[U-Boot] [PATCH V3] ppc4xx: Remove CANBT board
This board and especially the CPU (PPC405CR) is EOL.
Signed-off-by: Matthias Fuchs matthias.fuchs@esd.eu --- V2: add entry to doc/README.scrapyard V3: add missing commit IDs in README.scrapyard
MAINTAINERS | 1 - board/esd/canbt/Makefile | 31 -- board/esd/canbt/canbt.c | 164 --------- board/esd/canbt/canbt.h | 28 -- board/esd/canbt/flash.c | 68 ---- board/esd/canbt/fpgadata.c | 807 -------------------------------------------- boards.cfg | 1 - doc/README.scrapyard | 7 +- include/configs/CANBT.h | 215 ------------ 9 files changed, 4 insertions(+), 1318 deletions(-) delete mode 100644 board/esd/canbt/Makefile delete mode 100644 board/esd/canbt/canbt.c delete mode 100644 board/esd/canbt/canbt.h delete mode 100644 board/esd/canbt/flash.c delete mode 100644 board/esd/canbt/fpgadata.c delete mode 100644 include/configs/CANBT.h
diff --git a/MAINTAINERS b/MAINTAINERS index 081cf96..bc4b867 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -184,7 +184,6 @@ Matthias Fuchs matthias.fuchs@esd-electronics.com APC405 PPC405GP AR405 PPC405GP ASH405 PPC405EP - CANBT PPC405CR CPCI2DP PPC405GP CPCI405 PPC405GP CPCI4052 PPC405GP diff --git a/board/esd/canbt/Makefile b/board/esd/canbt/Makefile deleted file mode 100644 index e5caf23..0000000 --- a/board/esd/canbt/Makefile +++ /dev/null @@ -1,31 +0,0 @@ -# -# (C) Copyright 2000-2006 -# Wolfgang Denk, DENX Software Engineering, wd@denx.de. -# -# SPDX-License-Identifier: GPL-2.0+ -# - -include $(TOPDIR)/config.mk -ifneq ($(OBJTREE),$(SRCTREE)) -$(shell mkdir -p $(obj)../common) -endif - -LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o flash.o ../common/misc.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/board/esd/canbt/canbt.c b/board/esd/canbt/canbt.c deleted file mode 100644 index 5884975..0000000 --- a/board/esd/canbt/canbt.c +++ /dev/null @@ -1,164 +0,0 @@ -/* - * (C) Copyright 2001 - * Matthias Fuchs, esd gmbh germany, matthias.fuchs@esd-electronics.com - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include "canbt.h" -#include <asm/processor.h> -#include <asm/io.h> -#include <command.h> - -DECLARE_GLOBAL_DATA_PTR; - -/* ------------------------------------------------------------------------- */ - -#if 0 -#define FPGA_DEBUG -#endif - -/* fpga configuration data */ -const unsigned char fpgadata[] = { -#include "fpgadata.c" -}; - -/* - * include common fpga code (for esd boards) - */ -#include "../common/fpga.c" - - -int board_early_init_f (void) -{ - unsigned long CPC0_CR0Reg; - int index, len, i; - int status; - - /* - * Setup GPIO pins - */ - CPC0_CR0Reg = mfdcr (CPC0_CR0) & 0xf0001fff; - CPC0_CR0Reg |= 0x0070f000; - mtdcr (CPC0_CR0, CPC0_CR0Reg); - -#ifdef FPGA_DEBUG - /* set up serial port with default baudrate */ - (void) get_clocks (); - gd->baudrate = CONFIG_BAUDRATE; - serial_init (); - console_init_f (); -#endif - - /* - * Boot onboard FPGA - */ - status = fpga_boot ((unsigned char *) fpgadata, sizeof (fpgadata)); - if (status != 0) { - /* booting FPGA failed */ -#ifndef FPGA_DEBUG - /* set up serial port with default baudrate */ - (void) get_clocks (); - gd->baudrate = CONFIG_BAUDRATE; - serial_init (); - console_init_f (); -#endif - printf ("\nFPGA: Booting failed "); - switch (status) { - case ERROR_FPGA_PRG_INIT_LOW: - printf ("(Timeout: INIT not low after asserting PROGRAM*)\n "); - break; - case ERROR_FPGA_PRG_INIT_HIGH: - printf ("(Timeout: INIT not high after deasserting PROGRAM*)\n "); - break; - case ERROR_FPGA_PRG_DONE: - printf ("(Timeout: DONE not high after programming FPGA)\n "); - break; - } - - /* display infos on fpgaimage */ - index = 15; - for (i = 0; i < 4; i++) { - len = fpgadata[index]; - printf ("FPGA: %s\n", &(fpgadata[index + 1])); - index += len + 3; - } - putc ('\n'); - /* delayed reboot */ - for (i = 20; i > 0; i--) { - printf ("Rebooting in %2d seconds \r", i); - for (index = 0; index < 1000; index++) - udelay (1000); - } - putc ('\n'); - do_reset (NULL, 0, 0, NULL); - } - - /* - * Setup port pins for normal operation - */ - out_be32 ((void *)GPIO0_ODR, 0x00000000); /* no open drain pins */ - out_be32 ((void *)GPIO0_TCR, 0x07038100); /* setup for output */ - out_be32 ((void *)GPIO0_OR, 0x07030100); /* set output pins to high (default) */ - - /* - * IRQ 0-15 405GP internally generated; active high; level sensitive - * IRQ 16 405GP internally generated; active low; level sensitive - * IRQ 17-24 RESERVED - * IRQ 25 (EXT IRQ 0) CAN0; active low; level sensitive - * IRQ 26 (EXT IRQ 1) CAN1; active low; level sensitive - * IRQ 27 (EXT IRQ 2) PCI SLOT 0; active low; level sensitive - * IRQ 28 (EXT IRQ 3) PCI SLOT 1; active low; level sensitive - * IRQ 29 (EXT IRQ 4) PCI SLOT 2; active low; level sensitive - * IRQ 30 (EXT IRQ 5) PCI SLOT 3; active low; level sensitive - * IRQ 31 (EXT IRQ 6) COMPACT FLASH; active high; level sensitive - */ - mtdcr (UIC0SR, 0xFFFFFFFF); /* clear all ints */ - mtdcr (UIC0ER, 0x00000000); /* disable all ints */ - mtdcr (UIC0CR, 0x00000000); /* set all to be non-critical */ - mtdcr (UIC0PR, 0xFFFFFF81); /* set int polarities */ - mtdcr (UIC0TR, 0x10000000); /* set int trigger levels */ - mtdcr (UIC0VCR, 0x00000001); /* set vect base=0,INT0 highest priority */ - mtdcr (UIC0SR, 0xFFFFFFFF); /* clear all ints */ - - return 0; -} - - -/* ------------------------------------------------------------------------- */ - -/* - * Check Board Identity: - */ - -int checkboard (void) -{ - int index; - int len; - char str[64]; - int i = getenv_f("serial#", str, sizeof (str)); - - puts ("Board: "); - - if (!i || strncmp (str, "CANBT", 5)) { - puts ("### No HW ID - assuming CANBT\n"); - return (0); - } - - puts (str); - - puts ("\nFPGA: "); - - /* display infos on fpgaimage */ - index = 15; - for (i = 0; i < 4; i++) { - len = fpgadata[index]; - printf ("%s ", &(fpgadata[index + 1])); - index += len + 3; - } - - putc ('\n'); - - return 0; -} diff --git a/board/esd/canbt/canbt.h b/board/esd/canbt/canbt.h deleted file mode 100644 index 75e7950..0000000 --- a/board/esd/canbt/canbt.h +++ /dev/null @@ -1,28 +0,0 @@ -/* - * (C) Copyright 2000 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -/**************************************************************************** - * FLASH Memory Map as used by TQ Monitor: - * - * Start Address Length - * +-----------------------+ 0x4000_0000 Start of Flash ----------------- - * | MON8xx code | 0x4000_0100 Reset Vector - * +-----------------------+ 0x400?