[PATCH v5 0/3] Add Renesas SoC identification driver support
This patch series aims to support Renesas SoC identification driver. Also added soc_id attribute support in UCLASS_SOC which is required for Renesas SoC identification driver similar to mainline linux.
Patch 3 in this series depend on [1]
[1] http://u-boot.10912.n7.nabble.com/PATCH-v5-dm-core-Add-of-match-node-helper-...
v4->v5 * Rebased to master and changed "priv_auto_alloc_size" to "priv_auto" * Improved the spl image size, when Renesas SoC identification driver is disabled
with v5 on Koelsch board:- $ ls -al spl/u-boot-spl.bin -rwxr-xr-x 1 biju biju 13916 Jan 16 14:19 spl/u-boot-spl.bin
$ size spl/u-boot-spl text data bss dec hex filename 13785 128 1100 15013 3aa5 spl/u-boot-spl
with v4 on Koelsch board:
$ ls -al spl/u-boot-spl.bin -rwxr-xr-x 1 biju biju 13996 Jan 16 14:16 spl/u-boot-spl.bin
$ size spl/u-boot-spl text data bss dec hex filename 13789 204 1100 15093 3af5 spl/u-boot-spl
v3->v4 * Added Simon's Rb tag * Updated patch description for SoC identification using soc_id * Updated probe function of Renesas SoC identification driver.
Biju Das (3): soc: Fix comments from SOC to SoC dm: soc: Add SoC id for attribute matching dm: soc: SoC identification driver for Renesas SoC's
drivers/soc/Kconfig | 7 ++ drivers/soc/Makefile | 7 ++ drivers/soc/soc-uclass.c | 19 ++- drivers/soc/soc_renesas.c | 244 ++++++++++++++++++++++++++++++++++++++ drivers/soc/soc_sandbox.c | 8 ++ include/soc.h | 39 +++++- test/dm/soc.c | 8 ++ 7 files changed, 325 insertions(+), 7 deletions(-) create mode 100644 drivers/soc/soc_renesas.c
Fix the comments from "an SOC" to "an SoC".
Signed-off-by: Biju Das biju.das.jz@bp.renesas.com Reviewed-by: Lad Prabhakar prabhakar.mahadev-lad.rj@bp.renesas.com Reviewed-by: Simon Glass sjg@chromium.org --- v4->v5: No Change.
v3->v4: No Change * Added Simon's Rb tag.
v3: * New patch (Ref: https://patchwork.ozlabs.org/project/uboot/patch/20201102150959.4793-3-biju....) --- include/soc.h | 12 ++++++------ 1 file changed, 6 insertions(+), 6 deletions(-)
diff --git a/include/soc.h b/include/soc.h index a55eb1b572..05058f9331 100644 --- a/include/soc.h +++ b/include/soc.h @@ -31,7 +31,7 @@ struct soc_attr {
struct soc_ops { /** - * get_machine() - Get machine name of an SOC + * get_machine() - Get machine name of an SoC * * @dev: Device to check (UCLASS_SOC) * @buf: Buffer to place string @@ -41,7 +41,7 @@ struct soc_ops { int (*get_machine)(struct udevice *dev, char *buf, int size);
/** - * get_revision() - Get revision name of a SOC + * get_revision() - Get revision name of an SoC * * @dev: Device to check (UCLASS_SOC) * @buf: Buffer to place string @@ -51,7 +51,7 @@ struct soc_ops { int (*get_revision)(struct udevice *dev, char *buf, int size);
/** - * get_family() - Get family name of an SOC + * get_family() - Get family name of an SoC * * @dev: Device to check (UCLASS_SOC) * @buf: Buffer to place string @@ -76,7 +76,7 @@ struct soc_ops { int soc_get(struct udevice **devp);
/** - * soc_get_machine() - Get machine name of an SOC + * soc_get_machine() - Get machine name of an SoC * @dev: Device to check (UCLASS_SOC) * @buf: Buffer to place string * @size: Size of string space @@ -86,7 +86,7 @@ int soc_get(struct udevice **devp); int soc_get_machine(struct udevice *dev, char *buf, int size);
/** - * soc_get_revision() - Get revision name of an SOC + * soc_get_revision() - Get revision name of an SoC * @dev: Device to check (UCLASS_SOC) * @buf: Buffer to place string * @size: Size of string space @@ -96,7 +96,7 @@ int soc_get_machine(struct udevice *dev, char *buf, int size); int soc_get_revision(struct udevice *dev, char *buf, int size);
/** - * soc_get_family() - Get family name of an SOC + * soc_get_family() - Get family name of an SoC * @dev: Device to check (UCLASS_SOC) * @buf: Buffer to place string * @size: Size of string space
Mainline kernel uses the "soc_id" attribute to identify the SoC for some of the h/w platforms. On such platforms adding this attribute in u-boot will make SoC identification similar to the mainline kernel, so that it can be easily maintained.
