[U-Boot] [PATCH 4/4] ARM Add New Board GEC2410
Fix cs8900 dev->priv not init issue, do it as Ben Warren's suggestion.
checkpatch.pl result is
total: 0 errors, 0 warnings, 19 lines checked
0004-Fix-dev-priv-not-init-issue.patch has no obvious style problems and is ready for submission.
========================================================= Signed-off-by: Hui.Tang zetalabs@gmail.com --- drivers/net/cs8900.c | 7 ++++--- 1 files changed, 4 insertions(+), 3 deletions(-)
diff --git a/drivers/net/cs8900.c b/drivers/net/cs8900.c index 587f7f6..a9d1f22 100644 --- a/drivers/net/cs8900.c +++ b/drivers/net/cs8900.c @@ -321,15 +321,16 @@ int cs8900_initialize(u8 dev_num, int base_addr) memset(priv, 0, sizeof(*priv)); priv->regs = (struct cs8900_regs *)base_addr;
- /* Load MAC address from EEPROM */ - cs8900_get_enetaddr(dev); - dev->iobase = base_addr; dev->priv = priv; dev->init = cs8900_init; dev->halt = cs8900_halt; dev->send = cs8900_send; dev->recv = cs8900_recv; + + /* Load MAC address from EEPROM */ + cs8900_get_enetaddr(dev); + sprintf(dev->name, "%s-%hu", CS8900_DRIVERNAME, dev_num);
eth_register(dev);
This stuff should go below the '---' line so that it doesn't become part of the changelog. Also, this patch has nothing to do with 'ARM Add New Board GEC2410'. It should be a stand-alone patch, not part of your board submission. Please use a more appropriate title.
eth_register(dev);
The content looks fine, but the patch metadata needs to be re-done.
regards, Ben
Ben Warren
Hui.Tang
