Re: [PATCH v4 1/8] binman: ti-secure: Add support for firewalling entities
Hi Manorit,
This commit added a possibly unintentional dependency on python 3.9+.
I ran into this while trying to build the soon-to-be-released 09.01.00.008.
Build failure on ubuntu 20.04 which uses python 3.8: "binman: 'type' object is not subscriptable"
This can be fixed by:
diff --git a/tools/binman/etype/ti_secure.py b/tools/binman/etype/ti_secure.py index f80eb542c956..872c6d38ff46 100644 --- a/tools/binman/etype/ti_secure.py +++ b/tools/binman/etype/ti_secure.py @@ -16,7 +16,7 @@ class Firewall(): id: int region: int control : int - permissions: list[hex] + permissions: list start_address: str end_address: str
Hi Manorit,
On Wed, 11 Oct 2023 at 23:02, Manorit Chawdhry m-chawd...@ti.com wrote:
Hi Simon,
On 11:54-20231011, Manorit Chawdhry wrote:
We can now firewall entities while loading them through our secure entity TIFS, the required information should be present in the certificate that is being parsed by TIFS.
The following commit adds the support to enable the certificates to be generated if the firewall configurations are present in the binman dtsi nodes.
Signed-off-by: Manorit Chawdhry m-chawd...@ti.com
tools/binman/btool/openssl.py | 16 +++++++- tools/binman/etype/ti_secure.py | 90 +++++++++++++++++++++++++++++++++++++++++ tools/binman/etype/x509_cert.py | 3 +- 3 files changed, 106 insertions(+), 3 deletions(-)
from binman.entry import EntryArg from binman.etype.x509_cert import Entry_x509_cert +from dataclasses import dataclass
What all python versions do we support in u-boot? I see that dataclasses are in-built from python3.7 but for older versions we would need to install them separately, do I need to add this in buildman requirements for those versions?
I would prefer not to worry about Python 3.6 if possible. There are a few workarounds in buildman for it, though.
Hi Jon,
On Thu, 14 Dec 2023 at 14:49, Jon Cormier jcormier@criticallink.com wrote:
Hi Manorit,
Thank you for reporting this. Yes, we should not require python 3.9, even though I feel it is reasonable to give up on 3.6 at this stage.
- permissions: list start_address: str end_address: str
Hi Manorit,
Hi Simon,
Jon Cormier