_???? - * | (unused) | - * +-----------------------+ 0x4001_FF00 - * | Ethernet Addresses | 0x78 - * +-----------------------+ 0x4001_FF78 - * | (Reserved for MON8xx) | 0x44 - * +-----------------------+ 0x4001_FFBC - * | Lock Address | 0x04 - * +-----------------------+ 0x4001_FFC0 ^ - * | Hardware Information | 0x40 | MON8xx - * +=======================+ 0x4002_0000 (sector border) ----------------- - * | Autostart Header | | Applications - * | ... | v - * - *****************************************************************************/ diff --git a/board/esd/canbt/flash.c b/board/esd/canbt/flash.c deleted file mode 100644 index 34bdc05..0000000 --- a/board/esd/canbt/flash.c +++ /dev/null @@ -1,68 +0,0 @@ -/* - * (C) Copyright 2001 - * Stefan Roese, esd gmbh germany, stefan.roese@esd-electronics.com - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <asm/ppc4xx.h> -#include <asm/processor.h> - -/* - * include common flash code (for esd boards) - */ -#include "../common/flash.c" - -/*----------------------------------------------------------------------- - * Functions - */ -static ulong flash_get_size (vu_long *addr, flash_info_t *info); -static void flash_get_offsets (ulong base, flash_info_t *info); - -/*----------------------------------------------------------------------- - */ - -unsigned long flash_init (void) -{ - unsigned long size_b0; - int i; - uint pbcr; - unsigned long base_b0; - - /* Init: no FLASHes known */ - for (i=0; i<CONFIG_SYS_MAX_FLASH_BANKS; ++i) { - flash_info[i].flash_id = FLASH_UNKNOWN; - } - - /* Static FLASH Bank configuration here - FIXME XXX */ - - size_b0 = flash_get_size((vu_long *)FLASH_BASE0_PRELIM, &flash_info[0]); - - if (flash_info[0].flash_id == FLASH_UNKNOWN) { - printf ("## Unknown FLASH on Bank 0 - Size = 0x%08lx = %ld MB\n", - size_b0, size_b0<<20); - } - - /* Setup offsets */ - flash_get_offsets (-size_b0, &flash_info[0]); - - /* Re-do sizing to get full correct info */ - mtdcr(EBC0_CFGADDR, PB0CR); - pbcr = mfdcr(EBC0_CFGDATA); - mtdcr(EBC0_CFGADDR, PB0CR); - base_b0 = -size_b0; - pbcr = (pbcr & 0x0001ffff) | base_b0 | (((size_b0/1024/1024)-1)<<17); - mtdcr(EBC0_CFGDATA, pbcr); - /* printf("PB1CR = %x\n", pbcr); */ - - /* Monitor protection ON by default */ - (void)flash_protect(FLAG_PROTECT_SET, - -monitor_flash_len, - 0xffffffff, - &flash_info[0]); - - flash_info[0].size = size_b0; - - return (size_b0); -} diff --git a/board/esd/canbt/fpgadata.c b/board/esd/canbt/fpgadata.c deleted file mode 100644 index af401cd..0000000 --- a/board/esd/canbt/fpgadata.c +++ /dev/null @@ -1,807 +0,0 @@ -0x00, 0x09, 0x0f, 0xf0, 0x0f, 0xf0, 0x0f, 0xf0, -0x0f, 0xf0, 0x00, 0x00, 0x01, 0x61, 0x00, 0x0c, -0x69, 0x6f, 0x5f, 0x63, 0x68, 0x69, 0x70, 0x2e, -0x6e, 0x63, 0x64, 0x00, 0x62, 0x00, 0x0b, 0x73, -0x30, 0x35, 0x78, 0x6c, 0x76, 0x71, 0x31, 0x30, -0x30, 0x00, 0x63, 0x00, 0x0b, 0x32, 0x30, 0x30, -0x31, 0x2f, 0x31, 0x31, 0x2f, 0x32, 0x33, 0x00, -0x64, 0x00, 0x09, 0x31, 0x33, 0x3a, 0x33, 0x34, -0x3a, 0x34, 0x33, 0x00, 0x65, 0xe2, 0x01, 0x00, -0x00, 0x18, 0xe6, 0xff, 0x30, 0xe8, 0x01, 0x01, -0x01, 0x01, 0xe7, 0xe6, 0x04, 0x01, 0x0d, 0x04, -0x07, 0x03, 0x05, 0x03, 0x05, 0x03, 0xe5, 0xe5, -0x05, 0x09, 0x04, 0x06, 0x01, 0x07, 0x09, 0x01, -0x07, 0x0b, 0x0f, 0x07, 0x03, 0x05, 0x03, 0x05, -0x03, 0x11, 0x03, 0x0f, 0x09, 0x03, 0x05, 0x10, -0xe5, 0xe6, 0x1a, 0x0a, 0x13, 0x29, 0x19, 0x05, -0x09, 0x04, 0x04, 0x09, 0x09, 0x09, 0x0b, 0x04, -0x04, 0x09, 0x09, 0x09, 0x0e, 0xe5, 0x01, 0x14, -0x09, 0x09, 0x09, 0x03, 0x05, 0x0b, 0x03, 0x05, -0x09, 0x09, 0x09, 0x09, 0x01, 0xe6, 0x7b, 0x01, -0x01, 0x02, 0x75, 0xe8, 0x3e, 0x3b, 0x02, 0x34, -0x0a, 0x09, 0x07, 0x09, 0x01, 0x11, 0x0a, 0xe5, -0xe6, 0x5c, 0x1e, 0xe6, 0xe5, 0x0a, 0xe5, 0x50, -0x1d, 0x0d, 0x31, 0x09, 0x14, 0x13, 0x07, 0x01, -0x01, 0x2a, 0x08, 0x0b, 0x1e, 0x1c, 0x01, 0xe5, -0x0f, 0x09, 0x09, 0xe5, 0x07, 0x09, 0xe6, 0x08, -0x05, 0x03, 0x01, 0x07, 0x09, 0x09, 0x0d, 0xe8, -0x0f, 0x09, 0xe5, 0x07, 0x09, 0x04, 0x05, 0x0a, -0x01, 0x07, 0x01, 0x07, 0x09, 0x09, 0x0d, 0xe5, -0xe6, 0x0c, 0xe5, 0x07, 0xe5, 0x07, 0xe5, 0x07, -0xe5, 0x03, 0x03, 0xe5, 0x06, 0xe5, 0xe6, 0x03, -0x03, 0xe5, 0x04, 0x02, 0xe5, 0x01, 0x05, 0xe5, -0x07, 0xe5, 0x01, 0x07, 0x05, 0xe7, 0x0f, 0x09, -0x09, 0x09, 0x10, 0x04, 0x05, 0x03, 0x03, 0x05, -0x09, 0x09, 0x08, 0x08, 0x04, 0x01, 0x06, 0xe5, -0x07, 0xe5, 0x07, 0xe5, 0x07, 0xe5, 0x07, 0xe5, -0x02, 0xe5, 0x04, 0xe5, 0x07, 0xe5, 0x07, 0xe5, -0x07, 0xe5, 0x02, 0x04, 0xe5, 0x07, 0x02, 0x03, -0x02, 0xe5, 0x0e, 0x09, 0x09, 0x09, 0x15, 0x09, -0x09, 0x09, 0x09, 0x0e, 0xe6, 0xe5, 0x0c, 0x09, -0x09, 0x09, 0x09, 0x04, 0x04, 0x01, 0x09, 0x06, -0x02, 0x09, 0x09, 0x11, 0xe7, 0x0c, 0x02, 0x06, -0x02, 0x04, 0x01, 0x02, 0x01, 0x01, 0x02, 0x02, -0x06, 0x02, 0x03, 0x02, 0x01, 0x02, 0x06, 0x02, -0x01, 0x04, 0x02, 0x06, 0x02, 0x03, 0x02, 0x02, -0x11, 0x03, 0x17, 0x03, 0x05, 0x12, 0x15, 0x02, -0x23, 0x08, 0x16, 0x06, 0x0c, 0x05, 0x15, 0x07, -0x01, 0x0a, 0x02, 0x0f, 0x01, 0x07, 0x02, 0xe5, -0xe5, 0x08, 0x07, 0x02, 0x07, 0x02, 0x10, 0x03, -0x11, 0x03, 0x2b, 0x05, 0xe6, 0x2b, 0x0a, 0x06, -0x01, 0x01, 0x11, 0x0b, 0x0e, 0xe5, 0x08, 0xe6, -0xe5, 0x0f, 0x09, 0x09, 0x09, 0x09, 0x0b, 0x09, -0x09, 0x01, 0x07, 0x09, 0x0e, 0x01, 0xe5, 0x0f, -0x0d, 0x22, 0xe5, 0xe5, 0x27, 0x0e, 0xe6, 0x47, -0x11, 0x17, 0x02, 0x04, 0x01, 0x01, 0x0d, 0x0d, -0x1f, 0x04, 0x01, 0x24, 0x10, 0x03, 0x01, 0x2a, -0x12, 0x0c, 0x06, 0xe5, 0x0a, 0x09, 0x11, 0xe5, -0x01, 0x1c, 0x09, 0x17, 0x0b, 0x09, 0x09, 0x04, -0x19, 0xe5, 0x0c, 0x01, 0x0d, 0x22, 0x0a, 0x01, -0x0d, 0xe5, 0x04, 0x18, 0x01, 0xe5, 0x01, 0x05, -0x04, 0x01, 0x02, 0xe5, 0x14, 0x10, 0x0b, 0x02, -0x01, 0x02, 0x02, 0xe5, 0x19, 0x0d, 0xe5, 0xe5, -0x0e, 0x09, 0x09, 0x02, 0x06, 0x09, 0x02, 0x03, -0x04, 0x03, 0x05, 0x09, 0x15, 0x0c, 0x02, 0xe5, -0x01, 0x0b, 0x04, 0x04, 0x09, 0x09, 0x02, 0x06, -0x09, 0xe5, 0x01, 0x06, 0x05, 0x03, 0x06, 0x1e, -0x02, 0x1c, 0x1d, 0x08, 0xe5, 0x05, 0x02, 0x06, -0x02, 0x03, 0xe5, 0x1b, 0x03, 0x17, 0xe5, 0x08, -0x02, 0x09, 0xe5, 0x09, 0x0f, 0xe5, 0x08, 0x07, -0x09, 0x06, 0x0b, 0x02, 0x17, 0xe5, 0x09, 0x01, -0x1f, 0x05, 0xe5, 0x02, 0x05, 0x03, 0x1f, 0xe5, -0xe6, 0x0e, 0x09, 0x03, 0x05, 0x03, 0x05, 0x09, -0x11, 0x01, 0x01, 0x04, 0x0c, 0x01, 0x0a, 0x0e, -0x01, 0xe5, 0x0c, 0xe6, 0x06, 0xe6, 0x06, 0xe6, -0x06, 0xe6, 0x02, 0x03, 0xe6, 0x03, 0x03, 0x02, -0x09, 0x06, 0xe5, 0xe5, 0x25, 0x14, 0x1a, 0x12, -0x05, 0x04, 0x02, 0x13, 0x16, 0xe7, 0xe5, 0x11, -0xe5, 0x11, 0xe5, 0x06, 0xe5, 0x14, 0xe5, 0x11, -0xe5, 0x03, 0xe5, 0x08, 0xe5, 0x06, 0x01, 0x02, -0x02, 0x02, 0x01, 0x2c, 0xe5, 0x08, 0x01, 0x1d, -0xe5, 0xe6, 0x01, 0x02, 0x01, 0x04, 0x09, 0x01, -0x02, 0xe6, 0x03, 0x04, 0xe5, 0x02, 0x01, 0x02, -0xe5, 0x02, 0x01, 0x07, 0x01, 0x07, 0x01, 0x07, -0x01, 0x02, 0xe5, 0x04, 0x01, 0x07, 0x05, 0xe5, -0x01, 0x01, 0x02, 0xe5, 0x07, 0xe5, 0x01, 0x01, -0xe5, 0x09, 0xe5, 0xe5, 0xe7, 0x01, 0x0e, 0x08, -0x03, 0xe5, 0x04, 0x02, 0x06, 0x02, 0xe5, 0x04, -0x0d, 0xe5, 0x07, 0xe5, 0x08, 0xe5, 0x07, 0x05, -0x07, 0x02, 0x01, 0x01, 0xe8, 0xe5, 0x10, 0x01, -0x05, 0x0c, 0x10, 0xe5, 0x01, 0x06, 0xe5, 0x08, -0x08, 0xe6, 0x01, 0x02, 0x05, 0xe5, 0x04, 0xe5, -0x01, 0x06, 0xe5, 0x01, 0xe5, 0x01, 0x10, 0x02, -0x05, 0xe5, 0x01, 0x06, 0x02, 0x06, 0x02, 0x05, -0x03, 0x07, 0xe5, 0x01, 0x05, 0xe5, 0x01, 0x05, -0x04, 0x03, 0x03, 0xe5, 0x04, 0x08, 0xe6, 0xe5, -0xe6, 0x01, 0x0b, 0x05, 0x03, 0x09, 0x09, 0x09, -0x06, 0x04, 0x05, 0x01, 0x01, 0x09, 0x05, 0x0a, -0x01, 0x01, 0x02, 0x08, 0x02, 0xe5, 0xe6, 0x01, -0x11, 0xe5, 0x31, 0x14, 0x10, 0x0a, 0x02, 0xe8, -0x0c, 0x03, 0xe6, 0x02, 0x03, 0x05, 0x03, 0x05, -0x03, 0x02, 0x02, 0x03, 0x02, 0x04, 0x03, 0x01, -0x03, 0x03, 0x05, 0x0d, 0xe5, 0x06, 0x0b, 0x01, -0x01, 0x11, 0x0c, 