[U-Boot] [PATCH 1/5][v3] powerpc/mpc85xx:No NOR boot, do not compile IFC errata A003399
IFC errata A003399 is valid for IFC NOR boot i.e.if no on-board NOR flash or no NOR boot, do not compile its workaround.
Signed-off-by: Prabhakar Kushwaha prabhakar@freescale.com --- Based upon git://git.denx.de/u-boot.git branch master Changes for v2: - Add CONFIG_A003399_NOR_WORKAROUND for errata workaround - Add CONFIG_A003399_NOR_WORKAROUND in README Changes for v3: - Use only CONFIG_A003399_NOR_WORKAROUND for errata workaround
README | 4 ++++ arch/powerpc/cpu/mpc85xx/cpu_init_early.c | 6 +++--- arch/powerpc/cpu/mpc8xxx/fsl_ifc.c | 2 +- 3 files changed, 8 insertions(+), 4 deletions(-)
diff --git a/README b/README index 5701016..ee86f75 100644 --- a/README +++ b/README @@ -414,6 +414,10 @@ The following options need to be configured: See Freescale App Note 4493 for more information about this erratum.
+ CONFIG_A003399_NOR_WORKAROUND + Enables a workaround for IFC erratum A003399. It is only + requred during NOR boot. + CONFIG_SYS_FSL_CORENET_SNOOPVEC_COREONLY
This is the value to write into CCSR offset 0x18600 diff --git a/arch/powerpc/cpu/mpc85xx/cpu_init_early.c b/arch/powerpc/cpu/mpc85xx/cpu_init_early.c index dacfdd1..439a873 100644 --- a/arch/powerpc/cpu/mpc85xx/cpu_init_early.c +++ b/arch/powerpc/cpu/mpc85xx/cpu_init_early.c @@ -25,7 +25,7 @@
DECLARE_GLOBAL_DATA_PTR;
-#if defined(CONFIG_SYS_FSL_ERRATUM_IFC_A003399) && !defined(CONFIG_SYS_RAMBOOT) +#ifdef CONFIG_A003399_NOR_WORKAROUND void setup_ifc(void) { struct fsl_ifc *ifc_regs = (void *)CONFIG_SYS_IFC_ADDR; @@ -99,7 +99,7 @@ void cpu_init_early_f(void) #ifdef CONFIG_SYS_FSL_ERRATUM_P1010_A003549 ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); #endif -#if defined(CONFIG_SYS_FSL_ERRATUM_IFC_A003399) && !defined(CONFIG_SYS_RAMBOOT) +#ifdef CONFIG_A003399_NOR_WORKAROUND ccsr_l2cache_t *l2cache = (void *)CONFIG_SYS_MPC85xx_L2_ADDR; u32 *dst, *src; void (*setup_ifc_sram)(void); @@ -138,7 +138,7 @@ void cpu_init_early_f(void) * Work Around for IFC Erratum A003399, issue will hit only when execution * from NOR Flash */ -#if defined(CONFIG_SYS_FSL_ERRATUM_IFC_A003399) && !defined(CONFIG_SYS_RAMBOOT) +#ifdef CONFIG_A003399_NOR_WORKAROUND #define SRAM_BASE_ADDR (0x00000000) /* TLB for SRAM */ mas0 = MAS0_TLBSEL(1) | MAS0_ESEL(9); diff --git a/arch/powerpc/cpu/mpc8xxx/fsl_ifc.c b/arch/powerpc/cpu/mpc8xxx/fsl_ifc.c index 56b319f..959a0e2 100644 --- a/arch/powerpc/cpu/mpc8xxx/fsl_ifc.c +++ b/arch/powerpc/cpu/mpc8xxx/fsl_ifc.c @@ -43,7 +43,7 @@ void init_early_memctl_regs(void) set_ifc_ftim(IFC_CS0, IFC_FTIM2, CONFIG_SYS_CS0_FTIM2); set_ifc_ftim(IFC_CS0, IFC_FTIM3, CONFIG_SYS_CS0_FTIM3);
-#if !defined(CONFIG_SYS_FSL_ERRATUM_IFC_A003399) || defined(CONFIG_SYS_RAMBOOT) +#ifndef CONFIG_A003399_NOR_WORKAROUND #ifdef CONFIG_SYS_CSPR0_EXT set_ifc_cspr_ext(IFC_CS0, CONFIG_SYS_CSPR0_EXT); #endif
Prabhakar Kushwaha
