[PATCH 1/4] configs: defconfig: Enable UBI and UBIFS for Agilex and Stratix10
Enabling configs required for UBI and UBIFS commands. Set environment in a UBI volume. So, remove CONFIG_ENV_IS_IN_NAND as the environment is now in UBI volume.
Signed-off-by: Sin Hui Kho sin.hui.kho@intel.com Signed-off-by: Jit Loon Lim jit.loon.lim@intel.com --- configs/socfpga_agilex_nand_atf_defconfig | 11 +++++++++-- configs/socfpga_agilex_nand_defconfig | 11 +++++++++-- configs/socfpga_stratix10_nand_atf_defconfig | 11 +++++++++-- configs/socfpga_stratix10_nand_defconfig | 11 +++++++++-- 4 files changed, 36 insertions(+), 8 deletions(-)
diff --git a/configs/socfpga_agilex_nand_atf_defconfig b/configs/socfpga_agilex_nand_atf_defconfig index bfc893fd39..16509d868b 100644 --- a/configs/socfpga_agilex_nand_atf_defconfig +++ b/configs/socfpga_agilex_nand_atf_defconfig @@ -53,7 +53,6 @@ CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_MTDIDS_DEFAULT="nand0=ffb90000.nand.0" CONFIG_MTDPARTS_DEFAULT="mtdparts=ffb90000.nand.0:2m(u-boot),256k(env),256k(dtb),32m(kernel),32m(misc),-(rootfs)" -CONFIG_ENV_IS_IN_NAND=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_SPL_ALTERA_SDRAM=y @@ -90,4 +89,12 @@ CONFIG_USB_STORAGE=y CONFIG_DESIGNWARE_WATCHDOG=y CONFIG_WDT=y # CONFIG_SPL_USE_TINY_PRINTF is not set -# CONFIG_SPL_RAW_IMAGE_SUPPORT is not set \ No newline at end of file +# CONFIG_SPL_RAW_IMAGE_SUPPORT is not set +CONFIG_CMD_UBI=y +CONFIG_CMD_UBIFS=y +CONFIG_MTD_UBI=y +CONFIG_MTD_UBI_WL_THRESHOLD=4096 +CONFIG_MTD_UBI_BEB_LIMIT=20 +CONFIG_ENV_IS_IN_UBI=y +CONFIG_ENV_UBI_PART="root" +CONFIG_ENV_UBI_VOLUME="env" \ No newline at end of file diff --git a/configs/socfpga_agilex_nand_defconfig b/configs/socfpga_agilex_nand_defconfig index 3f95aac147..7ba5016c2e 100644 --- a/configs/socfpga_agilex_nand_defconfig +++ b/configs/socfpga_agilex_nand_defconfig @@ -46,7 +46,6 @@ CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_MTDIDS_DEFAULT="nand0=ffb90000.nand.0" CONFIG_MTDPARTS_DEFAULT="mtdparts=ffb90000.nand.0:2m(u-boot),256k(env),256k(dtb),32m(kernel),32m(misc),-(rootfs)" -CONFIG_ENV_IS_IN_NAND=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_SPL_ALTERA_SDRAM=y @@ -83,4 +82,12 @@ CONFIG_USB_STORAGE=y CONFIG_DESIGNWARE_WATCHDOG=y CONFIG_WDT=y # CONFIG_SPL_USE_TINY_PRINTF is not set -# CONFIG_SPL_RAW_IMAGE_SUPPORT is not set \ No newline at end of file +# CONFIG_SPL_RAW_IMAGE_SUPPORT is not set +CONFIG_CMD_UBI=y +CONFIG_CMD_UBIFS=y +CONFIG_MTD_UBI=y +CONFIG_MTD_UBI_WL_THRESHOLD=4096 +CONFIG_MTD_UBI_BEB_LIMIT=20 +CONFIG_ENV_IS_IN_UBI=y +CONFIG_ENV_UBI_PART="root" +CONFIG_ENV_UBI_VOLUME="env" \ No newline at end of file diff --git a/configs/socfpga_stratix10_nand_atf_defconfig b/configs/socfpga_stratix10_nand_atf_defconfig index a9abd85e68..4a4b426b99 100644 --- a/configs/socfpga_stratix10_nand_atf_defconfig +++ b/configs/socfpga_stratix10_nand_atf_defconfig @@ -53,7 +53,6 @@ CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_MTDIDS_DEFAULT="nand0=ffb90000.nand.0" CONFIG_MTDPARTS_DEFAULT="mtdparts=ffb90000.nand.0:2m(u-boot),256k(env),256k(dtb),32m(kernel),32m(misc),-(rootfs)" -CONFIG_ENV_IS_IN_NAND=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_SPL_ALTERA_SDRAM=y @@ -91,4 +90,12 @@ CONFIG_DESIGNWARE_WATCHDOG=y CONFIG_WDT=y # CONFIG_SPL_USE_TINY_PRINTF is not set CONFIG_PANIC_HANG=y -# CONFIG_SPL_RAW_IMAGE_SUPPORT is not set \ No newline at end of file +# CONFIG_SPL_RAW_IMAGE_SUPPORT is not set +CONFIG_CMD_UBI=y +CONFIG_CMD_UBIFS=y +CONFIG_MTD_UBI=y +CONFIG_MTD_UBI_WL_THRESHOLD=4096 +CONFIG_MTD_UBI_BEB_LIMIT=20 +CONFIG_ENV_IS_IN_UBI=y +CONFIG_ENV_UBI_PART="root" +CONFIG_ENV_UBI_VOLUME="env" \ No newline at end of file diff --git a/configs/socfpga_stratix10_nand_defconfig b/configs/socfpga_stratix10_nand_defconfig index 48c20e5b11..a148eac83f 100644 --- a/configs/socfpga_stratix10_nand_defconfig +++ b/configs/socfpga_stratix10_nand_defconfig @@ -46,7 +46,6 @@ CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_MTDIDS_DEFAULT="nand0=ffb90000.nand.0" CONFIG_MTDPARTS_DEFAULT="mtdparts=ffb90000.nand.0:2m(u-boot),256k(env),256k(dtb),32m(kernel),32m(misc),-(rootfs)" -CONFIG_ENV_IS_IN_NAND=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_SPL_ALTERA_SDRAM=y @@ -84,4 +83,12 @@ CONFIG_DESIGNWARE_WATCHDOG=y CONFIG_WDT=y # CONFIG_SPL_USE_TINY_PRINTF is not set CONFIG_PANIC_HANG=y -# CONFIG_SPL_RAW_IMAGE_SUPPORT is not set \ No newline at end of file +# CONFIG_SPL_RAW_IMAGE_SUPPORT is not set +CONFIG_CMD_UBI=y +CONFIG_CMD_UBIFS=y +CONFIG_MTD_UBI=y +CONFIG_MTD_UBI_WL_THRESHOLD=4096 +CONFIG_MTD_UBI_BEB_LIMIT=20 +CONFIG_ENV_IS_IN_UBI=y +CONFIG_ENV_UBI_PART="root" +CONFIG_ENV_UBI_VOLUME="env" \ No newline at end of file
Change default MTD partition scheme for NAND flash after implementation of UBI and UBIFS. "u-boot" partition remain for raw u-boot image, but "root" partition is use for UBI image containing all other components.
