[U-Boot] [PATCH v3 1/4] PXA: PXA27x Matrix keypad driver
Signed-off-by: Marek Vasut marek.vasut@gmail.com Signed-off-by: Vasily Khoruzhick anarsoul@gmail.com [vasily: adapted Marek's old version for newer u-boot, fixed multiple keypresses handling] --- v2: use struct-based access to regs, minor cleanup v3: fix multiple keypresses handling, minor cleanup
arch/arm/include/asm/arch-pxa/pxa-regs.h | 52 ----- arch/arm/include/asm/arch-pxa/regs-keypad.h | 84 ++++++++ drivers/input/Makefile | 2 + drivers/input/pxa27x-mkp.c | 301 +++++++++++++++++++++++++++ 4 files changed, 387 insertions(+), 52 deletions(-) create mode 100644 arch/arm/include/asm/arch-pxa/regs-keypad.h create mode 100644 drivers/input/pxa27x-mkp.c
diff --git a/arch/arm/include/asm/arch-pxa/pxa-regs.h b/arch/arm/include/asm/arch-pxa/pxa-regs.h index b81b42c..d562658 100644 --- a/arch/arm/include/asm/arch-pxa/pxa-regs.h +++ b/arch/arm/include/asm/arch-pxa/pxa-regs.h @@ -2567,58 +2567,6 @@ typedef void (*ExcpHndlr) (void) ; #define OVL2C1_O2EN (1<<31) /* Enable bit for Overlay 2 */ #define CCR_CEN (1<<31) /* Enable bit for Cursor */
-/* Keypad controller */ - -#define KPC 0x41500000 /* Keypad Interface Control register */ -#define KPDK 0x41500008 /* Keypad Interface Direct Key register */ -#define KPREC 0x41500010 /* Keypad Intefcace Rotary Encoder register */ -#define KPMK 0x41500018 /* Keypad Intefcace Matrix Key register */ -#define KPAS 0x41500020 /* Keypad Interface Automatic Scan register */ -#define KPASMKP0 0x41500028 /* Keypad Interface Automatic Scan Multiple Key Presser register 0 */ -#define KPASMKP1 0x41500030 /* Keypad Interface Automatic Scan Multiple Key Presser register 1 */ -#define KPASMKP2 0x41500038 /* Keypad Interface Automatic Scan Multiple Key Presser register 2 */ -#define KPASMKP3 0x41500040 /* Keypad Interface Automatic Scan Multiple Key Presser register 3 */ -#define KPKDI 0x41500048 /* Keypad Interface Key Debounce Interval register */ - -#define KPC_AS (0x1 << 30) /* Automatic Scan bit */ -#define KPC_ASACT (0x1 << 29) /* Automatic Scan on Activity */ -#define KPC_MI (0x1 << 22) /* Matrix interrupt bit */ -#define KPC_IMKP (0x1 << 21) /* Ignore Multiple Key Press */ -#define KPC_MS7 (0x1 << 20) /* Matrix scan line 7 */ -#define KPC_MS6 (0x1 << 19) /* Matrix scan line 6 */ -#define KPC_MS5 (0x1 << 18) /* Matrix scan line 5 */ -#define KPC_MS4 (0x1 << 17) /* Matrix scan line 4 */ -#define KPC_MS3 (0x1 << 16) /* Matrix scan line 3 */ -#define KPC_MS2 (0x1 << 15) /* Matrix scan line 2 */ -#define KPC_MS1 (0x1 << 14) /* Matrix scan line 1 */ -#define KPC_MS0 (0x1 << 13) /* Matrix scan line 0 */ -#define KPC_ME (0x1 << 12) /* Matrix Keypad Enable */ -#define KPC_MIE (0x1 << 11) /* Matrix Interrupt Enable */ -#define KPC_DK_DEB_SEL (0x1 << 9) /* Direct Key Debounce select */ -#define KPC_DI (0x1 << 5) /* Direct key interrupt bit */ -#define KPC_DEE0 (0x1 << 2) /* Rotary Encoder 0 Enable */ -#define KPC_DE (0x1 << 1) /* Direct Keypad Enable */ -#define