[U-Boot] [PATCH] Fix variation in timestamps caused by timezone differences.
When building with SOURCE_DATE_EPOCH set, avoid use of mktime in default_image.c, which converts the timestamp into localtime. This causes variation based on timezone when building u-boot.img and u-boot-sunxi-with-spl.bin targets.
Signed-off-by: Vagrant Cascadian vagrant@debian.org ---
tools/default_image.c | 6 +----- 1 file changed, 1 insertion(+), 5 deletions(-)
diff --git a/tools/default_image.c b/tools/default_image.c index 18940af..3ed7014 100644 --- a/tools/default_image.c +++ b/tools/default_image.c @@ -89,7 +89,6 @@ static void image_set_header(void *ptr, struct stat *sbuf, int ifd, { uint32_t checksum; char *source_date_epoch; - struct tm *time_universal; time_t time;
image_header_t * hdr = (image_header_t *)ptr; @@ -103,13 +102,10 @@ static void image_set_header(void *ptr, struct stat *sbuf, int ifd, if (source_date_epoch != NULL) { time = (time_t) strtol(source_date_epoch, NULL, 10);
- time_universal = gmtime(&time); - if (time_universal == NULL) { + if (gmtime(&time) == NULL) { fprintf(stderr, "%s: SOURCE_DATE_EPOCH is not valid\n", __func__); time = 0; - } else { - time = mktime(time_universal); } } else { time = sbuf->st_mtime;
I have tested this with the Cubieboard2_defconfig when setting SOURCE_DATE_EPOCH and changing TZ. This corrects the problem in the way I suggested, so this is:
Tested-by: Paul Kocialkowski contact@paulk.fr Acked-by: Paul Kocialkowski contact@paulk.fr
Thanks!
} else {
} } else { time = sbuf->st_mtime;time = mktime(time_universal);
Signed-off-by: Vagrant Cascadian vagrant@debian.org Tested-by: Paul Kocialkowski contact@paulk.fr Acked-by: Paul Kocialkowski contact@paulk.fr
Paul Kocialkowski
Vagrant Cascadian
