[U-Boot] [PATCH] dma: import linux/dma-direction.h to consolidate enum dma_data_direction
Import include/linux/dma-direction.h from Linux 4.13-rc7 and delete duplicated definitions of enum dma_data_direction.
Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com ---
arch/arm/include/asm/dma-mapping.h | 8 ++------ arch/nds32/include/asm/dma-mapping.h | 6 +----- arch/x86/include/asm/dma-mapping.h | 8 ++------ drivers/ata/sata_dwc.c | 1 + drivers/ata/sata_dwc.h | 7 ------- drivers/mmc/uniphier-sd.c | 2 +- include/linux/dma-direction.h | 13 +++++++++++++ 7 files changed, 20 insertions(+), 25 deletions(-) create mode 100644 include/linux/dma-direction.h
diff --git a/arch/arm/include/asm/dma-mapping.h b/arch/arm/include/asm/dma-mapping.h index a5821f54e567..287466800e4b 100644 --- a/arch/arm/include/asm/dma-mapping.h +++ b/arch/arm/include/asm/dma-mapping.h @@ -8,13 +8,9 @@ #ifndef __ASM_ARM_DMA_MAPPING_H #define __ASM_ARM_DMA_MAPPING_H
-#define dma_mapping_error(x, y) 0 +#include <linux/dma-direction.h>
-enum dma_data_direction { - DMA_BIDIRECTIONAL = 0, - DMA_TO_DEVICE = 1, - DMA_FROM_DEVICE = 2, -}; +#define dma_mapping_error(x, y) 0
static inline void *dma_alloc_coherent(size_t len, unsigned long *handle) { diff --git a/arch/nds32/include/asm/dma-mapping.h b/arch/nds32/include/asm/dma-mapping.h index 25e5a1b6ec8a..a627306ed852 100644 --- a/arch/nds32/include/asm/dma-mapping.h +++ b/arch/nds32/include/asm/dma-mapping.h @@ -7,11 +7,7 @@ #ifndef __ASM_NDS_DMA_MAPPING_H #define __ASM_NDS_DMA_MAPPING_H
-enum dma_data_direction { - DMA_BIDIRECTIONAL = 0, - DMA_TO_DEVICE = 1, - DMA_FROM_DEVICE = 2, -}; +#include <linux/dma-direction.h>
static void *dma_alloc_coherent(size_t len, unsigned long *handle) { diff --git a/arch/x86/include/asm/dma-mapping.h b/arch/x86/include/asm/dma-mapping.h index 7de4c08e36ea..43073ad2524f 100644 --- a/arch/x86/include/asm/dma-mapping.h +++ b/arch/x86/include/asm/dma-mapping.h @@ -8,13 +8,9 @@ #ifndef __ASM_X86_DMA_MAPPING_H #define __ASM_X86_DMA_MAPPING_H
static inline void *dma_alloc_coherent(size_t len, unsigned long *handle) { diff --git a/drivers/ata/sata_dwc.c b/drivers/ata/sata_dwc.c index a226ca2decb5..2f3b2ddb411f 100644 --- a/drivers/ata/sata_dwc.c +++ b/drivers/ata/sata_dwc.c @@ -26,6 +26,7 @@ #include <command.h> #include <pci.h> #include <asm/processor.h> +#include <linux/dma-direction.h> #include <linux/errno.h> #include <asm/io.h> #include <malloc.h> diff --git a/drivers/ata/sata_dwc.h b/drivers/ata/sata_dwc.h index e2d9e0c1fce8..17fb20cf437b 100644 --- a/drivers/ata/sata_dwc.h +++ b/drivers/ata/sata_dwc.h @@ -401,13 +401,6 @@ struct ata_device { #endif };
-enum dma_data_direction { - DMA_BIDIRECTIONAL = 0, - DMA_TO_DEVICE = 1, - DMA_FROM_DEVICE = 2, - DMA_NONE = 3, -}; - struct ata_link { struct ata_port *ap; int pmp; diff --git a/drivers/mmc/uniphier-sd.c b/drivers/mmc/uniphier-sd.c index e272b1415324..721b75fddace 100644 --- a/drivers/mmc/uniphier-sd.c +++ b/drivers/mmc/uniphier-sd.c @@ -11,10 +11,10 @@ #include <mmc.h> #include <dm.h> #include <linux/compat.h> +#include <linux/dma-direction.h> #include <linux/io.h> #include <linux/sizes.h> #include <asm/unaligned.h> -#include <asm/dma-mapping.h>
DECLARE_GLOBAL_DATA_PTR;
diff --git a/include/linux/dma-direction.h b/include/linux/dma-direction.h new file mode 100644 index 000000000000..95b6a82f5951 --- /dev/null +++ b/include/linux/dma-direction.h @@ -0,0 +1,13 @@ +#ifndef _LINUX_DMA_DIRECTION_H +#define _LINUX_DMA_DIRECTION_H +/* + * These definitions mirror those in pci.h, so they can be used + * interchangeably with their PCI_ counterparts. + */ +enum dma_data_direction { + DMA_BIDIRECTIONAL = 0, + DMA_TO_DEVICE = 1, + DMA_FROM_DEVICE = 2, + DMA_NONE = 3, +}; +#endif
Makes sense.
