[U-Boot] [PATCH 1/2] MX5: Update to autogenerated asm-offsets.h
On i.MX5, the asm-offsets.h file is not yet generated as it should be.
Signed-off-by: Stefano Babic sbabic@denx.de CC: Matthias Weisser weisserm@arcor.de --- arch/arm/cpu/armv7/mx5/Makefile | 13 +++++ arch/arm/cpu/armv7/mx5/asm-offsets.c | 76 +++++++++++++++++++++++++++ arch/arm/include/asm/arch-mx5/asm-offsets.h | 55 ------------------- arch/arm/include/asm/arch-mx5/imx-regs.h | 18 ++++++ 4 files changed, 107 insertions(+), 55 deletions(-) create mode 100644 arch/arm/cpu/armv7/mx5/asm-offsets.c delete mode 100644 arch/arm/include/asm/arch-mx5/asm-offsets.h
diff --git a/arch/arm/cpu/armv7/mx5/Makefile b/arch/arm/cpu/armv7/mx5/Makefile index e8be9c9..5d53f6a 100644 --- a/arch/arm/cpu/armv7/mx5/Makefile +++ b/arch/arm/cpu/armv7/mx5/Makefile @@ -45,4 +45,17 @@ include $(SRCTREE)/rules.mk
sinclude $(obj).depend
+lowlevel_init.o : $(TOPDIR)/include/asm/arch/asm-offsets.h + ######################################################################### + +$(TOPDIR)/include/asm/arch/asm-offsets.h: $(TOPDIR)/include/autoconf.mk.dep \ + ./asm-offsets.s + @echo Generating $@ + $(TOPDIR)/tools/scripts/make-asm-offsets ./asm-offsets.s $@ + +asm-offsets.s: $(TOPDIR)/include/autoconf.mk.dep \ + ./asm-offsets.c + $(CC) -DDO_DEPS_ONLY \ + $(CFLAGS) $(CFLAGS_$(BCURDIR)/$(@F)) $(CFLAGS_$(BCURDIR)) \ + -o $@ ./asm-offsets.c -c -S diff --git a/arch/arm/cpu/armv7/mx5/asm-offsets.c b/arch/arm/cpu/armv7/mx5/asm-offsets.c new file mode 100644 index 0000000..f972498 --- /dev/null +++ b/arch/arm/cpu/armv7/mx5/asm-offsets.c @@ -0,0 +1,76 @@ +/* + * Adapted from Linux v2.6.36 kernel: arch/powerpc/kernel/asm-offsets.c + * + * This program is used to generate definitions needed by + * assembly language modules. + * + * We use the technique used in the OSF Mach kernel code: + * generate asm statements containing #defines, + * compile this file to assembler, and then extract the + * #defines from the assembly-language output. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License + * as published by the Free Software Foundation; either version + * 2 of the License, or (at your option) any later version. + */ + +#include <common.h> +#include <asm/arch/imx-regs.h> + +#include <linux/kbuild.h> + +int main(void) +{ + + /* Round up to make sure size gives nice stack alignment */ + DEFINE(CLKCTL_CCMR, offsetof(struct clkctl, ccr)); + DEFINE(CLKCTL_CCDR, offsetof(struct clkctl, ccdr)); + DEFINE(CLKCTL_CSR, offsetof(struct clkctl, csr)); + DEFINE(CLKCTL_CCSR, offsetof(struct clkctl, ccsr)); + DEFINE(CLKCTL_CACRR, offsetof(struct clkctl, cacrr)); + DEFINE(CLKCTL_CBCDR, offsetof(struct clkctl, cbcdr)); + DEFINE(CLKCTL_CBCMR, offsetof(struct clkctl, cbcmr)); + DEFINE(CLKCTL_CSCMR1, offsetof(struct clkctl, cscmr1)); + DEFINE(CLKCTL_CSCMR2, offsetof(struct clkctl, cscmr2)); + DEFINE(CLKCTL_CSCDR1, offsetof(struct clkctl, cscdr1)); + DEFINE(CLKCTL_CS1CDR, offsetof(struct clkctl, cs1cdr)); + DEFINE(CLKCTL_CS2CDR, offsetof(struct