[U-Boot] [PATCH] nds32: mmc: Support ftsdc010 DM.
Support Andestech ftsdc010 SD/MMC device tree flow on AG101P/AE3XX platforms. Verification : boot linux kernel from sd card
NDS32 # mmc rescan NDS32 # fatls mmc 0:1 13938796 boomimage-310y-ag101p.bin
1 file(s)
NDS32 # fatload mmc 0:1 0x600000 boomimage-310y-ag101p.bin reading boomimage-310y-ag101p.bin 13938796 bytes read in 17358 ms (784.2 KiB/s) NDS32 # bootm 0x600000 Image Name: Created: 2017-05-23 1:58:24 UTC Image Type: NDS32 Linux Kernel Image (uncompressed) Data Size: 13938732 Bytes = 13.3 MiB Load Address: 0000c000 Entry Point: 0000c000 Verifying Checksum ... OK Loading Kernel Image ... OK Linux version 3.10.102-20420-g301b0f6 (rick@app09) (gcc version 4.9.3 (2016-07-06_nds32le-linux-glibc-v3_experimental) )#798 PREEMPT Tue May 23 09:57:59 CST 2017 CPU: NDS32 N13, AndesCore ID(wb), CPU_VER 0x0d0c003f(id 13, rev 12, cfg 63) ... ... Signed-off-by: rick rick@andestech.com --- arch/nds32/dts/ae3xx.dts | 8 ++ arch/nds32/dts/ag101p.dts | 8 ++ board/AndesTech/adp-ae3xx/adp-ae3xx.c | 4 +- board/AndesTech/adp-ag101p/adp-ag101p.c | 7 +- configs/adp-ae3xx_defconfig | 5 ++ configs/adp-ag101p_defconfig | 5 ++ drivers/mmc/Kconfig | 12 +++ drivers/mmc/Makefile | 1 + drivers/mmc/ftsdc010_mci.c | 140 ++++++++++++++++++++++++------- drivers/mmc/ftsdc010_mci.h | 54 ++++++++++++ drivers/mmc/nds32_mmc.c | 139 ++++++++++++++++++++++++++++++ include/configs/adp-ae3xx.h | 1 - include/configs/adp-ag101p.h | 1 - 13 files changed, 344 insertions(+), 41 deletions(-) create mode 100644 drivers/mmc/ftsdc010_mci.h create mode 100644 drivers/mmc/nds32_mmc.c
diff --git a/arch/nds32/dts/ae3xx.dts b/arch/nds32/dts/ae3xx.dts index 4221e4b..781eabc 100644 --- a/arch/nds32/dts/ae3xx.dts +++ b/arch/nds32/dts/ae3xx.dts @@ -62,6 +62,14 @@ interrupts = <25 4>; };
+ mmc0: mmc@f0e00000 { + compatible = "andestech,atsdc010"; + clock-freq-min-max = <400000 100000000>; + fifo-depth = <0x10>; + reg = <0xf0e00000 0x1000>; + interrupts = <17 4>; + }; + nor@0,0 { compatible = "cfi-flash"; reg = <0x88000000 0x1000>; diff --git a/arch/nds32/dts/ag101p.dts b/arch/nds32/dts/ag101p.dts index 99cde2f..dd2bf8f 100644 --- a/arch/nds32/dts/ag101p.dts +++ b/arch/nds32/dts/ag101p.dts @@ -60,4 +60,12 @@ reg = <0x90900000 0x1000>; interrupts = <25 4>; }; + + mmc0: mmc@98e00000 { + compatible = "andestech,atsdc010"; + clock-freq-min-max = <400000 30000000>; + fifo-depth = <0x10>; + reg = <0x98e00000 0x1000>; + interrupts = <5 4>; + }; }; diff --git a/board/AndesTech/adp-ae3xx/adp-ae3xx.c b/board/AndesTech/adp-ae3xx/adp-ae3xx.c index 98ed4d9..3903427 100644 --- a/board/AndesTech/adp-ae3xx/adp-ae3xx.c +++ b/board/AndesTech/adp-ae3xx/adp-ae3xx.c @@ -77,10 +77,8 @@ ulong board_flash_get_legacy(ulong base, int banknum, flash_info_t *info)
int board_mmc_init(bd_t *bis) { -#ifndef CONFIG_DM_MMC -#ifdef CONFIG_FTSDC010 +#if defined(CONFIG_FTSDC010) && !defined(CONFIG_DM_MMC) ftsdc010_mmc_init(0); #endif -#endif return 0; } diff --git a/board/AndesTech/adp-ag101p/adp-ag101p.c b/board/AndesTech/adp-ag101p/adp-ag101p.c index a462941..826ba14 100644 --- a/board/AndesTech/adp-ag101p/adp-ag101p.c +++ b/board/AndesTech/adp-ag101p/adp-ag101p.c @@ -20,7 +20,6 @@ DECLARE_GLOBAL_DATA_PTR; /* * Miscellaneous platform dependent initializations */ - int board_init(void) { /* @@ -30,7 +29,6 @@ int board_init(void) printf("Board: %s\n" , CONFIG_SYS_BOARD); gd->bd->bi_arch_number = MACH_TYPE_ADPAG101P; gd->bd->bi_boot_params = PHYS_SDRAM_0 + 0x400; - return 0; }
