[U-Boot] [PATCH] sh: add support Renesas SH7723
Renesas SH7723 has 5 SCIF, SD, Camera, LCDC and other. This patch supports CPU register's header file and SCIF serial driver.
Signed-off-by: Nobuhiro Iwamatsu iwamatsu.nobuhiro@renesas.com --- drivers/serial/serial_sh.c | 46 +++++++--- include/asm-sh/cpu_sh4.h | 2 + include/asm-sh/cpu_sh7723.h | 209 +++++++++++++++++++++++++++++++++++++++++++ 3 files changed, 245 insertions(+), 12 deletions(-) create mode 100644 include/asm-sh/cpu_sh7723.h
diff --git a/drivers/serial/serial_sh.c b/drivers/serial/serial_sh.c index 2b9eeed..6944523 100644 --- a/drivers/serial/serial_sh.c +++ b/drivers/serial/serial_sh.c @@ -20,14 +20,20 @@ #include <common.h> #include <asm/processor.h>
-#if defined (CONFIG_CONS_SCIF0) -#define SCIF_BASE SCIF0_BASE -#elif defined (CONFIG_CONS_SCIF1) -#define SCIF_BASE SCIF1_BASE -#elif defined (CONFIG_CONS_SCIF2) -#define SCIF_BASE SCIF2_BASE +#if defined(CONFIG_CONS_SCIF0) +# define SCIF_BASE SCIF0_BASE +#elif defined(CONFIG_CONS_SCIF1) +# define SCIF_BASE SCIF1_BASE +#elif defined(CONFIG_CONS_SCIF2) +# define SCIF_BASE SCIF2_BASE +#elif defined(CONFIG_CONS_SCIF3) +# define SCIF_BASE SCIF3_BASE +#elif defined(CONFIG_CONS_SCIF4) +# define SCIF_BASE SCIF4_BASE +#elif defined(CONFIG_CONS_SCIF5) +# define SCIF_BASE SCIF5_BASE #else -#error "Default SCIF doesn't set....." +# error "Default SCIF doesn't set....." #endif
/* Base register */ @@ -36,7 +42,8 @@ #define SCSCR (vu_short *)(SCIF_BASE + 0x8) #define SCFCR (vu_short *)(SCIF_BASE + 0x18) #define SCFDR (vu_short *)(SCIF_BASE + 0x1C) -#ifdef CONFIG_CPU_SH7720 /* SH7720 specific */ +#if defined(CONFIG_CPU_SH7720) || \ + (defined(CONFIG_CPU_SH7723) && defined(CONFIG_SCIF_A)) # define SCFSR (vu_short *)(SCIF_BASE + 0x14) /* SCSSR */ # define SCFTDR (vu_char *)(SCIF_BASE + 0x20) # define SCFRDR (vu_char *)(SCIF_BASE + 0x24) @@ -55,7 +62,7 @@ # define LSR_ORER 1 # define FIFOLEVEL_MASK 0xFF #elif defined(CONFIG_CPU_SH7763) -# if defined (CONFIG_CONS_SCIF2) +# if defined(CONFIG_CONS_SCIF2) # define SCSPTR (vu_short *)(SCIF_BASE + 0x20) # define SCLSR (vu_short *)(SCIF_BASE + 0x24) # define LSR_ORER 1 @@ -68,6 +75,16 @@ # define LSR_ORER 1 # define FIFOLEVEL_MASK 0xFF # endif +#elif defined(CONFIG_CPU_SH7723) +# if defined(CONIFG_SCIF_A) +# define SCLSR SCFSR +# define LSR_ORER 0x0200 +# define FIFOLEVEL_MASK 0x3F +#else +# define SCLSR (vu_short *)(SCIF_BASE + 0x24) +# define LSR_ORER 1 +# define FIFOLEVEL_MASK 0x1F +#endif #elif defined(CONFIG_CPU_SH7750) || \ defined(CONFIG_CPU_SH7751) || \ defined(CONFIG_CPU_SH7722) @@ -89,6 +106,9 @@ /* SCBRR register value setting */ #if defined(CONFIG_CPU_SH7720) # define SCBRR_VALUE(bps, clk) (((clk*2)+16*bps)/(32*bps)-1) +#elif defined(CONFIG_CPU_SH7723) && defined(CONFIG_SCIF_A) +/* SH7723 SCIFA use bus clock. So clock *2 */ +# define SCBRR_VALUE(bps, clk) (((clk*2*2)+16*bps)/(32*bps)-1) #else /* Generic SuperH */ # define SCBRR_VALUE(bps, clk) ((clk+16*bps)/(32*bps)-1) #endif @@ -167,7 +187,7 @@ void serial_puts(const char *s)
