 42261f5b80..091808b48a 100644 --- a/configs/dra7xx_hs_evm_defconfig +++ b/configs/dra7xx_hs_evm_defconfig @@ -19,6 +19,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y CONFIG_BOARD_LATE_INIT=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y CONFIG_SPL_STACK_R=y CONFIG_SPL_DMA_SUPPORT=y diff --git a/configs/ea20_defconfig b/configs/ea20_defconfig index e9d6788040..00c59e087a 100644 --- a/configs/ea20_defconfig +++ b/configs/ea20_defconfig @@ -11,6 +11,7 @@ CONFIG_VERSION_VARIABLE=y CONFIG_BOARD_LATE_INIT=y # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="ea20 > " # CONFIG_CMD_IMLS is not set diff --git a/configs/edb9315a_defconfig b/configs/edb9315a_defconfig index 0d24e8fb51..bbad18aa26 100644 --- a/configs/edb9315a_defconfig +++ b/configs/edb9315a_defconfig @@ -3,6 +3,7 @@ CONFIG_TARGET_EDB93XX=y CONFIG_SYS_EXTRA_OPTIONS="MK_edb9315a" # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="EDB9315A> " CONFIG_CMD_BOOTZ=y diff --git a/configs/efi-x86_defconfig b/configs/efi-x86_defconfig index 79f4df2a62..e5778d6e12 100644 --- a/configs/efi-x86_defconfig +++ b/configs/efi-x86_defconfig @@ -6,6 +6,7 @@ CONFIG_FIT=y CONFIG_CONSOLE_MUX=y CONFIG_SYS_CONSOLE_INFO_QUIET=y # CONFIG_ARCH_EARLY_INIT_R is not set +# CONFIG_BOARD_EARLY_INIT_F is not set CONFIG_HUSH_PARSER=y # CONFIG_CMD_BOOTM is not set # CONFIG_CMD_IMLS is not set diff --git a/configs/flea3_defconfig b/configs/flea3_defconfig index 47dfc0c349..9360f3ba00 100644 --- a/configs/flea3_defconfig +++ b/configs/flea3_defconfig @@ -4,6 +4,7 @@ CONFIG_FIT=y CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="flea3 U-Boot > " CONFIG_CMD_SPI=y diff --git a/configs/fo300_defconfig b/configs/fo300_defconfig index 81ecbd4700..2dfb7c2aaa 100644 --- a/configs/fo300_defconfig +++ b/configs/fo300_defconfig @@ -8,6 +8,7 @@ CONFIG_BOOTDELAY=5 CONFIG_SILENT_CONSOLE=y # CONFIG_CONSOLE_MUX is not set CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_ASKENV=y CONFIG_LOOPW=y diff --git a/configs/gdppc440etx_defconfig b/configs/gdppc440etx_defconfig index 8c10383b0d..86d4718cf3 100644 --- a/configs/gdppc440etx_defconfig +++ b/configs/gdppc440etx_defconfig @@ -6,6 +6,7 @@ CONFIG_BOOTDELAY=5 CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_STOP_STR=" " diff --git a/configs/ge_b450v3_defconfig b/configs/ge_b450v3_defconfig index d131504090..2891d0d3c3 100644 --- a/configs/ge_b450v3_defconfig +++ b/configs/ge_b450v3_defconfig @@ -7,6 +7,7 @@ CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_DEFAULT_FDT_FILE="/boot/imx6q-b450v3.dtb" CONFIG_BOARD_LATE_INIT=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/ge_b650v3_defconfig b/configs/ge_b650v3_defconfig index bbab3c1872..24d26e900a 100644 --- a/configs/ge_b650v3_defconfig +++ b/configs/ge_b650v3_defconfig @@ -7,6 +7,7 @@ CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_DEFAULT_FDT_FILE="/boot/imx6q-b650v3.dtb" CONFIG_BOARD_LATE_INIT=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/ge_b850v3_defconfig b/configs/ge_b850v3_defconfig index 9e7b66e02c..a76d7c4456 100644 --- a/configs/ge_b850v3_defconfig +++ b/configs/ge_b850v3_defconfig @@ -7,6 +7,7 @@ CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_DEFAULT_FDT_FILE="/boot/imx6q-b850v3.dtb" CONFIG_BOARD_LATE_INIT=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/glacier_defconfig b/configs/glacier_defconfig index e19cb7e602..45e3c61017 100644 --- a/configs/glacier_defconfig +++ b/configs/glacier_defconfig @@ -7,6 +7,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTDELAY=5 CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_ASKENV=y CONFIG_CMD_GREPENV=y diff --git a/configs/glacier_ramboot_defconfig b/configs/glacier_ramboot_defconfig index 9911729db3..33ea6ae064 100644 --- a/configs/glacier_ramboot_defconfig +++ b/configs/glacier_ramboot_defconfig @@ -8,6 +8,7 @@ CONFIG_SYS_EXTRA_OPTIONS="SYS_RAMBOOT,SYS_TEXT_BASE=0x01000000,SYS_LDSCRIPT=boar CONFIG_BOOTDELAY=5 CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_ASKENV=y CONFIG_CMD_GREPENV=y diff --git a/configs/gplugd_defconfig b/configs/gplugd_defconfig index 286c0b050e..9584e27496 100644 --- a/configs/gplugd_defconfig +++ b/configs/gplugd_defconfig @@ -3,6 +3,7 @@ CONFIG_TARGET_GPLUGD=y CONFIG_IDENT_STRING="\nMarvell-gplugD" CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_BOARD_EARLY_INIT_F=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_I2C=y diff --git a/configs/grasshopper_defconfig b/configs/grasshopper_defconfig index 26b8a1f583..784eada1b7 100644 --- a/configs/grasshopper_defconfig +++ b/configs/grasshopper_defconfig @@ -1,6 +1,7 @@ CONFIG_AVR32=y CONFIG_TARGET_GRASSHOPPER=y CONFIG_BOOTDELAY=1 +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " CONFIG_AUTOBOOT_KEYED=y diff --git a/configs/gurnard_defconfig b/configs/gurnard_defconfig index 0c10a2c4a9..e90d397631 100644 --- a/configs/gurnard_defconfig +++ b/configs/gurnard_defconfig @@ -7,6 +7,7 @@ CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9G45" CONFIG_BOOTDELAY=3 CONFIG_BOARD_LATE_INIT=y # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_BDI is not set # CONFIG_CMD_IMI is not set diff --git a/configs/gwventana_defconfig b/configs/gwventana_defconfig index 0819a22d8d..6cc58970cd 100644 --- a/configs/gwventana_defconfig +++ b/configs/gwventana_defconfig @@ -19,6 +19,7 @@ CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,MX6QDL" CONFIG_BOOTDELAY=3 # CONFIG_SYS_STDIO_DEREGISTER is not set # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y CONFIG_SPL_STACK_R=y CONFIG_SPL_DMA_SUPPORT=y diff --git a/configs/haleakala_defconfig b/configs/haleakala_defconfig index 8a195581f4..0d9e75dc2c 100644 --- a/configs/haleakala_defconfig +++ b/configs/haleakala_defconfig @@ -7,6 +7,7 @@ CONFIG_BOOTDELAY=5 CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_ASKENV=y CONFIG_CMD_GREPENV=y diff --git a/configs/hikey_defconfig b/configs/hikey_defconfig index 539c7d31e9..8dd330ad75 100644 --- a/configs/hikey_defconfig +++ b/configs/hikey_defconfig @@ -5,6 +5,7 @@ CONFIG_DEFAULT_DEVICE_TREE="hi6220-hikey" CONFIG_DISTRO_DEFAULTS=y # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_BOARD_EARLY_INIT_F=y # CONFIG_CMD_IMLS is not set CONFIG_CMD_MMC=y CONFIG_CMD_USB=y diff --git a/configs/hrcon_defconfig b/configs/hrcon_defconfig index 4e920191f9..1d5950196d 100644 --- a/configs/hrcon_defconfig +++ b/configs/hrcon_defconfig @@ -9,6 +9,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_BOOTDELAY=5 CONFIG_SYS_CONSOLE_INFO_QUIET=y # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_STOP_STR=" " diff --git a/configs/hrcon_dh_defconfig b/configs/hrcon_dh_defconfig index d7c9ee1020..e05ba96dcc 100644 --- a/configs/hrcon_dh_defconfig +++ b/configs/hrcon_dh_defconfig @@ -10,6 +10,7 @@ CONFIG_SYS_EXTRA_OPTIONS="HRCON_DH" CONFIG_BOOTDELAY=5 CONFIG_SYS_CONSOLE_INFO_QUIET=y # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y diff --git a/configs/icon_defconfig b/configs/icon_defconfig index 19080d7c3f..6588cef64b 100644 --- a/configs/icon_defconfig +++ b/configs/icon_defconfig @@ -8,6 +8,7 @@ CONFIG_BOOTDELAY=5 CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_ASKENV=y CONFIG_CMD_GREPENV=y diff --git a/configs/intip_defconfig b/configs/intip_defconfig index 3ce0ec8259..368e203180 100644 --- a/configs/intip_defconfig +++ b/configs/intip_defconfig @@ -9,6 +9,7 @@ CONFIG_BOOTDELAY=5 CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_STOP_STR=" " diff --git a/configs/io64_defconfig b/configs/io64_defconfig index 6b22ab6a02..172e3d5a9d 100644 --- a/configs/io64_defconfig +++ b/configs/io64_defconfig @@ -10,6 +10,7 @@ CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_STOP_STR=" " diff --git a/configs/io_defconfig b/configs/io_defconfig index 6c5ebc3a5b..b293fdb7ac 100644 --- a/configs/io_defconfig +++ b/configs/io_defconfig @@ -9,6 +9,7 @@ CONFIG_BOOTDELAY=5 CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_STOP_STR=" " diff --git a/configs/iocon_defconfig b/configs/iocon_defconfig index cb36cd8d79..049f201848 100644 --- a/configs/iocon_defconfig +++ b/configs/iocon_defconfig @@ -8,6 +8,7 @@ CONFIG_BOOTDELAY=5 CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_STOP_STR=" " diff --git a/configs/ipam390_defconfig b/configs/ipam390_defconfig index faa9709370..7b2445ae22 100644 --- a/configs/ipam390_defconfig +++ b/configs/ipam390_defconfig @@ -9,6 +9,7 @@ CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y CONFIG_SPL_OS_BOOT=y CONFIG_HUSH_PARSER=y diff --git a/configs/jupiter_defconfig b/configs/jupiter_defconfig index 7c9186e2aa..4953f030fe 100644 --- a/configs/jupiter_defconfig +++ b/configs/jupiter_defconfig @@ -2,6 +2,7 @@ CONFIG_PPC=y CONFIG_MPC5xxx=y CONFIG_TARGET_JUPITER=y CONFIG_BOOTDELAY=5 +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_SNTP=y diff --git a/configs/k2e_evm_defconfig b/configs/k2e_evm_defconfig index 5fb3e71fb4..e9284c6cae 100644 --- a/configs/k2e_evm_defconfig +++ b/configs/k2e_evm_defconfig @@ -12,6 +12,7 @@ CONFIG_DEFAULT_DEVICE_TREE="k2e-evm" CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="K2E EVM # " diff --git a/configs/k2g_evm_defconfig b/configs/k2g_evm_defconfig index b5cc9ef061..5251105b6e 100644 --- a/configs/k2g_evm_defconfig +++ b/configs/k2g_evm_defconfig @@ -12,6 +12,7 @@ CONFIG_DEFAULT_DEVICE_TREE="k2g-evm" CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y diff --git a/configs/k2hk_evm_defconfig b/configs/k2hk_evm_defconfig index fd2da4b65d..e2868d6574 100644 --- a/configs/k2hk_evm_defconfig +++ b/configs/k2hk_evm_defconfig @@ -12,6 +12,7 @@ CONFIG_DEFAULT_DEVICE_TREE="k2hk-evm" CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="K2HK EVM # " diff --git a/configs/k2l_evm_defconfig b/configs/k2l_evm_defconfig index 95152b5e28..bba5f66fe5 100644 --- a/configs/k2l_evm_defconfig +++ b/configs/k2l_evm_defconfig @@ -12,6 +12,7 @@ CONFIG_DEFAULT_DEVICE_TREE="k2l-evm" CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="K2L EVM # " diff --git a/configs/katmai_defconfig b/configs/katmai_defconfig index 816d1b3202..a2c5ab3ff8 100644 --- a/configs/katmai_defconfig +++ b/configs/katmai_defconfig @@ -5,6 +5,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTDELAY=5 CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_ASKENV=y CONFIG_CMD_GREPENV=y diff --git a/configs/kilauea_defconfig b/configs/kilauea_defconfig index 8d4978ebed..5d47061abf 100644 --- a/configs/kilauea_defconfig +++ b/configs/kilauea_defconfig @@ -7,6 +7,7 @@ CONFIG_BOOTDELAY=5 CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_ASKENV=y CONFIG_CMD_GREPENV=y diff --git a/configs/kmcoge4_defconfig b/configs/kmcoge4_defconfig index d4b403bb08..b17822648e 100644 --- a/configs/kmcoge4_defconfig +++ b/configs/kmcoge4_defconfig @@ -7,6 +7,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="KMCOGE4" CONFIG_VERSION_VARIABLE=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Hit <SPACE> key to stop autoboot in %2ds\n" diff --git a/configs/kmlion1_defconfig b/configs/kmlion1_defconfig index a6a4db3eae..3097b34ea6 100644 --- a/configs/kmlion1_defconfig +++ b/configs/kmlion1_defconfig @@ -7,6 +7,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="KMLION1" CONFIG_VERSION_VARIABLE=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Hit <SPACE> key to stop autoboot in %2ds\n" diff --git a/configs/legoev3_defconfig b/configs/legoev3_defconfig index 8b01405158..510c4c5bf6 100644 --- a/configs/legoev3_defconfig +++ b/configs/legoev3_defconfig @@ -5,6 +5,7 @@ CONFIG_BOOTDELAY=0 CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Autoboot in %d seconds - press 'l' to stop...\n" diff --git a/configs/liteboard_defconfig b/configs/liteboard_defconfig index 5a46d1f45d..930d363125 100644 --- a/configs/liteboard_defconfig +++ b/configs/liteboard_defconfig @@ -11,6 +11,7 @@ CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg" CONFIG_BOOTDELAY=1 CONFIG_DEFAULT_FDT_FILE="imx6ul-liteboard.dtb" CONFIG_BOARD_LATE_INIT=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y diff --git a/configs/ls1021aiot_qspi_defconfig b/configs/ls1021aiot_qspi_defconfig index a526476b36..9ba702626e 100644 --- a/configs/ls1021aiot_qspi_defconfig +++ b/configs/ls1021aiot_qspi_defconfig @@ -3,6 +3,7 @@ CONFIG_TARGET_LS1021AIOT=y CONFIG_DEFAULT_DEVICE_TREE="ls1021a-iot-duart" CONFIG_SYS_EXTRA_OPTIONS="QSPI_BOOT" CONFIG_BOARD_LATE_INIT=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_SPI_FLASH=y diff --git a/configs/ls1021aiot_sdcard_defconfig b/configs/ls1021aiot_sdcard_defconfig index 5c3c23ca5e..4e138d65fd 100644 --- a/configs/ls1021aiot_sdcard_defconfig +++ b/configs/ls1021aiot_sdcard_defconfig @@ -3,6 +3,7 @@ CONFIG_TARGET_LS1021AIOT=y CONFIG_DEFAULT_DEVICE_TREE="ls1021a-iot-duart" CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SPL_FSL_PBL,SD_BOOT,SD_BOOT_QSPI" CONFIG_BOARD_LATE_INIT=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0xe8 diff --git a/configs/luan_defconfig b/configs/luan_defconfig index 5abcf3ad98..9c39625864 100644 --- a/configs/luan_defconfig +++ b/configs/luan_defconfig @@ -5,6 +5,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTDELAY=5 CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_ASKENV=y CONFIG_CMD_GREPENV=y diff --git a/configs/lwmon5_defconfig b/configs/lwmon5_defconfig index 735e25fa20..4526a5ab69 100644 --- a/configs/lwmon5_defconfig +++ b/configs/lwmon5_defconfig @@ -10,6 +10,7 @@ CONFIG_BOOTDELAY=5 CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_ASKENV=y CONFIG_LOOPW=y diff --git a/configs/m28evk_defconfig b/configs/m28evk_defconfig index e69a262ba7..1560f00311 100644 --- a/configs/m28evk_defconfig +++ b/configs/m28evk_defconfig @@ -11,6 +11,7 @@ CONFIG_BOOTDELAY=3 CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set diff --git a/configs/ma5d4evk_defconfig b/configs/ma5d4evk_defconfig index e2a68fb160..adeab1a0e9 100644 --- a/configs/ma5d4evk_defconfig +++ b/configs/ma5d4evk_defconfig @@ -12,6 +12,7 @@ CONFIG_SYS_EXTRA_OPTIONS="SAMA5D4" CONFIG_BOOTDELAY=3 CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y diff --git a/configs/makalu_defconfig b/configs/makalu_defconfig index 966c3077de..2f79e74ddd 100644 --- a/configs/makalu_defconfig +++ b/configs/makalu_defconfig @@ -6,6 +6,7 @@ CONFIG_BOOTDELAY=5 CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_ASKENV=y CONFIG_CMD_GREPENV=y diff --git a/configs/malta64_defconfig b/configs/malta64_defconfig index 4308b4f86f..440a1b4227 100644 --- a/configs/malta64_defconfig +++ b/configs/malta64_defconfig @@ -2,6 +2,7 @@ CONFIG_MIPS=y CONFIG_TARGET_MALTA=y CONFIG_CPU_MIPS64_R2=y CONFIG_DEFAULT_DEVICE_TREE="mti,malta" +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="malta # " # CONFIG_AUTOBOOT is not set diff --git a/configs/malta64el_defconfig b/configs/malta64el_defconfig index b3b1401a89..cd8dc1407c 100644 --- a/configs/malta64el_defconfig +++ b/configs/malta64el_defconfig @@ -3,6 +3,7 @@ CONFIG_TARGET_MALTA=y CONFIG_SYS_LITTLE_ENDIAN=y CONFIG_CPU_MIPS64_R2=y CONFIG_DEFAULT_DEVICE_TREE="mti,malta" +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="maltael # " # CONFIG_AUTOBOOT is not set diff --git a/configs/malta_defconfig b/configs/malta_defconfig index f1c8118115..e848f42e45 100644 --- a/configs/malta_defconfig +++ b/configs/malta_defconfig @@ -1,6 +1,7 @@ CONFIG_MIPS=y CONFIG_TARGET_MALTA=y CONFIG_DEFAULT_DEVICE_TREE="mti,malta" +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="malta # " # CONFIG_AUTOBOOT is not set diff --git a/configs/maltael_defconfig b/configs/maltael_defconfig index 88012c7538..a8df759986 100644 --- a/configs/maltael_defconfig +++ b/configs/maltael_defconfig @@ -2,6 +2,7 @@ CONFIG_MIPS=y CONFIG_TARGET_MALTA=y CONFIG_SYS_LITTLE_ENDIAN=y CONFIG_DEFAULT_DEVICE_TREE="mti,malta" +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="maltael # " # CONFIG_AUTOBOOT is not set diff --git a/configs/marsboard_defconfig b/configs/marsboard_defconfig index 656fdfba5f..70b0968b13 100644 --- a/configs/marsboard_defconfig +++ b/configs/marsboard_defconfig @@ -8,6 +8,7 @@ CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6q.cfg,MX CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_BOARD_LATE_INIT=y +CONFIG_BOARD_EARLY_INIT_F=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_MMC=y diff --git a/configs/mecp5123_defconfig b/configs/mecp5123_defconfig index ca56b64f5b..a9e8a19b76 100644 --- a/configs/mecp5123_defconfig +++ b/configs/mecp5123_defconfig @@ -3,6 +3,7 @@ CONFIG_MPC512X=y CONFIG_TARGET_MECP5123=y CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTDELAY=5 +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_ASKENV=y CONFIG_CMD_I2C=y diff --git a/configs/meesc_dataflash_defconfig b/configs/meesc_dataflash_defconfig index 8f2c834f3a..de8a8cbf0a 100644 --- a/configs/meesc_dataflash_defconfig +++ b/configs/meesc_dataflash_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_MEESC=y CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9263,SYS_USE_DATAFLASH" CONFIG_BOOTDELAY=3 +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_BDI is not set CONFIG_CMD_BOOTZ=y diff --git a/configs/meesc_defconfig b/configs/meesc_defconfig index 0b162e8809..12482bf795 100644 --- a/configs/meesc_defconfig +++ b/configs/meesc_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_MEESC=y CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9263,SYS_USE_NANDFLASH" CONFIG_BOOTDELAY=3 +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_BDI is not set CONFIG_CMD_BOOTZ=y diff --git a/configs/minnowmax_defconfig b/configs/minnowmax_defconfig index 2589050b0a..9215bca362 100644 --- a/configs/minnowmax_defconfig +++ b/configs/minnowmax_defconfig @@ -16,7 +16,7 @@ CONFIG_FIT_SIGNATURE=y CONFIG_BOOTSTAGE=y CONFIG_BOOTSTAGE_REPORT=y CONFIG_SYS_CONSOLE_INFO_QUIET=y -CONFIG_ARCH_EARLY_INIT_R=y +# CONFIG_BOARD_EARLY_INIT_F is not set CONFIG_HUSH_PARSER=y CONFIG_CMD_CPU=y # CONFIG_CMD_IMLS is not set diff --git a/configs/mpc5121ads_defconfig b/configs/mpc5121ads_defconfig index f09f2e9d5e..64204fac90 100644 --- a/configs/mpc5121ads_defconfig +++ b/configs/mpc5121ads_defconfig @@ -3,6 +3,7 @@ CONFIG_MPC512X=y CONFIG_TARGET_MPC5121ADS=y CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTDELAY=5 +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_ASKENV=y CONFIG_CMD_I2C=y diff --git a/configs/mpc5121ads_rev2_defconfig b/configs/mpc5121ads_rev2_defconfig index 4e1c9840b3..598f599b28 100644 --- a/configs/mpc5121ads_rev2_defconfig +++ b/configs/mpc5121ads_rev2_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_MPC5121ADS=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="MPC5121ADS_REV2" CONFIG_BOOTDELAY=5 +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_ASKENV=y CONFIG_CMD_I2C=y diff --git a/configs/mvebu_db-88f3720_defconfig b/configs/mvebu_db-88f3720_defconfig index 337c4512c9..fa3269a0c6 100644 --- a/configs/mvebu_db-88f3720_defconfig +++ b/configs/mvebu_db-88f3720_defconfig @@ -9,6 +9,7 @@ CONFIG_SYS_CONSOLE_INFO_QUIET=y # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_ARCH_EARLY_INIT_R=y +CONFIG_BOARD_EARLY_INIT_F=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_SF=y diff --git a/configs/mvebu_db-88f7040_defconfig b/configs/mvebu_db-88f7040_defconfig index 0ba00c2adf..71fd7b5d88 100644 --- a/configs/mvebu_db-88f7040_defconfig +++ b/configs/mvebu_db-88f7040_defconfig @@ -11,6 +11,7 @@ CONFIG_BOARD_LATE_INIT=y # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_ARCH_EARLY_INIT_R=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/mvebu_db-88f8040_defconfig b/configs/mvebu_db-88f8040_defconfig index f375f2c725..4ef5892803 100644 --- a/configs/mvebu_db-88f8040_defconfig +++ b/configs/mvebu_db-88f8040_defconfig @@ -11,6 +11,7 @@ CONFIG_BOARD_LATE_INIT=y # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_ARCH_EARLY_INIT_R=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/mx35pdk_defconfig b/configs/mx35pdk_defconfig index 948ae844ad..f382e4c4b6 100644 --- a/configs/mx35pdk_defconfig +++ b/configs/mx35pdk_defconfig @@ -3,6 +3,7 @@ CONFIG_TARGET_MX35PDK=y CONFIG_BOOTDELAY=1 CONFIG_BOARD_LATE_INIT=y # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y CONFIG_CMD_MMC=y diff --git a/configs/mx6cuboxi_defconfig b/configs/mx6cuboxi_defconfig index 6f4da5e86c..c66b7e69c5 100644 --- a/configs/mx6cuboxi_defconfig +++ b/configs/mx6cuboxi_defconfig @@ -15,6 +15,7 @@ CONFIG_DISTRO_DEFAULTS=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,MX6QDL" # CONFIG_SYS_STDIO_DEREGISTER is not set CONFIG_BOARD_LATE_INIT=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/mx6dlarm2_defconfig b/configs/mx6dlarm2_defconfig index 9ba7599ecb..e370c41f77 100644 --- a/configs/mx6dlarm2_defconfig +++ b/configs/mx6dlarm2_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_MX6=y CONFIG_TARGET_MX6QARM2=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx6qarm2/imximage_mx6dl.cfg,MX6DL,DDR_MB=2048" CONFIG_BOOTDELAY=3 +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/mx6dlarm2_lpddr2_defconfig b/configs/mx6dlarm2_lpddr2_defconfig index 89b7bbb60e..c507278686 100644 --- a/configs/mx6dlarm2_lpddr2_defconfig +++ b/configs/mx6dlarm2_lpddr2_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_MX6=y CONFIG_TARGET_MX6QARM2=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx6qarm2/imximage_mx6dl.cfg,MX6DL,MX6DL_LPDDR2,DDR_MB=512" CONFIG_BOOTDELAY=3 +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/mx6qarm2_defconfig b/configs/mx6qarm2_defconfig index 0dbbfa77ed..e0e99188fb 100644 --- a/configs/mx6qarm2_defconfig +++ b/configs/mx6qarm2_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_MX6=y CONFIG_TARGET_MX6QARM2=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx6qarm2/imximage.cfg,MX6Q,DDR_MB=2048" CONFIG_BOOTDELAY=3 +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/mx6qarm2_lpddr2_defconfig b/configs/mx6qarm2_lpddr2_defconfig index a3694b0e92..0f80ba19a9 100644 --- a/configs/mx6qarm2_lpddr2_defconfig +++ b/configs/mx6qarm2_lpddr2_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_MX6=y CONFIG_TARGET_MX6QARM2=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx6qarm2/imximage.cfg,MX6Q,MX6DQ_LPDDR2,DDR_MB=512" CONFIG_BOOTDELAY=3 +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/mx6qsabrelite_defconfig b/configs/mx6qsabrelite_defconfig index d0ecdb9cda..fe633fcbbd 100644 --- a/configs/mx6qsabrelite_defconfig +++ b/configs/mx6qsabrelite_defconfig @@ -6,6 +6,7 @@ CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6q.cfg,MX CONFIG_BOOTDELAY=3 CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y # CONFIG_SYS_STDIO_DEREGISTER is not set +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/mx6slevk_defconfig b/configs/mx6slevk_defconfig index f4b0e1e842..39bcabad28 100644 --- a/configs/mx6slevk_defconfig +++ b/configs/mx6slevk_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_MX6=y CONFIG_TARGET_MX6SLEVK=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx6slevk/imximage.cfg,MX6SL" CONFIG_BOOTDELAY=3 +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/mx6slevk_spinor_defconfig b/configs/mx6slevk_spinor_defconfig index 00dbebdd60..7c0a3a801a 100644 --- a/configs/mx6slevk_spinor_defconfig +++ b/configs/mx6slevk_spinor_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_MX6=y CONFIG_TARGET_MX6SLEVK=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx6slevk/imximage.cfg,MX6SL,SYS_BOOT_SPINOR" CONFIG_BOOTDELAY=3 +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/mx6slevk_spl_defconfig b/configs/mx6slevk_spl_defconfig index 4dd24842cb..29e179da7c 100644 --- a/configs/mx6slevk_spl_defconfig +++ b/configs/mx6slevk_spl_defconfig @@ -12,6 +12,7 @@ CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,SPL,MX6SL" CONFIG_BOOTDELAY=3 +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y diff --git a/configs/mx6sllevk_defconfig b/configs/mx6sllevk_defconfig index bffcf3099c..9f32a72f79 100644 --- a/configs/mx6sllevk_defconfig +++ b/configs/mx6sllevk_defconfig @@ -5,6 +5,7 @@ CONFIG_DEFAULT_DEVICE_TREE="imx6sll-evk" CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx6sllevk/imximage.cfg" CONFIG_BOOTDELAY=3 CONFIG_BOARD_LATE_INIT=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/mx6sllevk_plugin_defconfig b/configs/mx6sllevk_plugin_defconfig index 99d160bb5a..5f042dbce6 100644 --- a/configs/mx6sllevk_plugin_defconfig +++ b/configs/mx6sllevk_plugin_defconfig @@ -6,6 +6,7 @@ CONFIG_DEFAULT_DEVICE_TREE="imx6sll-evk" CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx6sllevk/imximage.cfg" CONFIG_BOOTDELAY=3 CONFIG_BOARD_LATE_INIT=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/mx6ul_14x14_evk_defconfig b/configs/mx6ul_14x14_evk_defconfig index 7f75bfbc26..4ca8f8188a 100644 --- a/configs/mx6ul_14x14_evk_defconfig +++ b/configs/mx6ul_14x14_evk_defconfig @@ -16,6 +16,7 @@ CONFIG_BOOTDELAY=3 # CONFIG_CONSOLE_MUX is not set CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_BOARD_LATE_INIT=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y diff --git a/configs/mx6ul_9x9_evk_defconfig b/configs/mx6ul_9x9_evk_defconfig index 08772446b3..428f5a02a1 100644 --- a/configs/mx6ul_9x9_evk_defconfig +++ b/configs/mx6ul_9x9_evk_defconfig @@ -16,6 +16,7 @@ CONFIG_BOOTDELAY=3 # CONFIG_CONSOLE_MUX is not set CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_BOARD_LATE_INIT=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y