[U-Boot] Please pull u-boot-rockchip/master
Hi Tom,
The following changes since commit c07f38208a73bbe3efaa939d6742096c1cb7e0ce:
Merge git://git.denx.de/u-boot-x86 (2017-09-17 11:46:51 -0400)
git://git.denx.de/u-boot-rockchip.git master
for you to fetch changes up to 60d7c50945d65185a5c86c4f52d4671fb59292e3:
rockchip: puma_rk3399: increase serialno_str size (2017-09-18 20:40:38 +0200)
---------------------------------------------------------------- Andy Yan (2): rockchip: rk3368: add ENV_MEM_LAYOUT to extra env settings rockchip: rk3368: add the missing target and pinctrl config for sheep board
David Wu (1): rockchip: rk322x: Disable integrated macphy for saving power consuming
Jagan Teki (1): rk3288: Add Vyasa initial board support
Kever Yang (4): rockchip: enable rk322x sysreset driver rockchip: rk322x: enable fastboot to set boot mode tag rockchip: sdhci: update reg map for of-platdata rockchip: ram: rk3399: update reg map for of-platdata
Klaus Goger (3): rockchip: board: lion_rk3368: update README flash instructions rockchip: board: puma_rk3399: update README flash instructions rockchip: puma_rk3399: increase serialno_str size
Philipp Tomsich (28): bootstage: adjust Makefile to allow including bootstage in SPL, but not in TPL dm: timer: Convert to livetree dm: timer: handle being called before dm_root is ready dm: core: add dev_read_addr_ptr() net: designware: Convert to livetree net: phy: micrel: Convert to livetree rockchip: mmc: convert to livetree rockchip: timer: implement timer_get_boot_us rockchip: timer: Convert to livetree rockchip: clk: rk3368: Convert to livetree rockchip: pinctrl: rk3368: Convert to livetree rockchip: spi: Convert to livetree rockchip: sdhci: Convert to livetree rockchip: rk8xx: remove unused header includes rockchip: i2c: Convert to livetree rockchip: gpio: convert to livetree rockchip: gpio: remove outdated/misleading comment rockchip: dts: rk3368-lion: add /chosen/tick-timer rockchip: lion-rk3368: defconfig: resync w/ OF_LIVE and BOOTSTAGE enabled rockchip: rk3399: spl: remove hard-coded addresses for GRF and SGRF rockchip: clk: rk3399: add clk_enable function and support USB HOST0/1 rockchip: dts: rk3399-puma: replace 'rockchip, vbus-gpio' with fixed regulator rockchip: clk: rk3399: Convert to livetree rockchip: efuse: change to use dev_read_addr_ptr rockchip: defconfig: puma-rk3399: enable OF_LIVE (live tree) rockchip: timer: update for 32/64bit-aware OF_PLATDATA rockchip: rk3368: adjust DMC driver for 32/64bit-aware OF_PLATDATA rockchip: dts: rk3368: reduce the number of nodes seen in TPL
William Wu (2): configs: rockchip: add USB configs for evb-rv1108 board ARM: dts: rockchip: add USB nodes for evb-rv1108
arch/arm/dts/Makefile | 1 + arch/arm/dts/rk3288-vyasa.dts | 327 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ arch/arm/dts/rk3368-lion-u-boot.dtsi | 10 ++-- arch/arm/dts/rk3399-puma.dtsi | 12 +++- arch/arm/dts/rv1108-evb.dts | 22 +++++++ arch/arm/dts/rv1108.dtsi | 24 ++++++++ arch/arm/include/asm/arch-rockchip/grf_rk322x.h | 32 ++++++++++ arch/arm/mach-rockchip/rk322x-board.c | 23 ++++++++ arch/arm/mach-rockchip/rk3288/Kconfig | 11 ++++ arch/arm/mach-rockchip/rk3399-board-spl.c | 34 +++++------ arch/arm/mach-rockchip/rk3399/sdram_rk3399.c | 2 +- board/amarula/vyasa-rk3288/Kconfig | 12 ++++ board/amarula/vyasa-rk3288/MAINTAINERS | 6 ++ board/amarula/vyasa-rk3288/Makefile | 7 +++ board/amarula/vyasa-rk3288/vyasa-rk3288.c | 7 +++ board/theobroma-systems/lion_rk3368/README | 24 +++++++- board/theobroma-systems/puma_rk3399/README | 51 +++++++++++++--- board/theobroma-systems/puma_rk3399/puma-rk3399.c | 2 +- common/Makefile | 2 +- configs/evb-rv1108_defconfig | 21 +++++++ configs/lion-rk3368_defconfig | 7 +++ configs/puma-rk3399_defconfig | 1 + configs/sheep-rk3368_defconfig | 2 + configs/vyasa-rk3288_defconfig | 63 ++++++++++++++++++++ drivers/clk/rockchip/clk_rk3368.c | 2 +- drivers/clk/rockchip/clk_rk3399.c | 19 +++++- drivers/core/read.c | 7 +++ drivers/gpio/rk_gpio.c | 3 +- drivers/i2c/rk_i2c.c | 2 +- drivers/misc/rockchip-efuse.c | 2 +- drivers/mmc/rockchip_dw_mmc.c | 2 +- drivers/mmc/rockchip_sdhci.c | 5 +- drivers/net/designware.c | 11 +--- drivers/net/phy/micrel_ksz90x1.c | 5 +- drivers/pinctrl/rockchip/pinctrl_rk3368.c | 3 +- drivers/power/pmic/rk8xx.c | 2 - drivers/ram/rockchip/dmc-rk3368.c | 11 +--- drivers/spi/rk_spi.c | 2 +- drivers/sysreset/Makefile | 1 + drivers/timer/rockchip_timer.c | 78 ++++++++++++++++++++++--- drivers/timer/timer-uclass.c | 52 ++++++++++------- include/configs/rk3368_common.h | 1 + include/configs/rv1108_common.h | 3 + include/configs/vyasa-rk3288.h | 23 ++++++++ include/dm/read.h | 15 +++++ 45 files changed, 851 insertions(+), 101 deletions(-) create mode 100644 arch/arm/dts/rk3288-vyasa.dts create mode 100644 board/amarula/vyasa-rk3288/Kconfig create mode 100644 board/amarula/vyasa-rk3288/MAINTAINERS create mode 100644 board/amarula/vyasa-rk3288/Makefile create mode 100644 board/amarula/vyasa-rk3288/vyasa-rk3288.c create mode 100644 configs/vyasa-rk3288_defconfig create mode 100644 include/configs/vyasa-rk3288.h
On Mon, Sep 18, 2017 at 08:44:15PM +0200, Dr. Philipp Tomsich wrote:
Hi Tom,
Dr. Philipp Tomsich
