[U-Boot] [POWERPC] mgcoge, mgsuvd: add I2C support.
Also support CONFIG_I2C_MULTI_BUS for the soft_i2c and the cpu/mpc8260/i2c.c driver.
Signed-off-by: Heiko Schocher hs@denx.de --- board/keymile/mgcoge/mgcoge.c | 93 ++++++++++++++++++++++------------------- board/keymile/mgsuvd/mgsuvd.c | 13 ++++++ cpu/mpc8260/i2c.c | 36 ++++++++++++++++ drivers/i2c/soft_i2c.c | 36 ++++++++++++++++ include/configs/mgcoge.h | 25 +++++++++++ include/configs/mgsuvd.h | 42 ++++++++++++++++++ 6 files changed, 202 insertions(+), 43 deletions(-)
diff --git a/board/keymile/mgcoge/mgcoge.c b/board/keymile/mgcoge/mgcoge.c index 51b6dc6..9b37959 100644 --- a/board/keymile/mgcoge/mgcoge.c +++ b/board/keymile/mgcoge/mgcoge.c @@ -1,5 +1,5 @@ /* - * (C) Copyright 2007 + * (C) Copyright 2007 - 2008 * Heiko Schocher, DENX Software Engineering, hs@denx.de. * * See file CREDITS for list of people who contributed to this @@ -24,11 +24,16 @@ #include <common.h> #include <mpc8260.h> #include <ioports.h> +#include <malloc.h>
#if defined(CONFIG_OF_BOARD_SETUP) && defined(CONFIG_OF_LIBFDT) #include <libfdt.h> #endif
+#if defined(CONFIG_HARD_I2C) || defined(CONFIG_SOFT_I2C) +#include <i2c.h> +#endif + /* * I/O Port configuration table * @@ -163,8 +168,13 @@ const iop_conf_t iop_conf_tab[4][32] = { /* PD18 */ { 0, 0, 0, 0, 0, 0 }, /* PD18 */ /* PD17 */ { 0, 0, 0, 0, 0, 0 }, /* PD17 */ /* PD16 */ { 0, 0, 0, 0, 0, 0 }, /* PD16 */ - /* PD15 */ { 0, 0, 0, 0, 0, 0 }, /* PD15 */ - /* PD14 */ { 0, 0, 0, 0, 0, 0 }, /* PD14 */ +#if defined(CONFIG_HARD_I2C) + /* PD15 */ { 1, 1, 1, 0, 1, 0 }, /* I2C SDA */ + /* PD14 */ { 1, 1, 1, 0, 1, 0 }, /* I2C SCL */ +#else + /* PD15 */ { 1, 0, 0, 0, 1, 1 }, /* PD15 */ + /* PD14 */ { 1, 0, 0, 1, 1, 1 }, /* PD14 */ +#endif /* PD13 */ { 0, 0, 0, 0, 0, 0 }, /* PD13 */ /* PD12 */ { 0, 0, 0, 0, 0, 0 }, /* PD12 */ /* PD11 */ { 0, 0, 0, 0, 0, 0 }, /* PD11 */ @@ -243,13 +253,13 @@ static long int try_init (volatile memctl8260_t * memctl, ulong sdmr, *sdmr_ptr = sdmr | PSDMR_OP_NORM | PSDMR_RFEN; *base = c;
- size = get_ram_size((long *)base, maxsize); + size = get_ram_size ((long *)base, maxsize); *orx_ptr = orx | ~(size - 1);
return (size); }
-phys_size_t initdram(int board_type) +phys_size_t initdram (int board_type) { volatile immap_t *immap = (immap_t *) CFG_IMMR; volatile memctl8260_t *memctl = &immap->im_memctl; @@ -273,7 +283,7 @@ phys_size_t initdram(int board_type)
int checkboard(void) { - puts("Board: mgcoge\n"); + puts ("Board: mgcoge\n");
return 0; } @@ -281,7 +291,7 @@ int checkboard(void) /* * Early board initalization. */ -int board_early_init_r(void) +int board_early_init_r (void) { /* setup the UPIOx */ *(char *)(CFG_PIGGY_BASE + 0x02) = 0xc0; @@ -293,68 +303,65 @@ int board_early_init_r(void) /* * update "memory" property in the blob */ -void ft_blob_update(void *blob, bd_t *bd) +void ft_blob_update (void *blob, bd_t *bd) { int ret, nodeoffset = 0; ulong memory_data[2] = {0}; ulong flash_data[8] = {0};
- memory_data[0] = cpu_to_be32(bd->bi_memstart); - memory_data[1] = cpu_to_be32(bd->bi_memsize); + memory_data[0] = cpu_to_be32 (bd->bi_memstart); + memory_data[1] = cpu_to_be32 (bd->bi_memsize);
