[PATCH v4 0/2] Support SPL for i.MX7ULP
I've just realized this patch was not applied from the original patchset "Support SPL for i.MX7ULP".
Please apply this patch to fix the code as now "include/configs/mx7ulp_com.h" refers to non-existent "include/configs/imx7ulp_spl.h".
This supersedes the patchset https://patchwork.ozlabs.org/project/uboot/list/?series=309021
Changes in v4: - rebase to the current master - fix a reference to a non-existent option SPL_MMC_SUPPORT - add a small fix for imx spl.
Changes in v3: - rebase the patch to the current codebase
Oleksandr Suvorov (1): imx: spl: fix a comment adding IMX9
Ricardo Salveti (1): mx7ulp: add base SPL support for mx7ulp
arch/arm/mach-imx/Makefile | 2 +- arch/arm/mach-imx/mx7ulp/soc.c | 2 +- arch/arm/mach-imx/spl.c | 6 ++++-- include/configs/imx7ulp_spl.h | 39 ++++++++++++++++++++++++++++++++++ 4 files changed, 45 insertions(+), 4 deletions(-) create mode 100644 include/configs/imx7ulp_spl.h
Add a base implementation of mx7ulp SPL config header and soc, and changes in makefiles in order to allow building SPL on mx7ulp based devices.
Signed-off-by: Ricardo Salveti ricardo@foundries.io Co-developed-by: Oleksandr Suvorov oleksandr.suvorov@foundries.io Signed-off-by: Oleksandr Suvorov oleksandr.suvorov@foundries.io ---
diff --git a/arch/arm/mach-imx/Makefile b/arch/arm/mach-imx/Makefile index 80c497e6d81..71e6cac2f63 100644 --- a/arch/arm/mach-imx/Makefile +++ b/arch/arm/mach-imx/Makefile @@ -29,7 +29,7 @@ endif obj-$(CONFIG_GPT_TIMER) += timer.o obj-$(CONFIG_SYS_I2C_MXC) += i2c-mxv7.o endif -ifeq ($(SOC),$(filter $(SOC),mx7 mx6 mxs imx8m imx8 imx9 imxrt)) +ifeq ($(SOC),$(filter $(SOC),mx7 mx7ulp mx6 mxs imx8m imx8 imx9 imxrt)) obj-y += misc.o obj-$(CONFIG_CMD_PRIBLOB) += priblob.o obj-$(CONFIG_SPL_BUILD) += spl.o diff --git a/arch/arm/mach-imx/mx7ulp/soc.c b/arch/arm/mach-imx/mx7ulp/soc.c index 217b7c45867..951b1888c58 100644 --- a/arch/arm/mach-imx/mx7ulp/soc.c +++ b/arch/arm/mach-imx/mx7ulp/soc.c @@ -234,7 +234,7 @@ void s_init(void) } #endif
-#ifndef CONFIG_ULP_WATCHDOG +#if !CONFIG_IS_ENABLED(ULP_WATCHDOG) || CONFIG_IS_ENABLED(SPL_BUILD) void reset_cpu(void) { setbits_le32(SIM0_RBASE, SIM_SOPT1_A7_SW_RESET); diff --git a/arch/arm/mach-imx/spl.c b/arch/arm/mach-imx/spl.c index ef00969a5e0..bca0b1123a7 100644 --- a/arch/arm/mach-imx/spl.c +++ b/arch/arm/mach-imx/spl.c @@ -147,7 +147,7 @@ u32 spl_boot_device(void) return BOOT_DEVICE_NONE; }
-#elif defined(CONFIG_MX7) || defined(CONFIG_IMX8M) || defined(CONFIG_IMX8) || defined(CONFIG_IMX9) +#elif defined(CONFIG_MX7) || defined(CONFIG_MX7ULP) || defined(CONFIG_IMX8M) || defined(CONFIG_IMX8) || defined(CONFIG_IMX9) /* Translate iMX7/i.MX8M boot device to the SPL boot device enumeration */ u32 spl_boot_device(void) { @@ -160,7 +160,9 @@ u32 spl_boot_device(void) */ if (((bmode >> 24) & 0x03) == 0x01) /* Serial Downloader */ return BOOT_DEVICE_BOARD; +#endif
+#if defined(CONFIG_MX7) || defined(CONFIG_MX7ULP) /* * The above method does not detect that the boot ROM used * serial downloader in case the boot ROM decided to use the @@ -178,7 +180,7 @@ u32 spl_boot_device(void)
return spl_board_boot_device(boot_device_spl); } -#endif /* CONFIG_MX7 || CONFIG_IMX8M || CONFIG_IMX8 */ +#endif /* CONFIG_MX7 || CONFIG_MX7ULP || CONFIG_IMX8M || CONFIG_IMX8 */