0x01, 0x04, 0x02, 0x01, 0x04, -0x02, 0x09, 0x0b, 0x01, 0x07, 0x01, 0x07, 0x09, -0x13, 0xe6, 0xe6, 0x0a, 0x02, 0x06, 0x02, 0x03, -0x02, 0x02, 0x04, 0xe6, 0x01, 0x05, 0xe5, 0x01, -0x03, 0x07, 0x03, 0x02, 0x02, 0x05, 0xe5, 0x01, -0x03, 0x02, 0x02, 0x03, 0xe5, 0xe5, 0x01, 0x06, -0x04, 0x01, 0x01, 0xe5, 0xe5, 0x01, 0x08, 0xe5, -0x07, 0xe5, 0x07, 0xe5, 0x08, 0x08, 0xe5, 0x08, -0x0a, 0xe5, 0x05, 0x09, 0x02, 0x09, 0x05, 0xe5, -0x01, 0x07, 0xe5, 0xe6, 0x08, 0x05, 0x03, 0x05, -0x03, 0x05, 0x05, 0x03, 0x03, 0x05, 0x03, 0x07, -0x03, 0x05, 0x09, 0x03, 0x0a, 0x08, 0x0d, 0xe5, -0x5e, 0x06, 0x07, 0x0b, 0xe8, 0x10, 0x01, 0x07, -0x09, 0x01, 0x07, 0x01, 0x07, 0x0b, 0x09, 0x09, -0x08, 0x03, 0x06, 0x0c, 0xe8, 0x09, 0x54, 0x01, -0x0d, 0x02, 0x07, 0x01, 0x01, 0x15, 0xe5, 0x05, -0xe7, 0x05, 0xe7, 0x07, 0xe5, 0x06, 0xe6, 0x08, -0xe6, 0x05, 0xe7, 0x06, 0xe7, 0xe5, 0x02, 0xe7, -0x05, 0xe7, 0x0a, 0x10, 0xe5, 0x07, 0x09, 0x33, -0x06, 0x0b, 0x0f, 0xe7, 0x19, 0x05, 0x03, 0x02, -0x02, 0x13, 0x0b, 0x09, 0x03, 0x05, 0x06, 0x02, -0xe5, 0x07, 0x08, 0x02, 0xe5, 0x1b, 0xe6, 0x07, -0xe5, 0x11, 0xe5, 0x01, 0x07, 0xe5, 0x06, 0xe6, -0x07, 0xe5, 0xe5, 0xe5, 0x03, 0xe5, 0x02, 0x03, -0xe6, 0x0a, 0xe5, 0x02, 0x0e, 0x09, 0xe5, 0xe6, -0x04, 0xe8, 0x04, 0x09, 0xe5, 0xe6, 0x06, 0xe5, -0xe6, 0x04, 0xe5, 0xe6, 0x04, 0xe5, 0xe7, 0xe6, -0x01, 0x01, 0xe6, 0x03, 0xe8, 0x06, 0x01, 0x01, -0x0e, 0x01, 0x03, 0x03, 0x01, 0x07, 0x01, 0x07, -0x01, 0xe5, 0x05, 0x01, 0x09, 0x01, 0x07, 0x01, -0x07, 0x01, 0x01, 0x08, 0x08, 0x01, 0x0a, 0xe9, -0x10, 0x01, 0x01, 0x05, 0x01, 0xe5, 0x05, 0x01, -0xe6, 0x04, 0x01, 0xe6, 0x04, 0x01, 0x01, 0x02, -0x03, 0xe5, 0xe5, 0xe5, 0x03, 0xe5, 0xe5, 0x06, -0x01, 0x02, 0x04, 0x01, 0x07, 0x01, 0xe5, 0x08, -0x01, 0xe6, 0x0e, 0xe5, 0x02, 0x0e, 0xe5, 0x07, -0xe5, 0x07, 0xe5, 0xe5, 0x0d, 0x09, 0xe5, 0x06, -0x04, 0xe5, 0x05, 0x01, 0xe5, 0x0c, 0xe6, 0xe6, -0x1e, 0x07, 0x15, 0x07, 0x09, 0xe5, 0x0d, 0xe5, -0xe5, 0xe5, 0x01, 0x01, 0x09, 0x04, 0xe6, 0xe6, -0x04, 0x02, 0x04, 0x01, 0x02, 0x09, 0x04, 0x01, -0x02, 0x04, 0x01, 0x07, 0x01, 0x04, 0x02, 0x08, -0x0b, 0x06, 0x0e, 0x10, 0xe5, 0xe6, 0x0b, 0x01, -0x07, 0x01, 0x03, 0xe5, 0x01, 0x01, 0x07, 0x01, -0x07, 0x01, 0x02, 0x05, 0x09, 0x17, 0x04, 0x03, -0x03, 0x09, 0xe7, 0xe5, 0x0d, 0x01, 0x07, 0x01, -0x07, 0x01, 0x04, 0x02, 0x01, 0x07, 0x01, 0x04, -0x01, 0x0a, 0x07, 0x06, 0x01, 0x02, 0x0a, 0x13, -0xe6, 0x0d, 0x03, 0x05, 0x09, 0x03, 0x05, 0x09, -0x03, 0x03, 0x03, 0x02, 0x05, 0xe5, 0x02, 0x04, -0xe5, 0x07, 0xe5, 0x01, 0x03, 0x02, 0x0d, 0x01, -0x02, 0x0d, 0x02, 0x02, 0x03, 0x09, 0x02, 0x06, -0x04, 0x04, 0x02, 0xe5, 0x04, 0x01, 0x05, 0x03, -0x01, 0xe5, 0x05, 0x01, 0x07, 0x01, 0x08, 0x0c, -0x06, 0x06, 0x02, 0x05, 0xe6, 0x06, 0xe6, 0x06, -0xe5, 0x07, 0xe5, 0x07, 0xe5, 0xe5, 0x03, 0xe5, -0x01, 0xe5, 0xe5, 0xe5, 0x06, 0x09, 0x01, 0xe5, -0x17, 0x03, 0x01, 0xe6, 0x09, 0x02, 0xe5, 0x07, -0xe5, 0x07, 0xe5, 0x07, 0xe5, 0x07, 0xe5, 0x07, -0x01, 0xe6, 0x07, 0x11, 0xe5, 0xe5, 0x09, 0x02, -0x0e, 0x0b, 0x04, 0x01, 0x03, 0x03, 0x09, 0x01, -0x07, 0x04, 0x04, 0x02, 0xe5, 0xe6, 0x03, 0x07, -0x18, 0xe5, 0x13, 0xe5, 0xe6, 0x0c, 0xe5, 0x03, -0x03, 0xe5, 0x07, 0xe5, 0x02, 0x04, 0xe5, 0x07, -0xe5, 0x0a, 0x03, 0xe5, 0x01, 0x01, 0x07, 0x01, -0xe5, 0x03, 0xe5, 0x09, 0x01, 0x0a, 0x02, 0x03, -0xe5, 0x0c, 0xe6, 0x06, 0xe6, 0x01, 0x04, 0xe6, -0x06, 0xe7, 0xe5, 0x03, 0xe6, 0x01, 0x05, 0x02, -0x09, 0x05, 0x03, 0x07, 0x01, 0x02, 0x06, 0x0a, -0x03, 0xe5, 0xe6, 0xe5, 0x06, 0x1c, 0x1a, 0xe5, -0x02, 0x05, 0x0a, 0x12, 0x02, 0x0c, 0xe5, 0x01, -0x01, 0x1b, 0xe5, 0x04, 0x03, 0x01, 0x06, 0xe5, -0x10, 0xe5, 0x01, 0xe5, 0x03, 0xe5, 0x12, 0xe5, -0x06, 0xe5, 0x07, 0x01, 0x03, 0xe9, 0xe5, 0x17, -0xe5, 0x08, 0xe5, 0x06, 0xe5, 0x08, 0xe5, 0x09, -0xe5, 0x17, 0x03, 0x01, 0x0e, 0x01, 0x01, 0x02, -0x02, 0x01, 0x04, 0xe5, 0x02, 0x04, 0xe5, 0x02, -0x09, 0x09, 0x09, 0x04, 0xe5, 0x04, 0x01, 0xe5, -0x05, 0x01, 0xe5, 0x05, 0x01, 0x08, 0xe5, 0x01, -0xe5, 0x05, 0xe5, 0x07, 0xe5, 0x01, 0x01, 0xe5, -0x01, 0x1b, 0x09, 0xe5, 0x07, 0x14, 0xe5, 0x05, -0x01, 0xe5, 0x04, 0x02, 0xe5, 0x01, 0x06, 0x0d, -0x02, 0x01, 0xe5, 0x02, 0xe5, 0xe5, 0x06, 0x01, -0x05, 0xe5, 0x01, 0x05, 0x02, 0x10, 0xe5, 0xe6, -0x04, 0x01, 0x01, 0x06, 0x01, 0x02, 0x0f, 0xe5, -0x01, 0xe5, 0x02, 0xe5, 0x01, 0x08, 0x01, 0x06, -0xe5, 0xe7, 0x01, 0x06, 0x02, 0x05, 0x01, 0x01, -0x05, 0x03, 0x07, 0x01, 0x05, 0x01, 0x01, 0x05, -0x0d, 0x01, 0x0f, 0x04, 0x04, 0x08, 0x01, 0x02, -0x04, 0xe6, 0x01, 0xe6, 0x01, 0x0b, 0x09, 0x06, -0x02, 0x09, 0x09, 0x0b, 0x05, 0x03, 0x09, 0x0a, -0x02, 0x06, 0x08, 0x02, 0x02, 0xe6, 0xe5, 0x12, -0xe5, 0x11, 0xe5, 0x1d, 0xe6, 0x14, 0x04, 0xe6, -0x01, 0x0f, 0x03, 0xe6, 0x07, 0x05, 0x03, 0x02, -0x02, 0x03, 0x05, 0x03, 0xe5, 0x03, 0x03, 0x02, -0x02, 0x03, 0x02, 0x04, 0x03, 0xe5, 0x03, 0x03, -0x05, 0x03, 0x08, 0xe5, 0x01, 0x12, 0xe5, 0xe5, -0xe5, 0x07, 0x01, 0x07, 0xe5, 0x07, 0x01, 0x04, -0x16, 0x08, 0x02, 0xe5, 0x04, 0x02, 0x01, 0x07, -0x01, 0x07, 0xe5, 0x07, 0x09, 0xe5, 0x01, 0xe5, -0x09, 0xe5, 0x01, 0x06, 0x02, 0x03, 0x02, 0x02, -0x06, 0x02, 0x06, 0x02, 0x03, 0x07, 0x06, 0x02, -0x03, 0x05, 0x03, 0xe5, 0xe5, 0x01, 0x04, 0x01, -0x02, 0x05, 0xe5, 0x05, 0x01, 0xe5, 0xe5, 0x0a, -0xe5, 0x07, 0xe5, 0x07, 0xe5, 0x07, 0x09, 0xe5, -0x08, 0x0a, 0xe5, 0x08, 0x09, 0x05, 0x03, 0x06, -0x02, 0x07, 0xe8, 0x08, 0x05, 0x03, 0x05, 0x03, -0x05, 0x09, 0x03, 0x05, 0x05, 0x05, 0x03, 0x05, -0x03, 0x05, 0x04, 0x09, 0x0a, 0x08, 0xe5, 0xe6, -0x5b, 0x07, 0x17, 0xe6, 0x01, 0x0e, 0x09, 0x09, -0x01, 0x07, 0x09, 0x0b, 0x01, 0x07, 0x01, 0x07, -0x05, 0x03, 0x04, 0xe5, 0x01, 0x0e, 0xe5, 0xe6, -0x1c, 0x1c, 0xe5, 0x1e, 0x04, 0x09, 0x0e, 0x01, -0xe6, 0x08, 0x0b, 0xe5, 0x05, 0x01, 0xe5, 0x05, -0x01, 0xe5, 0x07, 0xe5, 0x05, 0x01, 0xe5, 0x07, -0xe7, 0x05, 0xe7, 0x05, 0x01, 0xe6, 0x04, 0x01, -0xe6, 0x04, 0xe7, 0x06, 0x02, 0xe5, 0xe5, 0x0d, -0xe5, 0x07, 0x29, 0x09, 0x09, 0x08, 0x09, 0x0e, -0x03, 0x20, 0x09, 0x13, 0x05, 0x05, 0x03, 0x05, -0x09, 0x09, 0xe5, 0x07, 0x09, 0xe6, 0x19, 0x02, -0x01, 0x07, 0x01, 0x11, 0x01, 0x02, 0x06, 0xe6, -0x06, 0xe6, 0x03, 0x02, 0x01, 0x07, 0x01, 0x03, -0x03, 0xe6, 0x07, 0xe5, 0xe6, 0x11, 0x09, 0xe8, -0x04, 0x01, 0xe6, 0x04, 0x09, 0xe8, 0x06, 0xe5, -0xe6, 0x04, 0xe5, 0xe6, 0x04, 0xe8, 0x04, 0xe9, -0x04, 0x01, 0xe5, 0x06, 0x03, 0xe5, 0x0b, 0xe5, -0xe5, 0x05, 0xe5, 0xe5, 0x05, 0xe5, 0xe5, 0x05, -0xe5, 0xe5, 0x05, 0xe5, 0xe5, 0x07, 0xe5, 0xe5, -0x05, 0xe5, 0xe6, 0x04, 0x02, 0x06, 0x02, 0x01, -0x14, 0xe9, 0x05, 0x0a, 0x01, 0xe5, 0x05, 0x01, -0xe5, 0x05, 0x01, 0xe6, 0x04, 0x01, 0x01, 0x05, -0x01, 0xe6, 0x01, 0x04, 0x01, 0x01, 0x05, 0x01, -0xe6, 0x01, 0x02, 0x01, 0x01, 0x05, 0x01, 0x01, -0x05, 0x01, 0x02, 0x07, 0xe8, 0x02, 0x05, 0x04, -0x07, 0x01, 0xe5, 0x07, 0x03, 0x02, 0x02, 0x09, -0x04, 0x01, 0x04, 0x04, 0xe5, 0x02, 0xe6, 0x02, -0x02, 0x02, 0x03, 0x02, 0xe5, 0x01, 0x1a, 0xe5, -0x1a, 0x02, 0x06, 0x0a, 0x02, 0x16, 0x08, 0xe5, -0x06, 0x04, 0x02, 0x02, 0x0d, 0xe5, 0xe5, 0x01, -0xe6, 0x12, 0x04, 0x1b, 0x04, 0x05, 0x0a, 0x02, -0x02, 0x07, 0x0b, 0x15, 0xe5, 0x01, 0xe5, 0x0b, -0xe6, 0x03, 0x02, 0xe6, 0x03, 0x02, 0xe6, 0x03, -0x02, 0xe7, 0x05, 0xe6, 0x02, 0x08, 0x09, 0x06, -0xe6, 0x01, 0x02, 0x03, 0x09, 0xe5, 