Add a new attribute named "soc_id" to SOC uclass, in order to allow device drivers for identifying the SoC using SoC identification string and also for matching this attribute for selecting SoC specific data.
Signed-off-by: Biju Das biju.das.jz@bp.renesas.com Reviewed-by: Lad Prabhakar prabhakar.mahadev-lad.rj@bp.renesas.com Reviewed-by: Simon Glass sjg@chromium.org --- v4->v5: * No change.
v3->v4: * Updated patch description * Added Simon's Rb tag.
v2->v3: * split the comments patch seperate. Ref:https://patchwork.ozlabs.org/project/uboot/patch/20201102150959.4793-3-biju....
v1->v2: Changed the comments from "a SoC" to "an SoC" Ref: https://patchwork.ozlabs.org/project/uboot/patch/20201030140724.12773-1-biju... --- drivers/soc/soc-uclass.c | 19 ++++++++++++++++++- drivers/soc/soc_sandbox.c | 8 ++++++++ include/soc.h | 27 +++++++++++++++++++++++++++ test/dm/soc.c | 8 ++++++++ 4 files changed, 61 insertions(+), 1 deletion(-)
diff --git a/drivers/soc/soc-uclass.c b/drivers/soc/soc-uclass.c index c32d647864..a3f8be841b 100644 --- a/drivers/soc/soc-uclass.c +++ b/drivers/soc/soc-uclass.c @@ -46,6 +46,16 @@ int soc_get_revision(struct udevice *dev, char *buf, int size) return ops->get_revision(dev, buf, size); }
+int soc_get_soc_id(struct udevice *dev, char *buf, int size) +{ + struct soc_ops *ops = soc_get_ops(dev); + + if (!ops->get_soc_id) + return -ENOSYS; + + return ops->get_soc_id(dev, buf, size); +} + const struct soc_attr * soc_device_match(const struct soc_attr *matches) { @@ -61,7 +71,7 @@ soc_device_match(const struct soc_attr *matches)
while (1) { if (!(matches->machine || matches->family || - matches->revision)) + matches->revision || matches->soc_id)) break;
match = true; @@ -87,6 +97,13 @@ soc_device_match(const struct soc_attr *matches) } }
+ if (matches->soc_id) { + if (!soc_get_soc_id(soc, str, SOC_MAX_STR_SIZE)) { + if (strcmp(matches->soc_id, str)) + match = false; + } + } + if (match) return matches;
diff --git a/drivers/soc/soc_sandbox.c b/drivers/soc/soc_sandbox.c index 5c82ad84fc..1a81d3562a 100644 --- a/drivers/soc/soc_sandbox.c +++ b/drivers/soc/soc_sandbox.c @@ -31,10 +31,18 @@ int soc_sandbox_get_revision(struct udevice *dev, char *buf, int size) return 0; }
+int soc_sandbox_get_soc_id(struct udevice *dev, char *buf, int size) +{ + snprintf(buf, size, "r8a774a1"); + + return 0; +} + static const struct soc_ops soc_sandbox_ops = { .get_family = soc_sandbox_get_family, .get_revision = soc_sandbox_get_revision, .get_machine = soc_sandbox_get_machine, + .get_soc_id = soc_sandbox_get_soc_id, };
int soc_sandbox_probe(struct udevice *dev) diff --git a/include/soc.h b/include/soc.h index 05058f9331..db0e8880d1 100644 --- a/include/soc.h +++ b/include/soc.h @@ -20,12 +20,14 @@ * variants. Example: am33 * @machine - Name of a specific SoC. Example: am3352 * @revision - Name of a specific SoC revision. Example: SR1.1 + * @soc_id - SoC identification string. Example: r8a774a1 * @data - A pointer to user data for the SoC variant */ struct soc_attr { const char *family; const char *machine; const char *revision; + const char *soc_id; const void *data; };
@@ -59,6 +61,16 @@ struct soc_ops { * @return 0 if OK, -ENOSPC if buffer is too small, other -ve on error */ int (*get_family)(struct udevice *dev, char *buf, int size); + + /** + * get_soc_id() - Get SoC identification name of an SoC + * + * @dev: Device to check (UCLASS_SOC) + * @buf: Buffer to place string + * @size: Size of string space + * @return 0 if OK, -ENOSPC if buffer is too small, other -ve on error + */ + int (*get_soc_id)(struct udevice *dev, char *buf, int size); };
