[U-Boot] at91sam9g20 sd card boot
Greetings,
Is there a framework in place for using U-Boot to boot Linux from an SD Card on an at91sam9g20 processor?
I've been reading through the code and found at a minimum, I would need to enable the mmc command and the atmel_mci library. Then the mmc commands exist in the console but mmcinfo does nothing. Am I looking in the right place to get this functional?
Thank you,
Rob
On 16:56 Thu 16 Apr , Rob Emanuele wrote:
Greetings,
the mci drivers could help you about it but it need to be tested and updated
yes
Best Regards, J.
Jean-Christophe PLAGNIOL-VILLARD
Rob Emanuele