0x01, 0x09, -0x04, 0x09, 0x03, 0x09, 0x09, 0x09, 0x09, 0x03, -0x03, 0x01, 0xe5, 0x07, 0x0b, 0x19, 0x0c, 0xe7, -0x08, 0x08, 0x06, 0xe6, 0x0c, 0x01, 0xe6, 0x04, -0x0a, 0xe5, 0x05, 0xe5, 0x03, 0x02, 0x0a, 0x03, -0x05, 0x03, 0x05, 0x09, 0x04, 0x10, 0x13, 0x06, -0x02, 0x09, 0x02, 0x03, 0x04, 0x04, 0x04, 0x09, -0x0f, 0x12, 0x02, 0x01, 0x04, 0x15, 0x02, 0x08, -0x02, 0x04, 0x0e, 0x08, 0x05, 0x28, 0x04, 0x01, -0x03, 0x19, 0x20, 0xe6, 0x08, 0x06, 0x10, 0x19, -0x01, 0x06, 0x01, 0x1d, 0x15, 0x02, 0x0a, 0x08, -0x06, 0x01, 0xe6, 0x06, 0x07, 0x0b, 0x02, 0xe7, -0xe5, 0x05, 0x09, 0x01, 0x11, 0x04, 0xe5, 0x02, -0x04, 0xe5, 0x04, 0x01, 0x08, 0x07, 0x08, 0xe5, -0x05, 0x16, 0x01, 0x02, 0x19, 0x10, 0x01, 0x0a, -0x08, 0x0d, 0x0a, 0x0b, 0x0a, 0x09, 0x01, 0x01, -0x19, 0x0e, 0x07, 0x04, 0xe5, 0x1a, 0x28, 0x02, -0x01, 0x26, 0xe5, 0x04, 0x11, 0x02, 0xe5, 0x01, -0xe5, 0xe5, 0x08, 0x02, 0xe5, 0x07, 0xe5, 0x13, -0x01, 0xe5, 0xe9, 0xe5, 0x1b, 0xe5, 0x12, 0xe5, -0x03, 0x01, 0x02, 0x03, 0x01, 0xe5, 0x01, 0xe6, -0x03, 0x01, 0xe5, 0x0c, 0x11, 0x01, 0x01, 0xe5, -0xe5, 0xe5, 0x01, 0x01, 0x12, 0x01, 0x09, 0x02, -0x01, 0xe5, 0xe5, 0xe7, 0x01, 0xe5, 0x03, 0x08, -0x06, 0x01, 0xe5, 0x01, 0x01, 0x04, 0x03, 0x16, -0x01, 0x02, 0x01, 0xe5, 0xe6, 0x01, 0x02, 0x11, -0xe5, 0xe5, 0xe5, 0x06, 0x06, 0xe5, 0xe5, 0xe5, -0x02, 0xe5, 0x05, 0x07, 0x0b, 0x07, 0x19, 0xe5, -0x05, 0x02, 0xe6, 0xe6, 0xe5, 0x01, 0x03, 0x02, -0x16, 0x09, 0x01, 0x01, 0x02, 0x02, 0x09, 0x09, -0x01, 0x01, 0xe5, 0x03, 0x23, 0xe5, 0x01, 0xe5, -0x01, 0x06, 0x02, 0x0e, 0x05, 0x03, 0x0c, 0x01, -0x02, 0x01, 0x07, 0x03, 0x05, 0x01, 0x01, 0x05, -0x03, 0x1d, 0xe5, 0x02, 0x01, 0x02, 0x14, 0x01, -0x09, 0x07, 0x04, 0x01, 0x0e, 0x04, 0x04, 0x03, -0xe5, 0xe5, 0xe6, 0x03, 0x19, 0x02, 0x02, 0x03, -0x17, 0x01, 0x07, 0x09, 0x04, 0x01, 0xe5, 0x0c, -0x09, 0x01, 0x04, 0x01, 0xe5, 0x25, 0x01, 0xe5, -0x03, 0x03, 0x26, 0xe5, 0xe5, 0x05, 0x0c, 0x08, -0x0a, 0xe5, 0x1b, 0x02, 0xe6, 0x09, 0x01, 0x22, -0x02, 0x01, 0x13, 0x01, 0x04, 0x02, 0xe5, 0x11, -0xe5, 0x12, 0xe5, 0xe6, 0x07, 0x05, 0x09, 0x09, -0x09, 0x03, 0x05, 0x0b, 0x03, 0x05, 0x09, 0x09, -0x09, 0x06, 0x06, 0x03, 0xe5, 0x29, 0x05, 0x03, -0x05, 0x0f, 0x05, 0x20, 0x0b, 0xe5, 0x27, 0x09, -0x14, 0x07, 0x2b, 0xe7, 0x15, 0x02, 0x16, 0x10, -0x01, 0x04, 0x02, 0x09, 0x01, 0x07, 0x01, 0x18, -0x03, 0x19, 0xe5, 0x0c, 0x02, 0x01, 0x01, 0x01, -0x06, 0xe5, 0x03, 0x02, 0x01, 0xe5, 0x07, 0xe6, -0x04, 0x01, 0xe5, 0x04, 0xe5, 0xe6, 0x16, 0x03, -0xe5, 0x17, 0x22, 0x0b, 0x02, 0x2e, 0xe5, 0x01, -0x15, 0xe5, 0x01, 0x03, 0xe5, 0xe5, 0x05, 0x02, -0xe5, 0xe5, 0x04, 0xe5, 0x07, 0x0a, 0xe7, 0xe5, -0x04, 0xe5, 0x06, 0xe6, 0x07, 0xe5, 0x07, 0xe5, -0x06, 0x03, 0x04, 0x14, 0x03, 0x23, 0x01, 0x04, -0x0c, 0x01, 0xe6, 0x04, 0x01, 0x1b, 0xe5, 0x18, -0x06, 0x09, 0xe5, 0xe5, 0x0f, 0x02, 0x01, 0x06, -0x09, 0xe5, 0xe5, 0x05, 0xe5, 0xe5, 0x18, 0x02, -0x19, 0x04, 0xe6, 0x05, 0x01, 0xe5, 0x09, 0x0a, -0x09, 0x09, 0x07, 0x01, 0x1b, 0x01, 0x01, 0x19, -0x04, 0x08, 0xe5, 0x01, 0x04, 0x09, 0x01, 0x07, -0x0b, 0x01, 0x05, 0x21, 0x01, 0x01, 0xe5, 0x0f, -0x19, 0xe5, 0xe5, 0x11, 0x01, 0xe6, 0x04, 0x01, -0xe5, 0xe5, 0x03, 0xe5, 0xe5, 0xe5, 0x1d, 0x01, -0xe7, 0x05, 0x0a, 0x01, 0x02, 0x04, 0x01, 0x07, -0x01, 0xe5, 0x02, 0x01, 0xe5, 0xe6, 0xe5, 0x03, -0x01, 0x01, 0x02, 0x01, 0x02, 0x01, 0xe5, 0x01, -0x03, 0x01, 0x07, 0x01, 0x01, 0x05, 0x01, 0x07, -0x01, 0x0b, 0x01, 0xe5, 0x08, 0x20, 0x09, 0x02, -0xe6, 0xe6, 0x05, 0x03, 0x0e, 0x0a, 0xe5, 0x01, -0x16, 0xe7, 0x1d, 0x08, 0x07, 0x04, 0x01, 0x03, -0x02, 0x05, 0x02, 0x06, 0x05, 0x0b, 0x07, 0x07, -0x08, 0xe5, 0x01, 0xe5, 0x11, 0x16, 0x0f, 0xe5, -0x03, 0xe5, 0xe5, 0x01, 0x04, 0x03, 0x04, 0x05, -0x06, 0x19, 0xe6, 0xe7, 0x05, 0xe5, 0x05, 0x09, -0x03, 0x09, 0x04, 0x02, 0x01, 0x02, 0x01, 0x10, -0x02, 0x01, 0x04, 0x01, 0x03, 0x20, 0x02, 0xe6, -0x10, 0x18, 0xe5, 0x03, 0x04, 0x01, 0x05, 0x01, -0x09, 0x04, 0x14, 0x16, 0xe5, 0x01, 0xe5, 0x12, -0x0b, 0x04, 0x07, 0x0e, 0x02, 0xe5, 0x02, 0x06, -0x05, 0x26, 0xe6, 0xe7, 0x12, 0xe5, 0x04, 0x0f, -0x03, 0x0b, 0x04, 0x0e, 0x0f, 0x03, 0x18, 0x01, -0xe5, 0x1a, 0xe5, 0x10, 0x05, 0x0a, 0x11, 0x14, -0x14, 0xe5, 0xe5, 0x16, 0xe6, 0x02, 0x02, 0xe7, -0x02, 0x03, 0xe6, 0x06, 0xe6, 0xe6, 0x03, 0xe5, -0x08, 0xe7, 0xe5, 0x29, 0x03, 0x02, 0x10, 0x06, -0x03, 0x05, 0x03, 0x01, 0x02, 0x0a, 0x03, 0x02, -0x07, 0xe5, 0x04, 0x0a, 0x20, 0x01, 0x01, 0xe5, -0x14, 0x17, 0x02, 0xe5, 0x19, 0x01, 0xe5, 0xe5, -0xe5, 0x02, 0x03, 0x06, 0x0d, 0x07, 0xe6, 0x01, -0x2e, 0x03, 0x02, 0x01, 0x03, 0x02, 0x01, 0x0b, -0xe5, 0x09, 0x01, 0x1f, 0x01, 0xe6, 0x12, 0x0c, -0x0e, 0x17, 0x05, 0x0d, 0x09, 0x14, 0x02, 0xe5, -0xe5, 0x01, 0x0b, 0xe5, 0xe6, 0x05, 0x02, 0xe5, -0x10, 0xe5, 0x01, 0x0e, 0xe8, 0x05, 0xe5, 0xe6, -0xe5, 0x01, 0xe5, 0x1d, 0x02, 0x01, 0xe5, 0x01, -0x0e, 0x01, 0xe5, 0x04, 0x03, 0x01, 0x0c, 0x03, -0xe5, 0x01, 0x0b, 0xe5, 0x01, 0x01, 0xe5, 0x05, -0xe5, 0x03, 0x03, 0x1b, 0x01, 0x01, 0xe5, 0xe5, -0xe5, 0x03, 0x15, 0x12, 0x07, 0x0b, 0x01, 0x04, -0xe5, 0x03, 0x06, 0x1a, 0x01, 0x02, 0x01, 0xe5, -0xe6, 0xe7, 0xe5, 0x16, 0x10, 0x01, 0x07, 0x05, -0xe5, 0x03, 0x01, 0x04, 0xe5, 0xe5, 0x01, 0x06, -0x1a, 0xe5, 0x04, 0x02, 0x01, 0x01, 0xe5, 0xe5, -0x18, 0x09, 0x04, 0x04, 0x04, 0x04, 0x08, 0x0c, -0x04, 0x23, 0xe6, 0xe7, 0xe5, 0x01, 0x25, 0x04, -0x04, 0x03, 0x07, 0x03, 0x01, 0x02, 0x04, 0x04, -0xe5, 0x02, 0x1d, 0xe5, 0xe6, 0x01, 0x02, 0x18, -0x02, 0x06, 0x02, 0x02, 0x01, 0x04, 0x02, 0x06, -0x01, 0x02, 0x01, 0x03, 0xe5, 0x08, 0xe7, 0x20, -0x06, 0xe5, 0x1a, 0x01, 0xe5, 0x05, 0xe7, 0xe5, -0x03, 0x01, 0xe7, 0x02, 0xe7, 0x03, 0x01, 0x04, -0x02, 0x03, 0xe5, 0xe5, 0x01, 0x25, 0x01, 0xe5, -0x04, 0x14, 0x01, 0xe5, 0xe6, 0x02, 0x01, 0x09, -0x07, 0x01, 0x0c, 0x01, 0xe5, 0x02, 0x01, 0x02, -0x25, 0x01, 0x02, 0x01, 0x18, 0xe5, 0x07, 0xe5, -0x11, 0xe5, 0x13, 0xe5, 0x01, 0x27, 0x02, 0xe6, -0x0d, 0x09, 0xe6, 0x06, 0xe6, 0x06, 0x09, 0xe5, -0x04, 0x04, 0x09, 0xe5, 0x01, 0x05, 0x02, 0x01, -0x01, 0x02, 0x09, 0x0d, 0xe9, 0x01, 0x19, 0x09, -0x09, 0x09, 0xe5, 0x01, 0x11, 0x2a, 0x02, 0x39, -0x01, 0x13, 0x2b, 0x02, 0x17, 0x01, 0xe7, 0x06, -0x01, 0x09, 0x06, 0xe7, 0x02, 0x02, 0x01, 0x04, -0x05, 0xe6, 0xe5, 0xe6, 0xe5, 0x08, 0x18, 0xe8, -0x16, 0x01, 0xe6, 0x08, 0x09, 0x04, 0x02, 0xe6, -0x01, 0x04, 0x01, 0xe5, 0x04, 0x02, 0xe6, 0x04, -0x01, 0xe5, 0x05, 0x02, 0x17, 0xe8, 0x15, 0x04, -0x0c, 0x0e, 0x09, 0x01, 0x04, 0x04, 0x01, 0x05, -0x01, 0x06, 0x02, 0x18, 0xe6, 0xe5, 0x14, 0xe5, -0x05, 0xe6, 0x06, 0xe6, 0x08, 0xe5, 0x01, 0xe5, -0x02, 0xe5, 0x02, 0x01, 0x04, 0xe5, 0x02, 0x04, -0xe5, 0xe5, 0xe5, 0x03, 0xe5, 0xe5, 0x06, 0xe5, -0x07, 0xe5, 0x0a, 0x17, 0x01, 0xe5, 0x03, 0x09, -0x01, 0x01, 0x09, 0xe5, 0x07, 0x01, 0xe6, 0x06, -0xe5, 0x11, 0x18, 0xe5, 0x01, 0x17, 0x01, 0x03, -0x02, 0x06, 0x02, 0xe5, 0xe5, 0x08, 0x06, 0x02, -0x01, 0x06, 0x02, 0xe5, 0x04, 0x09, 0xe5, 0x19, -0xe8, 0x19, 0x03, 0xe5, 0x07, 0xe5, 0xe5, 0xe5, -0x08, 0xe5, 0x02, 0x03, 0x02, 0x04, 0x04, 0x04, -0x09, 0x04, 0x17, 0xe9, 0x1b, 0xe5, 0x07, 0xe5, -0x02, 0x01, 0x02, 0x06, 0x02, 0x06, 0x02, 0x03, -0x04, 0x02, 0x07, 0x03, 0x02, 0x1a, 0xe9, 0x09, -0x09, 0x09, 0x08, 0x05, 0xe5, 0x07, 0x0c, 0x05, -0x02, 0x06, 0x24, 0x03, 0x0b, 0x05, 0x01, 0x06, -0xe5, 