int serial_tstc(void) { - return serial_rx_fifo_level()? 1 : 0; + return serial_rx_fifo_level() ? 1 : 0; }
#define FSR_ERR_CLEAR 0x0063 @@ -191,14 +211,16 @@ int serial_getc_check(void) handle_error(); if (*SCLSR & LSR_ORER) handle_error(); - return (status & (FSR_DR | FSR_RDF)); + return status & (FSR_DR | FSR_RDF); }
int serial_getc(void) { unsigned short status; char ch; - while (!serial_getc_check()) ; + + while (!serial_getc_check()) + ;
ch = *SCFRDR; status = *SCFSR; diff --git a/include/asm-sh/cpu_sh4.h b/include/asm-sh/cpu_sh4.h index 5a8a5a1..05d9c2c 100644 --- a/include/asm-sh/cpu_sh4.h +++ b/include/asm-sh/cpu_sh4.h @@ -35,6 +35,8 @@ # include <asm/cpu_sh7750.h> #elif defined (CONFIG_CPU_SH7722) # include <asm/cpu_sh7722.h> +#elif defined (CONFIG_CPU_SH7723) +# include <asm/cpu_sh7723.h> #elif defined (CONFIG_CPU_SH7763) # include <asm/cpu_sh7763.h> #elif defined (CONFIG_CPU_SH7780) diff --git a/include/asm-sh/cpu_sh7723.h b/include/asm-sh/cpu_sh7723.h new file mode 100644 index 0000000..6dac6e9 --- /dev/null +++ b/include/asm-sh/cpu_sh7723.h @@ -0,0 +1,209 @@ +/* + * (C) Copyright 2008 Renesas Solutions Corp. + * + * SH7723 Internal I/O register + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef _ASM_CPU_SH7723_H_ +#define _ASM_CPU_SH7723_H_ + +#define CACHE_OC_NUM_WAYS 4 +#define CCR_CACHE_INIT 0x0000090d + +/* EXP */ +#define TRA 0xFF000020 +#define EXPEVT 0xFF000024 +#define INTEVT 0xFF000028 + +/* MMU */ +#define PTEH 0xFF000000 +#define PTEL 0xFF000004 +#define TTB 0xFF000008 +#define TEA 0xFF00000C +#define MMUCR 0xFF000010 +#define PASCR 0xFF000070 +#define IRMCR 0xFF000078 + +/* CACHE */ +#define CCR 0xFF00001C +#define RAMCR 0xFF000074 + +/* INTC */ + +/* BSC */ +#define CMNCR 0xFEC10000 +#define CS0BCR 0xFEC10004 +#define CS2BCR 0xFEC10008 +#define CS4BCR 0xFEC10010 +#define CS5ABCR 0xFEC10014 +#define CS5BBCR 0xFEC10018 +#define CS6ABCR 0xFEC1001C +#define CS6BBCR 0xFEC10020 +#define CS0WCR 0xFEC10024 +#define CS2WCR 0xFEC10028 +#define CS4WCR 0xFEC10030 +#define CS5AWCR 0xFEC10034 +#define CS5BWCR 0xFEC10038 +#define CS6AWCR 0xFEC1003C +#define CS6BWCR 0xFEC10040 +#define RBWTCNT 0xFEC10054 + +/* SBSC */ +#define SBSC_SDCR 0xFE400008 +#define SBSC_SDWCR 0xFE40000C +#define SBSC_SDPCR 0xFE400010 +#define SBSC_RTCSR 0xFE400014 +#define SBSC_RTCNT 0xFE400018 +#define SBSC_RTCOR 0xFE40001C +#define SBSC_RFCR 0xFE400020 + +/* DMAC */ + +/* CPG */ +#define FRQCR 0xA4150000 +#define VCLKCR 0xA4150004 +#define