#define soc_get_ops(dev) ((struct soc_ops *)(dev)->driver->ops) @@ -105,6 +117,16 @@ int soc_get_revision(struct udevice *dev, char *buf, int size); */ int soc_get_family(struct udevice *dev, char *buf, int size);
+/** + * soc_get_soc_id() - Get SoC identification name of an SoC + * @dev: Device to check (UCLASS_SOC) + * @buf: Buffer to place string + * @size: Size of string space + * + * Return: 0 if OK, -ENOSPC if buffer is too small, other -ve on error + */ +int soc_get_soc_id(struct udevice *dev, char *buf, int size); + /** * soc_device_match() - Return match from an array of soc_attr * @matches: Array with any combination of family, revision or machine set @@ -136,6 +158,11 @@ static inline int soc_get_family(struct udevice *dev, char *buf, int size) return -ENOSYS; }
+static inline int soc_get_soc_id(struct udevice *dev, char *buf, int size) +{ + return -ENOSYS; +} + static inline const struct soc_attr * soc_device_match(const struct soc_attr *matches) { diff --git a/test/dm/soc.c b/test/dm/soc.c index 17e1b5ba01..82cd53ff29 100644 --- a/test/dm/soc.c +++ b/test/dm/soc.c @@ -32,24 +32,28 @@ static int dm_test_soc(struct unit_test_state *uts) .family = "SANDBOX0xx", .machine = "SANDBOX012", .revision = "1.0", + .soc_id = "r8a774a1", .data = NULL, }, { .family = "SANDBOX1xx", .machine = "SANDBOX107", .revision = "1.0", + .soc_id = "r8a774a1", .data = NULL, }, { .family = "SANDBOX1xx", .machine = "SANDBOX123", .revision = "1.0", + .soc_id = "r8a774a1", .data = &soc_sandbox123_data, }, { .family = "SANDBOX1xx", .machine = "SANDBOX131", .revision = "2.0", + .soc_id = "r8a774a1", .data = NULL, }, { /* sentinel */ } @@ -78,6 +82,7 @@ static int dm_test_soc(struct unit_test_state *uts) { .family = "SANDBOX0xx", .revision = "1.0", + .soc_id = "r8a774b1", .data = NULL, }, { @@ -99,6 +104,9 @@ static int dm_test_soc(struct unit_test_state *uts) ut_assertok(soc_get_revision(dev, text, sizeof(text))); ut_asserteq_str(text, "1.0");
+ ut_assertok(soc_get_soc_id(dev, text, sizeof(text))); + ut_asserteq_str(text, "r8a774a1"); + soc_data = soc_device_match(sb_soc_devices_full); ut_assert(soc_data);
Add SoC identification driver for Renesas SoC's. This allows to identify the SoC type and revision based on Product Register.
This can be checked where needed using soc_device_match().
Signed-off-by: Biju Das biju.das.jz@bp.renesas.com Reviewed-by: Lad Prabhakar prabhakar.mahadev-lad.rj@bp.renesas.com --- This patch depend on [1] [1] http://u-boot.10912.n7.nabble.com/PATCH-v5-dm-core-Add-of-match-node-helper-...
v4->v5 * Rebased to master and changed "priv_auto_alloc_size" to "priv_auto" * Improved the spl image size, when Renesas SoC identification driver is disabled with v5 on Koelsch board:- $ ls -al spl/u-boot-spl.bin -rwxr-xr-x 1 biju biju 13916 Jan 16 14:19 spl/u-boot-spl.bin $ size spl/u-boot-spl text data bss dec hex filename 13785 128 1100 15013 3aa5 spl/u-boot-spl with v4 on Koelsch board: $ ls -al spl/u-boot-spl.bin -rwxr-xr-x 1 biju biju 13996 Jan 16 14:16 spl/u-boot-spl.bin $ size spl/u-boot-spl text data bss dec hex filename 13789 204 1100 15093 3af5 spl/u-boot-spl
v3->v4: * Updated Copy right information from Linux. * Updated probe function, use the prr address from DT. v2->v3: No Change. v2: New patch --- drivers/soc/Kconfig | 7 ++ drivers/soc/Makefile | 7 ++ drivers/soc/soc_renesas.c | 244 ++++++++++++++++++++++++++++++++++++++ 3 files changed, 258 insertions(+) create mode 100644 drivers/soc/soc_renesas.c
diff --git a/drivers/soc/Kconfig b/drivers/soc/Kconfig index 864d00a885..475e94cd77 100644 --- a/drivers/soc/Kconfig +++ b/drivers/soc/Kconfig @@ -16,6 +16,13 @@ config SOC_DEVICE_TI_K3 This allows Texas Instruments Keystone 3 SoCs to identify specifics about the SoC in use.