@@ -39,11 +37,8 @@ int dram_init(void) unsigned long sdram_base = PHYS_SDRAM_0; unsigned long expected_size = PHYS_SDRAM_0_SIZE + PHYS_SDRAM_1_SIZE; unsigned long actual_size; - actual_size = get_ram_size((void *)sdram_base, expected_size); - gd->ram_size = actual_size; - if (expected_size != actual_size) { printf("Warning: Only %lu of %lu MiB SDRAM is working\n", actual_size >> 20, expected_size >> 20); @@ -83,7 +78,7 @@ ulong board_flash_get_legacy(ulong base, int banknum, flash_info_t *info)
int board_mmc_init(bd_t *bis) { -#ifdef CONFIG_FTSDC010 +#if defined(CONFIG_FTSDC010) && !defined(CONFIG_DM_MMC) ftsdc010_mmc_init(0); #endif return 0; diff --git a/configs/adp-ae3xx_defconfig b/configs/adp-ae3xx_defconfig index cbef412..d12f307 100644 --- a/configs/adp-ae3xx_defconfig +++ b/configs/adp-ae3xx_defconfig @@ -18,6 +18,11 @@ CONFIG_BAUDRATE=38400 CONFIG_OF_CONTROL=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y +CONFIG_BLK=y +CONFIG_DM_MMC=y +CONFIG_DM_MMC_OPS=y +CONFIG_MMC_NDS32=y +CONFIG_FTSDC010=y CONFIG_MTD=y CONFIG_CFI_FLASH=y CONFIG_DM_ETH=y diff --git a/configs/adp-ag101p_defconfig b/configs/adp-ag101p_defconfig index 22b1182..85e2225 100644 --- a/configs/adp-ag101p_defconfig +++ b/configs/adp-ag101p_defconfig @@ -18,6 +18,11 @@ CONFIG_BAUDRATE=38400 CONFIG_OF_CONTROL=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y +CONFIG_BLK=y +CONFIG_DM_MMC=y +CONFIG_DM_MMC_OPS=y +CONFIG_MMC_NDS32=y +CONFIG_FTSDC010=y CONFIG_DM_ETH=y CONFIG_FTMAC100=y CONFIG_DM_SERIAL=y diff --git a/drivers/mmc/Kconfig b/drivers/mmc/Kconfig index 0dd4443..ca1376a 100644 --- a/drivers/mmc/Kconfig +++ b/drivers/mmc/Kconfig @@ -377,6 +377,18 @@ config GENERIC_ATMEL_MCI the SD Memory Card Specification V2.0, the SDIO V2.0 specification and CE-ATA V1.1.
+config MMC_NDS32 + bool "Andestech SD/MMC controller support" + depends on DM_MMC && OF_CONTROL + help + This enables support for the Andestech SD/MMM controller, which is + based on Faraday IP. + +config FTSDC010 + bool "Ftsdc010 SD/MMC controller Support" + help + This SD/MMC controller is present in Andestech SoCs which is based on Faraday IP. + endif
config TEGRA124_MMC_DISABLE_EXT_LOOPBACK diff --git a/drivers/mmc/Makefile b/drivers/mmc/Makefile index a078649..08a552a 100644 --- a/drivers/mmc/Makefile +++ b/drivers/mmc/Makefile @@ -44,6 +44,7 @@ obj-$(CONFIG_S3C_SDI) += s3c_sdi.o obj-$(CONFIG_MMC_SANDBOX) += sandbox_mmc.o obj-$(CONFIG_SH_MMCIF) += sh_mmcif.o obj-$(CONFIG_SH_SDHI) += sh_sdhi.o +obj-$(CONFIG_MMC_NDS32) += nds32_mmc.o
# SDHCI obj-$(CONFIG_MMC_SDHCI) += sdhci.o diff --git a/drivers/mmc/ftsdc010_mci.c b/drivers/mmc/ftsdc010_mci.c index 652a718..ec0bc6b 100644 --- a/drivers/mmc/ftsdc010_mci.c +++ b/drivers/mmc/ftsdc010_mci.c @@ -12,24 +12,15 @@ #include <part.h> #include <mmc.h>
-#include <asm/io.h> +#include <linux/io.h> #include <linux/errno.h> #include <asm/byteorder.h> #include <faraday/ftsdc010.h> +#include "ftsdc010_mci.h"
