[U-Boot] [PATCH v2 1/1] scripts/coccinelle: add some more coccinelle tests
kmerr: verify that malloc and calloc are followed by a check to verify that we are not out of memory.
badzero: Compare pointer-typed values to NULL rather than 0
Both checks are copied from the Linux kernel archive.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- v2 Add SPDX license identifier --- scripts/coccinelle/null/badzero.cocci | 241 ++++++++++++++++++++++++++++++++++ scripts/coccinelle/null/kmerr.cocci | 75 +++++++++++ 2 files changed, 316 insertions(+) create mode 100644 scripts/coccinelle/null/badzero.cocci create mode 100644 scripts/coccinelle/null/kmerr.cocci
diff --git a/scripts/coccinelle/null/badzero.cocci b/scripts/coccinelle/null/badzero.cocci new file mode 100644 index 00000000000..619b058f93f --- /dev/null +++ b/scripts/coccinelle/null/badzero.cocci @@ -0,0 +1,241 @@ +/// Compare pointer-typed values to NULL rather than 0 +/// +//# This makes an effort to choose between !x and x == NULL. !x is used +//# if it has previously been used with the function used to initialize x. +//# This relies on type information. More type information can be obtained +//# using the option -all_includes and the option -I to specify an +//# include path. +// +// Confidence: High +// Copyright: (C) 2012 Julia Lawall, INRIA/LIP6. GPLv2. +// Copyright: (C) 2012 Gilles Muller, INRIA/LiP6. GPLv2. +// URL: http://coccinelle.lip6.fr/ +// Requires: 1.0.0 +// Options: +// +// SPDX-License-Identifier: GPL-2.0 +// + +virtual patch +virtual context +virtual org +virtual report + +@initialize:ocaml@ +@@ +let negtable = Hashtbl.create 101 + +@depends on patch@ +expression *E; +identifier f; +@@ + +( + (E = f(...)) == +- 0 ++ NULL +| + (E = f(...)) != +- 0 ++ NULL +| +- 0 ++ NULL + == (E = f(...)) +| +- 0 ++ NULL + != (E = f(...)) +) + + +@t1 depends on !patch@ +expression *E; +identifier f; +position p; +@@ + +( + (E = f(...)) == +* 0@p +| + (E = f(...)) != +* 0@p +| +* 0@p + == (E = f(...)) +| +* 0@p + != (E = f(...)) +) + +@script:python depends on org@ +p << t1.p; +@@ + +coccilib.org.print_todo(p[0], "WARNING comparing pointer to 0") + +@script:python depends on report@ +p << t1.p; +@@ + +coccilib.report.print_report(p[0], "WARNING comparing pointer to 0") + +// Tests of returned values + +@s@ +identifier f; +expression E,E1; +@@ + + E = f(...) + ... when != E = E1 + !E + +@script:ocaml depends on s@ +f << s.f; +@@ + +try let _ = Hashtbl.find negtable f in () +with Not_found -> Hashtbl.add negtable f () + +@ r disable is_zero,isnt_zero exists @ +expression *E; +identifier f; +@@ + +E = f(...) +... +(E == 0 +|E != 0 +|0 == E +|0 != E +) + +@script:ocaml@ +f << r.f; +@@ + +try let _ = Hashtbl.find negtable f in () +with Not_found -> include_match false + +// This rule may lead to inconsistent path problems, if E is defined in two +// places +@ depends on patch disable is_zero,isnt_zero @ +expression *E; +expression E1; +identifier r.f; +@@ + +E = f(...) +<... +( +- E == 0 ++ !E +| +- E != 0 ++ E +| +- 0 == E ++ !E +| +- 0 != E ++ E +) +...> +?E = E1 + +@t2 depends on !patch disable is_zero,isnt_zero @ +expression *E; +expression E1; +identifier r.f; +position p1; +position p2; +@@ + +E = f(...) +<... +( +* E == 0@p1 +| +* E != 0@p2 +| +* 0@p1 == E +| +* 0@p1 != E +) +...> +?E = E1 + +@script:python depends on org@ +p << t2.p1; +@@ + +coccilib.org.print_todo(p[0], "WARNING comparing pointer to 0, suggest !E") + +@script:python depends on org@ +p << t2.p2; +@@ + +coccilib.org.print_todo(p[0], "WARNING comparing pointer to 0") + +@script:python depends on report@ +p << t2.p1; +@@ + +coccilib.report.print_report(p[0], "WARNING comparing pointer to 0, suggest !E") + +@script:python depends on report@ +p << t2.p2; +@@ + +coccilib.report.print_report(p[0], "WARNING comparing pointer to 0") + +@ depends on patch disable is_zero,isnt_zero @ +expression *E; +@@ + +( + E == +- 0 ++ NULL +| + E != +- 0 ++ NULL +| +- 0 ++ NULL + == E +| +- 0 ++ NULL + != E +) + +@ t3 depends on !patch disable is_zero,isnt_zero @ +expression *E; +position p; +@@ + +( +* E == 0@p +| +* E != 0@p +| +* 0@p == E +| +* 0@p != E +) + +@script:python depends on org@ +p << t3.p; +@@ + +coccilib.org.print_todo(p[0], "WARNING comparing pointer to 0") + +@script:python depends on report@ +p << t3.p; +@@ + +coccilib.report.print_report(p[0], "WARNING comparing pointer to 0") diff --git a/scripts/coccinelle/null/kmerr.cocci b/scripts/coccinelle/null/kmerr.cocci new file mode 100644 index 00000000000..a1e75e617d0 --- /dev/null +++ b/scripts/coccinelle/null/kmerr.cocci @@ -0,0 +1,75 @@ +/// This semantic patch looks for malloc etc that are not followed by a +/// NULL check. It only gives a report in the case where there is some +/// error handling code later in the function, which may be helpful +/// in determining what the error handling code for the call to malloc etc +/// should be. +/// +// Confidence: High +// Copyright: (C) 2010 Nicolas Palix, DIKU. GPLv2. +// Copyright: (C) 2010 Julia Lawall, DIKU. GPLv2. +// Copyright: (C) 2010 Gilles Muller, INRIA/LiP6. GPLv2. +// URL: http://coccinelle.lip6.fr/ +// Comments: +// Options: --no-includes --include-headers +// +// SPDX-License-Identifier: GPL-2.0 +// + +virtual context +virtual org +virtual report + +@withtest@ +expression x; +position p; +identifier f,fld; +@@ + +x@p = f(...); +... when != x->fld +(x == NULL | x != NULL) + +@fixed depends on context && !org && !report@ +expression x,x1; +position p1 != withtest.p; +statement S; +position any withtest.p; +identifier f; +@@ + +*x@p1 = (malloc|calloc)(...); +... +*x1@p = f(...); +if (!x1) S + +// ------------------------------------------------------------------------ + +@rfixed depends on (org || report) && !context exists@ +expression x,x1; +position p1 != withtest.p; +position p2; +statement S; +position any withtest.p; +identifier f; +@@ + +x@p1 = (malloc|calloc)(...); +... +x1@p = f@p2(...); +if (!x1) S + +@script:python depends on org@ +p1 << rfixed.p1; +p2 << rfixed.p2; +@@ + +cocci.print_main("alloc call",p1) +cocci.print_secs("possible model",p2) + +@script:python depends on report@ +p1 << rfixed.p1; +p2 << rfixed.p2; +@@ + +msg = "alloc with no test, possible model on line %s" % (p2[0].line) +coccilib.report.print_report(p1[0],msg)