Signed-off-by: Sin Hui Kho sin.hui.kho@intel.com Signed-off-by: Jit Loon Lim jit.loon.lim@intel.com --- configs/socfpga_agilex_nand_atf_defconfig | 2 +- configs/socfpga_agilex_nand_defconfig | 2 +- configs/socfpga_stratix10_nand_atf_defconfig | 2 +- configs/socfpga_stratix10_nand_defconfig | 2 +- 4 files changed, 4 insertions(+), 4 deletions(-)
diff --git a/configs/socfpga_agilex_nand_atf_defconfig b/configs/socfpga_agilex_nand_atf_defconfig index 16509d868b..eeaaacff7a 100644 --- a/configs/socfpga_agilex_nand_atf_defconfig +++ b/configs/socfpga_agilex_nand_atf_defconfig @@ -52,7 +52,7 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_MTDIDS_DEFAULT="nand0=ffb90000.nand.0" -CONFIG_MTDPARTS_DEFAULT="mtdparts=ffb90000.nand.0:2m(u-boot),256k(env),256k(dtb),32m(kernel),32m(misc),-(rootfs)" +CONFIG_MTDPARTS_DEFAULT="mtdparts=ffb90000.nand.0:2m(u-boot),-(root)" CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_SPL_ALTERA_SDRAM=y diff --git a/configs/socfpga_agilex_nand_defconfig b/configs/socfpga_agilex_nand_defconfig index 7ba5016c2e..50c17bd8af 100644 --- a/configs/socfpga_agilex_nand_defconfig +++ b/configs/socfpga_agilex_nand_defconfig @@ -45,7 +45,7 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_MTDIDS_DEFAULT="nand0=ffb90000.nand.0" -CONFIG_MTDPARTS_DEFAULT="mtdparts=ffb90000.nand.0:2m(u-boot),256k(env),256k(dtb),32m(kernel),32m(misc),-(rootfs)" +CONFIG_MTDPARTS_DEFAULT="mtdparts=ffb90000.nand.0:2m(u-boot),-(root)" CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_SPL_ALTERA_SDRAM=y diff --git a/configs/socfpga_stratix10_nand_atf_defconfig b/configs/socfpga_stratix10_nand_atf_defconfig index 4a4b426b99..443f057219 100644 --- a/configs/socfpga_stratix10_nand_atf_defconfig +++ b/configs/socfpga_stratix10_nand_atf_defconfig @@ -52,7 +52,7 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_MTDIDS_DEFAULT="nand0=ffb90000.nand.0" -CONFIG_MTDPARTS_DEFAULT="mtdparts=ffb90000.nand.0:2m(u-boot),256k(env),256k(dtb),32m(kernel),32m(misc),-(rootfs)" +CONFIG_MTDPARTS_DEFAULT="mtdparts=ffb90000.nand.0:2m(u-boot),-(root)" CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_SPL_ALTERA_SDRAM=y diff --git a/configs/socfpga_stratix10_nand_defconfig b/configs/socfpga_stratix10_nand_defconfig index a148eac83f..db2dd17dff 100644 --- a/configs/socfpga_stratix10_nand_defconfig +++ b/configs/socfpga_stratix10_nand_defconfig @@ -45,7 +45,7 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_MTDIDS_DEFAULT="nand0=ffb90000.nand.0" -CONFIG_MTDPARTS_DEFAULT="mtdparts=ffb90000.nand.0:2m(u-boot),256k(env),256k(dtb),32m(kernel),32m(misc),-(rootfs)" +CONFIG_MTDPARTS_DEFAULT="mtdparts=ffb90000.nand.0:2m(u-boot),-(root)" CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_SPL_ALTERA_SDRAM=y
Change NAND flash MTD partition in device tree after implementation of UBI and UBIFS. "u-boot" partition remain for raw u-boot image, but "root" partition is use for UBI image containing all other components.