0xe5, 0x06, 0xe6, 0xe5, 0x04, 0x01, 0xe5, -0x05, 0x01, 0x04, 0x04, 0xe7, 0x01, 0x03, 0x01, -0xe6, 0x04, 0x01, 0x07, 0x01, 0xe5, 0xe5, 0x03, -0x01, 0x0a, 0xe8, 0x0e, 0xe5, 0x09, 0x07, 0xe5, -0x05, 0x08, 0xe5, 0xe5, 0x02, 0x08, 0xe6, 0xe5, -0xe6, 0xe6, 0x01, 0x04, 0xe5, 0x0c, 0x0a, 0x06, -0x02, 0x01, 0xe7, 0x13, 0x07, 0xe5, 0x01, 0x01, -0x06, 0x0c, 0xe5, 0x03, 0x03, 0x03, 0x05, 0x12, -0x1a, 0x01, 0x02, 0x0d, 0x01, 0x03, 0x09, 0x02, -0x04, 0x01, 0xe5, 0xe5, 0x08, 0x09, 0xe5, 0x05, -0x03, 0x01, 0x07, 0x01, 0x0d, 0x0f, 0xe5, 0x03, -0x03, 0x03, 0xe5, 0x18, 0x0e, 0x12, 0xe7, 0x06, -0x01, 0x09, 0x03, 0x19, 0x05, 0x02, 0xe5, 0x06, -0x09, 0x09, 0xe5, 0x07, 0x02, 0x01, 0x05, 0x01, -0x0b, 0x01, 0x07, 0x03, 0x01, 0x03, 0x01, 0x0f, -0x10, 0x02, 0xe5, 0xe8, 0x08, 0x01, 0x06, 0x12, -0x06, 0x09, 0x03, 0xe5, 0x01, 0x03, 0x03, 0x03, -0xe6, 0x08, 0x06, 0x10, 0x01, 0x07, 0xe5, 0xe8, -0xe5, 0x0c, 0x0f, 0x0b, 0x02, 0xe5, 0x04, 0x04, -0x03, 0xe5, 0x02, 0x03, 0x02, 0x02, 0x01, 0x04, -0x06, 0x0b, 0x10, 0x01, 0xe5, 0xe5, 0x11, 0x01, -0x06, 0x14, 0x08, 0x02, 0x01, 0xe5, 0x03, 0xe5, -0xe5, 0x01, 0x02, 0x04, 0x02, 0x02, 0x01, 0x1f, -0x03, 0xe5, 0x0a, 0x09, 0x09, 0xe7, 0x02, 0x0d, -0xe6, 0x06, 0xe6, 0x03, 0x05, 0x04, 0x27, 0xe7, -0xe5, 0xe5, 0x06, 0x1a, 0x03, 0x0e, 0x07, 0x01, -0x0a, 0x23, 0x0b, 0xe7, 0xe6, 0x11, 0x02, 0x0a, -0xe5, 0xe5, 0x01, 0x02, 0x01, 0x07, 0x03, 0xe5, -0x05, 0x0d, 0x02, 0x02, 0x05, 0x1b, 0x02, 0x01, -0x03, 0x0f, 0x09, 0xe5, 0x06, 0x05, 0xe5, 0xe7, -0x01, 0x01, 0xe6, 0xe5, 0x04, 0xe7, 0x05, 0x02, -0xe5, 0x06, 0xe5, 0x04, 0x1d, 0x02, 0x17, 0x0d, -0x06, 0x02, 0x06, 0x16, 0x09, 0x24, 0x01, 0x01, -0x11, 0xe5, 0x08, 0x01, 0x0d, 0xe5, 0x04, 0x02, -0xe5, 0x0b, 0x08, 0x05, 0x02, 0xe6, 0x06, 0xe5, -0x13, 0x01, 0xe6, 0xe5, 0x01, 0x01, 0x0e, 0xe5, -0x08, 0xe5, 0xe6, 0x03, 0xe5, 0x0f, 0x15, 0x06, -0xe6, 0x09, 0x11, 0x01, 0x01, 0x02, 0xe6, 0x03, -0x15, 0x08, 0xe5, 0x09, 0x05, 0x06, 0x01, 0x04, -0x11, 0x01, 0x02, 0x15, 0x01, 0x02, 0x01, 0xe5, -0xe6, 0x01, 0x02, 0x17, 0x06, 0x03, 0x01, 0xe5, -0x12, 0x1a, 0x18, 0xe5, 0x04, 0x03, 0xe5, 0xe6, -0xe5, 0x18, 0x06, 0x02, 0x03, 0xe5, 0x08, 0x01, -0x05, 0x03, 0x04, 0x01, 0x01, 0x06, 0x02, 0xe5, -0xe6, 0x02, 0x01, 0x1a, 0xe5, 0xe5, 0xe5, 0x01, -0x1e, 0x03, 0x02, 0xe6, 0x01, 0x01, 0x01, 0x02, -0xe5, 0xe5, 0xe5, 0x06, 0x04, 0x04, 0x08, 0xe5, -0xe6, 0x01, 0x02, 0x15, 0x02, 0xe5, 0x03, 0xe5, -0x01, 0x18, 0x07, 0x04, 0x01, 0x0a, 0x01, 0x09, -0x01, 0x02, 0x01, 0x01, 0x08, 0x01, 0x01, 0x0c, -0x12, 0x02, 0xe8, 0x1b, 0xe6, 0x01, 0x03, 0xe5, -0xe5, 0x0b, 0x01, 0x09, 0x04, 0x01, 0x01, 0xe5, -0x08, 0x01, 0xe5, 0x22, 0x01, 0xe5, 0x07, 0x10, -0x01, 0xe5, 0x01, 0x03, 0x01, 0x02, 0x07, 0x02, -0x06, 0xe5, 0x08, 0xe5, 0x01, 0x06, 0xe5, 0x07, -0x09, 0x02, 0x10, 0x04, 0x0a, 0x01, 0x0d, 0xe5, -0x01, 0x05, 0xe5, 0x15, 0x0b, 0xe5, 0x04, 0x02, -0xe5, 0x07, 0xe6, 0x1a, 0x01, 0xe8, 0x06, 0x05, -0x09, 0xe6, 0xe5, 0x04, 0xe5, 0x02, 0x01, 0x02, -0x02, 0x06, 0x02, 0xe5, 0x01, 0x04, 0x09, 0x09, -0xe5, 0x02, 0x01, 0x02, 0x09, 0x0d, 0x01, 0x02, -0x02, 0x19, 0x03, 0x04, 0xe5, 0x02, 0x09, 0x08, -0xe5, 0x06, 0x09, 0x03, 0x09, 0x1f, 0x1f, 0x05, -0x03, 0x09, 0x09, 0x13, 0x09, 0x1e, 0x01, 0x01, -0x17, 0x01, 0xe5, 0xe5, 0x05, 0xe7, 0x02, 0x02, -0x07, 0x01, 0x04, 0x09, 0x01, 0x01, 0xe5, 0x03, -0x04, 0x02, 0x08, 0x07, 0x01, 0x0e, 0xe5, 0xe6, -0x15, 0xe5, 0xe7, 0x01, 0x02, 0x02, 0xe5, 0x01, -0x02, 0x01, 0xe5, 0x05, 0x01, 0xe5, 0x09, 0x01, -0x05, 0x02, 0xe5, 0xe5, 0x01, 0xe5, 0xe6, 0x05, -0x02, 0x06, 0x01, 0xe5, 0x0c, 0x01, 0x01, 0x08, -0x0b, 0x02, 0x0b, 0xe5, 0x05, 0x01, 0x09, 0x04, -0x06, 0x07, 0x09, 0x09, 0x09, 0x01, 0x10, 0x01, -0x15, 0xe6, 0x04, 0xe8, 0x04, 0xe8, 0xe5, 0x04, -0xe6, 0xe5, 0x03, 0xe5, 0x0a, 0x01, 0x07, 0x01, -0x01, 0x05, 0x03, 0x05, 0xe6, 0xe5, 0x04, 0xe5, -0x06, 0xe5, 0x01, 0x1a, 0x08, 0x09, 0xe5, 0x05, -0x01, 0xe5, 0x09, 0x07, 0x01, 0x07, 0x0b, 0x1b, -0xe5, 0x19, 0x02, 0x02, 0xe5, 0x05, 0x01, 0xe5, -0xe5, 0x06, 0x01, 0xe5, 0x02, 0x01, 0x0b, 0xe5, -0xe5, 0x05, 0xe5, 0xe5, 0x05, 0xe5, 0x19, 0x01, -0x01, 0xe5, 0x15, 0x06, 0xe5, 0x02, 0x03, 0x01, -0x01, 0x01, 0xe5, 0x07, 0x08, 0x02, 0x07, 0x09, -0x09, 0x1b, 0xe7, 0x16, 0x04, 0xe5, 0xe7, 0x03, -0x01, 0xe7, 0xe6, 0x05, 0x01, 0xe5, 0x02, 0x09, -0x01, 0x02, 0x04, 0x04, 0x0b, 0x1a, 0x01, 0xe5, -0x34, 0x01, 0x03, 0x04, 0x01, 0xe6, 0x01, 0xe5, -0x03, 0xe5, 0x02, 0x01, 0x23, 0x01, 0x01, 0xe5, -0x10, 0x01, 0x07, 0x01, 0xe5, 0x05, 0x01, 0x06, -0xe5, 0xe6, 0x05, 0x01, 0x04, 0xe5, 0x02, 0x01, -0x07, 0x01, 0x02, 0xe5, 0x02, 0x01, 0xe5, 0xe5, -0x03, 0x01, 0xe6, 0x04, 0x01, 0x0a, 0x03, 0x16, -0x02, 0xe5, 0x07, 0x06, 0x02, 0xe5, 0x04, 0x02, -0xe5, 0x02, 0x08, 0x01, 0x03, 0x01, 0xe5, 0x08, -0x02, 0x05, 0xe5, 0x01, 0x0a, 0x09, 0x01, 0x01, -0xe5, 0x15, 0x01, 0x05, 0x0c, 0x09, 0xe5, 0xe5, -0x01, 0x03, 0x06, 0x02, 0xe5, 0xe5, 0x02, 0xe5, -0x01, 0x03, 0x01, 0x03, 0x08, 0x09, 0x06, 0xe5, -0xe7, 0x04, 0x1d, 0x01, 0x07, 0x0a, 0xe5, 0x03, -0xe5, 0x05, 0x03, 0x05, 0xe5, 0x01, 0x0c, 0x18, -0xe9, 0x17, 0x05, 0x0a, 0x05, 0x09, 0x06, 0x06, -0x04, 0x07, 0xe6, 0xe5, 0x0e, 0x0b, 0x05, 0xe5, -0xe5, 0x15, 0xe5, 0x07, 0x0e, 0x01, 0x01, 0x0b, -0x04, 0xe5, 0x02, 0x01, 0x05, 0xe6, 0xe5, 0x15, -0x09, 0x02, 0x03, 0xe7, 0x17, 0x12, 0x0d, 0x03, -0x0a, 0x09, 0x01, 0xe5, 0x02, 0x01, 0x1b, 0x01, -0xe5, 0xe5, 0x11, 0x0d, 0x0a, 0xe6, 0x05, 0xe5, -0x02, 0x05, 0xe5, 0x09, 0x01, 0x03, 0x06, 0x04, -0x1b, 0x01, 0xe5, 0xe5, 0x1a, 0x0a, 0x0b, 0x01, -0xe5, 0x05, 0x02, 0xe5, 0x04, 0xe6, 0x08, 0x09, -0x14, 0x08, 0xe5, 0x01, 0x06, 0x11, 0x0c, 0x01, -0x11, 0x04, 0xe5, 0x09, 0x05, 0x08, 0x1f, 0xe5, -0xe7, 0x0a, 0x06, 0x03, 0x02, 0x06, 0x1e, 0x09, -0x07, 0x0c, 0x04, 0x09, 0x0d, 0x02, 0xe5, 0x01, -0x06, 0x09, 0x05, 0x03, 0x04, 0x06, 0x02, 0x10, -0x06, 0x08, 0x03, 0x02, 0x01, 0x01, 0x07, 0x12, -0x04, 0x04, 0x03, 0x18, 0x0d, 0x02, 0x0d, 0x04, -0x05, 0x02, 0x03, 0x03, 0x05, 0x03, 0x05, 0x11, -0x09, 0xe5, 0xe5, 0x1e, 0x05, 0x03, 0x01, 0x17, -0x06, 0x09, 0x05, 0x02, 0xe5, 0x12, 0x07, 0x01, -0x03, 0x06, 0x23, 0x06, 0x04, 0x0b, 0x10, 0x01, -0x08, 0x11, 0x02, 0x02, 0xe5, 0xe6, 0x07, 0x07, -0x14, 0x08, 0x06, 0x18, 0x09, 0x09, 0x09, 0x0e, -0x02, 0xe6, 0x0a, 0x09, 0x09, 0x02, 0xe5, 0x1d, -0xe5, 0x01, 0x01, 0x04, 0xe5, 0x24, 0xe6, 0xe9, -0x01, 0x01, 0x08, 0x09, 0xe6, 0x06, 0xe6, 0xe5, -0x1e, 0x02, 0x01, 0xe5, 0x2a, 0x01, 0x01, 0xe5, -0xe5, 0x03, 0x08, 0x06, 0x01, 0x0a, 0x2c, 0xe5, -0x26, 0x02, 0xe5, 0xe6, 0x01, 0x0a, 0x06, 0xe5, -0x02, 0x04, 0x02, 0x01, 0x27, 0x06, 0xe5, 0x02, -0x1c, 0x02, 0x01, 0xe6, 0xe6, 0x0c, 0x09, 0x01, -0x02, 0x02, 0x01, 0x01, 0x03, 0x02, 0xe5, 0xe5, -0x06, 0x01, 0x15, 0x01, 0xe5, 0xe5, 0xe5, 0x05, -0x02, 0x19, 0xe6, 0xe7, 0x01, 0x0a, 0x03, 0x05, -0x01, 0x02, 0x01, 0x01, 0xe5, 0xe5, 0xe5, 0x03, -0xe5, 0xe5, 0xe5, 0x04, 0x01, 0x01, 0x16, 0x08, -0x02, 0x01, 0x15, 0x02, 0x01, 0xe5, 0x02, 0xe5, -0x03, 0xe5, 0x05, 0x0e, 0x04, 0x01, 0x03, 0xe6, -0xe5, 0xe5, 0x06, 0x01, 0x15, 0x02, 0x0b, 0x1a, -0x02, 0xe5, 0xe6, 0x05, 0x06, 0x0b, 0x07, 0x05, -0xe5, 0x01, 0x01, 0x07, 0x01, 0x18, 0xe6, 0x07, -0xe6, 0x18, 0x01, 0xe6, 0xe6, 0x12, 0x08, 0x0a, -0x02, 0x25, 0x14, 0xe5, 0x0c, 0x02, 0x03, 0x02, -0x0a, 0x09, 0x01, 0x11, 