[U-Boot] [PATCH] AT91: Enable PLLB for USB
At least some (old ?) versions of the AT91Bootstrap do not set up the PLLB correctly to 48 MHz in order to make USB host function correctly.
This patch sets up the PLLB to the same values Linux uses, and makes USB work ok on the following CPUs: - AT91CAP9 - AT91SAM9260 - AT91SAM9263
This patch also defines CONFIG_USB_STORAGE and CONFIG_CMD_FAT for all the relevant AT91CAP9/AT91SAM9 boards.
Signed-off-by: Stelian Pop stelian@popies.net --- cpu/arm926ejs/at91/usb.c | 18 ++++++++++++++++++ include/configs/at91cap9adk.h | 3 +++ include/configs/at91sam9260ek.h | 2 ++ include/configs/at91sam9261ek.h | 1 + include/configs/at91sam9263ek.h | 2 ++ 5 files changed, 26 insertions(+), 0 deletions(-)
diff --git a/cpu/arm926ejs/at91/usb.c b/cpu/arm926ejs/at91/usb.c index 2a92f73..c02334f 100644 --- a/cpu/arm926ejs/at91/usb.c +++ b/cpu/arm926ejs/at91/usb.c @@ -31,6 +31,15 @@
int usb_cpu_init(void) { + +#if defined(CONFIG_AT91CAP9) || defined(CONFIG_AT91SAM9260) || \ + defined(CONFIG_AT91SAM9263) + /* Enable PLLB */ + at91_sys_write(AT91_CKGR_PLLBR, CFG_AT91_PLLB); + while ((at91_sys_read(AT91_PMC_SR) & AT91_PMC_LOCKB) != AT91_PMC_LOCKB) + ; +#endif + /* Enable USB host clock. */ at91_sys_write(AT91_PMC_PCER, 1 << AT91_ID_UHP); #ifdef CONFIG_AT91SAM9261 @@ -51,6 +60,15 @@ int usb_cpu_stop(void) #else at91_sys_write(AT91_PMC_SCDR, AT91_PMC_UHP); #endif + +#if defined(CONFIG_AT91CAP9) || defined(CONFIG_AT91SAM9260) || \ + defined(CONFIG_AT91SAM9263) + /* Disable PLLB */ + at91_sys_write(AT91_CKGR_PLLBR, 0); + while ((at91_sys_read(AT91_PMC_SR) & AT91_PMC_LOCKB) != 0) + ; +#endif + return 0; }
diff --git a/include/configs/at91cap9adk.h b/include/configs/at91cap9adk.h index 1dbd3a4..47145d8 100644 --- a/include/configs/at91cap9adk.h +++ b/include/configs/at91cap9adk.h @@ -32,6 +32,7 @@ #define AT91_MAIN_CLOCK 12000000 /* 12 MHz crystal */ #define AT91_MASTER_CLOCK 100000000 /* peripheral */ #define AT91_CPU_CLOCK 200000000 /* cpu */ +#define CFG_AT91_PLLB 0x10073e01 /* PLLB settings for USB */ #define CFG_HZ 1000000 /* 1us resolution */
#define AT91_SLOW_CLOCK 32768 /* slow clock */ @@ -137,6 +138,8 @@ #define CFG_USB_OHCI_REGS_BASE 0x00700000 /* AT91_BASE_UHP */ #define CFG_USB_OHCI_SLOT_NAME "at91cap9" #define CFG_USB_OHCI_MAX_ROOT_PORTS 2 +#define CONFIG_USB_STORAGE 1 +#define CONFIG_CMD_FAT 1
#define CFG_LOAD_ADDR 0x72000000 /* load address */
diff --git a/include/configs/at91sam9260ek.h b/include/configs/at91sam9260ek.h index cb8857a..cd09288 100644 --- a/include/configs/at91sam9260ek.h +++ b/include/configs/at91sam9260ek.h @@ -32,6 +32,7 @@ #define AT91_MAIN_CLOCK 18432000 /* 18.432 MHz crystal */ #define AT91_MASTER_CLOCK 100000000 /* peripheral */ #define AT91_CPU_CLOCK 200000000 /* cpu */ +#define CFG_AT91_PLLB 0x107c3e18 /* PLLB settings for USB */ #define CFG_HZ 1000000 /* 1us resolution */