KPC_DIE (0x1 << 0) /* Direct Keypad interrupt Enable */ - -#define KPDK_DKP (0x1 << 31) -#define KPDK_DK7 (0x1 << 7) -#define KPDK_DK6 (0x1 << 6) -#define KPDK_DK5 (0x1 << 5) -#define KPDK_DK4 (0x1 << 4) -#define KPDK_DK3 (0x1 << 3) -#define KPDK_DK2 (0x1 << 2) -#define KPDK_DK1 (0x1 << 1) -#define KPDK_DK0 (0x1 << 0) - -#define KPREC_OF1 (0x1 << 31) -#define kPREC_UF1 (0x1 << 30) -#define KPREC_OF0 (0x1 << 15) -#define KPREC_UF0 (0x1 << 14) - -#define KPMK_MKP (0x1 << 31) -#define KPAS_SO (0x1 << 31) -#define KPASMKPx_SO (0x1 << 31) - #define GPIO113_BIT (1 << 17)/* GPIO113 in GPSR, GPCR, bit 17 */ #define PSLR 0x40F00034 #define PSTR 0x40F00038 /* Power Manager Standby Configuration Reg */ diff --git a/arch/arm/include/asm/arch-pxa/regs-keypad.h b/arch/arm/include/asm/arch-pxa/regs-keypad.h new file mode 100644 index 0000000..f13da56 --- /dev/null +++ b/arch/arm/include/asm/arch-pxa/regs-keypad.h @@ -0,0 +1,84 @@ +/* + * Copyright (C) 2012 Vasily Khoruzhick anarsoul@gmail.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __REGS_KEYPAD_H__ +#define __REGS_KEYPAD_H__ + +#define KEYPAD_BASE 0x41500000 + +struct kpasmkp_regs { + uint32_t kpasmkpx; + uint32_t reserved; +}; + +struct pxa_keypad_regs { + uint32_t kpc; + uint32_t reserved_1; + uint32_t kpdk; + uint32_t reserved_2; + uint32_t kprec; + uint32_t reserved_3; + uint32_t kpmk; + uint32_t reserved_4; + uint32_t kpas; + uint32_t reserved_5; + struct kpasmkp_regs kpasmkp[4]; + uint32_t kpkdi; +}; + +#define KPC_AS (0x1 << 30) /* Automatic Scan bit */ +#define KPC_ASACT (0x1 << 29) /* Automatic Scan on Activity */ +#define KPC_MI (0x1 << 22) /* Matrix interrupt bit */ +#define KPC_IMKP (0x1 << 21) /* Ignore Multiple Key Press */ +#define KPC_MS7 (0x1 << 20) /* Matrix scan line 7 */ +#define KPC_MS6 (0x1 << 19) /* Matrix scan line 6 */ +#define KPC_MS5 (0x1 << 18) /* Matrix scan line 5 */ +#define KPC_MS4 (0x1 << 17) /* Matrix scan line 4 */ +#define KPC_MS3 (0x1 << 16) /* Matrix scan line 3 */ +#define KPC_MS2 (0x1 << 15) /* Matrix scan line 2 */ +#define KPC_MS1 (0x1 << 14) /* Matrix scan line 1 */ +#define KPC_MS0 (0x1 << 13) /* Matrix scan line 0 */ +#define KPC_ME (0x1 << 12) /* Matrix Keypad Enable */ +#define KPC_MIE (0x1 << 11) /* Matrix Interrupt Enable */ +#define KPC_DK_DEB_SEL (0x1 << 9) /* Direct Key Debounce select */ +#define KPC_DI (0x1 << 5) /* Direct key interrupt bit */ +#define KPC_DEE0 (0x1 << 2) /* Rotary Encoder 0 Enable */ +#define KPC_DE (0x1 << 1) /* Direct Keypad Enable */ +#define KPC_DIE (0x1 << 0) /* Direct Keypad interrupt Enable */ + +#define KPDK_DKP (0x1 << 31) +#define KPDK_DK7 (0x1 << 7) +#define KPDK_DK6 (0x1 << 6) +#define KPDK_DK5 (0x1 << 5) +#define KPDK_DK4 (0x1 << 4) +#define KPDK_DK3 (0x1 << 3) +#define KPDK_DK2 (0x1 << 2) +#define KPDK_DK1 (0x1 << 1) +#define KPDK_DK0 (0x1 << 0) + +#define KPREC_OF1 (0x1 << 31) +#define kPREC_UF1 (0x1 << 30) +#define KPREC_OF0 (0x1 << 15) +#define KPREC_UF0 (0x1 << 14) + +#define KPMK_MKP (0x1 << 31) +#define KPAS_SO (0x1 << 31) +#define KPASMKPx_SO (0x1 << 31) + +#endif diff --git a/drivers/input/Makefile b/drivers/input/Makefile index 1f4dad3..792d29d 100644 --- a/drivers/input/Makefile +++ b/drivers/input/Makefile @@ -31,6 +31,8 @@ COBJS-y += keyboard.o pc_keyb.o COBJS-$(CONFIG_PS2MULT) += ps2mult.o ps2ser.o endif
