[U-Boot] [PATCH v2 1/3] vf610: refactor DDRMC code
The VF610 DDRMC driver code contains settings which are board-specific. Move these out to boards so that new boards can define their own without having to modify the driver.
Signed-off-by: Albert ARIBAUD (3ADEV) albert.aribaud@3adev.fr ---
Changes in v2: - reverted from all-custom to JEDEC+PHY+custom settings
arch/arm/imx-common/ddrmc-vf610.c | 193 ++++++++++---------------- arch/arm/include/asm/arch-vf610/ddrmc-vf610.h | 40 ++++-- arch/arm/include/asm/arch-vf610/imx-regs.h | 6 +- board/freescale/vf610twr/vf610twr.c | 156 ++++++++++++++------- board/toradex/colibri_vf/colibri_vf.c | 144 +++++++++++++------ 5 files changed, 314 insertions(+), 225 deletions(-)
diff --git a/arch/arm/imx-common/ddrmc-vf610.c b/arch/arm/imx-common/ddrmc-vf610.c index e462631..daf3c7e 100644 --- a/arch/arm/imx-common/ddrmc-vf610.c +++ b/arch/arm/imx-common/ddrmc-vf610.c @@ -12,9 +12,9 @@ #include <asm/arch/iomux-vf610.h> #include <asm/arch/ddrmc-vf610.h>
-void ddrmc_setup_iomux(void) +void ddrmc_setup_iomux(const iomux_v3_cfg_t *pads, int pads_count) { - static const iomux_v3_cfg_t ddr_pads[] = { + static const iomux_v3_cfg_t default_pads[] = { VF610_PAD_DDR_A15__DDR_A_15, VF610_PAD_DDR_A14__DDR_A_14, VF610_PAD_DDR_A13__DDR_A_13, @@ -65,76 +65,54 @@ void ddrmc_setup_iomux(void) VF610_PAD_DDR_RESETB, };
- imx_iomux_v3_setup_multiple_pads(ddr_pads, ARRAY_SIZE(ddr_pads)); -} + if ((pads == NULL) || (pads_count == 0)) { + pads = default_pads; + pads_count = ARRAY_SIZE(default_pads); + }
-void ddrmc_phy_init(void) -{ - struct ddrmr_regs *ddrmr = (struct ddrmr_regs *)DDR_BASE_ADDR; + imx_iomux_v3_setup_multiple_pads(pads, pads_count); +}
- writel(DDRMC_PHY_DQ_TIMING, &ddrmr->phy[0]); - writel(DDRMC_PHY_DQ_TIMING, &ddrmr->phy[16]); - writel(DDRMC_PHY_DQ_TIMING, &ddrmr->phy[32]); +static struct ddrmc_phy_setting default_phy_settings[] = { + { DDRMC_PHY_DQ_TIMING, 0 }, + { DDRMC_PHY_DQ_TIMING, 16 }, + { DDRMC_PHY_DQ_TIMING, 32 },
- writel(DDRMC_PHY_DQS_TIMING, &ddrmr->phy[1]); - writel(DDRMC_PHY_DQS_TIMING, &ddrmr->phy[17]); + { DDRMC_PHY_DQS_TIMING, 1 }, + { DDRMC_PHY_DQS_TIMING, 17 },
- writel(DDRMC_PHY_CTRL, &ddrmr->phy[2]); - writel(DDRMC_PHY_CTRL, &ddrmr->phy[18]); - writel(DDRMC_PHY_CTRL, &ddrmr->phy[34]); + { DDRMC_PHY_CTRL, 2 }, + { DDRMC_PHY_CTRL, 18 }, + { DDRMC_PHY_CTRL, 34 },
- writel(DDRMC_PHY_MASTER_CTRL, &ddrmr->phy[3]); - writel(DDRMC_PHY_MASTER_CTRL, &ddrmr->phy[19]); - writel(DDRMC_PHY_MASTER_CTRL, &ddrmr->phy[35]); + { DDRMC_PHY_MASTER_CTRL, 3 }, + { DDRMC_PHY_MASTER_CTRL, 19 }, + { DDRMC_PHY_MASTER_CTRL, 35 },
- writel(DDRMC_PHY_SLAVE_CTRL, &ddrmr->phy[4]); - writel(DDRMC_PHY_SLAVE_CTRL, &ddrmr->phy[20]); - writel(DDRMC_PHY_SLAVE_CTRL, &ddrmr->phy[36]); + { DDRMC_PHY_SLAVE_CTRL, 4 }, + { DDRMC_PHY_SLAVE_CTRL, 20 }, + { DDRMC_PHY_SLAVE_CTRL, 36 },
/* LPDDR2 only parameter */ - writel(DDRMC_PHY_OFF, &ddrmr->phy[49]); + { DDRMC_PHY_OFF, 49 },
- writel(DDRMC_PHY50_DDR3_MODE | - DDRMC_PHY50_EN_SW_HALF_CYCLE, &ddrmr->phy[50]); + { DDRMC_PHY50_DDR3_MODE | DDRMC_PHY50_EN_SW_HALF_CYCLE, 50 },
/* Processor Pad ODT settings */ - writel(DDRMC_PHY_PROC_PAD_ODT, &ddrmr->phy[52]); -} - -static void ddrmc_ctrl_lvl_init(struct ddrmc_lvl_info *lvl) -{ - struct ddrmr_regs *ddrmr = (struct ddrmr_regs *)DDR_BASE_ADDR; - u32 cr102 = 0, cr105 = 0, cr106 = 0, cr110 = 0; + { DDRMC_PHY_PROC_PAD_ODT, 52 },
- if (lvl->wrlvl_reg_en) { - writel(DDRMC_CR97_WRLVL_EN, &ddrmr->cr[97]); - writel(DDRMC_CR98_WRLVL_DL_0(lvl->wrlvl_dl_0), &ddrmr->cr[98]); - writel(DDRMC_CR99_WRLVL_DL_1(lvl->wrlvl_dl_1), &ddrmr->cr[99]); - } - - if (lvl->rdlvl_reg_en) { - cr102 |= DDRMC_CR102_RDLVL_REG_EN; - cr105 |= DDRMC_CR105_RDLVL_DL_0(lvl->rdlvl_dl_0); - cr110 |= DDRMC_CR110_RDLVL_DL_1(lvl->rdlvl_dl_1); - } - - if (lvl->rdlvl_gt_reg_en) { - cr102 |= DDRMC_CR102_RDLVL_GT_REGEN; - cr106 |= DDRMC_CR106_RDLVL_GTDL_0(lvl->rdlvl_gt_dl_0); - cr110 |= DDRMC_CR110_RDLVL_GTDL_1(lvl->rdlvl_gt_dl_1); - } - - writel(cr102, &ddrmr->cr[102]); - writel(cr105, &ddrmr->cr[105]); - writel(cr106, &ddrmr->cr[106]); - writel(cr110, &ddrmr->cr[110]); -} + /* end marker */ + { 0, -1 } +};
void ddrmc_ctrl_init_ddr3(struct ddr3_jedec_timings const *timings, - struct ddrmc_lvl_info *lvl, - int col_diff, int row_diff) + struct ddrmc_cr_setting *board_cr_settings, + struct ddrmc_phy_setting *board_phy_settings, + int col_diff, int row_diff) { struct ddrmr_regs *ddrmr = (struct ddrmr_regs *)DDR_BASE_ADDR; + struct ddrmc_cr_setting *cr_setting; + struct ddrmc_phy_setting *phy_setting;
writel(DDRMC_CR00_DRAM_CLASS_DDR3, &ddrmr->cr[0]); writel(DDRMC_CR02_DRAM_TINIT(timings->tinit), &ddrmr->cr[2]); @@ -144,7 +122,9 @@ void ddrmc_ctrl_init_ddr3(struct ddr3_jedec_timings const *timings, writel(DDRMC_CR12_WRLAT(timings->wrlat) | DDRMC_CR12_CASLAT_LIN(timings->caslat_lin), &ddrmr->cr[12]); writel(DDRMC_CR13_TRC(timings->trc) | DDRMC_CR13_TRRD(timings->trrd) | - DDRMC_CR13_TCCD(timings->tccd), &ddrmr->cr[13]); + DDRMC_CR13_TCCD(timings->tccd) | + DDRMC_CR13_TBST_INT_INTERVAL(timings->tbst_int_interval), + &ddrmr->cr[13]); writel(DDRMC_CR14_TFAW(timings->tfaw) | DDRMC_CR14_TRP(timings->trp) | DDRMC_CR14_TWTR(timings->twtr) | DDRMC_CR14_TRAS_MIN(timings->tras_min), &ddrmr->cr[14]); @@ -156,18 +136,19 @@ void ddrmc_ctrl_init_ddr3(struct ddr3_jedec_timings const *timings, DDRMC_CR18_TCKE(timings->tcke), &ddrmr->cr[18]);
writel(DDRMC_CR20_AP_EN, &ddrmr->cr[20]); - writel(DDRMC_CR21_TRCD_INT(timings->trcd_int) | - DDRMC_CR21_CCMAP_EN, &ddrmr->cr[21]); + writel(DDRMC_CR21_TRCD_INT(timings->trcd_int) | DDRMC_CR21_CCMAP_EN | + DDRMC_CR21_TRAS_LOCKOUT(timings->tras_lockout), + &ddrmr->cr[21]);
writel(DDRMC_CR22_TDAL(timings->tdal), &ddrmr->cr[22]); - writel(DDRMC_CR23_BSTLEN(3) | + writel(DDRMC_CR23_BSTLEN(timings->bstlen) | DDRMC_CR23_TDLL(timings->tdll), &ddrmr->cr[23]); writel(DDRMC_CR24_TRP_AB(timings->trp_ab), &ddrmr->cr[24]);
writel(DDRMC_CR25_TREF_EN, &ddrmr->cr[25]); writel(DDRMC_CR26_TREF(timings->tref) | DDRMC_CR26_TRFC(timings->trfc), &ddrmr->cr[26]); - writel(DDRMC_CR28_TREF_INT(0), &ddrmr->cr[28]); + writel(DDRMC_CR28_TREF_INT(timings->tref_int), &ddrmr->cr[28]); writel(DDRMC_CR29_TPDEX(timings->tpdex), &ddrmr->cr[29]);
writel(DDRMC_CR30_TXPDLL(timings->txpdll), &ddrmr->cr[30]); @@ -177,7 +158,7 @@ void ddrmc_ctrl_init_ddr3(struct ddr3_jedec_timings const *timings, writel(DDRMC_CR34_CKSRX(timings->cksrx) | DDRMC_CR34_CKSRE(timings->cksre), &ddrmr->cr[34]);
- writel(DDRMC_CR38_FREQ_CHG_EN(0), &ddrmr->cr[38]); + writel(DDRMC_CR38_FREQ_CHG_EN(timings->freq_chg_en), &ddrmr->cr[38]); writel(DDRMC_CR39_PHY_INI_COM(1024) | DDRMC_CR39_PHY_INI_STA(16) | DDRMC_CR39_FRQ_CH_DLLOFF(2), &ddrmr->cr[39]);
@@ -191,13 +172,14 @@ void ddrmc_ctrl_init_ddr3(struct ddr3_jedec_timings const *timings, writel(DDRMC_CR69_ZQ_ON_SREF_EX(2), &ddrmr->cr[69]);
writel(DDRMC_CR70_REF_PER_ZQ(timings->ref_per_zq), &ddrmr->cr[70]); - writel(DDRMC_CR72_ZQCS_ROTATE(0), &ddrmr->cr[72]); + writel(DDRMC_CR72_ZQCS_ROTATE(timings->zqcs_rotate), &ddrmr->cr[72]);
writel(DDRMC_CR73_APREBIT(timings->aprebit) | DDRMC_CR73_COL_DIFF(col_diff) | DDRMC_CR73_ROW_DIFF(row_diff), &ddrmr->cr[73]); writel(DDRMC_CR74_BANKSPLT_EN | DDRMC_CR74_ADDR_CMP_EN | - DDRMC_CR74_CMD_AGE_CNT(64) | DDRMC_CR74_AGE_CNT(64), + DDRMC_CR74_CMD_AGE_CNT(timings->cmd_age_cnt) | + DDRMC_CR74_AGE_CNT(timings->age_cnt), &ddrmr->cr[74]); writel(DDRMC_CR75_RW_PG_EN | DDRMC_CR75_RW_EN | DDRMC_CR75_PRI_EN | DDRMC_CR75_PLEN, &ddrmr->cr[75]); @@ -205,13 +187,15 @@ void ddrmc_ctrl_init_ddr3(struct ddr3_jedec_timings const *timings, DDRMC_CR76_W2R_SPLT_EN, &ddrmr->cr[76]); writel(DDRMC_CR77_CS_MAP | DDRMC_CR77_DI_RD_INTLEAVE | DDRMC_CR77_SWAP_EN, &ddrmr->cr[77]); - writel(DDRMC_CR78_Q_FULLNESS(7) | + writel(DDRMC_CR78_Q_FULLNESS(timings->q_fullness) | DDRMC_CR78_BUR_ON_FLY_BIT(12), &ddrmr->cr[78]); writel(DDRMC_CR79_CTLUPD_AREF(0), &ddrmr->cr[79]);
