[PATCH v6 0/4] arch: riscv: jh7110: Correctly zero L2 LIM
This series is the sixth version of Bo Gan's L2 LIM series.
Background information: JH7110 SPL runs in L2 LIM (2M in size mapped at 0x8000000). It consists of 16 0x20000 sized regions, each one can be used as either L2 cache way or SRAM (not both). From top to bottom, there're ways 0-15. The way 0 is always enabled, at most 0x1e0000 can be used.
In SPL, we don't enable any cache ways, thus all 15 (except way 0) ways can be used. However, due to HW requirement, we must zero the LIM before use. This is because ECC is applied to LIM, and if not cleared first, the ECC part is invalid, which can trigger ECC errors when reading/writing data.
There are several issues currently. We clear L2 LIM from __bss_end to 0x81FFFFF in `harts_early_init`. This is wrong because:
1. Each hart (in the middle of a function call) overwriting its own stack and other harts' stacks. (data-race and data-corruption) 2. Lottery winner hart can be doing `board_init_f_init_reserve`, while other harts're in the middle of zeroing L2 LIM. (data-race)
To fix this, we split the job, such that there's one and only one owner of zeroing a specific region (No data-race). A new SPL config option `SPL_ZERO_MEM_BEFORE_USE` is introduced. Allowing The zeroing to happen in the same code path. (much easier to reason about).
Besides, currently we use DDR ram for SPL malloc arena on Visionfive 2 board in defconfig, but it's also possible to use L2 LIM as SPL malloc arena. To avoid triggering ECC error in this scenario, we add support SYS_MALLOC_CLEAR_ON_INIT in SPL, and imply SPL_SYS_MALLOC_CLEAR_ON_INIT on JH7110 as default.
Changes since v1: - Separate single patch into several patches
Changes since v2: - Fix typo (ZERO_MEM_BEFORE_USE to SPL_ZERO_MEM_BEFORE_USE)
Changes since v3: - Revert v3's fix since original implementation is actually right
Changes since v4: - Add support for SPL_SYS_MALLOC_CLEAR_ON_INIT - Remove already merged patches
Changes since v5: - Fix whitespace in patch 1 - Disable SYS_MALLOC_CLEAR_ON_INIT by default on Visionfive 2
Shengyu Qu (4): Kconfig: Add SPL_SYS_MALLOC_CLEAR_ON_INIT dlmalloc: Add support for SPL_SYS_MALLOC_CLEAR_ON_INIT riscv: cpu: jh7110: Imply SPL_SYS_MALLOC_CLEAR_ON_INIT configs: starfive: Disable SYS_MALLOC_CLEAR_ON_INIT by default
Kconfig | 11 +++++++++++ arch/riscv/cpu/jh7110/Kconfig | 1 + common/dlmalloc.c | 6 +++--- configs/starfive_visionfive2_defconfig | 2 ++ 4 files changed, 17 insertions(+), 3 deletions(-)
Shengyu Qu