clkctl, cs2cdr)); + DEFINE(CLKCTL_CDCDR, offsetof(struct clkctl, cdcdr)); + DEFINE(CLKCTL_CHSCCDR, offsetof(struct clkctl, chsccdr)); + DEFINE(CLKCTL_CSCDR2, offsetof(struct clkctl, cscdr2)); + DEFINE(CLKCTL_CSCDR3, offsetof(struct clkctl, cscdr3)); + DEFINE(CLKCTL_CSCDR4, offsetof(struct clkctl, cscdr4)); + DEFINE(CLKCTL_CWDR, offsetof(struct clkctl, cwdr)); + DEFINE(CLKCTL_CDHIPR, offsetof(struct clkctl, cdhipr)); + DEFINE(CLKCTL_CDCR, offsetof(struct clkctl, cdcr)); + DEFINE(CLKCTL_CTOR, offsetof(struct clkctl, ctor)); + DEFINE(CLKCTL_CLPCR, offsetof(struct clkctl, clpcr)); + DEFINE(CLKCTL_CISR, offsetof(struct clkctl, cisr)); + DEFINE(CLKCTL_CIMR, offsetof(struct clkctl, cimr)); + DEFINE(CLKCTL_CCOSR, offsetof(struct clkctl, ccosr)); + DEFINE(CLKCTL_CGPR, offsetof(struct clkctl, cgpr)); + DEFINE(CLKCTL_CCGR0, offsetof(struct clkctl, ccgr0)); + DEFINE(CLKCTL_CCGR1, offsetof(struct clkctl, ccgr1)); + DEFINE(CLKCTL_CCGR2, offsetof(struct clkctl, ccgr2)); + DEFINE(CLKCTL_CCGR3, offsetof(struct clkctl, ccgr3)); + DEFINE(CLKCTL_CCGR4, offsetof(struct clkctl, ccgr4)); + DEFINE(CLKCTL_CCGR5, offsetof(struct clkctl, ccgr5)); + DEFINE(CLKCTL_CCGR6, offsetof(struct clkctl, ccgr6)); + DEFINE(CLKCTL_CMEOR, offsetof(struct clkctl, cmeor)); +#if defined(CONFIG_MX53) + DEFINE(CLKCTL_CCGR7, offsetof(struct clkctl, ccgr7)); +#endif + + /* DPLL */ + DEFINE(PLL_DP_CTL, offsetof(struct dpll, dp_ctl)); + DEFINE(PLL_DP_CONFIG, offsetof(struct dpll, dp_config)); + DEFINE(PLL_DP_OP, offsetof(struct dpll, dp_op)); + DEFINE(PLL_DP_MFD, offsetof(struct dpll, dp_mfd)); + DEFINE(PLL_DP_MFN, offsetof(struct dpll, dp_mfn)); + DEFINE(PLL_DP_HFS_OP, offsetof(struct dpll, dp_hfs_op)); + DEFINE(PLL_DP_HFS_MFD, offsetof(struct dpll, dp_hfs_mfd)); + DEFINE(PLL_DP_HFS_MFN, offsetof(struct dpll, dp_hfs_mfn)); + + return 0; +} diff --git a/arch/arm/include/asm/arch-mx5/asm-offsets.h b/arch/arm/include/asm/arch-mx5/asm-offsets.h deleted file mode 100644 index 793f69c..0000000 --- a/arch/arm/include/asm/arch-mx5/asm-offsets.h +++ /dev/null @@ -1,55 +0,0 @@ -/* - * needed for arch/arm/cpu/armv7/mx51/lowlevel_init.S - * - * These should be auto-generated - */ -/* CCM */ -#define CLKCTL_CCR 0x00 -#define CLKCTL_CCDR 0x04 -#define CLKCTL_CSR 0x08 -#define CLKCTL_CCSR 0x0C -#define CLKCTL_CACRR 0x10 -#define CLKCTL_CBCDR 0x14 -#define CLKCTL_CBCMR 0x18 -#define CLKCTL_CSCMR1 0x1C -#define CLKCTL_CSCMR2 0x20 -#define CLKCTL_CSCDR1 0x24 -#define CLKCTL_CS1CDR 0x28 -#define CLKCTL_CS2CDR 0x2C -#define CLKCTL_CDCDR 0x30 -#define CLKCTL_CHSCCDR 0x34 -#define CLKCTL_CSCDR2 0x38 -#define CLKCTL_CSCDR3 0x3C -#define CLKCTL_CSCDR4 0x40 -#define CLKCTL_CWDR 0x44 -#define CLKCTL_CDHIPR 0x48 -#define CLKCTL_CDCR 0x4C -#define CLKCTL_CTOR 0x50 -#define CLKCTL_CLPCR 0x54 -#define CLKCTL_CISR 0x58 -#define CLKCTL_CIMR 0x5C -#define CLKCTL_CCOSR 0x60 -#define CLKCTL_CGPR 0x64 -#define CLKCTL_CCGR0 0x68 -#define CLKCTL_CCGR1 0x6C -#define CLKCTL_CCGR2 