+COBJS-$(CONFIG_PXA27X_MKP) += pxa27x-mkp.o + COBJS := $(COBJS-y) SRCS := $(COBJS:.o=.c) OBJS := $(addprefix $(obj),$(COBJS)) diff --git a/drivers/input/pxa27x-mkp.c b/drivers/input/pxa27x-mkp.c new file mode 100644 index 0000000..013b6fe --- /dev/null +++ b/drivers/input/pxa27x-mkp.c @@ -0,0 +1,301 @@ +/* + * PXA27x matrix keypad controller driver + * + * Copyright (C) 2010 Marek Vasut marek.vasut@gmail.com + * Copyright (C) 2012 Vasily Khoruzhick anarsoul@gmail.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <stdio_dev.h> +#include <asm/arch/regs-keypad.h> +#include <asm/io.h> + +#define DEVNAME "pxa27x-mkp" + +struct { + char row; + char col; + char key; + char shift; + char alt; + char ctrl; +} keymap[] = { + CONFIG_PXA27X_MKP_KEYMAP, +}; + +static unsigned char queue[64] = {0}; +static int queue_len; +static struct pxa_keypad_regs *regs; + +/* autorepeat stuff */ +static int last_key_row = 0xff, last_key_col = 0xff; +static char key_counter; + +/* number of key scans before autorepeat kicks in */ +#ifndef CONFIG_PXA27X_KEY_REPEAT_FIRST +#define CONFIG_PXA27X_KEY_REPEAT_FIRST 12 +#endif +#ifndef CONFIG_PXA27X_KEY_REPEAT_NEXT +#define CONFIG_PXA27X_KEY_REPEAT_NEXT 2 +#endif + +/* 100 milliseconds (in wait cycles below it's 100 x 10uS waits) */ +#define PXA_KEYPAD_TIMEOUT 10000 + +enum { + MOD_NONE, + MOD_SHIFT, + MOD_ALT, + MOD_CTRL, +}; + +static int kbd_get_mdf(int row, int col) +{ + char mod_shift[2] = CONFIG_PXA27X_MKP_MOD_SHIFT; + char mod_alt[2] = CONFIG_PXA27X_MKP_MOD_ALT; + char mod_ctrl[2] = CONFIG_PXA27X_MKP_MOD_CTRL; + + if (mod_shift[0] == row && mod_shift[1] == col) + return MOD_SHIFT; + if (mod_alt[0] == row && mod_alt[1] == col) + return MOD_ALT; + if (mod_ctrl[0] == row && mod_ctrl[1] == col) + return MOD_CTRL; + return MOD_NONE; +} + +static int kbd_lookup(int row, int col, int mod) +{ + int i = 0; + char key = 0xff; + + while (!(keymap[i].col == 0xff && keymap[i].row == 0xff)) { + if (keymap[i].row != row || keymap[i].col != col) { + i++; + continue; + } + switch (mod) { + case MOD_NONE: + key = keymap[i].key; + break; + case MOD_SHIFT: + key = keymap[i].shift; + break; + case MOD_ALT: + key = keymap[i].alt; + break; + case MOD_CTRL: + key = keymap[i].ctrl; + break; + } + if (key == 0xff) { + i++; + continue; + } + + if (row != last_key_row || col != last_key_col) { + queue[queue_len++] = key; + last_key_row = row; + last_key_col = col; + key_counter = 0; + } else /* same key as before */ + if (key_counter < CONFIG_PXA27X_KEY_REPEAT_FIRST) { + /* ignore key press */ + key_counter++; + } else { + /* ok, autorepeat */ + queue[queue_len++] = key; + key_counter = CONFIG_PXA27X_KEY_REPEAT_FIRST + - CONFIG_PXA27X_KEY_REPEAT_NEXT; + } + i++; + } + return key; +} + +static int scan_keys(int scan_modif, uint32_t kpasmkp[4]) +{ + uint32_t reg = 0; + int col, row; + static int mod = MOD_NONE; + int key; + for (col = 0; col < 8; col += 2) { + reg = kpasmkp[col >> 1]; + for (row = 0; row < 8; row++) { + if (reg & (1 << row)) { + if (scan_modif) { + mod = kbd_get_mdf(row, col); + if (mod != MOD_NONE) + return mod; + } else { + key = kbd_lookup(row, col, mod); + if (key != 0xff) + return key; + } + } + if ((reg >> 16) & (1 << row)) { + if (scan_modif) { + mod = kbd_get_mdf(row, col + 1); + if (mod != MOD_NONE) + return mod; + } else { + key = kbd_lookup(row, col + 1, mod); + if (key != 0xff) + return key; + } + } + } + } + if (scan_modif) + return MOD_NONE; + else + return 0xff; +} + +static void kbd_read(void) +{ + uint32_t reg; + int col, row, i, have_new_key = 0; + int numkeys; + int mod = MOD_NONE; + unsigned int timeout = PXA_KEYPAD_TIMEOUT; + static uint32_t kpasmkp_old[4]; + uint32_t kpasmkp[4], kpasmkp_diff[4]; + + /* start one automatic scan */ + writel(readl(®s->kpc) | KPC_AS, ®s->kpc); + + /* wait for scan to finish */ + while (timeout--) { + if (!(readl(®s->kpc) & KPC_AS)) + break; + udelay(10); + } + + if (!timeout) + return; + + numkeys = (readl(®s->kpas) >> 26) & 0x1f; + switch (numkeys) { + case 0: + /* no key pressed, clear autorepeat counter */ + key_counter = 0; + last_key_row = last_key_col = 0xff; + for (i = 0; i < ARRAY_SIZE(kpasmkp); i++) + kpasmkp[i] = 0; + break; + case 1: + reg = readl(®s->kpas) & 0xff; + col = reg & 0x0f; + row = reg >> 4; + for (i = 0; i < ARRAY_SIZE(kpasmkp); i++) + kpasmkp[i] = 0; + kpasmkp[col >> 1] |= (1 << (row + 16 * (col % 2))); + + break; + default: + for (i = 0; i < ARRAY_SIZE(kpasmkp); i++) { + timeout = PXA_KEYPAD_TIMEOUT; + while (timeout--) { + kpasmkp[i] = readl(®s->kpasmkp[i].kpasmkpx); + if (!(kpasmkp[i] & KPASMKPx_SO)) + break; + udelay(10); + } + if (!timeout) + kpasmkp[i] = 0; + } + break; + } + + /* Find new keypress */ + for (i = 0; i < ARRAY_SIZE(kpasmkp); i++) { + kpasmkp_diff[i] = (kpasmkp_old[i] ^ kpasmkp[i]) & + kpasmkp[i]; + if (kpasmkp_diff[i]) + have_new_key = 1; + kpasmkp_old[i] = kpasmkp[i]; + } + + if (!numkeys) + return; + + /* Scan for modifiers */ + mod = scan_keys(1, kpasmkp); + if (!have_new_key) { + /* Check if old key is still pressed */ + if (kpasmkp[last_key_col >> 1] & + (1 << (last_key_row + 16 * (last_key_col % 2)))) + kbd_lookup(last_key_row, last_key_col, mod); + serial_printf("No new key\n"); + + } else { + key_counter = 0; + last_key_row = last_key_col = 0xff; + scan_keys(0, kpasmkp_diff); + serial_printf("New key\n"); + } +} + +static int kbd_getc(void) +{ + if (!queue_len) { + kbd_read(); + udelay(CONFIG_PXA27X_MKP_DELAY); + } + + if (queue_len) + return queue[--queue_len]; + else + return 0; +} + +static int kbd_testc(void) +{ + if (!queue_len) + kbd_read(); + return queue_len; +} + +int drv_keyboard_init(void) +{ + int error = 0; + struct