[PATCH] configs: fsl: move bootrom specific defines to Kconfig
Moves below bootrom specific defines to Kconfig:
CONFIG_SYS_FSL_BOOTROM_BASE CONFIG_SYS_FSL_BOOTROM_SIZE
Signed-off-by: Rajesh Bhagat rajesh.bhagat@nxp.com --- arch/arm/cpu/armv8/fsl-layerscape/Kconfig | 10 ++++++++++ arch/arm/include/asm/arch-fsl-layerscape/cpu.h | 2 -- scripts/config_whitelist.txt | 2 -- 3 files changed, 10 insertions(+), 4 deletions(-)
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig index 4d46587214..ae0b7b21e8 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig +++ b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig @@ -640,3 +640,13 @@ config HAS_FSL_XHCI_USB help For some SoC(such as LS1043A and LS1046A), USB and QE-HDLC multiplex use pins, select it when the pins are assigned to USB. + +config SYS_FSL_BOOTROM_BASE + hex + depends on FSL_LSCH2 + default 0 + +config SYS_FSL_BOOTROM_SIZE + hex + depends on FSL_LSCH2 + default 0x1000000 diff --git a/arch/arm/include/asm/arch-fsl-layerscape/cpu.h b/arch/arm/include/asm/arch-fsl-layerscape/cpu.h index 4335aa0ec2..c51b65ea36 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/cpu.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/cpu.h @@ -69,8 +69,6 @@ #define CONFIG_SYS_FSL_DRAM_SIZE2 0x7F80000000 #endif #elif defined(CONFIG_FSL_LSCH2) -#define CONFIG_SYS_FSL_BOOTROM_BASE 0x0 -#define CONFIG_SYS_FSL_BOOTROM_SIZE 0x1000000 #define CONFIG_SYS_FSL_CCSR_BASE 0x1000000 #define CONFIG_SYS_FSL_CCSR_SIZE 0xf000000 #define CONFIG_SYS_FSL_DCSR_BASE 0x20000000 diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index c6a8312495..6934c7ed2e 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -2296,8 +2296,6 @@ CONFIG_SYS_FSL_AIOP1_SIZE CONFIG_SYS_FSL_B4860QDS_XFI_ERR CONFIG_SYS_FSL_BMAN_ADDR CONFIG_SYS_FSL_BMAN_OFFSET -CONFIG_SYS_FSL_BOOTROM_BASE -CONFIG_SYS_FSL_BOOTROM_SIZE CONFIG_SYS_FSL_CCSR_BASE CONFIG_SYS_FSL_CCSR_GUR_BE CONFIG_SYS_FSL_CCSR_GUR_LE
Rajesh Bhagat
