[U-Boot] How does Driver Model UART work?
Simon,
Now I am seeing driver/serial/serial_tegra.c
U_BOOT_DRIVER(serial_ns16550) = { .name = "serial_tegra20", .id = UCLASS_SERIAL, .of_match = tegra_serial_ids, .ofdata_to_platdata = tegra_serial_ofdata_to_platdata, .platdata_auto_alloc_size = sizeof(struct ns16550_platdata), .priv_auto_alloc_size = sizeof(struct NS16550), .probe = ns16550_serial_probe, .ops = &ns16550_serial_ops,
You require sizeof(struct NS16550) (= about 30~ 40 bytes) for .priv_auto_alloc_size.
Seems strange.
It looks like the private date is used as the base address of the hardware
Here,
struct NS16550 *const com_port = dev_get_priv(dev);
If the hardware register has 0x10000 width, do we need to allocation 0x10000 memory for .priv data?
I think 4 byte (or 8 byte on 64bit architectures) is enough to store the base address.
It looks like the memory is allocated for .priv in device_probe() function, but I could not find where .priv is set for pointing to the base address.
Perhaps I am not understanding well yet, but I'm still not convinced how it is working.
Best Regards Masahiro Yamada
Simon,
I am totally being confused.
As far as I looked at the dm code, the private data is calloc'ed in device_probe() function
if (drv->priv_auto_alloc_size) { dev->priv = calloc(1, drv->priv_auto_alloc_size); if (!dev->priv) { ret = -ENOMEM; goto fail; } }
So, dev->priv is storing the address of the allocated memory.
Am I understanding correctly?
If so, I can't understand the following code:
static int ns16550_serial_getc(struct udevice *dev) { struct NS16550 *const com_port = dev_get_priv(dev);
if (!serial_in(&com_port->lsr) & UART_LSR_DR) return -EAGAIN;
"com_port" is dev->priv, so it is pointing to the allocated area on RAM, I guess.
It looks like serial_in(&com_port->lsr) is trying to read from the hardware register ?
Or reading from malloc area RAM ??
Hi Masahiro,
On 3 October 2014 07:04, Masahiro Yamada yamada.m@jp.panasonic.com wrote:
Simon,
Yes, it always does in driver model. This driver is no different.
BTW the ns16550 driver is probably the oddest in U-Boot - it looks like UniPhier has its own UART driver so it would be better to convert that I think. See below for ideas on other UART drivers to look at which are much more normal.
If you go one level deeper you will see that serial_in() is defined at the top in about 5 ways, one of which is used for driver model:
#define serial_in(addr) \ ns16550_readb(com_port, addr - (unsigned char *)com_port)
So it used com_port which is not an parameter. The parameter addr is only used to specify the register. This is actually the same as the non-DM code except in that case the parameter specifies the register and hardware address at the same time.
This is done since the internal NS16550_t type is unfortunately exported all over U-Boot. This is annoying because it is actually an internal register format for the UART. Even worse is the fact that the structure changes depending on CONFIG_SYS_NS16550_REG_SIZE. We can't have this sort of thing in driver model - we need to be able to cope with the device tree specifying all the information that the UART needs. So for driver model:
/* * For driver model we always use one byte per register, and sort out the * differences in the driver */ #define CONFIG_SYS_NS16550_REG_SIZE (-1)
(see ns16550.h header for where this is used)
I would like to avoid having that type exported and use a different method to pass the UART information around. But it is used in about 30 places . So this approach allows us to move forward bit by bit, without duplicating the UART driver and creating a maintenance headache.
In terns of implementing a new UART driver, are you using device tree?
If so then you should just be able to follow along with Tegra - it's really easy - just copy that serial_tegra.c and adjust the device tree compat string and input clock. Other examples are serial_omap and serial_dw. (See u-boot-dm/working)
If you are using platform data, then the examples are serial_mxc and serial_pl01x.
Hi Simon,
2014-10-03 22:51 GMT+09:00 Simon Glass sjg@chromium.org:
Hi Masahiro,
Simon,
Without your help, I never could have understood this code. Now it is clearer, thanks! (although this code is really unfortunate...)
Agreed. We should pass "reg-shift" from a device tree or a board-file.
If all the board switched to the driver model, the driver code would become much clean.
- For driver model we always use one byte per register, and sort out the
- differences in the driver
UniPhier SoCs have not supported the device tree control yet.
I am planning to do the dm conversion with a board file.
These are unfortunate. They are borrowing ns16550 code.
I am doing this way.
Anyway, the register map of UniPhier is not 8250-compatible. It cannot borrow ns16550 code.
Hi Masahiro,
On 4 October 2014 06:57, Masahiro YAMADA yamada.m@jp.panasonic.com wrote:
Hi Simon,
Hi Masahiro,
Simon,
It felt like laparoscopic surgery - there is a nicely-healed wound but inside is another story.
Yes, I'm looking forward to that day.
Tegra and many other SOCs have used this code for a while, just with some defines to make it work. I didn't want to copy it.
That's probably for the best.
Masahiro YAMADA
Masahiro Yamada