0xe5, 0x31, 0x09, 0xe5, -0x12, 0x02, 0xe5, 0x09, 0x03, 0x05, 0xe5, 0x01, -0x06, 0x02, 0x02, 0x06, 0x09, 0x0b, 0x09, 0x04, -0x01, 0x02, 0x03, 0x05, 0x09, 0x0d, 0xe9, 0x01, -0x12, 0x09, 0xe5, 0x2e, 0x03, 0x26, 0xe5, 0xe5, -0x1e, 0x31, 0x2b, 0xe5, 0xe5, 0x0a, 0x01, 0x09, -0x04, 0x02, 0x06, 0x1f, 0x07, 0x01, 0x0e, 0x1a, -0x01, 0x0d, 0x01, 0xe5, 0x04, 0xe5, 0x01, 0xe5, -0x07, 0x05, 0x03, 0x19, 0x06, 0x07, 0xe5, 0x04, -0x02, 0xe5, 0x17, 0x02, 0x0c, 0x0c, 0x06, 0x3e, -0x1a, 0x01, 0x01, 0x13, 0xe5, 0xe6, 0x04, 0xe6, -0x06, 0xe6, 0x06, 0xe6, 0x08, 0xe5, 0x09, 0xe5, -0x07, 0xe5, 0x07, 0xe6, 0x06, 0xe5, 0x07, 0xe5, -0x06, 0x01, 0xe6, 0x13, 0x05, 0x04, 0x04, 0xe5, -0x02, 0x01, 0x02, 0x03, 0xe5, 0x18, 0x0a, 0xe5, -0x04, 0x1a, 0xe5, 0xe6, 0x15, 0x07, 0x01, 0x09, -0xe5, 0x07, 0x18, 0x11, 0x1b, 0xe5, 0xe5, 0x12, -0x01, 0xe5, 0x02, 0x02, 0x01, 0x07, 0xe6, 0xe5, -0x01, 0x02, 0x01, 0x0c, 0x0c, 0x13, 0x18, 0x01, -0xe6, 0x12, 0x06, 0x01, 0xe6, 0x04, 0x03, 0x02, -0x02, 0x02, 0x1b, 0x02, 0x07, 0x08, 0x18, 0xe5, -0x01, 0x0d, 0xe5, 0xe5, 0x05, 0x01, 0xe5, 0x02, -0x02, 0x03, 0x0a, 0x02, 0x17, 0x02, 0x03, 0x05, -0x0e, 0x11, 0x02, 0x01, 0x0a, 0x06, 0x01, 0xe5, -0x01, 0x03, 0x01, 0x04, 0x02, 0x01, 0x07, 0x01, -0x01, 0x05, 0x01, 0x02, 0x01, 0x04, 0x01, 0x01, -0x05, 0x01, 0x07, 0x01, 0x02, 0x04, 0xe6, 0x06, -0x01, 0x0b, 0x02, 0x09, 0x04, 0x0a, 0x09, 0xe5, -0x01, 0x05, 0xe5, 0x13, 0xe5, 0x01, 0x03, 0xe5, -0x01, 0x05, 0x05, 0x1e, 0x01, 0x01, 0xe5, 0xe5, -0x01, 0x0b, 0x04, 0x05, 0x04, 0x01, 0x05, 0x03, -0x12, 0xe5, 0xe5, 0x0b, 0x01, 0x06, 0x01, 0x1d, -0x02, 0x01, 0x0b, 0x0d, 0x11, 0x0e, 0x04, 0x09, -0x30, 0x03, 0xe5, 0x03, 0x02, 0x04, 0x01, 0x02, -0x01, 0xe5, 0xe7, 0x04, 0x01, 0x01, 0x07, 0x01, -0x0a, 0x0b, 0x08, 0x09, 0xe5, 0x05, 0x01, 0xe5, -0x11, 0x05, 0x02, 0x02, 0x02, 0x09, 0x03, 0x04, -0x0a, 0x0a, 0x02, 0x01, 0x07, 0x03, 0x11, 0x01, -0x01, 0x05, 0x05, 0x0d, 0x06, 0x02, 0xe5, 0xe5, -0xe6, 0x0b, 0x08, 0x06, 0xe8, 0xe5, 0x03, 0xe5, -0xe5, 0xe5, 0x10, 0x04, 0x04, 0x01, 0x0a, 0xe5, -0x01, 0x04, 0xe6, 0x16, 0x02, 0x01, 0x05, 0x0a, -0x06, 0x02, 0x02, 0x04, 0x01, 0x15, 0x04, 0x05, -0x04, 0x0a, 0x01, 0x21, 0x03, 0xe5, 0x05, 0x12, -0x04, 0x07, 0x07, 0x10, 0x12, 0x27, 0xe8, 0x02, -0x08, 0x0f, 0x16, 0x08, 0x02, 0x0a, 0x05, 0x03, -0x07, 0x1c, 0xe6, 0xe6, 0xe5, 0x11, 0x1a, 0x01, -0x02, 0x08, 0x01, 0x06, 0x1c, 0x16, 0xe5, 0xe6, -0x08, 0xe5, 0x07, 0x0c, 0x02, 0xe5, 0x07, 0x09, -0x10, 0x08, 0x05, 0xe5, 0x03, 0x01, 0x01, 0x17, -0x01, 0xe7, 0x18, 0x08, 0xe5, 0x02, 0x05, 0x08, -0xe5, 0x07, 0x16, 0x05, 0xe5, 0x01, 0x01, 0x18, -0xe6, 0x18, 0x08, 0x08, 0xe5, 0x09, 0x17, 0x01, -0x03, 0xe5, 0x08, 0x16, 0x03, 0x02, 0x03, 0x09, -0x09, 0x13, 0x04, 0x20, 0xe5, 0x01, 0x02, 0x06, -0x17, 0xe5, 0x01, 0x01, 0xe6, 0x0b, 0x0b, 0x02, -0x0b, 0x01, 0xe7, 0x22, 0xe5, 0x02, 0x09, 0x14, -0x01, 0x01, 0x03, 0xe5, 0x0c, 0x05, 0xe5, 0x0e, -0x02, 0xe5, 0x04, 0x22, 0xe5, 0x03, 0x07, 0x0f, -0xe5, 0x03, 0x01, 0x04, 0x01, 0xe5, 0xe5, 0x01, -0x07, 0x19, 0xe5, 0x01, 0x01, 0xe5, 0x22, 0x04, -0x04, 0xe5, 0xe5, 0x0e, 0xe5, 0x05, 0x02, 0x01, -0x01, 0xe5, 0x0b, 0x12, 0xe5, 0x02, 0x05, 0x01, -0x02, 0xe5, 0x01, 0x1e, 0x01, 0x02, 0x1f, 0xeb, -0xe5, 0x09, 0x03, 0x09, 0x01, 0x01, 0xe6, 0x08, -0x01, 0x04, 0x01, 0x20, 0x02, 0x06, 0x01, 0x01, -0x01, 0x02, 0x0e, 0x05, 0xe6, 0x0b, 0x13, 0x09, -0x01, 0x27, 0x01, 0x04, 0x04, 0x15, 0x04, 0xe7, -0x0b, 0x13, 0x06, 0x01, 0xe5, 0xe5, 0xe5, 0x2b, -0xe5, 0x02, 0x1a, 0xe6, 0x1c, 0x02, 0x05, 0xe5, -0x07, 0xe5, 0x01, 0x06, 0x1c, 0x02, 0x01, 0xe5, -0x05, 0x02, 0x0b, 0x04, 0xe5, 0x02, 0x0a, 0x13, -0x06, 0x02, 0x01, 0x05, 0x01, 0x0b, 0x1d, 0x1d, -0x01, 0xe7, 0x09, 0x03, 0x02, 0x06, 0x02, 0x02, -0x03, 0x03, 0x05, 0xe5, 0xe5, 0xe7, 0x01, 0x0b, -0x09, 0x04, 0x01, 0x02, 0x02, 0x01, 0xe6, 0x01, -0x02, 0x06, 0x0d, 0x01, 0xe7, 0x15, 0x09, 0x05, -0x03, 0x09, 0x1f, 0x09, 0x1b, 0xe8, 0x14, 0x09, -0x08, 0x08, 0x20, 0x08, 0x1e, 0xe5, 0x01, 0x16, -0xe5, 0xe5, 0x06, 0x01, 0x06, 0xe5, 0x07, 0x20, -0x01, 0xe6, 0x04, 0x01, 0x19, 0x01, 0xe5, 0x01, -0x14, 0x01, 0xe5, 0x05, 0x01, 0x01, 0x01, 0x06, -0xe5, 0x07, 0x1c, 0x08, 0xe5, 0x01, 0x17, 0xe6, -0xe6, 0x15, 0x01, 0x04, 0x40, 0x01, 0x18, 0xe8, -0x14, 0xe5, 0x01, 0x05, 0xe5, 0x07, 0xe5, 0x07, -0xe5, 0x07, 0xe5, 0x09, 0xe5, 0x07, 0xe6, 0x01, -0x04, 0xe6, 0xe5, 0x04, 0xe5, 0x07, 0xe5, 0x06, -0x02, 0xe5, 0x16, 0x01, 0x07, 0x01, 0x57, 0xe7, -0x03, 0x12, 0x01, 0x07, 0x01, 0x13, 0x1f, 0x07, -0x1c, 0xe6, 0x16, 0x01, 0x26, 0x14, 0x01, 0x07, -0x1c, 0x01, 0x04, 0x12, 0x01, 0x07, 0x04, 0x09, -0x26, 0x07, 0x15, 0x01, 0x04, 0xe6, 0x0c, 0x01, -0xe5, 0x09, 0x05, 0xe5, 0xe5, 0x13, 0x1b, 0x06, -0x02, 0x10, 0x04, 0x03, 0xe6, 0xe6, 0x02, 0xe5, -0x06, 0x01, 0x02, 0x01, 0xe5, 0x05, 0x01, 0x04, -0x02, 0xe6, 0x06, 0x01, 0x01, 0x05, 0x01, 0x04, -0x04, 0x01, 0x02, 0x04, 0x01, 0x04, 0x02, 0x01, -0x01, 0x02, 0x02, 0x01, 0x07, 0x01, 0x01, 0x04, -0x05, 0xe6, 0x02, 0x12, 0x0e, 0x07, 0x03, 0x0c, -0x08, 0x0c, 0x06, 0x1e, 0x01, 0xe7, 0x1d, 0x08, -0x01, 0x0e, 0x24, 0x13, 0x06, 0xe5, 0xe5, 0xe5, -0x14, 0x09, 0xe5, 0x07, 0xe5, 0x01, 0x01, 0x0a, -0x02, 0x01, 0x05, 0x34, 0xe9, 0xe5, 0x01, 0x02, -0x0e, 0x01, 0x07, 0x01, 0xe5, 0x05, 0xe7, 0x01, -0xe5, 0x01, 0x0f, 0x0f, 0x09, 0x15, 0x07, 0xe5, -0x16, 0x01, 0x0a, 0x03, 0x03, 0x06, 0x03, 0x02, -0x04, 0x13, 0x03, 0x09, 0x03, 0x10, 0x02, 0x01, -0xe5, 0xe6, 0x18, 0x06, 0x0b, 0xe6, 0x07, 0x06, -0x06, 0x07, 0x0e, 0x1b, 0xe9, 0x0f, 0x05, 0x04, -0x08, 0x06, 0xe5, 0x04, 0x05, 0x02, 0x03, 0x14, -0x04, 0x03, 0x1b, 0x01, 0x02, 0x11, 0x0a, 0xe5, -0x07, 0x06, 0x11, 0xe5, 0x39, 0x02, 0x0d, 0xe5, -0x0b, 0x03, 0x0c, 0x10, 0x01, 0x39, 0x01, 0xe5, -0xe5, 0x0c, 0x02, 0x05, 0x04, 0x10, 0x05, 0xe5, -0x0a, 0x3a, 0xe5, 0xe6, 0x01, 0x16, 0x0d, 0x02, -0x06, 0x05, 0xe5, 0x06, 0xe5, 0xe5, 0x0e, 0x25, -0xe5, 0x01, 0xe5, 0x1b, 0x09, 0xe5, 0x04, 0x08, -0xe5, 0x07, 0x02, 0x19, 0x11, 0x0b, 0x02, 0x17, -0x15, 0x06, 0x02, 0x0a, 0x3a, 0xe7, 0x11, 0xe5, -0x04, 0x0f, 0x4b, 0xe5, 0x02, 0xe6, 0x01, 0x01, -0x0e, 0xe5, 0x05, 0x0f, 0xe6, 0x11, 0x34, 0x01, -0x01, 0x03, 0xe5, 0x03, 0x05, 0x01, 0xe5, 0xe5, -0x03, 0xe5, 0xe5, 0xe6, 0x0f, 0x01, 0x04, 0x01, -0xe5, 0x01, 0x03, 0xe5, 0x02, 0x04, 0x28, 0xe5, -0x03, 0x01, 0x03, 0x02, 0x02, 0x07, 0x02, 0x01, -0x04, 0xe5, 0xe5, 0xe6, 0x0c, 0xe5, 0xe5, 0xe5, -0x03, 0xe5, 0x02, 0x04, 0x32, 0xe5, 0x05, 0x02, -0x01, 0x01, 0x0b, 0x01, 0x01, 0x02, 0x04, 0x21, -0xe5, 0x01, 0xe5, 0xe5, 0x05, 0x02, 0x2d, 0xe7, -0xe6, 0x01, 0x0a, 0x01, 0x02, 0x04, 0x13, 0x01, -0x01, 0x01, 0x02, 0x05, 0x02, 0xe5, 0x05, 0x2e, -0x02, 0x03, 0x01, 0xe6, 0x17, 0x11, 0x01, 0x07, -0x07, 0x03, 0x35, 0x02, 0xe8, 0x11, 0x06, 0x11, -0x01, 0x09, 0x03, 0xe5, 0x3d, 0x01, 0xe5, 0x11, -0x09, 0x14, 0x02, 0x05, 0x3e, 0xe7, 0xe5, 0x1a, -0xe5, 0x1e, 0x3d, 0xe5, 0x01, 0xe5, 0x0a, 0x02, -0x09, 0x09, 0x09, 0x06, 0x02, 0x03, 0x02, 0x04, -0x09, 0x09, 0x09, 0x09, 0x0d, 0xe9, 0x01, 0x08, -0xe5, 0x04, 0x09, 0x14, 0x02, 0x05, 0x02, 0xe5, -0x3a, 0xe5, 0xe6, 0x0a, 0x26, 0x08, 0x40, 0xe6, -0x0c, 0x04, 0x04, 0x01, 0x02, 0x15, 0x0b, 0x04, -0x36, 0xe8, 0x0e, 0x01, 0x02, 0x02, 0x01, 0xe6, -0xe5, 0x0f, 0x0a, 0x09, 0xe5, 0x35, 0xe8, 0x08, -0x02, 0x09, 0x01, 0x10, 0x07, 0x08, 0x07, 