writel(DDRMC_CR82_INT_MASK, &ddrmr->cr[82]);
- writel(DDRMC_CR87_ODT_WR_MAPCS0, &ddrmr->cr[87]); + writel(DDRMC_CR87_ODT_RD_MAPCS0(timings->odt_rd_mapcs0) | + DDRMC_CR87_ODT_WR_MAPCS0(timings->odt_wr_mapcs0), + &ddrmr->cr[87]); writel(DDRMC_CR88_TODTL_CMD(4), &ddrmr->cr[88]); writel(DDRMC_CR89_AODT_RWSMCS(2), &ddrmr->cr[89]);
@@ -219,58 +203,33 @@ void ddrmc_ctrl_init_ddr3(struct ddr3_jedec_timings const *timings, writel(DDRMC_CR96_WLMRD(timings->wlmrd) | DDRMC_CR96_WLDQSEN(timings->wldqsen), &ddrmr->cr[96]);
- if (lvl != NULL) - ddrmc_ctrl_lvl_init(lvl); - - writel(DDRMC_CR117_AXI0_W_PRI(0) | - DDRMC_CR117_AXI0_R_PRI(0), &ddrmr->cr[117]); - writel(DDRMC_CR118_AXI1_W_PRI(1) | - DDRMC_CR118_AXI1_R_PRI(1), &ddrmr->cr[118]); - - writel(DDRMC_CR120_AXI0_PRI1_RPRI(2) | - DDRMC_CR120_AXI0_PRI0_RPRI(2), &ddrmr->cr[120]); - writel(DDRMC_CR121_AXI0_PRI3_RPRI(2) | - DDRMC_CR121_AXI0_PRI2_RPRI(2), &ddrmr->cr[121]); - writel(DDRMC_CR122_AXI1_PRI1_RPRI(1) | DDRMC_CR122_AXI1_PRI0_RPRI(1) | - DDRMC_CR122_AXI0_PRIRLX(100), &ddrmr->cr[122]); - writel(DDRMC_CR123_AXI1_P_ODR_EN | DDRMC_CR123_AXI1_PRI3_RPRI(1) | - DDRMC_CR123_AXI1_PRI2_RPRI(1), &ddrmr->cr[123]); - writel(DDRMC_CR124_AXI1_PRIRLX(100), &ddrmr->cr[124]); - - writel(DDRMC_CR126_PHY_RDLAT(8), &ddrmr->cr[126]); - writel(DDRMC_CR132_WRLAT_ADJ(5) | - DDRMC_CR132_RDLAT_ADJ(6), &ddrmr->cr[132]); - writel(DDRMC_CR137_PHYCTL_DL(2), &ddrmr->cr[137]); - writel(DDRMC_CR138_PHY_WRLV_MXDL(256) | - DDRMC_CR138_PHYDRAM_CK_EN(1), &ddrmr->cr[138]); - writel(DDRMC_CR139_PHY_WRLV_RESPLAT(4) | DDRMC_CR139_PHY_WRLV_LOAD(7) | - DDRMC_CR139_PHY_WRLV_DLL(3) | - DDRMC_CR139_PHY_WRLV_EN(3), &ddrmr->cr[139]); - writel(DDRMC_CR140_PHY_WRLV_WW(64), &ddrmr->cr[140]); - writel(DDRMC_CR143_RDLV_GAT_MXDL(1536) | - DDRMC_CR143_RDLV_MXDL(128), &ddrmr->cr[143]); - writel(DDRMC_CR144_PHY_RDLVL_RES(4) | DDRMC_CR144_PHY_RDLV_LOAD(7) | - DDRMC_CR144_PHY_RDLV_DLL(3) | - DDRMC_CR144_PHY_RDLV_EN(3), &ddrmr->cr[144]); - writel(DDRMC_CR145_PHY_RDLV_RR(64), &ddrmr->cr[145]); - writel(DDRMC_CR146_PHY_RDLVL_RESP(64), &ddrmr->cr[146]); - writel(DDRMC_CR147_RDLV_RESP_MASK(983040), &ddrmr->cr[147]); - writel(DDRMC_CR148_RDLV_GATE_RESP_MASK(983040), &ddrmr->cr[148]); - writel(DDRMC_CR151_RDLV_GAT_DQ_ZERO_CNT(1) | - DDRMC_CR151_RDLVL_DQ_ZERO_CNT(1), &ddrmr->cr[151]); - - writel(DDRMC_CR154_PAD_ZQ_EARLY_CMP_EN_TIMER(13) | - DDRMC_CR154_PAD_ZQ_MODE(1) | - DDRMC_CR154_DDR_SEL_PAD_CONTR(3) | - DDRMC_CR154_PAD_ZQ_HW_FOR(1), &ddrmr->cr[154]); - writel(DDRMC_CR155_PAD_ODT_BYTE1(2) | - DDRMC_CR155_PAD_ODT_BYTE0(2), &ddrmr->cr[155]); - writel(DDRMC_CR158_TWR(6), &ddrmr->cr[158]); - writel(DDRMC_CR161_ODT_EN(1) | DDRMC_CR161_TODTH_RD(2) | - DDRMC_CR161_TODTH_WR(2), &ddrmr->cr[161]); - - ddrmc_phy_init(); + /* execute custom CR setting sequence (may be NULL) */ + cr_setting = board_cr_settings; + if (cr_setting != NULL) + while (cr_setting->cr_rnum >= 0) { + writel(cr_setting->setting, + &ddrmr->cr[cr_setting->cr_rnum]); + cr_setting++; + } + + /* perform default PHY settings (may be overriden by custom settings */ + phy_setting = default_phy_settings; + while (phy_setting->phy_rnum >= 0) { + writel(phy_setting->setting, + &ddrmr->phy[phy_setting->phy_rnum]); + phy_setting++; + } + + /* execute custom PHY setting sequence (may be NULL) */ + phy_setting = board_phy_settings; + if (phy_setting != NULL) + while (phy_setting->phy_rnum >= 0) { + writel(phy_setting->setting, + &ddrmr->phy[phy_setting->phy_rnum]); + phy_setting++; + }
+ /* all inits done, start the DDR controller */ writel(DDRMC_CR00_DRAM_CLASS_DDR3 | DDRMC_CR00_START, &ddrmr->cr[0]);
while (!(readl(&ddrmr->cr[80]) && 0x100)) diff --git a/arch/arm/include/asm/arch-vf610/ddrmc-vf610.h b/arch/arm/include/asm/arch-vf610/ddrmc-vf610.h index 6730cde..9022c46 100644 --- a/arch/arm/include/asm/arch-vf610/ddrmc-vf610.h +++ b/arch/arm/include/asm/arch-vf610/ddrmc-vf610.h @@ -11,18 +11,6 @@ #ifndef __ASM_ARCH_VF610_DDRMC_H #define __ASM_ARCH_VF610_DDRMC_H
-struct ddrmc_lvl_info { - u16 wrlvl_reg_en; - u16 wrlvl_dl_0; - u16 wrlvl_dl_1; - u16 rdlvl_gt_reg_en; - u16 rdlvl_gt_dl_0; - u16 rdlvl_gt_dl_1; - u16 rdlvl_reg_en; - u16 rdlvl_dl_0; - u16 rdlvl_dl_1; -}; - struct ddr3_jedec_timings { u8 tinit; u32 trst_pwron; @@ -32,6 +20,7 @@ struct ddr3_jedec_timings { u8 trc; u8 trrd; u8 tccd; + u8 tbst_int_interval; u8 tfaw; u8 trp; u8 twtr; @@ -43,30 +32,51 @@ struct ddr3_jedec_timings { u8 tckesr; u8 tcke; u8 trcd_int; + u8 tras_lockout; u8 tdal; + u8 bstlen; u16 tdll; u8 trp_ab; u16 tref; u8 trfc; + u16 tref_int; u8 tpdex; u8 txpdll; u8 txsnr; u16 txsr; u8 cksrx; u8 cksre; + u8 freq_chg_en; u16 zqcl; u16 zqinit; u8 zqcs; u8 ref_per_zq; + u8 zqcs_rotate; u8 aprebit; + u8 cmd_age_cnt; + u8 age_cnt; + u8 q_fullness; + u8 odt_rd_mapcs0; + u8 odt_wr_mapcs0; u8 wlmrd; u8 wldqsen; };
-void ddrmc_setup_iomux(void); +struct ddrmc_cr_setting { + u32 setting; + int cr_rnum; /* CR register ; -1 for last entry */ +}; + +struct ddrmc_phy_setting { + u32 setting; + int phy_rnum; /* PHY register ; -1 for last entry */ +}; + +void ddrmc_setup_iomux(const iomux_v3_cfg_t *pads, int pads_count); void ddrmc_phy_init(void); void ddrmc_ctrl_init_ddr3(struct ddr3_jedec_timings const *timings, - struct ddrmc_lvl_info *lvl, - int col_diff, int row_diff); + struct ddrmc_cr_setting *board_cr_settings, + struct ddrmc_phy_setting *board_phy_settings, + int col_diff, int row_diff);
#endif diff --git a/arch/arm/include/asm/arch-vf610/imx-regs.h b/arch/arm/include/asm/arch-vf610/imx-regs.h index 4366985..9758323 100644 --- a/arch/arm/include/asm/arch-vf610/imx-regs.h +++ b/arch/arm/include/asm/arch-vf610/imx-regs.h @@ -148,7 +148,7 @@ #define DDRMC_CR18_TCKE(v) ((v) & 0x7) #define DDRMC_CR20_AP_EN (1 << 24) #define DDRMC_CR21_TRCD_INT(v) (((v) & 0xff) << 16) -#define DDRMC_CR21_TRAS_LOCKOUT (1 << 8) +#define DDRMC_CR21_TRAS_LOCKOUT(v) ((v) << 8) #define DDRMC_CR21_CCMAP_EN 1 #define DDRMC_CR22_TDAL(v) (((v) & 0x3f) << 16) #define DDRMC_CR23_BSTLEN(v) (((v) & 0x7) << 24) @@ -200,8 +200,8 @@ #define DDRMC_CR78_BUR_ON_FLY_BIT(v) ((v) & 0xf) #define DDRMC_CR79_CTLUPD_AREF(v) (((v) & 0x1) << 24) #define DDRMC_CR82_INT_MASK 0x10000000 -#define DDRMC_CR87_ODT_WR_MAPCS0 (1 << 24) -#define DDRMC_CR87_ODT_RD_MAPCS0 (1 << 16) +#define DDRMC_CR87_ODT_WR_MAPCS0(v) ((v) << 24) +#define DDRMC_CR87_ODT_RD_MAPCS0(v) ((v) << 16) #define DDRMC_CR88_TODTL_CMD(v) (((v) & 0x1f) << 16) #define DDRMC_CR89_AODT_RWSMCS(v) ((v) & 0xf) #define DDRMC_CR91_R2W_SMCSDL(v) (((v) & 0x7) << 16) diff --git a/board/freescale/vf610twr/vf610twr.c b/board/freescale/vf610twr/vf610twr.c index 4160acd..7834931 100644 --- a/board/freescale/vf610twr/vf610twr.c +++ b/board/freescale/vf610twr/vf610twr.c @@ -28,63 +28,117 @@ DECLARE_GLOBAL_DATA_PTR; #define ENET_PAD_CTRL (PAD_CTL_PUS_47K_UP | PAD_CTL_SPEED_HIGH | \ PAD_CTL_DSE_50ohm | PAD_CTL_OBE_IBE_ENABLE)
