[U-Boot] [PATCH v2] vboot: Add FIT_SIGNATURE_MAX_SIZE protection
This adds a new config value FIT_SIGNATURE_MAX_SIZE, which controls the max size of a FIT header's totalsize field. The field is checked before signature checks are applied to protect from reading past the intended FIT regions.
This field is not part of the vboot signature so it should be sanity checked. If the field is corrupted then the structure or string region reads may have unintended behavior, such as reading from device memory. A default value of 256MB is set and intended to support most max storage sizes.
Suggested-by: Simon Glass sjg@chromium.org Signed-off-by: Teddy Reed teddy.reed@gmail.com Reviewed-by: Simon Glass sjg@chromium.org --- Kconfig | 10 ++++++++++ common/image-sig.c | 5 +++++ test/py/tests/test_vboot.py | 33 +++++++++++++++++++++++++++++++++ tools/Makefile | 1 + 4 files changed, 49 insertions(+)
diff --git a/Kconfig b/Kconfig index 5a82c95..c8b86cd 100644 --- a/Kconfig +++ b/Kconfig @@ -267,6 +267,16 @@ config FIT_SIGNATURE format support in this case, enable it using CONFIG_IMAGE_FORMAT_LEGACY.
+config FIT_SIGNATURE_MAX_SIZE + hex "Max size of signed FIT structures" + depends on FIT_SIGNATURE + default 0x10000000 + help + This option sets a max size in bytes for verified FIT uImages. + A sane value of 256MB protects corrupted DTB structures from overlapping + device memory. Assure this size does not extend past expected storage + space. + config FIT_VERBOSE bool "Show verbose messages when FIT images fail" help diff --git a/common/image-sig.c b/common/image-sig.c index f65d883..8d2fd10 100644 --- a/common/image-sig.c +++ b/common/image-sig.c @@ -156,6 +156,11 @@ static int fit_image_setup_verify(struct image_sign_info *info, { char *algo_name;
+ if (fdt_totalsize(fit) > CONFIG_FIT_SIGNATURE_MAX_SIZE) { + *err_msgp = "Total size too large"; + return 1; + } + if (fit_image_hash_get_algo(fit, noffset, &algo_name)) { *err_msgp = "Can't get hash algo property"; return -1; diff --git a/test/py/tests/test_vboot.py b/test/py/tests/test_vboot.py index ee939f2..3d25ec3 100644 --- a/test/py/tests/test_vboot.py +++ b/test/py/tests/test_vboot.py @@ -26,6 +26,7 @@ Tests run with both SHA1 and SHA256 hashing.
import pytest import sys +import struct import u_boot_utils as util
@pytest.mark.boardspec('sandbox') @@ -105,6 +106,26 @@ def test_vboot(u_boot_console): util.run_and_log(cons, [mkimage, '-F', '-k', tmpdir, '-K', dtb, '-r', fit])
+ def replace_fit_totalsize(size): + """Replace FIT header's totalsize with something greater. + + The totalsize must be less than or equal to FIT_SIGNATURE_MAX_SIZE. + If the size is greater, the signature verification should return false. + + Args: + size: The new totalsize of the header + + Returns: + prev_size: The previous totalsize read from the header + """ + total_size = 0 + with open(fit, 'r+b') as handle: + handle.seek(4) + total_size = handle.read(4) + handle.seek(4) + handle.write(struct.pack(">I", size)) + return struct.unpack(">I", total_size)[0] + def test_with_algo(sha_algo): """Test verified boot with the given hash algorithm.
@@ -146,6 +167,18 @@ def test_vboot(u_boot_console): util.run_and_log(cons, [fit_check_sign, '-f', fit, '-k', tmpdir, '-k', dtb])
+ # Replace header bytes + bcfg = u_boot_console.config.buildconfig + max_size = int(bcfg.get('config_fit_signature_max_size', 0x10000000), 0) + existing_size = replace_fit_totalsize(max_size + 1) + run_bootm(sha_algo, 'Signed config with bad hash', 'Bad Data Hash', False) + cons.log.action('%s: Check overflowed FIT header totalsize' % sha_algo) + + # Replace with existing header bytes + replace_fit_totalsize(existing_size) + run_bootm(sha_algo, 'signed config', 'dev+', True) + cons.log.action('%s: Check default FIT header totalsize' % sha_algo) + # Increment the first byte of the signature, which should cause failure sig = util.run_and_log(cons, 'fdtget -t bx %s %s value' % (fit, sig_node)) diff --git a/tools/Makefile b/tools/Makefile index 5dd33ed..0c3341e 100644 --- a/tools/Makefile +++ b/tools/Makefile @@ -133,6 +133,7 @@ ifdef CONFIG_FIT_SIGNATURE # This affects include/image.h, but including the board config file # is tricky, so manually define this options here. HOST_EXTRACFLAGS += -DCONFIG_FIT_SIGNATURE +HOST_EXTRACFLAGS += -DCONFIG_FIT_SIGNATURE_MAX_SIZE=$(CONFIG_FIT_SIGNATURE_MAX_SIZE) endif
ifdef CONFIG_SYS_U_BOOT_OFFS
Teddy Reed
