[PATCH] arm: dts: imx7: Fix error in coresight TPIU graph connection
OF graph endpoint connections must be bidirectional and dtc warn if they are not. i.MX7 based DTs have an error and generate warnings:
arch/arm/dts/imx7d-sdb.dtb: Warning (graph_endpoint): /replicator/ports/port@0/endpoint: graph connection to node '/soc/tpiu@30087000/port/endpoint' is not bidirectional arch/arm/dts/imx7d-sdb.dtb: Warning (graph_endpoint): /soc/tpiu@30087000/port/endpoint: graph connection to node '/replicator/ports/port@1/endpoint' is not bidirectional
Signed-off-by: Ilko Iliev iliev@ronetix.at --- arch/arm/dts/imx7s.dtsi | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/dts/imx7s.dtsi b/arch/arm/dts/imx7s.dtsi index 5c2e98be06..967023fde1 100644 --- a/arch/arm/dts/imx7s.dtsi +++ b/arch/arm/dts/imx7s.dtsi @@ -323,7 +323,7 @@ port { tpiu_in_port: endpoint { slave-mode; - remote-endpoint = <&replicator_out_port1>; + remote-endpoint = <&replicator_out_port0>; }; }; };
OF graph endpoint connections must be bidirectional and dtc warn if they are not. i.MX7 based DTs have an error and generate warnings: arch/arm/dts/imx7d-sdb.dtb: Warning (graph_endpoint): /replicator/ports/port@0/endpoint: graph connection to node '/soc/tpiu@30087000/port/endpoint' is not bidirectional arch/arm/dts/imx7d-sdb.dtb: Warning (graph_endpoint): /soc/tpiu@30087000/port/endpoint: graph connection to node '/replicator/ports/port@1/endpoint' is not bidirectional Signed-off-by: Ilko Iliev iliev@ronetix.at
Best regards, Stefano Babic
Ilko Iliev
sbabic@denx.de
