[U-Boot] DFU and UBIFS Volume upgrade
AFAIU, today it's possible to update a UBI partition via DFU with a new UBI blob using 'partubi'. However, this causes two issues/limitations: - It erases the partition, causing PEB erase counters amnesia (contrary to Linux ubiformat) - It's no possible to have a volume-grained upgrade (per UBIFS volume)
I saw some (very) old threads on this subject but no conclusion. Did I miss something? any recommendations?
Regards, Loic
Hello Loic,
added Lukasz as he is the DFU custodian.
Am 03.09.2019 um 09:59 schrieb Loic Poulain:
Yes.
Linux ubiformat)
Yes, patches which fixes this are welcome :-P
I am not to deep in the DFU topic involved, but I think the problem is that ubi is not an interface like "nand" or "mmc" it is more something like a partition type ...
The big problem with writting an ubi image into nand is, that you need to store the image first in RAM and you may have not enough ... so may writting volume serverally it may help out here.
On the other side, it is may possible to introduce an ubi interface for UBI volumes. But what if your board has not setup yet UBI, nor the UBI Volumes? Is there an interface in DFU for setting up something like "partitions" ? You need to pass several parameters to create a new UBI Volume ...
May Lukasz can say here more ...
I prefer nowadays to boot a linux and use swupdate, which can handle UBI Volumes ...
No there is no update on this, or I do not know it.
bye, Heiko
Thanks Heiko,
On Wed, 4 Sep 2019 at 07:24, Heiko Schocher hs@denx.de wrote:
Hello Loic,
UBI
Yes.
to
Linux ubiformat)
That's a good point. This makes things a bit complicated.
I agree, so let's keep that out of DFU.
So, the priority is maybe to preserve erase-counters to keep optimal wear leveling. This should be quite simple to fix, I'll look at the UBI spec and come back with a patch.
Regards, Loic
Heiko Schocher
Loic Poulain