diff --git a/configs/mx6ull_14x14_evk_defconfig b/configs/mx6ull_14x14_evk_defconfig index b8a30df95b..0ed6de93df 100644 --- a/configs/mx6ull_14x14_evk_defconfig +++ b/configs/mx6ull_14x14_evk_defconfig @@ -5,6 +5,7 @@ CONFIG_DEFAULT_DEVICE_TREE="imx6ull-14x14-evk" CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx6ullevk/imximage.cfg" CONFIG_BOOTDELAY=3 CONFIG_BOARD_LATE_INIT=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/mx6ull_14x14_evk_plugin_defconfig b/configs/mx6ull_14x14_evk_plugin_defconfig index d220c50cab..593166707e 100644 --- a/configs/mx6ull_14x14_evk_plugin_defconfig +++ b/configs/mx6ull_14x14_evk_plugin_defconfig @@ -6,6 +6,7 @@ CONFIG_DEFAULT_DEVICE_TREE="imx6ull-14x14-evk" CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx6ullevk/imximage.cfg" CONFIG_BOOTDELAY=3 CONFIG_BOARD_LATE_INIT=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/neo_defconfig b/configs/neo_defconfig index 955f29270f..e1e9ed4d3e 100644 --- a/configs/neo_defconfig +++ b/configs/neo_defconfig @@ -9,6 +9,7 @@ CONFIG_BOOTDELAY=5 CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_ELF is not set CONFIG_CMD_ASKENV=y diff --git a/configs/nitrogen6dl2g_defconfig b/configs/nitrogen6dl2g_defconfig index cd4b675dd3..0268298bb7 100644 --- a/configs/nitrogen6dl2g_defconfig +++ b/configs/nitrogen6dl2g_defconfig @@ -6,6 +6,7 @@ CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6dl2g.cfg CONFIG_BOOTDELAY=3 CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y # CONFIG_SYS_STDIO_DEREGISTER is not set +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/nitrogen6dl_defconfig b/configs/nitrogen6dl_defconfig index 7ea8f51782..886e28a1be 100644 --- a/configs/nitrogen6dl_defconfig +++ b/configs/nitrogen6dl_defconfig @@ -6,6 +6,7 @@ CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6dl.cfg,M CONFIG_BOOTDELAY=3 CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y # CONFIG_SYS_STDIO_DEREGISTER is not set +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/nitrogen6q2g_defconfig b/configs/nitrogen6q2g_defconfig index d9df123cf6..c9cc534066 100644 --- a/configs/nitrogen6q2g_defconfig +++ b/configs/nitrogen6q2g_defconfig @@ -6,6 +6,7 @@ CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6q2g.cfg, CONFIG_BOOTDELAY=3 CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y # CONFIG_SYS_STDIO_DEREGISTER is not set +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/nitrogen6q_defconfig b/configs/nitrogen6q_defconfig index 0063df7c3b..8791272ac5 100644 --- a/configs/nitrogen6q_defconfig +++ b/configs/nitrogen6q_defconfig @@ -6,6 +6,7 @@ CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6q.cfg,MX CONFIG_BOOTDELAY=3 CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y # CONFIG_SYS_STDIO_DEREGISTER is not set +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/nitrogen6s1g_defconfig b/configs/nitrogen6s1g_defconfig index 1572b9bb45..7e2eb86146 100644 --- a/configs/nitrogen6s1g_defconfig +++ b/configs/nitrogen6s1g_defconfig @@ -6,6 +6,7 @@ CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6s1g.cfg, CONFIG_BOOTDELAY=3 CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y # CONFIG_SYS_STDIO_DEREGISTER is not set +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/nitrogen6s_defconfig b/configs/nitrogen6s_defconfig index 6c4061634e..6fc18e43d6 100644 --- a/configs/nitrogen6s_defconfig +++ b/configs/nitrogen6s_defconfig @@ -6,6 +6,7 @@ CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6s.cfg,MX CONFIG_BOOTDELAY=3 CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y # CONFIG_SYS_STDIO_DEREGISTER is not set +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/novena_defconfig b/configs/novena_defconfig index cac32885f5..500ff2f6ee 100644 --- a/configs/novena_defconfig +++ b/configs/novena_defconfig @@ -18,6 +18,7 @@ CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,MX6Q" CONFIG_VERSION_VARIABLE=y CONFIG_BOARD_LATE_INIT=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y # CONFIG_CMD_IMLS is not set CONFIG_CMD_ASKENV=y diff --git a/configs/omapl138_lcdk_defconfig b/configs/omapl138_lcdk_defconfig index 77ede8a1c8..d20af19bf9 100644 --- a/configs/omapl138_lcdk_defconfig +++ b/configs/omapl138_lcdk_defconfig @@ -10,6 +10,7 @@ CONFIG_BOOTDELAY=3 CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0xb5 CONFIG_HUSH_PARSER=y diff --git a/configs/ot1200_defconfig b/configs/ot1200_defconfig index 42432ebab1..213f036266 100644 --- a/configs/ot1200_defconfig +++ b/configs/ot1200_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_MX6=y CONFIG_TARGET_OT1200=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/bachmann/ot1200/mx6q_4x_mt41j128.cfg,MX6Q" CONFIG_BOOTDELAY=3 +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/ot1200_spl_defconfig b/configs/ot1200_spl_defconfig index d1bdbde545..0ddc2fbbcc 100644 --- a/configs/ot1200_spl_defconfig +++ b/configs/ot1200_spl_defconfig @@ -11,6 +11,7 @@ CONFIG_SPL_SPI_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,MX6Q" CONFIG_BOOTDELAY=3 +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y diff --git a/configs/pcm052_defconfig b/configs/pcm052_defconfig index f7db263f25..fbd7841051 100644 --- a/configs/pcm052_defconfig +++ b/configs/pcm052_defconfig @@ -3,6 +3,7 @@ CONFIG_TARGET_PCM052=y CONFIG_DEFAULT_DEVICE_TREE="pcm052" CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/phytec/pcm052/imximage.cfg,ENV_IS_IN_NAND" CONFIG_BOOTDELAY=3 +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/pcm058_defconfig b/configs/pcm058_defconfig index 05ce347cfe..66d195f5f5 100644 --- a/configs/pcm058_defconfig +++ b/configs/pcm058_defconfig @@ -17,6 +17,7 @@ CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,MX6Q" CONFIG_BOOTDELAY=3 CONFIG_BOARD_LATE_INIT=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y CONFIG_SPL_DMA_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/pico-imx6ul_defconfig b/configs/pico-imx6ul_defconfig index 8856afb13f..a2a303c37a 100644 --- a/configs/pico-imx6ul_defconfig +++ b/configs/pico-imx6ul_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_PICO_IMX6UL=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/technexion/pico-imx6ul/imximage.cfg" CONFIG_BOOTDELAY=3 CONFIG_DEFAULT_FDT_FILE="imx6ul-pico-hobbit.dtb" +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/picosam9g45_defconfig b/configs/picosam9g45_defconfig index 90cc75e0cf..bf6ffc6437 100644 --- a/configs/picosam9g45_defconfig +++ b/configs/picosam9g45_defconfig @@ -14,6 +14,7 @@ CONFIG_BOOTDELAY=3 # CONFIG_CONSOLE_MUX is not set CONFIG_SYS_CONSOLE_IS_IN_ENV=y # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " diff --git a/configs/platinum_picon_defconfig b/configs/platinum_picon_defconfig index 71ebc257ee..186c489882 100644 --- a/configs/platinum_picon_defconfig +++ b/configs/platinum_picon_defconfig @@ -13,6 +13,7 @@ CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,MX6DL" CONFIG_BOOTDELAY=3 +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y CONFIG_SPL_DMA_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/platinum_titanium_defconfig b/configs/platinum_titanium_defconfig index 51aeff1ace..d84e02ae68 100644 --- a/configs/platinum_titanium_defconfig +++ b/configs/platinum_titanium_defconfig @@ -13,6 +13,7 @@ CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,MX6Q" CONFIG_BOOTDELAY=3 +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y CONFIG_SPL_DMA_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/pm9261_defconfig b/configs/pm9261_defconfig index 0defe059e7..7fa38529d2 100644 --- a/configs/pm9261_defconfig +++ b/configs/pm9261_defconfig @@ -6,6 +6,7 @@ CONFIG_BOOTDELAY=3 # CONFIG_CONSOLE_MUX is not set CONFIG_SYS_CONSOLE_IS_IN_ENV=y # CONFIG_DISPLAY_CPUINFO is not set +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SYS_PROMPT="pm9261> " # CONFIG_CMD_BDI is not set # CONFIG_CMD_IMI is not set diff --git a/configs/pm9263_defconfig b/configs/pm9263_defconfig index 76ef7ac3b1..0a424af76f 100644 --- a/configs/pm9263_defconfig +++ b/configs/pm9263_defconfig @@ -5,6 +5,7 @@ CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9263" CONFIG_BOOTDELAY=3 # CONFIG_CONSOLE_MUX is not set CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SYS_PROMPT="u-boot-pm9263> " # CONFIG_CMD_BDI is not set # CONFIG_CMD_IMI is not set diff --git a/configs/pm9g45_defconfig b/configs/pm9g45_defconfig index 6cf628808e..7235922a94 100644 --- a/configs/pm9g45_defconfig +++ b/configs/pm9g45_defconfig @@ -5,6 +5,7 @@ CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9G45" CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_IMLS is not set diff --git a/configs/qemu-ppce500_defconfig b/configs/qemu-ppce500_defconfig index 4cc4e03f12..4c9ab198c9 100644 --- a/configs/qemu-ppce500_defconfig +++ b/configs/qemu-ppce500_defconfig @@ -7,6 +7,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_BOOTDELAY=1 # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/qemu-x86_defconfig b/configs/qemu-x86_defconfig index 4566d3701e..39a7b7ebcd 100644 --- a/configs/qemu-x86_defconfig +++ b/configs/qemu-x86_defconfig @@ -9,6 +9,7 @@ CONFIG_FIT=y CONFIG_BOOTSTAGE=y CONFIG_BOOTSTAGE_REPORT=y CONFIG_SYS_CONSOLE_INFO_QUIET=y +# CONFIG_BOARD_EARLY_INIT_F is not set CONFIG_HUSH_PARSER=y CONFIG_CMD_CPU=y # CONFIG_CMD_IMLS is not set diff --git a/configs/qemu-x86_efi_payload32_defconfig b/configs/qemu-x86_efi_payload32_defconfig index 0968689302..f984f7e59e 100644 --- a/configs/qemu-x86_efi_payload32_defconfig +++ b/configs/qemu-x86_efi_payload32_defconfig @@ -6,7 +6,7 @@ CONFIG_FIT=y CONFIG_BOOTSTAGE=y CONFIG_BOOTSTAGE_REPORT=y CONFIG_SYS_CONSOLE_INFO_QUIET=y -CONFIG_ARCH_EARLY_INIT_R=y +# CONFIG_BOARD_EARLY_INIT_F is not set CONFIG_HUSH_PARSER=y CONFIG_CMD_CPU=y # CONFIG_CMD_IMLS is not set diff --git a/configs/qemu-x86_efi_payload64_defconfig b/configs/qemu-x86_efi_payload64_defconfig index 399bbdf6ee..e25238ce5d 100644 --- a/configs/qemu-x86_efi_payload64_defconfig +++ b/configs/qemu-x86_efi_payload64_defconfig @@ -6,7 +6,7 @@ CONFIG_FIT=y CONFIG_BOOTSTAGE=y CONFIG_BOOTSTAGE_REPORT=y CONFIG_SYS_CONSOLE_INFO_QUIET=y -CONFIG_ARCH_EARLY_INIT_R=y +# CONFIG_BOARD_EARLY_INIT_F is not set CONFIG_HUSH_PARSER=y CONFIG_CMD_CPU=y # CONFIG_CMD_BOOTEFI_HELLO_COMPILE is not set diff --git a/configs/rainier_defconfig b/configs/rainier_defconfig index ebb1b1a8b8..9562219b26 100644 --- a/configs/rainier_defconfig +++ b/configs/rainier_defconfig @@ -7,6 +7,7 @@ CONFIG_BOOTDELAY=5 CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_ASKENV=y CONFIG_CMD_GREPENV=y diff --git a/configs/rainier_ramboot_defconfig b/configs/rainier_ramboot_defconfig index f3fcd2c773..dfc89d50e2 100644 --- a/configs/rainier_ramboot_defconfig +++ b/configs/rainier_ramboot_defconfig @@ -7,6 +7,7 @@ CONFIG_BOOTDELAY=5 CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_ASKENV=y CONFIG_CMD_GREPENV=y diff --git a/configs/redwood_defconfig b/configs/redwood_defconfig index 5c9085c12a..1fe23b6119 100644 --- a/configs/redwood_defconfig +++ b/configs/redwood_defconfig @@ -5,6 +5,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTDELAY=5 CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_ASKENV=y CONFIG_CMD_GREPENV=y diff --git a/configs/riotboard_defconfig b/configs/riotboard_defconfig index afc1fddfac..251d7fc8d3 100644 --- a/configs/riotboard_defconfig +++ b/configs/riotboard_defconfig @@ -8,6 +8,7 @@ CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6s1g.cfg, CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_BOARD_LATE_INIT=y +CONFIG_BOARD_EARLY_INIT_F=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_MMC=y diff --git a/configs/s32v234evb_defconfig b/configs/s32v234evb_defconfig index 0da90dc903..302ec6d030 100644 --- a/configs/s32v234evb_defconfig +++ b/configs/s32v234evb_defconfig @@ -3,5 +3,6 @@ CONFIG_TARGET_S32V234EVB=y CONFIG_DISTRO_DEFAULTS=y CONFIG_SYS_MALLOC_F=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/s32v234evb/s32v234evb.cfg" +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_CMD_BOOTZ=y CONFIG_OF_LIBFDT=y diff --git a/configs/sansa_fuze_plus_defconfig b/configs/sansa_fuze_plus_defconfig index a147bdb6b9..cb38697de0 100644 --- a/configs/sansa_fuze_plus_defconfig +++ b/configs/sansa_fuze_plus_defconfig @@ -10,6 +10,7 @@ CONFIG_BOOTDELAY=3 CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set diff --git a/configs/sbc8548_PCI_33_PCIE_defconfig b/configs/sbc8548_PCI_33_PCIE_defconfig index 790ebdc372..5407f543e0 100644 --- a/configs/sbc8548_PCI_33_PCIE_defconfig +++ b/configs/sbc8548_PCI_33_PCIE_defconfig @@ -6,6 +6,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="33,PCIE" CONFIG_BOOTDELAY=10 # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set diff --git a/configs/sbc8548_PCI_33_defconfig b/configs/sbc8548_PCI_33_defconfig index 24a443a729..f594319c20 100644 --- a/configs/sbc8548_PCI_33_defconfig +++ b/configs/sbc8548_PCI_33_defconfig @@ -6,6 +6,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="33" CONFIG_BOOTDELAY=10 # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set diff --git a/configs/sbc8548_PCI_66_PCIE_defconfig b/configs/sbc8548_PCI_66_PCIE_defconfig index f484bcab45..974e96cf0e 100644 --- a/configs/sbc8548_PCI_66_PCIE_defconfig +++ b/configs/sbc8548_PCI_66_PCIE_defconfig @@ -6,6 +6,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="66,PCIE" CONFIG_BOOTDELAY=10 # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set diff --git a/configs/sbc8548_PCI_66_defconfig b/configs/sbc8548_PCI_66_defconfig index d600055c72..fd0ac38a76 100644 --- a/configs/sbc8548_PCI_66_defconfig +++ b/configs/sbc8548_PCI_66_defconfig @@ -6,6 +6,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="66" CONFIG_BOOTDELAY=10 # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set diff --git a/configs/sbc8548_defconfig b/configs/sbc8548_defconfig index 47ac2f80f0..be75525527 100644 --- a/configs/sbc8548_defconfig +++ b/configs/sbc8548_defconfig @@ -5,6 +5,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_BOOTDELAY=10 # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set diff --git a/configs/sc_sps_1_defconfig b/configs/sc_sps_1_defconfig index b5638c52a0..ed8b94adf0 100644 --- a/configs/sc_sps_1_defconfig +++ b/configs/sc_sps_1_defconfig @@ -7,6 +7,7 @@ CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_BOOTDELAY=3 CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set diff --git a/configs/secomx6quq7_defconfig b/configs/secomx6quq7_defconfig index 3e9e329e7e..2866bb02f5 100644 --- a/configs/secomx6quq7_defconfig +++ b/configs/secomx6quq7_defconfig @@ -6,6 +6,7 @@ CONFIG_SECOMX6Q=y CONFIG_SECOMX6_2GB=y CONFIG_SYS_EXTRA_OPTIONS="ENV_IS_IN_MMC" CONFIG_BOOTDELAY=3 +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="SECO MX6Q uQ7 U-Boot > " CONFIG_CMD_BOOTZ=y diff --git a/configs/sequoia_defconfig b/configs/sequoia_defconfig index 9479ac55a0..dd4d3a41ab 100644 --- a/configs/sequoia_defconfig +++ b/configs/sequoia_defconfig @@ -7,6 +7,7 @@ CONFIG_BOOTDELAY=5 CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_ASKENV=y CONFIG_CMD_GREPENV=y diff --git a/configs/sequoia_ramboot_defconfig b/configs/sequoia_ramboot_defconfig index a589d748ff..109d47b88b 100644 --- a/configs/sequoia_ramboot_defconfig +++ b/configs/sequoia_ramboot_defconfig @@ -7,6 +7,7 @@ CONFIG_BOOTDELAY=5 CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_ASKENV=y CONFIG_CMD_GREPENV=y diff --git a/configs/smartweb_defconfig b/configs/smartweb_defconfig index bd69b6a066..57ff5082f1 100644 --- a/configs/smartweb_defconfig +++ b/configs/smartweb_defconfig @@ -12,6 +12,7 @@ CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9260" CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot# " diff --git a/configs/socfpga_sr1500_defconfig b/configs/socfpga_sr1500_defconfig index 6fd7bc0846..981600b766 100644 --- a/configs/socfpga_sr1500_defconfig +++ b/configs/socfpga_sr1500_defconfig @@ -11,6 +11,7 @@ CONFIG_SYS_CONSOLE_ENV_OVERWRITE=y CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_STACK_R=y diff --git a/configs/stm32f429-discovery_defconfig b/configs/stm32f429-discovery_defconfig index b5b04180de..6ec70aff7b 100644 --- a/configs/stm32f429-discovery_defconfig +++ b/configs/stm32f429-discovery_defconfig @@ -5,6 +5,7 @@ CONFIG_TARGET_STM32F429_DISCOVERY=y CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot > " # CONFIG_CMD_BOOTEFI_HELLO_COMPILE is not set diff --git a/configs/stm32f746-disco_defconfig b/configs/stm32f746-disco_defconfig index 10d9120237..8734c763bb 100644 --- a/configs/stm32f746-disco_defconfig +++ b/configs/stm32f746-disco_defconfig @@ -5,6 +5,7 @@ CONFIG_TARGET_STM32F746_DISCO=y CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot > " CONFIG_AUTOBOOT_KEYED=y diff --git a/configs/strider_con_defconfig b/configs/strider_con_defconfig index 6ab1f5116b..1b2b185029 100644 --- a/configs/strider_con_defconfig +++ b/configs/strider_con_defconfig @@ -10,6 +10,7 @@ CONFIG_SYS_EXTRA_OPTIONS="STRIDER_CON" CONFIG_BOOTDELAY=5 CONFIG_SYS_CONSOLE_INFO_QUIET=y # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_STOP_STR=" " diff --git a/configs/strider_con_dp_defconfig b/configs/strider_con_dp_defconfig index 71193d063f..4c863dfbda 100644 --- a/configs/strider_con_dp_defconfig +++ b/configs/strider_con_dp_defconfig @@ -10,6 +10,7 @@ CONFIG_SYS_EXTRA_OPTIONS="STRIDER_CON_DP" CONFIG_BOOTDELAY=5 CONFIG_SYS_CONSOLE_INFO_QUIET=y # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_STOP_STR=" " diff --git a/configs/strider_cpu_defconfig b/configs/strider_cpu_defconfig index 61963be897..bb7db2ec89 100644 --- a/configs/strider_cpu_defconfig +++ b/configs/strider_cpu_defconfig @@ -10,6 +10,7 @@ CONFIG_SYS_EXTRA_OPTIONS="STRIDER_CPU" CONFIG_BOOTDELAY=5 CONFIG_SYS_CONSOLE_INFO_QUIET=y # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_STOP_STR=" " diff --git a/configs/strider_cpu_dp_defconfig b/configs/strider_cpu_dp_defconfig index 560dc65f25..eebd17da65 100644 --- a/configs/strider_cpu_dp_defconfig +++ b/configs/strider_cpu_dp_defconfig @@ -10,6 +10,7 @@ CONFIG_SYS_EXTRA_OPTIONS="STRIDER_CPU,STRIDER_CPU_DP" CONFIG_BOOTDELAY=5 CONFIG_SYS_CONSOLE_INFO_QUIET=y # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_STOP_STR=" " diff --git a/configs/stv0991_defconfig b/configs/stv0991_defconfig index 2c80a5e64b..c91b8b7335 100644 --- a/configs/stv0991_defconfig +++ b/configs/stv0991_defconfig @@ -6,6 +6,7 @@ CONFIG_SYS_EXTRA_OPTIONS="STV0991" CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SYS_PROMPT="STV0991> " CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Hit SPACE in %d seconds to stop autoboot.\n" diff --git a/configs/sycamore_defconfig b/configs/sycamore_defconfig index 530dc6ba76..4d7503c7b6 100644 --- a/configs/sycamore_defconfig +++ b/configs/sycamore_defconfig @@ -5,6 +5,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTDELAY=5 CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_ASKENV=y CONFIG_CMD_GREPENV=y diff --git a/configs/t3corp_defconfig b/configs/t3corp_defconfig index 7c64986dd5..c1c05fa7c6 100644 --- a/configs/t3corp_defconfig +++ b/configs/t3corp_defconfig @@ -7,6 +7,7 @@ CONFIG_BOOTDELAY=5 CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_ASKENV=y CONFIG_CMD_GREPENV=y diff --git a/configs/taurus_defconfig b/configs/taurus_defconfig index c2eeb52c1f..05bad6b9ac 100644 --- a/configs/taurus_defconfig +++ b/configs/taurus_defconfig @@ -14,6 +14,7 @@ CONFIG_DEFAULT_DEVICE_TREE="at91sam9g20-taurus" CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9G20,MACH_TYPE=2067,BOARD_TAURUS" CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " diff --git a/configs/tbs2910_defconfig b/configs/tbs2910_defconfig index 9fefa5f104..edcf054222 100644 --- a/configs/tbs2910_defconfig +++ b/configs/tbs2910_defconfig @@ -6,6 +6,7 @@ CONFIG_VIDEO=y CONFIG_FIT=y CONFIG_BOOTDELAY=3 CONFIG_PRE_CON_BUF_ADDR=0x7c000000 +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Matrix U-Boot> " CONFIG_CMD_BOOTZ=y diff --git a/configs/titanium_defconfig b/configs/titanium_defconfig index 478eba9959..d772ec5777 100644 --- a/configs/titanium_defconfig +++ b/configs/titanium_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_MX6=y CONFIG_TARGET_TITANIUM=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/barco/titanium/imximage.cfg" CONFIG_BOOTDELAY=3 +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Titanium > " CONFIG_CMD_BOOTZ=y diff --git a/configs/tplink_wdr4300_defconfig b/configs/tplink_wdr4300_defconfig index 8d8908dde4..9161427afb 100644 --- a/configs/tplink_wdr4300_defconfig +++ b/configs/tplink_wdr4300_defconfig @@ -6,6 +6,7 @@ CONFIG_DEFAULT_DEVICE_TREE="tplink_wdr4300" CONFIG_BOOTDELAY=3 CONFIG_VERSION_VARIABLE=y CONFIG_DISPLAY_CPUINFO=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_ELF is not set # CONFIG_CMD_IMLS is not set diff --git a/configs/tqma6q_mba6_mmc_defconfig b/configs/tqma6q_mba6_mmc_defconfig index d6478e956c..1107abf0ae 100644 --- a/configs/tqma6q_mba6_mmc_defconfig +++ b/configs/tqma6q_mba6_mmc_defconfig @@ -7,6 +7,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTDELAY=3 CONFIG_DEFAULT_FDT_FILE="imx6q-mba6x.dtb" CONFIG_BOARD_LATE_INIT=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/tqma6q_mba6_spi_defconfig b/configs/tqma6q_mba6_spi_defconfig index 48153fa084..2a671ea036 100644 --- a/configs/tqma6q_mba6_spi_defconfig +++ b/configs/tqma6q_mba6_spi_defconfig @@ -8,6 +8,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTDELAY=3 CONFIG_DEFAULT_FDT_FILE="imx6q-mba6x.dtb" CONFIG_BOARD_LATE_INIT=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/tqma6s_mba6_mmc_defconfig b/configs/tqma6s_mba6_mmc_defconfig index 6e7b483051..61ddc367bb 100644 --- a/configs/tqma6s_mba6_mmc_defconfig +++ b/configs/tqma6s_mba6_mmc_defconfig @@ -8,6 +8,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTDELAY=3 CONFIG_DEFAULT_FDT_FILE="imx6dl-mba6x.dtb" CONFIG_BOARD_LATE_INIT=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/tqma6s_mba6_spi_defconfig b/configs/tqma6s_mba6_spi_defconfig index c38a566647..35e3f229f2 100644 --- a/configs/tqma6s_mba6_spi_defconfig +++ b/configs/tqma6s_mba6_spi_defconfig @@ -9,6 +9,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTDELAY=3 CONFIG_DEFAULT_FDT_FILE="imx6dl-mba6x.dtb" CONFIG_BOARD_LATE_INIT=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/tqma6s_wru4_mmc_defconfig b/configs/tqma6s_wru4_mmc_defconfig index 857150accc..2c73e54251 100644 --- a/configs/tqma6s_wru4_mmc_defconfig +++ b/configs/tqma6s_wru4_mmc_defconfig @@ -9,6 +9,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTDELAY=3 CONFIG_DEFAULT_FDT_FILE="imx6s-wru4.dtb" CONFIG_BOARD_LATE_INIT=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Enter password in %d seconds to stop autoboot\n" diff --git a/configs/ts4600_defconfig b/configs/ts4600_defconfig index 40e20c48af..680a13c836 100644 --- a/configs/ts4600_defconfig +++ b/configs/ts4600_defconfig @@ -6,6 +6,7 @@ CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="ENV_IS_IN_MMC" CONFIG_SYS_CONSOLE_IS_IN_ENV=y # CONFIG_DISPLAY_CPUINFO is not set +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y diff --git a/configs/ts4800_defconfig b/configs/ts4800_defconfig index bd0540596a..255eedfbc3 100644 --- a/configs/ts4800_defconfig +++ b/configs/ts4800_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_TARGET_TS4800=y CONFIG_BOOTDELAY=1 +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/udoo_defconfig b/configs/udoo_defconfig index 54d419ec58..c2ad07c67c 100644 --- a/configs/udoo_defconfig +++ b/configs/udoo_defconfig @@ -13,6 +13,7 @@ CONFIG_SPL_WATCHDOG_SUPPORT=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,MX6QDL" CONFIG_BOOTDELAY=3 CONFIG_BOARD_LATE_INIT=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y diff --git a/configs/udoo_neo_defconfig b/configs/udoo_neo_defconfig index 1eea47fc3a..1d2f626a9a 100644 --- a/configs/udoo_neo_defconfig +++ b/configs/udoo_neo_defconfig @@ -12,6 +12,7 @@ CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg" CONFIG_BOARD_LATE_INIT=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y diff --git a/configs/v38b_defconfig b/configs/v38b_defconfig index 6ffdfdd6da..fd38dc6d66 100644 --- a/configs/v38b_defconfig +++ b/configs/v38b_defconfig @@ -2,6 +2,7 @@ CONFIG_PPC=y CONFIG_MPC5xxx=y CONFIG_TARGET_V38B=y CONFIG_BOOTDELAY=3 +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set diff --git a/configs/ve8313_defconfig b/configs/ve8313_defconfig index 86ba0c1e45..557ab4474d 100644 --- a/configs/ve8313_defconfig +++ b/configs/ve8313_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_VE8313=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_BOOTDELAY=6 +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y diff --git a/configs/vf610twr_defconfig b/configs/vf610twr_defconfig index 5794c28679..3f5db8b671 100644 --- a/configs/vf610twr_defconfig +++ b/configs/vf610twr_defconfig @@ -3,6 +3,7 @@ CONFIG_TARGET_VF610TWR=y CONFIG_DEFAULT_DEVICE_TREE="vf610-twr" CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/vf610twr/imximage.cfg,ENV_IS_IN_MMC" CONFIG_BOOTDELAY=3 +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/vf610twr_nand_defconfig b/configs/vf610twr_nand_defconfig index 60d0126508..c78f71659e 100644 --- a/configs/vf610twr_nand_defconfig +++ b/configs/vf610twr_nand_defconfig @@ -3,6 +3,7 @@ CONFIG_TARGET_VF610TWR=y CONFIG_DEFAULT_DEVICE_TREE="vf610-twr" CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/vf610twr/imximage.cfg,ENV_IS_IN_NAND" CONFIG_BOOTDELAY=3 +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/vinco_defconfig b/configs/vinco_defconfig index 34a02bdfbe..feed1dc590 100644 --- a/configs/vinco_defconfig +++ b/configs/vinco_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_VINCO=y CONFIG_SYS_EXTRA_OPTIONS="SAMA5D4,SYS_USE_SERIALFLASH" CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="vinco => " CONFIG_CMD_BOOTZ=y diff --git a/configs/vining_2000_defconfig b/configs/vining_2000_defconfig index 6a26bdcf46..72044f20a4 100644 --- a/configs/vining_2000_defconfig +++ b/configs/vining_2000_defconfig @@ -5,6 +5,7 @@ CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/samtec/vining_2000/imximage.cfg" CONFIG_BOOTDELAY=0 CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_BOARD_LATE_INIT=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/walnut_defconfig b/configs/walnut_defconfig index 530dc6ba76..4d7503c7b6 100644 --- a/configs/walnut_defconfig +++ b/configs/walnut_defconfig @@ -5,6 +5,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTDELAY=5 CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_ASKENV=y CONFIG_CMD_GREPENV=y diff --git a/configs/wandboard_defconfig b/configs/wandboard_defconfig index 8de5a43a86..bef93a1b41 100644 --- a/configs/wandboard_defconfig +++ b/configs/wandboard_defconfig @@ -17,6 +17,7 @@ CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,MX6QDL" CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_BOARD_LATE_INIT=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/warp_defconfig b/configs/warp_defconfig index eb758b212c..2774b40f2e 100644 --- a/configs/warp_defconfig +++ b/configs/warp_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_WARP=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/warp/imximage.cfg,MX6SL" CONFIG_BOOTDELAY=3 CONFIG_BOARD_LATE_INIT=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/woodburn_defconfig b/configs/woodburn_defconfig index aa5d587b55..ed4250dbaf 100644 --- a/configs/woodburn_defconfig +++ b/configs/woodburn_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_TARGET_WOODBURN=y CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="woodburn U-Boot > " CONFIG_CMD_MMC=y diff --git a/configs/work_92105_defconfig b/configs/work_92105_defconfig index d3b739f93d..780eab333d 100644 --- a/configs/work_92105_defconfig +++ b/configs/work_92105_defconfig @@ -7,6 +7,7 @@ CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_BOOTDELAY=3 CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_HUSH_PARSER=y diff --git a/configs/xfi3_defconfig b/configs/xfi3_defconfig index f98ad3486f..021a55b3a3 100644 --- a/configs/xfi3_defconfig +++ b/configs/xfi3_defconfig @@ -10,6 +10,7 @@ CONFIG_BOOTDELAY=3 CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set diff --git a/configs/xpedite1000_defconfig b/configs/xpedite1000_defconfig index 2b6a8e7bde..99374e2fbd 100644 --- a/configs/xpedite1000_defconfig +++ b/configs/xpedite1000_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_XPEDITE1000=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_BOOTDELAY=3 +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_ASKENV=y CONFIG_CMD_I2C=y diff --git a/configs/xpress_defconfig b/configs/xpress_defconfig index eadd9d5434..2d21d27e6a 100644 --- a/configs/xpress_defconfig +++ b/configs/xpress_defconfig @@ -5,6 +5,7 @@ CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/ccv/xpress/imximage.cfg" CONFIG_BOOTDELAY=3 CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_BOARD_LATE_INIT=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/xpress_spl_defconfig b/configs/xpress_spl_defconfig index 8cf3197dcd..7ea44988d5 100644 --- a/configs/xpress_spl_defconfig +++ b/configs/xpress_spl_defconfig @@ -14,6 +14,7 @@ CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg" CONFIG_BOOTDELAY=3 CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_BOARD_LATE_INIT=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y diff --git a/configs/yellowstone_defconfig b/configs/yellowstone_defconfig index aa02381de7..37319054d1 100644 --- a/configs/yellowstone_defconfig +++ b/configs/yellowstone_defconfig @@ -6,6 +6,7 @@ CONFIG_SYS_EXTRA_OPTIONS="YELLOWSTONE" CONFIG_BOOTDELAY=5 CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_ASKENV=y CONFIG_CMD_GREPENV=y diff --git a/configs/yosemite_defconfig b/configs/yosemite_defconfig index b81e57d390..4cc14d796e 100644 --- a/configs/yosemite_defconfig +++ b/configs/yosemite_defconfig @@ -6,6 +6,7 @@ CONFIG_SYS_EXTRA_OPTIONS="YOSEMITE" CONFIG_BOOTDELAY=5 CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_ASKENV=y CONFIG_CMD_GREPENV=y diff --git a/configs/yucca_defconfig b/configs/yucca_defconfig index 2033610522..9a77bae2ae 100644 --- a/configs/yucca_defconfig +++ b/configs/yucca_defconfig @@ -5,6 +5,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTDELAY=5 CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_ASKENV=y CONFIG_CMD_GREPENV=y diff --git a/configs/zc5202_defconfig b/configs/zc5202_defconfig index 93e9a04a3d..1d87a3a049 100644 --- a/configs/zc5202_defconfig +++ b/configs/zc5202_defconfig @@ -17,6 +17,7 @@ CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,MX6Q" CONFIG_BOOTDELAY=3 CONFIG_DEFAULT_FDT_FILE="imx6q-zc5202.dtb" CONFIG_BOARD_LATE_INIT=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y CONFIG_CMD_MMC=y CONFIG_CMD_SF=y diff --git a/configs/zc5601_defconfig b/configs/zc5601_defconfig index e7c3546205..f300304f11 100644 --- a/configs/zc5601_defconfig +++ b/configs/zc5601_defconfig @@ -17,6 +17,7 @@ CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,MX6Q" CONFIG_BOOTDELAY=3 CONFIG_DEFAULT_FDT_FILE="imx6q-zc5601.dtb" CONFIG_BOARD_LATE_INIT=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y CONFIG_CMD_MMC=y CONFIG_CMD_SF=y diff --git a/include/configs/BSC9131RDB.h b/include/configs/BSC9131RDB.h index a6f73f2df3..31976f3bd2 100644 --- a/include/configs/BSC9131RDB.h +++ b/include/configs/BSC9131RDB.h @@ -198,8 +198,6 @@ extern unsigned long get_sdram_size(void); #define CONFIG_SYS_CS0_FTIM2 CONFIG_SYS_NAND_FTIM2 #define CONFIG_SYS_CS0_FTIM3 CONFIG_SYS_NAND_FTIM3
-#define CONFIG_BOARD_EARLY_INIT_F /* Call board_pre_init */ - #define CONFIG_SYS_INIT_RAM_LOCK #define CONFIG_SYS_INIT_RAM_ADDR 0xffd00000 /* stack in RAM */ #define CONFIG_SYS_INIT_RAM_SIZE 0x00004000/* End of used area in RAM */ diff --git a/include/configs/BSC9132QDS.h b/include/configs/BSC9132QDS.h index 8aec315959..dbd3724a83 100644 --- a/include/configs/BSC9132QDS.h +++ b/include/configs/BSC9132QDS.h @@ -373,7 +373,6 @@ combinations. this should be removed later #define CONFIG_SYS_CS1_FTIM3 CONFIG_SYS_NAND_FTIM3 #endif
-#define CONFIG_BOARD_EARLY_INIT_F /* Call board_pre_init */ #define CONFIG_BOARD_EARLY_INIT_R
#define CONFIG_SYS_INIT_RAM_LOCK diff --git a/include/configs/CPCI2DP.h b/include/configs/CPCI2DP.h index 55e48e24cb..ff46020842 100644 --- a/include/configs/CPCI2DP.h +++ b/include/configs/CPCI2DP.h @@ -21,8 +21,6 @@
#define CONFIG_SYS_TEXT_BASE 0xFFFC0000
-#define CONFIG_BOARD_EARLY_INIT_F 1 /* call board_early_init_f() */ - #define CONFIG_SYS_CLK_FREQ 33330000 /* external frequency to pll */
#define CONFIG_BAUDRATE 9600 diff --git a/include/configs/CPCI4052.h b/include/configs/CPCI4052.h index fb6e0ef473..da3edfaa4a 100644 --- a/include/configs/CPCI4052.h +++ b/include/configs/CPCI4052.h @@ -24,7 +24,6 @@
-#define CONFIG_BOARD_EARLY_INIT_F 1 /* call board_early_init_f() */ #define CONFIG_MISC_INIT_R 1 /* call misc_init_r() */
#define CONFIG_SYS_CLK_FREQ 33330000 /* external frequency to pll */ diff --git a/include/configs/MIP405.h b/include/configs/MIP405.h index f7fc652b4e..61d6fd080d 100644 --- a/include/configs/MIP405.h +++ b/include/configs/MIP405.h @@ -246,7 +246,6 @@ /* Size: 0=1MB, 1=2MB, 2=4MB, 3=8MB, 4=16MB, 5=32MB, 6=64MB, 7=128MB */ #define FLASH_SIZE_PRELIM 3 /* maximal flash FLASH size bank #0 */
-#define CONFIG_BOARD_EARLY_INIT_F 1 #define CONFIG_BOARD_EARLY_INIT_R
/* Peripheral Bus Mapping */ diff --git a/include/configs/MPC8313ERDB.h b/include/configs/MPC8313ERDB.h index 4b0b35206c..64a1467b10 100644 --- a/include/configs/MPC8313ERDB.h +++ b/include/configs/MPC8313ERDB.h @@ -78,7 +78,6 @@
#define CONFIG_SYS_CLK_FREQ CONFIG_83XX_CLKIN
-#define CONFIG_BOARD_EARLY_INIT_F /* call board_early_init_f */ #define CONFIG_BOARD_EARLY_INIT_R /* call board_early_init_r */
#define CONFIG_SYS_IMMR 0xE0000000 diff --git a/include/configs/MPC8315ERDB.h b/include/configs/MPC8315ERDB.h index bd25c0b462..2e3e44c20f 100644 --- a/include/configs/MPC8315ERDB.h +++ b/include/configs/MPC8315ERDB.h @@ -77,7 +77,6 @@ #define CONFIG_SYS_SICRH 0x00000000 #define CONFIG_SYS_SICRL 0x00000000 /* 3.3V, no delay */
-#define CONFIG_BOARD_EARLY_INIT_F /* call board_pre_init */ #define CONFIG_HWCONFIG
/* diff --git a/include/configs/MPC832XEMDS.h b/include/configs/MPC832XEMDS.h index 12a47b215f..3bc10aa532 100644 --- a/include/configs/MPC832XEMDS.h +++ b/include/configs/MPC832XEMDS.h @@ -72,7 +72,6 @@ */ #define CONFIG_SYS_SICRL 0x00000000
-#define CONFIG_BOARD_EARLY_INIT_F /* call board_pre_init */ #define CONFIG_BOARD_EARLY_INIT_R
/* diff --git a/include/configs/MPC8349EMDS.h b/include/configs/MPC8349EMDS.h index 3d3eeb5f46..09f052452e 100644 --- a/include/configs/MPC8349EMDS.h +++ b/include/configs/MPC8349EMDS.h @@ -44,8 +44,6 @@ #endif #endif
-#define CONFIG_BOARD_EARLY_INIT_F /* call board_pre_init */ - #define CONFIG_SYS_IMMR 0xE0000000
#undef CONFIG_SYS_DRAM_TEST /* memory test, takes time */ diff --git a/include/configs/MPC837XEMDS.h b/include/configs/MPC837XEMDS.h index f86b008879..a8cb186d24 100644 --- a/include/configs/MPC837XEMDS.h +++ b/include/configs/MPC837XEMDS.h @@ -97,7 +97,6 @@ */ #define CONFIG_SYS_OBIR 0x31100000
-#define CONFIG_BOARD_EARLY_INIT_F /* call board_pre_init */ #define CONFIG_BOARD_EARLY_INIT_R #define CONFIG_HWCONFIG
diff --git a/include/configs/MPC837XERDB.h b/include/configs/MPC837XERDB.h index d843bd1a75..7754ec72da 100644 --- a/include/configs/MPC837XERDB.h +++ b/include/configs/MPC837XERDB.h @@ -18,7 +18,6 @@
#define CONFIG_SYS_TEXT_BASE 0xFE000000
-#define CONFIG_BOARD_EARLY_INIT_F #define CONFIG_MISC_INIT_R #define CONFIG_HWCONFIG
diff --git a/include/configs/MPC8536DS.h b/include/configs/MPC8536DS.h index ce3340584c..9bfaa4bfc2 100644 --- a/include/configs/MPC8536DS.h +++ b/include/configs/MPC8536DS.h @@ -61,8 +61,6 @@ #define CONFIG_L2_CACHE /* toggle L2 cache */ #define CONFIG_BTB /* toggle branch predition */
-#define CONFIG_BOARD_EARLY_INIT_F 1 /* Call board_pre_init */ - #define CONFIG_ENABLE_36BIT_PHYS 1
#ifdef CONFIG_PHYS_64BIT diff --git a/include/configs/MPC8568MDS.h b/include/configs/MPC8568MDS.h index 0d3707f82b..4296ba7f8b 100644 --- a/include/configs/MPC8568MDS.h +++ b/include/configs/MPC8568MDS.h @@ -41,8 +41,6 @@ extern unsigned long get_clock_freq(void); */ #define CONFIG_ENABLE_36BIT_PHYS 1
-#define CONFIG_BOARD_EARLY_INIT_F 1 /* Call board_pre_init */ - #define CONFIG_SYS_MEMTEST_START 0x00200000 /* memtest works on */ #define CONFIG_SYS_MEMTEST_END 0x00400000
diff --git a/include/configs/MPC8569MDS.h b/include/configs/MPC8569MDS.h index 3e00f691ad..01be54be2f 100644 --- a/include/configs/MPC8569MDS.h +++ b/include/configs/MPC8569MDS.h @@ -54,7 +54,6 @@ extern unsigned long get_clock_freq(void); */ #define CONFIG_ENABLE_36BIT_PHYS 1
-#define CONFIG_BOARD_EARLY_INIT_F 1 /* Call board_pre_init */ #define CONFIG_BOARD_EARLY_INIT_R 1 #define CONFIG_HWCONFIG
diff --git a/include/configs/MPC8610HPCD.h b/include/configs/MPC8610HPCD.h index c5f3634979..1178661635 100644 --- a/include/configs/MPC8610HPCD.h +++ b/include/configs/MPC8610HPCD.h @@ -61,7 +61,6 @@ #define CONFIG_SYS_CLK_FREQ get_board_sys_clk(0) #endif
-#define CONFIG_BOARD_EARLY_INIT_F 1 /* Call board_pre_init */ #define CONFIG_MISC_INIT_R 1
#define CONFIG_SYS_MEMTEST_START 0x00200000 /* memtest region */ diff --git a/include/configs/P1010RDB.h b/include/configs/P1010RDB.h index cd9cd9ac56..979a8f1f65 100644 --- a/include/configs/P1010RDB.h +++ b/include/configs/P1010RDB.h @@ -504,7 +504,6 @@ extern unsigned long get_sdram_size(void); #endif #endif
#define CONFIG_SYS_INIT_RAM_LOCK diff --git a/include/configs/P1022DS.h b/include/configs/P1022DS.h index 505b4178a4..1d219a79e2 100644 --- a/include/configs/P1022DS.h +++ b/include/configs/P1022DS.h @@ -274,7 +274,6 @@
#endif /* CONFIG_NAND_FSL_ELBC */
-#define CONFIG_BOARD_EARLY_INIT_F #define CONFIG_BOARD_EARLY_INIT_R #define CONFIG_MISC_INIT_R #define CONFIG_HWCONFIG diff --git a/include/configs/P1023RDB.h b/include/configs/P1023RDB.h index d8ff10e284..1ab54123ff 100644 --- a/include/configs/P1023RDB.h +++ b/include/configs/P1023RDB.h @@ -109,7 +109,6 @@ extern unsigned long get_clock_freq(void); #define CONFIG_SYS_FLASH_ERASE_TOUT 60000 /* Flash Erase Timeout (ms) */ #define CONFIG_SYS_FLASH_WRITE_TOUT 500 /* Flash Write Timeout (ms) */
-#define CONFIG_BOARD_EARLY_INIT_F /* call board_early_init_f function */ #define CONFIG_BOARD_EARLY_INIT_R /* call board_early_init_r function */
#define CONFIG_SYS_INIT_RAM_LOCK diff --git a/include/configs/P2041RDB.h b/include/configs/P2041RDB.h index 3cd5c3c613..ac579b69b4 100644 --- a/include/configs/P2041RDB.h +++ b/include/configs/P2041RDB.h @@ -276,7 +276,6 @@ unsigned long get_board_sys_clk(unsigned long dummy); #define CONFIG_SYS_FLASH_AMD_CHECK_DQ7 #define CONFIG_SYS_FLASH_BANKS_LIST {CONFIG_SYS_FLASH_BASE_PHYS + 0x8000000}
-#define CONFIG_BOARD_EARLY_INIT_F #define CONFIG_BOARD_EARLY_INIT_R /* call board_early_init_r function */ #define CONFIG_MISC_INIT_R
diff --git a/include/configs/PATI.h b/include/configs/PATI.h index 9589c359ef..cb343e592e 100644 --- a/include/configs/PATI.h +++ b/include/configs/PATI.h @@ -74,8 +74,6 @@
#define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200, 1250000 }
-#define CONFIG_BOARD_EARLY_INIT_F - /*********************************************************************** * Last Stage Init ***********************************************************************/ diff --git a/include/configs/PIP405.h b/include/configs/PIP405.h index 3dcb6acc17..35f04ffe41 100644 --- a/include/configs/PIP405.h +++ b/include/configs/PIP405.h @@ -81,7 +81,6 @@ ***************************************************************/ #define SPD_EEPROM_ADDRESS 0x50
/************************************************************** @@ -205,8 +204,6 @@ /* Size: 0=1MB, 1=2MB, 2=4MB, 3=8MB, 4=16MB, 5=32MB, 6=64MB, 7=128MB */ #define FLASH_SIZE_PRELIM 3 /* maximal flash FLASH size bank #0 */
-#define CONFIG_BOARD_EARLY_INIT_F - /* Configuration Port location */ #define CONFIG_PORT_ADDR 0xF4000000 #define MULTI_PURPOSE_SOCKET_ADDR 0xF8000000 diff --git a/include/configs/PLU405.h b/include/configs/PLU405.h index 0967577e47..91450624d4 100644 --- a/include/configs/PLU405.h +++ b/include/configs/PLU405.h @@ -22,7 +22,6 @@
#define CONFIG_SYS_TEXT_BASE 0xFFF80000
#define CONFIG_SYS_CLK_FREQ 33333400 /* external frequency to pll */ diff --git a/include/configs/PMC405DE.h b/include/configs/PMC405DE.h index d7af4e008c..71adc110d8 100644 --- a/include/configs/PMC405DE.h +++ b/include/configs/PMC405DE.h @@ -13,7 +13,6 @@
-#define CONFIG_BOARD_EARLY_INIT_F 1 /* call board_early_init_f() */ #define CONFIG_MISC_INIT_R 1 /* call misc_init_r() */ #define CONFIG_BOARD_TYPES 1 /* support board types */
diff --git a/include/configs/PMC440.h b/include/configs/PMC440.h index 2e7f6e4803..d4207d7438 100644 --- a/include/configs/PMC440.h +++ b/include/configs/PMC440.h @@ -35,7 +35,6 @@ #define CONFIG_4xx_DCACHE /* enable dcache */ #endif
-#define CONFIG_BOARD_EARLY_INIT_F 1 /* Call board_early_init_f */ #define CONFIG_MISC_INIT_F 1 #define CONFIG_MISC_INIT_R 1 /* Call misc_init_r */ #define CONFIG_BOARD_TYPES 1 /* support board types */ diff --git a/include/configs/T102xQDS.h b/include/configs/T102xQDS.h index c9a1334ca5..530253fcc6 100644 --- a/include/configs/T102xQDS.h +++ b/include/configs/T102xQDS.h @@ -28,9 +28,6 @@ #define CONFIG_ENV_OVERWRITE
#define CONFIG_DEEP_SLEEP -#if defined(CONFIG_DEEP_SLEEP) -#define CONFIG_BOARD_EARLY_INIT_F -#endif
#define CONFIG_FSL_CAAM /* Enable SEC/CAAM */
diff --git a/include/configs/T102xRDB.h b/include/configs/T102xRDB.h index 36eba4ec2c..88094e0e13 100644 --- a/include/configs/T102xRDB.h +++ b/include/configs/T102xRDB.h @@ -33,9 +33,6 @@ #ifdef CONFIG_ARCH_T1024 #define CONFIG_DEEP_SLEEP #endif -#if defined(CONFIG_DEEP_SLEEP) -#define CONFIG_BOARD_EARLY_INIT_F -#endif
#ifdef CONFIG_RAMBOOT_PBL #define CONFIG_SYS_FSL_PBL_PBI board/freescale/t102xrdb/t1024_pbi.cfg diff --git a/include/configs/T1040QDS.h b/include/configs/T1040QDS.h index 8d6d986a49..58bafd25a7 100644 --- a/include/configs/T1040QDS.h +++ b/include/configs/T1040QDS.h @@ -40,9 +40,6 @@
/* support deep sleep */ #define CONFIG_DEEP_SLEEP -#if defined(CONFIG_DEEP_SLEEP) -#define CONFIG_BOARD_EARLY_INIT_F -#endif
#ifndef CONFIG_SYS_TEXT_BASE #define CONFIG_SYS_TEXT_BASE 0xeff40000 diff --git a/include/configs/T104xRDB.h b/include/configs/T104xRDB.h index d574bbbef2..703e1e3049 100644 --- a/include/configs/T104xRDB.h +++ b/include/configs/T104xRDB.h @@ -151,9 +151,6 @@ $(SRCTREE)/board/freescale/t104xrdb/t1042d4_sd_rcw.cfg
#ifndef CONFIG_SYS_TEXT_BASE #define CONFIG_SYS_TEXT_BASE 0xeff40000 diff --git a/include/configs/TQM5200.h b/include/configs/TQM5200.h index 708eb76638..405efadfdd 100644 --- a/include/configs/TQM5200.h +++ b/include/configs/TQM5200.h @@ -51,7 +51,6 @@
#ifdef CONFIG_FO300 #define CONFIG_SYS_DEVICE_NULLDEV 1 /* enable null device */ -#define CONFIG_BOARD_EARLY_INIT_F 1 /* used to detect S1 switch position */ #define CONFIG_USB_BIN_FIXUP 1 /* for a buggy USB device */ #if 0 #define FO300_SILENT_CONSOLE_WHEN_S1_CLOSED 1 /* silent console on PSC1 when S1 */ diff --git a/include/configs/TQM834x.h b/include/configs/TQM834x.h index 68e59900c0..af19a512a1 100644 --- a/include/configs/TQM834x.h +++ b/include/configs/TQM834x.h @@ -41,7 +41,6 @@ #define CONFIG_SYS_LCRR_CLKDIV LCRR_CLKDIV_8
/* board pre init: do not call, nothing to do */ -#undef CONFIG_BOARD_EARLY_INIT_F
/* detect the number of flash banks */ #define CONFIG_BOARD_EARLY_INIT_R diff --git a/include/configs/UCP1020.h b/include/configs/UCP1020.h index f32fb4d041..a0255dcb52 100644 --- a/include/configs/UCP1020.h +++ b/include/configs/UCP1020.h @@ -157,8 +157,6 @@ #define CONFIG_L2_CACHE #define CONFIG_BTB
-#define CONFIG_BOARD_EARLY_INIT_F /* Call board_pre_init */ - #define CONFIG_ENABLE_36BIT_PHYS
#define CONFIG_SYS_MEMTEST_START 0x00200000 /* memtest works on */ diff --git a/include/configs/VOM405.h b/include/configs/VOM405.h index 50d24050a4..760a4bedaf 100644 --- a/include/configs/VOM405.h +++ b/include/configs/VOM405.h @@ -20,7 +20,6 @@
#define CONFIG_SYS_TEXT_BASE 0xFFFC8000
#define CONFIG_SYS_CLK_FREQ 33330000 /* external frequency to pll */ diff --git a/include/configs/acadia.h b/include/configs/acadia.h index c10c646f6c..3e8d48be45 100644 --- a/include/configs/acadia.h +++ b/include/configs/acadia.h @@ -32,7 +32,6 @@ #define CONFIG_SYS_CLK_FREQ ((in8(CONFIG_SYS_CPLD_BASE + 0) == 0x0c) ? \ 66666666 : 33333000)
-#define CONFIG_BOARD_EARLY_INIT_F 1 /* Call board_early_init_f */ #define CONFIG_MISC_INIT_F 1 /* Call misc_init_f */
#define CONFIG_NO_SERIAL_EEPROM diff --git a/include/configs/advantech_dms-ba16.h b/include/configs/advantech_dms-ba16.h index bf87b2bc96..c410544f62 100644 --- a/include/configs/advantech_dms-ba16.h +++ b/include/configs/advantech_dms-ba16.h @@ -33,8 +33,6 @@ #define CONFIG_REVISION_TAG #define CONFIG_SYS_MALLOC_LEN (10 * SZ_1M)
-#define CONFIG_BOARD_EARLY_INIT_F - #define CONFIG_MXC_GPIO #define CONFIG_MXC_UART
diff --git a/include/configs/am43xx_evm.h b/include/configs/am43xx_evm.h index 966503a6c6..961ad0a0c8 100644 --- a/include/configs/am43xx_evm.h +++ b/include/configs/am43xx_evm.h @@ -57,9 +57,6 @@ * we need to call board_early_init_f. This is taken care of in * s_init when we have SPL used. */ -#if !defined(CONFIG_SKIP_LOWLEVEL_INIT) && !defined(CONFIG_SPL) -#define CONFIG_BOARD_EARLY_INIT_F -#endif
/* Now bring in the rest of the common code. */ #include <configs/ti_armv7_omap.h> diff --git a/include/configs/am57xx_evm.h b/include/configs/am57xx_evm.h index 03e6e3045e..840502c5b1 100644 --- a/include/configs/am57xx_evm.h +++ b/include/configs/am57xx_evm.h @@ -20,8 +20,6 @@ #define CONFIG_IODELAY_RECALIBRATION #endif
-#define CONFIG_BOARD_EARLY_INIT_F - #define CONFIG_NR_DRAM_BANKS 2
#define CONFIG_ENV_SIZE (64 << 10) diff --git a/include/configs/ap121.h b/include/configs/ap121.h index 2da520eda9..1253e0a64c 100644 --- a/include/configs/ap121.h +++ b/include/configs/ap121.h @@ -7,8 +7,6 @@ #ifndef __CONFIG_H #define __CONFIG_H
-#define CONFIG_BOARD_EARLY_INIT_F - #define CONFIG_SYS_HZ 1000 #define CONFIG_SYS_MHZ 200 #define CONFIG_SYS_MIPS_TIMER_FREQ (CONFIG_SYS_MHZ * 1000000) diff --git a/include/configs/ap143.h b/include/configs/ap143.h index ce64c941d5..99027e078e 100644 --- a/include/configs/ap143.h +++ b/include/configs/ap143.h @@ -7,8 +7,6 @@ #ifndef __CONFIG_H #define __CONFIG_H
-#define CONFIG_BOARD_EARLY_INIT_F - #define CONFIG_SYS_HZ 1000 #define CONFIG_SYS_MHZ 325 #define CONFIG_SYS_MIPS_TIMER_FREQ (CONFIG_SYS_MHZ * 1000000) diff --git a/include/configs/apalis_imx6.h b/include/configs/apalis_imx6.h index db53ef88d5..97c1f1a8ea 100644 --- a/include/configs/apalis_imx6.h +++ b/include/configs/apalis_imx6.h @@ -36,7 +36,6 @@ /* Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (32 * 1024 * 1024)
#define CONFIG_MXC_UART diff --git a/include/configs/aristainetos-common.h b/include/configs/aristainetos-common.h index 56530fd072..030f01c36d 100644 --- a/include/configs/aristainetos-common.h +++ b/include/configs/aristainetos-common.h @@ -21,8 +21,6 @@ /* Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (64 * SZ_1M)
-#define CONFIG_BOARD_EARLY_INIT_F - #define CONFIG_MXC_UART
/* MMC Configs */ diff --git a/include/configs/armadillo-800eva.h b/include/configs/armadillo-800eva.h index 3775a496a4..25b88f9798 100644 --- a/include/configs/armadillo-800eva.h +++ b/include/configs/armadillo-800eva.h @@ -27,7 +27,6 @@ #undef CONFIG_SHOW_BOOT_PROGRESS
#define CONFIG_ARCH_CPU_INIT -#define CONFIG_BOARD_EARLY_INIT_F #define CONFIG_TMU_TIMER #define CONFIG_SYS_DCACHE_OFF
diff --git a/include/configs/at91-sama5_common.h b/include/configs/at91-sama5_common.h index 13140bae1f..42410a8526 100644 --- a/include/configs/at91-sama5_common.h +++ b/include/configs/at91-sama5_common.h @@ -24,8 +24,6 @@ #define CONFIG_SKIP_LOWLEVEL_INIT #endif
-#define CONFIG_BOARD_EARLY_INIT_F - #define CONFIG_ENV_VARS_UBOOT_CONFIG
/* general purpose I/O */ diff --git a/include/configs/at91rm9200ek.h b/include/configs/at91rm9200ek.h index ed0daf5276..82e2cb7401 100644 --- a/include/configs/at91rm9200ek.h +++ b/include/configs/at91rm9200ek.h @@ -56,8 +56,6 @@ #define CONFIG_SETUP_MEMORY_TAGS #define CONFIG_INITRD_TAG
-#define CONFIG_BOARD_EARLY_INIT_F - /* * Memory Configuration */ diff --git a/include/configs/at91sam9260ek.h b/include/configs/at91sam9260ek.h index f07366e653..95499c8764 100644 --- a/include/configs/at91sam9260ek.h +++ b/include/configs/at91sam9260ek.h @@ -42,7 +42,6 @@ #define CONFIG_SETUP_MEMORY_TAGS #define CONFIG_INITRD_TAG #define CONFIG_SKIP_LOWLEVEL_INIT -#define CONFIG_BOARD_EARLY_INIT_F
/* general purpose I/O */ #define CONFIG_ATMEL_LEGACY /* required until (g)pio is fixed */ diff --git a/include/configs/at91sam9263ek.h b/include/configs/at91sam9263ek.h index 6806cc7e25..b8d3791346 100644 --- a/include/configs/at91sam9263ek.h +++ b/include/configs/at91sam9263ek.h @@ -41,8 +41,6 @@ #define CONFIG_SYS_USE_NORFLASH #endif
-#define CONFIG_BOARD_EARLY_INIT_F - /* * Hardware drivers */ diff --git a/include/configs/at91sam9m10g45ek.h b/include/configs/at91sam9m10g45ek.h index 12a92c2871..743153bb18 100644 --- a/include/configs/at91sam9m10g45ek.h +++ b/include/configs/at91sam9m10g45ek.h @@ -27,7 +27,6 @@ #define CONFIG_SETUP_MEMORY_TAGS #define CONFIG_INITRD_TAG #define CONFIG_SKIP_LOWLEVEL_INIT -#define CONFIG_BOARD_EARLY_INIT_F
/* general purpose I/O */ #define CONFIG_ATMEL_LEGACY /* required until (g)pio is fixed */ diff --git a/include/configs/at91sam9n12ek.h b/include/configs/at91sam9n12ek.h index 9c9e809acc..0b8448c4e3 100644 --- a/include/configs/at91sam9n12ek.h +++ b/include/configs/at91sam9n12ek.h @@ -27,7 +27,6 @@ #define CONFIG_SETUP_MEMORY_TAGS #define CONFIG_INITRD_TAG #define CONFIG_SKIP_LOWLEVEL_INIT -#define CONFIG_BOARD_EARLY_INIT_F
/* general purpose I/O */ #define CONFIG_AT91_GPIO diff --git a/include/configs/at91sam9rlek.h b/include/configs/at91sam9rlek.h index b5aebe634a..3f0bb6e974 100644 --- a/include/configs/at91sam9rlek.h +++ b/include/configs/at91sam9rlek.h @@ -23,7 +23,6 @@
#define CONFIG_ARCH_CPU_INIT #define CONFIG_SKIP_LOWLEVEL_INIT -#define CONFIG_BOARD_EARLY_INIT_F
#define CONFIG_CMDLINE_TAG 1 /* enable passing of ATAGs */ #define CONFIG_SETUP_MEMORY_TAGS 1 diff --git a/include/configs/at91sam9x5ek.h b/include/configs/at91sam9x5ek.h index 6dee45a9f2..361830bec0 100644 --- a/include/configs/at91sam9x5ek.h +++ b/include/configs/at91sam9x5ek.h @@ -23,7 +23,6 @@ #define CONFIG_SETUP_MEMORY_TAGS #define CONFIG_INITRD_TAG #define CONFIG_SKIP_LOWLEVEL_INIT -#define CONFIG_BOARD_EARLY_INIT_F