#define AT91_SLOW_CLOCK 32768 /* slow clock */ @@ -123,6 +124,7 @@ #define CFG_USB_OHCI_SLOT_NAME "at91sam9260" #define CFG_USB_OHCI_MAX_ROOT_PORTS 2 #define CONFIG_USB_STORAGE 1 +#define CONFIG_CMD_FAT 1
#define CFG_LOAD_ADDR 0x22000000 /* load address */
diff --git a/include/configs/at91sam9261ek.h b/include/configs/at91sam9261ek.h index 92e134d..aa6c6ab 100644 --- a/include/configs/at91sam9261ek.h +++ b/include/configs/at91sam9261ek.h @@ -137,6 +137,7 @@ #define CFG_USB_OHCI_SLOT_NAME "at91sam9261" #define CFG_USB_OHCI_MAX_ROOT_PORTS 2 #define CONFIG_USB_STORAGE 1 +#define CONFIG_CMD_FAT 1
diff --git a/include/configs/at91sam9263ek.h b/include/configs/at91sam9263ek.h index c914571..1e9c5c5 100644 --- a/include/configs/at91sam9263ek.h +++ b/include/configs/at91sam9263ek.h @@ -32,6 +32,7 @@ #define AT91_MAIN_CLOCK 16367660 /* 16.367 MHz crystal */ #define AT91_MASTER_CLOCK 100000000 /* peripheral */ #define AT91_CPU_CLOCK 200000000 /* cpu */ +#define CFG_AT91_PLLB 0x133a3e8d /* PLLB settings for USB */ #define CFG_HZ 1000000 /* 1us resolution */
#define AT91_SLOW_CLOCK 32768 /* slow clock */ @@ -143,6 +144,7 @@ #define CFG_USB_OHCI_SLOT_NAME "at91sam9263" #define CFG_USB_OHCI_MAX_ROOT_PORTS 2 #define CONFIG_USB_STORAGE 1 +#define CONFIG_CMD_FAT 1
Hello Stelian,
2008/10/21 Stelian Pop stelian@popies.net:
Are all your USB stick problems solved by now? Including that stick that did not work?
I noticed that (with my latest patchset) sometimes a cold boot result in a non-working USB stick on my boards, but a hard reset always worked...
I will try your patches tomorrow, but I have one question:
Are such nice rounded values possible with that unrounded crystal?
Looking at sam9261 I see: #define AT91_MAIN_CLOCK 198656000 /* from 18.432 MHz crystal */ #define AT91_MASTER_CLOCK 99328000 /* peripheral = main / 2
This seems more logical to me, but I may be wrong...
Kind Regards,
Remy
- defined(CONFIG_AT91SAM9263)
/* Enable PLLB */
/* Disable PLLB */
-- 1.5.4.3
Le mardi 21 octobre 2008 à 19:54 +0200, Remy Bohmer a écrit :
Hello Stelian,
Hi Remy,
Nope. I still have one (kinda old) stick which does not work, on any AT91 board. But I suspect the issues are no longer in the board/cpu code, but in the core USB layer.
This one is clearly wrong. 18.432 MHz is 18432000 Hz.
And the master clock is not main / 2, but PLLA / 2, where PLLA is initialized by the bootstrap to (main * 0x60) / 9.
This gives: PLLA = 18432000 * 0x60 / 9 = 196608000 Hz MASTER = 196608000 / 2 = 98304000 Hz.
The defines in the header files contain rounded values, I don't think it's too important to be precise here.
Stelian.
- AT91CAP9
- AT91SAM9260
- AT91SAM9263
failed to apply
could you rebase it against u-boot-at91?
Best Regards, J.
Le jeudi 06 novembre 2008 à 20:27 +0100, Jean-Christophe PLAGNIOL-VILLARD a écrit :
- AT91CAP9
- AT91SAM9260
- AT91SAM9263
failed to apply
Here it is.
Thanks,
Stelian.
