[U-Boot] [PATCH] rockchip: rk3399: defconfig: add CONFIG_OF_EMBED support
Need to enablt CONFIG_OF_EMBED if we use separate uboot and dtb in FIT image for SPL loading.
Run make savedefconfig to make the options order correct.
Signed-off-by: Kever Yang kever.yang@rock-chips.com ---
configs/evb-rk3399_defconfig | 43 ++++++++++++++++++++----------------------- 1 file changed, 20 insertions(+), 23 deletions(-)
diff --git a/configs/evb-rk3399_defconfig b/configs/evb-rk3399_defconfig index 195a421..961fe8b 100644 --- a/configs/evb-rk3399_defconfig +++ b/configs/evb-rk3399_defconfig @@ -1,30 +1,37 @@ CONFIG_ARM=y CONFIG_ARCH_ROCKCHIP=y +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_SYS_MALLOC_F_LEN=0x4000 CONFIG_ROCKCHIP_RK3399=y +CONFIG_SPL_STACK_R_ADDR=0x80000 CONFIG_DEFAULT_DEVICE_TREE="rk3399-evb" CONFIG_FIT=y CONFIG_SPL_LOAD_FIT=y -CONFIG_SPL_OF_LIBFDT=y -CONFIG_SPL_ATF_SUPPORT=y -CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x200 -CONFIG_SPL_ATF_TEXT_BASE=0x00010000 # CONFIG_DISPLAY_CPUINFO is not set CONFIG_SPL_STACK_R=y -CONFIG_SPL_STACK_R_ADDR=0x80000 CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x4000 -CONFIG_SPL_LIBCOMMON_SUPPORT=y -CONFIG_SPL_LIBGENERIC_SUPPORT=y -CONFIG_SYS_MALLOC_F_LEN=0x4000 +CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x200 +CONFIG_SPL_ATF_SUPPORT=y +CONFIG_SPL_ATF_TEXT_BASE=0x00010000 +CONFIG_FASTBOOT=y +CONFIG_USB_FUNCTION_FASTBOOT=y +CONFIG_CMD_FASTBOOT=y +CONFIG_FASTBOOT_BUF_ADDR=0x00800800 +CONFIG_FASTBOOT_BUF_SIZE=0x08000000 +CONFIG_FASTBOOT_FLASH=y +CONFIG_FASTBOOT_FLASH_MMC_DEV=1 CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set CONFIG_CMD_GPT=y CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_USB=y +CONFIG_CMD_USB_MASS_STORAGE=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_TIME=y -CONFIG_CMD_PXE=y CONFIG_SPL_OF_CONTROL=y +CONFIG_OF_EMBED=y CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" CONFIG_SPL_OF_PLATDATA=y CONFIG_REGMAP=y @@ -57,23 +64,13 @@ CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_GENERIC=y -CONFIG_USB_STORAGE=y -CONFIG_USE_TINY_PRINTF=y -CONFIG_ERRNO_STR=y -CONFIG_USB_GADGET=y -CONFIG_USB_GADGET_DUALSPEED=y -CONFIG_USB_GADGET_VBUS_DRAW=0 CONFIG_USB_DWC3=y CONFIG_USB_DWC3_GADGET=y +CONFIG_USB_STORAGE=y +CONFIG_USB_GADGET=y CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_G_DNL_MANUFACTURER="Rockchip" CONFIG_G_DNL_VENDOR_NUM=0x2207 CONFIG_G_DNL_PRODUCT_NUM=0x330a -CONFIG_FASTBOOT=y -CONFIG_CMD_FASTBOOT=y -CONFIG_USB_FUNCTION_FASTBOOT=y -CONFIG_FASTBOOT_FLASH=y -CONFIG_FASTBOOT_FLASH_MMC_DEV=1 -CONFIG_FASTBOOT_BUF_ADDR=0x00800800 -CONFIG_FASTBOOT_BUF_SIZE=0x08000000 -CONFIG_CMD_USB_MASS_STORAGE=y +CONFIG_USE_TINY_PRINTF=y +CONFIG_ERRNO_STR=y
Hi Kever,
Can you please explain that a bit more? We shouldn't OF_EMBED in production code, only for debug/test.
Hi Simon,
On 04/10/2017 03:28 AM, Simon Glass wrote:
Hi Kever,
When I test with latest code for SPL loading FIT which u-boot and dtb are separate, the U-Boot code can not find its dtb file. This issue is not happen when I test with code older than v2017.03, and with CONFIG_OF_EMBED, U-Boot can find dtb with latest code.
Maybe I need to do some debugging for root cause, please ignore this patch if this is not correct.
Thanks, - Kever
Hi Kever,
On 9 April 2017 at 20:36, Kever Yang kever.yang@rock-chips.com wrote:
Hi Simon,
Hi Kever,
Yes this needs to be figured out. If you have the debug UART enabled you should be able to add debugging to fdtdec_setup() to see what is happening. Perhaps the DT is not word-aligned?
Thanks,
- Kever
Hi Simon,
On 04/11/2017 09:55 PM, Simon Glass wrote:
Hi Kever,
Hi Simon,
Hi Kever,
I find the root cause. I try to truncate the input image like uboot-no-dtb.bin and u-boot.dtb to block size 512, so the SPL get the image size is 512 aligned, but the fdtdec_setup() using the end of image address &_end which is not 512 aligned, and can not find available dtb.
I want to make the mkimage output header and input image aligned to 512 to reduce no necessary copy.
Thanks, - Kever
Thanks,
- Kever
Hi Kever,
On 14 April 2017 at 01:59, Kever Yang kever.yang@rock-chips.com wrote:
Hi Simon,
Hi Kever,
Hi Simon,
Hi Kever,
I still don't really understand this. Can you not use u-boot.bin which includes both U-Boot and the DT? Then only the alignment of the whole file matters.
Instead of truncating you should pad - otherwise you lose data. But I suspect I just misunderstand what you mean.
Kever Yang