stdio_dev kbddev; + + regs = (struct pxa_keypad_regs *)KEYPAD_BASE; + queue_len = 0; + + writel((CONFIG_PXA27X_MKP_MKP_ROWS << 26) | + (CONFIG_PXA27X_MKP_MKP_COLS << 23) | + (0xff << 13) | KPC_ME, ®s->kpc); + writel(CONFIG_PXA27X_MKP_DEBOUNCE, ®s->kpkdi); + + memset(&kbddev, 0, sizeof(kbddev)); + strcpy(kbddev.name, DEVNAME); + kbddev.flags = DEV_FLAGS_INPUT | DEV_FLAGS_SYSTEM; + kbddev.putc = NULL ; + kbddev.puts = NULL ; + kbddev.getc = kbd_getc ; + kbddev.tstc = kbd_testc ; + + error = stdio_register(&kbddev); + return error; +}
Signed-off-by: Vasily Khoruzhick anarsoul@gmail.com --- v2: remove usbtty stuff from EXTRA_ENV_SETTINGS v3: shift+backspace should produce backspace code
include/configs/zipitz2.h | 82 ++++++++++++++++++++++++++++++++++++++++++--- 1 files changed, 77 insertions(+), 5 deletions(-)
diff --git a/include/configs/zipitz2.h b/include/configs/zipitz2.h index 26204af..76054af 100644 --- a/include/configs/zipitz2.h +++ b/include/configs/zipitz2.h @@ -80,6 +80,12 @@ #define CONFIG_CMD_MMC #define CONFIG_CMD_SPI
+#define CONFIG_EXTRA_ENV_SETTINGS \ + "stdout=lcd\0" \ + "stdin=pxa27x-mkp\0" \ + "stderr=lcd\0" \ + "" +#define CONFIG_KEYBOARD /* * MMC Card Configuration */ @@ -206,15 +212,81 @@ unsigned char zipitz2_spi_read(void); #define CONFIG_SYS_FLASH_PROTECTION
/* + * Matrix keypad + */ +#ifdef CONFIG_KEYBOARD +#define CONFIG_PXA27X_MKP + +#define CONFIG_PXA27X_MKP_MKP_COLS 7 +#define CONFIG_PXA27X_MKP_MKP_ROWS 6 + +#define CONFIG_PXA27X_MKP_DEBOUNCE 30 +#define CONFIG_PXA27X_MKP_DELAY 30000 + +#define CONFIG_PXA27X_MKP_MOD_SHIFT {5, 3} +#define CONFIG_PXA27X_MKP_MOD_ALT {5, 2} +#define CONFIG_PXA27X_MKP_MOD_CTRL {5, 4} + +#define CONFIG_PXA27X_MKP_KEYMAP \ + { 1, 1, 'q', 'Q', '1', 0xff }, \ + { 2, 1, 'i', 'I', '8', 0xff }, \ + { 3, 1, 'g', 'G', '"', 0xff }, \ + { 4, 1, 'x', 'X', '/', 0xff }, \ + { 5, 1, '\r', 0xff, 0xff, 0xff }, \ + { 6, 1, '-', 0xff, 0xff, 0xff }, \ + \ + { 1, 2, 'w', 'W', '2', 0xff }, \ + { 2, 2, 'o', 'O', '9', 0xff }, \ + { 3, 2, 'h', 'H', ''', 0xff }, \ + { 4, 2, 'c', 'C', '+', 0xff }, \ + \ + { 1, 3, 'e', 'E', '3', 0xff }, \ + { 2, 3, 'p', 'P', '0', 0xff }, \ + { 3, 3, 'j', 'J', '[', 0xff }, \ + { 4, 3, 'v', 'V', '*', 0xff }, \ + \ + { 0, 4, '\e', 0xff, '|', 0xff }, \ + { 1, 4, 'r', 'R', '4', 0xff }, \ + { 2, 4, 'a', 'A', '$', 0xff }, \ + { 3, 4, 'k', 'K', ']', 0xff }, \ + { 4, 4, 'b', 'B', '=', 0xff }, \ + \ + { 0, 5, '\t', 0xff, 0xff, 0xff }, \ + { 1, 5, 't', 'T', '5', 0xff }, \ + { 2, 5, 's', 'S', '#', 0xff }, \ + { 3, 5, 'l', 'L', '-', 0xff }, \ + { 4, 5, 'n', 'N', '_', 0xff }, \ + { 5, 5, ' ', 0xff, 0xff, 0xff }, \ + \ + { 1, 6, 'y', 'Y', '6', 0xff }, \ + { 2, 6, 'd', 'D', '&', 0xff }, \ + { 3, 6, '\b', '\b', '\', 0xff }, \ + { 4, 6, 'm', 'M', '?', 0xff }, \ + { 5, 6, ',', '(', '<', '{' }, \ + \ + { 1, 7, 'u', 'U', '7', 0xff }, \ + { 2, 7, 'f', 'F', '@', 0xff }, \ + { 3, 7, 'z', 'Z', '!', 0xff }, \ + { 4, 7, ';', '~', ':', 0xff }, \ + { 5, 7, '.', ')', '>', '}' }, \ + \ + { 0xff, 