Re: [U-Boot-Users] [PATCH] Fill in remaining MTD driver data for OneNAND (take #2)
Don't cast the return of malloc.
ok.
Why not just declare a static array?
I tried with a static array but it doesn't give the expected result (a quick test with onenand info command returns an empty mtd name), so I used a pointer.
It'd be better to use snprintf, even if you're pretty sure it won't overflow.
I tried it too :) U-Boot doesn't have snprintf or asprintf or I missed something.
Do I need to re-submit the patch only for cast ?
cheers,
Fathi
Odd... Maybe a relocation issue?
Hmm, so it doesn't. That sucks.
No, I'll fix it and apply to nand-flash/testing.
-Scott
Fathi BOUDRA
Scott Wood