/* general purpose I/O */ #define CONFIG_ATMEL_LEGACY /* required until (g)pio is fixed */ diff --git a/include/configs/atngw100.h b/include/configs/atngw100.h index 00a8c7970f..b0c4a05bcc 100644 --- a/include/configs/atngw100.h +++ b/include/configs/atngw100.h @@ -14,7 +14,6 @@ #define CONFIG_AT32AP7000 #define CONFIG_ATNGW100
/* diff --git a/include/configs/atngw100mkii.h b/include/configs/atngw100mkii.h index d1f61b3243..eb7e0b2249 100644 --- a/include/configs/atngw100mkii.h +++ b/include/configs/atngw100mkii.h @@ -16,7 +16,6 @@ #define CONFIG_AT32AP7000 #define CONFIG_ATNGW100MKII
/* diff --git a/include/configs/atstk1002.h b/include/configs/atstk1002.h index 3d17ae1264..2480c3d217 100644 --- a/include/configs/atstk1002.h +++ b/include/configs/atstk1002.h @@ -94,7 +94,6 @@ #define CONFIG_BOOTP_GATEWAY
/* generic board */ -#define CONFIG_BOARD_EARLY_INIT_F #define CONFIG_BOARD_EARLY_INIT_R
/* diff --git a/include/configs/axs10x.h b/include/configs/axs10x.h index 2dd9d31295..58b1850d64 100644 --- a/include/configs/axs10x.h +++ b/include/configs/axs10x.h @@ -38,7 +38,6 @@ * This board might be of different versions so handle it */ #define CONFIG_BOARD_TYPES -#define CONFIG_BOARD_EARLY_INIT_F
/* * NAND Flash configuration diff --git a/include/configs/bamboo.h b/include/configs/bamboo.h index 1b22a3717e..2e8105afd4 100644 --- a/include/configs/bamboo.h +++ b/include/configs/bamboo.h @@ -32,8 +32,6 @@ /* Reclaim some space. */ #undef CONFIG_SYS_LONGHELP
-#define CONFIG_BOARD_EARLY_INIT_F 1 /* Call board_early_init_f */ - /* * Please note that, if NAND support is enabled, the 2nd ethernet port * can't be used because of pin multiplexing. So, if you want to use the diff --git a/include/configs/bf506f-ezkit.h b/include/configs/bf506f-ezkit.h index dc7d83f61d..6948e20243 100644 --- a/include/configs/bf506f-ezkit.h +++ b/include/configs/bf506f-ezkit.h @@ -78,7 +78,6 @@ /* * Misc Settings */ -#define CONFIG_BOARD_EARLY_INIT_F #define CONFIG_ICACHE_OFF #define CONFIG_DCACHE_OFF #define CONFIG_UART_CONSOLE 0 diff --git a/include/configs/bf518f-ezbrd.h b/include/configs/bf518f-ezbrd.h index 43e4971b74..05b338ff12 100644 --- a/include/configs/bf518f-ezbrd.h +++ b/include/configs/bf518f-ezbrd.h @@ -135,7 +135,6 @@ /* * Misc Settings */ -#define CONFIG_BOARD_EARLY_INIT_F #define CONFIG_MISC_INIT_R #define CONFIG_RTC_BFIN #define CONFIG_UART_CONSOLE 0 diff --git a/include/configs/bf548-ezkit.h b/include/configs/bf548-ezkit.h index b79aa2bd30..81d5af6046 100644 --- a/include/configs/bf548-ezkit.h +++ b/include/configs/bf548-ezkit.h @@ -158,7 +158,6 @@ /* * Misc Settings */ -#define CONFIG_BOARD_EARLY_INIT_F #define CONFIG_BOARD_SIZE_LIMIT $$(( 512 * 1024 )) #define CONFIG_RTC_BFIN #define CONFIG_UART_CONSOLE 1 diff --git a/include/configs/bf609-ezkit.h b/include/configs/bf609-ezkit.h index 337bb0a580..55127c58a8 100644 --- a/include/configs/bf609-ezkit.h +++ b/include/configs/bf609-ezkit.h @@ -132,7 +132,6 @@ /* * Misc Settings */ -#define CONFIG_BOARD_EARLY_INIT_F #define CONFIG_UART_CONSOLE 0
#define CONFIG_CMD_SOFTSWITCH diff --git a/include/configs/bubinga.h b/include/configs/bubinga.h index c9890239b7..8a5994af51 100644 --- a/include/configs/bubinga.h +++ b/include/configs/bubinga.h @@ -28,8 +28,6 @@ #define CONFIG_HOSTNAME bubinga #include "amcc-common.h"
-#define CONFIG_BOARD_EARLY_INIT_F 1 /* Call board_early_init_f */ - #define CONFIG_SYS_CLK_FREQ 33333333 /* external frequency to pll */
#define CONFIG_NO_SERIAL_EEPROM diff --git a/include/configs/canyonlands.h b/include/configs/canyonlands.h index 1d189d22a1..ca4d6ecaee 100644 --- a/include/configs/canyonlands.h +++ b/include/configs/canyonlands.h @@ -47,7 +47,6 @@
#define CONFIG_SYS_CLK_FREQ 66666667 /* external freq to pll */
-#define CONFIG_BOARD_EARLY_INIT_F /* Call board_early_init_f */ #define CONFIG_BOARD_EARLY_INIT_R /* Call board_early_init_r */ #define CONFIG_MISC_INIT_R /* Call misc_init_r */ #define CONFIG_BOARD_TYPES /* support board types */ diff --git a/include/configs/cgtqmx6eval.h b/include/configs/cgtqmx6eval.h index a34f6b9b23..c32372a66c 100644 --- a/include/configs/cgtqmx6eval.h +++ b/include/configs/cgtqmx6eval.h @@ -26,7 +26,6 @@ /* Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (10 * 1024 * 1024)
#define CONFIG_MXC_UART diff --git a/include/configs/cm-bf548.h b/include/configs/cm-bf548.h index c5b82f748e..02a46cae3d 100644 --- a/include/configs/cm-bf548.h +++ b/include/configs/cm-bf548.h @@ -102,7 +102,6 @@ * Misc Settings */ #define CONFIG_BAUDRATE 115200 -#define CONFIG_BOARD_EARLY_INIT_F #define CONFIG_RTC_BFIN #define CONFIG_UART_CONSOLE 1 #define CONFIG_BOOTCOMMAND "run flashboot" diff --git a/include/configs/colibri_imx6.h b/include/configs/colibri_imx6.h index cd870463b9..ca94fab4c0 100644 --- a/include/configs/colibri_imx6.h +++ b/include/configs/colibri_imx6.h @@ -34,7 +34,6 @@ /* Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (32 * 1024 * 1024)
#define CONFIG_MXC_UART diff --git a/include/configs/colibri_imx7.h b/include/configs/colibri_imx7.h index 69b0ae7701..56a6f1ed4f 100644 --- a/include/configs/colibri_imx7.h +++ b/include/configs/colibri_imx7.h @@ -20,7 +20,6 @@ #define PHYS_SDRAM_SIZE SZ_512M
#define CONFIG_ARCH_MISC_INIT -#define CONFIG_BOARD_EARLY_INIT_F
#define CONFIG_DISPLAY_BOARDINFO_LATE /* Calls show_board_info() */
diff --git a/include/configs/colibri_vf.h b/include/configs/colibri_vf.h index d2d4330ddc..3f36d6a522 100644 --- a/include/configs/colibri_vf.h +++ b/include/configs/colibri_vf.h @@ -31,8 +31,6 @@ /* Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 2 * 1024 * 1024)
-#define CONFIG_BOARD_EARLY_INIT_F - /* Allow to overwrite serial and ethaddr */ #define CONFIG_ENV_OVERWRITE #define CONFIG_ENV_VARS_UBOOT_CONFIG diff --git a/include/configs/conga-qeval20-qa3-e3845.h b/include/configs/conga-qeval20-qa3-e3845.h index 9a71dda54c..12e6eb2e49 100644 --- a/include/configs/conga-qeval20-qa3-e3845.h +++ b/include/configs/conga-qeval20-qa3-e3845.h @@ -14,7 +14,6 @@ #include <configs/x86-common.h>
#define CONFIG_SYS_MONITOR_LEN (1 << 20) -#define CONFIG_BOARD_EARLY_INIT_F #define CONFIG_ARCH_MISC_INIT
#define CONFIG_STD_DEVICES_SETTINGS "stdin=serial\0" \ diff --git a/include/configs/controlcenterd.h b/include/configs/controlcenterd.h index 17360978fc..d236f3a020 100644 --- a/include/configs/controlcenterd.h +++ b/include/configs/controlcenterd.h @@ -357,14 +357,12 @@ /* * Board initialisation callbacks */ -#define CONFIG_BOARD_EARLY_INIT_F #define CONFIG_BOARD_EARLY_INIT_R #define CONFIG_MISC_INIT_R #define CONFIG_LAST_STAGE_INIT
#else /* CONFIG_TRAILBLAZER */
-#define CONFIG_BOARD_EARLY_INIT_F #define CONFIG_BOARD_EARLY_INIT_R #define CONFIG_LAST_STAGE_INIT
diff --git a/include/configs/corenet_ds.h b/include/configs/corenet_ds.h index c9c00c5388..7a3de31606 100644 --- a/include/configs/corenet_ds.h +++ b/include/configs/corenet_ds.h @@ -285,7 +285,6 @@ #define CONFIG_SYS_FLASH_AMD_CHECK_DQ7 #define CONFIG_SYS_FLASH_BANKS_LIST {CONFIG_SYS_FLASH_BASE_PHYS + 0x8000000, CONFIG_SYS_FLASH_BASE_PHYS}
diff --git a/include/configs/corvus.h b/include/configs/corvus.h index e6a52d8b57..ec7e3029f6 100644 --- a/include/configs/corvus.h +++ b/include/configs/corvus.h @@ -36,7 +36,6 @@ #define CONFIG_SETUP_MEMORY_TAGS #define CONFIG_INITRD_TAG #define CONFIG_SKIP_LOWLEVEL_INIT_ONLY -#define CONFIG_BOARD_EARLY_INIT_F
/* general purpose I/O */ #define CONFIG_ATMEL_LEGACY /* required until (g)pio is fixed */ diff --git a/include/configs/cougarcanyon2.h b/include/configs/cougarcanyon2.h index 2e9fa075de..5f4800bdac 100644 --- a/include/configs/cougarcanyon2.h +++ b/include/configs/cougarcanyon2.h @@ -10,7 +10,6 @@ #include <configs/x86-common.h>
#define CONFIG_SYS_MONITOR_LEN (2 << 20) -#define CONFIG_BOARD_EARLY_INIT_F
#define CONFIG_SMSC_SIO1007
diff --git a/include/configs/crownbay.h b/include/configs/crownbay.h index 506b22790e..219944ae19 100644 --- a/include/configs/crownbay.h +++ b/include/configs/crownbay.h @@ -14,7 +14,6 @@ #include <configs/x86-common.h>
#define CONFIG_SMSC_LPC47M
diff --git a/include/configs/cyrus.h b/include/configs/cyrus.h index 14e207e935..71a55d8ccd 100644 --- a/include/configs/cyrus.h +++ b/include/configs/cyrus.h @@ -164,7 +164,6 @@ #define CONFIG_SYS_RAMBOOT #endif
diff --git a/include/configs/da850evm.h b/include/configs/da850evm.h index 0ad6e4c163..e1f9b90171 100644 --- a/include/configs/da850evm.h +++ b/include/configs/da850evm.h @@ -249,7 +249,6 @@ * U-Boot general configuration */ #define CONFIG_MISC_INIT_R -#define CONFIG_BOARD_EARLY_INIT_F #define CONFIG_BOOTFILE "uImage" /* Boot file name */ #define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ #define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) diff --git a/include/configs/devkit3250.h b/include/configs/devkit3250.h index a71f67c352..c04146ffcd 100644 --- a/include/configs/devkit3250.h +++ b/include/configs/devkit3250.h @@ -24,7 +24,6 @@ #if !defined(CONFIG_SPL_BUILD) #define CONFIG_SKIP_LOWLEVEL_INIT #endif -#define CONFIG_BOARD_EARLY_INIT_F
/* * Memory configurations diff --git a/include/configs/dfi-bt700.h b/include/configs/dfi-bt700.h index 727baae061..211c9ea130 100644 --- a/include/configs/dfi-bt700.h +++ b/include/configs/dfi-bt700.h @@ -14,7 +14,6 @@ #include <configs/x86-common.h>
#ifndef CONFIG_INTERNAL_UART /* Use BayTrail internal HS UART which is memory-mapped */ diff --git a/include/configs/dlvision-10g.h b/include/configs/dlvision-10g.h index a5384a235b..6b3cd15cb6 100644 --- a/include/configs/dlvision-10g.h +++ b/include/configs/dlvision-10g.h @@ -19,7 +19,6 @@ #define CONFIG_HOSTNAME dlvsion-10g #include "amcc-common.h"
-#define CONFIG_BOARD_EARLY_INIT_F #define CONFIG_BOARD_EARLY_INIT_R #define CONFIG_MISC_INIT_R #define CONFIG_LAST_STAGE_INIT diff --git a/include/configs/dlvision.h b/include/configs/dlvision.h index 57640da325..6269768df1 100644 --- a/include/configs/dlvision.h +++ b/include/configs/dlvision.h @@ -19,7 +19,6 @@ #define CONFIG_HOSTNAME dlvision #include "amcc-common.h"
-#define CONFIG_BOARD_EARLY_INIT_F /* call board_early_init_f */ #define CONFIG_MISC_INIT_R /* call misc_init_r */
#define CONFIG_SYS_CLK_FREQ 33333333 /* external frequency to pll */ diff --git a/include/configs/dra7xx_evm.h b/include/configs/dra7xx_evm.h index c51961736e..da458a47b4 100644 --- a/include/configs/dra7xx_evm.h +++ b/include/configs/dra7xx_evm.h @@ -15,7 +15,6 @@ #include <environment/ti/dfu.h>
#define CONFIG_DRA7XX -#define CONFIG_BOARD_EARLY_INIT_F
#ifdef CONFIG_SPL_BUILD #define CONFIG_IODELAY_RECALIBRATION diff --git a/include/configs/ea20.h b/include/configs/ea20.h index 27654c8bdb..8319dc4d34 100644 --- a/include/configs/ea20.h +++ b/include/configs/ea20.h @@ -19,7 +19,6 @@ #define CONFIG_SYS_USE_NAND #define CONFIG_DRIVER_TI_EMAC_USE_RMII #define CONFIG_DRIVER_TI_EMAC_RMII_NO_NEGOTIATE -#define CONFIG_BOARD_EARLY_INIT_F #define CONFIG_PREBOOT
/* diff --git a/include/configs/edb93xx.h b/include/configs/edb93xx.h index 9cc62ed452..774d3296ab 100644 --- a/include/configs/edb93xx.h +++ b/include/configs/edb93xx.h @@ -223,8 +223,6 @@ #define CONFIG_SYS_USB_OHCI_SLOT_NAME "ep93xx-ohci" #define CONFIG_SYS_USB_OHCI_REGS_BASE 0x80020000
-#define CONFIG_BOARD_EARLY_INIT_F - /* Define to disable flash configuration*/ /* #define CONFIG_EP93XX_NO_FLASH_CFG */
diff --git a/include/configs/el6x_common.h b/include/configs/el6x_common.h index c124abe542..484565c9aa 100644 --- a/include/configs/el6x_common.h +++ b/include/configs/el6x_common.h @@ -19,8 +19,6 @@ /* Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (10 * SZ_1M)
#ifdef CONFIG_SPL diff --git a/include/configs/embestmx6boards.h b/include/configs/embestmx6boards.h index d9709249f6..48c9e0b3e9 100644 --- a/include/configs/embestmx6boards.h +++ b/include/configs/embestmx6boards.h @@ -24,8 +24,6 @@ /* Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (10 * SZ_1M)
/* I2C Configs */ diff --git a/include/configs/exynos-common.h b/include/configs/exynos-common.h index cdbe154839..978495527d 100644 --- a/include/configs/exynos-common.h +++ b/include/configs/exynos-common.h @@ -18,7 +18,6 @@
/* Keep L2 Cache Disabled */
diff --git a/include/configs/exynos7420-common.h b/include/configs/exynos7420-common.h index 1cea74e954..4d73b9331f 100644 --- a/include/configs/exynos7420-common.h +++ b/include/configs/exynos7420-common.h @@ -18,7 +18,6 @@ #include <linux/sizes.h>
/* Size of malloc() pool before and after relocation */ #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + (80 << 20)) diff --git a/include/configs/flea3.h b/include/configs/flea3.h index 0f7b3c82db..96a2a80aca 100644 --- a/include/configs/flea3.h +++ b/include/configs/flea3.h @@ -31,7 +31,6 @@ #define CONFIG_SYS_TEXT_BASE 0xA0000000
/* This is required to setup the ESDC controller */ -#define CONFIG_BOARD_EARLY_INIT_F
#define CONFIG_CMDLINE_TAG /* enable passing of ATAGs */ #define CONFIG_REVISION_TAG diff --git a/include/configs/galileo.h b/include/configs/galileo.h index 360f379728..1094143cb0 100644 --- a/include/configs/galileo.h +++ b/include/configs/galileo.h @@ -14,7 +14,6 @@ #include <configs/x86-common.h>
/* ns16550 UART is memory-mapped in Quark SoC */ diff --git a/include/configs/gdppc440etx.h b/include/configs/gdppc440etx.h index 12bf95f5dd..fee46add80 100644 --- a/include/configs/gdppc440etx.h +++ b/include/configs/gdppc440etx.h @@ -30,7 +30,6 @@ */ #include "amcc-common.h"
-#define CONFIG_BOARD_EARLY_INIT_F 1 /* call board_early_init_f*/ #define CONFIG_MISC_INIT_R 1 /* call misc_init_r() */
/* diff --git a/include/configs/ge_bx50v3.h b/include/configs/ge_bx50v3.h index e8de711755..91712c178d 100644 --- a/include/configs/ge_bx50v3.h +++ b/include/configs/ge_bx50v3.h @@ -44,8 +44,6 @@ #define CONFIG_REVISION_TAG #define CONFIG_SYS_MALLOC_LEN (10 * SZ_1M)
diff --git a/include/configs/grasshopper.h b/include/configs/grasshopper.h index f1afdedb3c..b727314c90 100644 --- a/include/configs/grasshopper.h +++ b/include/configs/grasshopper.h @@ -62,7 +62,6 @@ #define CONFIG_USART_BASE ATMEL_BASE_USART1 #define CONFIG_USART_ID 1
/* User serviceable stuff */ diff --git a/include/configs/gw_ventana.h b/include/configs/gw_ventana.h index 8f6d9bb873..24e3150620 100644 --- a/include/configs/gw_ventana.h +++ b/include/configs/gw_ventana.h @@ -39,7 +39,6 @@ #define CONFIG_SYS_MALLOC_LEN (10 * SZ_1M)
/* Init Functions */ -#define CONFIG_BOARD_EARLY_INIT_F #define CONFIG_MISC_INIT_R
/* Driver Model */ diff --git a/include/configs/hikey.h b/include/configs/hikey.h index 4048bce77c..0f6f11755d 100644 --- a/include/configs/hikey.h +++ b/include/configs/hikey.h @@ -21,8 +21,6 @@
#define CONFIG_SUPPORT_RAW_INITRD
-#define CONFIG_BOARD_EARLY_INIT_F - /* Physical Memory Map */
/* CONFIG_SYS_TEXT_BASE needs to align with where ATF loads bl33.bin */ diff --git a/include/configs/hrcon.h b/include/configs/hrcon.h index b224706040..079c4cfdcc 100644 --- a/include/configs/hrcon.h +++ b/include/configs/hrcon.h @@ -20,7 +20,6 @@
diff --git a/include/configs/icon.h b/include/configs/icon.h index b15016b5a3..29d33650c1 100644 --- a/include/configs/icon.h +++ b/include/configs/icon.h @@ -30,7 +30,6 @@ #define CONFIG_HOSTNAME icon #include "amcc-common.h"
-#define CONFIG_BOARD_EARLY_INIT_F /* Call board_pre_init */ #define CONFIG_BOARD_EARLY_INIT_R /* Call board_early_init_r */
/* diff --git a/include/configs/imx31_phycore.h b/include/configs/imx31_phycore.h index efeb008b6b..d59cc5092f 100644 --- a/include/configs/imx31_phycore.h +++ b/include/configs/imx31_phycore.h @@ -118,7 +118,6 @@ #define CONFIG_NR_DRAM_BANKS 1 #define PHYS_SDRAM_1 0x80000000 #define PHYS_SDRAM_1_SIZE (128 * 1024 * 1024) -#define CONFIG_BOARD_EARLY_INIT_F #define CONFIG_SYS_TEXT_BASE 0xA0000000
#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_1 diff --git a/include/configs/intip.h b/include/configs/intip.h index e61005be1c..5c8b68dfa5 100644 --- a/include/configs/intip.h +++ b/include/configs/intip.h @@ -40,7 +40,6 @@
-#define CONFIG_BOARD_EARLY_INIT_F 1 /* Call board_early_init_f */ #define CONFIG_BOARD_EARLY_INIT_R 1 /* Call board_early_init_r */ #define CONFIG_MISC_INIT_R 1 /* Call misc_init_r */ #define CONFIG_BOARD_TYPES 1 /* support board types */ diff --git a/include/configs/io.h b/include/configs/io.h index 8c9ee0e1ae..8a21b3f60f 100644 --- a/include/configs/io.h +++ b/include/configs/io.h @@ -19,7 +19,6 @@ #define CONFIG_HOSTNAME io #include "amcc-common.h"
-#define CONFIG_BOARD_EARLY_INIT_F #define CONFIG_BOARD_EARLY_INIT_R #define CONFIG_MISC_INIT_R #define CONFIG_LAST_STAGE_INIT diff --git a/include/configs/io64.h b/include/configs/io64.h index 7f2cbd51f5..8619de4af9 100644 --- a/include/configs/io64.h +++ b/include/configs/io64.h @@ -38,7 +38,6 @@ #define CONFIG_HOSTNAME io64 #include "amcc-common.h"
-#define CONFIG_BOARD_EARLY_INIT_F #define CONFIG_BOARD_EARLY_INIT_R #define CONFIG_MISC_INIT_R #define CONFIG_LAST_STAGE_INIT diff --git a/include/configs/iocon.h b/include/configs/iocon.h index 87f56f187b..9c3be78bc7 100644 --- a/include/configs/iocon.h +++ b/include/configs/iocon.h @@ -22,7 +22,6 @@ /* Reclaim some space. */ #undef CONFIG_SYS_LONGHELP
diff --git a/include/configs/ipam390.h b/include/configs/ipam390.h index 991dad1ce3..74dad5fc2d 100644 --- a/include/configs/ipam390.h +++ b/include/configs/ipam390.h @@ -198,7 +198,6 @@ * U-Boot general configuration */ #define CONFIG_MISC_INIT_R -#define CONFIG_BOARD_EARLY_INIT_F #define CONFIG_BOOTFILE "uImage" /* Boot file name */ #define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ #define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) diff --git a/include/configs/jupiter.h b/include/configs/jupiter.h index e073528633..26cbd6df3b 100644 --- a/include/configs/jupiter.h +++ b/include/configs/jupiter.h @@ -28,7 +28,6 @@ #define CONFIG_SYS_MPC5XXX_CLKIN 33000000 /* ... running at 33.000000MHz */
#define CONFIG_BOARD_EARLY_INIT_R 1 -#define CONFIG_BOARD_EARLY_INIT_F 1
#define CONFIG_HIGH_BATS 1 /* High BATs supported */
diff --git a/include/configs/katmai.h b/include/configs/katmai.h index a41c127b08..0ddd6c4596 100644 --- a/include/configs/katmai.h +++ b/include/configs/katmai.h @@ -37,7 +37,6 @@ #define CONFIG_HOSTNAME katmai #include "amcc-common.h"
-#define CONFIG_BOARD_EARLY_INIT_F 1 /* Call board_pre_init */ #undef CONFIG_SHOW_BOOT_PROGRESS
/*----------------------------------------------------------------------- diff --git a/include/configs/kilauea.h b/include/configs/kilauea.h index 2254eca5a4..43eb405e63 100644 --- a/include/configs/kilauea.h +++ b/include/configs/kilauea.h @@ -46,7 +46,6 @@ #define CONFIG_HOSTNAME kilauea #include "amcc-common.h"
-#define CONFIG_BOARD_EARLY_INIT_F 1 /* Call board_early_init_f */ #define CONFIG_MISC_INIT_R 1 /* Call misc_init_r */ #define CONFIG_BOARD_TYPES #define CONFIG_BOARD_EMAC_COUNT diff --git a/include/configs/km/km_arm.h b/include/configs/km/km_arm.h index bcde7681ab..9dfb0510b5 100644 --- a/include/configs/km/km_arm.h +++ b/include/configs/km/km_arm.h @@ -305,7 +305,6 @@ int get_scl(void); /* additions for new relocation code, must be added to all boards */ #define CONFIG_SYS_SDRAM_BASE 0x00000000 /* Do early setups now in board_init_f() */ -#define CONFIG_BOARD_EARLY_INIT_F
/* * resereved pram area at the end of memroy [hex] diff --git a/include/configs/km/kmp204x-common.h b/include/configs/km/kmp204x-common.h index b4cdb67a51..37be339573 100644 --- a/include/configs/km/kmp204x-common.h +++ b/include/configs/km/kmp204x-common.h @@ -199,7 +199,6 @@ unsigned long get_board_sys_clk(unsigned long dummy); #define CONFIG_BOOTCOUNT_LIMIT #define CONFIG_SYS_BOOTCOUNT_ADDR (CONFIG_SYS_QRIO_BASE + 0x20)
-#define CONFIG_BOARD_EARLY_INIT_F #define CONFIG_BOARD_EARLY_INIT_R /* call board_early_init_r function */ #define CONFIG_MISC_INIT_F #define CONFIG_MISC_INIT_R diff --git a/include/configs/kzm9g.h b/include/configs/kzm9g.h index 9402aca1bc..2e672b35eb 100644 --- a/include/configs/kzm9g.h +++ b/include/configs/kzm9g.h @@ -18,7 +18,6 @@ #include <asm/arch/rmobile.h>
#define CONFIG_CMDLINE_TAG #define CONFIG_SETUP_MEMORY_TAGS diff --git a/include/configs/legoev3.h b/include/configs/legoev3.h index 402dab2915..bd4135e891 100644 --- a/include/configs/legoev3.h +++ b/include/configs/legoev3.h @@ -142,7 +142,6 @@ /* * U-Boot general configuration */ -#define CONFIG_BOARD_EARLY_INIT_F #define CONFIG_BOOTFILE "uImage" /* Boot file name */ #define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ #define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) diff --git a/include/configs/liteboard.h b/include/configs/liteboard.h index 1f5dba2df4..2ce39ffecf 100644 --- a/include/configs/liteboard.h +++ b/include/configs/liteboard.h @@ -19,8 +19,6 @@ /* Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (16 * SZ_1M)
-#define CONFIG_BOARD_EARLY_INIT_F - #define CONFIG_MXC_UART #define CONFIG_MXC_UART_BASE UART1_BASE
diff --git a/include/configs/ls1012a_common.h b/include/configs/ls1012a_common.h index eddfa1493e..81f8d6263e 100644 --- a/include/configs/ls1012a_common.h +++ b/include/configs/ls1012a_common.h @@ -22,7 +22,6 @@ #define CONFIG_SYS_CLK_FREQ 125000000
#define CONFIG_SKIP_LOWLEVEL_INIT -#define CONFIG_BOARD_EARLY_INIT_F 1
#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_FSL_OCRAM_BASE + 0xfff0) #define CONFIG_SYS_LOAD_ADDR (CONFIG_SYS_DDR_SDRAM_BASE + 0x10000000) diff --git a/include/configs/ls1021aiot.h b/include/configs/ls1021aiot.h index 69ba8bff06..3daa3450b4 100644 --- a/include/configs/ls1021aiot.h +++ b/include/configs/ls1021aiot.h @@ -13,8 +13,6 @@
#define CONFIG_SYS_FSL_CLK
-#define CONFIG_BOARD_EARLY_INIT_F - /* * Size of malloc() pool */ diff --git a/include/configs/ls1021aqds.h b/include/configs/ls1021aqds.h index 031dce7604..fc41ea15b8 100644 --- a/include/configs/ls1021aqds.h +++ b/include/configs/ls1021aqds.h @@ -16,7 +16,6 @@ #define CONFIG_SYS_FSL_CLK
diff --git a/include/configs/ls1021atwr.h b/include/configs/ls1021atwr.h index 1f179f40c8..b97ee34343 100644 --- a/include/configs/ls1021atwr.h +++ b/include/configs/ls1021atwr.h @@ -16,7 +16,6 @@ #define CONFIG_SYS_FSL_CLK
#define CONFIG_SKIP_LOWLEVEL_INIT -#define CONFIG_BOARD_EARLY_INIT_F #define CONFIG_DEEP_SLEEP
/* diff --git a/include/configs/ls1043a_common.h b/include/configs/ls1043a_common.h index 66805c2d7a..74278de047 100644 --- a/include/configs/ls1043a_common.h +++ b/include/configs/ls1043a_common.h @@ -21,7 +21,6 @@ #define CONFIG_SUPPORT_RAW_INITRD
#define CONFIG_VERY_BIG_RAM #define CONFIG_SYS_DDR_SDRAM_BASE 0x80000000 diff --git a/include/configs/ls1046a_common.h b/include/configs/ls1046a_common.h index 5ac89380e5..965d6c9451 100644 --- a/include/configs/ls1046a_common.h +++ b/include/configs/ls1046a_common.h @@ -20,7 +20,6 @@ #define CONFIG_SUPPORT_RAW_INITRD
#define CONFIG_VERY_BIG_RAM #define CONFIG_SYS_DDR_SDRAM_BASE 0x80000000 diff --git a/include/configs/ls2080a_common.h b/include/configs/ls2080a_common.h index 99c0661b90..851db612d7 100644 --- a/include/configs/ls2080a_common.h +++ b/include/configs/ls2080a_common.h @@ -40,7 +40,6 @@ #define CONFIG_SUPPORT_RAW_INITRD
#ifndef CONFIG_SPL #define CONFIG_FSL_DDR_INTERACTIVE /* Interactive debugging */ diff --git a/include/configs/luan.h b/include/configs/luan.h index 2ab6f58364..f4a63de088 100644 --- a/include/configs/luan.h +++ b/include/configs/luan.h @@ -28,7 +28,6 @@ #define CONFIG_HOSTNAME luan #include "amcc-common.h"
/*----------------------------------------------------------------------- diff --git a/include/configs/lwmon5.h b/include/configs/lwmon5.h index 638682f392..658e359b20 100644 --- a/include/configs/lwmon5.h +++ b/include/configs/lwmon5.h @@ -25,7 +25,6 @@
#define CONFIG_4xx_DCACHE /* enable cache in SDRAM */
-#define CONFIG_BOARD_EARLY_INIT_F /* Call board_early_init_f */ #define CONFIG_BOARD_EARLY_INIT_R /* Call board_early_init_r */ #define CONFIG_BOARD_POSTCLK_INIT /* Call board_postclk_init */ #define CONFIG_MISC_INIT_R /* Call misc_init_r */ diff --git a/include/configs/m53evk.h b/include/configs/m53evk.h index 8ec98fd633..22397773d5 100644 --- a/include/configs/m53evk.h +++ b/include/configs/m53evk.h @@ -13,7 +13,6 @@
#include <asm/arch/imx-regs.h>
-#define CONFIG_BOARD_EARLY_INIT_F #define CONFIG_REVISION_TAG #define CONFIG_SYS_NO_FLASH #define CONFIG_SYS_FSL_CLK diff --git a/include/configs/makalu.h b/include/configs/makalu.h index 7c358bc8e8..42fdb370a7 100644 --- a/include/configs/makalu.h +++ b/include/configs/makalu.h @@ -31,7 +31,6 @@ #define CONFIG_ADDMISC "addmisc=setenv bootargs ${bootargs} rtc-x1205.probe=0,0x6f\0" #include "amcc-common.h"
/*----------------------------------------------------------------------- diff --git a/include/configs/malta.h b/include/configs/malta.h index 65cd3218a0..103360d248 100644 --- a/include/configs/malta.h +++ b/include/configs/malta.h @@ -11,7 +11,6 @@ * System configuration */ #define CONFIG_MALTA -#define CONFIG_BOARD_EARLY_INIT_F
#define CONFIG_MEMSIZE_IN_BYTES
diff --git a/include/configs/mecp5123.h b/include/configs/mecp5123.h index 4f90c34da1..c9dbc5ab72 100644 --- a/include/configs/mecp5123.h +++ b/include/configs/mecp5123.h @@ -35,7 +35,6 @@
#define CONFIG_SYS_MPC512X_CLKIN 33333333 /* in Hz */