From 87abe92b4c34d8deb58f0743d2f4ffca3bd8bf6c Mon Sep 17 00:00:00 2001
From: Stelian Pop stelian@popies.net Date: Thu, 6 Nov 2008 22:51:32 +0100 Subject: [PATCH] AT91: Enable PLLB for USB
diff --git a/cpu/arm926ejs/at91/usb.c b/cpu/arm926ejs/at91/usb.c index 7cb082d..2f5c337 100644 --- a/cpu/arm926ejs/at91/usb.c +++ b/cpu/arm926ejs/at91/usb.c @@ -31,6 +31,15 @@
diff --git a/include/configs/at91cap9adk.h b/include/configs/at91cap9adk.h index 667e049..aeb06ac 100644 --- a/include/configs/at91cap9adk.h +++ b/include/configs/at91cap9adk.h @@ -32,6 +32,7 @@ #define AT91_MAIN_CLOCK 12000000 /* 12 MHz crystal */ #define AT91_MASTER_CLOCK 100000000 /* peripheral */ #define AT91_CPU_CLOCK 200000000 /* cpu */ +#define CFG_AT91_PLLB 0x10073e01 /* PLLB settings for USB */ #define CONFIG_SYS_HZ 1000000 /* 1us resolution */
#define AT91_SLOW_CLOCK 32768 /* slow clock */ @@ -137,6 +138,8 @@ #define CONFIG_SYS_USB_OHCI_REGS_BASE 0x00700000 /* AT91_BASE_UHP */ #define CONFIG_SYS_USB_OHCI_SLOT_NAME "at91cap9" #define CONFIG_SYS_USB_OHCI_MAX_ROOT_PORTS 2 +#define CONFIG_USB_STORAGE 1 +#define CONFIG_CMD_FAT 1
#define CONFIG_SYS_LOAD_ADDR 0x72000000 /* load address */
diff --git a/include/configs/at91sam9260ek.h b/include/configs/at91sam9260ek.h index 81c8d39..fbc470f 100644 --- a/include/configs/at91sam9260ek.h +++ b/include/configs/at91sam9260ek.h @@ -32,6 +32,7 @@ #define AT91_MAIN_CLOCK 18432000 /* 18.432 MHz crystal */ #define AT91_MASTER_CLOCK 100000000 /* peripheral */ #define AT91_CPU_CLOCK 200000000 /* cpu */ +#define CFG_AT91_PLLB 0x107c3e18 /* PLLB settings for USB */ #define CONFIG_SYS_HZ 1000000 /* 1us resolution */
#define AT91_SLOW_CLOCK 32768 /* slow clock */ @@ -123,6 +124,7 @@ #define CONFIG_SYS_USB_OHCI_SLOT_NAME "at91sam9260" #define CONFIG_SYS_USB_OHCI_MAX_ROOT_PORTS 2 #define CONFIG_USB_STORAGE 1 +#define CONFIG_CMD_FAT 1
#define CONFIG_SYS_LOAD_ADDR 0x22000000 /* load address */
diff --git a/include/configs/at91sam9261ek.h b/include/configs/at91sam9261ek.h index efe35a4..bd66823 100644 --- a/include/configs/at91sam9261ek.h +++ b/include/configs/at91sam9261ek.h @@ -137,6 +137,7 @@ #define CONFIG_SYS_USB_OHCI_SLOT_NAME "at91sam9261" #define CONFIG_SYS_USB_OHCI_MAX_ROOT_PORTS 2 #define CONFIG_USB_STORAGE 1 +#define CONFIG_CMD_FAT 1
diff --git a/include/configs/at91sam9263ek.h b/include/configs/at91sam9263ek.h index ef5b666..a2b09ca 100644 --- a/include/configs/at91sam9263ek.h +++ b/include/configs/at91sam9263ek.h @@ -32,6 +32,7 @@ #define AT91_MAIN_CLOCK 16367660 /* 16.367 MHz crystal */ #define AT91_MASTER_CLOCK 100000000 /* peripheral */ #define AT91_CPU_CLOCK 200000000 /* cpu */ +#define CFG_AT91_PLLB 0x133a3e8d /* PLLB settings for USB */ #define CONFIG_SYS_HZ 1000000 /* 1us resolution */
#define AT91_SLOW_CLOCK 32768 /* slow clock */ @@ -143,6 +144,7 @@ #define CONFIG_SYS_USB_OHCI_SLOT_NAME "at91sam9263" #define CONFIG_SYS_USB_OHCI_MAX_ROOT_PORTS 2 #define CONFIG_USB_STORAGE 1 +#define CONFIG_CMD_FAT 1
- AT91CAP9
- AT91SAM9260
- AT91SAM9263
failed to apply
Here it is.
Thanks,
Stelian.
Applied to u-boot-at91
Best Regards, J.
Remy Bohmer
Stelian Pop
