[RFC PATCH] imx8m: Drop env_get_location for imx8mn and imx8mp
This function defined for two architecture is not really clean and can be generate problem when people add a new board
Signed-off-by: Michael Trimarchi michael@amarulasolutions.com --- arch/arm/mach-imx/imx8m/soc.c | 42 ----------------------------------- 1 file changed, 42 deletions(-)
diff --git a/arch/arm/mach-imx/imx8m/soc.c b/arch/arm/mach-imx/imx8m/soc.c index e75d2fa255..83a515c973 100644 --- a/arch/arm/mach-imx/imx8m/soc.c +++ b/arch/arm/mach-imx/imx8m/soc.c @@ -1311,45 +1311,3 @@ void do_error(struct pt_regs *pt_regs, unsigned int esr) } #endif #endif - -#if defined(CONFIG_IMX8MN) || defined(CONFIG_IMX8MP) -enum env_location env_get_location(enum env_operation op, int prio) -{ - enum boot_device dev = get_boot_device(); - enum env_location env_loc = ENVL_UNKNOWN; - - if (prio) - return env_loc; - - switch (dev) { -#ifdef CONFIG_ENV_IS_IN_SPI_FLASH - case QSPI_BOOT: - env_loc = ENVL_SPI_FLASH; - break; -#endif -#ifdef CONFIG_ENV_IS_IN_NAND - case NAND_BOOT: - env_loc = ENVL_NAND; - break; -#endif -#ifdef CONFIG_ENV_IS_IN_MMC - case SD1_BOOT: - case SD2_BOOT: - case SD3_BOOT: - case MMC1_BOOT: - case MMC2_BOOT: - case MMC3_BOOT: - env_loc = ENVL_MMC; - break; -#endif - default: -#if defined(CONFIG_ENV_IS_NOWHERE) - env_loc = ENVL_NOWHERE; -#endif - break; - } - - return env_loc; -} - -#endif
Hello Michael,
-----Original Message----- From: U-Boot u-boot-bounces@lists.denx.de On Behalf Of Michael Trimarchi Sent: Thursday, November 18, 2021 2:58 PM To: Ye Li ye.li@nxp.com; Stefano Babic sbabic@denx.de; Fabio Estevam festevam@gmail.com Cc: u-boot@lists.denx.de; Ariel D'Alessandro ariel.dalessandro@collabora.com; linux-amarula@amarulasolutions.com; Anthony Brandon anthony@amarulasolutions.com Subject: [RFC PATCH] imx8m: Drop env_get_location for imx8mn and imx8mp
Not sure what you mean by "not clean" and "can generate problems" here, perhaps you can elaborate that more in commit message?
Quick git grep shows that there are boards that have it implemented, but only two CPU families have them: - arch/arm/cpu/armv8/fsl-layerscape/cpu.c - arch/arm/mach-imx/imx8m/soc.c
- board/aristainetos/aristainetos.c - board/engicam/stm32mp1/stm32mp1.c -board/renesas/alt/alt.c - board/renesas/gose/gose.c - board/renesas/koelsch/koelsch.c - board/renesas/lager/lager.c - board/renesas/porter/porter.c - board/renesas/silk/silk.c - board/renesas/stout/stout.c - board/sandbox/sandbox.c - board/st/stm32mp1/stm32mp1.c - board/sunxi/board.c - board/xilinx/versal/board.c - board/xilinx/zynq/board.c - board/xilinx/zynqmp/zynqmp.c
If it does interfere with certain things you do - why not moving it to imx8mn-evk and imx8mp-evk instead? At least this would give adopters a hint, as EVKs are normally a reference target.
-- andrey
Hi ZHIZHIKIN
On Thu, Nov 18, 2021 at 7:53 PM ZHIZHIKIN Andrey andrey.zhizhikin@leica-geosystems.com wrote:
Hello Michael,
Sorry, I will adjust the commit message. This should be done at board level, that would like to define the enviroment from it's own config or from some specific setup.
Yes, the patch is only involve the imx8mp and imx8mn. For the problem is that make no sense to define an unique way for multiple board. One board can boot from emmc and having env on spi flash etc
Michael
-- andrey
Hello Michael,
-----Original Message----- From: Michael Nazzareno Trimarchi michael@amarulasolutions.com Sent: Thursday, November 18, 2021 10:48 PM To: ZHIZHIKIN Andrey andrey.zhizhikin@leica-geosystems.com Cc: Ye Li ye.li@nxp.com; Stefano Babic sbabic@denx.de; Fabio Estevam festevam@gmail.com; u-boot@lists.denx.de; Ariel D'Alessandro ariel.dalessandro@collabora.com; linux-amarula@amarulasolutions.com; Anthony Brandon anthony@amarulasolutions.com Subject: Re: [RFC PATCH] imx8m: Drop env_get_location for imx8mn and imx8mp
Hi ZHIZHIKIN
It's Andrey, mail client swaps last and first names. :)
Hello Michael,
From your other patch I've seen on ML [1], combined with this one - it looks like you're trying to revert 2707faf01f ("imx8mn/imx8mp: override env_get_offset and env_get_location"). If you go ahead with both patches, then I suggest you submit a revert instead.
I see, but this is rather a specialization to me. How can one ensure that the env deployed on another storage device is valid for the media you're booting from?
Anyways, I suggest that this function is kept in both imx8mn and imx8mp evk boards instead of being completely dropped.
Michael
-- andrey
-- Michael Nazzareno Trimarchi Co-Founder & Chief Executive Officer M. +39 347 913 2170 michael@amarulasolutions.com __________________________________
Amarula Solutions BV Joop Geesinkweg 125, 1114 AB, Amsterdam, NL T. +31 (0)85 111 9172 info@amarulasolutions.com
Link: [1]: http://patchwork.ozlabs.org/project/uboot/patch/20211117143456.34441-1-micha...
-- andrey
Michael Trimarchi
ZHIZHIKIN Andrey
