[U-Boot] Pull request: u-boot-arm/master
Hello Tom,
The following changes since commit b68d6712c379735e886ef9c01b946bc36f295273:
ARM: fix u-boot.lds for -ffunction-sections/-fdata-sections (2012-10-26 23:46:21 +0200)
git://git.denx.de/u-boot-arm master
for you to fetch changes up to 46d626d3926cf6b9f9c477782c5a0ee620a424cd:
socfpga/spl: Remove malloc.h (2012-11-04 16:23:23 +0100)
---------------------------------------------------------------- Albert ARIBAUD (2): Merge remote-tracking branch 'u-boot-imx/master' Merge remote-tracking branch 'u-boot-ti/master'
Allen Martin (5): SPL: make jump_to_image_no_args a weak symbol tegra: move to common SPL framework tegra20: initialize variable to avoid compiler warning serial: remove calls to serial_assign() arm720t: add back common.h include
Andrew Bradford (4): am33xx: Enable UART{1,2,3,4,5} clocks am33xx: Enable UART{1,2,3,4,5} pin-mux serial: ns16550: Enable COM5 and COM6 am335x_evm: Enable use of UART{1,2,3,4,5}
Benoît Thébaudeau (4): mx35: Clean up lowlevel_init mx35: Fix eSDHC clocks mxc: Fix SDHC multi-instance clock mx25: Clean up imx-regs.h
Dirk Behme (1): mx6qsabrelite: enable DCache and MMC bounce buffer
Eric Nelson (7): i.MX: iomux: input pad array can be const i.MX: declare iomux_v3_cfg_t arrays as const i.MX video: struct fb_videomode can be const i.MX: ipufb: add const to fb_videomode declarations i.MX6: set drive strength for parallel RGB pads i.MX6: add HDMI transmitter register declarations from kernel WIP. i.MX6: mx6qsabrelite: Add splash screen support
Fabio Estevam (11): mx6qsabreauto: Pass the board revision to the kernel mx5: lowlevel_init.S: Split init_clock macro mx5: lowlevel_init.S: Fix PLL settings for mx53 mx53loco: Adapt the IPU clock configs: mx53loco: Remove CONFIG_HAS_ETH1 configs: mx51evk: Remove CONFIG_HAS_ETH1 configs: mx53evk: Remove CONFIG_HAS_ETH1 mx5: Add workaround for ARM erratum ID 468414 mx25pdk: Use internal RAM for stack pointer mx6qsabre_common: Enable DCACHE and CONFIG_MMC_BOUNCE_BUFFER mx6qarm2: Enable DCACHE and CONFIG_MMC_BOUNCE_BUFFER
Jens Scharsig (BuS Elektronik) (1): arm: atmel: cpux9k2: add missing cache configs
Koen Kooi (1): am335x: add mux config for DDR3 version of beaglebone
Lucas Stach (2): tegra: add Colibri T20 board support tegra: nand: make ONFI detection work
Marc Dietrich (1): tegra: move common features to a common makefile
Matthias Fuchs (1): am335x: add initial AM335x IDK board support
Otavio Salvador (1): mx6qsabreauto: Change mmcroot so it works out of box
Pali Rohár (4): arm bootm: Allow to pass board specified atags Add power bus message definitions in twl4030.h cfb_console: Add support for some ANSI terminal escape codes New board support: Nokia RX-51 aka N900
Raphael Assenat (1): eco5pk: Add new board and default config
Stefano Babic (1): MX5: fix warning in clock.c
Stephen Warren (10): ARM: tegra: define CONFIG_SYS_BOOTMAPSZ ARM: tegra: use standard variables to define load addresses ARM: tegra: Harmony: enable ULPI USB port ARM: tegra: Seaboard: enable multiple USB ports ARM: tegra: Whistler: remove unused USB alias ARM: enhance u-boot.lds to detect over-sized SPL ARM: tegra: derive CONFIG_SPL_MAX_SIZE instead of hard-coding it ARM: tegra: select between Seaboard/Ventana at compile time ARM: tegra: don't request GPIO from Seaboard's SPL ARM: tegra: combine duplicate Makefile rules