SCLKACR 0xA4150008 +#define SCLKBCR 0xA415000C +#define IRDACLKCR 0xA4150018 +#define PLLCR 0xA4150024 +#define DLLFRQ 0xA4150050 + +/* LOW POWER MODE */ +#define STBCR 0xA4150020 +#define MSTPCR0 0xA4150030 +#define MSTPCR1 0xA4150034 +#define MSTPCR2 0xA4150038 + +/* RWDT */ +#define RWTCNT 0xA4520000 +#define RWTCSR 0xA4520004 +#define WTCNT RWTCNT + +/* TMU */ +#define TSTR 0xFFD80004 +#define TCOR0 0xFFD80008 +#define TCNT0 0xFFD8000C +#define TCR0 0xFFD80010 +#define TCOR1 0xFFD80014 +#define TCNT1 0xFFD80018 +#define TCR1 0xFFD8001C +#define TCOR2 0xFFD80020 +#define TCNT2 0xFFD80024 +#define TCR2 0xFFD80028 + +/* TPU */ + +/* CMT */ +#define CMSTR 0xA44A0000 +#define CMCSR 0xA44A0060 +#define CMCNT 0xA44A0064 +#define CMCOR 0xA44A0068 + +/* MSIOF */ + +/* SCIF */ +#define SCIF0_BASE 0xFFE00000 +#define SCIF1_BASE 0xFFE10000 +#define SCIF2_BASE 0xFFE20000 +#define SCIF3_BASE 0xa4e30000 +#define SCIF4_BASE 0xa4e40000 +#define SCIF5_BASE 0xa4e50000 + +/* RTC */ +/* IrDA */ +/* KEYSC */ +/* USB */ +/* IIC */ +/* FLCTL */ +/* VPU */ +/* VIO(CEU) */ +/* VIO(VEU) */ +/* VIO(BEU) */ +/* 2DG */ +/* LCDC */ +/* VOU */ +/* TSIF */ +/* SIU */ +/* ATAPI */ + +/* PFC */ +#define PACR 0xA4050100 +#define PBCR 0xA4050102 +#define PCCR 0xA4050104 +#define PDCR 0xA4050106 +#define PECR 0xA4050108 +#define PFCR 0xA405010A +#define PGCR 0xA405010C +#define PHCR 0xA405010E +#define PJCR 0xA4050110 +#define PKCR 0xA4050112 +#define PLCR 0xA4050114 +#define PMCR 0xA4050116 +#define PNCR 0xA4050118 +#define PQCR 0xA405011A +#define PRCR 0xA405011C +#define PSCR 0xA405011E +#define PTCR 0xA4050140 +#define PUCR 0xA4050142 +#define PVCR 0xA4050144 +#define PWCR 0xA4050146 +#define PXCR 0xA4050148 +#define PYCR 0xA405014A +#define PZCR 0xA405014C +#define PSELA 0xA405014E +#define PSELB 0xA4050150 +#define PSELC 0xA4050152 +#define PSELD 0xA4050154 +#define HIZCRA 0xA4050158 +#define HIZCRB 0xA405015A +#define HIZCRC 0xA405015C +#define HIZCRD 0xA405015E +#define MSELCRA 0xA4050180 +#define MSELCRB 0xA4050182 +#define PULCR 0xA4050184 +#define DRVCRA 0xA405018A +#define DRVCRB 0xA405018C + +/* I/O Port */ +#define PADR 0xA4050120 +#define PBDR 0xA4050122 +#define PCDR 0xA4050124 +#define PDDR 0xA4050126 +#define PEDR 0xA4050128 +#define PFDR 0xA405012A +#define PGDR 0xA405012C +#define PHDR 0xA405012E +#define PJDR 0xA4050130 +#define PKDR 0xA4050132 +#define PLDR 0xA4050134 +#define PMDR 0xA4050136 +#define PNDR 0xA4050138 +#define PQDR 0xA405013A +#define PRDR 0xA405013C +#define PSDR 0xA405013E +#define PTDR 0xA4050160 +#define PUDR 0xA4050162 +#define PVDR 0xA4050164 +#define PWDR 0xA4050166 +#define PYDR 0xA4050168 +#define PZDR 0xA405016A + +/* UBC */ +/* H-UDI */ + +#endif /* _ASM_CPU_SH7723_H_ */
Nobuhiro Iwamatsu
