[U-Boot] [PATCH] common: fdt: set the value of MEMORY_BANKS_MAX to 8
set the value of MEMORY_BANKS_MAX to 8. Odroid-XU4 fails to boot with following message
fdt_fixup_memory_banks: num banks 8 exceeds hardcoded limit 4. Recompile with higher MEMORY_BANKS_MAX? ERROR: arch-specific fdt fixup failed - must RESET the board to recover.
Fixes: commit 2a1f4f1758b5 (Revert "fdt_support: Use CONFIG_NR_DRAM_BANKS if defined")
CC: Ramon Fried ramon.fried@gmail.com CC: Simon Glass sjg@chromium.org Signed-off-by: Anand Moon linux.amoon@gmail.com --- common/fdt_support.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/common/fdt_support.c b/common/fdt_support.c index 34d2bd59c4..ad87f31ab3 100644 --- a/common/fdt_support.c +++ b/common/fdt_support.c @@ -409,7 +409,7 @@ static int fdt_pack_reg(const void *fdt, void *buf, u64 *address, u64 *size, return p - (char *)buf; }
-#define MEMORY_BANKS_MAX 4 +#define MEMORY_BANKS_MAX 8 int fdt_fixup_memory_banks(void *blob, u64 start[], u64 size[], int banks) { int err, nodeoffset;
I think it's better to check if MEMORY_BANKS was defined and only if not
to define it to 4. Then users can define MEMORY_BANKS at include/configs/....h Simon, what do you say ?
+#define MEMORY_BANKS_MAX 8 int fdt_fixup_memory_banks(void *blob, u64 start[], u64 size[], int banks) { int err, nodeoffset; -- 2.17.1
I think it's better to check if MEMORY_BANKS was defined and only if not to define it to 4. Then users can define MEMORY_BANKS at include/configs/....h Simon, what do you say ?
My vote is for Kconfig to define this, perhaps with a defaul of 4. But I see there is a lot of discussion and I have been out for a few weeks, so I don't have a strong opinion.
-#define MEMORY_BANKS_MAX 4 +#define MEMORY_BANKS_MAX 8 int fdt_fixup_memory_banks(void *blob, u64 start[], u64 size[], int banks) { int err, nodeoffset; -- 2.17.1
Anand Moon
Ramon Fried
