[U-Boot] [PATCH v2] mtd: spi: Kconfig: Imply SPI_FLASH if DM_SPI_FLASH
DM_SPI_FLASH should require spi flash interface code for dm version, so select SPI_FLASH core by default if any board enabled DM_SPI_FLASH.
This overcome the explicit enablement of CONFIG_SPI_FLASH on respective boards when DM_SPI_FLASH being used.
Cc: Vignesh R vigneshr@ti.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- Changes for v2: - use imply than select
drivers/mtd/spi/Kconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/drivers/mtd/spi/Kconfig b/drivers/mtd/spi/Kconfig index a0cfc623c6..681dc9cccc 100644 --- a/drivers/mtd/spi/Kconfig +++ b/drivers/mtd/spi/Kconfig @@ -3,6 +3,7 @@ menu "SPI Flash Support" config DM_SPI_FLASH bool "Enable Driver Model for SPI flash" depends on DM && DM_SPI + imply SPI_FLASH help Enable driver model for SPI flash. This SPI flash interface (spi_flash_probe(), spi_flash_write(), etc.) is then
Acked-by: Vignesh Raghavendra vigneshr@ti.com
Changes for v2:
- imply SPI_FLASH help Enable driver model for SPI flash. This SPI flash interface (spi_flash_probe(), spi_flash_write(), etc.) is then
Jagan Teki
Vignesh Raghavendra
