[U-Boot] [PATCH] cmd: cp: add missing map_sysmem
The command cp fails on sandbox because the address is used directly. To fix this issue, we call the function map_sysmem to translate the address.
Signed-off-by: Philippe Reynes philippe.reynes@softathome.com --- cmd/mem.c | 16 +++++++++++++--- 1 file changed, 13 insertions(+), 3 deletions(-)
diff --git a/cmd/mem.c b/cmd/mem.c index c6b8038..1757c84 100644 --- a/cmd/mem.c +++ b/cmd/mem.c @@ -303,6 +303,7 @@ static int do_mem_cmp(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) static int do_mem_cp(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { ulong addr, dest, count; + void *src, *dst; int size;
if (argc != 4) @@ -326,25 +327,34 @@ static int do_mem_cp(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) return 1; }
+ src = map_sysmem(addr, count * size); + dst = map_sysmem(dest, count * size); + #ifdef CONFIG_MTD_NOR_FLASH /* check if we are copying to Flash */ - if (addr2info(dest) != NULL) { + if (addr2info((ulong)dst)) { int rc;
puts ("Copy to Flash... ");
- rc = flash_write ((char *)addr, dest, count*size); + rc = flash_write((char *)src, (ulong)dst, count * size); if (rc != 0) { flash_perror (rc); + unmap_sysmem(src); + unmap_sysmem(dst); return (1); } puts ("done\n"); + unmap_sysmem(src); + unmap_sysmem(dst); return 0; } #endif
- memcpy((void *)dest, (void *)addr, count * size); + memcpy(dst, src, count * size);
Philippe Reynes
