[U-Boot-Users] [PATCH] syscon3: remove redundant and unused code
Remove board_early_init_r() - not used for this board.
Remove ft_board_setup() - redundant as now handled by weak default routine, see commit "ppc4xx: Add weak default ft_board_setup() routine"
Signed-off-by: Wolfgang Denk wd@denx.de --- board/syscon3/syscon3.c | 35 ----------------------------------- 1 files changed, 0 insertions(+), 35 deletions(-)
diff --git a/board/syscon3/syscon3.c b/board/syscon3/syscon3.c index b814bae..d4ef569 100644 --- a/board/syscon3/syscon3.c +++ b/board/syscon3/syscon3.c @@ -132,7 +132,6 @@ int misc_init_r (void) */ void local_bus_init (void) { - volatile ccsr_lbc_t *lbc = (void *)(CFG_MPC85xx_LBC_ADDR); volatile ccsr_local_ecm_t *ecm = (void *)(CFG_MPC85xx_ECM_ADDR);
@@ -160,7 +159,6 @@ static struct pci_config_table pci_mpc85xxads_config_table[] = { }; #endif
- static struct pci_controller hose = { #ifndef CONFIG_PCI_PNP config_table:pci_mpc85xxads_config_table, @@ -176,36 +174,3 @@ void pci_init_board (void) pci_mpc85xx_init (&hose); #endif /* CONFIG_PCI */ } - -#ifdef CONFIG_BOARD_EARLY_INIT_R -int board_early_init_r (void) -{ -#ifdef CONFIG_PS2MULT - ps2mult_early_init(); -#endif /* CONFIG_PS2MULT */ - return (0); -} -#endif /* CONFIG_BOARD_EARLY_INIT_R */ - -#if defined(CONFIG_OF_LIBFDT) && defined(CONFIG_OF_BOARD_SETUP) -void -ft_board_setup(void *blob, bd_t *bd) -{ - u32 val[4]; - int rc; - - ft_cpu_setup(blob, bd); - - /* Fixup NOR mapping */ - val[0] = 0; /* chip select number */ - val[1] = 0; /* always 0 */ - val[2] = gd->bd->bi_flashstart; - val[3] = gd->bd->bi_flashsize; - - rc = fdt_find_and_setprop(blob, "/localbus", "ranges", - val, sizeof(val), 1); - if (rc) - printf("Unable to update property NOR mapping, err=%s\n", - fdt_strerror(rc)); -} -#endif /* defined(CONFIG_OF_LIBFDT) && defined(CONFIG_OF_BOARD_SETUP) */
