Hi Wolfgang,
please pull The following changes since commit 59869ca72df8bc4e4ffa9dd17cb6673bbe010272: Wolfgang Denk (1): Merge branch 'master' of git://git.denx.de/u-boot-video
git://git.denx.de/u-boot-arm.git master
Daniel Mack (2): pxa: add clock for system bus 2 arbiter pxa: fix CKEN_B register bits
Grazvydas Ignotas (4): OMAP3 pandora: pin mux cleanup OMAP3 pandora: setup pin mux for pins used on rev3 boards OMAP3 pandora: setup pulls for various GPIOs OMAP3 pandora: Fix CKE1 MUX setting to allow self-refresh
Jean-Christophe PLAGNIOL-VILLARD (2): versatile: specify the board type on the prompt versatile: update config and merge to cfi flash driver
Prafulla Wadaskar (2): nand: Add Marvell Kirkwood NAND driver arm: Kirkwood: bugfix: UART1 bar correction
Sedji Gaouaou (2): at91: Introduction of at91sam9g45 SOC. at91: Introduction of at91sam9g10 SOC.
MAINTAINERS | 4 + MAKEALL | 38 +- Makefile | 41 ++- board/armltd/versatile/Makefile | 2 +- board/armltd/versatile/flash.c | 514 ----------------------- board/atmel/at91sam9261ek/at91sam9261ek.c | 36 ++ board/atmel/at91sam9m10g45ek/Makefile | 55 +++ board/atmel/at91sam9m10g45ek/at91sam9m10g45ek.c | 334 +++++++++++++++ board/atmel/at91sam9m10g45ek/config.mk | 1 + board/atmel/at91sam9m10g45ek/led.c | 41 ++ board/omap3/pandora/pandora.h | 86 ++--- cpu/arm926ejs/at91/Makefile | 3 + cpu/arm926ejs/at91/at91sam9m10g45_devices.c | 175 ++++++++ cpu/arm926ejs/at91/clock.c | 12 +- doc/README.at91 | 22 +- drivers/mtd/nand/Makefile | 1 + drivers/mtd/nand/kirkwood_nand.c | 82 ++++ drivers/net/macb.c | 6 +- include/asm-arm/arch-at91/at91_pmc.h | 1 + include/asm-arm/arch-at91/at91sam9_matrix.h | 2 + include/asm-arm/arch-at91/at91sam9g45.h | 139 ++++++ include/asm-arm/arch-at91/at91sam9g45_matrix.h | 153 +++++++ include/asm-arm/arch-at91/clk.h | 5 + include/asm-arm/arch-at91/hardware.h | 8 +- include/asm-arm/arch-at91/memory-map.h | 1 + include/asm-arm/arch-kirkwood/kirkwood.h | 2 +- include/asm-arm/arch-pxa/pxa-regs.h | 13 +- include/configs/at91sam9261ek.h | 13 +- include/configs/at91sam9m10g45ek.h | 225 ++++++++++ include/configs/versatile.h | 77 +++- 30 files changed, 1474 insertions(+), 618 deletions(-) delete mode 100644 board/armltd/versatile/flash.c create mode 100644 board/atmel/at91sam9m10g45ek/Makefile create mode 100644 board/atmel/at91sam9m10g45ek/at91sam9m10g45ek.c create mode 100644 board/atmel/at91sam9m10g45ek/config.mk create mode 100644 board/atmel/at91sam9m10g45ek/led.c create mode 100644 cpu/arm926ejs/at91/at91sam9m10g45_devices.c create mode 100644 drivers/mtd/nand/kirkwood_nand.c create mode 100644 include/asm-arm/arch-at91/at91sam9g45.h create mode 100644 include/asm-arm/arch-at91/at91sam9g45_matrix.h create mode 100644 include/configs/at91sam9m10g45ek.h
Best Regards, J.
Dear Jean-Christophe PLAGNIOL-VILLARD,
In message 20090712214057.GF1686@game.jcrosoft.org you wrote:
Hi Wolfgang,
Applied, thanks.
