[U-Boot] [PATCH] Add gc-section support for ARM
Seems odd that this hasn't been done yet. Shaves 5k off an omap overo build.
Signed-off-by: Charles Manning cdhmanning@gmail.com --- arch/arm/config.mk | 4 ++++ 1 files changed, 4 insertions(+), 0 deletions(-)
diff --git a/arch/arm/config.mk b/arch/arm/config.mk index 45f9dca..73e0cce 100644 --- a/arch/arm/config.mk +++ b/arch/arm/config.mk @@ -55,6 +55,10 @@ PF_CPPFLAGS_ABI := $(call cc-option,\ ) PLATFORM_CPPFLAGS += $(PF_CPPFLAGS_ARM) $(PF_CPPFLAGS_ABI)
+PLATFORM_RELFLAGS += -ffunction-sections + +LDFLAGS_FINAL += --gc-sections + # For EABI, make sure to provide raise() ifneq (,$(findstring -mabi=aapcs-linux,$(PLATFORM_CPPFLAGS))) # This file is parsed many times, so the string may get added multiple
On Monday 14 May 2012 17:15:50 Mike Frysinger wrote:
my understanding is that it doesn't work for some
It won't work for people that don't set up their lds properly.
where's the -fdata-sections ?
I tried that once before and could not get that to work with u-boot. I figure doing just the function sections is better than nothing.
current u-boot policy is to not introduce changes that knowingly break other platforms. so if you want to update the common arm config.mk, you need to at least compile test all arm boards.
so even your lds isn't setup properly ? :P
other arches are using both fine, so it isn't a problem of common code. -mike
... and considering this is dependent on toolchain setups, this should also be performed for the most common toolchains versions around (ELDK 4.2 and 5.x; CS 2011, 2010, maybe even 2009; Linaro; LLVM even).
Amicalement,
Doesn't that makes it an impossible task? Not having all the boards makes it pretty hard to test them all.
Correct. I was aiming to achieve a certain size. Once I achieved that I stopped fiddling. The problem was probably in the relocation stuff.
I might be incorrect, but I have noticed what appears to be some differences between different versions of binutils.
-- CHarles
Dear Charles,
A compile test does not require any actual hardware.
Please be more specific. The same "different versions of binutils" appear to work fine on other architectures ?
On Wednesday 16 May 2012 10:25:26 Wolfgang Denk wrote:
Dear Charles,
Does the patch fail I submitted fail any compile tests?
AFAIK, it compiles but the resulting binary might just be rubbish on some boards.
It worked fine on my overo board without any changes to the overo lds.
I have just verified that it builds on overo mx51evk davinci_sonata
If there is an expectation to build every possible config is there a script that will do that?
That was based on some observations a year or two ago. I don't know if the problem has now gone away and have no way of reproducing it.
-- Charles
Dear Charles,
Yes, MAKEALL in the top level. Assuming you've installed ELDK5.1 or 4.2 to their default locations: $ source /opt/eldk-5.1/armv7a/environment-setup-armv7a-vfp-neon-linux-gnueabi $ CROSS_COMPILE=arm-linux-gnueabi- BUILD_DIR=eldk51 ./MAKEALL -a arm $ CROSS_COMPILE=/opt/eldk-4.2/arm/usr/bin/arm-linux-gnueabi- BUILD_DIR=eldk42 ./MAKEALL -a arm
(I've got the above in a script with a few tweaks to build all TI stuff, for example).
Dear Charles Manning,
What exactly do you mean by "could not get that to work"? What exactly was the problem? And which exact tool chain did you use then?
participants (6)
Albert ARIBAUD
Charles Manning
Charles Manning
Mike Frysinger
