[U-Boot] [PATCH] rockchip: rk3399: correct memory region
RK3399 device memory region is 0xf8000000~0xffffffff.
Signed-off-by: Kever Yang kever.yang@rock-chips.com ---
arch/arm/mach-rockchip/rk3399/rk3399.c | 8 ++++---- 1 file changed, 4 insertions(+), 4 deletions(-)
diff --git a/arch/arm/mach-rockchip/rk3399/rk3399.c b/arch/arm/mach-rockchip/rk3399/rk3399.c index 8bb950e..a621a6f 100644 --- a/arch/arm/mach-rockchip/rk3399/rk3399.c +++ b/arch/arm/mach-rockchip/rk3399/rk3399.c @@ -15,13 +15,13 @@ static struct mm_region rk3399_mem_map[] = { { .virt = 0x0UL, .phys = 0x0UL, - .size = 0x80000000UL, + .size = 0xf8000000UL, .attrs = PTE_BLOCK_MEMTYPE(MT_NORMAL) | PTE_BLOCK_INNER_SHARE }, { - .virt = 0xf0000000UL, - .phys = 0xf0000000UL, - .size = 0x10000000UL, + .virt = 0xf8000000UL, + .phys = 0xf8000000UL, + .size = 0x08000000UL, .attrs = PTE_BLOCK_MEMTYPE(MT_DEVICE_NGNRNE) | PTE_BLOCK_NON_SHARE | PTE_BLOCK_PXN | PTE_BLOCK_UXN
Applied to u-boot-rockchip/next, thanks!
Kever Yang