Tom Rini (1): omap3: Rework board.c for !CONFIG_SYS_L2CACHE_OFF
Troy Kisky (7): imximage: check dcd_len as entries added imximage: remove redundant setting of app_dest_ptr imximage: move flash_offset check to common location imximage: fix size of image to load. imximage: delay setting of image size imximage: change parameters to set_imx_hdr imximage: make set_imx_hdr_v1/v2 easier to read
Vikram Narayanan (2): socfpga/spl: Remove timer_init from spl_board_init socfpga/spl: Remove malloc.h
MAINTAINERS | 12 + Makefile | 15 +- README | 4 + arch/arm/cpu/arm1136/mx35/generic.c | 14 +- arch/arm/cpu/arm720t/interrupts.c | 2 + arch/arm/cpu/arm720t/tegra-common/spl.c | 91 +- arch/arm/cpu/armv7/am33xx/clock.c | 35 + arch/arm/cpu/armv7/mx5/clock.c | 2 +- arch/arm/cpu/armv7/mx5/lowlevel_init.S | 158 ++- arch/arm/cpu/armv7/omap3/board.c | 28 +- arch/arm/cpu/armv7/socfpga/spl.c | 4 - arch/arm/cpu/tegra20-common/emc.c | 2 +- arch/arm/cpu/u-boot.lds | 4 + arch/arm/imx-common/iomux-v3.c | 5 +- arch/arm/include/asm/arch-mx25/imx-regs.h | 6 +- arch/arm/include/asm/arch-mx35/clock.h | 4 +- arch/arm/include/asm/arch-mx35/lowlevel_macro.S | 191 ++-- arch/arm/include/asm/arch-mx5/imx-regs.h | 4 + arch/arm/include/asm/arch-mx6/imx-regs.h | 6 + arch/arm/include/asm/arch-mx6/mx6x_pins.h | 58 +- arch/arm/include/asm/arch-mx6/mxc_hdmi.h | 1053 ++++++++++++++++++++ arch/arm/include/asm/arch-tegra20/spl.h | 28 + arch/arm/include/asm/imx-common/iomux-v3.h | 3 +- arch/arm/include/asm/setup.h | 5 + arch/arm/lib/bootm.c | 4 + board/8dtech/eco5pk/Makefile | 43 + board/8dtech/eco5pk/eco5pk.c | 61 ++ board/8dtech/eco5pk/eco5pk.h | 404 ++++++++ board/CarMediaLab/flea3/lowlevel_init.S | 41 - board/avionic-design/medcom-wide/Makefile | 6 +- board/avionic-design/plutux/Makefile | 6 +- board/avionic-design/tec/Makefile | 6 +- board/compal/paz00/Makefile | 6 +- board/compulab/trimslice/Makefile | 6 +- board/esg/ima3-mx53/ima3-mx53.c | 1 + board/freescale/mx35pdk/lowlevel_init.S | 119 +-- board/freescale/mx35pdk/mx35pdk.c | 2 + board/freescale/mx35pdk/mx35pdk.h | 25 - board/freescale/mx51evk/mx51evk.c | 6 +- board/freescale/mx53ard/mx53ard.c | 4 + board/freescale/mx53evk/mx53evk.c | 4 + board/freescale/mx53loco/mx53loco.c | 5 +- board/freescale/mx53smd/mx53smd.c | 3 + board/freescale/mx6qarm2/mx6qarm2.c | 12 +- board/freescale/mx6qsabreauto/mx6qsabreauto.c | 55 +- board/freescale/mx6qsabrelite/mx6qsabrelite.c | 350 ++++++- board/freescale/mx6qsabresd/mx6qsabresd.c | 7 +- board/genesi/mx51_efikamx/efikamx.c | 20 +- board/nokia/rx51/Makefile | 46 + board/nokia/rx51/lowlevel_init.S | 209 ++++ board/nokia/rx51/rx51.c | 677 +++++++++++++ board/nokia/rx51/rx51.h | 389 ++++++++ board/nokia/rx51/tag_omap.h | 311 ++++++ board/nvidia/common/Makefile | 4 +- board/nvidia/common/common.mk | 4 + board/nvidia/dts/tegra20-harmony.dts | 3 +- board/nvidia/dts/tegra20-whistler.dts | 5 +- board/nvidia/harmony/harmony.c | 9 + board/nvidia/seaboard/seaboard.c | 18 +- board/ti/am335x/board.c | 24 +- board/ti/am335x/board.h | 5 + board/ti/am335x/mux.c | 80 ++ .../colibri_t20-common/colibri_t20-common.c | 44 + .../colibri_t20-common/colibri_t20-common.h | 16 + board/toradex/colibri_t20_iris/Makefile | 40 + board/toradex/colibri_t20_iris/colibri_t20_iris.c | 46 + board/toradex/dts/tegra20-colibri_t20_iris.dts | 38 + board/ttcontrol/vision2/vision2.c | 4 +- boards.cfg | 10 +- common/cmd_nvedit.c | 3 - common/iomux.c | 10 - common/spl/spl.c | 8 +- doc/README.nokia_rx51 | 104 ++ drivers/mmc/fsl_esdhc.c | 5 +- drivers/mtd/nand/tegra_nand.c | 36 + drivers/serial/serial_ns16550.c | 36 +- drivers/video/cfb_console.c | 328 +++++- drivers/video/mxc_ipuv3_fb.c | 8 +- include/configs/am335x_evm.h | 12 +- include/configs/colibri_t20_iris.h | 83 ++ include/configs/eb_cpux9k2.h | 5 +- include/configs/eco5pk.h | 81 ++ include/configs/harmony.h | 3 + include/configs/mx25pdk.h | 11 +- include/configs/mx51evk.h | 1 - include/configs/mx53evk.h | 1 - include/configs/mx53loco.h | 3 +- include/configs/mx6qarm2.h | 3 +- include/configs/mx6qsabre_common.h | 5 +- include/configs/mx6qsabreauto.h | 3 +- include/configs/mx6qsabrelite.h | 18 +- include/configs/mx6qsabresd.h | 1 + include/configs/nokia_rx51.h | 452 +++++++++ include/configs/seaboard.h | 1 + include/configs/tegra-common-post.h | 32 +- include/configs/tegra20-common.h | 10 +- include/fsl_esdhc.h | 1 + include/ipu_pixfmt.h | 4 +- include/twl4030.h | 98 ++ tools/imximage.c | 102 +- tools/imximage.h | 6 +- 101 files changed, 5733 insertions(+), 653 deletions(-) create mode 100644 arch/arm/include/asm/arch-mx6/mxc_hdmi.h create mode 100644 arch/arm/include/asm/arch-tegra20/spl.h create mode 100644 board/8dtech/eco5pk/Makefile create mode 100644 board/8dtech/eco5pk/eco5pk.c create mode 100644 board/8dtech/eco5pk/eco5pk.h create mode 100644 board/nokia/rx51/Makefile create mode 100644 board/nokia/rx51/lowlevel_init.S create mode 100644 board/nokia/rx51/rx51.c create mode 100644 board/nokia/rx51/rx51.h create mode 100644 board/nokia/rx51/tag_omap.h create mode 100644 board/nvidia/common/common.mk create mode 100644 board/toradex/colibri_t20-common/colibri_t20-common.c create mode 100644 board/toradex/colibri_t20-common/colibri_t20-common.h create mode 100644 board/toradex/colibri_t20_iris/Makefile create mode 100644 board/toradex/colibri_t20_iris/colibri_t20_iris.c create mode 100644 board/toradex/dts/tegra20-colibri_t20_iris.dts create mode 100644 doc/README.nokia_rx51 create mode 100644 include/configs/colibri_t20_iris.h create mode 100644 include/configs/eco5pk.h create mode 100644 include/configs/nokia_rx51.h
Amicalement,
On Sun, Nov 04, 2012 at 10:51:23PM +0100, Albert ARIBAUD wrote:
Hello Tom,
Beno??t Th??baudeau (4): mx35: Clean up lowlevel_init mx35: Fix eSDHC clocks mxc: Fix SDHC multi-instance clock mx25: Clean up imx-regs.h
Pali Roh??r (4): arm bootm: Allow to pass board specified atags Add power bus message definitions in twl4030.h cfb_console: Add support for some ANSI terminal escape codes New board support: Nokia RX-51 aka N900
- .../colibri_t20-common/colibri_t20-common.h | 16 +
Hello Tom,
Did you push this out to the git server? I'd love to rebase my local branch on top of it and test. The last commit I see in u-boot/master is the EXTRAVERSION fixup.
Hello Tom,
Just the master -> public git sync delay, sorry.
Albert ARIBAUD
Stephen Warren