-#define CONFIG_BOARD_EARLY_INIT_F /* call board_early_init_f() */ #define CONFIG_MISC_INIT_R
#define CONFIG_SYS_IMMR 0x80000000 diff --git a/include/configs/meesc.h b/include/configs/meesc.h index 6b9bb6a529..5356e4c43a 100644 --- a/include/configs/meesc.h +++ b/include/configs/meesc.h @@ -44,7 +44,6 @@ /* Misc CPU related */ #define CONFIG_SKIP_LOWLEVEL_INIT #define CONFIG_ARCH_CPU_INIT -#define CONFIG_BOARD_EARLY_INIT_F /* call board_early_init_f() */ #define CONFIG_SETUP_MEMORY_TAGS #define CONFIG_INITRD_TAG #define CONFIG_SERIAL_TAG diff --git a/include/configs/mpc5121ads.h b/include/configs/mpc5121ads.h index c36141a007..0159da4a21 100644 --- a/include/configs/mpc5121ads.h +++ b/include/configs/mpc5121ads.h @@ -49,7 +49,6 @@ #define CONFIG_SYS_MPC512X_CLKIN 33333333 /* in Hz */ #endif
#define CONFIG_SYS_IMMR 0x80000000 diff --git a/include/configs/mv-common.h b/include/configs/mv-common.h index b28030caf9..d7fbe963a9 100644 --- a/include/configs/mv-common.h +++ b/include/configs/mv-common.h @@ -85,7 +85,6 @@ #define CONFIG_CMDLINE_EDITING #define CONFIG_ARCH_CPU_INIT /* call arch_cpu_init() */ #define CONFIG_ARCH_MISC_INIT /* call arch_misc_init() */ -#define CONFIG_BOARD_EARLY_INIT_F /* call board_init_f for early inits */ #define CONFIG_SYS_LOAD_ADDR 0x00800000 /* default load adr- 8M */ #define CONFIG_SYS_MEMTEST_START 0x00800000 /* 8M */ #define CONFIG_SYS_MEMTEST_END 0x00ffffff /*(_16M -1) */ diff --git a/include/configs/mvebu_armada-8k.h b/include/configs/mvebu_armada-8k.h index fd185321d1..27dc6282d4 100644 --- a/include/configs/mvebu_armada-8k.h +++ b/include/configs/mvebu_armada-8k.h @@ -53,7 +53,6 @@ #define CONFIG_AUTO_COMPLETE #define CONFIG_CMDLINE_EDITING #define CONFIG_ARCH_CPU_INIT /* call arch_cpu_init() */ -#define CONFIG_BOARD_EARLY_INIT_F /* call board_init_f for early inits */ #define CONFIG_SYS_LOAD_ADDR 0x00800000 /* default load adr- 8M */ #define CONFIG_SYS_MEMTEST_START 0x00800000 /* 8M */ #define CONFIG_SYS_MEMTEST_END 0x00ffffff /*(_16M -1) */ diff --git a/include/configs/mvebu_db-88f3720.h b/include/configs/mvebu_db-88f3720.h index 7fc3dcc790..caaad86221 100644 --- a/include/configs/mvebu_db-88f3720.h +++ b/include/configs/mvebu_db-88f3720.h @@ -51,7 +51,6 @@ #define CONFIG_AUTO_COMPLETE #define CONFIG_CMDLINE_EDITING #define CONFIG_ARCH_CPU_INIT /* call arch_cpu_init() */ -#define CONFIG_BOARD_EARLY_INIT_F /* call board_init_f for early inits */ #define CONFIG_SYS_LOAD_ADDR 0x00800000 /* default load adr- 8M */ #define CONFIG_SYS_MEMTEST_START 0x00800000 /* 8M */ #define CONFIG_SYS_MEMTEST_END 0x00ffffff /*(_16M -1) */ diff --git a/include/configs/mx25pdk.h b/include/configs/mx25pdk.h index 1484762b77..c818d3e2c5 100644 --- a/include/configs/mx25pdk.h +++ b/include/configs/mx25pdk.h @@ -35,8 +35,6 @@ #define PHYS_SDRAM_1 0x80000000 #define PHYS_SDRAM_1_SIZE (64 * 1024 * 1024)
-#define CONFIG_BOARD_EARLY_INIT_F - #define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_1 #define CONFIG_SYS_INIT_RAM_ADDR IMX_RAM_BASE #define CONFIG_SYS_INIT_RAM_SIZE IMX_RAM_SIZE diff --git a/include/configs/mx31ads.h b/include/configs/mx31ads.h index 28fa51327e..ce4936d01c 100644 --- a/include/configs/mx31ads.h +++ b/include/configs/mx31ads.h @@ -121,7 +121,6 @@ #define CONFIG_NR_DRAM_BANKS 1 #define PHYS_SDRAM_1 CSD0_BASE #define PHYS_SDRAM_1_SIZE (128 * 1024 * 1024) -#define CONFIG_BOARD_EARLY_INIT_F
#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_1 #define CONFIG_SYS_INIT_RAM_ADDR IRAM_BASE_ADDR diff --git a/include/configs/mx31pdk.h b/include/configs/mx31pdk.h index 36716a982f..e351f05c06 100644 --- a/include/configs/mx31pdk.h +++ b/include/configs/mx31pdk.h @@ -117,7 +117,6 @@ #define CONFIG_NR_DRAM_BANKS 1 #define PHYS_SDRAM_1 CSD0_BASE #define PHYS_SDRAM_1_SIZE (128 * 1024 * 1024) -#define CONFIG_BOARD_EARLY_INIT_F
#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_1 #define CONFIG_SYS_INIT_RAM_ADDR IRAM_BASE_ADDR diff --git a/include/configs/mx35pdk.h b/include/configs/mx35pdk.h index a75cd25b3b..22bfa147d2 100644 --- a/include/configs/mx35pdk.h +++ b/include/configs/mx35pdk.h @@ -23,8 +23,6 @@ /* Set TEXT at the beginning of the NOR flash */ #define CONFIG_SYS_TEXT_BASE 0xA0000000
-#define CONFIG_BOARD_EARLY_INIT_F - #define CONFIG_CMDLINE_TAG /* enable passing of ATAGs */ #define CONFIG_REVISION_TAG #define CONFIG_SETUP_MEMORY_TAGS diff --git a/include/configs/mx51evk.h b/include/configs/mx51evk.h index ea738726f1..56650ba199 100644 --- a/include/configs/mx51evk.h +++ b/include/configs/mx51evk.h @@ -212,8 +212,6 @@ #define CONFIG_SYS_INIT_RAM_ADDR (IRAM_BASE_ADDR) #define CONFIG_SYS_INIT_RAM_SIZE (IRAM_SIZE)
-#define CONFIG_BOARD_EARLY_INIT_F - #define CONFIG_SYS_INIT_SP_OFFSET \ (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_ADDR \ diff --git a/include/configs/mx53ard.h b/include/configs/mx53ard.h index d84d524deb..28b3738144 100644 --- a/include/configs/mx53ard.h +++ b/include/configs/mx53ard.h @@ -25,7 +25,6 @@ /* Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 2 * 1024 * 1024)
-#define CONFIG_BOARD_EARLY_INIT_F #define CONFIG_MXC_GPIO
#define CONFIG_SYS_MAX_NAND_DEVICE 1 diff --git a/include/configs/mx53cx9020.h b/include/configs/mx53cx9020.h index 7d84f51da3..6656f1306c 100644 --- a/include/configs/mx53cx9020.h +++ b/include/configs/mx53cx9020.h @@ -24,7 +24,6 @@ /* Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (10 * 1024 * 1024)
-#define CONFIG_BOARD_EARLY_INIT_F #define CONFIG_MXC_GPIO #define CONFIG_REVISION_TAG
diff --git a/include/configs/mx53evk.h b/include/configs/mx53evk.h index 62d153cd92..76136a8945 100644 --- a/include/configs/mx53evk.h +++ b/include/configs/mx53evk.h @@ -25,7 +25,6 @@ /* Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 2 * 1024 * 1024)
#define CONFIG_MXC_UART diff --git a/include/configs/mx53loco.h b/include/configs/mx53loco.h index 313f4dfd0a..96c4b4f912 100644 --- a/include/configs/mx53loco.h +++ b/include/configs/mx53loco.h @@ -25,7 +25,6 @@ /* Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (10 * 1024 * 1024)
diff --git a/include/configs/mx53smd.h b/include/configs/mx53smd.h index ad4964c182..18dfa71d21 100644 --- a/include/configs/mx53smd.h +++ b/include/configs/mx53smd.h @@ -25,7 +25,6 @@ /* Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 2 * 1024 * 1024)
#define CONFIG_MXC_UART diff --git a/include/configs/mx6cuboxi.h b/include/configs/mx6cuboxi.h index dfd37cdc45..2782911da3 100644 --- a/include/configs/mx6cuboxi.h +++ b/include/configs/mx6cuboxi.h @@ -16,7 +16,6 @@ #define CONFIG_IMX_THERMAL
#define CONFIG_SYS_MALLOC_LEN (10 * SZ_1M) -#define CONFIG_BOARD_EARLY_INIT_F #define CONFIG_MXC_UART
/* MMC Configs */ diff --git a/include/configs/mx6qarm2.h b/include/configs/mx6qarm2.h index 4e40483269..9f42735571 100644 --- a/include/configs/mx6qarm2.h +++ b/include/configs/mx6qarm2.h @@ -14,8 +14,6 @@ /* Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 2 * 1024 * 1024)
-#define CONFIG_BOARD_EARLY_INIT_F - #define CONFIG_MXC_UART #define CONFIG_MXC_UART_BASE UART4_BASE
diff --git a/include/configs/mx6sabre_common.h b/include/configs/mx6sabre_common.h index d2a584a580..a2ab77a727 100644 --- a/include/configs/mx6sabre_common.h +++ b/include/configs/mx6sabre_common.h @@ -16,8 +16,6 @@ /* Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (10 * SZ_1M)
/* MMC Configs */ diff --git a/include/configs/mx6slevk.h b/include/configs/mx6slevk.h index 501d7de544..e54982af2e 100644 --- a/include/configs/mx6slevk.h +++ b/include/configs/mx6slevk.h @@ -21,8 +21,6 @@ /* Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (3 * SZ_1M)
-#define CONFIG_BOARD_EARLY_INIT_F - #define CONFIG_MXC_UART #define CONFIG_MXC_UART_BASE UART1_IPS_BASE_ADDR
diff --git a/include/configs/mx6sllevk.h b/include/configs/mx6sllevk.h index 8f56541012..8215e63baa 100644 --- a/include/configs/mx6sllevk.h +++ b/include/configs/mx6sllevk.h @@ -20,8 +20,6 @@ /* Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (16 * SZ_1M)
diff --git a/include/configs/mx6sxsabreauto.h b/include/configs/mx6sxsabreauto.h index 0ba1e14a38..90a935bbd0 100644 --- a/include/configs/mx6sxsabreauto.h +++ b/include/configs/mx6sxsabreauto.h @@ -14,8 +14,6 @@ /* Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (3 * SZ_1M)
diff --git a/include/configs/mx6sxsabresd.h b/include/configs/mx6sxsabresd.h index d423880420..aff7a24587 100644 --- a/include/configs/mx6sxsabresd.h +++ b/include/configs/mx6sxsabresd.h @@ -18,8 +18,6 @@ /* Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (3 * SZ_1M)
diff --git a/include/configs/mx6ul_14x14_evk.h b/include/configs/mx6ul_14x14_evk.h index 2faa10c55d..f84bff9ff4 100644 --- a/include/configs/mx6ul_14x14_evk.h +++ b/include/configs/mx6ul_14x14_evk.h @@ -23,8 +23,6 @@ /* Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (16 * SZ_1M)
diff --git a/include/configs/mx6ullevk.h b/include/configs/mx6ullevk.h index b8eddf1da6..b56482427f 100644 --- a/include/configs/mx6ullevk.h +++ b/include/configs/mx6ullevk.h @@ -27,8 +27,6 @@ /* Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (16 * SZ_1M)
#define CONFIG_MXC_UART diff --git a/include/configs/mx7dsabresd.h b/include/configs/mx7dsabresd.h index 7e172e0b07..4aa360288a 100644 --- a/include/configs/mx7dsabresd.h +++ b/include/configs/mx7dsabresd.h @@ -19,8 +19,6 @@ /* Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (32 * SZ_1M)
-#define CONFIG_BOARD_EARLY_INIT_F - /* Network */ #define CONFIG_FEC_MXC #define CONFIG_MII diff --git a/include/configs/mxs.h b/include/configs/mxs.h index b26bc01977..a225a96f7a 100644 --- a/include/configs/mxs.h +++ b/include/configs/mxs.h @@ -42,7 +42,6 @@ */
/* Startup hooks */ -#define CONFIG_BOARD_EARLY_INIT_F #define CONFIG_ARCH_MISC_INIT
/* SPL */ diff --git a/include/configs/neo.h b/include/configs/neo.h index 8b6ee92f66..f6b4cc01c2 100644 --- a/include/configs/neo.h +++ b/include/configs/neo.h @@ -19,7 +19,6 @@ #define CONFIG_HOSTNAME neo #include "amcc-common.h"
-#define CONFIG_BOARD_EARLY_INIT_F #define CONFIG_BOARD_EARLY_INIT_R #define CONFIG_MISC_INIT_R #define CONFIG_LAST_STAGE_INIT diff --git a/include/configs/nitrogen6x.h b/include/configs/nitrogen6x.h index c22fed70a4..ca55063f77 100644 --- a/include/configs/nitrogen6x.h +++ b/include/configs/nitrogen6x.h @@ -17,7 +17,6 @@ /* Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (10 * 1024 * 1024)
-#define CONFIG_BOARD_EARLY_INIT_F #define CONFIG_MISC_INIT_R #define CONFIG_USBD_HS #define CONFIG_USB_ETHER diff --git a/include/configs/novena.h b/include/configs/novena.h index 63fc59a182..5a07bf3891 100644 --- a/include/configs/novena.h +++ b/include/configs/novena.h @@ -10,7 +10,6 @@ #define __CONFIG_H
/* System configurations */ -#define CONFIG_BOARD_EARLY_INIT_F #define CONFIG_MISC_INIT_R #define CONFIG_KEYBOARD
diff --git a/include/configs/omapl138_lcdk.h b/include/configs/omapl138_lcdk.h index 43da339f39..65354b0ead 100644 --- a/include/configs/omapl138_lcdk.h +++ b/include/configs/omapl138_lcdk.h @@ -246,7 +246,6 @@ * U-Boot general configuration */ #define CONFIG_MISC_INIT_R -#define CONFIG_BOARD_EARLY_INIT_F #define CONFIG_BOOTFILE "zImage" /* Boot file name */ #define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ #define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) diff --git a/include/configs/ot1200.h b/include/configs/ot1200.h index f4b3e06f92..6704e973de 100644 --- a/include/configs/ot1200.h +++ b/include/configs/ot1200.h @@ -13,7 +13,6 @@ /* Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (10 * 1024 * 1024)
/* UART Configs */ diff --git a/include/configs/p1_p2_rdb_pc.h b/include/configs/p1_p2_rdb_pc.h index f91a7628d8..c8d5e89338 100644 --- a/include/configs/p1_p2_rdb_pc.h +++ b/include/configs/p1_p2_rdb_pc.h @@ -291,8 +291,6 @@ #define CONFIG_L2_CACHE #define CONFIG_BTB
#ifdef CONFIG_PHYS_64BIT diff --git a/include/configs/p1_twr.h b/include/configs/p1_twr.h index 63825b0bde..041e016f52 100644 --- a/include/configs/p1_twr.h +++ b/include/configs/p1_twr.h @@ -71,8 +71,6 @@ extern unsigned long get_board_sys_clk(unsigned long dummy); #define CONFIG_L2_CACHE #define CONFIG_BTB
-#define CONFIG_BOARD_EARLY_INIT_F /* Call board_pre_init */ - #define CONFIG_SYS_MEMTEST_START 0x00200000 /* memtest works on */ #define CONFIG_SYS_MEMTEST_END 0x1fffffff #define CONFIG_PANIC_HANG /* do not reset board on panic */ diff --git a/include/configs/pcm052.h b/include/configs/pcm052.h index f3cf95469a..182f22e147 100644 --- a/include/configs/pcm052.h +++ b/include/configs/pcm052.h @@ -23,8 +23,6 @@ /* Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 2 * 1024 * 1024)
-#define CONFIG_BOARD_EARLY_INIT_F - /* Allow to overwrite serial and ethaddr */ #define CONFIG_ENV_OVERWRITE #define CONFIG_BAUDRATE 115200 diff --git a/include/configs/pcm058.h b/include/configs/pcm058.h index 5f649537d1..098b02afa8 100644 --- a/include/configs/pcm058.h +++ b/include/configs/pcm058.h @@ -29,7 +29,6 @@ #define PHYS_SDRAM_SIZE (1u * 1024 * 1024 * 1024)
/* Early setup */ -#define CONFIG_BOARD_EARLY_INIT_F #define CONFIG_DISPLAY_BOARDINFO_LATE
diff --git a/include/configs/pico-imx6ul.h b/include/configs/pico-imx6ul.h index 2bd7076499..6b0c546696 100644 --- a/include/configs/pico-imx6ul.h +++ b/include/configs/pico-imx6ul.h @@ -27,8 +27,6 @@ /* Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (35 * SZ_1M) /* Increase due to DFU */
-#define CONFIG_BOARD_EARLY_INIT_F - #define CONFIG_MXC_UART #define CONFIG_MXC_UART_BASE UART6_BASE_ADDR
diff --git a/include/configs/picosam9g45.h b/include/configs/picosam9g45.h index 20fb0366f3..bf817d7bec 100644 --- a/include/configs/picosam9g45.h +++ b/include/configs/picosam9g45.h @@ -30,7 +30,6 @@ #define CONFIG_SETUP_MEMORY_TAGS #define CONFIG_INITRD_TAG #define CONFIG_SKIP_LOWLEVEL_INIT -#define CONFIG_BOARD_EARLY_INIT_F
/* general purpose I/O */ #define CONFIG_ATMEL_LEGACY /* required until (g)pio is fixed */ diff --git a/include/configs/platinum.h b/include/configs/platinum.h index f3ac4589aa..2610e243e7 100644 --- a/include/configs/platinum.h +++ b/include/configs/platinum.h @@ -117,7 +117,6 @@ */
/* Board startup config */ -#define CONFIG_BOARD_EARLY_INIT_F #define CONFIG_MISC_INIT_R
#define CONFIG_SYS_MEMTEST_START PHYS_SDRAM diff --git a/include/configs/pm9261.h b/include/configs/pm9261.h index c19e7dc9f3..9254722422 100644 --- a/include/configs/pm9261.h +++ b/include/configs/pm9261.h @@ -138,7 +138,6 @@ #define CONFIG_INITRD_TAG 1
#undef CONFIG_SKIP_LOWLEVEL_INIT -#define CONFIG_BOARD_EARLY_INIT_F
/* * Hardware drivers diff --git a/include/configs/pm9263.h b/include/configs/pm9263.h index eddc81a8bd..ac1f7fbb53 100644 --- a/include/configs/pm9263.h +++ b/include/configs/pm9263.h @@ -151,7 +151,6 @@
#undef CONFIG_SKIP_LOWLEVEL_INIT #define CONFIG_USER_LOWLEVEL_INIT 1 -#define CONFIG_BOARD_EARLY_INIT_F
/* * Hardware drivers diff --git a/include/configs/pm9g45.h b/include/configs/pm9g45.h index 28690c28fa..2ed977c29c 100644 --- a/include/configs/pm9g45.h +++ b/include/configs/pm9g45.h @@ -40,7 +40,6 @@ #define CONFIG_INITRD_TAG 1
/* * Hardware drivers diff --git a/include/configs/qemu-ppce500.h b/include/configs/qemu-ppce500.h index 9517674010..9f267877ab 100644 --- a/include/configs/qemu-ppce500.h +++ b/include/configs/qemu-ppce500.h @@ -36,7 +36,6 @@ #define CONFIG_PANIC_HANG /* do not reset board on panic */
/* Needed to fill the ccsrbar pointer */ -#define CONFIG_BOARD_EARLY_INIT_F
/* Virtual address to CCSRBAR */ #define CONFIG_SYS_CCSRBAR 0xe0000000 diff --git a/include/configs/rcar-gen2-common.h b/include/configs/rcar-gen2-common.h index 459b077fb3..1338cd3469 100644 --- a/include/configs/rcar-gen2-common.h +++ b/include/configs/rcar-gen2-common.h @@ -34,7 +34,6 @@ #undef CONFIG_SHOW_BOOT_PROGRESS
#define CONFIG_TMU_TIMER #define CONFIG_SH_GPIO_PFC diff --git a/include/configs/rcar-gen3-common.h b/include/configs/rcar-gen3-common.h index ec4d54ed97..930f2d5f3c 100644 --- a/include/configs/rcar-gen3-common.h +++ b/include/configs/rcar-gen3-common.h @@ -43,7 +43,6 @@ #undef CONFIG_SHOW_BOOT_PROGRESS
diff --git a/include/configs/redwood.h b/include/configs/redwood.h index 72fbf108fa..9f8f60c2c1 100644 --- a/include/configs/redwood.h +++ b/include/configs/redwood.h @@ -14,7 +14,6 @@ *----------------------------------------------------------------------*/ #define CONFIG_440 1 /* ... PPC460 family */ #define CONFIG_460SX 1 /* ... PPC460 family */ -#define CONFIG_BOARD_EARLY_INIT_F 1 /* Call board_pre_init */
#define CONFIG_SYS_TEXT_BASE 0xfffb0000
diff --git a/include/configs/s32v234evb.h b/include/configs/s32v234evb.h index 9ee68dde7b..4d048ba28b 100644 --- a/include/configs/s32v234evb.h +++ b/include/configs/s32v234evb.h @@ -61,7 +61,6 @@ #else #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 2 * 1024 * 1024) #endif -#define CONFIG_BOARD_EARLY_INIT_F
#define CONFIG_DM_SERIAL #define CONFIG_FSL_LINFLEXUART diff --git a/include/configs/sama5d2_xplained.h b/include/configs/sama5d2_xplained.h index 4f72c83d6b..49b0419e9a 100644 --- a/include/configs/sama5d2_xplained.h +++ b/include/configs/sama5d2_xplained.h @@ -15,8 +15,6 @@
#include "at91-sama5_common.h"
-#define CONFIG_BOARD_EARLY_INIT_F - #define CONFIG_MISC_INIT_R
/* SDRAM */ diff --git a/include/configs/sbc8349.h b/include/configs/sbc8349.h index ca1797d093..ca5e64fd9b 100644 --- a/include/configs/sbc8349.h +++ b/include/configs/sbc8349.h @@ -50,8 +50,6 @@ #endif #endif
-#undef CONFIG_BOARD_EARLY_INIT_F /* call board_pre_init */ - #define CONFIG_SYS_IMMR 0xE0000000
#undef CONFIG_SYS_DRAM_TEST /* memory test, takes time */ diff --git a/include/configs/sbc8548.h b/include/configs/sbc8548.h index 281a9938c4..f5a5b61940 100644 --- a/include/configs/sbc8548.h +++ b/include/configs/sbc8548.h @@ -86,8 +86,6 @@ */ #define CONFIG_ENABLE_36BIT_PHYS 1
-#define CONFIG_BOARD_EARLY_INIT_F 1 /* Call board_pre_init */ - #undef CONFIG_SYS_DRAM_TEST /* memory test, takes time */ #define CONFIG_SYS_MEMTEST_START 0x00200000 /* memtest works on */ #define CONFIG_SYS_MEMTEST_END 0x00400000 diff --git a/include/configs/sbc8641d.h b/include/configs/sbc8641d.h index f02634b1a2..30eb114812 100644 --- a/include/configs/sbc8641d.h +++ b/include/configs/sbc8641d.h @@ -75,8 +75,6 @@ #define CONFIG_SYS_CLK_FREQ get_board_sys_clk(0) #endif
-#define CONFIG_BOARD_EARLY_INIT_F 1 /* Call board_pre_init */ - #undef CONFIG_SYS_DRAM_TEST /* memory test, takes time */ #define CONFIG_SYS_MEMTEST_START 0x00200000 /* memtest region */ #define CONFIG_SYS_MEMTEST_END 0x00400000 diff --git a/include/configs/secomx6quq7.h b/include/configs/secomx6quq7.h index 51b88a485b..a5de46ac1c 100644 --- a/include/configs/secomx6quq7.h +++ b/include/configs/secomx6quq7.h @@ -16,8 +16,6 @@ /* Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (10 * SZ_1M)
-#define CONFIG_BOARD_EARLY_INIT_F - #define CONFIG_MXC_UART #define CONFIG_MXC_UART_BASE UART2_BASE
diff --git a/include/configs/sequoia.h b/include/configs/sequoia.h index ed8a51c663..a913cbf7ca 100644 --- a/include/configs/sequoia.h +++ b/include/configs/sequoia.h @@ -54,7 +54,6 @@ #define CONFIG_4xx_DCACHE /* enable dcache */ #endif
/* diff --git a/include/configs/smartweb.h b/include/configs/smartweb.h index fd35f71f91..5ecc693fc8 100644 --- a/include/configs/smartweb.h +++ b/include/configs/smartweb.h @@ -46,7 +46,6 @@ #define CONFIG_SETUP_MEMORY_TAGS /* pass memory defs to kernel */ #define CONFIG_INITRD_TAG /* pass initrd param to kernel */ #define CONFIG_SKIP_LOWLEVEL_INIT_ONLY /* U-Boot is loaded by a bootloader */ -#define CONFIG_BOARD_EARLY_INIT_F /* call board_early_init_f() */
/* We set the max number of command args high to avoid HUSH bugs. */ #define CONFIG_SYS_MAXARGS 32 diff --git a/include/configs/snapper9g45.h b/include/configs/snapper9g45.h index 6acc82ce9a..8cfdcdea12 100644 --- a/include/configs/snapper9g45.h +++ b/include/configs/snapper9g45.h @@ -26,7 +26,6 @@ #define CONFIG_SETUP_MEMORY_TAGS #define CONFIG_INITRD_TAG #define CONFIG_SKIP_LOWLEVEL_INIT_ONLY -#define CONFIG_BOARD_EARLY_INIT_F
/* SDRAM */ #define CONFIG_NR_DRAM_BANKS 1 diff --git a/include/configs/socfpga_sr1500.h b/include/configs/socfpga_sr1500.h index 0407f03969..424cada157 100644 --- a/include/configs/socfpga_sr1500.h +++ b/include/configs/socfpga_sr1500.h @@ -8,8 +8,6 @@
#include <asm/arch/base_addr_ac5.h>
-#define CONFIG_BOARD_EARLY_INIT_F - #define CONFIG_SYS_NO_FLASH #define CONFIG_DOS_PARTITION #define CONFIG_FAT_WRITE diff --git a/include/configs/som-6896.h b/include/configs/som-6896.h index ba11b2061a..af51c2a94b 100644 --- a/include/configs/som-6896.h +++ b/include/configs/som-6896.h @@ -14,7 +14,6 @@
#define CONFIG_SCSI_DEV_LIST \ diff --git a/include/configs/som-db5800-som-6867.h b/include/configs/som-db5800-som-6867.h index e13f343751..ec1b6acc02 100644 --- a/include/configs/som-db5800-som-6867.h +++ b/include/configs/som-db5800-som-6867.h @@ -14,7 +14,6 @@ #include <configs/x86-common.h>
#define CONFIG_STD_DEVICES_SETTINGS "stdin=serial,usbkbd\0" \ diff --git a/include/configs/spear-common.h b/include/configs/spear-common.h index 912b776409..77b80df2a6 100644 --- a/include/configs/spear-common.h +++ b/include/configs/spear-common.h @@ -172,7 +172,6 @@
/* Miscellaneous configurable options */ #define CONFIG_ARCH_CPU_INIT -#define CONFIG_BOARD_EARLY_INIT_F #define CONFIG_BOOT_PARAMS_ADDR 0x00000100 #define CONFIG_CMDLINE_TAG #define CONFIG_SETUP_MEMORY_TAGS diff --git a/include/configs/stm32f429-discovery.h b/include/configs/stm32f429-discovery.h index 6b35641102..69135ff0f6 100644 --- a/include/configs/stm32f429-discovery.h +++ b/include/configs/stm32f429-discovery.h @@ -11,7 +11,6 @@ #define CONFIG_SYS_THUMB_BUILD #define CONFIG_STM32F4DISCOVERY
#define CONFIG_SYS_FLASH_BASE 0x08000000 diff --git a/include/configs/stm32f746-disco.h b/include/configs/stm32f746-disco.h index 4391bff1cc..b4a8f41014 100644 --- a/include/configs/stm32f746-disco.h +++ b/include/configs/stm32f746-disco.h @@ -11,8 +11,6 @@ #define CONFIG_SYS_THUMB_BUILD /*#define CONFIG_SYS_NO_FLASH*/
-#define CONFIG_BOARD_EARLY_INIT_F - #define CONFIG_SYS_FLASH_BASE 0x08000000 #define CONFIG_SYS_INIT_SP_ADDR 0x20050000 #define CONFIG_SYS_TEXT_BASE 0x08000000 diff --git a/include/configs/strider.h b/include/configs/strider.h index 3be25976a4..a038ded2ae 100644 --- a/include/configs/strider.h +++ b/include/configs/strider.h @@ -20,7 +20,6 @@
#define CONFIG_SYS_TEXT_BASE 0xFE000000
diff --git a/include/configs/stv0991.h b/include/configs/stv0991.h index 09a3064bd6..0e7d8608a2 100644 --- a/include/configs/stv0991.h +++ b/include/configs/stv0991.h @@ -9,7 +9,6 @@ #define __CONFIG_STV0991_H #define CONFIG_SYS_DCACHE_OFF #define CONFIG_SYS_EXCEPTION_VECTORS_HIGH -#define CONFIG_BOARD_EARLY_INIT_F
#define CONFIG_SYS_CORTEX_R4
diff --git a/include/configs/t3corp.h b/include/configs/t3corp.h index e0c7674989..d3f2050736 100644 --- a/include/configs/t3corp.h +++ b/include/configs/t3corp.h @@ -30,7 +30,6 @@
-#define CONFIG_BOARD_EARLY_INIT_F 1 /* Call board_early_init_f */ #define CONFIG_BOARD_EARLY_INIT_R 1 /* Call board_early_init_r */ #define CONFIG_MISC_INIT_R 1 /* Call misc_init_r */ #define CONFIG_BOARD_TYPES 1 /* support board types */ diff --git a/include/configs/taurus.h b/include/configs/taurus.h index ab457da2a0..0b07e30fa0 100644 --- a/include/configs/taurus.h +++ b/include/configs/taurus.h @@ -46,7 +46,6 @@ #define CONFIG_SETUP_MEMORY_TAGS #define CONFIG_INITRD_TAG #define CONFIG_SKIP_LOWLEVEL_INIT_ONLY -#define CONFIG_BOARD_EARLY_INIT_F
/* general purpose I/O */ #define CONFIG_ATMEL_LEGACY /* required until (g)pio is fixed */ diff --git a/include/configs/tbs2910.h b/include/configs/tbs2910.h index 0dc4a28a43..3b56be8b0b 100644 --- a/include/configs/tbs2910.h +++ b/include/configs/tbs2910.h @@ -16,8 +16,6 @@
#define CONFIG_MACH_TYPE 3980
#define CONFIG_IMX_THERMAL diff --git a/include/configs/tegra-common.h b/include/configs/tegra-common.h index 6528624108..8bdfade2e9 100644 --- a/include/configs/tegra-common.h +++ b/include/configs/tegra-common.h @@ -104,8 +104,6 @@ CONFIG_SPL_TEXT_BASE) #define CONFIG_SYS_SPL_MALLOC_SIZE 0x00010000
-#define CONFIG_BOARD_EARLY_INIT_F - /* Misc utility code */ #define CONFIG_BOUNCE_BUFFER #define CONFIG_CRC32_VERIFY diff --git a/include/configs/ti_am335x_common.h b/include/configs/ti_am335x_common.h index 809d015cf9..c0e4336eb0 100644 --- a/include/configs/ti_am335x_common.h +++ b/include/configs/ti_am335x_common.h @@ -75,9 +75,6 @@ * we need to call board_early_init_f. This is taken care of in * s_init when we have SPL used. */ -#if !defined(CONFIG_SKIP_LOWLEVEL_INIT) && !defined(CONFIG_SPL) -#define CONFIG_BOARD_EARLY_INIT_F -#endif
#ifdef CONFIG_NAND #define CONFIG_SPL_NAND_AM33XX_BCH /* ELM support */ diff --git a/include/configs/ti_armv7_keystone2.h b/include/configs/ti_armv7_keystone2.h index 28a80f5267..f88501505f 100644 --- a/include/configs/ti_armv7_keystone2.h +++ b/include/configs/ti_armv7_keystone2.h @@ -14,7 +14,6 @@
/* U-Boot Build Configuration */ #define CONFIG_SKIP_LOWLEVEL_INIT /* U-Boot is a 2nd stage loader */ -#define CONFIG_BOARD_EARLY_INIT_F
/* SoC Configuration */ #define CONFIG_ARCH_CPU_INIT diff --git a/include/configs/titanium.h b/include/configs/titanium.h index bbdaf0443d..a53969f74f 100644 --- a/include/configs/titanium.h +++ b/include/configs/titanium.h @@ -23,7 +23,6 @@ /* Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (2 * 1024 * 1024)