#ifdef CONFIG_SPL_USB_GADGET int g_dnl_bind_fixup(struct usb_device_descriptor *dev, const char *name) diff --git a/include/configs/imx7ulp_spl.h b/include/configs/imx7ulp_spl.h new file mode 100644 index 00000000000..516238ec02e --- /dev/null +++ b/include/configs/imx7ulp_spl.h @@ -0,0 +1,39 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * SPL definitions for the i.MX7ULP SPL + * + * (C) Copyright 2019 Foundries.io + */ + +#ifndef __IMX7ULP_SPL_CONFIG_H +#define __IMX7ULP_SPL_CONFIG_H + +#if CONFIG_IS_ENABLED(SPL) +/* + * see figure 35-5 in i.MX 7ULP Reference manual: + * - IMX7ULP A7 OCRAM free area RAM is from 0x2F010000 to 0x2F03FF00. + * - Set the stack at the end of the free area section, at 0x2003FEB8. + * - The BOOT ROM loads what they consider the firmware image + * which consists of a 4K header in front of us that contains the IVT, DCD, + * and some padding thus 'our' max size is really 0x2F03FF00 - 0x2F011000. + * 187KB is more than enough for the SPL. + */ +#define CONFIG_SPL_STACK 0x2F03FEB8 + +/* MMC support */ +#if CONFIG_IS_ENABLED(SPL_MMC) +#define CONFIG_SYS_MMCSD_FS_BOOT_PARTITION 1 +#define CONFIG_SYS_MONITOR_LEN 409600 /* 400 KB */ +#endif + +/* Define the payload for FAT/EXT support */ +#if CONFIG_IS_ENABLED(SPL_FS_FAT) || CONFIG_IS_ENABLED(SPL_FS_EXT4) +#define CONFIG_SPL_FS_LOAD_PAYLOAD_NAME "u-boot-dtb.img" +#endif + +#define CONFIG_SYS_SPL_MALLOC_START 0x68300000 +#define CONFIG_SYS_SPL_MALLOC_SIZE 0x100000 /* 1 MB */ + +#endif /* CONFIG_SPL */ + +#endif /* __IMX7ULP_SPL_CONFIG_H */
There is a paired to ifdef comment which should include CONFIG_IMX9 as well.
Fixes: 881df6ed84c ("imx: add basic i.MX9 support") Signed-off-by: Oleksandr Suvorov oleksandr.suvorov@foundries.io ---
Changes in v4: - add a small fix for imx spl.
arch/arm/mach-imx/spl.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/mach-imx/spl.c b/arch/arm/mach-imx/spl.c index bca0b1123a7..46fb1b388cc 100644 --- a/arch/arm/mach-imx/spl.c +++ b/arch/arm/mach-imx/spl.c @@ -180,7 +180,7 @@ u32 spl_boot_device(void)
return spl_board_boot_device(boot_device_spl); } -#endif /* CONFIG_MX7 || CONFIG_MX7ULP || CONFIG_IMX8M || CONFIG_IMX8 */ +#endif /* CONFIG_MX7 || CONFIG_MX7ULP || CONFIG_IMX8M || CONFIG_IMX8 || CONFIG_IMX9 */
There is a paired to ifdef comment which should include CONFIG_IMX9 as well. Fixes: 881df6ed84c ("imx: add basic i.MX9 support") Signed-off-by: Oleksandr Suvorov oleksandr.suvorov@foundries.io
Best regards, Stefano Babic
Hi Oleksandr, Ricardo,
Changes in v4:
Changes in v3:
- SPL definitions for the i.MX7ULP SPL
- (C) Copyright 2019 Foundries.io
- see figure 35-5 in i.MX 7ULP Reference manual:
- which consists of a 4K header in front of us that contains the IVT, DCD,
- and some padding thus 'our' max size is really 0x2F03FF00 - 0x2F011000.
- 187KB is more than enough for the SPL.
This should be in defconfig and it is not accepted anymore in header, it raises an error. See :
https://source.denx.de/u-boot/custodians/u-boot-imx/-/jobs/516648
From: Ricardo Salveti ricardo@foundries.io Add a base implementation of mx7ulp SPL config header and soc, and changes in makefiles in order to allow building SPL on mx7ulp based devices. Signed-off-by: Ricardo Salveti ricardo@foundries.io Co-developed-by: Oleksandr Suvorov oleksandr.suvorov@foundries.io Signed-off-by: Oleksandr Suvorov oleksandr.suvorov@foundries.io
Oleksandr Suvorov
sbabic@denx.de
Stefano Babic