0x70 -#define CLKCTL_CCGR3 0x74 -#define CLKCTL_CCGR4 0x78 -#define CLKCTL_CCGR5 0x7C -#define CLKCTL_CCGR6 0x80 -#if defined(CONFIG_MX53) -#define CLKCTL_CCGR7 0x84 -#define CLKCTL_CMEOR 0x88 -#elif defined(CONFIG_MX51) -#define CLKCTL_CMEOR 0x84 -#endif - -/* DPLL */ -#define PLL_DP_CTL 0x00 -#define PLL_DP_CONFIG 0x04 -#define PLL_DP_OP 0x08 -#define PLL_DP_MFD 0x0C -#define PLL_DP_MFN 0x10 -#define PLL_DP_HFS_OP 0x1C -#define PLL_DP_HFS_MFD 0x20 -#define PLL_DP_HFS_MFN 0x24 diff --git a/arch/arm/include/asm/arch-mx5/imx-regs.h b/arch/arm/include/asm/arch-mx5/imx-regs.h index 9589a62..e83ca29 100644 --- a/arch/arm/include/asm/arch-mx5/imx-regs.h +++ b/arch/arm/include/asm/arch-mx5/imx-regs.h @@ -317,9 +317,27 @@ struct clkctl { u32 ccgr4; u32 ccgr5; u32 ccgr6; +#if defined(CONFIG_MX53) + u32 ccgr7; +#endif u32 cmeor; };
+/* DPLL registers */ +struct dpll { + u32 dp_ctl; + u32 dp_config; + u32 dp_op; + u32 dp_mfd; + u32 dp_mfn; + u32 dp_mfn_minus; + u32 dp_mfn_plus; + u32 dp_hfs_op; + u32 dp_hfs_mfd; + u32 dp_hfs_mfn; + u32 dp_mfn_togc; + u32 dp_destat; +}; /* WEIM registers */ struct weim { u32 cs0gcr1;
On i.MX27, the asm-offsets.h file is not yet generated as it should be.
Signed-off-by: Stefano Babic sbabic@denx.de CC: Matthias Weisser weisserm@arcor.de --- arch/arm/cpu/arm926ejs/mx27/Makefile | 13 +++++++ arch/arm/cpu/arm926ejs/mx27/asm-offsets.c | 45 ++++++++++++++++++++++++++ arch/arm/include/asm/arch-mx27/asm-offsets.h | 16 --------- 3 files changed, 58 insertions(+), 16 deletions(-) create mode 100644 arch/arm/cpu/arm926ejs/mx27/asm-offsets.c delete mode 100644 arch/arm/include/asm/arch-mx27/asm-offsets.h
diff --git a/arch/arm/cpu/arm926ejs/mx27/Makefile b/arch/arm/cpu/arm926ejs/mx27/Makefile index 0e112b3..2d65e70 100644 --- a/arch/arm/cpu/arm926ejs/mx27/Makefile +++ b/arch/arm/cpu/arm926ejs/mx27/Makefile @@ -34,6 +34,8 @@ all: $(obj).depend $(LIB) $(LIB): $(OBJS) $(call cmd_link_o_target, $(OBJS))
+$(OBJS) : $(TOPDIR)/include/asm/arch/asm-offsets.h + #########################################################################
# defines $(obj).depend target @@ -42,3 +44,14 @@ include $(SRCTREE)/rules.mk sinclude $(obj).depend
######################################################################### + +$(TOPDIR)/include/asm/arch/asm-offsets.h: $(TOPDIR)/include/autoconf.mk.dep \ + ./asm-offsets.s + @echo Generating $@ + $(TOPDIR)/tools/scripts/make-asm-offsets ./asm-offsets.s $@ + +asm-offsets.s: $(TOPDIR)/include/autoconf.mk.dep \ + ./asm-offsets.c + $(CC) -DDO_DEPS_ONLY \ + $(CFLAGS) $(CFLAGS_$(BCURDIR)/$(@F)) $(CFLAGS_$(BCURDIR)) \ + -o $@ ./asm-offsets.c -c -S diff --git a/arch/arm/cpu/arm926ejs/mx27/asm-offsets.c b/arch/arm/cpu/arm926ejs/mx27/asm-offsets.c new file mode 100644 index 0000000..f3a8d7b --- /dev/null +++ b/arch/arm/cpu/arm926ejs/mx27/asm-offsets.c @@ -0,0 +1,45 @@ +/* + * Adapted from Linux v2.6.36 kernel: arch/powerpc/kernel/asm-offsets.c + * + * This program is used to generate definitions needed by + * assembly language modules. + * + * We use the technique used in the OSF Mach kernel code: + * generate asm statements containing #defines, + * compile this file to assembler, and then extract the + * #defines from the assembly-language output. