[PATCH v2] xilinx: zynqmp: Save multiboot as variable
Save multiboot register as u-boot variable. And use it as primary source for composing dfu_alt_info for capsule update. If variable is not defined
Changes in v2: - Handle also error values from mult_boot() - Reported by Oleksandr Suvorov oleksandr.suvorov@foundries.io
board/xilinx/zynqmp/zynqmp.c | 10 +++++++++- 1 file changed, 9 insertions(+), 1 deletion(-)
diff --git a/board/xilinx/zynqmp/zynqmp.c b/board/xilinx/zynqmp/zynqmp.c index 5a1f8153409c..dfb5dab7afa3 100644 --- a/board/xilinx/zynqmp/zynqmp.c +++ b/board/xilinx/zynqmp/zynqmp.c @@ -640,7 +640,7 @@ int board_late_init(void) const char *mode; char *new_targets; char *env_targets; - int ret; + int ret, multiboot;
#if defined(CONFIG_USB_ETHER) && !defined(CONFIG_USB_GADGET_DOWNLOAD) usb_ether_init(); @@ -658,6 +658,10 @@ int board_late_init(void) if (ret) return ret;
+ multiboot = multi_boot(); + if (multiboot >= 0) + env_set_hex("multiboot", multiboot); + bootmode = zynqmp_get_bootmode();
puts("Bootmode: "); @@ -864,6 +868,10 @@ void set_dfu_alt_info(char *interface, char *devstr) memset(buf, 0, sizeof(buf));
multiboot = multi_boot(); + if (multiboot < 0) + multiboot = 0; + + multiboot = env_get_hex("multiboot", multiboot); debug("Multiboot: %d\n", multiboot);
switch (zynqmp_get_bootmode()) {
Reviewed-by: Oleksandr Suvorov oleksandr.suvorov@foundries.io
Changes in v2:
int ret;
int ret, multiboot;
if (multiboot >= 0)
bootmode = zynqmp_get_bootmode(); puts("Bootmode: ");
if (multiboot < 0)
multiboot = 0;
multiboot = env_get_hex("multiboot", multiboot); debug("Multiboot: %d\n", multiboot); switch (zynqmp_get_bootmode()) {
-- 2.33.1
Changes in v2:
- int ret;
int ret, multiboot;
if (multiboot >= 0)
puts("Bootmode: ");
if (multiboot < 0)
multiboot = 0;
Applied, Michal
Michal Simek
Oleksandr Suvorov