#define CFG_CMD_TIMEOUT (CONFIG_SYS_HZ >> 4) /* 250 ms */ #define CFG_RST_TIMEOUT CONFIG_SYS_HZ /* 1 sec reset timeout */
-struct ftsdc010_chip { - void __iomem *regs; - uint32_t wprot; /* write protected (locked) */ - uint32_t rate; /* actual SD clock in Hz */ - uint32_t sclk; /* FTSDC010 source clock in Hz */ - uint32_t fifo; /* fifo depth in bytes */ - uint32_t acmd; - struct mmc_config cfg; /* mmc configuration */ -}; - static inline int ftsdc010_send_cmd(struct mmc *mmc, struct mmc_cmd *mmc_cmd) { struct ftsdc010_chip *chip = mmc->priv; @@ -127,9 +118,8 @@ static void ftsdc010_clkset(struct mmc *mmc, uint32_t rate) static int ftsdc010_wait(struct ftsdc010_mmc __iomem *regs, uint32_t mask) { int ret = -ETIMEDOUT; - uint32_t st, ts; - - for (ts = get_timer(0); get_timer(ts) < CFG_CMD_TIMEOUT; ) { + uint32_t st, timeout = 10000000; + while (timeout--) { st = readl(®s->status); if (!(st & mask)) continue; @@ -147,10 +137,16 @@ static int ftsdc010_wait(struct ftsdc010_mmc __iomem *regs, uint32_t mask) /* * u-boot mmc api */ - +#ifdef CONFIG_DM_MMC_OPS +static int ftsdc010_request(struct udevice *dev, struct mmc_cmd *cmd, + struct mmc_data *data) +{ + struct mmc *mmc = mmc_get_mmc_dev(dev); +#else static int ftsdc010_request(struct mmc *mmc, struct mmc_cmd *cmd, struct mmc_data *data) { +#endif int ret = -EOPNOTSUPP; uint32_t len = 0; struct ftsdc010_chip *chip = mmc->priv; @@ -251,8 +247,14 @@ static int ftsdc010_request(struct mmc *mmc, struct mmc_cmd *cmd, return ret; }
+#ifdef CONFIG_DM_MMC_OPS +static int ftsdc010_set_ios(struct udevice *dev) +{ + struct mmc *mmc = mmc_get_mmc_dev(dev); +#else static int ftsdc010_set_ios(struct mmc *mmc) { +#endif struct ftsdc010_chip *chip = mmc->priv; struct ftsdc010_mmc __iomem *regs = chip->regs;
@@ -274,20 +276,46 @@ static int ftsdc010_set_ios(struct mmc *mmc) return 0; }
-static int ftsdc010_init(struct mmc *mmc) +#ifdef CONFIG_DM_MMC_OPS +static int ftsdc010_get_cd(struct udevice *dev) { + struct mmc *mmc = mmc_get_mmc_dev(dev); +#else +static int ftsdc010_getcd(struct mmc *mmc) +{ +#endif struct ftsdc010_chip *chip = mmc->priv; struct ftsdc010_mmc __iomem *regs = chip->regs; - uint32_t ts; - if (readl(®s->status) & FTSDC010_STATUS_CARD_DETECT) - return -ENOMEDIUM; + return 0; + + return 1; +}
+#ifdef CONFIG_DM_MMC_OPS +static int ftsdc010_get_wp(struct udevice *dev) +{ + struct mmc *mmc = mmc_get_mmc_dev(dev); +#else +static int ftsdc010_getwp(struct mmc *mmc) +{ +#endif + struct ftsdc010_chip *chip = mmc->priv; + struct ftsdc010_mmc __iomem *regs = chip->regs; if (readl(®s->status) & FTSDC010_STATUS_WRITE_PROT) { printf("ftsdc010: write protected\n"); chip->wprot = 1; }
+ return 0; +} + +static int ftsdc010_init(struct mmc *mmc) +{ + struct ftsdc010_chip *chip = mmc->priv; + struct ftsdc010_mmc __iomem *regs = chip->regs; + uint32_t ts; + chip->fifo = (readl(®s->feature) & 0xff) << 2;
/* 1. chip reset */ @@ -311,11 +339,70 @@ static int ftsdc010_init(struct mmc *mmc) return 0; }