#define CONFIG_MXC_UART diff --git a/include/configs/tplink_wdr4300.h b/include/configs/tplink_wdr4300.h index fefc902360..6f780bc0b0 100644 --- a/include/configs/tplink_wdr4300.h +++ b/include/configs/tplink_wdr4300.h @@ -7,8 +7,6 @@ #ifndef __CONFIG_H #define __CONFIG_H
-#define CONFIG_BOARD_EARLY_INIT_F - #define CONFIG_SYS_HZ 1000 #define CONFIG_SYS_MHZ 280 #define CONFIG_SYS_MIPS_TIMER_FREQ (CONFIG_SYS_MHZ * 1000000) diff --git a/include/configs/tqma6.h b/include/configs/tqma6.h index a35d292f16..09783a2ca0 100644 --- a/include/configs/tqma6.h +++ b/include/configs/tqma6.h @@ -32,8 +32,6 @@ #define PHYS_SDRAM_SIZE (1024u * SZ_1M) #endif
/* SPI */ diff --git a/include/configs/ts4800.h b/include/configs/ts4800.h index 261daef9aa..ac8c59f4f2 100644 --- a/include/configs/ts4800.h +++ b/include/configs/ts4800.h @@ -148,8 +148,6 @@ #define CONFIG_SYS_INIT_RAM_ADDR (IRAM_BASE_ADDR) #define CONFIG_SYS_INIT_RAM_SIZE (IRAM_SIZE)
-#define CONFIG_BOARD_EARLY_INIT_F - #define CONFIG_SYS_INIT_SP_OFFSET \ (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_ADDR \ diff --git a/include/configs/udoo.h b/include/configs/udoo.h index 05687dda4a..961062178d 100644 --- a/include/configs/udoo.h +++ b/include/configs/udoo.h @@ -19,8 +19,6 @@ /* Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (2 * SZ_1M)
diff --git a/include/configs/udoo_neo.h b/include/configs/udoo_neo.h index 94a38d1264..9835ce8875 100644 --- a/include/configs/udoo_neo.h +++ b/include/configs/udoo_neo.h @@ -18,7 +18,6 @@
/* Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (3 * SZ_1M) -#define CONFIG_BOARD_EARLY_INIT_F #define CONFIG_MXC_UART
/* MMC Configuration */ diff --git a/include/configs/usbarmory.h b/include/configs/usbarmory.h index 904b7727a8..b32cd6a391 100644 --- a/include/configs/usbarmory.h +++ b/include/configs/usbarmory.h @@ -13,7 +13,6 @@
#define CONFIG_MX53 #define CONFIG_SYS_FSL_CLK -#define CONFIG_BOARD_EARLY_INIT_F #define CONFIG_MXC_GPIO #define CONFIG_SYS_NO_FLASH
diff --git a/include/configs/v38b.h b/include/configs/v38b.h index 7d013232b6..1f48a41589 100644 --- a/include/configs/v38b.h +++ b/include/configs/v38b.h @@ -27,7 +27,6 @@ #define CONFIG_NETCONSOLE 1
#define CONFIG_BOARD_EARLY_INIT_R 1 /* do board-specific init */ -#define CONFIG_BOARD_EARLY_INIT_F 1 /* do board-specific init */ #define CONFIG_MISC_INIT_R
#define CONFIG_SYS_XLB_PIPELINING 1 /* gives better performance */ diff --git a/include/configs/ve8313.h b/include/configs/ve8313.h index e293f12b4e..564607e516 100644 --- a/include/configs/ve8313.h +++ b/include/configs/ve8313.h @@ -28,8 +28,6 @@ #define CONFIG_PCI_INDIRECT_BRIDGE 1 #define CONFIG_FSL_ELBC 1
-#define CONFIG_BOARD_EARLY_INIT_F 1 - /* * On-board devices * diff --git a/include/configs/vf610twr.h b/include/configs/vf610twr.h index f122c9886f..a8cd96b02e 100644 --- a/include/configs/vf610twr.h +++ b/include/configs/vf610twr.h @@ -30,8 +30,6 @@ /* Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 2 * 1024 * 1024)
-#define CONFIG_BOARD_EARLY_INIT_F - /* Allow to overwrite serial and ethaddr */ #define CONFIG_ENV_OVERWRITE #define CONFIG_BAUDRATE 115200 diff --git a/include/configs/vining_2000.h b/include/configs/vining_2000.h index 1aca9d2900..0ff0a16171 100644 --- a/include/configs/vining_2000.h +++ b/include/configs/vining_2000.h @@ -18,8 +18,6 @@ /* Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (3 * SZ_1M)
diff --git a/include/configs/walnut.h b/include/configs/walnut.h index 2edc0b0e8e..c48a6ae445 100644 --- a/include/configs/walnut.h +++ b/include/configs/walnut.h @@ -29,8 +29,6 @@ #define CONFIG_HOSTNAME walnut #include "amcc-common.h"
/* diff --git a/include/configs/wandboard.h b/include/configs/wandboard.h index 125c74ed1e..d337979f7c 100644 --- a/include/configs/wandboard.h +++ b/include/configs/wandboard.h @@ -20,8 +20,6 @@ /* Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (10 * SZ_1M)
diff --git a/include/configs/warp.h b/include/configs/warp.h index 90ff9417c6..865f2ac81c 100644 --- a/include/configs/warp.h +++ b/include/configs/warp.h @@ -18,8 +18,6 @@ /* Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (35 * SZ_1M) /* Increase due to DFU */
diff --git a/include/configs/warp7.h b/include/configs/warp7.h index 10c20e77b3..4528f094ce 100644 --- a/include/configs/warp7.h +++ b/include/configs/warp7.h @@ -18,8 +18,6 @@ /* Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (35 * SZ_1M)
-#define CONFIG_BOARD_EARLY_INIT_F - /* MMC Config*/ #define CONFIG_SYS_FSL_ESDHC_ADDR USDHC3_BASE_ADDR #define CONFIG_SUPPORT_EMMC_BOOT diff --git a/include/configs/woodburn.h b/include/configs/woodburn.h index c14f7d47d0..f3bc719404 100644 --- a/include/configs/woodburn.h +++ b/include/configs/woodburn.h @@ -16,6 +16,5 @@
/* Set TEXT at the beginning of the NOR flash */ #define CONFIG_SYS_TEXT_BASE 0xA0000000 -#define CONFIG_BOARD_EARLY_INIT_F
#endif /* __CONFIG_H */ diff --git a/include/configs/work_92105.h b/include/configs/work_92105.h index b08641fcf0..33e2b98bb5 100644 --- a/include/configs/work_92105.h +++ b/include/configs/work_92105.h @@ -26,7 +26,6 @@ #if !defined(CONFIG_SPL_BUILD) #define CONFIG_SKIP_LOWLEVEL_INIT #endif -#define CONFIG_BOARD_EARLY_INIT_F #define CONFIG_BOARD_EARLY_INIT_R
/* generate LPC32XX-specific SPL image */ diff --git a/include/configs/x86-chromebook.h b/include/configs/x86-chromebook.h index 545cffbfaa..e8ad29d3d0 100644 --- a/include/configs/x86-chromebook.h +++ b/include/configs/x86-chromebook.h @@ -9,7 +9,6 @@
#define CONFIG_X86_MRC_ADDR 0xfffa0000 diff --git a/include/configs/xpedite1000.h b/include/configs/xpedite1000.h index bfe68f01d1..45436c8ac0 100644 --- a/include/configs/xpedite1000.h +++ b/include/configs/xpedite1000.h @@ -20,7 +20,6 @@ #define CONFIG_SYS_FORM_PMC 1 #define CONFIG_440 1 #define CONFIG_440GX 1 /* 440 GX */ -#define CONFIG_BOARD_EARLY_INIT_F 1 /* Call board_pre_init */ #define CONFIG_SYS_CLK_FREQ 33333333 /* external freq to pll */
#define CONFIG_SYS_TEXT_BASE 0xFFF80000 diff --git a/include/configs/xpress.h b/include/configs/xpress.h index 2dc57e9124..ce355bf671 100644 --- a/include/configs/xpress.h +++ b/include/configs/xpress.h @@ -17,8 +17,6 @@ /* Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (16 << 20)
diff --git a/include/configs/yosemite.h b/include/configs/yosemite.h index a355112ab6..c77967b1d3 100644 --- a/include/configs/yosemite.h +++ b/include/configs/yosemite.h @@ -32,7 +32,6 @@ */ #include "amcc-common.h"
-#define CONFIG_BOARD_EARLY_INIT_F 1 /* Call board_early_init_f */ #define CONFIG_MISC_INIT_R 1 /* call misc_init_r() */ #define CONFIG_BOARD_RESET 1 /* call board_reset() */
diff --git a/include/configs/yucca.h b/include/configs/yucca.h index 0a3e4b3bea..183bfce2af 100644 --- a/include/configs/yucca.h +++ b/include/configs/yucca.h @@ -21,7 +21,6 @@ #define CONFIG_440 1 /* ... PPC440 family */ #define CONFIG_440SPE 1 /* Specifc SPe support */ #define CONFIG_440SPE_REVA 1 /* Support old Rev A. */ -#define CONFIG_BOARD_EARLY_INIT_F 1 /* Call board_pre_init */ #define CONFIG_SYS_CLK_FREQ 33333333 /* external freq to pll */ #define EXTCLK_33_33 33333333 #define EXTCLK_66_66 66666666
On Mon, Jan 23, 2017 at 01:31:20PM -0700, Simon Glass wrote:
This converts the following to Kconfig: CONFIG_BOARD_EARLY_INIT_F
Signed-off-by: Simon Glass sjg@chromium.org
This converts the following to Kconfig: CONFIG_ARCH_MISC_INIT
arch/Kconfig | 1 + arch/arm/Kconfig | 7 +++++++ arch/arm/mach-mvebu/Kconfig | 1 + arch/blackfin/include/asm/config.h | 2 -- common/Kconfig | 8 ++++++++ configs/am335x_baltos_defconfig | 1 + configs/am335x_boneblack_defconfig | 1 + configs/am335x_boneblack_vboot_defconfig | 1 + configs/am335x_evm_defconfig | 1 + configs/am335x_evm_nor_defconfig | 1 + configs/am335x_evm_norboot_defconfig | 1 + configs/am335x_evm_spiboot_defconfig | 1 + configs/am335x_evm_usbspl_defconfig | 1 + configs/apalis_t30_defconfig | 1 + configs/apx4devkit_defconfig | 1 + configs/bayleybay_defconfig | 1 + configs/bg0900_defconfig | 1 + configs/birdland_bav335a_defconfig | 1 + configs/birdland_bav335b_defconfig | 1 + configs/brppt1_mmc_defconfig | 1 + configs/brppt1_nand_defconfig | 1 + configs/brppt1_spi_defconfig | 1 + configs/brxre1_defconfig | 1 + configs/colibri_t20_defconfig | 1 + configs/colibri_t30_defconfig | 1 + configs/colibri_vf_defconfig | 1 + configs/conga-qeval20-qa3-e3845-internal-uart_defconfig | 1 + configs/conga-qeval20-qa3-e3845_defconfig | 1 + configs/draco_defconfig | 1 + configs/edminiv2_defconfig | 1 + configs/etamin_defconfig | 1 + configs/galileo_defconfig | 1 + configs/m28evk_defconfig | 1 + configs/minnowmax_defconfig | 1 + configs/mx23_olinuxino_defconfig | 1 + configs/mx23evk_defconfig | 1 + configs/mx28evk_auart_console_defconfig | 1 + configs/mx28evk_defconfig | 1 + configs/mx28evk_nand_defconfig | 1 + configs/mx28evk_spi_defconfig | 1 + configs/pcm051_rev1_defconfig | 1 + configs/pcm051_rev3_defconfig | 1 + configs/pengwyn_defconfig | 1 + configs/pxm2_defconfig | 1 + configs/rastaban_defconfig | 1 + configs/rut_defconfig | 1 + configs/sansa_fuze_plus_defconfig | 1 + configs/sc_sps_1_defconfig | 1 + configs/som-db5800-som-6867_defconfig | 1 + configs/thuban_defconfig | 1 + configs/ts4600_defconfig | 1 + configs/xfi3_defconfig | 1 + include/configs/am335x_evm.h | 1 - include/configs/apalis_t30.h | 2 -- include/configs/aspenite.h | 1 - include/configs/baltos.h | 1 - include/configs/bav335x.h | 1 - include/configs/bayleybay.h | 1 - include/configs/brppt1.h | 1 - include/configs/brxre1.h | 1 - include/configs/colibri_imx7.h | 2 -- include/configs/colibri_t20.h | 2 -- include/configs/colibri_t30.h | 2 -- include/configs/colibri_vf.h | 1 - include/configs/conga-qeval20-qa3-e3845.h | 1 - include/configs/edminiv2.h | 1 - include/configs/galileo.h | 1 - include/configs/gplugd.h | 1 - include/configs/km/km_arm.h | 1 - include/configs/ls2080a_common.h | 1 - include/configs/minnowmax.h | 1 - include/configs/mv-common.h | 1 - include/configs/mx7_common.h | 2 -- include/configs/mxs.h | 1 - include/configs/pcm051.h | 1 - include/configs/pengwyn.h | 1 - include/configs/siemens-am33x-common.h | 1 - include/configs/socfpga_common.h | 1 - include/configs/som-db5800-som-6867.h | 1 - scripts/config_whitelist.txt | 1 - 80 files changed, 64 insertions(+), 35 deletions(-)
diff --git a/arch/Kconfig b/arch/Kconfig index 692610b2ff..36637d8448 100644 --- a/arch/Kconfig +++ b/arch/Kconfig @@ -26,6 +26,7 @@ config AVR32
config BLACKFIN bool "Blackfin architecture" + select ARCH_MISC_INIT
config M68K bool "M68000 architecture" diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 4085a9a731..826c9cbf0c 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -202,6 +202,7 @@ config KIRKWOOD bool "Marvell Kirkwood" select CPU_ARM926EJS select BOARD_EARLY_INIT_F + select ARCH_MISC_INIT
config ARCH_MVEBU bool "Marvell MVEBU family (Armada XP/375/38x/3700/7K/8K)" @@ -498,6 +499,7 @@ config ARCH_MX7 select SYS_FSL_SEC_COMPAT_4 select SYS_FSL_SEC_LE select BOARD_EARLY_INIT_F + select ARCH_MISC_INIT
config ARCH_MX6 bool "Freescale MX6" @@ -608,6 +610,7 @@ config ARCH_SOCFPGA select DM_SPI select ENABLE_ARM_SOC_BOOT0_HOOK select ARCH_EARLY_INIT_R + select ARCH_MISC_INIT
config TARGET_CM_T43 bool "Support cm_t43" @@ -729,6 +732,7 @@ config TARGET_LS2080A_EMU select ARCH_LS2080A select ARM64 select ARMV8_MULTIENTRY + select ARCH_MISC_INIT help Support for Freescale LS2080A_EMU platform The LS2080A Development System (EMULATOR) is a pre silicon @@ -740,6 +744,7 @@ config TARGET_LS2080A_SIMU select ARCH_LS2080A select ARM64 select ARMV8_MULTIENTRY + select ARCH_MISC_INIT help Support for Freescale LS2080A_SIMU platform The LS2080A Development System (QDS) is a pre silicon @@ -752,6 +757,7 @@ config TARGET_LS2080AQDS select ARM64 select ARMV8_MULTIENTRY select SUPPORT_SPL + select ARCH_MISC_INIT help Support for Freescale LS2080AQDS platform The LS2080A Development System (QDS) is a high-performance @@ -764,6 +770,7 @@ config TARGET_LS2080ARDB select ARM64 select ARMV8_MULTIENTRY select SUPPORT_SPL + select ARCH_MISC_INIT help Support for Freescale LS2080ARDB platform. The LS2080A Reference design board (RDB) is a high-performance diff --git a/arch/arm/mach-mvebu/Kconfig b/arch/arm/mach-mvebu/Kconfig index 06dc82a8d2..d80e97920d 100644 --- a/arch/arm/mach-mvebu/Kconfig +++ b/arch/arm/mach-mvebu/Kconfig @@ -9,6 +9,7 @@ config ARMADA_32BIT select SPL_OF_CONTROL select SPL_SIMPLE_BUS select BOARD_EARLY_INIT_F + select ARCH_MISC_INIT
config ARMADA_64BIT bool diff --git a/arch/blackfin/include/asm/config.h b/arch/blackfin/include/asm/config.h index de3c97931d..4e8313d811 100644 --- a/arch/blackfin/include/asm/config.h +++ b/arch/blackfin/include/asm/config.h @@ -171,8 +171,6 @@ } #endif
-#define CONFIG_ARCH_MISC_INIT - #define CONFIG_CPU CONFIG_BFIN_CPU
#endif diff --git a/common/Kconfig b/common/Kconfig index fa90076a70..32d72ca95b 100644 --- a/common/Kconfig +++ b/common/Kconfig @@ -410,6 +410,14 @@ config ARCH_EARLY_INIT_R is on. Note that board_early_init_r() is called first, if enabled. This can be used to set up architecture-specific devices.
+config ARCH_MISC_INIT + bool "Call arch-specific init after relocation, when console is ready" + help + With this option U-Boot will call arch_misc_init() after + relocation to allow miscellaneous arch-dependent initialisation + to be performed. This function should be defined by the board + and will be called after the console is set up, after relocaiton. + config BOARD_EARLY_INIT_F bool "Call board-specific init before relocation" default y if X86 diff --git a/configs/am335x_baltos_defconfig b/configs/am335x_baltos_defconfig index d3a3e0305e..b1cb6dc5d5 100644 --- a/configs/am335x_baltos_defconfig +++ b/configs/am335x_baltos_defconfig @@ -22,6 +22,7 @@ CONFIG_SYS_EXTRA_OPTIONS="NAND" CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y CONFIG_BOARD_LATE_INIT=y +CONFIG_ARCH_MISC_INIT=y CONFIG_SPL=y CONFIG_SPL_STACK_R=y CONFIG_SPL_MTD_SUPPORT=y diff --git a/configs/am335x_boneblack_defconfig b/configs/am335x_boneblack_defconfig index b9e2706cc4..57b67cc8e3 100644 --- a/configs/am335x_boneblack_defconfig +++ b/configs/am335x_boneblack_defconfig @@ -9,6 +9,7 @@ CONFIG_SYS_EXTRA_OPTIONS="EMMC_BOOT" CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y CONFIG_BOARD_LATE_INIT=y +CONFIG_ARCH_MISC_INIT=y CONFIG_SPL=y CONFIG_SPL_STACK_R=y CONFIG_SPL_MUSB_NEW_SUPPORT=y diff --git a/configs/am335x_boneblack_vboot_defconfig b/configs/am335x_boneblack_vboot_defconfig index 0c51789599..ab24daf7ac 100644 --- a/configs/am335x_boneblack_vboot_defconfig +++ b/configs/am335x_boneblack_vboot_defconfig @@ -12,6 +12,7 @@ CONFIG_SYS_EXTRA_OPTIONS="EMMC_BOOT,ENABLE_VBOOT" CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y CONFIG_BOARD_LATE_INIT=y +CONFIG_ARCH_MISC_INIT=y CONFIG_SPL=y CONFIG_SPL_STACK_R=y CONFIG_SPL_MUSB_NEW_SUPPORT=y diff --git a/configs/am335x_evm_defconfig b/configs/am335x_evm_defconfig index 5e063ce422..fb50d40082 100644 --- a/configs/am335x_evm_defconfig +++ b/configs/am335x_evm_defconfig @@ -10,6 +10,7 @@ CONFIG_SYS_EXTRA_OPTIONS="NAND" CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y CONFIG_BOARD_LATE_INIT=y +CONFIG_ARCH_MISC_INIT=y CONFIG_SPL=y CONFIG_SPL_STACK_R=y CONFIG_SPL_MTD_SUPPORT=y diff --git a/configs/am335x_evm_nor_defconfig b/configs/am335x_evm_nor_defconfig index 2f39facb54..6158dc6d03 100644 --- a/configs/am335x_evm_nor_defconfig +++ b/configs/am335x_evm_nor_defconfig @@ -9,6 +9,7 @@ CONFIG_SYS_EXTRA_OPTIONS="NAND" CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y CONFIG_BOARD_LATE_INIT=y +CONFIG_ARCH_MISC_INIT=y CONFIG_SPL=y CONFIG_SPL_STACK_R=y CONFIG_SPL_MTD_SUPPORT=y diff --git a/configs/am335x_evm_norboot_defconfig b/configs/am335x_evm_norboot_defconfig index 3eb73f0238..a228189e84 100644 --- a/configs/am335x_evm_norboot_defconfig +++ b/configs/am335x_evm_norboot_defconfig @@ -8,6 +8,7 @@ CONFIG_NOR_BOOT=y CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y CONFIG_BOARD_LATE_INIT=y +CONFIG_ARCH_MISC_INIT=y CONFIG_BOARD_EARLY_INIT_F=y # CONFIG_CMD_IMLS is not set CONFIG_CMD_ASKENV=y diff --git a/configs/am335x_evm_spiboot_defconfig b/configs/am335x_evm_spiboot_defconfig index 089c8426cf..aacb74513c 100644 --- a/configs/am335x_evm_spiboot_defconfig +++ b/configs/am335x_evm_spiboot_defconfig @@ -12,6 +12,7 @@ CONFIG_SPI_BOOT=y CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y CONFIG_BOARD_LATE_INIT=y +CONFIG_ARCH_MISC_INIT=y CONFIG_SPL=y CONFIG_SPL_STACK_R=y CONFIG_SPL_MUSB_NEW_SUPPORT=y diff --git a/configs/am335x_evm_usbspl_defconfig b/configs/am335x_evm_usbspl_defconfig index 5d699ad8da..c67d859cf2 100644 --- a/configs/am335x_evm_usbspl_defconfig +++ b/configs/am335x_evm_usbspl_defconfig @@ -8,6 +8,7 @@ CONFIG_SYS_EXTRA_OPTIONS="NAND" CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y CONFIG_BOARD_LATE_INIT=y +CONFIG_ARCH_MISC_INIT=y CONFIG_SPL=y CONFIG_SPL_STACK_R=y CONFIG_SPL_MTD_SUPPORT=y diff --git a/configs/apalis_t30_defconfig b/configs/apalis_t30_defconfig index 4c8ce092df..c2774df2e1 100644 --- a/configs/apalis_t30_defconfig +++ b/configs/apalis_t30_defconfig @@ -8,6 +8,7 @@ CONFIG_CONSOLE_MUX=y CONFIG_SYS_STDIO_DEREGISTER=y CONFIG_BOARD_LATE_INIT=y # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_ARCH_MISC_INIT=y CONFIG_SYS_PROMPT="Apalis T30 # " # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set diff --git a/configs/apx4devkit_defconfig b/configs/apx4devkit_defconfig index b7d7b50337..0e789948d6 100644 --- a/configs/apx4devkit_defconfig +++ b/configs/apx4devkit_defconfig @@ -7,6 +7,7 @@ CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_BOOTDELAY=1 CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_ARCH_MISC_INIT=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y diff --git a/configs/bayleybay_defconfig b/configs/bayleybay_defconfig index 0ad2a88720..98483d839b 100644 --- a/configs/bayleybay_defconfig +++ b/configs/bayleybay_defconfig @@ -18,6 +18,7 @@ CONFIG_BOOTSTAGE_REPORT=y CONFIG_SYS_CONSOLE_INFO_QUIET=y # CONFIG_ARCH_EARLY_INIT_R is not set # CONFIG_BOARD_EARLY_INIT_F is not set +CONFIG_ARCH_MISC_INIT=y CONFIG_HUSH_PARSER=y CONFIG_CMD_CPU=y # CONFIG_CMD_IMLS is not set diff --git a/configs/bg0900_defconfig b/configs/bg0900_defconfig index f8e8aa0aee..7ef91a85db 100644 --- a/configs/bg0900_defconfig +++ b/configs/bg0900_defconfig @@ -7,6 +7,7 @@ CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_BOOTDELAY=3 CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_ARCH_MISC_INIT=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y diff --git a/configs/birdland_bav335a_defconfig b/configs/birdland_bav335a_defconfig index b06f691f87..3605be2ed6 100644 --- a/configs/birdland_bav335a_defconfig +++ b/configs/birdland_bav335a_defconfig @@ -19,6 +19,7 @@ CONFIG_SYS_EXTRA_OPTIONS="SERIAL1,CONS_INDEX=1" CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y CONFIG_BOARD_LATE_INIT=y +CONFIG_ARCH_MISC_INIT=y CONFIG_SPL=y CONFIG_SPL_MUSB_NEW_SUPPORT=y CONFIG_SPL_OS_BOOT=y diff --git a/configs/birdland_bav335b_defconfig b/configs/birdland_bav335b_defconfig index a21b39159e..8dab9faa77 100644 --- a/configs/birdland_bav335b_defconfig +++ b/configs/birdland_bav335b_defconfig @@ -19,6 +19,7 @@ CONFIG_SYS_EXTRA_OPTIONS="SERIAL1,CONS_INDEX=1" CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y CONFIG_BOARD_LATE_INIT=y +CONFIG_ARCH_MISC_INIT=y CONFIG_SPL=y CONFIG_SPL_MUSB_NEW_SUPPORT=y CONFIG_SPL_OS_BOOT=y diff --git a/configs/brppt1_mmc_defconfig b/configs/brppt1_mmc_defconfig index 623f26001c..8e5b7b8e89 100644 --- a/configs/brppt1_mmc_defconfig +++ b/configs/brppt1_mmc_defconfig @@ -20,6 +20,7 @@ CONFIG_VERSION_VARIABLE=y CONFIG_BOARD_LATE_INIT=y # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_ARCH_MISC_INIT=y CONFIG_SPL=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 diff --git a/configs/brppt1_nand_defconfig b/configs/brppt1_nand_defconfig index eedf1dce28..45e9047ab9 100644 --- a/configs/brppt1_nand_defconfig +++ b/configs/brppt1_nand_defconfig @@ -20,6 +20,7 @@ CONFIG_VERSION_VARIABLE=y CONFIG_BOARD_LATE_INIT=y # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_ARCH_MISC_INIT=y CONFIG_SPL=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 diff --git a/configs/brppt1_spi_defconfig b/configs/brppt1_spi_defconfig index 53c5f7dd50..0dd1232e3b 100644 --- a/configs/brppt1_spi_defconfig +++ b/configs/brppt1_spi_defconfig @@ -23,6 +23,7 @@ CONFIG_VERSION_VARIABLE=y CONFIG_BOARD_LATE_INIT=y # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_ARCH_MISC_INIT=y CONFIG_SPL=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 diff --git a/configs/brxre1_defconfig b/configs/brxre1_defconfig index 9dac59f237..ae75fa56b6 100644 --- a/configs/brxre1_defconfig +++ b/configs/brxre1_defconfig @@ -18,6 +18,7 @@ CONFIG_VERSION_VARIABLE=y CONFIG_BOARD_LATE_INIT=y # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_ARCH_MISC_INIT=y CONFIG_SPL=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 diff --git a/configs/colibri_t20_defconfig b/configs/colibri_t20_defconfig index 64991d3bf9..8c02952bf1 100644 --- a/configs/colibri_t20_defconfig +++ b/configs/colibri_t20_defconfig @@ -7,6 +7,7 @@ CONFIG_OF_SYSTEM_SETUP=y CONFIG_SYS_STDIO_DEREGISTER=y CONFIG_BOARD_LATE_INIT=y # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_ARCH_MISC_INIT=y CONFIG_SYS_PROMPT="Colibri T20 # " # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set diff --git a/configs/colibri_t30_defconfig b/configs/colibri_t30_defconfig index 44dac6d3d6..a83644ca0f 100644 --- a/configs/colibri_t30_defconfig +++ b/configs/colibri_t30_defconfig @@ -8,6 +8,7 @@ CONFIG_CONSOLE_MUX=y CONFIG_SYS_STDIO_DEREGISTER=y CONFIG_BOARD_LATE_INIT=y # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_ARCH_MISC_INIT=y CONFIG_SYS_PROMPT="Colibri T30 # " # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set diff --git a/configs/colibri_vf_defconfig b/configs/colibri_vf_defconfig index 9862b76eef..c4222a7747 100644 --- a/configs/colibri_vf_defconfig +++ b/configs/colibri_vf_defconfig @@ -6,6 +6,7 @@ CONFIG_BOOTDELAY=1 CONFIG_VERSION_VARIABLE=y CONFIG_BOARD_LATE_INIT=y # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_ARCH_MISC_INIT=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Colibri VFxx # " diff --git a/configs/conga-qeval20-qa3-e3845-internal-uart_defconfig b/configs/conga-qeval20-qa3-e3845-internal-uart_defconfig index 1efe23fac8..e5c88b4d33 100644 --- a/configs/conga-qeval20-qa3-e3845-internal-uart_defconfig +++ b/configs/conga-qeval20-qa3-e3845-internal-uart_defconfig @@ -17,6 +17,7 @@ CONFIG_BOOTSTAGE=y CONFIG_BOOTSTAGE_REPORT=y CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_BOARD_LATE_INIT=y +CONFIG_ARCH_MISC_INIT=y CONFIG_HUSH_PARSER=y CONFIG_CMD_CPU=y # CONFIG_CMD_IMLS is not set diff --git a/configs/conga-qeval20-qa3-e3845_defconfig b/configs/conga-qeval20-qa3-e3845_defconfig index b924bd7933..61b3e50c83 100644 --- a/configs/conga-qeval20-qa3-e3845_defconfig +++ b/configs/conga-qeval20-qa3-e3845_defconfig @@ -16,6 +16,7 @@ CONFIG_BOOTSTAGE=y CONFIG_BOOTSTAGE_REPORT=y CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_BOARD_LATE_INIT=y +CONFIG_ARCH_MISC_INIT=y CONFIG_HUSH_PARSER=y CONFIG_CMD_CPU=y # CONFIG_CMD_IMLS is not set diff --git a/configs/draco_defconfig b/configs/draco_defconfig index 1990279bb5..cdea3a690a 100644 --- a/configs/draco_defconfig +++ b/configs/draco_defconfig @@ -22,6 +22,7 @@ CONFIG_BOARD_LATE_INIT=y CONFIG_SPL=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 +CONFIG_ARCH_MISC_INIT=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot# " CONFIG_AUTOBOOT_KEYED=y diff --git a/configs/edminiv2_defconfig b/configs/edminiv2_defconfig index ebd76238c3..811d3852ba 100644 --- a/configs/edminiv2_defconfig +++ b/configs/edminiv2_defconfig @@ -7,6 +7,7 @@ CONFIG_TARGET_EDMINIV2=y CONFIG_IDENT_STRING=" EDMiniV2" CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_ARCH_MISC_INIT=y CONFIG_SPL=y CONFIG_SPL_NOR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/etamin_defconfig b/configs/etamin_defconfig index 8599b427e0..83f6dd3ce6 100644 --- a/configs/etamin_defconfig +++ b/configs/etamin_defconfig @@ -22,6 +22,7 @@ CONFIG_BOARD_LATE_INIT=y CONFIG_SPL=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 +CONFIG_ARCH_MISC_INIT=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot# " CONFIG_AUTOBOOT_KEYED=y diff --git a/configs/galileo_defconfig b/configs/galileo_defconfig index e25556be38..baef377470 100644 --- a/configs/galileo_defconfig +++ b/configs/galileo_defconfig @@ -11,6 +11,7 @@ CONFIG_BOOTSTAGE=y CONFIG_BOOTSTAGE_REPORT=y CONFIG_CONSOLE_MUX=y CONFIG_SYS_CONSOLE_INFO_QUIET=y +CONFIG_ARCH_MISC_INIT=y CONFIG_HUSH_PARSER=y CONFIG_CMD_CPU=y # CONFIG_CMD_IMLS is not set diff --git a/configs/m28evk_defconfig b/configs/m28evk_defconfig index 1560f00311..c372450592 100644 --- a/configs/m28evk_defconfig +++ b/configs/m28evk_defconfig @@ -11,6 +11,7 @@ CONFIG_BOOTDELAY=3 CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_ARCH_MISC_INIT=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y diff --git a/configs/minnowmax_defconfig b/configs/minnowmax_defconfig index 9215bca362..8bc79d7bdf 100644 --- a/configs/minnowmax_defconfig +++ b/configs/minnowmax_defconfig @@ -17,6 +17,7 @@ CONFIG_BOOTSTAGE=y