nodeoffset = fdt_path_offset (blob, "/memory"); if (nodeoffset >= 0) { - ret = fdt_setprop(blob, nodeoffset, "reg", memory_data, - sizeof(memory_data)); + ret = fdt_setprop (blob, nodeoffset, "reg", memory_data, + sizeof (memory_data)); if (ret < 0) - printf("ft_blob_update(): cannot set /memory/reg " - "property err:%s\n", fdt_strerror(ret)); - } - else { + printf ("ft_blob_update(): cannot set /memory/reg " + "property err:%s\n", fdt_strerror (ret)); + } else { /* memory node is required in dts */ - printf("ft_blob_update(): cannot find /memory node " - "err:%s\n", fdt_strerror(nodeoffset)); + printf ("ft_blob_update(): cannot find /memory node " + "err:%s\n", fdt_strerror (nodeoffset)); } /* update Flash addr, size */ - flash_data[2] = cpu_to_be32(CFG_FLASH_BASE); - flash_data[3] = cpu_to_be32(CFG_FLASH_SIZE); - flash_data[4] = cpu_to_be32(1); - flash_data[5] = cpu_to_be32(0); - flash_data[6] = cpu_to_be32(CFG_FLASH_BASE_1); - flash_data[7] = cpu_to_be32(CFG_FLASH_SIZE_1); + flash_data[2] = cpu_to_be32 (CFG_FLASH_BASE); + flash_data[3] = cpu_to_be32 (CFG_FLASH_SIZE); + flash_data[4] = cpu_to_be32 (1); + flash_data[5] = cpu_to_be32 (0); + flash_data[6] = cpu_to_be32 (CFG_FLASH_BASE_1); + flash_data[7] = cpu_to_be32 (CFG_FLASH_SIZE_1); nodeoffset = fdt_path_offset (blob, "/localbus"); if (nodeoffset >= 0) { - ret = fdt_setprop(blob, nodeoffset, "ranges", flash_data, - sizeof(flash_data)); + ret = fdt_setprop (blob, nodeoffset, "ranges", flash_data, + sizeof (flash_data)); if (ret < 0) - printf("ft_blob_update(): cannot set /localbus/ranges " - "property err:%s\n", fdt_strerror(ret)); - } - else { + printf ("ft_blob_update(): cannot set /localbus/ranges " + "property err:%s\n", fdt_strerror (ret)); + } else { /* memory node is required in dts */ - printf("ft_blob_update(): cannot find /localbus node " - "err:%s\n", fdt_strerror(nodeoffset)); + printf ("ft_blob_update(): cannot find /localbus node " + "err:%s\n", fdt_strerror (nodeoffset)); } /* MAC Adresse */ nodeoffset = fdt_path_offset (blob, "/soc/cpm/ethernet"); if (nodeoffset >= 0) { - ret = fdt_setprop(blob, nodeoffset, "mac-address", bd->bi_enetaddr, - sizeof(uchar) * 6); + ret = fdt_setprop (blob, nodeoffset, "mac-address", bd->bi_enetaddr, + sizeof (uchar) * 6); if (ret < 0) - printf("ft_blob_update(): cannot set /soc/cpm/ethernet/mac-address " - "property err:%s\n", fdt_strerror(ret)); - } - else { + printf ("ft_blob_update(): cannot set /soc/cpm/ethernet/mac-address " + "property err:%s\n", fdt_strerror (ret)); + } else { /* memory node is required in dts */ - printf("ft_blob_update(): cannot find /soc/cpm/ethernet node " - "err:%s\n", fdt_strerror(nodeoffset)); + printf ("ft_blob_update(): cannot find /soc/cpm/ethernet node " + "err:%s\n", fdt_strerror (nodeoffset)); }
-void ft_board_setup(void *blob, bd_t *bd) +void ft_board_setup (void *blob, bd_t *bd) { - ft_cpu_setup( blob, bd); - ft_blob_update(blob, bd); + ft_cpu_setup (blob, bd); + ft_blob_update (blob, bd); } #endif /* defined(CONFIG_OF_BOARD_SETUP) && defined(CONFIG_OF_LIBFDT) */ diff --git a/board/keymile/mgsuvd/mgsuvd.c b/board/keymile/mgsuvd/mgsuvd.c index c51ea7e..49b43ee 100644 --- a/board/keymile/mgsuvd/mgsuvd.c +++ b/board/keymile/mgsuvd/mgsuvd.c @@ -225,3 +225,16 @@ void ft_board_setup(void *blob, bd_t *bd) ft_blob_update(blob, bd); } #endif /* defined(CONFIG_OF_BOARD_SETUP) && defined(CONFIG_OF_LIBFDT) */ + +#if defined(CONFIG_SOFT_I2C) +int i2c_mgsuvd_read (void) +{ + int val; + + *(unsigned short *)(I2C_BASE_DIR) &= ~SDA_CONF; + udelay(1); + val = *(unsigned char *)(I2C_BASE_PORT); + + return ((val & SDA_BIT) == SDA_BIT); +} +#endif diff --git a/cpu/mpc8260/i2c.c b/cpu/mpc8260/i2c.c index c3af7b6..335177f 100644 --- a/cpu/mpc8260/i2c.c +++ b/cpu/mpc8260/i2c.c @@ -36,6 +36,10 @@