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License + * as published by the Free Software Foundation; either version + * 2 of the License, or (at your option) any later version. + */ + +#include <common.h> +#include <asm/arch/imx-regs.h> + +#include <linux/kbuild.h> + +int main(void) +{ + DEFINE(AIPI1_PSR0, IMX_AIPI1_BASE + offsetof(struct aipi_regs, psr0)); + DEFINE(AIPI1_PSR1, IMX_AIPI1_BASE + offsetof(struct aipi_regs, psr1)); + DEFINE(AIPI2_PSR0, IMX_AIPI2_BASE + offsetof(struct aipi_regs, psr0)); + DEFINE(AIPI2_PSR1, IMX_AIPI2_BASE + offsetof(struct aipi_regs, psr1)); + + DEFINE(CSCR, IMX_PLL_BASE + offsetof(struct pll_regs, cscr)); + DEFINE(MPCTL0, IMX_PLL_BASE + offsetof(struct pll_regs, mpctl0)); + DEFINE(SPCTL0, IMX_PLL_BASE + offsetof(struct pll_regs, spctl0)); + DEFINE(PCDR0, IMX_PLL_BASE + offsetof(struct pll_regs, pcdr0)); + DEFINE(PCDR1, IMX_PLL_BASE + offsetof(struct pll_regs, pcdr1)); + DEFINE(PCCR0, IMX_PLL_BASE + offsetof(struct pll_regs, pccr0)); + DEFINE(PCCR1, IMX_PLL_BASE + offsetof(struct pll_regs, pccr1)); + + DEFINE(ESDCTL0_ROF, offsetof(struct esdramc_regs, esdctl0)); + DEFINE(ESDCFG0_ROF, offsetof(struct esdramc_regs, esdcfg0)); + DEFINE(ESDCTL1_ROF, offsetof(struct esdramc_regs, esdctl1)); + DEFINE(ESDCFG1_ROF, offsetof(struct esdramc_regs, esdcfg1)); + DEFINE(ESDMISC_ROF, offsetof(struct esdramc_regs, esdmisc)); + + return 0; +} diff --git a/arch/arm/include/asm/arch-mx27/asm-offsets.h b/arch/arm/include/asm/arch-mx27/asm-offsets.h deleted file mode 100644 index 497afe5..0000000 --- a/arch/arm/include/asm/arch-mx27/asm-offsets.h +++ /dev/null @@ -1,16 +0,0 @@ -#define AIPI1_PSR0 0x10000000 -#define AIPI1_PSR1 0x10000004 -#define AIPI2_PSR0 0x10020000 -#define AIPI2_PSR1 0x10020004 -#define CSCR 0x10027000 -#define MPCTL0 0x10027004 -#define SPCTL0 0x1002700c -#define PCDR0 0x10027018 -#define PCDR1 0x1002701c -#define PCCR0 0x10027020 -#define PCCR1 0x10027024 -#define ESDCTL0_ROF 0x00 -#define ESDCFG0_ROF 0x04 -#define ESDCTL1_ROF 0x08 -#define ESDCFG1_ROF 0x0C -#define ESDMISC_ROF 0x10
Dear Stefano Babic,
- ./asm-offsets.s
- @echo Generating $@
- $(TOPDIR)/tools/scripts/make-asm-offsets ./asm-offsets.s $@
- ./asm-offsets.c
- $(CC) -DDO_DEPS_ONLY \
I don't think it makes sense to copy the make rules for asm-offsets.h and asm-offsets.s into each and every Makefile that needs them.
We should rather add these rules only once (either in rules.mk or in the toplevel Makefile) and then only add the target to be built in the board / cpu Makefiles that need them.
Dear Stefano Babic,
- ./asm-offsets.s
- ./asm-offsets.c
See previous message. It is inherently wrong to copy these lines to several (and potentially many) Makefiles.
Stefano Babic