+config SOC_DEVICE_RENESAS + depends on SOC_DEVICE + bool "Enable SoC driver for Renesas SoCs" + help + This allows Renesas SoCs to identify specifics about the + SoC in use. + source "drivers/soc/ti/Kconfig"
endmenu diff --git a/drivers/soc/Makefile b/drivers/soc/Makefile index 9ef20ca506..eea37a8d84 100644 --- a/drivers/soc/Makefile +++ b/drivers/soc/Makefile @@ -3,6 +3,13 @@ # Makefile for the U-Boot SOC specific device drivers.
obj-$(CONFIG_SOC_TI) += ti/ +ifeq ($(CONFIG_SOC_DEVICE_RENESAS),y) +ifneq ($(CONFIG_SPL_BUILD),y) obj-$(CONFIG_SOC_DEVICE) += soc-uclass.o +obj-$(CONFIG_SOC_DEVICE_RENESAS) += soc_renesas.o +endif +else +obj-$(CONFIG_SOC_DEVICE) += soc-uclass.o +endif obj-$(CONFIG_SOC_DEVICE_TI_K3) += soc_ti_k3.o obj-$(CONFIG_SANDBOX) += soc_sandbox.o diff --git a/drivers/soc/soc_renesas.c b/drivers/soc/soc_renesas.c new file mode 100644 index 0000000000..f6813fc2fc --- /dev/null +++ b/drivers/soc/soc_renesas.c @@ -0,0 +1,244 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2014-2016 Glider bvba + * Copyright (C) 2020 Renesas Electronics Corp. + * + */ + +#include <common.h> +#include <dm.h> +#include <dm/device-internal.h> +#include <soc.h> + +#include <asm/io.h> + +struct soc_renesas_priv { + const char *family; + const char *soc_id; + char revision[6]; +}; + +struct renesas_family { + const char name[16]; + u32 reg; /* CCCR or PRR, if not in DT */ +}; + +static const struct renesas_family fam_rcar_gen3 __maybe_unused = { + .name = "R-Car Gen3", + .reg = 0xfff00044, /* PRR (Product Register) */ +}; + +static const struct renesas_family fam_rzg2 __maybe_unused = { + .name = "RZ/G2", + .reg = 0xfff00044, /* PRR (Product Register) */ +}; + +struct renesas_soc { + const struct renesas_family *family; + u8 id; +}; + +#ifdef CONFIG_R8A774A1 +static const struct renesas_soc soc_rz_g2m = { + .family = &fam_rzg2, + .id = 0x52, +}; +#endif + +#ifdef CONFIG_R8A774B1 +static const struct renesas_soc soc_rz_g2n = { + .family = &fam_rzg2, + .id = 0x55, +}; +#endif + +#ifdef CONFIG_R8A774C0 +static const struct renesas_soc soc_rz_g2e = { + .family = &fam_rzg2, + .id = 0x57, +}; +#endif + +#ifdef CONFIG_R8A774E1 +static const struct renesas_soc soc_rz_g2h = { + .family = &fam_rzg2, + .id = 0x4f, +}; +#endif + +#ifdef CONFIG_R8A7795 +static const struct renesas_soc soc_rcar_h3 = { + .family = &fam_rcar_gen3, + .id = 0x4f, +}; +#endif + +#ifdef CONFIG_R8A7796 +static const struct renesas_soc soc_rcar_m3_w = { + .family = &fam_rcar_gen3, + .id = 0x52, +}; +#endif + +#ifdef CONFIG_R8A77965 +static const struct renesas_soc soc_rcar_m3_n = { + .family = &fam_rcar_gen3, + .id = 0x55, +}; +#endif + +#ifdef CONFIG_R8A77970 +static const struct renesas_soc soc_rcar_v3m = { + .family = &fam_rcar_gen3, + .id = 0x54, +}; +#endif + +#ifdef CONFIG_R8A77980 +static const struct renesas_soc soc_rcar_v3h = { + .family = &fam_rcar_gen3, + .id = 0x56, +}; +#endif + +#ifdef CONFIG_R8A77990 +static const struct renesas_soc soc_rcar_e3 = { + .family = &fam_rcar_gen3, + .id = 0x57, +}; +#endif + +#ifdef CONFIG_R8A77995 +static const struct renesas_soc soc_rcar_d3 = { + .family = &fam_rcar_gen3, + .id = 0x58, +}; +#endif + +static int soc_renesas_get_family(struct udevice *dev, char *buf, int size) +{ + struct soc_renesas_priv *priv = dev_get_priv(dev); + + snprintf(buf, size, "%s", priv->family); + + return 