Re: [U-Boot] [PATCH] cmd_onenand.c: moved to standard subcommand handling
Hi Frans,
2010/3/29 Detlev Zundel dzu@denx.de:
Hi Frans,
Forgot this disclaimer, thought I added it, sry.
NOTE: This code is untested as I have no board with onenand support. However, it compiles properly (tested by building opap3_evm, which uses this). The changes I did are purely splitting do_onenand in separate functions and add the subcommand parsing (which itself was taken from i2c, on which I tested it before). So I do not expect any serious issues, but I would suggest testing this before integrating it.
Why don't you just add the maintainer of omap3_evm board (as I did) on CC to your mail, so he knows that his testing would be greatly appreciated?
Will try to do so next time :-) Actually there are more boards which utilize onenand. I just picked this one as I have an omap3 board (and actually only discovered when I wanted to start testing that it did not have onenand, but just regular nand)
Hm ok, then maybe add someone else from the list of boards using it, as the e-mail of the omap3_evm maintainer "Manikandan Pillai mani.pillai@ti.com" bounces.
I added Nishanth Menon from ti on CC, maybe he can tell us the whereabouts of Manikanden. Will someone else from ti be maintaining this board? If so, then a patch to MAINTAINERS is welcome :)
Cheers Detlev
Detlev Zundel