CONFIG_BOOTSTAGE_REPORT=y CONFIG_SYS_CONSOLE_INFO_QUIET=y # CONFIG_BOARD_EARLY_INIT_F is not set +CONFIG_ARCH_MISC_INIT=y CONFIG_HUSH_PARSER=y CONFIG_CMD_CPU=y # CONFIG_CMD_IMLS is not set diff --git a/configs/mx23_olinuxino_defconfig b/configs/mx23_olinuxino_defconfig index 00cff96f37..feaa0876ef 100644 --- a/configs/mx23_olinuxino_defconfig +++ b/configs/mx23_olinuxino_defconfig @@ -7,6 +7,7 @@ CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_BOOTDELAY=3 CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_ARCH_MISC_INIT=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set diff --git a/configs/mx23evk_defconfig b/configs/mx23evk_defconfig index 21d41e3fd7..61294907c4 100644 --- a/configs/mx23evk_defconfig +++ b/configs/mx23evk_defconfig @@ -10,6 +10,7 @@ CONFIG_BOOTDELAY=1 CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_ARCH_MISC_INIT=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y diff --git a/configs/mx28evk_auart_console_defconfig b/configs/mx28evk_auart_console_defconfig index ddd442dc2a..c6956606f6 100644 --- a/configs/mx28evk_auart_console_defconfig +++ b/configs/mx28evk_auart_console_defconfig @@ -11,6 +11,7 @@ CONFIG_BOOTDELAY=1 CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_ARCH_MISC_INIT=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y diff --git a/configs/mx28evk_defconfig b/configs/mx28evk_defconfig index 947676d158..021c6891f8 100644 --- a/configs/mx28evk_defconfig +++ b/configs/mx28evk_defconfig @@ -12,6 +12,7 @@ CONFIG_BOOTDELAY=1 CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_ARCH_MISC_INIT=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y diff --git a/configs/mx28evk_nand_defconfig b/configs/mx28evk_nand_defconfig index ebe1dde008..2668f9e5e1 100644 --- a/configs/mx28evk_nand_defconfig +++ b/configs/mx28evk_nand_defconfig @@ -11,6 +11,7 @@ CONFIG_BOOTDELAY=1 CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_ARCH_MISC_INIT=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y diff --git a/configs/mx28evk_spi_defconfig b/configs/mx28evk_spi_defconfig index 5ba17efd41..abda1c867b 100644 --- a/configs/mx28evk_spi_defconfig +++ b/configs/mx28evk_spi_defconfig @@ -11,6 +11,7 @@ CONFIG_BOOTDELAY=1 CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_ARCH_MISC_INIT=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y diff --git a/configs/pcm051_rev1_defconfig b/configs/pcm051_rev1_defconfig index 732a61c650..10ddb2f79f 100644 --- a/configs/pcm051_rev1_defconfig +++ b/configs/pcm051_rev1_defconfig @@ -17,6 +17,7 @@ CONFIG_SPL_YMODEM_SUPPORT=y CONFIG_SYS_EXTRA_OPTIONS="REV1" CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y +CONFIG_ARCH_MISC_INIT=y CONFIG_SPL=y CONFIG_SPL_ETH_SUPPORT=y CONFIG_SPL_NET_SUPPORT=y diff --git a/configs/pcm051_rev3_defconfig b/configs/pcm051_rev3_defconfig index 07b2e45db4..cce07c89b7 100644 --- a/configs/pcm051_rev3_defconfig +++ b/configs/pcm051_rev3_defconfig @@ -17,6 +17,7 @@ CONFIG_SPL_YMODEM_SUPPORT=y CONFIG_SYS_EXTRA_OPTIONS="REV3" CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y +CONFIG_ARCH_MISC_INIT=y CONFIG_SPL=y CONFIG_SPL_ETH_SUPPORT=y CONFIG_SPL_NET_SUPPORT=y diff --git a/configs/pengwyn_defconfig b/configs/pengwyn_defconfig index 7696e9d90f..3ce8f44b12 100644 --- a/configs/pengwyn_defconfig +++ b/configs/pengwyn_defconfig @@ -17,6 +17,7 @@ CONFIG_SPL_WATCHDOG_SUPPORT=y CONFIG_SPL_YMODEM_SUPPORT=y CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y +CONFIG_ARCH_MISC_INIT=y CONFIG_SPL=y CONFIG_SPL_ETH_SUPPORT=y CONFIG_SPL_MTD_SUPPORT=y diff --git a/configs/pxm2_defconfig b/configs/pxm2_defconfig index da03c7fce5..9db4db4341 100644 --- a/configs/pxm2_defconfig +++ b/configs/pxm2_defconfig @@ -26,6 +26,7 @@ CONFIG_BOARD_LATE_INIT=y CONFIG_SPL=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 +CONFIG_ARCH_MISC_INIT=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot# " CONFIG_AUTOBOOT_KEYED=y diff --git a/configs/rastaban_defconfig b/configs/rastaban_defconfig index 6e7a622599..666d834948 100644 --- a/configs/rastaban_defconfig +++ b/configs/rastaban_defconfig @@ -22,6 +22,7 @@ CONFIG_BOARD_LATE_INIT=y CONFIG_SPL=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 +CONFIG_ARCH_MISC_INIT=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot# " CONFIG_AUTOBOOT_KEYED=y diff --git a/configs/rut_defconfig b/configs/rut_defconfig index 7c9590f7d0..57b90bbd02 100644 --- a/configs/rut_defconfig +++ b/configs/rut_defconfig @@ -27,6 +27,7 @@ CONFIG_ARCH_EARLY_INIT_R=y CONFIG_SPL=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 +CONFIG_ARCH_MISC_INIT=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot# " CONFIG_AUTOBOOT_KEYED=y diff --git a/configs/sansa_fuze_plus_defconfig b/configs/sansa_fuze_plus_defconfig index cb38697de0..ff5a0823d4 100644 --- a/configs/sansa_fuze_plus_defconfig +++ b/configs/sansa_fuze_plus_defconfig @@ -10,6 +10,7 @@ CONFIG_BOOTDELAY=3 CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_ARCH_MISC_INIT=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y diff --git a/configs/sc_sps_1_defconfig b/configs/sc_sps_1_defconfig index ed8b94adf0..e2a8e3c762 100644 --- a/configs/sc_sps_1_defconfig +++ b/configs/sc_sps_1_defconfig @@ -7,6 +7,7 @@ CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_BOOTDELAY=3 CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_ARCH_MISC_INIT=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y diff --git a/configs/som-db5800-som-6867_defconfig b/configs/som-db5800-som-6867_defconfig index a3ba8c161e..2c60ed7edb 100644 --- a/configs/som-db5800-som-6867_defconfig +++ b/configs/som-db5800-som-6867_defconfig @@ -15,6 +15,7 @@ CONFIG_FIT_SIGNATURE=y CONFIG_BOOTSTAGE=y CONFIG_BOOTSTAGE_REPORT=y CONFIG_SYS_CONSOLE_INFO_QUIET=y +CONFIG_ARCH_MISC_INIT=y CONFIG_HUSH_PARSER=y CONFIG_CMD_CPU=y # CONFIG_CMD_IMLS is not set diff --git a/configs/thuban_defconfig b/configs/thuban_defconfig index 8f4793d67e..25c70dcd84 100644 --- a/configs/thuban_defconfig +++ b/configs/thuban_defconfig @@ -22,6 +22,7 @@ CONFIG_BOARD_LATE_INIT=y CONFIG_SPL=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 +CONFIG_ARCH_MISC_INIT=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot# " CONFIG_AUTOBOOT_KEYED=y diff --git a/configs/ts4600_defconfig b/configs/ts4600_defconfig index 680a13c836..209aa0850e 100644 --- a/configs/ts4600_defconfig +++ b/configs/ts4600_defconfig @@ -8,6 +8,7 @@ CONFIG_SYS_CONSOLE_IS_IN_ENV=y # CONFIG_DISPLAY_CPUINFO is not set CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y +CONFIG_ARCH_MISC_INIT=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/xfi3_defconfig b/configs/xfi3_defconfig index 021a55b3a3..ce1ad56c0b 100644 --- a/configs/xfi3_defconfig +++ b/configs/xfi3_defconfig @@ -10,6 +10,7 @@ CONFIG_BOOTDELAY=3 CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_ARCH_MISC_INIT=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y diff --git a/include/configs/am335x_evm.h b/include/configs/am335x_evm.h index 88349921a0..7e0aeffe79 100644 --- a/include/configs/am335x_evm.h +++ b/include/configs/am335x_evm.h @@ -260,7 +260,6 @@ * and DFU. */ #define CONFIG_USB_MUSB_DSPS -#define CONFIG_ARCH_MISC_INIT #define CONFIG_USB_MUSB_PIO_ONLY #define CONFIG_USB_MUSB_DISABLE_BULK_COMBINE_SPLIT #define CONFIG_AM335X_USB0 diff --git a/include/configs/apalis_t30.h b/include/configs/apalis_t30.h index 1c76de06f9..e645ad201e 100644 --- a/include/configs/apalis_t30.h +++ b/include/configs/apalis_t30.h @@ -13,8 +13,6 @@
#include "tegra30-common.h"
-#define CONFIG_ARCH_MISC_INIT - /* High-level configuration options */ #define CONFIG_DISPLAY_BOARDINFO_LATE /* Calls show_board_info() */
diff --git a/include/configs/aspenite.h b/include/configs/aspenite.h index 0cc72ca266..32647d9f5a 100644 --- a/include/configs/aspenite.h +++ b/include/configs/aspenite.h @@ -35,7 +35,6 @@ * to enable certain macros */ #include "mv-common.h" -#undef CONFIG_ARCH_MISC_INIT
/* * Environment variables configurations diff --git a/include/configs/baltos.h b/include/configs/baltos.h index 4e07e52a1b..b6a6e68298 100644 --- a/include/configs/baltos.h +++ b/include/configs/baltos.h @@ -293,7 +293,6 @@ * and DFU. */ #define CONFIG_USB_MUSB_DSPS -#define CONFIG_ARCH_MISC_INIT #define CONFIG_USB_MUSB_PIO_ONLY #define CONFIG_USB_MUSB_DISABLE_BULK_COMBINE_SPLIT #define CONFIG_AM335X_USB0 diff --git a/include/configs/bav335x.h b/include/configs/bav335x.h index f293a343e4..72e11d214c 100644 --- a/include/configs/bav335x.h +++ b/include/configs/bav335x.h @@ -430,7 +430,6 @@ DEFAULT_LINUX_BOOT_ENV \ * and DFU. */ #define CONFIG_USB_MUSB_DSPS -#define CONFIG_ARCH_MISC_INIT #define CONFIG_USB_MUSB_PIO_ONLY #define CONFIG_USB_MUSB_DISABLE_BULK_COMBINE_SPLIT #define CONFIG_AM335X_USB0 diff --git a/include/configs/bayleybay.h b/include/configs/bayleybay.h index 89260475e7..60c513982e 100644 --- a/include/configs/bayleybay.h +++ b/include/configs/bayleybay.h @@ -14,7 +14,6 @@ #include <configs/x86-common.h>
#define CONFIG_SYS_MONITOR_LEN (1 << 20) -#define CONFIG_ARCH_MISC_INIT
#define CONFIG_STD_DEVICES_SETTINGS "stdin=serial,usbkbd\0" \ "stdout=serial,vidconsole\0" \ diff --git a/include/configs/brppt1.h b/include/configs/brppt1.h index 13d5ca188f..d619d23e0a 100644 --- a/include/configs/brppt1.h +++ b/include/configs/brppt1.h @@ -232,7 +232,6 @@ MMCARGS
/* USB configuration */ #define CONFIG_USB_MUSB_DSPS -#define CONFIG_ARCH_MISC_INIT #define CONFIG_USB_MUSB_PIO_ONLY #define CONFIG_USB_MUSB_DISABLE_BULK_COMBINE_SPLIT #define CONFIG_AM335X_USB0 diff --git a/include/configs/brxre1.h b/include/configs/brxre1.h index 80564261d9..98f8901d8f 100644 --- a/include/configs/brxre1.h +++ b/include/configs/brxre1.h @@ -108,7 +108,6 @@ BUR_COMMON_ENV \
/* USB configuration */ #define CONFIG_USB_MUSB_DSPS -#define CONFIG_ARCH_MISC_INIT #define CONFIG_USB_MUSB_PIO_ONLY #define CONFIG_USB_MUSB_DISABLE_BULK_COMBINE_SPLIT #define CONFIG_AM335X_USB0 diff --git a/include/configs/colibri_imx7.h b/include/configs/colibri_imx7.h index 56a6f1ed4f..7866f623ca 100644 --- a/include/configs/colibri_imx7.h +++ b/include/configs/colibri_imx7.h @@ -19,8 +19,6 @@ /*#define CONFIG_DBG_MONITOR*/ #define PHYS_SDRAM_SIZE SZ_512M
-#define CONFIG_ARCH_MISC_INIT - #define CONFIG_DISPLAY_BOARDINFO_LATE /* Calls show_board_info() */
#define CONFIG_ENV_VARS_UBOOT_CONFIG diff --git a/include/configs/colibri_t20.h b/include/configs/colibri_t20.h index e141dfb99d..791a29b4d2 100644 --- a/include/configs/colibri_t20.h +++ b/include/configs/colibri_t20.h @@ -11,8 +11,6 @@
#include "tegra20-common.h"
diff --git a/include/configs/colibri_t30.h b/include/configs/colibri_t30.h index d78eb67d0f..5b66429b8e 100644 --- a/include/configs/colibri_t30.h +++ b/include/configs/colibri_t30.h @@ -13,8 +13,6 @@
diff --git a/include/configs/colibri_vf.h b/include/configs/colibri_vf.h index 3f36d6a522..9cca4b9d82 100644 --- a/include/configs/colibri_vf.h +++ b/include/configs/colibri_vf.h @@ -18,7 +18,6 @@ #define CONFIG_SYS_THUMB_BUILD #define CONFIG_SYS_FSL_CLK
-#define CONFIG_ARCH_MISC_INIT #define CONFIG_DISPLAY_BOARDINFO_LATE /* Calls show_board_info() */
#define CONFIG_SKIP_LOWLEVEL_INIT diff --git a/include/configs/conga-qeval20-qa3-e3845.h b/include/configs/conga-qeval20-qa3-e3845.h index 12e6eb2e49..d21c95abb5 100644 --- a/include/configs/conga-qeval20-qa3-e3845.h +++ b/include/configs/conga-qeval20-qa3-e3845.h @@ -14,7 +14,6 @@ #include <configs/x86-common.h>
#define CONFIG_STD_DEVICES_SETTINGS "stdin=serial\0" \ "stdout=serial\0" \ diff --git a/include/configs/edminiv2.h b/include/configs/edminiv2.h index af7b4701ff..1f43dc0ba4 100644 --- a/include/configs/edminiv2.h +++ b/include/configs/edminiv2.h @@ -209,7 +209,6 @@ * Other required minimal configurations */ #define CONFIG_ARCH_CPU_INIT /* call arch_cpu_init() */ -#define CONFIG_ARCH_MISC_INIT /* call arch_misc_init() */ #define CONFIG_NR_DRAM_BANKS 1
#define CONFIG_SYS_LOAD_ADDR 0x00800000 diff --git a/include/configs/galileo.h b/include/configs/galileo.h index 1094143cb0..986001e9b7 100644 --- a/include/configs/galileo.h +++ b/include/configs/galileo.h @@ -14,7 +14,6 @@ #include <configs/x86-common.h>
/* ns16550 UART is memory-mapped in Quark SoC */ #undef CONFIG_SYS_NS16550_PORT_MAPPED diff --git a/include/configs/gplugd.h b/include/configs/gplugd.h index 37b0a8c50d..612e8501ed 100644 --- a/include/configs/gplugd.h +++ b/include/configs/gplugd.h @@ -79,7 +79,6 @@ * to enable certain macros */ #include "mv-common.h" -#undef CONFIG_ARCH_MISC_INIT
#ifdef CONFIG_SYS_NS16550_COM1 #undef CONFIG_SYS_NS16550_COM1 diff --git a/include/configs/km/km_arm.h b/include/configs/km/km_arm.h index 9dfb0510b5..b8698de9c2 100644 --- a/include/configs/km/km_arm.h +++ b/include/configs/km/km_arm.h @@ -147,7 +147,6 @@ * Other required minimal configurations */ #define CONFIG_ARCH_CPU_INIT /* call arch_cpu_init() */ -#define CONFIG_ARCH_MISC_INIT /* call arch_misc_init() */ #define CONFIG_NR_DRAM_BANKS 4 #define CONFIG_SYS_RESET_ADDRESS 0xffff0000 /* Rst Vector Adr */
diff --git a/include/configs/ls2080a_common.h b/include/configs/ls2080a_common.h index 851db612d7..7aef43fac2 100644 --- a/include/configs/ls2080a_common.h +++ b/include/configs/ls2080a_common.h @@ -20,7 +20,6 @@ #define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_FSL_OCRAM_BASE + 0xfff0)
/* We need architecture specific misc initializations */ -#define CONFIG_ARCH_MISC_INIT
#define CONFIG_FSL_CAAM /* Enable SEC/CAAM */
diff --git a/include/configs/minnowmax.h b/include/configs/minnowmax.h index 3507cc8996..b01ab14ecf 100644 --- a/include/configs/minnowmax.h +++ b/include/configs/minnowmax.h @@ -14,7 +14,6 @@ #include <configs/x86-common.h>
#define CONFIG_SMSC_LPC47M
diff --git a/include/configs/mv-common.h b/include/configs/mv-common.h index d7fbe963a9..547f564ae9 100644 --- a/include/configs/mv-common.h +++ b/include/configs/mv-common.h @@ -84,7 +84,6 @@ #define CONFIG_AUTO_COMPLETE #define CONFIG_CMDLINE_EDITING #define CONFIG_ARCH_CPU_INIT /* call arch_cpu_init() */ -#define CONFIG_ARCH_MISC_INIT /* call arch_misc_init() */ #define CONFIG_SYS_LOAD_ADDR 0x00800000 /* default load adr- 8M */ #define CONFIG_SYS_MEMTEST_START 0x00800000 /* 8M */ #define CONFIG_SYS_MEMTEST_END 0x00ffffff /*(_16M -1) */ diff --git a/include/configs/mx7_common.h b/include/configs/mx7_common.h index 16fedfb20b..3a9118f844 100644 --- a/include/configs/mx7_common.h +++ b/include/configs/mx7_common.h @@ -29,8 +29,6 @@ /* Enable iomux-lpsr support */ #define CONFIG_IOMUX_LPSR
-#define CONFIG_ARCH_MISC_INIT - #define CONFIG_LOADADDR 0x80800000 #define CONFIG_SYS_TEXT_BASE 0x87800000
diff --git a/include/configs/mxs.h b/include/configs/mxs.h index a225a96f7a..6a223b683f 100644 --- a/include/configs/mxs.h +++ b/include/configs/mxs.h @@ -42,7 +42,6 @@ */
/* Startup hooks */ -#define CONFIG_ARCH_MISC_INIT
/* SPL */ #define CONFIG_SPL_NO_CPU_SUPPORT_CODE diff --git a/include/configs/pcm051.h b/include/configs/pcm051.h index aff4635e90..b19349aeb3 100644 --- a/include/configs/pcm051.h +++ b/include/configs/pcm051.h @@ -132,7 +132,6 @@ * USB configuration */ #define CONFIG_USB_MUSB_DSPS -#define CONFIG_ARCH_MISC_INIT #define CONFIG_USB_MUSB_PIO_ONLY #define CONFIG_AM335X_USB0 #define CONFIG_AM335X_USB0_MODE MUSB_PERIPHERAL diff --git a/include/configs/pengwyn.h b/include/configs/pengwyn.h index f1db204910..34f88e51c7 100644 --- a/include/configs/pengwyn.h +++ b/include/configs/pengwyn.h @@ -183,7 +183,6 @@ * add mass storage support. */ #define CONFIG_USB_MUSB_DSPS -#define CONFIG_ARCH_MISC_INIT #define CONFIG_USB_MUSB_PIO_ONLY #define CONFIG_USB_MUSB_DISABLE_BULK_COMBINE_SPLIT #define CONFIG_AM335X_USB0 diff --git a/include/configs/siemens-am33x-common.h b/include/configs/siemens-am33x-common.h index 854e992cb6..1c76e12efd 100644 --- a/include/configs/siemens-am33x-common.h +++ b/include/configs/siemens-am33x-common.h @@ -190,7 +190,6 @@ * USB configuration */ #define CONFIG_USB_MUSB_DSPS -#define CONFIG_ARCH_MISC_INIT #define CONFIG_USB_MUSB_PIO_ONLY #define CONFIG_USB_MUSB_DISABLE_BULK_COMBINE_SPLIT #undef CONFIG_USB_GADGET_DUALSPEED diff --git a/include/configs/socfpga_common.h b/include/configs/socfpga_common.h index 4559138f60..27bbd0ec5a 100644 --- a/include/configs/socfpga_common.h +++ b/include/configs/socfpga_common.h @@ -15,7 +15,6 @@ * High level configuration */ #define CONFIG_DISPLAY_BOARDINFO_LATE -#define CONFIG_ARCH_MISC_INIT #define CONFIG_SYS_NO_FLASH #define CONFIG_CLOCKS
diff --git a/include/configs/som-db5800-som-6867.h b/include/configs/som-db5800-som-6867.h index ec1b6acc02..17adf7e40d 100644 --- a/include/configs/som-db5800-som-6867.h +++ b/include/configs/som-db5800-som-6867.h @@ -14,7 +14,6 @@ #include <configs/x86-common.h>
#define CONFIG_STD_DEVICES_SETTINGS "stdin=serial,usbkbd\0" \ "stdout=serial,vidconsole\0" \ diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 23ebcc63c4..f40c432990 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -115,7 +115,6 @@ CONFIG_ARCH_INNOKOM CONFIG_ARCH_KIRKWOOD CONFIG_ARCH_LUBBOCK CONFIG_ARCH_MAP_SYSMEM -CONFIG_ARCH_MISC_INIT CONFIG_ARCH_OMAP4 CONFIG_ARCH_ORION5X CONFIG_ARCH_PLEB
To avoid an unnecessary arch-specific call in board_init_f(), rename this function.
arch/powerpc/cpu/mpc8xxx/cpu.c | 2 +- board/Arcturus/ucp1020/spl.c | 2 +- board/freescale/b4860qds/spl.c | 2 +- board/freescale/c29xpcie/spl.c | 2 +- board/freescale/p1010rdb/spl.c | 2 +- board/freescale/p1022ds/spl.c | 2 +- board/freescale/p1_p2_rdb_pc/spl.c | 2 +- board/freescale/t102xqds/spl.c | 2 +- board/freescale/t102xrdb/spl.c | 2 +- board/freescale/t104xrdb/spl.c | 2 +- board/freescale/t208xqds/spl.c | 2 +- board/freescale/t208xrdb/spl.c | 2 +- board/freescale/t4qds/spl.c | 2 +- board/freescale/t4rdb/spl.c | 2 +- common/board_f.c | 4 ---- include/common.h | 12 +++++++++++- 16 files changed, 25 insertions(+), 19 deletions(-)
diff --git a/arch/powerpc/cpu/mpc8xxx/cpu.c b/arch/powerpc/cpu/mpc8xxx/cpu.c index 584f3b8d61..afb5b512ba 100644 --- a/arch/powerpc/cpu/mpc8xxx/cpu.c +++ b/arch/powerpc/cpu/mpc8xxx/cpu.c @@ -308,7 +308,7 @@ int is_core_valid(unsigned int core) return !!((1 << core) & cpu_mask()); }
-int probecpu (void) +int arch_cpu_init(void) { uint svr; uint ver; diff --git a/board/Arcturus/ucp1020/spl.c b/board/Arcturus/ucp1020/spl.c index 9c19c87b72..3a775be9ae 100644 --- a/board/Arcturus/ucp1020/spl.c +++ b/board/Arcturus/ucp1020/spl.c @@ -83,7 +83,7 @@ void board_init_r(gd_t *gd, ulong dest_addr) bd->bi_memstart = CONFIG_SYS_INIT_L2_ADDR; bd->bi_memsize = CONFIG_SYS_L2_SIZE;
- probecpu(); + arch_cpu_init(); get_clocks(); mem_malloc_init(CONFIG_SPL_RELOC_MALLOC_ADDR, CONFIG_SPL_RELOC_MALLOC_SIZE); diff --git a/board/freescale/b4860qds/spl.c b/board/freescale/b4860qds/spl.c index fabc78301a..35b812cb18 100644 --- a/board/freescale/b4860qds/spl.c +++ b/board/freescale/b4860qds/spl.c @@ -87,7 +87,7 @@ void board_init_r(gd_t *gd, ulong dest_addr) bd->bi_memstart = CONFIG_SYS_INIT_L3_ADDR; bd->bi_memsize = CONFIG_SYS_L3_SIZE;
- probecpu(); + arch_cpu_init(); get_clocks(); mem_malloc_init(CONFIG_SPL_RELOC_MALLOC_ADDR, CONFIG_SPL_RELOC_MALLOC_SIZE); diff --git a/board/freescale/c29xpcie/spl.c b/board/freescale/c29xpcie/spl.c index d8d73c70b8..6613216950 100644 --- a/board/freescale/c29xpcie/spl.c +++ b/board/freescale/c29xpcie/spl.c @@ -53,7 +53,7 @@ void board_init_r(gd_t *gd, ulong dest_addr) bd->bi_memstart = CONFIG_SYS_INIT_L2_ADDR; bd->bi_memsize = CONFIG_SYS_L2_SIZE;
- probecpu(); + arch_cpu_init(); get_clocks(); mem_malloc_init(CONFIG_SPL_RELOC_MALLOC_ADDR, CONFIG_SPL_RELOC_MALLOC_SIZE); diff --git a/board/freescale/p1010rdb/spl.c b/board/freescale/p1010rdb/spl.c index c22e215675..05c76f2e45 100644 --- a/board/freescale/p1010rdb/spl.c +++ b/board/freescale/p1010rdb/spl.c @@ -69,7 +69,7 @@ void board_init_r(gd_t *gd, ulong dest_addr) bd->bi_memstart = CONFIG_SYS_INIT_L2_ADDR; bd->bi_memsize = CONFIG_SYS_L2_SIZE;
- probecpu(); + arch_cpu_init(); get_clocks(); mem_malloc_init(CONFIG_SPL_RELOC_MALLOC_ADDR, CONFIG_SPL_RELOC_MALLOC_SIZE); diff --git a/board/freescale/p1022ds/spl.c b/board/freescale/p1022ds/spl.c index 6a5fe74343..ef38551600 100644 --- a/board/freescale/p1022ds/spl.c +++ b/board/freescale/p1022ds/spl.c @@ -83,7 +83,7 @@ void board_init_r(gd_t *gd, ulong dest_addr) bd->bi_memstart = CONFIG_SYS_INIT_L2_ADDR; bd->bi_memsize = CONFIG_SYS_L2_SIZE;
- probecpu(); + arch_cpu_init(); get_clocks(); mem_malloc_init(CONFIG_SPL_RELOC_MALLOC_ADDR, CONFIG_SPL_RELOC_MALLOC_SIZE); diff --git a/board/freescale/p1_p2_rdb_pc/spl.c b/board/freescale/p1_p2_rdb_pc/spl.c index 9e8f359d0d..2af5576ff7 100644 --- a/board/freescale/p1_p2_rdb_pc/spl.c +++ b/board/freescale/p1_p2_rdb_pc/spl.c @@ -80,7 +80,7 @@ void board_init_r(gd_t *gd, ulong dest_addr) bd->bi_memstart = CONFIG_SYS_INIT_L2_ADDR; bd->bi_memsize = CONFIG_SYS_L2_SIZE;
- probecpu(); + arch_cpu_init(); get_clocks(); mem_malloc_init(CONFIG_SPL_RELOC_MALLOC_ADDR, CONFIG_SPL_RELOC_MALLOC_SIZE); diff --git a/board/freescale/t102xqds/spl.c b/board/freescale/t102xqds/spl.c index c9239b87db..3e96b33c40 100644 --- a/board/freescale/t102xqds/spl.c +++ b/board/freescale/t102xqds/spl.c @@ -117,7 +117,7 @@ void board_init_r(gd_t *gd, ulong dest_addr) bd->bi_memstart = CONFIG_SYS_INIT_L3_ADDR; bd->bi_memsize = CONFIG_SYS_L3_SIZE;
- probecpu(); + arch_cpu_init(); get_clocks(); mem_malloc_init(CONFIG_SPL_RELOC_MALLOC_ADDR, CONFIG_SPL_RELOC_MALLOC_SIZE); diff --git a/board/freescale/t102xrdb/spl.c b/board/freescale/t102xrdb/spl.c index 6d8866e87d..b70c2c5d79 100644 --- a/board/freescale/t102xrdb/spl.c +++ b/board/freescale/t102xrdb/spl.c @@ -104,7 +104,7 @@ void board_init_r(gd_t *gd, ulong dest_addr) bd->bi_memstart = CONFIG_SYS_INIT_L3_ADDR; bd->bi_memsize = CONFIG_SYS_L3_SIZE;
- probecpu(); + arch_cpu_init(); get_clocks(); mem_malloc_init(CONFIG_SPL_RELOC_MALLOC_ADDR, CONFIG_SPL_RELOC_MALLOC_SIZE); diff --git a/board/freescale/t104xrdb/spl.c b/board/freescale/t104xrdb/spl.c index 1c2023b6a3..4402e0f4b0 100644 --- a/board/freescale/t104xrdb/spl.c +++ b/board/freescale/t104xrdb/spl.c @@ -95,7 +95,7 @@ void board_init_r(gd_t *gd, ulong dest_addr) bd->bi_memstart = CONFIG_SYS_INIT_L3_ADDR; bd->bi_memsize = CONFIG_SYS_L3_SIZE;
- probecpu(); + arch_cpu_init(); get_clocks(); mem_malloc_init(CONFIG_SPL_RELOC_MALLOC_ADDR, CONFIG_SPL_RELOC_MALLOC_SIZE); diff --git a/board/freescale/t208xqds/spl.c b/board/freescale/t208xqds/spl.c index b1e1cf17e7..334f5083b8 100644 --- a/board/freescale/t208xqds/spl.c +++ b/board/freescale/t208xqds/spl.c @@ -103,7 +103,7 @@ void board_init_r(gd_t *gd, ulong dest_addr) bd->bi_memstart = CONFIG_SYS_INIT_L3_ADDR; bd->bi_memsize = CONFIG_SYS_L3_SIZE;
- probecpu(); + arch_cpu_init(); get_clocks(); mem_malloc_init(CONFIG_SPL_RELOC_MALLOC_ADDR, CONFIG_SPL_RELOC_MALLOC_SIZE); diff --git a/board/freescale/t208xrdb/spl.c b/board/freescale/t208xrdb/spl.c index bb23865d3b..aa8e9285fe 100644 --- a/board/freescale/t208xrdb/spl.c +++ b/board/freescale/t208xrdb/spl.c @@ -73,7 +73,7 @@ void board_init_r(gd_t *gd, ulong dest_addr) bd->bi_memstart = CONFIG_SYS_INIT_L3_ADDR; bd->bi_memsize = CONFIG_SYS_L3_SIZE;
- probecpu(); + arch_cpu_init(); get_clocks(); mem_malloc_init(CONFIG_SPL_RELOC_MALLOC_ADDR, CONFIG_SPL_RELOC_MALLOC_SIZE); diff --git a/board/freescale/t4qds/spl.c b/board/freescale/t4qds/spl.c index 6ca0f03ffe..5e946dc84f 100644 --- a/board/freescale/t4qds/spl.c +++ b/board/freescale/t4qds/spl.c @@ -112,7 +112,7 @@ void board_init_r(gd_t *gd, ulong dest_addr) bd->bi_memstart = CONFIG_SYS_INIT_L3_ADDR; bd->bi_memsize = CONFIG_SYS_L3_SIZE;
- probecpu(); + arch_cpu_init(); get_clocks(); mem_malloc_init(CONFIG_SPL_RELOC_MALLOC_ADDR, CONFIG_SPL_RELOC_MALLOC_SIZE); diff --git a/board/freescale/t4rdb/spl.c b/board/freescale/t4rdb/spl.c index b148a7fd1f..a32e34ef96 100644 --- a/board/freescale/t4rdb/spl.c +++ b/board/freescale/t4rdb/spl.c @@ -76,7 +76,7 @@ void board_init_r(gd_t *gd, ulong dest_addr) bd->bi_memstart = CONFIG_SYS_INIT_L3_ADDR; bd->bi_memsize = CONFIG_SYS_L3_SIZE;
- probecpu(); + arch_cpu_init(); get_clocks(); mem_malloc_init(CONFIG_SPL_RELOC_MALLOC_ADDR, CONFIG_SPL_RELOC_MALLOC_SIZE); diff --git a/common/board_f.c b/common/board_f.c index cc8aee74f0..5e2b8d14d4 100644 --- a/common/board_f.c +++ b/common/board_f.c @@ -858,10 +858,6 @@ static init_fnc_t init_sequence_f[] = { #endif initf_malloc, initf_console_record, -#if defined(CONFIG_MPC85xx) || defined(CONFIG_MPC86xx) - /* TODO: can this go into arch_cpu_init()? */ - probecpu, -#endif #if defined(CONFIG_X86) && defined(CONFIG_HAVE_FSP) x86_fsp_init, #endif diff --git a/include/common.h b/include/common.h index 2af555ee00..53cdadf09c 100644 --- a/include/common.h +++ b/include/common.h @@ -600,7 +600,17 @@ int cpu_num_dspcores(void); u32 cpu_mask (void); u32 cpu_dsp_mask(void); int is_core_valid (unsigned int); -int probecpu (void); + +/** + * arch_cpu_init() - basic cpu-dependent setup for an architecture + * + * This is called after early malloc is available. It should handle any + * CPU- or SoC- specific init needed to continue the init sequence. See + * board_f.c for where it is called. If this is not provided, a default + * version (which does nothing) will be used. + */ +int arch_cpu_init(void); + int checkcpu (void); int checkicache (void); int checkdcache (void);
This is not defined anywhere in U-Boot. Drop this dead code.