0xff, 0xff, 0xff, 0xff, 0xff } + +#define CONFIG_SYS_CONSOLE_ENV_OVERWRITE +#define CONFIG_SYS_CONSOLE_IS_IN_ENV + +#endif + +/* * GPIO settings */ #define CONFIG_SYS_GAFR0_L_VAL 0x02000140 -#define CONFIG_SYS_GAFR0_U_VAL 0x59188000 -#define CONFIG_SYS_GAFR1_L_VAL 0x63900002 +#define CONFIG_SYS_GAFR0_U_VAL 0x59188005 +#define CONFIG_SYS_GAFR1_L_VAL 0x639420a2 #define CONFIG_SYS_GAFR1_U_VAL 0xaaa03950 #define CONFIG_SYS_GAFR2_L_VAL 0x0aaaaaaa #define CONFIG_SYS_GAFR2_U_VAL 0x29000308 -#define CONFIG_SYS_GAFR3_L_VAL 0x54000000 +#define CONFIG_SYS_GAFR3_L_VAL 0x56aa9500 #define CONFIG_SYS_GAFR3_U_VAL 0x000000d5 #define CONFIG_SYS_GPCR0_VAL 0x00000000 #define CONFIG_SYS_GPCR1_VAL 0x00000020 @@ -222,7 +294,7 @@ unsigned char zipitz2_spi_read(void); #define CONFIG_SYS_GPCR3_VAL 0x00000000 #define CONFIG_SYS_GPDR0_VAL 0xdafcee00 #define CONFIG_SYS_GPDR1_VAL 0xffa3aaab -#define CONFIG_SYS_GPDR2_VAL 0x8fe9ffff +#define CONFIG_SYS_GPDR2_VAL 0x8fe1ffff #define CONFIG_SYS_GPDR3_VAL 0x001b1f8a #define CONFIG_SYS_GPSR0_VAL 0x06080400 #define CONFIG_SYS_GPSR1_VAL 0x007f0000 @@ -234,7 +306,7 @@ unsigned char zipitz2_spi_read(void); /* * Clock settings */ -#define CONFIG_SYS_CKEN 0x00511220 +#define CONFIG_SYS_CKEN 0x00591220 #define CONFIG_SYS_CCCR 0x00000190
Signed-off-by: Vasily Khoruzhick anarsoul@gmail.com --- v2: mmcinfo is necessary to scan card for partitions v3: replace mmcinfo with mmc rescan
board/zipitz2/zipitz2.c | 8 ++++++++ include/configs/zipitz2.h | 14 ++++++++------ 2 files changed, 16 insertions(+), 6 deletions(-)
diff --git a/board/zipitz2/zipitz2.c b/board/zipitz2/zipitz2.c index b093c2f..4075fb6 100644 --- a/board/zipitz2/zipitz2.c +++ b/board/zipitz2/zipitz2.c @@ -79,6 +79,14 @@ void dram_init_banksize(void) gd->bd->bi_dram[0].size = PHYS_SDRAM_1_SIZE; }
+#ifdef CONFIG_CMD_MMC +int board_mmc_init(bd_t *bis) +{ + pxa_mmc_register(0); + return 0; +} +#endif + #ifdef CONFIG_CMD_SPI
struct { diff --git a/include/configs/zipitz2.h b/include/configs/zipitz2.h index 76054af..4f48d9b 100644 --- a/include/configs/zipitz2.h +++ b/include/configs/zipitz2.h @@ -44,11 +44,12 @@ #define CONFIG_SYS_MALLOC_LEN (128*1024) #define CONFIG_ARCH_CPU_INIT
-#define CONFIG_BOOTCOMMAND \ - "if mmc init && fatload mmc 0 0xa0000000 uboot.script ; then " \ - "source 0xa0000000; " \ - "else " \ - "bootm 0x60000; " \ +#define CONFIG_BOOTCOMMAND \ + "if mmc rescan 0 && ext2load mmc 0 0xa0000000 boot/uboot.script ;" \ + "then " \ + "source 0xa0000000; " \ + "else " \ + "bootm 0x60000; " \ "fi; " #define CONFIG_BOOTARGS \ "console=tty0 console=ttyS2,115200 fbcon=rotate:3" @@ -91,7 +92,8 @@ */ #ifdef CONFIG_CMD_MMC #define CONFIG_MMC -#define CONFIG_PXA_MMC +#define CONFIG_GENERIC_MMC +#define CONFIG_PXA_MMC_GENERIC #define CONFIG_SYS_MMC_BASE 0xF0000000 #define CONFIG_CMD_FAT #define CONFIG_CMD_EXT2
- pxa_mmc_register(0);
+} +#endif
- "else " \
"bootm 0x60000; " \
- "if mmc rescan 0 && ext2load mmc 0 0xa0000000 boot/uboot.script ;" \
Why "mmc rescan 0" ?