+static struct ddrmc_cr_setting vf610twr_cr_settings[] = { + /* levelling */ + { DDRMC_CR97_WRLVL_EN, 97 }, + { DDRMC_CR98_WRLVL_DL_0(0), 98 }, + { DDRMC_CR99_WRLVL_DL_1(0), 99 }, + { DDRMC_CR102_RDLVL_REG_EN | DDRMC_CR102_RDLVL_GT_REGEN, 102 }, + { DDRMC_CR105_RDLVL_DL_0(0), 105 }, + { DDRMC_CR106_RDLVL_GTDL_0(4), 106 }, + { DDRMC_CR110_RDLVL_DL_1(0) | DDRMC_CR110_RDLVL_GTDL_1(4), 110 }, + /* AXI */ + { DDRMC_CR117_AXI0_W_PRI(0) | DDRMC_CR117_AXI0_R_PRI(0), 117 }, + { DDRMC_CR118_AXI1_W_PRI(1) | DDRMC_CR118_AXI1_R_PRI(1), 118 }, + { DDRMC_CR120_AXI0_PRI1_RPRI(2) | + DDRMC_CR120_AXI0_PRI0_RPRI(2), 120 }, + { DDRMC_CR121_AXI0_PRI3_RPRI(2) | + DDRMC_CR121_AXI0_PRI2_RPRI(2), 121 }, + { DDRMC_CR122_AXI1_PRI1_RPRI(1) | DDRMC_CR122_AXI1_PRI0_RPRI(1) | + DDRMC_CR122_AXI0_PRIRLX(100), 122 }, + { DDRMC_CR123_AXI1_P_ODR_EN | DDRMC_CR123_AXI1_PRI3_RPRI(1) | + DDRMC_CR123_AXI1_PRI2_RPRI(1), 123 }, + { DDRMC_CR124_AXI1_PRIRLX(100), 124 }, + { DDRMC_CR126_PHY_RDLAT(8), 126 }, + { DDRMC_CR132_WRLAT_ADJ(5) | + DDRMC_CR132_RDLAT_ADJ(6), 132 }, + { DDRMC_CR137_PHYCTL_DL(2), 137 }, + { DDRMC_CR138_PHY_WRLV_MXDL(256) | + DDRMC_CR138_PHYDRAM_CK_EN(1), 138 }, + { DDRMC_CR139_PHY_WRLV_RESPLAT(4) | DDRMC_CR139_PHY_WRLV_LOAD(7) | + DDRMC_CR139_PHY_WRLV_DLL(3) | + DDRMC_CR139_PHY_WRLV_EN(3), 139 }, + { DDRMC_CR140_PHY_WRLV_WW(64), 140 }, + { DDRMC_CR143_RDLV_GAT_MXDL(1536) | + DDRMC_CR143_RDLV_MXDL(128), 143 }, + { DDRMC_CR144_PHY_RDLVL_RES(4) | DDRMC_CR144_PHY_RDLV_LOAD(7) | + DDRMC_CR144_PHY_RDLV_DLL(3) | + DDRMC_CR144_PHY_RDLV_EN(3), 144 }, + { DDRMC_CR145_PHY_RDLV_RR(64), 145 }, + { DDRMC_CR146_PHY_RDLVL_RESP(64), 146 }, + { DDRMC_CR147_RDLV_RESP_MASK(983040), 147 }, + { DDRMC_CR148_RDLV_GATE_RESP_MASK(983040), 148 }, + { DDRMC_CR151_RDLV_GAT_DQ_ZERO_CNT(1) | + DDRMC_CR151_RDLVL_DQ_ZERO_CNT(1), 151 }, + + { DDRMC_CR154_PAD_ZQ_EARLY_CMP_EN_TIMER(13) | + DDRMC_CR154_PAD_ZQ_MODE(1) | + DDRMC_CR154_DDR_SEL_PAD_CONTR(3) | + DDRMC_CR154_PAD_ZQ_HW_FOR(1), 154 }, + { DDRMC_CR155_PAD_ODT_BYTE1(1) | DDRMC_CR155_PAD_ODT_BYTE0(1), 155 }, + { DDRMC_CR158_TWR(6), 158 }, + { DDRMC_CR161_ODT_EN(1) | DDRMC_CR161_TODTH_RD(2) | + DDRMC_CR161_TODTH_WR(2), 161 }, + /* end marker */ + { 0, -1 } +}; + int dram_init(void) { - struct ddrmc_lvl_info lvl = { - .wrlvl_reg_en = 1, - .wrlvl_dl_0 = 0, - .wrlvl_dl_1 = 0, - .rdlvl_gt_reg_en = 1, - .rdlvl_gt_dl_0 = 4, - .rdlvl_gt_dl_1 = 4, - .rdlvl_reg_en = 1, - .rdlvl_dl_0 = 0, - .rdlvl_dl_1 = 0, - }; - static const struct ddr3_jedec_timings timings = { - .tinit = 5, - .trst_pwron = 80000, - .cke_inactive = 200000, - .wrlat = 5, - .caslat_lin = 12, - .trc = 21, - .trrd = 4, - .tccd = 4, - .tfaw = 20, - .trp = 6, - .twtr = 4, - .tras_min = 15, - .tmrd = 4, - .trtp = 4, - .tras_max = 28080, - .tmod = 12, - .tckesr = 4, - .tcke = 3, - .trcd_int = 6, - .tdal = 12, - .tdll = 512, - .trp_ab = 6, - .tref = 3120, - .trfc = 44, - .tpdex = 3, - .txpdll = 10, - .txsnr = 48, - .txsr = 468, - .cksrx = 5, - .cksre = 5, - .zqcl = 256, - .zqinit = 512, - .zqcs = 64, - .ref_per_zq = 64, - .aprebit = 10, - .wlmrd = 40, - .wldqsen = 25, + .tinit = 5, + .trst_pwron = 80000, + .cke_inactive = 200000, + .wrlat = 5, + .caslat_lin = 12, + .trc = 21, + .trrd = 4, + .tccd = 4, + .tbst_int_interval = 0, + .tfaw = 20, + .trp = 6, + .twtr = 4, + .tras_min = 15, + .tmrd = 4, + .trtp = 4, + .tras_max = 28080, + .tmod = 12, + .tckesr = 4, + .tcke = 3, + .trcd_int = 6, + .tras_lockout = 0, + .tdal = 12, + .bstlen = 0, + .tdll = 512, + .trp_ab = 6, + .tref = 3120, + .trfc = 44, + .tref_int = 0, + .tpdex = 3, + .txpdll = 10, + .txsnr = 48, + .txsr = 468, + .cksrx = 5, + .cksre = 5, + .freq_chg_en = 0, + .zqcl = 256, + .zqinit = 512, + .zqcs = 64, + .ref_per_zq = 64, + .zqcs_rotate = 0, + .aprebit = 10, + .cmd_age_cnt = 64, + .age_cnt = 64, + .q_fullness = 7, + .odt_rd_mapcs0 = 0, + .odt_wr_mapcs0 = 1, + .wlmrd = 40, + .wldqsen = 25, };
- ddrmc_setup_iomux(); + ddrmc_setup_iomux(NULL, 0);
- ddrmc_ctrl_init_ddr3(&timings, &lvl, 1, 3); + ddrmc_ctrl_init_ddr3(&timings, vf610twr_cr_settings, NULL, 1, 3); gd->ram_size = get_ram_size((void *)PHYS_SDRAM, PHYS_SDRAM_SIZE);
return 0; diff --git a/board/toradex/colibri_vf/colibri_vf.c b/board/toradex/colibri_vf/colibri_vf.c index 8618fd0..39bf0ac 100644 --- a/board/toradex/colibri_vf/colibri_vf.c +++ b/board/toradex/colibri_vf/colibri_vf.c @@ -35,6 +35,61 @@ DECLARE_GLOBAL_DATA_PTR;
#define USB_PEN_GPIO 83
+static struct ddrmc_cr_setting colibri_vf_cr_settings[] = { + /* levelling */ + { DDRMC_CR97_WRLVL_EN, 97 }, + { DDRMC_CR98_WRLVL_DL_0(0), 98 }, + { DDRMC_CR99_WRLVL_DL_1(0), 99 }, + { DDRMC_CR102_RDLVL_REG_EN | DDRMC_CR102_RDLVL_GT_REGEN, 102 }, + { DDRMC_CR105_RDLVL_DL_0(0), 105 }, + { DDRMC_CR106_RDLVL_GTDL_0(4), 106 }, + { DDRMC_CR110_RDLVL_DL_1(0) | DDRMC_CR110_RDLVL_GTDL_1(4), 110 }, + /* AXI */ + { DDRMC_CR117_AXI0_W_PRI(0) | DDRMC_CR117_AXI0_R_PRI(0), 117 }, + { DDRMC_CR118_AXI1_W_PRI(1) | DDRMC_CR118_AXI1_R_PRI(1), 118 }, + { DDRMC_CR120_AXI0_PRI1_RPRI(2) | + DDRMC_CR120_AXI0_PRI0_RPRI(2), 120 }, + { DDRMC_CR121_AXI0_PRI3_RPRI(2) | + DDRMC_CR121_AXI0_PRI2_RPRI(2), 121 }, + { DDRMC_CR122_AXI1_PRI1_RPRI(1) | DDRMC_CR122_AXI1_PRI0_RPRI(1) | + DDRMC_CR122_AXI0_PRIRLX(100), 122 }, + { DDRMC_CR123_AXI1_P_ODR_EN | DDRMC_CR123_AXI1_PRI3_RPRI(1) | + DDRMC_CR123_AXI1_PRI2_RPRI(1), 123 }, + { DDRMC_CR124_AXI1_PRIRLX(100), 124 }, + { DDRMC_CR126_PHY_RDLAT(8), 126 }, + { DDRMC_CR132_WRLAT_ADJ(5) | + DDRMC_CR132_RDLAT_ADJ(6), 132 }, + { DDRMC_CR137_PHYCTL_DL(2), 137 }, + { DDRMC_CR138_PHY_WRLV_MXDL(256) | + DDRMC_CR138_PHYDRAM_CK_EN(1), 138 }, + { DDRMC_CR139_PHY_WRLV_RESPLAT(4) | DDRMC_CR139_PHY_WRLV_LOAD(7) | + DDRMC_CR139_PHY_WRLV_DLL(3) | + DDRMC_CR139_PHY_WRLV_EN(3), 139 }, + { DDRMC_CR140_PHY_WRLV_WW(64), 140 }, + { DDRMC_CR143_RDLV_GAT_MXDL(1536) | + DDRMC_CR143_RDLV_MXDL(128), 143 }, + { DDRMC_CR144_PHY_RDLVL_RES(4) | DDRMC_CR144_PHY_RDLV_LOAD(7) | + DDRMC_CR144_PHY_RDLV_DLL(3) | + DDRMC_CR144_PHY_RDLV_EN(3), 144 }, + { DDRMC_CR145_PHY_RDLV_RR(64), 145 }, + { DDRMC_CR146_PHY_RDLVL_RESP(64), 146 }, + { DDRMC_CR147_RDLV_RESP_MASK(983040), 147 }, + { DDRMC_CR148_RDLV_GATE_RESP_MASK(983040), 148 }, + { DDRMC_CR151_RDLV_GAT_DQ_ZERO_CNT(1) | + DDRMC_CR151_RDLVL_DQ_ZERO_CNT(1), 151 }, + + { DDRMC_CR154_PAD_ZQ_EARLY_CMP_EN_TIMER(13) | + DDRMC_CR154_PAD_ZQ_MODE(1) | + DDRMC_CR154_DDR_SEL_PAD_CONTR(3) | + DDRMC_CR154_PAD_ZQ_HW_FOR(1), 154 }, + { DDRMC_CR155_PAD_ODT_BYTE1(1) | DDRMC_CR155_PAD_ODT_BYTE0(1), 155 }, + { DDRMC_CR158_TWR(6), 158 }, + { DDRMC_CR161_ODT_EN(1) | DDRMC_CR161_TODTH_RD(2) | + DDRMC_CR161_TODTH_WR(2), 161 }, + /* end marker */ + { 0, -1 } +}; + static const iomux_v3_cfg_t usb_pads[] = { VF610_PAD_PTD4__GPIO_83, }; @@ -42,48 +97,59 @@ static const iomux_v3_cfg_t usb_pads[] = { int dram_init(void) { static const struct ddr3_jedec_timings timings = { - .tinit = 5, - .trst_pwron = 80000, - .cke_inactive = 200000, - .wrlat = 5, - .caslat_lin = 12, - .trc = 21, - .trrd = 4, - .tccd = 4, - .tfaw = 20, - .trp = 6, - .twtr = 4, - .tras_min = 15, - .tmrd = 4, - .trtp = 4, - .tras_max = 28080, - .tmod = 12, - .tckesr = 4, - .tcke = 3, - .trcd_int = 6, - .tdal = 12, - .tdll = 512, - .trp_ab = 6, - .tref = 3120, - .trfc = 64, - .tpdex = 3, - .txpdll = 10, - .txsnr = 48, - .txsr = 468, - .cksrx = 5, - .cksre = 5, - .zqcl = 256, - .zqinit = 512, - .zqcs = 64, - .ref_per_zq = 64, - .aprebit = 10, - .wlmrd = 40, - .wldqsen = 25, + .tinit = 5, + .trst_pwron = 80000, + .cke_inactive = 200000, + .wrlat = 5, + .caslat_lin = 12, + .trc = 21, + .trrd = 4, + .tccd = 4, + .tbst_int_interval = 0, + .tfaw = 20, + .trp = 6, + .twtr = 4, + .tras_min = 15, + .tmrd = 4, + .trtp = 4, + .tras_max = 28080, + .tmod = 12, + .tckesr = 4, + .tcke = 3, + .trcd_int = 6, + .tras_lockout = 0, + .tdal = 12, + .bstlen = 0, + .tdll = 512, + .trp_ab = 6, + .tref = 3120, + .trfc = 64, + .tref_int = 0, + .tpdex = 3, + .txpdll = 10, + .txsnr = 48, + .txsr = 468, + .cksrx = 5, + .cksre = 5, + .freq_chg_en = 0, + .zqcl = 256, + .zqinit = 512, + .zqcs = 64, + .ref_per_zq = 64, + .zqcs_rotate = 0, + .aprebit = 10, + .cmd_age_cnt = 64, + .age_cnt = 64, + .q_fullness = 7, + .odt_rd_mapcs0 = 0, + .odt_wr_mapcs0 = 1, + .wlmrd = 40, + .wldqsen = 25, };
- ddrmc_ctrl_init_ddr3(&timings, NULL, 1, 2); + ddrmc_ctrl_init_ddr3(&timings, colibri_vf_cr_settings, NULL, 1, 2); gd->ram_size = get_ram_size((void *)PHYS_SDRAM, PHYS_SDRAM_SIZE);
The driver assumed that I2C1 and I2C2 were always enabled, and if they were not, then an asynchronous abort was (silently) raised, to be caught much later on in the Linux kernel.
Fix this by making I2C1 and I2C2 optional just like I2C3 and I2C4 are.
To make the change binary-invariant, declare I2C1 and I2C2 in every include/configs/ file which defines CONFIG_SYS_I2C_MXC.
Also, while updating README about CONFIG_SYS_I2C_MXC_I2C1 and CONFIG_SYS_I2C_MXC_I2C2, add missing descriptions for I2C4 speed (CONFIG_SYS_MXC_I2C4_SPEED) and slave (CONFIG_SYS_MXC_I2C4_SLAVE) config options.
