[U-Boot] [PATCH 0/2] sunxi: fix eMMC stability issues on A64
eMMC seems to require new clocking mode and calibration on A64, otherwise it is pretty unstable on some boards (e.g. Pinebook) with some eMMCs.
Vasily Khoruzhick (2): sunxi-mmc: use new mode on A64 mmc: sunxi: run calibration on A64
arch/arm/include/asm/arch-sunxi/mmc.h | 6 +++++- arch/arm/mach-sunxi/Kconfig | 1 + drivers/mmc/sunxi_mmc.c | 10 ++++++++++ 3 files changed, 16 insertions(+), 1 deletion(-)
That is necessary for using automatic calibration on A64 eMMC.
Signed-off-by: Vasily khoruzhick anarsoul@gmail.com --- arch/arm/mach-sunxi/Kconfig | 1 + drivers/mmc/sunxi_mmc.c | 4 ++++ 2 files changed, 5 insertions(+)
diff --git a/arch/arm/mach-sunxi/Kconfig b/arch/arm/mach-sunxi/Kconfig index b868f0e350..774a39f580 100644 --- a/arch/arm/mach-sunxi/Kconfig +++ b/arch/arm/mach-sunxi/Kconfig @@ -256,6 +256,7 @@ config MACH_SUN50I select SUNXI_DE2 select SUNXI_GEN_SUN6I select SUNXI_HIGH_SRAM + select MMC_SUNXI_HAS_NEW_MODE select SUPPORT_SPL select SUNXI_DRAM_DW select SUNXI_DRAM_DW_32BIT diff --git a/drivers/mmc/sunxi_mmc.c b/drivers/mmc/sunxi_mmc.c index df6f32850e..06b0fd491c 100644 --- a/drivers/mmc/sunxi_mmc.c +++ b/drivers/mmc/sunxi_mmc.c @@ -167,8 +167,12 @@ static int mmc_set_mod_clk(struct sunxi_mmc_priv *priv, unsigned int hz)
if (new_mode) { #ifdef CONFIG_MMC_SUNXI_HAS_NEW_MODE +#ifdef CONFIG_MACH_SUN50I + val = 0; +#else val = CCM_MMC_CTRL_MODE_SEL_NEW; setbits_le32(&priv->reg->ntsr, SUNXI_MMC_NTSR_MODE_SEL_NEW); +#endif #endif } else { val = CCM_MMC_CTRL_OCLK_DLY(oclk_dly) |
- select MMC_SUNXI_HAS_NEW_MODE select SUPPORT_SPL select SUNXI_DRAM_DW select SUNXI_DRAM_DW_32BIT
val = 0;
Maybe we just can have #ifdef CONFIG_MMC_SUNXI_HAS_NEW_MODE && !CONFIG_MACH_SUN50I ?
Thanks! maxime
Along with using new mode it fixes eMMC instability on Pinebook
Signed-off-by: Vasily Khoruzhick anarsoul@gmail.com --- arch/arm/include/asm/arch-sunxi/mmc.h | 6 +++++- drivers/mmc/sunxi_mmc.c | 6 ++++++ 2 files changed, 11 insertions(+), 1 deletion(-)
diff --git a/arch/arm/include/asm/arch-sunxi/mmc.h b/arch/arm/include/asm/arch-sunxi/mmc.h index 69f737f3bf..8575b393e5 100644 --- a/arch/arm/include/asm/arch-sunxi/mmc.h +++ b/arch/arm/include/asm/arch-sunxi/mmc.h @@ -47,7 +47,9 @@ struct sunxi_mmc { u32 cbda; /* 0x94 */ u32 res2[26]; #ifdef CONFIG_SUNXI_GEN_SUN6I - u32 res3[64]; + u32 res3[17]; + u32 samp_dl; + u32 res4[46]; #endif u32 fifo; /* 0x100 / 0x200 FIFO access address */ }; @@ -131,5 +133,7 @@ struct sunxi_mmc { #define SUNXI_MMC_COMMON_CLK_GATE (1 << 16) #define SUNXI_MMC_COMMON_RESET (1 << 18)
+#define SUNXI_MMC_CAL_DL_SW_EN (0x1 << 7) + struct mmc *sunxi_mmc_init(int sdc_no); #endif /* _SUNXI_MMC_H */ diff --git a/drivers/mmc/sunxi_mmc.c b/drivers/mmc/sunxi_mmc.c index 06b0fd491c..9e7c42c571 100644 --- a/drivers/mmc/sunxi_mmc.c +++ b/drivers/mmc/sunxi_mmc.c @@ -227,6 +227,12 @@ static int mmc_config_clock(struct sunxi_mmc_priv *priv, struct mmc *mmc) rval &= ~SUNXI_MMC_CLK_DIVIDER_MASK; writel(rval, &priv->reg->clkcr);
+#ifdef CONFIG_MACH_SUN50I + /* Run calibration on A64 */ + if (priv->mmc_no == 2) + writel(SUNXI_MMC_CAL_DL_SW_EN, &priv->reg->samp_dl); +#endif + /* Re-enable Clock */ rval |= SUNXI_MMC_CLK_ENABLE; writel(rval, &priv->reg->clkcr);
- u32 res3[64];
- u32 res3[17];
- u32 samp_dl;
- u32 res4[46];
- /* Run calibration on A64 */
I guess we could improve the comment here. This is needed only on the A64 eMMC controller, and we have to have a delay of zero before starting the calibration. The Allwinner BSP sets a delay only in the case of using in HS400, that is not supported in U-Boot (or Linux, for that matter).
Maxime
Maxime Ripard
Vasily Khoruzhick