- "then " \
- "else " \
"fi; ""bootm 0x60000; " \
Because otherwise it does nothing to detect card and scan for partitions? 0 is mmc device index.
Regards Vasily
I see ... so mmc rescan takes such a parameter. Ok, but I can't find any evidence of it in the source code ... hmmmmmm.
Regards Vasily
CONFIG_SYS_INIT_SP_ADDR points to RAM, but it's used before DRAM controller init. Fix it by setting CONFIG_SYS_INIT_SP_ADDR to SRAM
Signed-off-by: Vasily Khoruzhick anarsoul@gmail.com --- v2: no changes v3: introduce PHYS_SRAM, use it for SYS_INIT_SP_ADDR calculation
include/configs/zipitz2.h | 8 +++++++- 1 files changed, 7 insertions(+), 1 deletions(-)
diff --git a/include/configs/zipitz2.h b/include/configs/zipitz2.h index 4f48d9b..8add384 100644 --- a/include/configs/zipitz2.h +++ b/include/configs/zipitz2.h @@ -170,6 +170,12 @@ unsigned char zipitz2_spi_read(void); #endif
/* + * SRAM Map + */ +#define PHYS_SRAM 0x5c000000 /* SRAM Bank #1 */ +#define PHYS_SRAM_SIZE 0x00040000 /* 256k */ + +/* * DRAM Map */ #define CONFIG_NR_DRAM_BANKS 1 /* We have 1 bank of DRAM */ @@ -185,7 +191,7 @@ unsigned char zipitz2_spi_read(void); #define CONFIG_SYS_LOAD_ADDR CONFIG_SYS_DRAM_BASE
#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_1 -#define CONFIG_SYS_INIT_SP_ADDR (GENERATED_GBL_DATA_SIZE + PHYS_SDRAM_1 + 2048) +#define CONFIG_SYS_INIT_SP_ADDR (GENERATED_GBL_DATA_SIZE + PHYS_SRAM + 2048)
/* * NOR FLASH
- SRAM Map
- DRAM Map
bank of DRAM */
PHYS_SDRAM_1 +
- +#define CONFIG_SYS_INIT_SP_ADDR (GENERATED_GBL_DATA_SIZE
PHYS_SRAM + 2048)
- NOR FLASH
Applied
register */
- Copyright (C) 2012 Vasily Khoruzhick anarsoul@gmail.com
- MA 02111-1307 USA
- uint32_t kpasmkpx;
- uint32_t reserved;
- uint32_t kpc;
- uint32_t reserved_1;
- uint32_t kpdk;
- uint32_t reserved_2;
- uint32_t kprec;
- uint32_t reserved_3;
- uint32_t kpmk;
- uint32_t reserved_4;
- uint32_t kpas;
- uint32_t reserved_5;
- struct kpasmkp_regs kpasmkp[4];
- uint32_t kpkdi;
Drop those two spaces here
- PXA27x matrix keypad controller driver
- Copyright (C) 2010 Marek Vasut marek.vasut@gmail.com
- project.
- MA 02111-1307 USA
+struct {
- char row;
- char col;
- char key;
- char shift;
- char alt;
- char ctrl;
+} keymap[] = {
- CONFIG_PXA27X_MKP_KEYMAP,
You can as well assign it here.
+enum {
- MOD_NONE,
- MOD_SHIFT,
- MOD_ALT,
- MOD_CTRL,
- char mod_shift[2] = CONFIG_PXA27X_MKP_MOD_SHIFT;
- char mod_alt[2] = CONFIG_PXA27X_MKP_MOD_ALT;
- char mod_ctrl[2] = CONFIG_PXA27X_MKP_MOD_CTRL;
- if (mod_shift[0] == row && mod_shift[1] == col)
return MOD_SHIFT;
- if (mod_alt[0] == row && mod_alt[1] == col)
return MOD_ALT;
- if (mod_ctrl[0] == row && mod_ctrl[1] == col)
return MOD_CTRL;
- return MOD_NONE;
- int i = 0;
- char key = 0xff;
- while (!(keymap[i].col == 0xff && keymap[i].row == 0xff)) {
i++;
continue;
switch (mod) {
case MOD_NONE:
break;
case MOD_SHIFT:
break;
case MOD_ALT:
break;
case MOD_CTRL:
break;
if (key == 0xff) {
i++;
continue;
last_key_row = row;
last_key_col = col;
key_counter = 0;
key_counter++;
} else {
i++;
- return key;
- uint32_t reg = 0;
- int col, row;
- static int mod = MOD_NONE;
Are you sure you know what you're doing using all those static vars all around?