+#ifdef CONFIG_DM_MMC_OPS +int ftsdc010_probe(struct udevice *dev) +{ + struct mmc *mmc = mmc_get_mmc_dev(dev); + return ftsdc010_init(mmc); +} + +const struct dm_mmc_ops dm_ftsdc010_ops = { + .send_cmd = ftsdc010_request, + .set_ios = ftsdc010_set_ios, + .get_cd = ftsdc010_get_cd, + .get_wp = ftsdc010_get_wp, +}; + +#else static const struct mmc_ops ftsdc010_ops = { .send_cmd = ftsdc010_request, .set_ios = ftsdc010_set_ios, + .getcd = ftsdc010_getcd, + .getwp = ftsdc010_getwp, .init = ftsdc010_init, }; +#endif + +void ftsdc_setup_cfg(struct mmc_config *cfg, const char *name, int buswidth, + uint caps, u32 max_clk, u32 min_clk) +{ + cfg->name = name; + cfg->f_min = min_clk; + cfg->f_max = max_clk; + cfg->voltages = MMC_VDD_32_33 | MMC_VDD_33_34 | MMC_VDD_165_195; + cfg->host_caps = caps; + if (buswidth == 8) { + cfg->host_caps |= MMC_MODE_8BIT; + cfg->host_caps &= ~MMC_MODE_4BIT; + } else { + cfg->host_caps |= MMC_MODE_4BIT; + cfg->host_caps &= ~MMC_MODE_8BIT; + } + cfg->host_caps |= MMC_MODE_HS | MMC_MODE_HS_52MHz; + cfg->part_type = PART_TYPE_DOS; + cfg->b_max = CONFIG_SYS_MMC_MAX_BLK_COUNT; +} + +void set_bus_width(struct ftsdc010_mmc __iomem *regs, struct mmc_config *cfg) +{ + switch (readl(®s->bwr) & FTSDC010_BWR_CAPS_MASK) { + case FTSDC010_BWR_CAPS_4BIT: + cfg->host_caps |= MMC_MODE_4BIT; + break; + case FTSDC010_BWR_CAPS_8BIT: + cfg->host_caps |= MMC_MODE_4BIT | MMC_MODE_8BIT; + break; + default: + break; + } +} + +#ifdef CONFIG_BLK +int ftsdc010_bind(struct udevice *dev, struct mmc *mmc, struct mmc_config *cfg) +{ + return mmc_bind(dev, mmc, cfg); +} +#else
int ftsdc010_mmc_init(int devid) { @@ -345,19 +432,11 @@ int ftsdc010_mmc_init(int devid) #endif
chip->cfg.name = "ftsdc010"; +#ifndef CONFIG_DM_MMC_OPS chip->cfg.ops = &ftsdc010_ops; +#endif chip->cfg.host_caps = MMC_MODE_HS | MMC_MODE_HS_52MHz; - switch (readl(®s->bwr) & FTSDC010_BWR_CAPS_MASK) { - case FTSDC010_BWR_CAPS_4BIT: - chip->cfg.host_caps |= MMC_MODE_4BIT; - break; - case FTSDC010_BWR_CAPS_8BIT: - chip->cfg.host_caps |= MMC_MODE_4BIT | MMC_MODE_8BIT; - break; - default: - break; - } - + set_bus_width(regs , &chip->cfg); chip->cfg.voltages = MMC_VDD_32_33 | MMC_VDD_33_34; chip->cfg.f_max = chip->sclk / 2; chip->cfg.f_min = chip->sclk / 0x100; @@ -373,3 +452,4 @@ int ftsdc010_mmc_init(int devid)
return 0; } +#endif diff --git a/drivers/mmc/ftsdc010_mci.h b/drivers/mmc/ftsdc010_mci.h new file mode 100644 index 0000000..f74015e --- /dev/null +++ b/drivers/mmc/ftsdc010_mci.h @@ -0,0 +1,54 @@ +/* + * Faraday FTSDC010 Secure Digital Memory Card Host Controller + * + * Copyright (C) 2011 Andes Technology Corporation + * Macpaul Lin, Andes Technology Corporation macpaul@andestech.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ +#include <mmc.h> + +#ifndef __FTSDC010_MCI_H +#define __FTSDC010_MCI_H + +struct ftsdc010_chip { + void __iomem *regs; + uint32_t wprot; /* write protected (locked) */ + uint32_t rate; /* actual SD clock in Hz */ + uint32_t sclk; /* FTSDC010 source clock in Hz */ + uint32_t fifo; /* fifo depth in bytes */ + uint32_t acmd; + struct mmc_config cfg; /* mmc configuration */ + const char *name; + void *ioaddr; + unsigned int quirks; + unsigned int caps; + unsigned int version; + unsigned int clock; + unsigned int bus_hz; + unsigned int div; + int dev_index; + int dev_id; + int buswidth; + u32 fifoth_val; + struct mmc *mmc; + void *priv; + bool fifo_mode; +}; + + +#ifdef CONFIG_DM_MMC_OPS +/* Export the operations to drivers */ +int ftsdc010_probe(struct udevice *dev); +extern const struct dm_mmc_ops