0x2e, -0x08, 0xe7, 0x0e, 0x05, 0xe6, 0xe5, 0x04, 0xe5, -0x07, 0xe5, 0x07, 0xe5, 0x07, 0xe5, 0x09, 0xe5, -0x07, 0xe5, 0x07, 0xe5, 0x07, 0xe5, 0x07, 0xe5, -0x09, 0xe5, 0x0c, 0x09, 0x01, 0x14, 0x14, 0x36, -0x02, 0xe5, 0x0e, 0x07, 0x16, 0x4d, 0x01, 0xe5, -0x0b, 0x09, 0x01, 0x11, 0x0b, 0x01, 0x06, 0x02, -0x36, 0xe5, 0xe6, 0x02, 0x0b, 0x02, 0x04, 0x04, -0x0e, 0x02, 0x11, 0x39, 0xe5, 0x01, 0x2b, 0x15, -0x01, 0xe5, 0x20, 0x12, 0xe5, 0xe7, 0x10, 0x01, -0x02, 0x03, 0xe5, 0xe5, 0x06, 0x01, 0x02, 0x04, -0x01, 0x07, 0x01, 0x05, 0x03, 0x01, 0x07, 0x01, -0x07, 0x01, 0x07, 0x01, 0x07, 0x01, 0x0b, 0xe5, -0xe5, 0x18, 0x12, 0x02, 0x09, 0x21, 0x01, 0x1c, -0xe6, 0xe6, 0x13, 0x1c, 0x0b, 0x01, 0x13, 0x24, -0xe5, 0x01, 0xe5, 0x18, 0x14, 0x10, 0x3b, 0x02, -0x17, 0x01, 0x0e, 0x02, 0x01, 0x07, 0xe5, 0x09, -0x01, 0x16, 0x1a, 0x05, 0x02, 0x17, 0x01, 0x13, -0x0d, 0x03, 0x04, 0x03, 0x10, 0x1c, 0x02, 0x02, -0xe6, 0x19, 0x09, 0x06, 0x05, 0x0f, 0x37, 0x01, -0xe7, 0x25, 0x04, 0x01, 0x11, 0x08, 0x10, 0x1f, -0x02, 0x01, 0x26, 0x08, 0x0f, 0x06, 0x33, 0x01, -0x01, 0x0a, 0x10, 0x0f, 0x13, 0x07, 0x31, 0x02, -0xe6, 0x11, 0x16, 0x01, 0x03, 0x0f, 0x3b, 0x02, -0x14, 0x01, 0x16, 0xe5, 0x0c, 0x28, 0x13, 0x04, -0xe5, 0x2b, 0x0a, 0x36, 0x0a, 0x01, 0x01, 0x2b, -0xe5, 0x0d, 0x3e, 0xe8, 0xe5, 0x75, 0xe5, 0x03, -0x02, 0x01, 0x28, 0x47, 0x01, 0x02, 0xe6, 0xe5, -0x03, 0x23, 0x01, 0x4a, 0x04, 0xe5, 0x01, 0x02, -0x74, 0x02, 0xe6, 0xe6, 0x04, 0x05, 0x21, 0x01, -0x01, 0x01, 0x45, 0x01, 0xe6, 0x01, 0x08, 0x25, -0x02, 0x3f, 0x02, 0x05, 0xe6, 0x72, 0x04, 0xe5, -0xe5, 0xe5, 0x01, 0x2c, 0x4a, 0x03, 0xe6, 0x2d, -0x43, 0x06, 0x01, 0xe5, 0x7a, 0xe8, 0x0d, 0x09, -0x09, 0x09, 0x09, 0x0b, 0x09, 0x09, 0x09, 0x09, -0x0d, 0x03, 0xe5, 0x01, 0x27, 0x4c, 0x06, 0x29, -0x52, 0x01, 0x2d, 0xe5, 0x48, 0x03, 0x01, 0x16, -0x03, 0x14, 0x4a, 0xe6, 0xe5, 0x2c, 0x03, 0x4a, -0xe6, 0x03, 0x10, 0xe5, 0x07, 0xe5, 0x07, 0xe5, -0x07, 0xe5, 0x07, 0xe5, 0x09, 0xe5, 0x07, 0xe5, -0x07, 0xe5, 0x07, 0xe5, 0x07, 0xe5, 0x06, 0x02, -0xe5, 0x16, 0x01, 0x13, 0x4c, 0x03, 0x17, 0x01, -0x63, 0xe6, 0x15, 0x01, 0x13, 0x12, 0x39, 0x03, -0x03, 0x13, 0x01, 0x16, 0x49, 0xe5, 0xe6, 0x2a, -0x01, 0xe5, 0x49, 0x02, 0xe6, 0x10, 0x01, 0x01, -0x05, 0x01, 0x02, 0x03, 0xe5, 0xe5, 0x02, 0x03, -0x01, 0x01, 0x05, 0x01, 0x01, 0x02, 0x03, 0xe5, -0xe5, 0x06, 0x01, 0x07, 0x01, 0x07, 0x01, 0x07, -0x01, 0x0a, 0xe5, 0x01, 0x5b, 0x22, 0xe5, 0x09, -0x34, 0x07, 0x09, 0x0b, 0x1a, 0x02, 0x01, 0x3f, -0x3a, 0xe6, 0xe5, 0x16, 0x10, 0x17, 0x07, 0x2b, -0x08, 0xe5, 0x19, 0x16, 0x09, 0x03, 0x3b, 0xe7, -0x23, 0x1a, 0x04, 0xe5, 0x33, 0x01, 0xe6, 0x1b, -0x22, 0x0a, 0x0d, 0x23, 0x01, 0x3f, 0x3c, 0xe6, -0x20, 0xe6, 0x15, 0x04, 0x2a, 0x09, 0x06, 0xe5, -0xe5, 0x23, 0x1a, 0xe5, 0x28, 0x0f, 0x02, 0xe5, -0x38, 0x41, 0xe5, 0xe6, 0xe5, 0x24, 0x04, 0x1a, -0x30, 0x01, 0xe5, 0xe5, 0x2c, 0x4c, 0xe5, 0x01, -0xe6, 0x75, 0xe8, 0xe5, 0x01, 0x01, 0x70, 0x01, -0x03, 0xe5, 0xe5, 0x03, 0x70, 0x04, 0xe5, 0x01, -0x02, 0x74, 0x02, 0x01, 0xe6, 0x01, 0x78, 0x02, -0x74, 0x02, 0x02, 0xe8, 0x13, 0x5f, 0x04, 0x03, -0xe5, 0x13, 0xe5, 0x63, 0x01, 0xe6, 0x08, 0x02, -0x08, 0x64, 0xe5, 0x01, 0x0a, 0xe5, 0x6e, 0xe5, -0xe6, 0x0d, 0x09, 0x09, 0x09, 0x09, 0x0b, 0x09, -0x09, 0x09, 0x09, 0x0d, 0xe9, 0x01, 0x74, 0x06, -0x7a, 0x03, 0x01, 0x2b, 0x4d, 0xe5, 0xe5, 0x23, -0x08, 0xe5, 0x47, 0x02, 0xe8, 0x2c, 0x4b, 0xe5, -0x01, 0xe5, 0x12, 0x01, 0x07, 0xe6, 0x07, 0xe5, -0x02, 0x03, 0x01, 0x09, 0xe5, 0x09, 0xe5, 0x07, -0xe5, 0x07, 0xe5, 0x07, 0xe5, 0x07, 0xe5, 0x06, -0x01, 0xe6, 0x0f, 0xe5, 0x02, 0x09, 0x01, 0x01, -0xe5, 0x03, 0x03, 0x03, 0x01, 0x38, 0x0b, 0x01, -0x01, 0x01, 0x13, 0x02, 0x09, 0xe5, 0xe6, 0x02, -0x01, 0x02, 0x06, 0x37, 0x0d, 0x01, 0x01, 0x15, -0x07, 0xe6, 0xe5, 0xe5, 0x04, 0x03, 0x05, 0x47, -0xe5, 0xe5, 0x0f, 0x02, 0xe5, 0x07, 0xe5, 0x01, -0x01, 0xe5, 0x01, 0xe5, 0x03, 0x03, 0xe5, 0x38, -0x0e, 0x01, 0xe5, 0x2e, 0x33, 0x15, 0xe5, 0xe5, -0xe5, 0x10, 0x01, 0x07, 0x01, 0x07, 0x01, 0xe5, -0xe5, 0x03, 0x01, 0xe5, 0xe5, 0x02, 0xe5, 0xe6, -0x07, 0x01, 0xe5, 0x05, 0x01, 0xe6, 0x04, 0xe7, -0x05, 0x01, 0x07, 0x01, 0x0b, 0xe7, 0x3d, 0x15, -0x21, 0x03, 0x03, 0xe5, 0x3e, 0x38, 0xe5, 0xe5, -0xe5, 0x12, 0x02, 0x09, 0x1e, 0x07, 0x32, 0x03, -0xe5, 0x19, 0x05, 0x01, 0x0a, 0x09, 0x06, 0x3a, -0xe5, 0x01, 0x23, 0x03, 0x17, 0x3a, 0x03, 0xe5, -0x1f, 0x1d, 0x16, 0xe5, 0x24, 0xe5, 0x1e, 0x09, -0x12, 0x02, 0x15, 0x01, 0x23, 0xe7, 0x3e, 0x23, -0x17, 0x01, 0xe5, 0x3e, 0x3c, 0xe6, 0x24, 0x19, -0x3d, 0xe6, 0x1b, 0xe5, 0x04, 0x02, 0xe5, 0x08, -0x38, 0x12, 0x33, 0x36, 0xe6, 0x0b, 0x01, 0xe5, -0xe5, 0x6a, 0x10, 0xe6, 0x02, 0x0b, 0xe5, 0xe5, -0x05, 0xe5, 0x07, 0xe5, 0x07, 0xe6, 0x06, 0xe5, -0x07, 0xe7, 0x07, 0xe5, 0x07, 0xe5, 0x07, 0xe5, -0x07, 0xe5, 0x0b, 0x03, 0xe5, 0x0f, 0x09, 0x09, -0x09, 0x09, 0x04, 0x04, 0x01, 0x09, 0x09, 0x09, -0x01, 0x07, 0x0d, 0xe5, 0xe6, 0x0e, 0x09, 0x03, -0x05, 0x09, 0x09, 0x04, 0x06, 0x04, 0x04, 0x04, -0x04, 0x04, 0x04, 0x09, 0x0e, 0x03, 0x26, 0x57, -0x0f, 0x09, 0x09, 0x09, 0x09, 0x0b, 0x01, 0x07, -0x09, 0x09, 0x02, 0x06, 0x0e, 0xe5, 0xe6, 0x0c, -0xe5, 0x07, 0xe5, 0x07, 0xe5, 0x07, 0xe5, 0x07, -0xe5, 0x09, 0xe5, 0x07, 0xe5, 0x07, 0xe5, 0x07, -0xe5, 0x07, 0xe5, 0x0e, 0x03, 0x03, 0x09, 0x09, -0x09, 0x09, 0x09, 0x0b, 0x09, 0x09, 0x09, 0x09, -0x12, 0xe6, 0x0d, 0xe5, 0xe5, 0x05, 0xe5, 0xe5, -0x05, 0xe5, 0xe5, 0x05, 0xe5, 0xe5, 0x05, 0xe5, -0xe5, 0x07, 0xe5, 0xe5, 0x05, 0xe5, 0xe5, 0x05, -0xe5, 0xe5, 0x05, 0xe5, 0xe5, 0x05, 0xe5, 0xe5, -0x0b, 0x03, 0x0e, 0x09, 0x09, 0x09, 0x09, 0x03, -0x07, 0x09, 0x09, 0x09, 0x09, 0x0f, 0x02, 0xe5, -0x79, 0xe5, 0x01, 0x0e, 0x09, 0x09, 0x09, 0x09, -0x08, 0x02, 0x09, 0x09, 0x09, 0x09, 0x11, 0xe6, -0x3e, 0x3b, 0x02, 0x10, 0x09, 0x09, 0x09, 0x09, -0x0b, 0x09, 0x09, 0x09, 0x09, 0x10, 0xe5, 0x7d, -0x3f, 0x3a, 0xe5, 0x01, 0x3f, 0x36, 0x04, 0x02, -0x7a, 0x01, 0x01, 0x13, 0x3d, 0x28, 0x01, 0x01, -0x3f, 0x33, 0x0a, 0x3f, 0x34, 0x08, 0xe5, 0x79, -0x01, 0x01, 0x14, 0x09, 0x09, 0x09, 0x09, 0x0b, -0x09, 0x09, 0x09, 0x09, 0x09, 0xe5, 0x01, 0x0f, -0x09, 0x09, 0x09, 0x09, 0x07, 0x03, 0x09, 0x09, -0x09, 0x08, 0xe5, 0x0d, 0x03, 0x3a, 0x04, 0x3a, -0x02, 0xe5, 0x0c, 0x09, 0x03, 0x05, 0x09, 0x09, -0x03, 0x07, 0x09, 0x09, 0x07, 0x01, 0x1b, 0x01, -0xe5, 0x0a, 0x02, 0x07, 0x05, 0x03, 0x01, 0x03, -0x03, 0x01, 0x03, 0x03, 0x09, 0x06, 0xe5, 0x02, -0x04, 0x04, 0x04, 0x02, 0x06, 0xe5, 0x02, 0x02, -0x06, 0x02, 0xe5, 0x02, 0x03, 0xff, 0xff, 0xff, -0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, -0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, -0xff, diff --git a/boards.cfg b/boards.cfg index 944ed4c..babf7dc 100644 --- a/boards.cfg +++ b/boards.cfg @@ -1108,7 +1108,6 @@ PPChameleonEVB_ME_33 powerpc ppc4xx PPChameleonEVB dave APC405 powerpc ppc4xx apc405 esd AR405 powerpc ppc4xx ar405 esd ASH405 powerpc ppc4xx ash405 esd -CANBT powerpc ppc4xx canbt esd CMS700 powerpc ppc4xx cms700 esd CPCI2DP powerpc ppc4xx cpci2dp esd CPCI405 powerpc ppc4xx cpci405 esd diff --git a/doc/README.scrapyard b/doc/README.scrapyard index a0f1fa3..87b1dfe 100644 --- a/doc/README.scrapyard +++ b/doc/README.scrapyard @@ -11,9 +11,10 @@ easily if here is something they might want to dig for...
