[PATCH 1/1] mmc: pci_mmc.c should build with ACPIGEN=n
sandbox_defconfig builds the PCI MMC driver. It should be possible to build the sandbox without ACPI support.
ACPI support in the PCI MMC driver is only needed when creating an ACPI table. Fix building with ACPIGEN=n.
Fixes: dba7ee419d9d ("acpi: mmc: Generate ACPI info for the PCI SD Card") Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- drivers/mmc/pci_mmc.c | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/drivers/mmc/pci_mmc.c b/drivers/mmc/pci_mmc.c index cba2ea8cf3..9fb7044029 100644 --- a/drivers/mmc/pci_mmc.c +++ b/drivers/mmc/pci_mmc.c @@ -86,6 +86,7 @@ static int pci_mmc_bind(struct udevice *dev) return sdhci_bind(dev, &plat->mmc, &plat->cfg); }
+__maybe_unused static int pci_mmc_acpi_fill_ssdt(const struct udevice *dev, struct acpi_ctx *ctx) { @@ -138,7 +139,9 @@ static int pci_mmc_acpi_fill_ssdt(const struct udevice *dev, }
struct acpi_ops pci_mmc_acpi_ops = { +#ifdef CONFIG_ACPIGEN .fill_ssdt = pci_mmc_acpi_fill_ssdt, +#endif };
static const struct udevice_id pci_mmc_match[] = { -- 2.36.1