dm_ftsdc010_ops; +#endif +void ftsdc_setup_cfg(struct mmc_config *cfg, const char *name, int buswidth, + uint caps, u32 max_clk, u32 min_clk); +void set_bus_width(struct ftsdc010_mmc __iomem *regs, struct mmc_config *cfg); + +#ifdef CONFIG_BLK +int ftsdc010_bind(struct udevice *dev, struct mmc *mmc, struct mmc_config *cfg); +#endif + + +#endif /* __FTSDC010_MCI_H */ diff --git a/drivers/mmc/nds32_mmc.c b/drivers/mmc/nds32_mmc.c new file mode 100644 index 0000000..ec25fe9 --- /dev/null +++ b/drivers/mmc/nds32_mmc.c @@ -0,0 +1,139 @@ +/* + * Andestech ATFSDC010 SD/MMC driver + * + * (C) Copyright 2016 + * Rick Chen, NDS32 Software Engineering, rick@andestech.com + + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <clk.h> +#include <dm.h> +#include <dt-structs.h> +#include <faraday/ftsdc010.h> +#include <errno.h> +#include <mapmem.h> +#include <pwrseq.h> +#include <syscon.h> +#include <mmc.h> +#include <linux/err.h> +#include "ftsdc010_mci.h" + +DECLARE_GLOBAL_DATA_PTR; + +#if CONFIG_IS_ENABLED(OF_PLATDATA) +struct nds_mmc { + fdt32_t bus_width; + bool cap_mmc_highspeed; + bool cap_sd_highspeed; + fdt32_t card_detect_delay; + fdt32_t clock_freq_min_max[2]; + struct phandle_2_cell clocks[4]; + bool disable_wp; + fdt32_t fifo_depth; + fdt32_t interrupts[3]; + fdt32_t num_slots; + fdt32_t reg[2]; + fdt32_t vmmc_supply; +}; +#endif + +struct nds_mmc_plat { +#if CONFIG_IS_ENABLED(OF_PLATDATA) + struct nds_mmc dtplat; +#endif + struct mmc_config cfg; + struct mmc mmc; +}; + +struct ftsdc_priv { + struct clk clk; + struct ftsdc010_chip chip; + int fifo_depth; + bool fifo_mode; + u32 minmax[2]; +}; + +static int nds32_mmc_ofdata_to_platdata(struct udevice *dev) +{ +#if !CONFIG_IS_ENABLED(OF_PLATDATA) + struct ftsdc_priv *priv = dev_get_priv(dev); + struct ftsdc010_chip *chip = &priv->chip; + chip->name = dev->name; + chip->ioaddr = (void *)dev_get_addr(dev); + chip->buswidth = fdtdec_get_int(gd->fdt_blob, dev->of_offset, + "bus-width", 4); + chip->priv = dev; + /* use non-removeable as sdcard and emmc as judgement */ + if (fdtdec_get_bool(gd->fdt_blob, dev->of_offset, "non-removable")) + chip->dev_index = 0; + else + chip->dev_index = 1; + + priv->fifo_depth = fdtdec_get_int(gd->fdt_blob, dev->of_offset, + "fifo-depth", 0); + priv->fifo_mode = fdtdec_get_bool(gd->fdt_blob, dev->of_offset, + "fifo-mode"); + if (fdtdec_get_int_array(gd->fdt_blob, dev->of_offset, + "clock-freq-min-max", priv->minmax, 2)) + return -EINVAL; +#endif + chip->sclk = priv->minmax[1]; + chip->regs = chip->ioaddr; + return 0; +} + +static int nds32_mmc_probe(struct udevice *dev) +{ + struct nds_mmc_plat *plat = dev_get_platdata(dev); + struct mmc_uclass_priv *upriv = dev_get_uclass_priv(dev); + struct ftsdc_priv *priv = dev_get_priv(dev); + struct ftsdc010_chip *chip = &priv->chip; + struct udevice *pwr_dev __maybe_unused; +#if CONFIG_IS_ENABLED(OF_PLATDATA) + int ret; + struct nds_mmc *dtplat = &plat->dtplat; + chip->name = dev->name; + chip->ioaddr = map_sysmem(dtplat->reg[0], dtplat->reg[1]); + chip->buswidth = dtplat->bus_width; + chip->priv = dev; + chip->dev_index = 0; + priv->fifo_depth = dtplat->fifo_depth; + priv->fifo_mode = 0; + memcpy(priv->minmax, dtplat->clock_freq_min_max, sizeof(priv->minmax)); + ret = clk_get_by_index_platdata(dev, 0, dtplat->clocks, &priv->clk); + if (ret < 0) + return ret; +#endif + ftsdc_setup_cfg(&plat->cfg, dev->name, chip->buswidth, chip->caps, + priv->minmax[1] , priv->minmax[0]); + chip->mmc = &plat->mmc; + chip->mmc->priv = &priv->chip; + chip->mmc->dev = dev; + upriv->mmc = chip->mmc; + return ftsdc010_probe(dev); +} + +static int nds32_mmc_bind(struct udevice *dev) +{ + struct nds_mmc_plat *plat = dev_get_platdata(dev); + return ftsdc010_bind(dev, &plat->mmc, &plat->cfg); +} + +static const struct udevice_id nds32_mmc_ids[] = { + { .compatible = "andestech,atsdc010" }, + { } +}; + +U_BOOT_DRIVER(nds32_mmc_drv) = { + .name = "nds32_mmc", + .id = UCLASS_MMC, + .of_match = nds32_mmc_ids, + .ofdata_to_platdata = nds32_mmc_ofdata_to_platdata, + .ops = &dm_ftsdc010_ops, + .bind = nds32_mmc_bind, + .probe = nds32_mmc_probe, + .priv_auto_alloc_size = sizeof(struct ftsdc_priv), + .platdata_auto_alloc_size = sizeof(struct nds_mmc_plat), +}; diff --git a/include/configs/adp-ae3xx.h b/include/configs/adp-ae3xx.h index 6bfc08e..011b2a8 100644 --- a/include/configs/adp-ae3xx.h +++ b/include/configs/adp-ae3xx.h @@ -92,7 +92,6 @@ /* * SD (MMC) controller */ -#define CONFIG_FTSDC010 #define CONFIG_FTSDC010_NUMBER 1 #define CONFIG_FTSDC010_SDIO
diff --git a/include/configs/adp-ag101p.h b/include/configs/adp-ag101p.h index 4cef64e..71a557b 100644 --- a/include/configs/adp-ag101p.h +++ b/include/configs/adp-ag101p.h @@ -98,7 +98,6 @@ /* * SD (MMC) controller */ -#define CONFIG_FTSDC010 #define CONFIG_FTSDC010_NUMBER 1 #define CONFIG_FTSDC010_SDIO
Split the patch...
1 file(s)
- mmc0: mmc@f0e00000 {
- nor@0,0 { compatible = "cfi-flash"; reg = <0x88000000 0x1000>;
- mmc0: mmc@98e00000 {
interrupts = <5 4>;
- Miscellaneous platform dependent initializations
+config MMC_NDS32
- bool "Andestech SD/MMC controller support"
- depends on DM_MMC && OF_CONTROL
- help
+config FTSDC010
- bool "Ftsdc010 SD/MMC controller Support"
- help
endif
- uint32_t acmd;
- uint32_t st, ts;
- uint32_t st, timeout = 10000000;
- while (timeout--) { st = readl(®s->status); if (!(st & mask)) continue;
- u-boot mmc api
- struct mmc_data *data)
- struct mmc *mmc = mmc_get_mmc_dev(dev);
- uint32_t ts;
return -ENOMEDIUM;
- return 1;
uint32_t ts;
/* 1. chip reset */
- return ftsdc010_init(mmc);
- .send_cmd = ftsdc010_request,
- .set_ios = ftsdc010_set_ios,
- .get_cd = ftsdc010_get_cd,
- .get_wp = ftsdc010_get_wp,
- .getcd = ftsdc010_getcd,
- .getwp = ftsdc010_getwp, .init = ftsdc010_init,
}; +#endif
- cfg->name = name;
- cfg->f_min = min_clk;
- cfg->f_max = max_clk;
- cfg->voltages = MMC_VDD_32_33 | MMC_VDD_33_34 | MMC_VDD_165_195;
- cfg->host_caps = caps;
- if (buswidth == 8) {
- } else {
- cfg->host_caps |= MMC_MODE_HS | MMC_MODE_HS_52MHz;
- cfg->part_type = PART_TYPE_DOS;
- cfg->b_max = CONFIG_SYS_MMC_MAX_BLK_COUNT;
break;
break;
- default:
break;
- return mmc_bind(dev, mmc, cfg);
+} +#else
break;
break;
- default:
break;
- set_bus_width(regs , &chip->cfg); chip->cfg.voltages = MMC_VDD_32_33 | MMC_VDD_33_34; chip->cfg.f_max = chip->sclk / 2; chip->cfg.f_min = chip->sclk / 0x100;
- Faraday FTSDC010 Secure Digital Memory Card Host Controller
- Copyright (C) 2011 Andes Technology Corporation