Changes in v2: - Make MXC I2C1 and I2C2 optional
README | 8 ++++++-- drivers/i2c/mxc_i2c.c | 6 ++++++ include/configs/apf27.h | 2 ++ include/configs/aristainetos-common.h | 2 ++ include/configs/cgtqmx6eval.h | 2 ++ include/configs/cm_fx6.h | 2 ++ include/configs/embestmx6boards.h | 2 ++ include/configs/flea3.h | 2 ++ include/configs/gw_ventana.h | 2 ++ include/configs/imx31_phycore.h | 2 ++ include/configs/ls1021aqds.h | 2 ++ include/configs/ls1021atwr.h | 2 ++ include/configs/ls2085a_common.h | 2 ++ include/configs/m53evk.h | 2 ++ include/configs/mx25pdk.h | 2 ++ include/configs/mx35pdk.h | 2 ++ include/configs/mx53ard.h | 2 ++ include/configs/mx53evk.h | 2 ++ include/configs/mx53loco.h | 2 ++ include/configs/mx53smd.h | 2 ++ include/configs/mx6qsabreauto.h | 2 ++ include/configs/mx6sabresd.h | 2 ++ include/configs/mx6slevk.h | 2 ++ include/configs/mx6sxsabresd.h | 2 ++ include/configs/mx6ul_14x14_evk.h | 2 ++ include/configs/mx7dsabresd.h | 2 +- include/configs/nitrogen6x.h | 2 ++ include/configs/novena.h | 2 ++ include/configs/ot1200.h | 2 ++ include/configs/platinum.h | 2 ++ include/configs/tbs2910.h | 2 ++ include/configs/titanium.h | 2 ++ include/configs/tqma6.h | 2 ++ include/configs/usbarmory.h | 2 ++ include/configs/vf610twr.h | 2 ++ include/configs/wandboard.h | 2 ++ include/configs/warp.h | 2 ++ include/configs/woodburn_common.h | 2 ++ 38 files changed, 83 insertions(+), 3 deletions(-)
diff --git a/README b/README index a13705a..c22b60b 100644 --- a/README +++ b/README @@ -2359,16 +2359,20 @@ CBFS (Coreboot Filesystem) support
- drivers/i2c/i2c_mxc.c - activate this driver with CONFIG_SYS_I2C_MXC + - enable bus 1 with CONFIG_SYS_I2C_MXC_I2C1 + - enable bus 2 with CONFIG_SYS_I2C_MXC_I2C2 + - enable bus 3 with CONFIG_SYS_I2C_MXC_I2C3 + - enable bus 4 with CONFIG_SYS_I2C_MXC_I2C4 - define speed for bus 1 with CONFIG_SYS_MXC_I2C1_SPEED - define slave for bus 1 with CONFIG_SYS_MXC_I2C1_SLAVE - define speed for bus 2 with CONFIG_SYS_MXC_I2C2_SPEED - define slave for bus 2 with CONFIG_SYS_MXC_I2C2_SLAVE - define speed for bus 3 with CONFIG_SYS_MXC_I2C3_SPEED - define slave for bus 3 with CONFIG_SYS_MXC_I2C3_SLAVE + - define speed for bus 4 with CONFIG_SYS_MXC_I2C4_SPEED + - define slave for bus 4 with CONFIG_SYS_MXC_I2C4_SLAVE If those defines are not set, default value is 100000 for speed, and 0 for slave. - - enable bus 3 with CONFIG_SYS_I2C_MXC_I2C3 - - enable bus 4 with CONFIG_SYS_I2C_MXC_I2C4
- drivers/i2c/rcar_i2c.c: - activate this driver with CONFIG_SYS_I2C_RCAR diff --git a/drivers/i2c/mxc_i2c.c b/drivers/i2c/mxc_i2c.c index f1056e2..0f977d7 100644 --- a/drivers/i2c/mxc_i2c.c +++ b/drivers/i2c/mxc_i2c.c @@ -612,16 +612,22 @@ static u32 mxc_i2c_set_bus_speed(struct i2c_adapter *adap, uint speed) /* * Register mxc i2c adapters */ +#ifdef CONFIG_SYS_I2C_MXC_I2C1 U_BOOT_I2C_ADAP_COMPLETE(mxc0, mxc_i2c_init, mxc_i2c_probe, mxc_i2c_read, mxc_i2c_write, mxc_i2c_set_bus_speed, CONFIG_SYS_MXC_I2C1_SPEED, CONFIG_SYS_MXC_I2C1_SLAVE, 0) +#endif + +#ifdef CONFIG_SYS_I2C_MXC_I2C2 U_BOOT_I2C_ADAP_COMPLETE(mxc1, mxc_i2c_init, mxc_i2c_probe, mxc_i2c_read, mxc_i2c_write, mxc_i2c_set_bus_speed, CONFIG_SYS_MXC_I2C2_SPEED, CONFIG_SYS_MXC_I2C2_SLAVE, 1) +#endif + #ifdef CONFIG_SYS_I2C_MXC_I2C3 U_BOOT_I2C_ADAP_COMPLETE(mxc2, mxc_i2c_init, mxc_i2c_probe, mxc_i2c_read, mxc_i2c_write, diff --git a/include/configs/apf27.h b/include/configs/apf27.h index 43fbdd3..49fbcac 100644 --- a/include/configs/apf27.h +++ b/include/configs/apf27.h @@ -317,6 +317,8 @@ #ifdef CONFIG_CMD_I2C #define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_MXC +#define CONFIG_SYS_I2C_MXC_I2C1 /* enable I2C bus 1 */ +#define CONFIG_SYS_I2C_MXC_I2C2 /* enable I2C bus 2 */ #define CONFIG_SYS_MXC_I2C1_SPEED 100000 /* 100 kHz */ #define CONFIG_SYS_MXC_I2C1_SLAVE 0x7F #define CONFIG_SYS_MXC_I2C2_SPEED 100000 /* 100 kHz */ diff --git a/include/configs/aristainetos-common.h b/include/configs/aristainetos-common.h index 20afdd6..f03297e 100644 --- a/include/configs/aristainetos-common.h +++ b/include/configs/aristainetos-common.h @@ -189,6 +189,8 @@ #define CONFIG_CMD_I2C #define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_MXC +#define CONFIG_SYS_I2C_MXC_I2C1 /* enable I2C bus 1 */ +#define CONFIG_SYS_I2C_MXC_I2C2 /* enable I2C bus 2 */ #define CONFIG_SYS_I2C_MXC_I2C3 /* enable I2C bus 3 */ #define CONFIG_SYS_I2C_SPEED 100000 #define CONFIG_SYS_I2C_SLAVE 0x7f diff --git a/include/configs/cgtqmx6eval.h b/include/configs/cgtqmx6eval.h index c7d54ee..5b6a4a5 100644 --- a/include/configs/cgtqmx6eval.h +++ b/include/configs/cgtqmx6eval.h @@ -39,6 +39,8 @@ #define CONFIG_CMD_I2C #define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_MXC +#define CONFIG_SYS_I2C_MXC_I2C1 /* enable I2C bus 1 */ +#define CONFIG_SYS_I2C_MXC_I2C2 /* enable I2C bus 2 */ #define CONFIG_SYS_I2C_MXC_I2C2 /* enable I2C bus 2 */ #define CONFIG_SYS_I2C_SPEED 100000
diff --git a/include/configs/cm_fx6.h b/include/configs/cm_fx6.h index 12734a1..0513204 100644 --- a/include/configs/cm_fx6.h +++ b/include/configs/cm_fx6.h @@ -198,6 +198,8 @@ /* I2C */ #define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_MXC +#define CONFIG_SYS_I2C_MXC_I2C1 /* enable I2C bus 1 */ +#define CONFIG_SYS_I2C_MXC_I2C2 /* enable I2C bus 2 */ #define CONFIG_SYS_I2C_MXC_I2C3 /* enable I2C bus 3 */ #define CONFIG_SYS_I2C_SPEED 100000 #define CONFIG_SYS_MXC_I2C3_SPEED 400000 diff --git a/include/configs/embestmx6boards.h b/include/configs/embestmx6boards.h index 58cee96..f55ba9f 100644 --- a/include/configs/embestmx6boards.h +++ b/include/configs/embestmx6boards.h @@ -33,6 +33,8 @@ #define CONFIG_CMD_I2C #define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_MXC +#define CONFIG_SYS_I2C_MXC_I2C1 /* enable I2C bus 1 */ +#define CONFIG_SYS_I2C_MXC_I2C2 /* enable I2C bus 2 */ #define CONFIG_SYS_I2C_MXC_I2C3 /* enable I2C bus 3 */ #define CONFIG_SYS_I2C_SPEED 100000
diff --git a/include/configs/flea3.h b/include/configs/flea3.h index 5b4b011..f646fee 100644 --- a/include/configs/flea3.h +++ b/include/configs/flea3.h @@ -52,6 +52,8 @@ */ #define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_MXC +#define CONFIG_SYS_I2C_MXC_I2C1 /* enable I2C bus 1 */ +#define CONFIG_SYS_I2C_MXC_I2C2 /* enable I2C bus 2 */ #define CONFIG_SYS_I2C_MXC_I2C3 /* enable I2C bus 3 */ #define CONFIG_SYS_SPD_BUS_NUM 2 /* I2C3 */ #define CONFIG_SYS_MXC_I2C3_SLAVE 0xfe diff --git a/include/configs/gw_ventana.h b/include/configs/gw_ventana.h index 231bea7..484d763 100644 --- a/include/configs/gw_ventana.h +++ b/include/configs/gw_ventana.h @@ -107,6 +107,8 @@ #define CONFIG_CMD_I2C #define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_MXC +#define CONFIG_SYS_I2C_MXC_I2C1 /* enable I2C bus 1 */ +#define CONFIG_SYS_I2C_MXC_I2C2 /* enable I2C bus 2 */ #define CONFIG_SYS_I2C_MXC_I2C3 /* enable I2C bus 3 */ #define CONFIG_SYS_I2C_SPEED 100000 #define CONFIG_I2C_GSC 0 diff --git a/include/configs/imx31_phycore.h b/include/configs/imx31_phycore.h index 86f327c..3bea71b 100644 --- a/include/configs/imx31_phycore.h +++ b/include/configs/imx31_phycore.h @@ -38,6 +38,8 @@
#define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_MXC +#define CONFIG_SYS_I2C_MXC_I2C1 /* enable I2C bus 1 */ +#define CONFIG_SYS_I2C_MXC_I2C2 /* enable I2C bus 2 */ #define CONFIG_SYS_I2C_MXC_I2C3 /* enable I2C bus 3 */ #define CONFIG_SYS_I2C_CLK_OFFSET I2C2_CLK_OFFSET
diff --git a/include/configs/ls1021aqds.h b/include/configs/ls1021aqds.h index b44f326..f73900f 100644 --- a/include/configs/ls1021aqds.h +++ b/include/configs/ls1021aqds.h @@ -389,6 +389,8 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_CMD_I2C #define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_MXC +#define CONFIG_SYS_I2C_MXC_I2C1 /* enable I2C bus 1 */ +#define CONFIG_SYS_I2C_MXC_I2C2 /* enable I2C bus 2 */ #define CONFIG_SYS_I2C_MXC_I2C3 /* enable I2C bus 3 */
/* diff --git a/include/configs/ls1021atwr.h b/include/configs/ls1021atwr.h index 7dcb719..f6bd5fc 100644 --- a/include/configs/ls1021atwr.h +++ b/include/configs/ls1021atwr.h @@ -275,6 +275,8 @@ #define CONFIG_CMD_I2C #define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_MXC +#define CONFIG_SYS_I2C_MXC_I2C1 /* enable I2C bus 1 */ +#define CONFIG_SYS_I2C_MXC_I2C2 /* enable I2C bus 2 */ #define CONFIG_SYS_I2C_MXC_I2C3 /* enable I2C bus 3 */
/* EEPROM */ diff --git a/include/configs/ls2085a_common.h b/include/configs/ls2085a_common.h index 2dbb5f7..55b909c 100644 --- a/include/configs/ls2085a_common.h +++ b/include/configs/ls2085a_common.h @@ -97,6 +97,8 @@ #define CONFIG_CMD_I2C #define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_MXC +#define CONFIG_SYS_I2C_MXC_I2C1 /* enable I2C bus 1 */ +#define CONFIG_SYS_I2C_MXC_I2C2 /* enable I2C bus 2 */ #define CONFIG_SYS_I2C_MXC_I2C3 /* enable I2C bus 3 */ #define CONFIG_SYS_I2C_MXC_I2C4 /* enable I2C bus 4 */
diff --git a/include/configs/m53evk.h b/include/configs/m53evk.h index 35058e2..8853d8f 100644 --- a/include/configs/m53evk.h +++ b/include/configs/m53evk.h @@ -172,6 +172,8 @@ #ifdef CONFIG_CMD_I2C #define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_MXC +#define CONFIG_SYS_I2C_MXC_I2C1 /* enable I2C bus 1 */ +#define CONFIG_SYS_I2C_MXC_I2C2 /* enable I2C bus 2 */ #define CONFIG_SYS_I2C_MXC_I2C3 /* enable I2C bus 3 */ #define CONFIG_SYS_RTC_BUS_NUM 1 /* I2C2 */ #endif diff --git a/include/configs/mx25pdk.h b/include/configs/mx25pdk.h index bd7216e..0414086 100644 --- a/include/configs/mx25pdk.h +++ b/include/configs/mx25pdk.h @@ -115,6 +115,8 @@ #define CONFIG_CMD_I2C #define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_MXC +#define CONFIG_SYS_I2C_MXC_I2C1 /* enable I2C bus 1 */ +#define CONFIG_SYS_I2C_MXC_I2C2 /* enable I2C bus 2 */