0; +} + +static int soc_renesas_get_revision(struct udevice *dev, char *buf, int size) +{ + struct soc_renesas_priv *priv = dev_get_priv(dev); + + snprintf(buf, size, "%s", priv->revision); + + return 0; +} + +static int soc_renesas_get_soc_id(struct udevice *dev, char *buf, int size) +{ + struct soc_renesas_priv *priv = dev_get_priv(dev); + + snprintf(buf, size, "%s", priv->soc_id); + + return 0; +} + +static const struct udevice_id renesas_socs[] = { +#ifdef CONFIG_R8A774A1 + { .compatible = "renesas,r8a774a1", .data = (ulong)&soc_rz_g2m, }, +#endif +#ifdef CONFIG_R8A774B1 + { .compatible = "renesas,r8a774b1", .data = (ulong)&soc_rz_g2n, }, +#endif +#ifdef CONFIG_R8A774C0 + { .compatible = "renesas,r8a774c0", .data = (ulong)&soc_rz_g2e, }, +#endif +#ifdef CONFIG_R8A774E1 + { .compatible = "renesas,r8a774e1", .data = (ulong)&soc_rz_g2h, }, +#endif +#ifdef CONFIG_R8A7795 + { .compatible = "renesas,r8a7795", .data = (ulong)&soc_rcar_h3, }, +#endif +#ifdef CONFIG_R8A7796 + { .compatible = "renesas,r8a7796", .data = (ulong)&soc_rcar_m3_w, }, +#endif +#ifdef CONFIG_R8A77965 + { .compatible = "renesas,r8a77965", .data = (ulong)&soc_rcar_m3_n, }, +#endif +#ifdef CONFIG_R8A77970 + { .compatible = "renesas,r8a77970", .data = (ulong)&soc_rcar_v3m, }, +#endif +#ifdef CONFIG_R8A77980 + { .compatible = "renesas,r8a77980", .data = (ulong)&soc_rcar_v3h, }, +#endif +#ifdef CONFIG_R8A77990 + { .compatible = "renesas,r8a77990", .data = (ulong)&soc_rcar_e3, }, +#endif +#ifdef CONFIG_R8A77995 + { .compatible = "renesas,r8a77995", .data = (ulong)&soc_rcar_d3, }, +#endif + { /* sentinel */ } +}; + +static const struct udevice_id prr_ids[] = { + { .compatible = "renesas,prr" }, + { /* sentinel */ } +}; + +static const struct soc_ops soc_renesas_ops = { + .get_family = soc_renesas_get_family, + .get_revision = soc_renesas_get_revision, + .get_soc_id = soc_renesas_get_soc_id, +}; + +int soc_renesas_probe(struct udevice *dev) +{ + struct soc_renesas_priv *priv = dev_get_priv(dev); + void *prr_addr = dev_read_addr_ptr(dev); + unsigned int product, eshi = 0, eslo; + const struct renesas_family *family; + const struct udevice_id *match; + struct renesas_soc *soc; + ofnode root_node; + + if (!prr_addr) + return -EINVAL; + + root_node = ofnode_path("/"); + match = of_match_node(renesas_socs, root_node); + if (!match) { + printf("SoC entry is missing in DT\n"); + return -EINVAL; + } + + soc = (struct renesas_soc *)match->data; + family = soc->family; + + product = readl(prr_addr); + /* R-Car M3-W ES1.1 incorrectly identifies as ES2.0 */ + if ((product & 0x7fff) == 0x5210) + product ^= 0x11; + /* R-Car M3-W ES1.3 incorrectly identifies as ES2.1 */ + if ((product & 0x7fff) == 0x5211) + product ^= 0x12; + if (soc->id && ((product >> 8) & 0xff) != soc->id) { + printf("SoC mismatch (product = 0x%x)\n", product); + return -EINVAL; + } + eshi = ((product >> 4) & 0x0f) + 1; + eslo = product & 0xf; + + priv->family = family->name; + priv->soc_id = strchr(match->compatible, ',') + 1; + snprintf(priv->revision, sizeof(priv->revision), "ES%u.%u", eshi, eslo); + + return 0; +} + +U_BOOT_DRIVER(soc_renesas) = { + .name = "soc_renesas", + .id = UCLASS_SOC, + .ops = &soc_renesas_ops, + .of_match = prr_ids, + .probe = soc_renesas_probe, + .priv_auto = sizeof(struct soc_renesas_priv), +};
Biju Das