- Macpaul Lin, Andes Technology Corporation macpaul@andestech.com
+#include <mmc.h>
- uint32_t acmd;
- const char *name;
- void *ioaddr;
- unsigned int quirks;
- unsigned int caps;
- unsigned int version;
- unsigned int clock;
- unsigned int bus_hz;
- unsigned int div;
- int dev_index;
- int dev_id;
- int buswidth;
- u32 fifoth_val;
- struct mmc *mmc;
- void *priv;
- bool fifo_mode;
- Andestech ATFSDC010 SD/MMC driver
- (C) Copyright 2016
- Rick Chen, NDS32 Software Engineering, rick@andestech.com
- fdt32_t bus_width;
- bool cap_mmc_highspeed;
- bool cap_sd_highspeed;
- fdt32_t card_detect_delay;
- fdt32_t clock_freq_min_max[2];
- struct phandle_2_cell clocks[4];
- bool disable_wp;
- fdt32_t fifo_depth;
- fdt32_t interrupts[3];
- fdt32_t num_slots;
- fdt32_t reg[2];
- fdt32_t vmmc_supply;
+}; +#endif
- struct nds_mmc dtplat;
- struct mmc mmc;
- struct clk clk;
- struct ftsdc010_chip chip;
- int fifo_depth;
- bool fifo_mode;
- u32 minmax[2];
- struct ftsdc_priv *priv = dev_get_priv(dev);
- struct ftsdc010_chip *chip = &priv->chip;
- chip->name = dev->name;
- chip->ioaddr = (void *)dev_get_addr(dev);
- chip->buswidth = fdtdec_get_int(gd->fdt_blob, dev->of_offset,
"bus-width", 4);
- chip->priv = dev;
- /* use non-removeable as sdcard and emmc as judgement */
- if (fdtdec_get_bool(gd->fdt_blob, dev->of_offset, "non-removable"))
- else
- priv->fifo_depth = fdtdec_get_int(gd->fdt_blob, dev->of_offset,
"fifo-depth", 0);
- priv->fifo_mode = fdtdec_get_bool(gd->fdt_blob, dev->of_offset,
"fifo-mode");
- if (fdtdec_get_int_array(gd->fdt_blob, dev->of_offset,
return -EINVAL;
- chip->sclk = priv->minmax[1];
- chip->regs = chip->ioaddr;
- struct nds_mmc_plat *plat = dev_get_platdata(dev);
- struct mmc_uclass_priv *upriv = dev_get_uclass_priv(dev);
- struct udevice *pwr_dev __maybe_unused;
- int ret;
- struct nds_mmc *dtplat = &plat->dtplat;
- chip->ioaddr = map_sysmem(dtplat->reg[0], dtplat->reg[1]);
- chip->buswidth = dtplat->bus_width;
- chip->priv = dev;
- chip->dev_index = 0;
- priv->fifo_depth = dtplat->fifo_depth;
- priv->fifo_mode = 0;
- memcpy(priv->minmax, dtplat->clock_freq_min_max, sizeof(priv->minmax));
- ret = clk_get_by_index_platdata(dev, 0, dtplat->clocks, &priv->clk);
- if (ret < 0)
return ret;
- ftsdc_setup_cfg(&plat->cfg, dev->name, chip->buswidth, chip->caps,
- chip->mmc = &plat->mmc;
- chip->mmc->priv = &priv->chip;
- chip->mmc->dev = dev;
- upriv->mmc = chip->mmc;
- return ftsdc010_probe(dev);
- return ftsdc010_bind(dev, &plat->mmc, &plat->cfg);
- { .compatible = "andestech,atsdc010" },
- .name = "nds32_mmc",
- .id = UCLASS_MMC,
- .of_match = nds32_mmc_ids,
- .ofdata_to_platdata = nds32_mmc_ofdata_to_platdata,
- .ops = &dm_ftsdc010_ops,
- .bind = nds32_mmc_bind,
- .probe = nds32_mmc_probe,
- .priv_auto_alloc_size = sizeof(struct ftsdc_priv),
- .platdata_auto_alloc_size = sizeof(struct nds_mmc_plat),
- SD (MMC) controller
Hi Jaehoon
Sorry for the late response because of the vacations.
I have splitted it to 3 parts.
Thanks
Rick
-----Original Message----- From: U-Boot [mailto:u-boot-bounces@lists.denx.de] On Behalf Of Jaehoon Chung Sent: Thursday, May 25, 2017 10:03 PM To: Open Source Project uboot; u-boot@lists.denx.de; wd@denx.de; dzu@denx.de Subject: Re: [U-Boot] [PATCH] nds32: mmc: Support ftsdc010 DM.