Board Arch CPU Commit Removed Last known maintainer/contact ================================================================================================= -Alaska8220 powerpc mpc8220 - - -Yukon8220 powerpc mpc8220 - - -sorcery powerpc mpc8220 - - +CANBT powerpc 405CR - - Matthias Fuchs matthias.fuchs@esd.eu +Alaska8220 powerpc mpc8220 d6ed322 2013-05-11 +Yukon8220 powerpc mpc8220 d6ed322 2013-05-11 +sorcery powerpc mpc8220 d6ed322 2013-05-11 smdk6400 arm arm1176 52587f1 2013-04-12 Zhong Hongbo bocui107@gmail.com ns9750dev arm arm926ejs 4cfc611 2013-02-28 Markus Pietrek mpietrek@fsforth.de AMX860 powerpc mpc860 1b0757e 2012-10-28 Wolfgang Denk wd@denx.de diff --git a/include/configs/CANBT.h b/include/configs/CANBT.h deleted file mode 100644 index 40471b7..0000000 --- a/include/configs/CANBT.h +++ /dev/null @@ -1,215 +0,0 @@ -/* - * (C) Copyright 2001 - * Matthias Fuchs, esd gmbh germany, matthias.fuchs@esd-electronics.com - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -/* - * board/config.h - configuration options, board specific - */ - -#ifndef __CONFIG_H -#define __CONFIG_H - -/* - * High Level Configuration Options - * (easy to change) - */ - -#define CONFIG_405CR 1 /* This is a PPC405CR CPU */ -#define CONFIG_4xx 1 /* ...member of PPC4xx family */ -#define CONFIG_CANBT 1 /* ...on a CANBT board */ - -#define CONFIG_SYS_TEXT_BASE 0xFFFC0000 - -#define CONFIG_BOARD_EARLY_INIT_F 1 /* call board_early_init_f() */ - -#define CONFIG_SYS_CLK_FREQ 25000000 /* external frequency to pll */ - -#define CONFIG_BAUDRATE 115200 -#define CONFIG_BOOTDELAY 1 /* autoboot after 1 seconds */ - -#undef CONFIG_BOOTARGS -#define CONFIG_BOOTCOMMAND \ - "setenv bootargs root=/dev/ram rw console=ttyS0,115200; " \ - "bootm ffe00000 ffe80000" - -#define CONFIG_LOADS_ECHO 1 /* echo on for serial download */ -#define CONFIG_SYS_LOADS_BAUD_CHANGE 1 /* allow baudrate change */ - -#undef CONFIG_PCI_PNP /* no pci plug-and-play */ - -#define CONFIG_PHY_ADDR 0 /* PHY address */ - - -/* - * BOOTP options - */ -#define CONFIG_BOOTP_BOOTFILESIZE -#define CONFIG_BOOTP_BOOTPATH -#define CONFIG_BOOTP_GATEWAY -#define CONFIG_BOOTP_HOSTNAME - - -/* - * Command line configuration. - */ -#include <config_cmd_default.h> - -#define CONFIG_CMD_IRQ -#define CONFIG_CMD_EEPROM - -#undef CONFIG_CMD_NET -#undef CONFIG_CMD_NFS - -#undef CONFIG_WATCHDOG /* watchdog disabled */ - -#define CONFIG_SDRAM_BANK0 1 /* init onboard SDRAM bank 0 */ - -/* - * Miscellaneous configurable options - */ -#define CONFIG_SYS_LONGHELP /* undef to save memory */ -#define CONFIG_SYS_PROMPT "=> " /* Monitor Command Prompt */ -#if defined(CONFIG_CMD_KGDB) -#define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ -#else -#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ -#endif -#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) /* Print Buffer Size */ -#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ -#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Argument Buffer Size */ - -#define CONFIG_SYS_CONSOLE_INFO_QUIET 1 /* don't print console @ startup*/ - -#define CONFIG_SYS_MEMTEST_START 0x0400000 /* memtest works on */ -#define CONFIG_SYS_MEMTEST_END 0x0C00000 /* 4 ... 12 MB in DRAM */ - -#define CONFIG_CONS_INDEX 1 /* Use UART0 */ -#define CONFIG_SYS_NS16550 -#define CONFIG_SYS_NS16550_SERIAL -#define CONFIG_SYS_NS16550_REG_SIZE 1 -#define CONFIG_SYS_NS16550_CLK get_serial_clock() - -#define CONFIG_SYS_EXT_SERIAL_CLOCK 14745600 /* use external serial clock */ - -/* The following table includes the supported baudrates */ -#define CONFIG_SYS_BAUDRATE_TABLE \ - { 300, 600, 1200, 2400, 4800, 9600, 19200, 38400, \ - 57600, 115200, 230400, 460800, 921600 } - -#define CONFIG_SYS_LOAD_ADDR 0x100000 /* default load address */ -#define CONFIG_SYS_EXTBDINFO 1 /* To use extended board_into (bd_t) */ - -#define CONFIG_SYS_HZ 1000 /* decrementer freq: 1 ms ticks */ - -#define CONFIG_ZERO_BOOTDELAY_CHECK /* check for keypress on bootdelay==0 */ - -/*----------------------------------------------------------------------- - * Start addresses for the final memory configuration - * (Set up by the startup code) - * Please note that CONFIG_SYS_SDRAM_BASE _must_ start at 0 - */ -#define CONFIG_SYS_SDRAM_BASE 0x00000000 -#define CONFIG_SYS_FLASH_BASE CONFIG_SYS_MONITOR_BASE -#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE -#define CONFIG_SYS_MONITOR_LEN (~(CONFIG_SYS_TEXT_BASE) + 1) -#define CONFIG_SYS_MALLOC_LEN (128 * 1024) /* Reserve 128 kB for malloc() */ - -/* - * For booting Linux, the board info and command line data - * have to be in the first 8 MB of memory, since this is - * the maximum mapped by the Linux kernel during initialization. - */ -#define CONFIG_SYS_BOOTMAPSZ (8 << 20) /* Initial Memory map for Linux */ -/*----------------------------------------------------------------------- - * FLASH organization - */ -#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* max number of memory banks */ -#define CONFIG_SYS_MAX_FLASH_SECT 256 /* max number of sectors on one chip */ - -#define CONFIG_SYS_FLASH_ERASE_TOUT 120000 /* Timeout for Flash Erase (in ms) */ -#define CONFIG_SYS_FLASH_WRITE_TOUT 500 /* Timeout for Flash Write (in ms) */ - -#define CONFIG_SYS_FLASH_WORD_SIZE unsigned short /* flash word size (width) */ -#define CONFIG_SYS_FLASH_ADDR0 0x5555 /* 1st address for flash config cycles */ -#define CONFIG_SYS_FLASH_ADDR1 0x2AAA /* 2nd address for flash config cycles */ -/* - * The following defines are added for buggy IOP480 byte interface. - * All other boards should use the standard values (CPCI405 etc.) - */ -#define CONFIG_SYS_FLASH_READ0 0x0000 /* 0 is standard */ -#define CONFIG_SYS_FLASH_READ1 0x0001 /* 1 is standard */ -#define CONFIG_SYS_FLASH_READ2 0x0002 /* 2 is standard */ - -#define CONFIG_SYS_FLASH_EMPTY_INFO /* print 'E' for empty sector on flinfo */ - -#if 0 /* Use FLASH for environment variables */ - -#define CONFIG_ENV_IS_IN_FLASH 1 -#define CONFIG_ENV_OFFSET 0x00010000 /* Offset of Environment Sector */ -#define CONFIG_ENV_SIZE 0x1000 /* Total Size of Environment Sector */ - -#define CONFIG_ENV_SECT_SIZE 0x10000 /* see README - env sector total size */ - -#else /* Use EEPROM for environment variables */ - -#define CONFIG_ENV_IS_IN_EEPROM 1 /* use EEPROM for environment vars */ -#define CONFIG_ENV_OFFSET 0x000 /* environment starts at the beginning of the EEPROM */ -#define CONFIG_ENV_SIZE 0x400 /* 1024 bytes may be used for env vars */ - /* total size of a CAT24WC08 is 1024 bytes */ -#endif - -/*----------------------------------------------------------------------- - * I2C EEPROM (CAT24WC08) for environment - */ -#define CONFIG_SYS_I2C -#define CONFIG_SYS_I2C_PPC4XX -#define CONFIG_SYS_I2C_PPC4XX_CH0 -#define CONFIG_SYS_I2C_PPC4XX_SPEED_0 400000 -#define CONFIG_SYS_I2C_PPC4XX_SLAVE_0 0x7F - -#define CONFIG_SYS_I2C_EEPROM_ADDR 0x50 /* EEPROM CAT28WC08 */ -#define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 1 /* bytes of address */ -/* mask of address bits that overflow into the "EEPROM chip address" */ -#define CONFIG_SYS_I2C_EEPROM_ADDR_OVERFLOW 0x07 - -/* - * Init Memory Controller: - * - * BR0/1 and OR0/1 (FLASH) - */ - -#define FLASH_BASE0_PRELIM 0xFFC00000 /* FLASH bank #0 */ -#define FLASH_BASE1_PRELIM 0 /* FLASH bank #1 */ - -/*----------------------------------------------------------------------- - * External Bus Controller (EBC) Setup - */ - -/* Memory Bank 0 (Flash Bank 0) initialization */ -#define CONFIG_SYS_EBC_PB0AP 0x92015480 -#define CONFIG_SYS_EBC_PB0CR 0xFFC5A000 /* BAS=0xFFC,BS=4MB,BU=R/W,BW=16bit */ - -/* Memory Bank 1 (CAN/USB) initialization */ -#define CONFIG_SYS_EBC_PB1AP 0x010053C0 /* enable Ready, BEM=1 */ -#define CONFIG_SYS_EBC_PB1CR 0xF0018000 /* BAS=0xF00,BS=1MB,BU=R/W,BW=8bit */ - -/* Memory Bank 2 (Misc-IO/LEDs) initialization */ -#define CONFIG_SYS_EBC_PB2AP 0x000004c0 /* no Ready, BEM=1 */ -#define CONFIG_SYS_EBC_PB2CR 0xF0118000 /* BAS=0xF01,BS=1MB,BU=R/W,BW=8bit */ - -/* Memory Bank 3 (CAN Features) initialization */ -#define CONFIG_SYS_EBC_PB3AP 0x80000040 /* no Ready, BEM=1 */ -#define CONFIG_SYS_EBC_PB3CR 0xF021C000 /* BAS=0xF02,BS=1MB,BU=R/W,BW=32bit */ - -/*----------------------------------------------------------------------- - * Definitions for initial stack pointer and data area (in RAM) - */ -#define CONFIG_SYS_INIT_RAM_ADDR 0x00ef0000 /* inside of SDRAM */ -#define CONFIG_SYS_INIT_RAM_SIZE 0x0f00 /* Size of used area in RAM */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) -#define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET - -#endif /* __CONFIG_H */
Dear Matthias Fuchs,
Thanks!
Acked-by: Wolfgang Denk wd@denx.de
Signed-off-by: Matthias Fuchs matthias.fuchs@esd.eu Acked-by: Wolfgang Denk wd@denx.de
Matthias Fuchs
