The div loop uses reassign and reuse parent_rate, which causes the parent rate reference to be wrong after the first loop, the resulting clock becomes incorrect for div != 1.
Fixes: 829e06bf4175 ("imx8ulp: clock: Add MIPI DSI clock and DCNano clock") Signed-off-by: Loic Poulain loic.poulain@linaro.org --- arch/arm/mach-imx/imx8ulp/clock.c | 5 ++--- 1 file changed, 2 insertions(+), 3 deletions(-)
diff --git a/arch/arm/mach-imx/imx8ulp/clock.c b/arch/arm/mach-imx/imx8ulp/clock.c index 91580b2..dbe0f78 100644 --- a/arch/arm/mach-imx/imx8ulp/clock.c +++ b/arch/arm/mach-imx/imx8ulp/clock.c @@ -381,10 +381,9 @@ void mxs_set_lcdclk(u32 base_addr, u32 freq_in_khz) debug("PLL4 rate %ukhz\n", pll4_rate);
for (pfd = 12; pfd <= 35; pfd++) { - parent_rate = pll4_rate; - parent_rate = parent_rate * 18 / pfd; - for (div = 1; div <= 64; div++) { + parent_rate = pll4_rate; + parent_rate = parent_rate * 18 / pfd; parent_rate = parent_rate / div;
for (pcd = 0; pcd < 8; pcd++) {
Reviewed-by: Peng Fan peng.fan@nxp.com
parent_rate = parent_rate * 18 / pfd; parent_rate = parent_rate / div; for (pcd = 0; pcd < 8; pcd++) {
The div loop uses reassign and reuse parent_rate, which causes the parent rate reference to be wrong after the first loop, the resulting clock becomes incorrect for div != 1. Fixes: 829e06bf4175 ("imx8ulp: clock: Add MIPI DSI clock and DCNano clock") Signed-off-by: Loic Poulain loic.poulain@linaro.org Reviewed-by: Peng Fan peng.fan@nxp.com
Best regards, Stefano Babic
Loic Poulain
Peng Fan (OSS)
sbabic@denx.de
