[U-Boot] [PATCH v3] moveconfig: add a second pass for empty #if/#endif blocks
Moveconfig already attempts to remove empty #if/#endif blocks when there is a matching CONFIG_ being moved. Add a second pass which covers files without a match.
Signed-off-by: Chris Packham judge.packham@gmail.com --- This was previously submitted as http://patchwork.ozlabs.org/patch/924901/ there still seems to be cases of #if/#endif left over from Kconfig migrations so perhaps this is still needed/wanted.
I've plumbed this in as a second pass because ultimately we may want to make this a separate option. Also I couldn't figure out how to implement this without using re.M so I couldn't make it work in with the line by line parsing of cleanup_one_header().
Changes in v3: - drop rfc
Changes in v2: - use re.compile
tools/moveconfig.py | 27 +++++++++++++++++++++++++-- 1 file changed, 25 insertions(+), 2 deletions(-)
diff --git a/tools/moveconfig.py b/tools/moveconfig.py index caa81ac2ed77..1a214c560546 100755 --- a/tools/moveconfig.py +++ b/tools/moveconfig.py @@ -545,6 +545,28 @@ def confirm(options, prompt):
return True
+def cleanup_empty_blocks(header_path, options): + """Clean up empty conditional blocks + + Arguments: + header_path: path to the cleaned file. + options: option flags. + """ + pattern = re.compile(r'^\s*#\s*if.*$\n^\s*#\s*endif.*$\n*', flags=re.M) + with open(header_path) as f: + data = f.read() + + new_data = pattern.sub('\n', data) + + show_diff(data.splitlines(True), new_data.splitlines(True), header_path, + options.color) + + if options.dry_run: + return + + with open(header_path, 'w') as f: + f.write(new_data) + def cleanup_one_header(header_path, patterns, options): """Clean regex-matched lines away from a file.
@@ -626,8 +648,9 @@ def cleanup_headers(configs, options): continue for filename in filenames: if not fnmatch.fnmatch(filename, '*~'): - cleanup_one_header(os.path.join(dirpath, filename), - patterns, options) + header_path = os.path.join(dirpath, filename) + cleanup_one_header(header_path, patterns, options) + cleanup_empty_blocks(header_path, options)
def cleanup_one_extra_option(defconfig_path, configs, options): """Delete config defines in CONFIG_SYS_EXTRA_OPTIONS in one defconfig file.
This seems useful to find leftover code regardless of the CONFIG options you are moving.
One drawback is, it may fold unrelated cleanups.
Maybe, it would be useful to add a separate option to turn on this feature, or make it into a separate tool.
Changes in v3:
- drop rfc
Changes in v2:
- use re.compile
return True
- """Clean up empty conditional blocks
- Arguments:
- pattern = re.compile(r'^\s*#\s*if.*$\n^\s*#\s*endif.*$\n*', flags=re.M)
- with open(header_path) as f:
data = f.read()
- new_data = pattern.sub('\n', data)
- show_diff(data.splitlines(True), new_data.splitlines(True), header_path,
options.color)
- if options.dry_run:
return
- with open(header_path, 'w') as f:
f.write(new_data)
patterns, options)
def cleanup_one_extra_option(defconfig_path, configs, options): """Delete config defines in CONFIG_SYS_EXTRA_OPTIONS in one defconfig file. -- 2.20.1
On Wed, Jan 30, 2019 at 5:55 PM Masahiro Yamada yamada.masahiro@socionext.com wrote:
I tested this patch. It detected one empty block.
diff --git a/include/configs/omap3_cairo.h b/include/configs/omap3_cairo.h index 04bce2f..ac1a6cb 100644 --- a/include/configs/omap3_cairo.h +++ b/include/configs/omap3_cairo.h @@ -197,8 +197,6 @@ * are needed and peripheral clocks for UART2 must be enabled in * function per_clocks_enable(). */ -#ifdef CONFIG_SPL_BUILD -#endif
/* Provide the MACH_TYPE value the vendor kernel requires */ #define CONFIG_MACH_TYPE 3063
This seems a leftover of 9baa2bce.
$ git show 9baa2bce -- include/configs/omap3_cairo.h commit 9baa2bce28901321d6f62399b5ebeb3fcb8e8a57 Author: Adam Ford aford173@gmail.com Date: Tue Aug 7 07:08:32 2018 -0500
Removed unused references to CONFIG_SERIALx
After creating CONS_INDEX and migrating a bunch of boards to it, there are a bunch of defined references to CONFIG_SERIALx which are not referenced in any C code or #ifdef, so they can now be removed
Signed-off-by: Adam Ford aford173@gmail.com
diff --git a/include/configs/omap3_cairo.h b/include/configs/omap3_cairo.h index 0133416..04bce2f 100644 --- a/include/configs/omap3_cairo.h +++ b/include/configs/omap3_cairo.h @@ -198,8 +198,6 @@ * function per_clocks_enable(). */ #ifdef CONFIG_SPL_BUILD -#undef CONFIG_SERIAL3 -#define CONFIG_SERIAL2 #endif
However, I doubt it used the moveconfig tool.
I re-ran the tool against the previous commit.
$ git checkout 9baa2bce2890^ $ tools/moveconfig.py -H SERIAL0 SERIAL1 SERIAL2 SERIAL3 Clean up headers? [y/n]: y y ... $ git diff -- include/configs/omap3_cairo.h diff --git a/include/configs/omap3_cairo.h b/include/configs/omap3_cairo.h index 0133416..ac1a6cb 100644 --- a/include/configs/omap3_cairo.h +++ b/include/configs/omap3_cairo.h @@ -197,10 +197,6 @@ * are needed and peripheral clocks for UART2 must be enabled in * function per_clocks_enable(). */ -#ifdef CONFIG_SPL_BUILD -#undef CONFIG_SERIAL3 -#define CONFIG_SERIAL2 -#endif
cleanup_one_header() did a good job.
Is there a particular case that the second path is needed?
On Thu, 31 Jan 2019 19:26 Masahiro Yamada <yamada.masahiro@socionext.com wrote:
there
cases
still
needed/wanted.
implement
feature,
- are needed and peripheral clocks for UART2 must be enabled in
- function per_clocks_enable().
Yes. I sent a patch for this as I was testing.
Removed unused references to CONFIG_SERIALx After creating CONS_INDEX and migrating a bunch of boards to it, there are a bunch of defined references to CONFIG_SERIALx which are not referenced in any C code or #ifdef, so they can now be removed Signed-off-by: Adam Ford <aford173@gmail.com>
Has moveconfig been updated to handle such cases in another way? I only re-sent this because I found it while cleaning up some old branches. I believe at the time I originally wrote it there were many more instances of empty guards (most if which I submitted patches for).
I agree that if moveconfig already handles this there is no point in adding a second pass (baring cases of double nesting).
There still may be benefit in running something as a one-off pass over all files to remove existing empty guards but there's no need to store such a script in the repository.
Chris Packham
Masahiro Yamada