Reviewed-by: Andy Shevchenko andriy.shevchenko@linux.intel.com
diff --git a/arch/arm/include/asm/dma-mapping.h b/arch/arm/include/asm/dma-mapping.h index a5821f54e567..287466800e4b 100644 --- a/arch/arm/include/asm/dma-mapping.h +++ b/arch/arm/include/asm/dma-mapping.h @@ -8,13 +8,9 @@ #ifndef __ASM_ARM_DMA_MAPPING_H #define __ASM_ARM_DMA_MAPPING_H -#define dma_mapping_error(x, y) 0 +#include <linux/dma-direction.h> -enum dma_data_direction {
-}; +#define dma_mapping_error(x, y) 0 static inline void *dma_alloc_coherent(size_t len, unsigned long *handle) { diff --git a/arch/nds32/include/asm/dma-mapping.h b/arch/nds32/include/asm/dma-mapping.h index 25e5a1b6ec8a..a627306ed852 100644 --- a/arch/nds32/include/asm/dma-mapping.h +++ b/arch/nds32/include/asm/dma-mapping.h @@ -7,11 +7,7 @@ #ifndef __ASM_NDS_DMA_MAPPING_H #define __ASM_NDS_DMA_MAPPING_H -enum dma_data_direction {
-}; +#include <linux/dma-direction.h> static void *dma_alloc_coherent(size_t len, unsigned long *handle) { diff --git a/arch/x86/include/asm/dma-mapping.h b/arch/x86/include/asm/dma-mapping.h index 7de4c08e36ea..43073ad2524f 100644 --- a/arch/x86/include/asm/dma-mapping.h +++ b/arch/x86/include/asm/dma-mapping.h @@ -8,13 +8,9 @@ #ifndef __ASM_X86_DMA_MAPPING_H #define __ASM_X86_DMA_MAPPING_H -#define dma_mapping_error(x, y) 0 +#include <linux/dma-direction.h> -enum dma_data_direction {
-}; +#define dma_mapping_error(x, y) 0 static inline void *dma_alloc_coherent(size_t len, unsigned long *handle) { diff --git a/drivers/ata/sata_dwc.c b/drivers/ata/sata_dwc.c index a226ca2decb5..2f3b2ddb411f 100644 --- a/drivers/ata/sata_dwc.c +++ b/drivers/ata/sata_dwc.c @@ -26,6 +26,7 @@ #include <command.h> #include <pci.h> #include <asm/processor.h> +#include <linux/dma-direction.h> #include <linux/errno.h> #include <asm/io.h> #include <malloc.h> diff --git a/drivers/ata/sata_dwc.h b/drivers/ata/sata_dwc.h index e2d9e0c1fce8..17fb20cf437b 100644 --- a/drivers/ata/sata_dwc.h +++ b/drivers/ata/sata_dwc.h @@ -401,13 +401,6 @@ struct ata_device { #endif }; -enum dma_data_direction {
- DMA_NONE = 3,
struct ata_link { struct ata_port *ap; int pmp; diff --git a/drivers/mmc/uniphier-sd.c b/drivers/mmc/uniphier-sd.c index e272b1415324..721b75fddace 100644 --- a/drivers/mmc/uniphier-sd.c +++ b/drivers/mmc/uniphier-sd.c @@ -11,10 +11,10 @@ #include <mmc.h> #include <dm.h> #include <linux/compat.h> +#include <linux/dma-direction.h> #include <linux/io.h> #include <linux/sizes.h> #include <asm/unaligned.h> -#include <asm/dma-mapping.h> DECLARE_GLOBAL_DATA_PTR; diff --git a/include/linux/dma-direction.h b/include/linux/dma- direction.h new file mode 100644 index 000000000000..95b6a82f5951 --- /dev/null +++ b/include/linux/dma-direction.h @@ -0,0 +1,13 @@ +#ifndef _LINUX_DMA_DIRECTION_H +#define _LINUX_DMA_DIRECTION_H +/*
- These definitions mirror those in pci.h, so they can be used
- interchangeably with their PCI_ counterparts.
- DMA_NONE = 3,
+}; +#endif
Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com Reviewed-by: Andy Shevchenko andriy.shevchenko@linux.intel.com
Andy Shevchenko
Masahiro Yamada
