[U-Boot] [PULL request] u-boot-atmel/master
Dear Albert,
The following changes since commit 385d2e0e93ca09fa9f763053afd03076b317228f: Matthias Weisser (1): arm: Update jadecpu board
git://git.denx.de/u-boot-atmel.git master
Andreas Bießmann (1): atstk100x: switch to common cfi driver
andreas.devel@googlemail.com (8): at91rm9200.h: fix ATMEL_PMX_AA_TXD2 arm920t/at91: add clock.c arm920t/at91: use new clock.c features arm920t/at91: add at91rm9200_devices.c at91rm9200ek: use atmel_usart eb_cpux9k2: use atmel_usart cpuat91: use atmel_usart driver/serial: delete at91rm9200_usart
esw@bus-elektronik.de (1): Fix compiler error for cpu at91sam9, if lowlevel init is enabled
arch/arm/cpu/arm920t/at91/Makefile | 3 + arch/arm/cpu/arm920t/at91/at91rm9200_devices.c | 85 ++++++++ arch/arm/cpu/arm920t/at91/clock.c | 160 +++++++++++++++ arch/arm/cpu/arm920t/at91/cpu.c | 43 ++++ arch/arm/cpu/arm926ejs/at91/clock.c | 35 +---- arch/arm/include/asm/arch-at91/at91rm9200.h | 12 +- arch/arm/include/asm/arch-at91/at91sam9_sdramc.h | 2 +- arch/arm/include/asm/arch-at91/clk.h | 42 ++++- board/BuS/eb_cpux9k2/cpux9k2.c | 7 + board/atmel/at91rm9200ek/at91rm9200ek.c | 7 + board/atmel/atstk1000/Makefile | 1 - board/atmel/atstk1000/flash.c | 232 ---------------------- board/eukrea/cpuat91/cpuat91.c | 8 + drivers/serial/Makefile | 1 - drivers/serial/at91rm9200_usart.c | 126 ------------ include/configs/at91rm9200ek.h | 10 +- include/configs/atstk1002.h | 9 +- include/configs/atstk1003.h | 9 +- include/configs/atstk1004.h | 9 +- include/configs/atstk1006.h | 9 +- include/configs/cpuat91.h | 12 +- include/configs/eb_cpux9k2.h | 10 +- 22 files changed, 389 insertions(+), 443 deletions(-) create mode 100644 arch/arm/cpu/arm920t/at91/at91rm9200_devices.c create mode 100644 arch/arm/cpu/arm920t/at91/clock.c create mode 100644 arch/arm/cpu/arm920t/at91/cpu.c delete mode 100644 board/atmel/atstk1000/flash.c delete mode 100644 drivers/serial/at91rm9200_usart.c
Best Regards, Reinhard
Hi Reinhard,
Le 30/06/2011 11:06, Reinhard Meyer a écrit :
Dear Albert,
Applied to u-boot-arm/master, thanks.
Amicalement,
Albert ARIBAUD
Reinhard Meyer