/* RTC */ #define CONFIG_RTC_IMXDI diff --git a/include/configs/mx35pdk.h b/include/configs/mx35pdk.h index c9983f3..6bfdaa6 100644 --- a/include/configs/mx35pdk.h +++ b/include/configs/mx35pdk.h @@ -42,6 +42,8 @@ */ #define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_MXC +#define CONFIG_SYS_I2C_MXC_I2C1 /* enable I2C bus 1 */ +#define CONFIG_SYS_I2C_MXC_I2C2 /* enable I2C bus 2 */ #define CONFIG_SYS_I2C_MXC_I2C3 /* enable I2C bus 3 */ #define CONFIG_MXC_SPI #define CONFIG_MXC_GPIO diff --git a/include/configs/mx53ard.h b/include/configs/mx53ard.h index 0479195..b889c25 100644 --- a/include/configs/mx53ard.h +++ b/include/configs/mx53ard.h @@ -48,6 +48,8 @@ #define CONFIG_CMD_I2C #define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_MXC +#define CONFIG_SYS_I2C_MXC_I2C1 /* enable I2C bus 1 */ +#define CONFIG_SYS_I2C_MXC_I2C2 /* enable I2C bus 2 */ #define CONFIG_SYS_I2C_MXC_I2C3 /* enable I2C bus 3 */
/* MMC Configs */ diff --git a/include/configs/mx53evk.h b/include/configs/mx53evk.h index 82c8af8..4f304ed 100644 --- a/include/configs/mx53evk.h +++ b/include/configs/mx53evk.h @@ -41,6 +41,8 @@ #define CONFIG_CMD_I2C #define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_MXC +#define CONFIG_SYS_I2C_MXC_I2C1 /* enable I2C bus 1 */ +#define CONFIG_SYS_I2C_MXC_I2C2 /* enable I2C bus 2 */ #define CONFIG_SYS_I2C_MXC_I2C3 /* enable I2C bus 3 */
/* PMIC Configs */ diff --git a/include/configs/mx53loco.h b/include/configs/mx53loco.h index ad2629d..3a65861 100644 --- a/include/configs/mx53loco.h +++ b/include/configs/mx53loco.h @@ -76,6 +76,8 @@ /* I2C Configs */ #define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_MXC +#define CONFIG_SYS_I2C_MXC_I2C1 /* enable I2C bus 1 */ +#define CONFIG_SYS_I2C_MXC_I2C2 /* enable I2C bus 2 */ #define CONFIG_SYS_I2C_MXC_I2C3 /* enable I2C bus 3 */
/* PMIC Controller */ diff --git a/include/configs/mx53smd.h b/include/configs/mx53smd.h index bcdb054..e46f2ee 100644 --- a/include/configs/mx53smd.h +++ b/include/configs/mx53smd.h @@ -38,6 +38,8 @@ #define CONFIG_CMD_I2C #define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_MXC +#define CONFIG_SYS_I2C_MXC_I2C1 /* enable I2C bus 1 */ +#define CONFIG_SYS_I2C_MXC_I2C2 /* enable I2C bus 2 */ #define CONFIG_SYS_I2C_MXC_I2C3 /* enable I2C bus 3 */
/* MMC Configs */ diff --git a/include/configs/mx6qsabreauto.h b/include/configs/mx6qsabreauto.h index 11cf538..1c99805 100644 --- a/include/configs/mx6qsabreauto.h +++ b/include/configs/mx6qsabreauto.h @@ -51,6 +51,8 @@ #define CONFIG_CMD_I2C #define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_MXC +#define CONFIG_SYS_I2C_MXC_I2C1 /* enable I2C bus 1 */ +#define CONFIG_SYS_I2C_MXC_I2C2 /* enable I2C bus 2 */ #define CONFIG_SYS_I2C_MXC_I2C3 /* enable I2C bus 3 */ #define CONFIG_SYS_I2C_SPEED 100000
diff --git a/include/configs/mx6sabresd.h b/include/configs/mx6sabresd.h index 5f635ca..e9e3b27 100644 --- a/include/configs/mx6sabresd.h +++ b/include/configs/mx6sabresd.h @@ -44,6 +44,8 @@ #define CONFIG_CMD_I2C #define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_MXC +#define CONFIG_SYS_I2C_MXC_I2C1 /* enable I2C bus 1 */ +#define CONFIG_SYS_I2C_MXC_I2C2 /* enable I2C bus 2 */ #define CONFIG_SYS_I2C_MXC_I2C3 /* enable I2C bus 3 */ #define CONFIG_SYS_I2C_SPEED 100000
diff --git a/include/configs/mx6slevk.h b/include/configs/mx6slevk.h index 51b297a..ae39503 100644 --- a/include/configs/mx6slevk.h +++ b/include/configs/mx6slevk.h @@ -35,6 +35,8 @@ #define CONFIG_CMD_I2C #define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_MXC +#define CONFIG_SYS_I2C_MXC_I2C1 /* enable I2C bus 1 */ +#define CONFIG_SYS_I2C_MXC_I2C2 /* enable I2C bus 2 */ #define CONFIG_SYS_I2C_MXC_I2C3 /* enable I2C bus 3 */ #define CONFIG_SYS_I2C_SPEED 100000
diff --git a/include/configs/mx6sxsabresd.h b/include/configs/mx6sxsabresd.h index 381eaa2..edf7d3f 100644 --- a/include/configs/mx6sxsabresd.h +++ b/include/configs/mx6sxsabresd.h @@ -127,6 +127,8 @@ #define CONFIG_CMD_I2C #define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_MXC +#define CONFIG_SYS_I2C_MXC_I2C1 /* enable I2C bus 1 */ +#define CONFIG_SYS_I2C_MXC_I2C2 /* enable I2C bus 2 */ #define CONFIG_SYS_I2C_MXC_I2C3 /* enable I2C bus 3 */ #define CONFIG_SYS_I2C_SPEED 100000
diff --git a/include/configs/mx6ul_14x14_evk.h b/include/configs/mx6ul_14x14_evk.h index 465ddee..d5faae6 100644 --- a/include/configs/mx6ul_14x14_evk.h +++ b/include/configs/mx6ul_14x14_evk.h @@ -54,6 +54,8 @@ #ifdef CONFIG_CMD_I2C #define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_MXC +#define CONFIG_SYS_I2C_MXC_I2C1 /* enable I2C bus 1 */ +#define CONFIG_SYS_I2C_MXC_I2C2 /* enable I2C bus 2 */ #define CONFIG_SYS_I2C_SPEED 100000
/* PMIC only for 9X9 EVK */ diff --git a/include/configs/mx7dsabresd.h b/include/configs/mx7dsabresd.h index ec6e0a6..f39c786 100644 --- a/include/configs/mx7dsabresd.h +++ b/include/configs/mx7dsabresd.h @@ -48,7 +48,7 @@ #define CONFIG_CMD_I2C #define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_MXC -#define CONFIG_SYS_I2C_MXC_I2C1 +#define CONFIG_SYS_I2C_MXC_I2C1 /* enable I2C bus 1 */ #define CONFIG_SYS_I2C_SPEED 100000
#define CONFIG_SUPPORT_EMMC_BOOT /* eMMC specific */ diff --git a/include/configs/nitrogen6x.h b/include/configs/nitrogen6x.h index dd4cb0f..b113771 100644 --- a/include/configs/nitrogen6x.h +++ b/include/configs/nitrogen6x.h @@ -43,6 +43,8 @@ #define CONFIG_CMD_I2C #define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_MXC +#define CONFIG_SYS_I2C_MXC_I2C1 /* enable I2C bus 1 */ +#define CONFIG_SYS_I2C_MXC_I2C2 /* enable I2C bus 2 */ #define CONFIG_SYS_I2C_MXC_I2C3 /* enable I2C bus 3 */ #define CONFIG_SYS_I2C_SPEED 100000 #define CONFIG_I2C_EDID diff --git a/include/configs/novena.h b/include/configs/novena.h index 0970fd7..cd426be 100644 --- a/include/configs/novena.h +++ b/include/configs/novena.h @@ -102,6 +102,8 @@ /* I2C */ #define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_MXC +#define CONFIG_SYS_I2C_MXC_I2C1 /* enable I2C bus 1 */ +#define CONFIG_SYS_I2C_MXC_I2C2 /* enable I2C bus 2 */ #define CONFIG_SYS_I2C_MXC_I2C3 /* enable I2C bus 3 */ #define CONFIG_I2C_MULTI_BUS #define CONFIG_I2C_MXC diff --git a/include/configs/ot1200.h b/include/configs/ot1200.h index 0d06fce..426ec72 100644 --- a/include/configs/ot1200.h +++ b/include/configs/ot1200.h @@ -44,6 +44,8 @@ #define CONFIG_CMD_I2C #define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_MXC +#define CONFIG_SYS_I2C_MXC_I2C1 /* enable I2C bus 1 */ +#define CONFIG_SYS_I2C_MXC_I2C2 /* enable I2C bus 2 */ #define CONFIG_SYS_I2C_MXC_I2C3 /* enable I2C bus 3 */ #define CONFIG_SYS_I2C_SPEED 100000
diff --git a/include/configs/platinum.h b/include/configs/platinum.h index d651432..bb7e845 100644 --- a/include/configs/platinum.h +++ b/include/configs/platinum.h @@ -45,6 +45,8 @@ /* I2C config */ #define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_MXC +#define CONFIG_SYS_I2C_MXC_I2C1 /* enable I2C bus 1 */ +#define CONFIG_SYS_I2C_MXC_I2C2 /* enable I2C bus 2 */ #define CONFIG_SYS_I2C_MXC_I2C3 /* enable I2C bus 3 */ #define CONFIG_SYS_I2C_SPEED 100000
diff --git a/include/configs/tbs2910.h b/include/configs/tbs2910.h index 70b4403..8371fe9 100644 --- a/include/configs/tbs2910.h +++ b/include/configs/tbs2910.h @@ -167,6 +167,8 @@ #ifdef CONFIG_CMD_I2C #define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_MXC +#define CONFIG_SYS_I2C_MXC_I2C1 /* enable I2C bus 1 */ +#define CONFIG_SYS_I2C_MXC_I2C2 /* enable I2C bus 2 */ #define CONFIG_SYS_I2C_MXC_I2C3 /* enable I2C bus 3 */ #define CONFIG_SYS_I2C_SPEED 100000 #define CONFIG_I2C_EDID diff --git a/include/configs/titanium.h b/include/configs/titanium.h index 1b4ca29..acfa84a 100644 --- a/include/configs/titanium.h +++ b/include/configs/titanium.h @@ -33,6 +33,8 @@ #define CONFIG_CMD_I2C #define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_MXC +#define CONFIG_SYS_I2C_MXC_I2C1 /* enable I2C bus 1 */ +#define CONFIG_SYS_I2C_MXC_I2C2 /* enable I2C bus 2 */ #define CONFIG_SYS_I2C_MXC_I2C3 /* enable I2C bus 3 */ #define CONFIG_SYS_I2C_SPEED 100000
diff --git a/include/configs/tqma6.h b/include/configs/tqma6.h index f7fade1..295e163 100644 --- a/include/configs/tqma6.h +++ b/include/configs/tqma6.h @@ -62,6 +62,8 @@ #define CONFIG_CMD_I2C #define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_MXC +#define CONFIG_SYS_I2C_MXC_I2C1 /* enable I2C bus 1 */ +#define CONFIG_SYS_I2C_MXC_I2C2 /* enable I2C bus 2 */ #define CONFIG_SYS_I2C_MXC_I2C3 /* enable I2C bus 3 */ #define CONFIG_I2C_MULTI_BUS #define CONFIG_SYS_I2C_SPEED 100000 diff --git a/include/configs/usbarmory.h b/include/configs/usbarmory.h index 4a7702c..714e3e2 100644 --- a/include/configs/usbarmory.h +++ b/include/configs/usbarmory.h @@ -67,6 +67,8 @@ #define CONFIG_CMD_I2C #define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_MXC +#define CONFIG_SYS_I2C_MXC_I2C1 /* enable I2C bus 1 */ +#define CONFIG_SYS_I2C_MXC_I2C2 /* enable I2C bus 2 */
/* Fuse */ #define CONFIG_CMD_FUSE diff --git a/include/configs/vf610twr.h b/include/configs/vf610twr.h index c5131af..324ba8f 100644 --- a/include/configs/vf610twr.h +++ b/include/configs/vf610twr.h @@ -110,6 +110,8 @@ #define CONFIG_CMD_I2C #define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_MXC +#define CONFIG_SYS_I2C_MXC_I2C1 /* enable I2C bus 1 */ +#define CONFIG_SYS_I2C_MXC_I2C2 /* enable I2C bus 2 */ #define CONFIG_SYS_SPD_BUS_NUM 0
#define CONFIG_BOOTDELAY 3 diff --git a/include/configs/wandboard.h b/include/configs/wandboard.h index f4e9cf2..6e8aec2 100644 --- a/include/configs/wandboard.h +++ b/include/configs/wandboard.h @@ -37,6 +37,8 @@ #define CONFIG_CMD_I2C #define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_MXC +#define CONFIG_SYS_I2C_MXC_I2C1 /* enable I2C bus 1 */ +#define CONFIG_SYS_I2C_MXC_I2C2 /* enable I2C bus 2 */ #define CONFIG_SYS_I2C_MXC_I2C3 /* enable I2C bus 3 */ #define CONFIG_SYS_I2C_SPEED 100000