- int key;
- for (col = 0; col < 8; col += 2) {
if (scan_modif) {
return mod;
} else {
if (key != 0xff)
return key;
if (scan_modif) {
return mod;
} else {
if (key != 0xff)
return key;
Can you do some elegant solution of this code duplication?
Newline
- if (scan_modif)
return MOD_NONE;
- else
return 0xff;
- uint32_t reg;
- int col, row, i, have_new_key = 0;
- int numkeys;
- int mod = MOD_NONE;
- unsigned int timeout = PXA_KEYPAD_TIMEOUT;
- static uint32_t kpasmkp_old[4];
- uint32_t kpasmkp[4], kpasmkp_diff[4];
- /* start one automatic scan */
- writel(readl(®s->kpc) | KPC_AS, ®s->kpc);
- /* wait for scan to finish */
- while (timeout--) {
break;
udelay(10);
Use WATCHDOG_RESET()
- if (!timeout)
return;
- numkeys = (readl(®s->kpas) >> 26) & 0x1f;
- switch (numkeys) {
- case 0:
key_counter = 0;
kpasmkp[i] = 0;
break;
- case 1:
col = reg & 0x0f;
row = reg >> 4;
kpasmkp[i] = 0;
break;
- default:
while (timeout--) {
break;
udelay(10);
if (!timeout)
kpasmkp[i] = 0;
break;
- /* Find new keypress */
- for (i = 0; i < ARRAY_SIZE(kpasmkp); i++) {
kpasmkp[i];
have_new_key = 1;
- if (!numkeys)
return;
- /* Scan for modifiers */
- mod = scan_keys(1, kpasmkp);
- if (!have_new_key) {
- } else {
key_counter = 0;
What's this dammit? And above too! Use debug() if you need it.
- if (!queue_len) {
kbd_read();
- if (queue_len)
- else
- if (!queue_len)
kbd_read();
- return queue_len;
- int error = 0;
- struct stdio_dev kbddev;
- regs = (struct pxa_keypad_regs *)KEYPAD_BASE;
See above
- queue_len = 0;
- writel((CONFIG_PXA27X_MKP_MKP_ROWS << 26) |
- writel(CONFIG_PXA27X_MKP_DEBOUNCE, ®s->kpkdi);
- memset(&kbddev, 0, sizeof(kbddev));
- strcpy(kbddev.name, DEVNAME);
- kbddev.flags = DEV_FLAGS_INPUT | DEV_FLAGS_SYSTEM;
- kbddev.putc = NULL ;
- kbddev.puts = NULL ;
- kbddev.getc = kbd_getc ;
- kbddev.tstc = kbd_testc ;
Drop spaces before semicolon
- error = stdio_register(&kbddev);
- return error;
Two spaces? It's tabs! Btw, it's for good looking formatting and it was taken from pxa-regs.h. I'd like to preserve it like it is.
Ok
- uint32_t reg = 0;
- int col, row;
I'm sure I know what I'm doing, right here it preserves modifier between two function calls, i.e. scan_keys(1, ...); scan_keys(0, ...);
if (scan_modif) {
return mod;
} else {
if (key != 0xff)
return key;
Ok
Newline
Ok
break;
udelay(10);
Why the heck you want to reset here? It's not fatal. We can handle this timeout gracefully, without resetting and messing up all the stuff.
- } else {
key_counter = 0;
Sorry, left it occasionally.
Ok
Thanks for review!
Regards, Vasily
Then change it to space ... (1 <<[TAB]3) is even weirder. And on my side, it still looks like two spaces.
Ok
- uint32_t reg = 0;
- int col, row;
if (scan_modif) {
return mod;
} else {
if (key != 0xff)
return key;
Ok
Newline
Ok
break;
udelay(10);
WATCHDOG_RESET() reloads the WDT ...
- } else {
key_counter = 0;
Ok
Thanks for review!
Regards, Vasily
Vasily Khoruzhick