Split the patch...
1 file(s)
interrupts = <5 4>;
+config MMC_NDS32
help
+config FTSDC010
help
endif
void __iomem *regs;
uint32_t acmd;
uint32_t st, ts;
- u-boot mmc api
struct mmc *mmc = mmc_get_mmc_dev(dev); #else
+#ifdef CONFIG_DM_MMC_OPS +static int ftsdc010_set_ios(struct udevice *dev) {
struct mmc *mmc = mmc_get_mmc_dev(dev); #else static int
+ftsdc010_getcd(struct mmc *mmc) { #endif struct ftsdc010_chip *chip = mmc->priv; struct ftsdc010_mmc __iomem *regs = chip->regs;
uint32_t ts;
return -ENOMEDIUM;
return 1;
+#ifdef CONFIG_DM_MMC_OPS +static int ftsdc010_get_wp(struct udevice *dev) {
+ftsdc010_getwp(struct mmc *mmc) { #endif
+static int ftsdc010_init(struct mmc *mmc) {
uint32_t ts;
chip->fifo = (readl(®s->feature) & 0xff) << 2; /* 1. chip reset */
+#ifdef CONFIG_DM_MMC_OPS +int ftsdc010_probe(struct udevice *dev) {
}; +#endif
uint caps, u32 max_clk, u32 min_clk) {
cfg->name = name;
} else {
cfg->b_max = CONFIG_SYS_MMC_MAX_BLK_COUNT; }
+void set_bus_width(struct ftsdc010_mmc __iomem *regs, struct +mmc_config *cfg) {
break;
break;
default:
break;
+#ifdef CONFIG_BLK +int ftsdc010_bind(struct udevice *dev, struct mmc *mmc, struct +mmc_config *cfg) {
+} +#else
break;
break;
default:
break;
+#include <mmc.h>
void __iomem *regs;
uint32_t acmd;
const char *name;
void *ioaddr;
unsigned int caps;
unsigned int clock;
unsigned int div;
int dev_index;
int dev_id;
int buswidth;
u32 fifoth_val;
struct mmc *mmc;
void *priv;
bool fifo_mode;
+#ifdef CONFIG_DM_MMC_OPS +/* Export the operations to drivers */ int ftsdc010_probe(struct +udevice *dev); extern const struct dm_mmc_ops dm_ftsdc010_ops; #endif +void ftsdc_setup_cfg(struct mmc_config *cfg, const char *name, int buswidth,
uint caps, u32 max_clk, u32 min_clk); void
+set_bus_width(struct ftsdc010_mmc __iomem *regs, struct mmc_config +*cfg);
+#ifdef CONFIG_BLK +int ftsdc010_bind(struct udevice *dev, struct mmc *mmc, struct +mmc_config *cfg); #endif
fdt32_t bus_width;
bool disable_wp;
fdt32_t fifo_depth;
fdt32_t num_slots;
fdt32_t reg[2];
+}; +#endif
struct mmc mmc;
struct clk clk;
int fifo_depth;
bool fifo_mode;
u32 minmax[2];
+static int nds32_mmc_ofdata_to_platdata(struct udevice *dev) { #if +!CONFIG_IS_ENABLED(OF_PLATDATA)
"bus-width", 4);
chip->priv = dev;
else
"fifo-depth", 0);
"fifo-mode");
return -EINVAL;
+static int nds32_mmc_probe(struct udevice *dev) {
struct udevice *pwr_dev __maybe_unused; #if
+CONFIG_IS_ENABLED(OF_PLATDATA)
int ret;
chip->priv = dev;
if (ret < 0)
return ret;
+static int nds32_mmc_bind(struct udevice *dev) {
return ftsdc010_bind(dev, &plat->mmc, &plat->cfg); }
.id = UCLASS_MMC,
.platdata_auto_alloc_size = sizeof(struct nds_mmc_plat), };
_______________________________________________ U-Boot mailing list U-Boot@lists.denx.de https://lists.denx.de/listinfo/u-boot CONFIDENTIALITY NOTICE:
This e-mail (and its attachments) may contain confidential and legally privileged information or information protected from disclosure. If you are not the intended recipient, you are hereby notified that any disclosure, copying, distribution, or use of the information contained herein is strictly prohibited. In this case, please immediately notify the sender by return e-mail, delete the message (and any accompanying documents) and destroy all printed hard copies. Thank you for your cooperation.
Copyright ANDES TECHNOLOGY CORPORATION - All Rights Reserved.
Andes
Jaehoon Chung
rickļ¼ andestech.com
