Hi, Recently I am start getting strange problem with u-boot-2011.09. MPC8313ERDB like configuration ( main change - I am using different NAND flash - 256MBib - need change page size)
If I am access NAND flash before nor u-boot not always read NOR correctly.
mtdparts
device nor0 <phys_mapped_flash>, # parts = 3 #: name size offset mask_flags 0: u-boot 0x000e0000 0x00000000 0 1: env 0x00020000 0x000e0000 0 2: jffs2 0x01f00000 0x00100000 0
device nand0 <e2800000.flash>, # parts = 1 #: name size offset mask_flags 0: ubifs 0x10000000 0x00000000 0
If I do: ubi part ubifs;ubifsmount iptec_nand
and read something from NAND before I read NOR
I am getting time to time after Linux update uImage:
run boot_cmd
### JFFS2 loading 'BANK1/uImage' to 0x100000 Scanning JFFS2 FS: . done. ### JFFS2 load complete: 4926025 bytes loaded to 0x100000 ### JFFS2 loading 'BANK1/vnp100_dtb.dtb' to 0x900000 ### JFFS2 load complete: 10205 bytes loaded to 0x900000 ## Booting kernel from Legacy Image at 00100000 ... Image Name: Linux-2.6.38.8 Image Type: PowerPC Linux Kernel Image (gzip compressed) Data Size: 4925961 Bytes = 4.7 MiB Load Address: 02000000 Entry Point: 02000000 Verifying Checksum ... Bad Data CRC ERROR: can't get kernel image!
but if I reset board and skip NAND access it always fine, some times I can add or remove some environment variable after NAND access and it boot even without reset:
run boot_cmd
### JFFS2 loading 'BANK1/uImage' to 0x100000 Scanning JFFS2 FS: . done. ### JFFS2 load complete: 4926025 bytes loaded to 0x100000 ### JFFS2 loading 'BANK1/vnp100_dtb.dtb' to 0x900000 ### JFFS2 load complete: 10205 bytes loaded to 0x900000 ## Booting kernel from Legacy Image at 00100000 ... Image Name: Linux-2.6.38.8 Image Type: PowerPC Linux Kernel Image (gzip compressed) Data Size: 4925961 Bytes = 4.7 MiB Load Address: 02000000 Entry Point: 02000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 00900000 Booting using the fdt blob at 0x900000 Uncompressing Kernel Image ... OK Loading Device Tree to 007fa000, end 007ff7dc ... OK
I found most stable configuration: mount NAND, read NAND, chaprt nor0,2 boot
and most unstable chaprt nor0,2 mount NAND, read NAND, boot
And I did increase malloc size to 1M.( ubifs does not like 128K). There is no option for stack size - it is PPC, so it should grow down as needed.
As long I am not mixing NOR and NAND evithing working perfect.
Any idea?
Thanks, Andrei
Please always try with the latest U-Boot when you have a problem -- or even when you don't have a problem. :-)
mtdparts
How much time passes between the NAND access and the NOR access? If it's all part of a script, maybe the NAND access isn't quite finished when the command returns.
We used to have problems on Linux with NAND and NOR interfering, though I wouldn't think that it would be possible in U-Boot even with the old broken code because of its single-tasking nature.
One thing you might want to try is applying Linux commit 476459a6cf46d20ec73d9b211f3894ced5f9871e ("mtd: eLBC NAND: use recommended command sequences") to U-Boot.
I don't see "chaprt" in the U-Boot sources. Where did you get U-Boot from?
I thought your problem was doing NAND before NOR, not the other way around.
MPC8313ERDB has always had a malloc size of 512K -- where did 128K come from?
It grows down within the area that has been designated for the stack. This area is not very large. Do you have any reason to believe you're seeing stack issues?
-Scott
Hi Scott, Thanks for you replay and sorry for my not speedy answer comments below.
mtdparts
It is few seconds - I am reading from NAND fpga images and loading them to FPGA's
I almost apply this patch already. Thanks for point out on it. Few changes in it. I do not know how it related to Linux, but I can not use CM0/CM2 instead of CW0 - even U-boot NAND detection get unstable ( READID command) if I replace CW0 to CM0 - so I kept CW0 every where, but before I miss changes in fsl_elbc_wait() - I have add it.
Sorry for my mistype "chpart"
Yes you correct, but it looks like chaprt command part ( as I understand) NOR or jffs MTDs and has nothing to do ubi mtd. And with few more test "ubiload" command corrupt next nor access no matter time is passing after that. Making me believe to memory than bus issue. eLbc as I remember must have bus timeout around few seconds, it must release all chips after that.
Sorry for that I think I have bump malloc size due to ubi fread files from ubi, bu I will check is it really needed.
How it is limited? in .lds?
As I understand memory allocation is : top malloc area, stack
or wise verse if one overshoot can corrupt other, and jffs keeping some staff from first scan. I actually did not think about possibility of lbs hangs or corrupting other CS, but Freesacle as usial :) I will test more with this changes, but as I mention this is intermittent issue, so I do not know whet I could declare it fixed. I do not see reason to post a patch, due to currently is discussing in mail list porting nand/ubi from Linux 3.xx something - so this changes mostly will be in I hope soon.
-Scott
Andrei
Scott Wood
