[PATCH] arm: kirkwood: nsa310s: Add Distro boot capability
- Add distro boot to board include file and deconfig file - Miscellaneous changes: - Remove Gerald from maintainer list (email bounced) - Add CONFIG_SUPPORT_PASSING_ATAGS and friends to support legacy kernel method of booting (e.g. OpenWrt) with appended DTB. - Add CONFIG_UBIFS_SILENCE_MSG to reduce binary size.
Note that this patch is depended on the following patch: https://patchwork.ozlabs.org/project/uboot/patch/20220807192709.21717-1-pali...
Signed-off-by: Tony Dinh mibodhi@gmail.com ---
board/zyxel/nsa310s/MAINTAINERS | 1 - configs/nsa310s_defconfig | 17 ++++-------- include/configs/nsa310s.h | 48 +++++++++++++++++++++++++++++---- 3 files changed, 48 insertions(+), 18 deletions(-)
diff --git a/board/zyxel/nsa310s/MAINTAINERS b/board/zyxel/nsa310s/MAINTAINERS index d153758c21..11106acf3e 100644 --- a/board/zyxel/nsa310s/MAINTAINERS +++ b/board/zyxel/nsa310s/MAINTAINERS @@ -1,5 +1,4 @@ NSA310S BOARD -M: Gerald Kerma dreagle@doukki.net M: Tony Dinh mibodhi@gmail.com M: Luka Perkov luka.perkov@sartura.hr S: Maintained diff --git a/configs/nsa310s_defconfig b/configs/nsa310s_defconfig index 2b39ae74b3..a5f01ef88e 100644 --- a/configs/nsa310s_defconfig +++ b/configs/nsa310s_defconfig @@ -4,6 +4,9 @@ CONFIG_SYS_DCACHE_OFF=y CONFIG_ARCH_CPU_INIT=y CONFIG_SYS_THUMB_BUILD=y CONFIG_ARCH_KIRKWOOD=y +CONFIG_SUPPORT_PASSING_ATAGS=y +CONFIG_CMDLINE_TAG=y +CONFIG_INITRD_TAG=y CONFIG_SYS_KWD_CONFIG="board/zyxel/nsa310s/kwbimage.cfg" CONFIG_SYS_TEXT_BASE=0x600000 CONFIG_SYS_MALLOC_F_LEN=0x400 @@ -14,35 +17,25 @@ CONFIG_ENV_OFFSET=0xE0000 CONFIG_DEFAULT_DEVICE_TREE="kirkwood-nsa310s" CONFIG_IDENT_STRING="\nZyXEL NSA310S/320S 1/2-Bay Power Media Server" CONFIG_SYS_LOAD_ADDR=0x800000 +CONFIG_DISTRO_DEFAULTS=y CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0xc8012000 CONFIG_BOOTDELAY=3 -CONFIG_USE_BOOTCOMMAND=y -CONFIG_BOOTCOMMAND="setenv bootargs ${console} ${mtdparts} ${bootargs_root}; ubi part root; ubifsmount ubi:rootfs; ubifsload 0x800000 ${kernel}; ubifsload 0x700000 ${fdt}; ubifsumount; fdt addr 0x700000; fdt resize; fdt chosen; bootz 0x800000 - 0x700000" CONFIG_USE_PREBOOT=y # CONFIG_DISPLAY_BOARDINFO is not set -CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="NSA310s> " CONFIG_SYS_MAXARGS=32 CONFIG_SYS_PBSIZE=1050 -CONFIG_CMD_BOOTZ=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_NAND=y CONFIG_CMD_SATA=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set -CONFIG_CMD_DHCP=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_FAT=y -CONFIG_CMD_FS_GENERIC=y CONFIG_CMD_JFFS2=y CONFIG_CMD_MTDPARTS=y CONFIG_MTDIDS_DEFAULT="nand0=orion_nand" CONFIG_MTDPARTS_DEFAULT="mtdparts=orion_nand:0xe0000@0x0(uboot),0x20000@0xe0000(uboot_env),0x100000@0x100000(second_stage_uboot),-@0x200000(root)" CONFIG_CMD_UBI=y -CONFIG_ISO_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_NAND=y @@ -65,6 +58,6 @@ CONFIG_MII=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y -CONFIG_USB_STORAGE=y +CONFIG_UBIFS_SILENCE_MSG=y CONFIG_LZMA=y CONFIG_BZIP2=y diff --git a/include/configs/nsa310s.h b/include/configs/nsa310s.h index 027a47b5a3..a538721c45 100644 --- a/include/configs/nsa310s.h +++ b/include/configs/nsa310s.h @@ -9,15 +9,53 @@ #ifndef _CONFIG_NSA310S_H #define _CONFIG_NSA310S_H
+/* + * mv-common.h should be defined after CMD configs since it used them + * to enable certain macros + */ #include "mv-common.h"
-/* default environment variables */ +/* Include the common distro boot environment */ +#ifndef CONFIG_SPL_BUILD + +#ifdef CONFIG_SATA +#define BOOT_TARGET_DEVICES_SATA(func) func(SATA, sata, 0) +#else +#define BOOT_TARGET_DEVICES_SATA(func) +#endif + +#ifdef CONFIG_USB_STORAGE +#define BOOT_TARGET_DEVICES_USB(func) func(USB, usb, 0) +#else +#define BOOT_TARGET_DEVICES_USB(func) +#endif + +#define BOOT_TARGET_DEVICES(func) \ + BOOT_TARGET_DEVICES_USB(func) \ + BOOT_TARGET_DEVICES_SATA(func) \ + func(DHCP, dhcp, na) + +#define KERNEL_ADDR_R __stringify(0x800000) +#define FDT_ADDR_R __stringify(0x2c00000) +#define RAMDISK_ADDR_R __stringify(0x01100000) +#define SCRIPT_ADDR_R __stringify(0x200000) + +#define LOAD_ADDRESS_ENV_SETTINGS \ + "kernel_addr_r=" KERNEL_ADDR_R "\0" \ + "fdt_addr_r=" FDT_ADDR_R "\0" \ + "ramdisk_addr_r=" RAMDISK_ADDR_R "\0" \ + "scriptaddr=" SCRIPT_ADDR_R "\0" + +#include <config_distro_bootcmd.h>
#define CONFIG_EXTRA_ENV_SETTINGS \ - "console=console=ttyS0,115200\0" \ - "kernel=/boot/zImage\0" \ - "fdt=/boot/nsa310s.dtb\0" \ - "bootargs_root=ubi.mtd=3 root=ubi0:rootfs rootfstype=ubifs rw\0" + LOAD_ADDRESS_ENV_SETTINGS \ + "fdtfile=" CONFIG_DEFAULT_DEVICE_TREE ".dtb\0" \ + "mtdparts=" CONFIG_MTDPARTS_DEFAULT "\0" \ + "console=ttyS0,115200\0" \ + BOOTENV + +#endif /* CONFIG_SPL_BUILD */
/* Ethernet driver configuration */ #define CONFIG_MVGBE_PORTS {1, 0} /* enable port 0 only */
Hi Stefan,
I need to resend this patch. Sorry for the noise!
Thanks, Tony
- mv-common.h should be defined after CMD configs since it used them
- to enable certain macros
BOOTENV
2.30.2
Tony Dinh