Signed-off-by: Sin Hui Kho sin.hui.kho@intel.com Signed-off-by: Jit Loon Lim jit.loon.lim@intel.com --- arch/arm/dts/socfpga_agilex_socdk_nand.dts | 55 ++++++ arch/arm/dts/socfpga_stratix10_socdk_nand.dts | 167 ++++++++++++++++++ 2 files changed, 222 insertions(+) create mode 100755 arch/arm/dts/socfpga_agilex_socdk_nand.dts create mode 100755 arch/arm/dts/socfpga_stratix10_socdk_nand.dts
diff --git a/arch/arm/dts/socfpga_agilex_socdk_nand.dts b/arch/arm/dts/socfpga_agilex_socdk_nand.dts new file mode 100755 index 0000000000..3237e34c99 --- /dev/null +++ b/arch/arm/dts/socfpga_agilex_socdk_nand.dts @@ -0,0 +1,55 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2019 Intel Corporation + */ +#include "socfpga_agilex_socdk.dts" +#include "socfpga_agilex_socdk-u-boot.dtsi" +&gmac0 { + status = "disabled"; +}; +&gmac2 { + status = "okay"; + phy-mode = "rgmii"; + phy-handle = <&phy0>; + max-frame-size = <3800>; + mdio2 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "snps,dwmac-mdio"; + phy2: ethernet-phy@2 { + reg = <4>; + txd0-skew-ps = <0>; /* -420ps */ + txd1-skew-ps = <0>; /* -420ps */ + txd2-skew-ps = <0>; /* -420ps */ + txd3-skew-ps = <0>; /* -420ps */ + rxd0-skew-ps = <420>; /* 0ps */ + rxd1-skew-ps = <420>; /* 0ps */ + rxd2-skew-ps = <420>; /* 0ps */ + rxd3-skew-ps = <420>; /* 0ps */ + txen-skew-ps = <0>; /* -420ps */ + txc-skew-ps = <1860>; /* 960ps */ + rxdv-skew-ps = <420>; /* 0ps */ + rxc-skew-ps = <1680>; /* 780ps */ + }; + }; +}; +&mmc { + status = "disabled"; +}; +&nand { + flash@0 { + partitions { + compatible = "fixed-partitions"; + #address-cells = <1>; + #size-cells = <1>; + partition@0 { + label = "u-boot"; + reg = <0 0x200000>; + }; + partition@200000 { + label = "root"; + reg = <0x200000 0x3fe00000>; + }; + }; + }; +}; \ No newline at end of file diff --git a/arch/arm/dts/socfpga_stratix10_socdk_nand.dts b/arch/arm/dts/socfpga_stratix10_socdk_nand.dts new file mode 100755 index 0000000000..9a23c36b92 --- /dev/null +++ b/arch/arm/dts/socfpga_stratix10_socdk_nand.dts @@ -0,0 +1,167 @@ +// SPDX-License-Identifier: GPL-2.0-only +/* + * Copyright Altera Corporation (C) 2015. All rights reserved. + */ +#include "socfpga_stratix10.dtsi" +/ { + model = "SoCFPGA Stratix 10 SoCDK"; + aliases { + serial0 = &uart0; + ethernet0 = &gmac0; + ethernet1 = &gmac1; + ethernet2 = &gmac2; + }; + leds { + compatible = "gpio-leds"; + hps0 { + label = "hps_led0"; + gpios = <&portb 20 GPIO_ACTIVE_HIGH>; + }; + hps1 { + label = "hps_led1"; + gpios = <&portb 19 GPIO_ACTIVE_HIGH>; + }; + hps2 { + label = "hps_led2"; + gpios = <&portb 21 GPIO_ACTIVE_HIGH>; + }; + }; + memory { + device_type = "memory"; + /* We expect the bootloader to fill in the reg */ + reg = <0 0 0 0>; + }; + ref_033v: 033-v-ref { + compatible = "regulator-fixed"; + regulator-name = "0.33V"; + regulator-min-microvolt = <330000>; + regulator-max-microvolt = <330000>; + }; + soc { + clocks { + osc1 { + clock-frequency = <25000000>; + }; + }; + eccmgr { + sdmmca-ecc@ff8c8c00 { + compatible = "altr,socfpga-s10-sdmmc-ecc", + "altr,socfpga-sdmmc-ecc"; + reg = <0xff8c8c00 0x100>; + altr,ecc-parent = <&mmc>; + interrupts = <14 4>, + <15 4>; + }; + }; + }; +}; +&gpio1 { + status = "okay"; +}; +&gmac2 { + status = "okay"; + phy-mode = "rgmii"; + phy-handle = <&phy0>; + max-frame-size = <9000>; + mdio0 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "snps,dwmac-mdio"; + phy0: ethernet-phy@0 { + reg = <4>; + txd0-skew-ps = <0>; /* -420ps */ + txd1-skew-ps = <0>; /* -420ps */ + txd2-skew-ps = <0>; /* -420ps */ + txd3-skew-ps = <0>; /* -420ps */ + rxd0-skew-ps = <420>; /* 0ps */ + rxd1-skew-ps = <420>; /* 0ps */ + rxd2-skew-ps = <420>; /* 0ps */ + rxd3-skew-ps = <420>; /* 0ps */ + txen-skew-ps = <0>; /* -420ps */ + txc-skew-ps = <900>; /* 0ps */ + rxdv-skew-ps = <420>; /* 0ps */ + rxc-skew-ps = <1680>; /* 780ps */ + }; + }; +}; +&nand { + flash@0 { + #address-cells = <1>; + #size-cells = <1>; + reg = <0>; + nand-bus-width = <16>; + partition@0 { + label = "u-boot"; + reg = <0 0x200000>; + }; + + partition@200000 { + label = "root"; + reg = <0x200000 0x3fe00000>; + }; + }; +}; +&uart0 { + status = "okay"; +}; +&usb0 { + status = "okay"; + disable-over-current; +}; +&watchdog0 { + status = "okay"; +}; +&i2c2 { + status = "okay"; + clock-frequency = <100000>; + i2c-sda-falling-time-ns = <890>; /* hcnt */ + i2c-sdl-falling-time-ns = <890>; /* lcnt */ + adc@14 { + compatible = "lltc,ltc2497"; + reg = <0x14>; + vref-supply = <&ref_033v>; + }; + temp@4c { + compatible = "maxim,max1619"; + reg = <0x4c>; + }; + eeprom@51 { + compatible = "atmel,24c32"; + reg = <0x51>; + pagesize = <32>; + }; + rtc@68 { + compatible = "dallas,ds1339"; + reg = <0x68>; + }; +}; +&qspi { + flash0: flash@0 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "n25q00a"; + reg = <0>; + spi-max-frequency = <100000000>; + m25p,fast-read; + cdns,page-size = <256>; + cdns,block-size = <16>; + cdns,read-delay = <1>; + cdns,tshsl-ns = <50>; + cdns,tsd2d-ns = <50>; + cdns,tchsh-ns = <4>; + cdns,tslch-ns = <4>; + partitions { + compatible = "fixed-partitions"; + #address-cells = <1>; + #size-cells = <1>; + qspi_boot: partition@0 { + label = "Boot and fpga data"; + reg = <0x0 0x034B0000>; + }; + qspi_rootfs: partition@4000000 { + label = "Root Filesystem - JFFS2"; + reg = <0x034B0000 0x0EB50000>; + }; + }; + }; +}; \ No newline at end of file
Load kernel and device tree from UBI volume. Set root file system type for NAND boot as UBIFS located at UBI volume on MTD partition 1 or namely "root".
Signed-off-by: Sin Hui Kho sin.hui.kho@intel.com Signed-off-by: Jit Loon Lim jit.loon.lim@intel.com --- include/configs/socfpga_soc64_common.h | 9 +++++++-- 1 file changed, 7 insertions(+), 2 deletions(-)
diff --git a/include/configs/socfpga_soc64_common.h b/include/configs/socfpga_soc64_common.h index 5939f13231..5b1d243153 100644 --- a/include/configs/socfpga_soc64_common.h +++ b/include/configs/socfpga_soc64_common.h @@ -92,10 +92,15 @@ "scriptfile=u-boot.scr\0" \ "fatscript=if fatload mmc 0:1 ${scriptaddr} ${scriptfile};" \ "then source ${scriptaddr}:script; fi\0" \ + "nandroot=ubi0:rootfs\0" \ + "nandload=ubi part root; ubi readvol ${loadaddr} kernel; ubi readvol ${fdt_addr} dtb\0" \ + "nandboot=setenv bootargs " CONFIG_BOOTARGS \ + " root=${nandroot} rw rootwait rootfstype=ubifs ubi.mtd=1; " \ + "booti ${loadaddr} - ${fdt_addr}\0" \ "nandfitboot=setenv bootargs " CONFIG_BOOTARGS \ - " root=${nandroot} rw rootwait rootfstype=jffs2; " \ + " root=${nandroot} rw rootwait rootfstype=ubifs ubi.mtd=1; " \ "bootm ${loadaddr}\0" \ - "nandfitload=nand read ${loadaddr} kernel\0" \ + "nandfitload=ubi part root; ubi readvol ${loadaddr} kernel\0" \ "socfpga_legacy_reset_compat=1\0" \ "rsu_status=rsu dtb; rsu display_dcmf_version; "\ "rsu display_dcmf_status; rsu display_max_retry\0" \
Jit Loon Lim