arch/powerpc/cpu/mpc8260/spi.c | 7 ---- arch/powerpc/cpu/mpc8xx/Makefile | 1 - arch/powerpc/cpu/mpc8xx/commproc.c | 69 ---------------------------------- arch/powerpc/cpu/mpc8xx/fec.c | 10 +---- arch/powerpc/cpu/mpc8xx/i2c.c | 10 ----- arch/powerpc/cpu/mpc8xx/scc.c | 10 +---- arch/powerpc/cpu/mpc8xx/serial.c | 17 +-------- arch/powerpc/cpu/mpc8xx/spi.c | 7 ---- arch/powerpc/include/asm/global_data.h | 2 +- common/board_f.c | 5 --- include/commproc.h | 16 -------- post/cpu/mpc8xx/ether.c | 5 --- post/cpu/mpc8xx/uart.c | 13 ------- scripts/config_whitelist.txt | 1 - 14 files changed, 7 insertions(+), 166 deletions(-) delete mode 100644 arch/powerpc/cpu/mpc8xx/commproc.c
diff --git a/arch/powerpc/cpu/mpc8260/spi.c b/arch/powerpc/cpu/mpc8260/spi.c index 8c91a713bb..c7fb4e9a6c 100644 --- a/arch/powerpc/cpu/mpc8260/spi.c +++ b/arch/powerpc/cpu/mpc8260/spi.c @@ -181,14 +181,7 @@ void spi_init_f (void) spi->spi_tbc = 0; spi->spi_txtmp = 0;
- /* Allocate space for one transmit and one receive buffer - * descriptor in the DP ram - */ -#ifdef CONFIG_SYS_ALLOC_DPRAM - dpaddr = m8260_cpm_dpalloc (sizeof(cbd_t)*2, 8); -#else dpaddr = CPM_SPI_BASE; -#endif
/* 3 */ /* Set up the SPI parameters in the parameter ram */ diff --git a/arch/powerpc/cpu/mpc8xx/Makefile b/arch/powerpc/cpu/mpc8xx/Makefile index f83fd5ecf4..6f81fee571 100644 --- a/arch/powerpc/cpu/mpc8xx/Makefile +++ b/arch/powerpc/cpu/mpc8xx/Makefile @@ -10,7 +10,6 @@ extra-y += start.o extra-y += traps.o obj-y += bedbug_860.o -obj-y += commproc.o obj-y += cpu.o obj-y += cpu_init.o obj-y += fec.o diff --git a/arch/powerpc/cpu/mpc8xx/commproc.c b/arch/powerpc/cpu/mpc8xx/commproc.c deleted file mode 100644 index f8581d130d..0000000000 --- a/arch/powerpc/cpu/mpc8xx/commproc.c +++ /dev/null @@ -1,69 +0,0 @@ -/* - * (C) Copyright 2000-2002 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <commproc.h> - -DECLARE_GLOBAL_DATA_PTR; - -#ifdef CONFIG_SYS_ALLOC_DPRAM - -int dpram_init (void) -{ - /* Reclaim the DP memory for our use. */ - gd->arch.dp_alloc_base = CPM_DATAONLY_BASE; - gd->arch.dp_alloc_top = CPM_DATAONLY_BASE + CPM_DATAONLY_SIZE; - - return (0); -} - -/* Allocate some memory from the dual ported ram. We may want to - * enforce alignment restrictions, but right now everyone is a good - * citizen. - */ -uint dpram_alloc (uint size) -{ - uint addr = gd->arch.dp_alloc_base; - - if ((gd->arch.dp_alloc_base + size) >= gd->arch.dp_alloc_top) - return (CPM_DP_NOSPACE); - - gd->arch.dp_alloc_base += size; - - return addr; -} - -uint dpram_base (void) -{ - return gd->arch.dp_alloc_base; -} - -/* Allocate some memory from the dual ported ram. We may want to - * enforce alignment restrictions, but right now everyone is a good - * citizen. - */ -uint dpram_alloc_align (uint size, uint align) -{ - uint addr, mask = align - 1; - - addr = (gd->arch.dp_alloc_base + mask) & ~mask; - - if ((addr + size) >= gd->arch.dp_alloc_top) - return (CPM_DP_NOSPACE); - - gd->arch.dp_alloc_base = addr + size; - - return addr; -} - -uint dpram_base_align (uint align) -{ - uint mask = align - 1; - - return (gd->arch.dp_alloc_base + mask) & ~mask; -} -#endif /* CONFIG_SYS_ALLOC_DPRAM */ diff --git a/arch/powerpc/cpu/mpc8xx/fec.c b/arch/powerpc/cpu/mpc8xx/fec.c index 0940906b1d..b27310fffb 100644 --- a/arch/powerpc/cpu/mpc8xx/fec.c +++ b/arch/powerpc/cpu/mpc8xx/fec.c @@ -570,14 +570,8 @@ static int fec_init (struct eth_device *dev, bd_t * bd) rxIdx = 0; txIdx = 0;
- if (!rtx) { -#ifdef CONFIG_SYS_ALLOC_DPRAM - rtx = (RTXBD *) (immr->im_cpm.cp_dpmem + - dpram_alloc_align (sizeof (RTXBD), 8)); -#else - rtx = (RTXBD *) (immr->im_cpm.cp_dpmem + CPM_FEC_BASE); -#endif - } + if (!rtx) + rtx = (RTXBD *)(immr->im_cpm.cp_dpmem + CPM_FEC_BASE); /* * Setup Receiver Buffer Descriptors (13.14.24.18) * Settings: diff --git a/arch/powerpc/cpu/mpc8xx/i2c.c b/arch/powerpc/cpu/mpc8xx/i2c.c index 3dff4ab4ac..54d5cb5130 100644 --- a/arch/powerpc/cpu/mpc8xx/i2c.c +++ b/arch/powerpc/cpu/mpc8xx/i2c.c @@ -190,17 +190,7 @@ void i2c_init(int speed, int slaveaddr) iip->iic_rpbase = 0; #endif
-#ifdef CONFIG_SYS_ALLOC_DPRAM - dpaddr = iip->iic_rbase; - if (dpaddr == 0) { - /* need to allocate dual port ram */ - dpaddr = dpram_alloc_align((NUM_RX_BDS * sizeof(I2C_BD)) + - (NUM_TX_BDS * sizeof(I2C_BD)) + - MAX_TX_SPACE, 8); - } -#else dpaddr = CPM_I2C_BASE; -#endif
/* * initialise data in dual port ram: diff --git a/arch/powerpc/cpu/mpc8xx/scc.c b/arch/powerpc/cpu/mpc8xx/scc.c index 3474637fac..17bcc2fe0a 100644 --- a/arch/powerpc/cpu/mpc8xx/scc.c +++ b/arch/powerpc/cpu/mpc8xx/scc.c @@ -199,14 +199,8 @@ static int scc_init (struct eth_device *dev, bd_t * bis) rxIdx = 0; txIdx = 0;
- if (!rtx) { -#ifdef CONFIG_SYS_ALLOC_DPRAM - rtx = (RTXBD *) (immr->im_cpm.cp_dpmem + - dpram_alloc_align (sizeof (RTXBD), 8)); -#else - rtx = (RTXBD *) (immr->im_cpm.cp_dpmem + CPM_SCC_BASE); -#endif - } + if (!rtx) + rtx = (RTXBD *)(immr->im_cpm.cp_dpmem + CPM_SCC_BASE);
#if (defined(PA_ENET_RXD) && defined(PA_ENET_TXD)) /* Configure port A pins for Txd and Rxd. diff --git a/arch/powerpc/cpu/mpc8xx/serial.c b/arch/powerpc/cpu/mpc8xx/serial.c index 94c785f611..b6e12d0d85 100644 --- a/arch/powerpc/cpu/mpc8xx/serial.c +++ b/arch/powerpc/cpu/mpc8xx/serial.c @@ -176,15 +176,7 @@ static int smc_init (void) /* Set the physical address of the host memory buffers in * the buffer descriptors. */ - -#ifdef CONFIG_SYS_ALLOC_DPRAM - /* allocate - * size of struct serialbuffer with bd rx/tx, buffer rx/tx and rx index - */ - dpaddr = dpram_alloc_align((sizeof(serialbuffer_t)), 8); -#else - dpaddr = CPM_SERIAL_BASE ; -#endif + dpaddr = CPM_SERIAL_BASE;
rtx = (serialbuffer_t *)&cp->cp_dpmem[dpaddr]; /* Allocate space for two buffer descriptors in the DP ram. @@ -421,12 +413,7 @@ static int scc_init (void) #endif
/* Allocate space for two buffer descriptors in the DP ram. */ - -#ifdef CONFIG_SYS_ALLOC_DPRAM - dpaddr = dpram_alloc_align (sizeof(cbd_t)*2 + 2, 8) ; -#else - dpaddr = CPM_SERIAL2_BASE ; -#endif + dpaddr = dpram_alloc_align(sizeof(cbd_t)*2 + 2, 8);
/* Enable SDMA. */ im->im_siu_conf.sc_sdcr = 0x0001; diff --git a/arch/powerpc/cpu/mpc8xx/spi.c b/arch/powerpc/cpu/mpc8xx/spi.c index 6267c0e204..35b425e7c1 100644 --- a/arch/powerpc/cpu/mpc8xx/spi.c +++ b/arch/powerpc/cpu/mpc8xx/spi.c @@ -187,14 +187,7 @@ void spi_init_f (void) spi->spi_tbc = 0; spi->spi_txtmp = 0;
- /* Allocate space for one transmit and one receive buffer - * descriptor in the DP ram - */ -#ifdef CONFIG_SYS_ALLOC_DPRAM - dpaddr = dpram_alloc_align (sizeof(cbd_t)*2, 8); -#else dpaddr = CPM_SPI_BASE; -#endif
/* 3 */ /* Set up the SPI parameters in the parameter ram */ diff --git a/arch/powerpc/include/asm/global_data.h b/arch/powerpc/include/asm/global_data.h index 4090975bf5..3943d0e92b 100644 --- a/arch/powerpc/include/asm/global_data.h +++ b/arch/powerpc/include/asm/global_data.h @@ -96,7 +96,7 @@ struct arch_global_data { unsigned long arbiter_event_attributes; unsigned long arbiter_event_address; #endif -#if defined(CONFIG_SYS_ALLOC_DPRAM) || defined(CONFIG_CPM2) +#if defined(CONFIG_CPM2) unsigned int dp_alloc_base; unsigned int dp_alloc_top; #endif diff --git a/common/board_f.c b/common/board_f.c index 5e2b8d14d4..8c9453cb7e 100644 --- a/common/board_f.c +++ b/common/board_f.c @@ -884,11 +884,6 @@ static init_fnc_t init_sequence_f[] = { defined(CONFIG_SH) || defined(CONFIG_SPARC) timer_init, /* initialize timer */ #endif -#ifdef CONFIG_SYS_ALLOC_DPRAM -#if !defined(CONFIG_CPM2) - dpram_init, -#endif -#endif #if defined(CONFIG_BOARD_POSTCLK_INIT) board_postclk_init, #endif diff --git a/include/commproc.h b/include/commproc.h index 9582746153..9d4cb109ad 100644 --- a/include/commproc.h +++ b/include/commproc.h @@ -51,20 +51,6 @@ /* * DPRAM defines and allocation functions */ - -/* The dual ported RAM is multi-functional. Some areas can be (and are - * being) used for microcode. There is an area that can only be used - * as data ram for buffer descriptors, which is all we use right now. - * Currently the first 512 and last 256 bytes are used for microcode. - */ -#ifdef CONFIG_SYS_ALLOC_DPRAM - -#define CPM_DATAONLY_BASE ((uint)0x0800) -#define CPM_DATAONLY_SIZE ((uint)0x0700) -#define CPM_DP_NOSPACE ((uint)0x7fffffff) - -#else - #define CPM_SERIAL_BASE 0x0800 #define CPM_I2C_BASE 0x0820 #define CPM_SPI_BASE 0x0840 @@ -74,8 +60,6 @@ #define CPM_POST_BASE 0x0980 #define CPM_WLKBD_BASE 0x0a00
-#endif - #ifndef CONFIG_SYS_CPM_POST_WORD_ADDR #define CPM_POST_WORD_ADDR 0x07FC #else diff --git a/post/cpu/mpc8xx/ether.c b/post/cpu/mpc8xx/ether.c index 1b75eb6fb8..47f6f32246 100644 --- a/post/cpu/mpc8xx/ether.c +++ b/post/cpu/mpc8xx/ether.c @@ -119,12 +119,7 @@ static void scc_init (int scc_index) rxIdx = 0; txIdx = 0;
-#ifdef CONFIG_SYS_ALLOC_DPRAM - rtx = (RTXBD *) (immr->im_cpm.cp_dpmem + - dpram_alloc_align (sizeof (RTXBD), 8)); -#else rtx = (RTXBD *) (immr->im_cpm.cp_dpmem + CPM_SCC_BASE); -#endif
#if 0
diff --git a/post/cpu/mpc8xx/uart.c b/post/cpu/mpc8xx/uart.c index e54a4cacfa..64ca7e4b98 100644 --- a/post/cpu/mpc8xx/uart.c +++ b/post/cpu/mpc8xx/uart.c @@ -103,12 +103,7 @@ static void smc_init (int smc_index) /* Set the physical address of the host memory buffers in * the buffer descriptors. */ - -#ifdef CONFIG_SYS_ALLOC_DPRAM - dpaddr = dpram_alloc_align (sizeof (cbd_t) * 2 + 2, 8); -#else dpaddr = CPM_POST_BASE; -#endif
/* Allocate space for two buffer descriptors in the DP ram. * For now, this address seems OK, but it may have to @@ -276,15 +271,7 @@ static void scc_init (int scc_index) */ sp->scc_gsmrl &= ~(SCC_GSMRL_ENR | SCC_GSMRL_ENT);
- - /* Allocate space for two buffer descriptors in the DP ram. - */ - -#ifdef CONFIG_SYS_ALLOC_DPRAM - dpaddr = dpram_alloc_align (sizeof (cbd_t) * 2 + 2, 8); -#else dpaddr = CPM_POST_BASE; -#endif
/* Enable SDMA. */ diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index f40c432990..b7463a808f 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -3162,7 +3162,6 @@ CONFIG_SYS_ACR_RPTCNT CONFIG_SYS_ADDRESS_MAP_A CONFIG_SYS_ADV7611_I2C CONFIG_SYS_AHB_BASE -CONFIG_SYS_ALLOC_DPRAM CONFIG_SYS_ALT_BOOT CONFIG_SYS_ALT_FLASH CONFIG_SYS_ALT_MEMTEST
This is not used in U-Boot. Drop this option and associated dead code.
common/board_r.c | 14 --- drivers/pci/Makefile | 1 - drivers/pci/w83c553f.c | 206 ------------------------------------------- scripts/config_whitelist.txt | 1 - 4 files changed, 222 deletions(-) delete mode 100644 drivers/pci/w83c553f.c
diff --git a/common/board_r.c b/common/board_r.c index 46a43b97a7..419471cfb8 100644 --- a/common/board_r.c +++ b/common/board_r.c @@ -262,17 +262,6 @@ static int initr_pci(void) } #endif
-#ifdef CONFIG_WINBOND_83C553 -static int initr_w83c553f(void) -{ - /* - * Initialise the ISA bridge - */ - initialise_w83c553f(); - return 0; -} -#endif - static int initr_barrier(void) { #ifdef CONFIG_PPC @@ -834,9 +823,6 @@ init_fnc_t init_sequence_r[] = { */ initr_pci, #endif -#ifdef CONFIG_WINBOND_83C553 - initr_w83c553f, -#endif #ifdef CONFIG_ARCH_EARLY_INIT_R arch_early_init_r, #endif diff --git a/drivers/pci/Makefile b/drivers/pci/Makefile index 42174f94e9..ad44e83996 100644 --- a/drivers/pci/Makefile +++ b/drivers/pci/Makefile @@ -29,7 +29,6 @@ obj-$(CONFIG_SH7751_PCI) +=pci_sh7751.o obj-$(CONFIG_SH7780_PCI) +=pci_sh7780.o obj-$(CONFIG_PCI_TEGRA) += pci_tegra.o obj-$(CONFIG_TSI108_PCI) += tsi108_pci.o -obj-$(CONFIG_WINBOND_83C553) += w83c553f.o obj-$(CONFIG_PCIE_DW_MVEBU) += pcie_dw_mvebu.o obj-$(CONFIG_PCIE_LAYERSCAPE) += pcie_layerscape.o obj-$(CONFIG_PCIE_LAYERSCAPE) += pcie_layerscape_fixup.o diff --git a/drivers/pci/w83c553f.c b/drivers/pci/w83c553f.c deleted file mode 100644 index 1192f0f644..0000000000 --- a/drivers/pci/w83c553f.c +++ /dev/null @@ -1,206 +0,0 @@ -/* - * (C) Copyright 2001 Sysgo Real-Time Solutions, GmbH <www.elinos.com> - * Andreas Heppel aheppel@sysgo.de - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -/* - * Initialisation of the PCI-to-ISA bridge and disabling the BIOS - * write protection (for flash) in function 0 of the chip. - * Enabling function 1 (IDE controller of the chip. - */ - -#include <common.h> -#include <config.h> - -#include <asm/io.h> -#include <pci.h> - -#include <w83c553f.h> - -#define out8(addr,val) do { \ - out_8((u8*) (addr),(val)); udelay(1); \ - } while (0) -#define out16(addr,val) do { \ - out_be16((u16*) (addr),(val)); udelay(1); \ - } while (0) - -extern uint ide_bus_offset[CONFIG_SYS_IDE_MAXBUS]; - -void initialise_pic(void); -void initialise_dma(void); - -void initialise_w83c553f(void) -{ - pci_dev_t devbusfn; - unsigned char reg8; - unsigned short reg16; - unsigned int reg32; - - devbusfn = pci_find_device(W83C553F_VID, W83C553F_DID, 0); - if (devbusfn == -1) - { - printf("Error: Cannot find W83C553F controller on any PCI bus."); - return; - } - - pci_read_config_word(devbusfn, PCI_COMMAND, ®16); - reg16 |= PCI_COMMAND_MASTER | PCI_COMMAND_IO | PCI_COMMAND_MEMORY; - pci_write_config_word(devbusfn, PCI_COMMAND, reg16); - - pci_read_config_byte(devbusfn, WINBOND_IPADCR, ®8); - /* 16 MB ISA memory space */ - reg8 |= (IPADCR_IPATOM4 | IPADCR_IPATOM5 | IPADCR_IPATOM6 | IPADCR_IPATOM7); - reg8 &= ~IPADCR_MBE512; - pci_write_config_byte(devbusfn, WINBOND_IPADCR, reg8); - - pci_read_config_byte(devbusfn, WINBOND_CSCR, ®8); - /* switch off BIOS write protection */ - reg8 |= CSCR_UBIOSCSE; - reg8 &= ~CSCR_BIOSWP; - pci_write_config_byte(devbusfn, WINBOND_CSCR, reg8); - - /* - * Interrupt routing: - * - IDE -> IRQ 9/0 - * - INTA -> IRQ 10 - * - INTB -> IRQ 11 - * - INTC -> IRQ 14 - * - INTD -> IRQ 15 - */ - pci_write_config_byte(devbusfn, WINBOND_IDEIRCR, 0x90); - pci_write_config_word(devbusfn, WINBOND_PCIIRCR, 0xABEF); - - /* - * Read IDE bus offsets from function 1 device. - * We must unmask the LSB indicating that ist is an IO address. - */ - devbusfn |= PCI_BDF(0,0,1); - - /* - * Switch off legacy IRQ for IDE and IDE port 1. - */ - pci_write_config_byte(devbusfn, 0x09, 0x8F); - - pci_read_config_dword(devbusfn, WINDOND_IDECSR, ®32); - reg32 &= ~(IDECSR_LEGIRQ | IDECSR_P1EN | IDECSR_P1F16); - pci_write_config_dword(devbusfn, WINDOND_IDECSR, reg32); - - pci_read_config_dword(devbusfn, PCI_BASE_ADDRESS_0, &ide_bus_offset[0]); - ide_bus_offset[0] &= ~1; -#if CONFIG_SYS_IDE_MAXBUS > 1 - pci_read_config_dword(devbusfn, PCI_BASE_ADDRESS_2, &ide_bus_offset[1]); - ide_bus_offset[1] &= ~1; -#endif - - /* - * Enable function 1, IDE -> busmastering and IO space access - */ - pci_read_config_word(devbusfn, PCI_COMMAND, ®16); - reg16 |= PCI_COMMAND_MASTER | PCI_COMMAND_IO; - pci_write_config_word(devbusfn, PCI_COMMAND, reg16); - - /* - * Initialise ISA interrupt controller - */ - initialise_pic(); - - /* - * Initialise DMA controller - */ - initialise_dma(); -} - -void initialise_pic(void) -{ - out8(W83C553F_PIC1_ICW1, 0x11); - out8(W83C553F_PIC1_ICW2, 0x08); - out8(W83C553F_PIC1_ICW3, 0x04); - out8(W83C553F_PIC1_ICW4, 0x01); - out8(W83C553F_PIC1_OCW1, 0xfb); - out8(W83C553F_PIC1_ELC, 0x20); - - out8(W83C553F_PIC2_ICW1, 0x11); - out8(W83C553F_PIC2_ICW2, 0x08); - out8(W83C553F_PIC2_ICW3, 0x02); - out8(W83C553F_PIC2_ICW4, 0x01); - out8(W83C553F_PIC2_OCW1, 0xff); - out8(W83C553F_PIC2_ELC, 0xce); - - out8(W83C553F_TMR1_CMOD, 0x74); - - out8(W83C553F_PIC2_OCW1, 0x20); - out8(W83C553F_PIC1_OCW1, 0x20); - - out8(W83C553F_PIC2_OCW1, 0x2b); - out8(W83C553F_PIC1_OCW1, 0x2b); -} - -void initialise_dma(void) -{ - unsigned int channel; - unsigned int rvalue1, rvalue2; - - /* perform a H/W reset of the devices */ - - out8(W83C553F_DMA1 + W83C553F_DMA1_MC, 0x00); - out16(W83C553F_DMA2 + W83C553F_DMA2_MC, 0x0000); - - /* initialise all channels to a sane state */ - - for (channel = 0; channel < 4; channel++) { - /* - * dependent upon the channel, setup the specifics: - * - * demand - * address-increment - * autoinitialize-disable - * verify-transfer - */ - - switch (channel) { - case 0: - rvalue1 = (W83C553F_MODE_TM_DEMAND|W83C553F_MODE_CH0SEL|W83C553F_MODE_TT_VERIFY); - rvalue2 = (W83C553F_MODE_TM_CASCADE|W83C553F_MODE_CH0SEL); - break; - case 1: - rvalue1 = (W83C553F_MODE_TM_DEMAND|W83C553F_MODE_CH1SEL|W83C553F_MODE_TT_VERIFY); - rvalue2 = (W83C553F_MODE_TM_DEMAND|W83C553F_MODE_CH1SEL|W83C553F_MODE_TT_VERIFY); - break; - case 2: - rvalue1 = (W83C553F_MODE_TM_DEMAND|W83C553F_MODE_CH2SEL|W83C553F_MODE_TT_VERIFY); - rvalue2 = (W83C553F_MODE_TM_DEMAND|W83C553F_MODE_CH2SEL|W83C553F_MODE_TT_VERIFY); - break; - case 3: - rvalue1 = (W83C553F_MODE_TM_DEMAND|W83C553F_MODE_CH3SEL|W83C553F_MODE_TT_VERIFY); - rvalue2 = (W83C553F_MODE_TM_DEMAND|W83C553F_MODE_CH3SEL|W83C553F_MODE_TT_VERIFY); - break; - default: - rvalue1 = 0x00; - rvalue2 = 0x00; - break; - } - - /* write to write mode registers */ - - out8(W83C553F_DMA1 + W83C553F_DMA1_WM, rvalue1 & 0xFF); - out16(W83C553F_DMA2 + W83C553F_DMA2_WM, rvalue2 & 0x00FF); - } - - /* enable all channels */ - - out8(W83C553F_DMA1 + W83C553F_DMA1_CM, 0x00); - out16(W83C553F_DMA2 + W83C553F_DMA2_CM, 0x0000); - /* - * initialize the global DMA configuration - * - * DACK# active low - * DREQ active high - * fixed priority - * channel group enable - */ - - out8(W83C553F_DMA1 + W83C553F_DMA1_CS, 0x00); - out16(W83C553F_DMA2 + W83C553F_DMA2_CS, 0x0000); -} diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index b7463a808f..fc98fe52f0 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -6891,7 +6891,6 @@ CONFIG_WATCHDOG_TIMEOUT_MSECS CONFIG_WDOG_GPIO_PIN CONFIG_WD_MAX_RATE CONFIG_WD_PERIOD -CONFIG_WINBOND_83C553 CONFIG_X600 CONFIG_X86EMU_DEBUG CONFIG_X86EMU_RAW_IO
Signed-off-by: Simon Glass sjg@chromium.org
This is only called from one place and the function cannot be inlined. Convert it to a normal function.
common/board_f.c | 2 ++ include/common.h | 7 ------- 2 files changed, 2 insertions(+), 7 deletions(-)
diff --git a/common/board_f.c b/common/board_f.c index 8c9453cb7e..e5d112dd1e 100644 --- a/common/board_f.c +++ b/common/board_f.c @@ -916,7 +916,9 @@ static init_fnc_t init_sequence_f[] = { #if defined(CONFIG_PPC) || defined(CONFIG_M68K) || defined(CONFIG_SH) checkcpu, #endif +#if defined(CONFIG_DISPLAY_CPUINFO) print_cpuinfo, /* display cpu info (and speed) */ +#endif #if defined(CONFIG_MPC5xxx) prt_mpc5xxx_clks, #endif /* CONFIG_MPC5xxx */ diff --git a/include/common.h b/include/common.h index 53cdadf09c..35ac78fede 100644 --- a/include/common.h +++ b/include/common.h @@ -284,14 +284,7 @@ int mac_read_from_eeprom(void); extern u8 __dtb_dt_begin[]; /* embedded device tree blob */ int set_cpu_clk_info(void); int mdm_init(void); -#if defined(CONFIG_DISPLAY_CPUINFO) int print_cpuinfo(void); -#else -static inline int print_cpuinfo(void) -{ - return 0; -} -#endif int update_flash_size(int flash_size); int arch_early_init_r(void);
Rather than having an arch-specific function, use the existing generic one.
arch/powerpc/cpu/mpc5xxx/speed.c | 2 +- common/Kconfig | 2 +- common/board_f.c | 3 --- 3 files changed, 2 insertions(+), 5 deletions(-)
diff --git a/arch/powerpc/cpu/mpc5xxx/speed.c b/arch/powerpc/cpu/mpc5xxx/speed.c index 30a0a358dd..b37c4a5208 100644 --- a/arch/powerpc/cpu/mpc5xxx/speed.c +++ b/arch/powerpc/cpu/mpc5xxx/speed.c @@ -69,7 +69,7 @@ int get_clocks (void) return (0); }
-int prt_mpc5xxx_clks (void) +int print_cpuinfo(void) { char buf1[32], buf2[32], buf3[32];
diff --git a/common/Kconfig b/common/Kconfig index 32d72ca95b..c709661454 100644 --- a/common/Kconfig +++ b/common/Kconfig @@ -385,7 +385,7 @@ config BOARD_LATE_INIT
config DISPLAY_CPUINFO bool "Display information about the CPU during start up" - default y if ARM || BLACKFIN || NIOS2 || X86 || XTENSA + default y if ARM || BLACKFIN || NIOS2 || X86 || XTENSA || MPC5xxx help Display information about the CPU that U-Boot is running on when U-Boot starts up. The function print_cpuinfo() is called diff --git a/common/board_f.c b/common/board_f.c index e5d112dd1e..99c0b5ac78 100644 --- a/common/board_f.c +++ b/common/board_f.c @@ -919,9 +919,6 @@ static init_fnc_t init_sequence_f[] = { #if defined(CONFIG_DISPLAY_CPUINFO) print_cpuinfo, /* display cpu info (and speed) */ #endif -#if defined(CONFIG_MPC5xxx) - prt_mpc5xxx_clks, -#endif /* CONFIG_MPC5xxx */ #if defined(CONFIG_DISPLAY_BOARDINFO) show_board_info, #endif
This is not used in U-Boot, and the only usage calls a non-existent function. Drop it.
board/mpl/common/common_util.c | 9 --------- board/mpl/common/common_util.h | 3 --- common/board_r.c | 13 ------------- include/common.h | 3 --- include/config_cmd_all.h | 1 - scripts/config_whitelist.txt | 1 - 6 files changed, 30 deletions(-)
diff --git a/board/mpl/common/common_util.c b/board/mpl/common/common_util.c index 101b6efd81..5ea5a5187b 100644 --- a/board/mpl/common/common_util.c +++ b/board/mpl/common/common_util.c @@ -622,15 +622,6 @@ int do_mplcommon(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) return cmd_usage(cmdtp); }
- -#if defined(CONFIG_CMD_DOC) -void doc_init (void) -{ - doc_probe(MULTI_PURPOSE_SOCKET_ADDR); -} -#endif - - #ifdef CONFIG_VIDEO /****************************************************** * Routines to display the Board information diff --git a/board/mpl/common/common_util.h b/board/mpl/common/common_util.h index 22f5c2e6d8..127853d29b 100644 --- a/board/mpl/common/common_util.h +++ b/board/mpl/common/common_util.h @@ -23,8 +23,5 @@ int get_boot_mode(void); void setup_cs_reloc(void);
void check_env(void); -#if defined(CONFIG_CMD_DOC) -void doc_init (void); -#endif
#endif /* _COMMON_UTIL_H_ */ diff --git a/common/board_r.c b/common/board_r.c index 419471cfb8..48fa4ee524 100644 --- a/common/board_r.c +++ b/common/board_r.c @@ -619,15 +619,6 @@ static int initr_scsi(void) } #endif
-#if defined(CONFIG_CMD_DOC) -static int initr_doc(void) -{ - puts("DOC: "); - doc_init(); - return 0; -} -#endif - #ifdef CONFIG_BITBANGMII static int initr_bbmii(void) { @@ -913,10 +904,6 @@ init_fnc_t init_sequence_r[] = { INIT_FUNC_WATCHDOG_RESET initr_scsi, #endif -#ifdef CONFIG_CMD_DOC - INIT_FUNC_WATCHDOG_RESET - initr_doc, -#endif #ifdef CONFIG_BITBANGMII initr_bbmii, #endif diff --git a/include/common.h b/include/common.h index 35ac78fede..fbbc2cbc52 100644 --- a/include/common.h +++ b/include/common.h @@ -346,9 +346,6 @@ extern ulong load_addr; /* Default Load Address */ extern ulong save_addr; /* Default Save Address */ extern ulong save_size; /* Default Save Size */
-/* common/cmd_doc.c */ -void doc_probe(unsigned long physadr); - /* common/cmd_net.c */ int do_tftpb(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]);
diff --git a/include/config_cmd_all.h b/include/config_cmd_all.h index 0c4f645930..a0d4e94a04 100644 --- a/include/config_cmd_all.h +++ b/include/config_cmd_all.h @@ -20,7 +20,6 @@ #define CONFIG_CMD_DATE /* support for RTC, date/time...*/ #define CONFIG_CMD_DIAG /* Diagnostics */ #define CONFIG_CMD_DISPLAY /* Display support */ -#define CONFIG_CMD_DOC /* Disk-On-Chip Support */ #define CONFIG_CMD_DTT /* Digital Therm and Thermostat */ #define CONFIG_CMD_EEPROM /* EEPROM read/write support */ #define CONFIG_CMD_FDC /* Floppy Disk Support */ diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index fc98fe52f0..b32c260d32 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -489,7 +489,6 @@ CONFIG_CMD_DEKBLOB CONFIG_CMD_DFL CONFIG_CMD_DIAG CONFIG_CMD_DISPLAY -CONFIG_CMD_DOC CONFIG_CMD_DS4510 CONFIG_CMD_DS4510_INFO CONFIG_CMD_DS4510_MEM
On Mon, Jan 23, 2017 at 01:31:16PM -0700, Simon Glass wrote:
This series moves three common CONFIG options to Kconfig. They are somewhat tricky and I've had a hard time figuring out good Kconfig defaults, particularly for CONFIG_BOARD_EARLY_INIT_F. Hopefully the board maintainers can improve things.
It is build-tested and I've also checked it with 'buildman -sK. The only config changes are:
draco etamin pxm2 rastaban rut thuban :
- u-boot-spl.cfg: CONFIG_ARCH_MISC_INIT=1
- all: CONFIG_ARCH_MISC_INIT=1
and this is due to this option being defined in SPL (i.e. harmless).
A few patches are included to tidy up some other things I noticed along the way.
In general I prefer to keep the "tidy up" patches in a follow-up series because the first set of tests I do is to make sure the changes are size-neutral (or understand why).
No need to re-send this series, I can split it easily enough, JFYI.
Hi Tom,
OK, understood. I started off with the goal of dropping all arch-specific things from the init sequence, but that was hopelessly ambitious, so I stopped along the way...
Thanks!
Masahiro Yamada