DECLARE_GLOBAL_DATA_PTR;
+#if defined(CONFIG_I2C_MULTI_BUS) +static unsigned int i2c_bus_num __attribute__ ((section ("data"))) = 0; +#endif /* CONFIG_I2C_MULTI_BUS */ + /* uSec to wait between polls of the i2c */ #define DELAY_US 100 /* uSec to wait for the CPM to start processing the buffer */ @@ -765,4 +769,36 @@ i2c_reg_write(uchar chip, uchar reg, uchar val) i2c_write(chip, reg, 1, &val, 1); }
+#if defined(CONFIG_I2C_MULTI_BUS) +/* + * Functions for multiple I2C bus handling + */ +unsigned int i2c_get_bus_num(void) +{ + return i2c_bus_num; +} + +int i2c_set_bus_num(unsigned int bus) +{ + if (bus >= CFG_MAX_I2C_BUS) + return -1; + i2c_bus_num = bus; + + return 0; +} +/* TODO: add 100/400k switching */ +unsigned int i2c_get_bus_speed(void) +{ + return CFG_I2C_SPEED; +} + +int i2c_set_bus_speed(unsigned int speed) +{ + if (speed != CFG_I2C_SPEED) + return -1; + + return 0; +} + +#endif /* CONFIG_I2C_MULTI_BUS */ #endif /* CONFIG_HARD_I2C */ diff --git a/drivers/i2c/soft_i2c.c b/drivers/i2c/soft_i2c.c index 23db2ee..57736da 100644 --- a/drivers/i2c/soft_i2c.c +++ b/drivers/i2c/soft_i2c.c @@ -68,6 +68,10 @@ DECLARE_GLOBAL_DATA_PTR; #define PRINTD(fmt,args...) #endif
+#if defined(CONFIG_I2C_MULTI_BUS) +static unsigned int i2c_bus_num __attribute__ ((section ("data"))) = 0; +#endif /* CONFIG_I2C_MULTI_BUS */ + /*----------------------------------------------------------------------- * Local functions */ @@ -230,6 +234,38 @@ static int write_byte(uchar data) return(nack); /* not a nack is an ack */ }
+#if defined(CONFIG_I2C_MULTI_BUS) +/* + * Functions for multiple I2C bus handling + */ +unsigned int i2c_get_bus_num(void) +{ + return i2c_bus_num; +} + +int i2c_set_bus_num(unsigned int bus) +{ + if (bus >= CFG_MAX_I2C_BUS) + return -1; + i2c_bus_num = bus; + + return 0; +} + +/* TODO: add 100/400k switching */ +unsigned int i2c_get_bus_speed(void) +{ + return CFG_I2C_SPEED; +} + +int i2c_set_bus_speed(unsigned int speed) +{ + if (speed != CFG_I2C_SPEED) + return -1; + + return 0; +} +#endif
/*----------------------------------------------------------------------- * if ack == I2C_ACK, ACK the byte so can continue reading, else diff --git a/include/configs/mgcoge.h b/include/configs/mgcoge.h index 23af3ec..159eeae 100644 --- a/include/configs/mgcoge.h +++ b/include/configs/mgcoge.h @@ -82,6 +82,7 @@ #include <config_cmd_default.h>
#define CONFIG_CMD_ECHO +#define CONFIG_CMD_I2C #define CONFIG_CMD_IMMAP #define CONFIG_CMD_MII #define CONFIG_CMD_PING @@ -176,6 +177,30 @@ #define CONFIG_ENV_ADDR (CFG_MONITOR_BASE + CFG_MONITOR_LEN) #endif /* CONFIG_ENV_IS_IN_FLASH */
+/* enable I2C and select the hardware/software driver */ +#undef CONFIG_HARD_I2C /* I2C with hardware support */ +#define CONFIG_SOFT_I2C 1 /* I2C bit-banged */ +#define CFG_I2C_SPEED 50000 /* I2C speed and slave address */ +#define CFG_I2C_SLAVE 0x7F + +/* + * Software (bit-bang) I2C driver configuration + */ + +#define I2C_PORT 3 /* Port A=0, B=1, C=2, D=3 */ +#define I2C_ACTIVE (iop->pdir |= 0x00010000) +#define I2C_TRISTATE (iop->pdir &= ~0x00010000) +#define I2C_READ ((iop->pdat & 0x00010000) != 0) +#define I2C_SDA(bit) if(bit) iop->pdat |= 0x00010000; \ + else iop->pdat &= ~0x00010000 +#define I2C_SCL(bit) if(bit) iop->pdat |= 0x00020000; \ + else iop->pdat &= ~0x00020000 +#define I2C_DELAY udelay(5) /* 1/4 I2C clock duration */ + +#define CONFIG_I2C_MULTI_BUS 1 +#define CONFIG_I2C_CMD_TREE 1 +#define CFG_MAX_I2C_BUS 2 + #define CFG_IMMR 0xF0000000
#define CFG_INIT_RAM_ADDR CFG_IMMR diff --git a/include/configs/mgsuvd.h b/include/configs/mgsuvd.h index 740767e..2c30fab 100644 --- a/include/configs/mgsuvd.h +++ b/include/configs/mgsuvd.h @@ -113,6 +113,7 @@
#define CONFIG_CMD_ASKENV #define CONFIG_CMD_DHCP +#define CONFIG_CMD_I2C #define CONFIG_CMD_NFS #define CONFIG_CMD_PING
@@ -330,4 +331,45 @@ #define OF_TBCLK (bd->bi_busfreq / 4) #define OF_STDOUT_PATH "/soc/cpm/serial@a80"
+/* enable I2C and select the hardware/software driver */ +#undef CONFIG_HARD_I2C /* I2C with hardware support */ +#define CONFIG_SOFT_I2C 1 /* I2C bit-banged */ +#define CFG_I2C_SPEED 50000 /* I2C speed and slave address */ +#define CFG_I2C_SLAVE 0x7F + +/* + * Software (bit-bang) I2C driver configuration + */ +#define I2C_BASE_DIR (CFG_PIGGY_BASE + 0x04) +#define I2C_BASE_PORT (CFG_PIGGY_BASE + 0x09) + +#define SDA_BIT 0x40 +#define SCL_BIT 0x80 +#define SDA_CONF 0x1000 +#define SCL_CONF 0x2000 + +#define I2C_ACTIVE do {} while (0) +#define I2C_TRISTATE do {} while (0) +#define I2C_READ i2c_mgsuvd_read () +#define I2C_SDA(bit) if(bit) { \ + *(unsigned short *)(I2C_BASE_DIR) &= ~SDA_CONF; \ + } \ + else { \ + *(unsigned char *)(I2C_BASE_PORT) &= ~SDA_BIT; \ + *(unsigned short *)(I2C_BASE_DIR) |= SDA_CONF; \ + } +#define I2C_SCL(bit) if(bit) { \ + *(unsigned short *)(I2C_BASE_DIR) &= ~SCL_CONF; \ + } \ + else { \ + *(unsigned char *)(I2C_BASE_PORT) &= ~SCL_BIT; \ + *(unsigned short *)(I2C_BASE_DIR) |= SCL_CONF; \ + } +#define I2C_DELAY udelay(50) /* 1/4 I2C clock duration */ + +#define CONFIG_I2C_MULTI_BUS 1 +#define CONFIG_I2C_CMD_TREE 1 +#define CFG_MAX_I2C_BUS 2 + + #endif /* __CONFIG_H */
Dear Heiko Schocher,
- (C) Copyright 2007
- (C) Copyright 2007 - 2008
- Heiko Schocher, DENX Software Engineering, hs@denx.de.
You send a number of patches here,. and from reviewing it it becomes clear that these should be applied in a certain order. But since you omitted using the "-n" (aka "--numbered") option, it is impossible to know which order is required.
Please add at least a description in which order to apply the patches. Thanks.
- I/O Port configuration table
- /* PD15 */ { 1, 1, 1, 0, 1, 0 }, /* I2C SDA */
- /* PD14 */ { 1, 1, 1, 0, 1, 0 }, /* I2C SCL */
+#else
- /* PD15 */ { 1, 0, 0, 0, 1, 1 }, /* PD15 */
- /* PD14 */ { 1, 0, 0, 1, 1, 1 }, /* PD14 */
- size = get_ram_size ((long *)base, maxsize); *orx_ptr = orx | ~(size - 1);
Please do not mix adding code and code cleanup in one patch. Please split in separate patches. Also note that this space is not mandatory (and actually many people think it should not be used) - it's sufficient if your source file is consistent in this respect. I will not enforce one or the other style here.
- else {
- } else { /* memory node is required in dts */
Indentation is not correct here.
Ditto.
Please make MULTI_BUS support a separate patch, too.
Added to "next" branch, thanks.
Heiko Schocher