diff --git a/include/configs/warp.h b/include/configs/warp.h index fa102bb..3e9a5a3 100644 --- a/include/configs/warp.h +++ b/include/configs/warp.h @@ -98,6 +98,8 @@ #define CONFIG_CMD_I2C #define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_MXC +#define CONFIG_SYS_I2C_MXC_I2C1 /* enable I2C bus 1 */ +#define CONFIG_SYS_I2C_MXC_I2C2 /* enable I2C bus 2 */ #define CONFIG_SYS_I2C_SPEED 100000
/* PMIC */ diff --git a/include/configs/woodburn_common.h b/include/configs/woodburn_common.h index 5d9f529..fc46565 100644 --- a/include/configs/woodburn_common.h +++ b/include/configs/woodburn_common.h @@ -47,6 +47,8 @@ */ #define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_MXC +#define CONFIG_SYS_I2C_MXC_I2C1 /* enable I2C bus 1 */ +#define CONFIG_SYS_I2C_MXC_I2C2 /* enable I2C bus 2 */ #define CONFIG_SYS_I2C_MXC_I2C3 /* enable I2C bus 3 */ #define CONFIG_SYS_SPD_BUS_NUM 0 #define CONFIG_MXC_SPI
Devices supported are: - NFC (NAND FLASH) - MMC - QSPI (SPI NOR FLASH) - I2C (only bus 2) - I2C RTC - I2C EEPROM - FEC
Patch-series: 2 - remove useless CONFIG_SYS_SPD_BUS_NUM from config - remove include of config_cmd_default.h - remove duplicate CONFIG_CMD_NET
Changes in v2: None
arch/arm/Kconfig | 5 + board/phytec/pcm052/Kconfig | 15 ++ board/phytec/pcm052/MAINTAINERS | 6 + board/phytec/pcm052/Makefile | 7 + board/phytec/pcm052/imximage.cfg | 17 ++ board/phytec/pcm052/pcm052.c | 515 +++++++++++++++++++++++++++++++++++++++ configs/pcm052_defconfig | 6 + include/configs/pcm052.h | 231 ++++++++++++++++++ 8 files changed, 802 insertions(+) create mode 100644 board/phytec/pcm052/Kconfig create mode 100644 board/phytec/pcm052/MAINTAINERS create mode 100644 board/phytec/pcm052/Makefile create mode 100644 board/phytec/pcm052/imximage.cfg create mode 100644 board/phytec/pcm052/pcm052.c create mode 100644 configs/pcm052_defconfig create mode 100644 include/configs/pcm052.h
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index c4371c7..341320c 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -538,6 +538,10 @@ config TARGET_COLIBRI_VF bool "Support Colibri VF50/61" select CPU_V7
+config TARGET_PCM052 + bool "Support pcm-052" + select CPU_V7 + config ARCH_ZYNQ bool "Xilinx Zynq Platform" select CPU_V7 @@ -751,6 +755,7 @@ source "board/maxbcm/Kconfig" source "board/mpl/vcma9/Kconfig" source "board/olimex/mx23_olinuxino/Kconfig" source "board/phytec/pcm051/Kconfig" +source "board/phytec/pcm052/Kconfig" source "board/ppcag/bg0900/Kconfig" source "board/samsung/smdk2410/Kconfig" source "board/sandisk/sansa_fuze_plus/Kconfig" diff --git a/board/phytec/pcm052/Kconfig b/board/phytec/pcm052/Kconfig new file mode 100644 index 0000000..d67a69a --- /dev/null +++ b/board/phytec/pcm052/Kconfig @@ -0,0 +1,15 @@ +if TARGET_PCM052 + +config SYS_BOARD + default "pcm052" + +config SYS_VENDOR + default "phytec" + +config SYS_SOC + default "vf610" + +config SYS_CONFIG_NAME + default "pcm052" + +endif diff --git a/board/phytec/pcm052/MAINTAINERS b/board/phytec/pcm052/MAINTAINERS new file mode 100644 index 0000000..a877436 --- /dev/null +++ b/board/phytec/pcm052/MAINTAINERS @@ -0,0 +1,6 @@ +PCM052 BOARD +M: Albert ARIBAUD (3ADEV) albert.aribaud@3adev.fr +S: Maintained +F: board/phytec/pcm052/ +F: include/configs/pcm052.h +F: configs/pcm052_defconfig diff --git a/board/phytec/pcm052/Makefile b/board/phytec/pcm052/Makefile new file mode 100644 index 0000000..144f4e7 --- /dev/null +++ b/board/phytec/pcm052/Makefile @@ -0,0 +1,7 @@ +# +# Copyright 2013 Freescale Semiconductor, Inc. +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y := pcm052.o diff --git a/board/phytec/pcm052/imximage.cfg b/board/phytec/pcm052/imximage.cfg new file mode 100644 index 0000000..f5a9747 --- /dev/null +++ b/board/phytec/pcm052/imximage.cfg @@ -0,0 +1,17 @@ +/* + * Copyright 2015 3ADEV http://www.3adev.com + * + * SPDX-License-Identifier: GPL-2.0+ + * + * Refer docs/README.imxmage for more details about how-to configure + * and create imximage boot image + * + * The syntax is taken as close as possible with the kwbimage + */ +#include <asm/imx-common/imximage.cfg> + +/* image version */ +IMAGE_VERSION 2 + +/* Boot Offset 0x400, valid for both SD and NAND boot */ +BOOT_OFFSET FLASH_OFFSET_STANDARD diff --git a/board/phytec/pcm052/pcm052.c b/board/phytec/pcm052/pcm052.c new file mode 100644 index 0000000..e4f61e1 --- /dev/null +++ b/board/phytec/pcm052/pcm052.c @@ -0,0 +1,515 @@ +/* + * Copyright 2013 Freescale Semiconductor, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/imx-regs.h> +#include <asm/arch/iomux-vf610.h> +#include <asm/arch/ddrmc-vf610.h> +#include <asm/arch/crm_regs.h> +#include <asm/arch/clock.h> +#include <mmc.h> +#include <fsl_esdhc.h> +#include <miiphy.h> +#include <netdev.h> +#include <i2c.h> + +DECLARE_GLOBAL_DATA_PTR; + +/* + * Default DDR pad settings in arch/arm/include/asm/arch-vf610/iomux-vf610.h + * do not match our settings. Let us (re)define our own settings here. + */ + +#define PCM052_VF610_DDR_PAD_CTRL PAD_CTL_DSE_20ohm +#define PCM052_VF610_DDR_PAD_CTRL_1 (PAD_CTL_DSE_20ohm | \ + PAD_CTL_INPUT_DIFFERENTIAL) +#define PCM052_VF610_DDR_RESET_PAD_CTL (PAD_CTL_DSE_150ohm | \ + PAD_CTL_PUS_100K_UP | \ + PAD_CTL_INPUT_DIFFERENTIAL) + +enum { + PCM052_VF610_PAD_DDR_RESETB = IOMUX_PAD(0x021c, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_RESET_PAD_CTL), + PCM052_VF610_PAD_DDR_A15__DDR_A_15 = IOMUX_PAD(0x0220, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), + PCM052_VF610_PAD_DDR_A14__DDR_A_14 = IOMUX_PAD(0x0224, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), + PCM052_VF610_PAD_DDR_A13__DDR_A_13 = IOMUX_PAD(0x0228, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), + PCM052_VF610_PAD_DDR_A12__DDR_A_12 = IOMUX_PAD(0x022c, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), + PCM052_VF610_PAD_DDR_A11__DDR_A_11 = IOMUX_PAD(0x0230, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), + PCM052_VF610_PAD_DDR_A10__DDR_A_10 = IOMUX_PAD(0x0234, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), + PCM052_VF610_PAD_DDR_A9__DDR_A_9 = IOMUX_PAD(0x0238, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), + PCM052_VF610_PAD_DDR_A8__DDR_A_8 = IOMUX_PAD(0x023c, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), + PCM052_VF610_PAD_DDR_A7__DDR_A_7 = IOMUX_PAD(0x0240, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), + PCM052_VF610_PAD_DDR_A6__DDR_A_6 = IOMUX_PAD(0x0244, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), + PCM052_VF610_PAD_DDR_A5__DDR_A_5 = IOMUX_PAD(0x0248, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), + PCM052_VF610_PAD_DDR_A4__DDR_A_4 = IOMUX_PAD(0x024c, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), + PCM052_VF610_PAD_DDR_A3__DDR_A_3 = IOMUX_PAD(0x0250, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), + PCM052_VF610_PAD_DDR_A2__DDR_A_2 = IOMUX_PAD(0x0254, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), + PCM052_VF610_PAD_DDR_A1__DDR_A_1 = IOMUX_PAD(0x0258, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), + PCM052_VF610_PAD_DDR_A0__DDR_A_0 = IOMUX_PAD(0x025c, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), + PCM052_VF610_PAD_DDR_BA2__DDR_BA_2 = IOMUX_PAD(0x0260, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), + PCM052_VF610_PAD_DDR_BA1__DDR_BA_1 = IOMUX_PAD(0x0264, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), + PCM052_VF610_PAD_DDR_BA0__DDR_BA_0 = IOMUX_PAD(0x0268, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), + PCM052_VF610_PAD_DDR_CAS__DDR_CAS_B = IOMUX_PAD(0x026c, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), + PCM052_VF610_PAD_DDR_CKE__DDR_CKE_0 = IOMUX_PAD(0x0270, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), + PCM052_VF610_PAD_DDR_CLK__DDR_CLK_0 = IOMUX_PAD(0x0274, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL_1), + PCM052_VF610_PAD_DDR_CS__DDR_CS_B_0 = IOMUX_PAD(0x0278, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), + PCM052_VF610_PAD_DDR_D15__DDR_D_15 = IOMUX_PAD(0x027c, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), + PCM052_VF610_PAD_DDR_D14__DDR_D_14 = IOMUX_PAD(0x0280, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), + PCM052_VF610_PAD_DDR_D13__DDR_D_13 = IOMUX_PAD(0x0284, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), + PCM052_VF610_PAD_DDR_D12__DDR_D_12 = IOMUX_PAD(0x0288, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), + PCM052_VF610_PAD_DDR_D11__DDR_D_11 = IOMUX_PAD(0x028c, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), + PCM052_VF610_PAD_DDR_D10__DDR_D_10 = IOMUX_PAD(0x0290, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), + PCM052_VF610_PAD_DDR_D9__DDR_D_9 = IOMUX_PAD(0x0294, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), + PCM052_VF610_PAD_DDR_D8__DDR_D_8 = IOMUX_PAD(0x0298, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), + PCM052_VF610_PAD_DDR_D7__DDR_D_7 = IOMUX_PAD(0x029c, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), + PCM052_VF610_PAD_DDR_D6__DDR_D_6 = IOMUX_PAD(0x02a0, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), + PCM052_VF610_PAD_DDR_D5__DDR_D_5 = IOMUX_PAD(0x02a4, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), + PCM052_VF610_PAD_DDR_D4__DDR_D_4 = IOMUX_PAD(0x02a8, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), + PCM052_VF610_PAD_DDR_D3__DDR_D_3 = IOMUX_PAD(0x02ac, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), + PCM052_VF610_PAD_DDR_D2__DDR_D_2 = IOMUX_PAD(0x02b0, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), + PCM052_VF610_PAD_DDR_D1__DDR_D_1 = IOMUX_PAD(0x02b4, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), + PCM052_VF610_PAD_DDR_D0__DDR_D_0 = IOMUX_PAD(0x02b8, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), + PCM052_VF610_PAD_DDR_DQM1__DDR_DQM_1 = IOMUX_PAD(0x02bc, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), + PCM052_VF610_PAD_DDR_DQM0__DDR_DQM_0 = IOMUX_PAD(0x02c0, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), + PCM052_VF610_PAD_DDR_DQS1__DDR_DQS_1 = IOMUX_PAD(0x02c4, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL_1), + PCM052_VF610_PAD_DDR_DQS0__DDR_DQS_0 = IOMUX_PAD(0x02c8, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL_1), + PCM052_VF610_PAD_DDR_RAS__DDR_RAS_B = IOMUX_PAD(0x02cc, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), + PCM052_VF610_PAD_DDR_WE__DDR_WE_B = IOMUX_PAD(0x02d0, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), + PCM052_VF610_PAD_DDR_ODT1__DDR_ODT_0 = IOMUX_PAD(0x02d4, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), + PCM052_VF610_PAD_DDR_ODT0__DDR_ODT_1 = IOMUX_PAD(0x02d8, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), + PCM052_VF610_PAD_DDR_DDRBYTE1__DDR_DDRBYTE1 = IOMUX_PAD(0x02dc, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), + PCM052_VF610_PAD_DDR_DDRBYTE0__DDR_DDRBYTE0 = IOMUX_PAD(0x02e0, __NA_, 0, __NA_, 0, PCM052_VF610_DDR_PAD_CTRL), +}; + +static struct ddrmc_cr_setting pcm052_cr_settings[] = { + /* not in the datasheets, but in the original code */ + { 0x00002000, 105 }, + { 0x00000020, 110 }, + /* AXI */ + { DDRMC_CR117_AXI0_W_PRI(1) | DDRMC_CR117_AXI0_R_PRI(1), 117 }, + { DDRMC_CR118_AXI1_W_PRI(1) | DDRMC_CR118_AXI1_R_PRI(1), 118 }, + { DDRMC_CR120_AXI0_PRI1_RPRI(2) | + DDRMC_CR120_AXI0_PRI0_RPRI(2), 120 }, + { DDRMC_CR121_AXI0_PRI3_RPRI(2) | + DDRMC_CR121_AXI0_PRI2_RPRI(2), 121 }, + { DDRMC_CR122_AXI1_PRI1_RPRI(1) | DDRMC_CR122_AXI1_PRI0_RPRI(1) | + DDRMC_CR122_AXI0_PRIRLX(100), 122 }, + { DDRMC_CR123_AXI1_P_ODR_EN | DDRMC_CR123_AXI1_PRI3_RPRI(1) | + DDRMC_CR123_AXI1_PRI2_RPRI(1), 123 }, + { DDRMC_CR124_AXI1_PRIRLX(100), 124 }, + { DDRMC_CR126_PHY_RDLAT(11), 126 }, + { DDRMC_CR132_WRLAT_ADJ(5) | DDRMC_CR132_RDLAT_ADJ(6), 132 }, + { DDRMC_CR137_PHYCTL_DL(2), 137 }, + { DDRMC_CR139_PHY_WRLV_RESPLAT(4) | DDRMC_CR139_PHY_WRLV_LOAD(7) | + DDRMC_CR139_PHY_WRLV_DLL(3) | + DDRMC_CR139_PHY_WRLV_EN(3), 139 }, + { DDRMC_CR154_PAD_ZQ_EARLY_CMP_EN_TIMER(13) | + DDRMC_CR154_PAD_ZQ_MODE(1) | + DDRMC_CR154_DDR_SEL_PAD_CONTR(3) | + DDRMC_CR154_PAD_ZQ_HW_FOR(0), 154 }, + { DDRMC_CR155_PAD_ODT_BYTE1(5) | DDRMC_CR155_PAD_ODT_BYTE0(5), 155 }, + { DDRMC_CR158_TWR(6), 158 }, + { DDRMC_CR161_ODT_EN(0) | DDRMC_CR161_TODTH_RD(0) | + DDRMC_CR161_TODTH_WR(6), 161 }, + /* end marker */ + { 0, -1 } +}; + +/* PHY settings -- most of them differ from default in imx-regs.h */ + +#define PCM052_DDRMC_PHY_DQ_TIMING 0x00002213 +#define PCM052_DDRMC_PHY_CTRL 0x00290000 +#define PCM052_DDRMC_PHY_SLAVE_CTRL 0x00002c00 +#define PCM052_DDRMC_PHY_PROC_PAD_ODT 0x00010020 + +static struct ddrmc_phy_setting pcm052_phy_settings[] = { + { PCM052_DDRMC_PHY_DQ_TIMING, 0 }, + { PCM052_DDRMC_PHY_DQ_TIMING, 16 }, + { PCM052_DDRMC_PHY_DQ_TIMING, 32 }, + { PCM052_DDRMC_PHY_DQ_TIMING, 48 }, + { DDRMC_PHY_DQS_TIMING, 1 }, + { DDRMC_PHY_DQS_TIMING, 17 }, + { DDRMC_PHY_DQS_TIMING, 33 }, + { DDRMC_PHY_DQS_TIMING, 49 }, + { PCM052_DDRMC_PHY_CTRL, 2 }, + { PCM052_DDRMC_PHY_CTRL, 18 }, + { PCM052_DDRMC_PHY_CTRL, 34 }, + { DDRMC_PHY_MASTER_CTRL, 3 }, + { DDRMC_PHY_MASTER_CTRL, 19 }, + { DDRMC_PHY_MASTER_CTRL, 35 }, + { PCM052_DDRMC_PHY_SLAVE_CTRL, 4 }, + { PCM052_DDRMC_PHY_SLAVE_CTRL, 20 }, + { PCM052_DDRMC_PHY_SLAVE_CTRL, 36 }, + { DDRMC_PHY50_DDR3_MODE | DDRMC_PHY50_EN_SW_HALF_CYCLE, 50 }, + { PCM052_DDRMC_PHY_PROC_PAD_ODT, 52 }, + + /* end marker */ + { 0, -1 } +}; + +int dram_init(void) +{ + static const struct ddr3_jedec_timings pcm052_ddr_timings = { + .tinit = 5, + .trst_pwron = 80000, + .cke_inactive = 200000, + .wrlat = 5, + .caslat_lin = 12, + .trc = 6, + .trrd = 4, + .tccd = 4, + .tbst_int_interval = 4, + .tfaw = 18, + .trp = 6, + .twtr = 4, + .tras_min = 15, + .tmrd = 4, + .trtp = 4, + .tras_max = 14040, + .tmod = 12, + .tckesr = 4, + .tcke = 3, + .trcd_int = 6, + .tras_lockout = 1, + .tdal = 10, + .bstlen = 3, + .tdll = 512, + .trp_ab = 6, + .tref = 1542, + .trfc = 64, + .tref_int = 5, + .tpdex = 3, + .txpdll = 10, + .txsnr = 68, + .txsr = 506, + .cksrx = 5, + .cksre = 5, + .freq_chg_en = 1, + .zqcl = 256, + .zqinit = 512, + .zqcs = 64, + .ref_per_zq = 64, + .zqcs_rotate = 1, + .aprebit = 10, + .cmd_age_cnt = 255, + .age_cnt = 255, + .q_fullness = 0, + .odt_rd_mapcs0 = 1, + .odt_wr_mapcs0 = 1, + .wlmrd = 40, + .wldqsen = 25, + }; + + static const iomux_v3_cfg_t pcm052_pads[] = { + PCM052_VF610_PAD_DDR_A15__DDR_A_15, + PCM052_VF610_PAD_DDR_A14__DDR_A_14, + PCM052_VF610_PAD_DDR_A13__DDR_A_13, + PCM052_VF610_PAD_DDR_A12__DDR_A_12, + PCM052_VF610_PAD_DDR_A11__DDR_A_11, + PCM052_VF610_PAD_DDR_A10__DDR_A_10, + PCM052_VF610_PAD_DDR_A9__DDR_A_9, + PCM052_VF610_PAD_DDR_A8__DDR_A_8, + PCM052_VF610_PAD_DDR_A7__DDR_A_7, + PCM052_VF610_PAD_DDR_A6__DDR_A_6, + PCM052_VF610_PAD_DDR_A5__DDR_A_5, + PCM052_VF610_PAD_DDR_A4__DDR_A_4, + PCM052_VF610_PAD_DDR_A3__DDR_A_3, + PCM052_VF610_PAD_DDR_A2__DDR_A_2, + PCM052_VF610_PAD_DDR_A1__DDR_A_1, + PCM052_VF610_PAD_DDR_A0__DDR_A_0, + PCM052_VF610_PAD_DDR_BA2__DDR_BA_2, + PCM052_VF610_PAD_DDR_BA1__DDR_BA_1, + PCM052_VF610_PAD_DDR_BA0__DDR_BA_0, + PCM052_VF610_PAD_DDR_CAS__DDR_CAS_B, + PCM052_VF610_PAD_DDR_CKE__DDR_CKE_0, + PCM052_VF610_PAD_DDR_CLK__DDR_CLK_0, + PCM052_VF610_PAD_DDR_CS__DDR_CS_B_0, + PCM052_VF610_PAD_DDR_D15__DDR_D_15, + PCM052_VF610_PAD_DDR_D14__DDR_D_14, + PCM052_VF610_PAD_DDR_D13__DDR_D_13, + PCM052_VF610_PAD_DDR_D12__DDR_D_12, + PCM052_VF610_PAD_DDR_D11__DDR_D_11, + PCM052_VF610_PAD_DDR_D10__DDR_D_10, + PCM052_VF610_PAD_DDR_D9__DDR_D_9, + PCM052_VF610_PAD_DDR_D8__DDR_D_8, + PCM052_VF610_PAD_DDR_D7__DDR_D_7, + PCM052_VF610_PAD_DDR_D6__DDR_D_6, + PCM052_VF610_PAD_DDR_D5__DDR_D_5, + PCM052_VF610_PAD_DDR_D4__DDR_D_4, + PCM052_VF610_PAD_DDR_D3__DDR_D_3, + PCM052_VF610_PAD_DDR_D2__DDR_D_2, + PCM052_VF610_PAD_DDR_D1__DDR_D_1, + PCM052_VF610_PAD_DDR_D0__DDR_D_0, + PCM052_VF610_PAD_DDR_DQM1__DDR_DQM_1, + PCM052_VF610_PAD_DDR_DQM0__DDR_DQM_0, + PCM052_VF610_PAD_DDR_DQS1__DDR_DQS_1, + PCM052_VF610_PAD_DDR_DQS0__DDR_DQS_0, + PCM052_VF610_PAD_DDR_RAS__DDR_RAS_B, + PCM052_VF610_PAD_DDR_WE__DDR_WE_B, + PCM052_VF610_PAD_DDR_ODT1__DDR_ODT_0, + PCM052_VF610_PAD_DDR_ODT0__DDR_ODT_1, + PCM052_VF610_PAD_DDR_DDRBYTE1__DDR_DDRBYTE1, + PCM052_VF610_PAD_DDR_DDRBYTE0__DDR_DDRBYTE0, + PCM052_VF610_PAD_DDR_RESETB, + }; + + imx_iomux_v3_setup_multiple_pads(pcm052_pads, ARRAY_SIZE(pcm052_pads)); + + ddrmc_ctrl_init_ddr3(&pcm052_ddr_timings, pcm052_cr_settings, + pcm052_phy_settings, 1, 2); + + gd->ram_size = get_ram_size((void *)PHYS_SDRAM, PHYS_SDRAM_SIZE); + + return 0; +} + +static void setup_iomux_uart(void) +{ + static const iomux_v3_cfg_t uart1_pads[] = { + NEW_PAD_CTRL(VF610_PAD_PTB4__UART1_TX, VF610_UART_PAD_CTRL), + NEW_PAD_CTRL(VF610_PAD_PTB5__UART1_RX, VF610_UART_PAD_CTRL), + }; + + imx_iomux_v3_setup_multiple_pads(uart1_pads, ARRAY_SIZE(uart1_pads)); +} + +#define ENET_PAD_CTRL (PAD_CTL_PUS_47K_UP | PAD_CTL_SPEED_HIGH | \ + PAD_CTL_DSE_50ohm | PAD_CTL_OBE_IBE_ENABLE) + +static void setup_iomux_enet(void) +{ + static const iomux_v3_cfg_t enet0_pads[] = { + NEW_PAD_CTRL(VF610_PAD_PTA6__RMII0_CLKIN, ENET_PAD_CTRL), + NEW_PAD_CTRL(VF610_PAD_PTC1__RMII0_MDIO, ENET_PAD_CTRL), + NEW_PAD_CTRL(VF610_PAD_PTC0__RMII0_MDC, ENET_PAD_CTRL), + NEW_PAD_CTRL(VF610_PAD_PTC2__RMII0_CRS_DV, ENET_PAD_CTRL), + NEW_PAD_CTRL(VF610_PAD_PTC3__RMII0_RD1, ENET_PAD_CTRL), + NEW_PAD_CTRL(VF610_PAD_PTC4__RMII0_RD0, ENET_PAD_CTRL), + NEW_PAD_CTRL(VF610_PAD_PTC5__RMII0_RXER, ENET_PAD_CTRL), + NEW_PAD_CTRL(VF610_PAD_PTC6__RMII0_TD1, ENET_PAD_CTRL), + NEW_PAD_CTRL(VF610_PAD_PTC7__RMII0_TD0, ENET_PAD_CTRL), + NEW_PAD_CTRL(VF610_PAD_PTC8__RMII0_TXEN, ENET_PAD_CTRL), + }; + + imx_iomux_v3_setup_multiple_pads(enet0_pads, ARRAY_SIZE(enet0_pads)); +} + +/* + * I2C2 is the only I2C used, on pads PTA22/PTA23. + */ + +static void setup_iomux_i2c(void) +{ + static const iomux_v3_cfg_t i2c_pads[] = { + VF610_PAD_PTA22__I2C2_SCL, + VF610_PAD_PTA23__I2C2_SDA, + }; + + imx_iomux_v3_setup_multiple_pads(i2c_pads, ARRAY_SIZE(i2c_pads)); +} + +#ifdef CONFIG_NAND_VF610_NFC +static void setup_iomux_nfc(void) +{ + static const iomux_v3_cfg_t nfc_pads[] = { + VF610_PAD_PTD31__NF_IO15, + VF610_PAD_PTD30__NF_IO14, + VF610_PAD_PTD29__NF_IO13, + VF610_PAD_PTD28__NF_IO12, + VF610_PAD_PTD27__NF_IO11, + VF610_PAD_PTD26__NF_IO10, + VF610_PAD_PTD25__NF_IO9, + VF610_PAD_PTD24__NF_IO8, + VF610_PAD_PTD23__NF_IO7, + VF610_PAD_PTD22__NF_IO6, + VF610_PAD_PTD21__NF_IO5, + VF610_PAD_PTD20__NF_IO4, + VF610_PAD_PTD19__NF_IO3, + VF610_PAD_PTD18__NF_IO2, + VF610_PAD_PTD17__NF_IO1, + VF610_PAD_PTD16__NF_IO0, + VF610_PAD_PTB24__NF_WE_B, + VF610_PAD_PTB25__NF_CE0_B, + VF610_PAD_PTB27__NF_RE_B, + VF610_PAD_PTC26__NF_RB_B, + VF610_PAD_PTC27__NF_ALE, + VF610_PAD_PTC28__NF_CLE + }; + + imx_iomux_v3_setup_multiple_pads(nfc_pads, ARRAY_SIZE(nfc_pads)); +} +#endif + +static void setup_iomux_qspi(void) +{ + static const iomux_v3_cfg_t qspi0_pads[] = { + VF610_PAD_PTD0__QSPI0_A_QSCK, + VF610_PAD_PTD1__QSPI0_A_CS0, + VF610_PAD_PTD2__QSPI0_A_DATA3, + VF610_PAD_PTD3__QSPI0_A_DATA2, + VF610_PAD_PTD4__QSPI0_A_DATA1, + VF610_PAD_PTD5__QSPI0_A_DATA0, + VF610_PAD_PTD7__QSPI0_B_QSCK, + VF610_PAD_PTD8__QSPI0_B_CS0, + VF610_PAD_PTD9__QSPI0_B_DATA3, + VF610_PAD_PTD10__QSPI0_B_DATA2, + VF610_PAD_PTD11__QSPI0_B_DATA1, + VF610_PAD_PTD12__QSPI0_B_DATA0, + }; + + imx_iomux_v3_setup_multiple_pads(qspi0_pads, ARRAY_SIZE(qspi0_pads)); +} + +#define ESDHC_PAD_CTRL (PAD_CTL_PUS_100K_UP | PAD_CTL_SPEED_HIGH | \ + PAD_CTL_DSE_20ohm | PAD_CTL_OBE_IBE_ENABLE) + +struct fsl_esdhc_cfg esdhc_cfg[1] = { + {ESDHC1_BASE_ADDR}, +}; + +int board_mmc_getcd(struct mmc *mmc) +{ + /* eSDHC1 is always present */ + return 1; +} + +int board_mmc_init(bd_t *bis) +{ + static const iomux_v3_cfg_t esdhc1_pads[] = { + NEW_PAD_CTRL(VF610_PAD_PTA24__ESDHC1_CLK, ESDHC_PAD_CTRL), + NEW_PAD_CTRL(VF610_PAD_PTA25__ESDHC1_CMD, ESDHC_PAD_CTRL), + NEW_PAD_CTRL(VF610_PAD_PTA26__ESDHC1_DAT0, ESDHC_PAD_CTRL), + NEW_PAD_CTRL(VF610_PAD_PTA27__ESDHC1_DAT1, ESDHC_PAD_CTRL), + NEW_PAD_CTRL(VF610_PAD_PTA28__ESDHC1_DAT2, ESDHC_PAD_CTRL), + NEW_PAD_CTRL(VF610_PAD_PTA29__ESDHC1_DAT3, ESDHC_PAD_CTRL), + }; + + esdhc_cfg[0].sdhc_clk = mxc_get_clock(MXC_ESDHC_CLK); + + imx_iomux_v3_setup_multiple_pads( + esdhc1_pads, ARRAY_SIZE(esdhc1_pads)); + + return fsl_esdhc_initialize(bis, &esdhc_cfg[0]); +} + +static void clock_init(void) +{ + struct ccm_reg *ccm = (struct ccm_reg *)CCM_BASE_ADDR; + struct anadig_reg *anadig = (struct anadig_reg *)ANADIG_BASE_ADDR; + + clrsetbits_le32(&ccm->ccgr0, CCM_REG_CTRL_MASK, + CCM_CCGR0_UART1_CTRL_MASK); + clrsetbits_le32(&ccm->ccgr1, CCM_REG_CTRL_MASK, + CCM_CCGR1_PIT_CTRL_MASK | CCM_CCGR1_WDOGA5_CTRL_MASK); + clrsetbits_le32(&ccm->ccgr2, CCM_REG_CTRL_MASK, + CCM_CCGR2_IOMUXC_CTRL_MASK | CCM_CCGR2_PORTA_CTRL_MASK | + CCM_CCGR2_PORTB_CTRL_MASK | CCM_CCGR2_PORTC_CTRL_MASK | + CCM_CCGR2_PORTD_CTRL_MASK | CCM_CCGR2_PORTE_CTRL_MASK | + CCM_CCGR2_QSPI0_CTRL_MASK); + clrsetbits_le32(&ccm->ccgr3, CCM_REG_CTRL_MASK, + CCM_CCGR3_ANADIG_CTRL_MASK | CCM_CCGR3_SCSC_CTRL_MASK); + clrsetbits_le32(&ccm->ccgr4, CCM_REG_CTRL_MASK, + CCM_CCGR4_WKUP_CTRL_MASK | CCM_CCGR4_CCM_CTRL_MASK | + CCM_CCGR4_GPC_CTRL_MASK); + clrsetbits_le32(&ccm->ccgr6, CCM_REG_CTRL_MASK, + CCM_CCGR6_OCOTP_CTRL_MASK | CCM_CCGR6_DDRMC_CTRL_MASK); + clrsetbits_le32(&ccm->ccgr7, CCM_REG_CTRL_MASK, + CCM_CCGR7_SDHC1_CTRL_MASK); + clrsetbits_le32(&ccm->ccgr9, CCM_REG_CTRL_MASK, + CCM_CCGR9_FEC0_CTRL_MASK | CCM_CCGR9_FEC1_CTRL_MASK); + clrsetbits_le32(&ccm->ccgr10, CCM_REG_CTRL_MASK, + CCM_CCGR10_NFC_CTRL_MASK | CCM_CCGR10_I2C2_CTRL_MASK); + + clrsetbits_le32(&anadig->pll2_ctrl, ANADIG_PLL2_CTRL_POWERDOWN, + ANADIG_PLL2_CTRL_ENABLE | ANADIG_PLL2_CTRL_DIV_SELECT); + clrsetbits_le32(&anadig->pll1_ctrl, ANADIG_PLL1_CTRL_POWERDOWN, + ANADIG_PLL1_CTRL_ENABLE | ANADIG_PLL1_CTRL_DIV_SELECT); + + clrsetbits_le32(&ccm->ccr, CCM_CCR_OSCNT_MASK, + CCM_CCR_FIRC_EN | CCM_CCR_OSCNT(5)); + clrsetbits_le32(&ccm->ccsr, CCM_REG_CTRL_MASK, + CCM_CCSR_PLL1_PFD_CLK_SEL(3) | CCM_CCSR_PLL2_PFD4_EN | + CCM_CCSR_PLL2_PFD3_EN | CCM_CCSR_PLL2_PFD2_EN | + CCM_CCSR_PLL2_PFD1_EN | CCM_CCSR_PLL1_PFD4_EN | + CCM_CCSR_PLL1_PFD3_EN | CCM_CCSR_PLL1_PFD2_EN | + CCM_CCSR_PLL1_PFD1_EN | CCM_CCSR_DDRC_CLK_SEL(1) | + CCM_CCSR_FAST_CLK_SEL(1) | CCM_CCSR_SYS_CLK_SEL(4)); + clrsetbits_le32(&ccm->cacrr, CCM_REG_CTRL_MASK, + CCM_CACRR_IPG_CLK_DIV(1) | CCM_CACRR_BUS_CLK_DIV(2) | + CCM_CACRR_ARM_CLK_DIV(0)); + clrsetbits_le32(&ccm->cscmr1, CCM_REG_CTRL_MASK, + CCM_CSCMR1_ESDHC1_CLK_SEL(3) | + CCM_CSCMR1_QSPI0_CLK_SEL(3) | + CCM_CSCMR1_NFC_CLK_SEL(0)); + clrsetbits_le32(&ccm->cscdr1, CCM_REG_CTRL_MASK, + CCM_CSCDR1_RMII_CLK_EN); + clrsetbits_le32(&ccm->cscdr2, CCM_REG_CTRL_MASK, + CCM_CSCDR2_ESDHC1_EN | CCM_CSCDR2_ESDHC1_CLK_DIV(0) | + CCM_CSCDR2_NFC_EN); + clrsetbits_le32(&ccm->cscdr3, CCM_REG_CTRL_MASK, + CCM_CSCDR3_QSPI0_EN | CCM_CSCDR3_QSPI0_DIV(1) | + CCM_CSCDR3_QSPI0_X2_DIV(1) | + CCM_CSCDR3_QSPI0_X4_DIV(3) | + CCM_CSCDR3_NFC_PRE_DIV(5)); + clrsetbits_le32(&ccm->cscmr2, CCM_REG_CTRL_MASK, + CCM_CSCMR2_RMII_CLK_SEL(0)); +} + +static void mscm_init(void) +{ + struct mscm_ir *mscmir = (struct mscm_ir *)MSCM_IR_BASE_ADDR; + int i; + + for (i = 0; i < MSCM_IRSPRC_NUM; i++) + writew(MSCM_IRSPRC_CP0_EN, &mscmir->irsprc[i]); +} + +int board_phy_config(struct phy_device *phydev) +{ + if (phydev->drv->config) + phydev->drv->config(phydev); + + return 0; +} + +int board_early_init_f(void) +{ + clock_init(); + mscm_init(); + setup_iomux_uart(); + setup_iomux_enet(); + setup_iomux_i2c(); + setup_iomux_qspi(); + setup_iomux_nfc(); + + return 0; +} + +int board_init(void) +{ + struct scsc_reg *scsc = (struct scsc_reg *)SCSC_BASE_ADDR; + + /* address of boot parameters */ + gd->bd->bi_boot_params = PHYS_SDRAM + 0x100; + + /* + * Enable external 32K Oscillator + * + * The internal clock experiences significant drift + * so we must use the external oscillator in order + * to maintain correct time in the hwclock + */ + setbits_le32(&scsc->sosc_ctr, SCSC_SOSC_CTR_SOSC_EN); + + return 0; +} + +int checkboard(void) +{ + puts("Board: PCM-052\n"); + + return 0; +} diff --git a/configs/pcm052_defconfig b/configs/pcm052_defconfig new file mode 100644 index 0000000..e8dc402 --- /dev/null +++ b/configs/pcm052_defconfig @@ -0,0 +1,6 @@ +CONFIG_ARM=y +CONFIG_TARGET_PCM052=y +CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/phytec/pcm052/imximage.cfg,ENV_IS_IN_NAND" +CONFIG_NAND_VF610_NFC=y +CONFIG_SYS_NAND_BUSWIDTH_16BIT=y +CONFIG_SYS_NAND_VF610_NFC_45_ECC_BYTES=y diff --git a/include/configs/pcm052.h b/include/configs/pcm052.h new file mode 100644 index 0000000..903f94c --- /dev/null +++ b/include/configs/pcm052.h @@ -0,0 +1,231 @@ +/* + * Copyright 2013 Freescale Semiconductor, Inc. + * + * Configuration settings for the phytec PCM-052 SoM. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +#include <asm/arch/imx-regs.h> + +#define CONFIG_VF610 + +#define CONFIG_SYS_GENERIC_BOARD +#define CONFIG_DISPLAY_CPUINFO +#define CONFIG_DISPLAY_BOARDINFO +#define CONFIG_SYS_THUMB_BUILD + +#define CONFIG_SKIP_LOWLEVEL_INIT + +/* Enable passing of ATAGs */ +#define CONFIG_CMDLINE_TAG + +/* Size of malloc() pool */ +#define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 2 * 1024 * 1024) + +#define CONFIG_BOARD_EARLY_INIT_F + +#define CONFIG_FSL_LPUART +#define LPUART_BASE UART1_BASE + +/* Allow to overwrite serial and ethaddr */ +#define CONFIG_ENV_OVERWRITE +#define CONFIG_SYS_UART_PORT (1) +#define CONFIG_BAUDRATE 115200 + +#undef CONFIG_CMD_IMLS + +/* NAND support */ +#define CONFIG_CMD_NAND +#define CONFIG_CMD_NAND_TRIMFFS +#define CONFIG_SYS_NAND_ONFI_DETECTION + +#ifdef CONFIG_CMD_NAND +#define CONFIG_USE_ARCH_MEMCPY +#define CONFIG_SYS_MAX_NAND_DEVICE 1 +#define CONFIG_SYS_NAND_BASE NFC_BASE_ADDR + +#define CONFIG_JFFS2_NAND + +/* UBI */ +#define CONFIG_CMD_UBI +#define CONFIG_CMD_UBIFS +#define CONFIG_RBTREE +#define CONFIG_LZO + +/* Dynamic MTD partition support */ +#define CONFIG_CMD_MTDPARTS +#define CONFIG_MTD_PARTITIONS +#define CONFIG_MTD_DEVICE +#define MTDIDS_DEFAULT "nand0=NAND,nor0=qspi0-a,nor1=qspi0-b" +#define MTDPARTS_DEFAULT "mtdparts=NAND:256k(spare)"\ + ",384k(bootloader)"\ + ",128k(env1)"\ + ",128k(env2)"\ + ",3840k(kernel)"\ + ",-(rootfs)"\ + ",qspi0-a:-(jffs2),qspio0-b:-(jffs2)" +#endif + +#define CONFIG_MMC +#define CONFIG_FSL_ESDHC +#define CONFIG_SYS_FSL_ESDHC_ADDR 0 +#define CONFIG_SYS_FSL_ESDHC_NUM 1 + +/*#define CONFIG_ESDHC_DETECT_USE_EXTERN_IRQ1*/ +#define CONFIG_SYS_FSL_ERRATUM_ESDHC135 +#define CONFIG_SYS_FSL_ERRATUM_ESDHC111 +#define CONFIG_SYS_FSL_ERRATUM_ESDHC_A001 + +#define CONFIG_CMD_MMC +#define CONFIG_GENERIC_MMC +#define CONFIG_CMD_FAT +#define CONFIG_DOS_PARTITION + +#define CONFIG_CMD_PING +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_MII +#define CONFIG_FEC_MXC +#define CONFIG_MII +#define IMX_FEC_BASE ENET_BASE_ADDR +#define CONFIG_FEC_XCV_TYPE RMII +#define CONFIG_FEC_MXC_PHYADDR 0 +#define CONFIG_PHYLIB +#define CONFIG_PHY_MICREL + +/* QSPI Configs*/ +#define CONFIG_FSL_QSPI + +#ifdef CONFIG_FSL_QSPI +#define CONFIG_CMD_SF +#define CONFIG_SPI_FLASH +#define CONFIG_SPI_FLASH_STMICRO +#define FSL_QSPI_FLASH_SIZE (1 << 24) +#define FSL_QSPI_FLASH_NUM 2 +#define CONFIG_SYS_FSL_QSPI_LE +#endif + +/* I2C Configs */ +#define CONFIG_CMD_I2C +#define CONFIG_SYS_I2C +#define CONFIG_SYS_I2C_MXC_I2C3 +#define CONFIG_SYS_I2C_MXC + +/* RTC (actually an RV-4162 but M41T62-compatible) */ +#define CONFIG_CMD_DATE +#define CONFIG_RTC_M41T62 +#define CONFIG_SYS_I2C_RTC_ADDR 0x68 +#define CONFIG_SYS_RTC_BUS_NUM 2 + +/* EEPROM (24FC256) */ +#define CONFIG_CMD_EEPROM +#define CONFIG_SYS_I2C_EEPROM_ADDR 0x50 +#define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 2 +#define CONFIG_SYS_I2C_EEPROM_BUS 2 + +#define CONFIG_BOOTDELAY 3 + +#define CONFIG_LOADADDR 0x82000000 + +/* We boot from the gfxRAM area of the OCRAM. */ +#define CONFIG_SYS_TEXT_BASE 0x3f408000 +#define CONFIG_BOARD_SIZE_LIMIT 524288 + +#define CONFIG_BOOTCOMMAND "run bootcmd_sd" +#define CONFIG_EXTRA_ENV_SETTINGS \ + "bootfile=uImage\0" \ + "bootargs_base=setenv bootargs rw mem=256M " \ + "console=ttymxc1,115200n8\0" \ + "bootargs_sd=setenv bootargs ${bootargs} " \ + "root=/dev/mmcblk0p2 rootwait\0" \ + "bootargs_net=setenv bootargs ${bootargs} root=/dev/nfs ip=dhcp " \ + "nfsroot=${serverip}:${nfs_root},v3,tcp\0" \ + "bootargs_nand=setenv bootargs ${bootargs} " \ + "root=/dev/mtdblock2 rootfstype=jffs2\0" \ + "bootargs_mtd=setenv bootargs ${bootargs} ${mtdparts}\0" \ + "bootcmd_sd=run bootargs_base bootargs_sd bootargs_mtd; mmc rescan; " \ + "fatload mmc 0:1 ${loadaddr} ${bootfile}; bootm ${loadaddr}\0" \ + "bootcmd_net=run bootargs_base bootargs_net bootargs_mtd; " \ + "tftpboot ${loadaddr} ${tftploc}${bootfile}; bootm\0" \ + "bootcmd_nand='run bootargs_base bootargs_nand bootargs_mtd; " \ + "nand read ${loadaddr} 0x000E0000 0x3C0000; " \ + "bootm ${loadaddr}\0" \ + "tftploc=/path/to/tftp/directory/\0" \ + "nfs_root=/path/to/nfs/root\0" \ + "mtdparts=" MTDPARTS_DEFAULT "\0" \ + "update_kernel_from_sd=mw.b $(loadaddr) 0xff 0x3C0000; " \ + "mmc rescan; fatload mmc 0:2 ${loadaddr} ${bootfile}; " \ + "nand erase 0xE0000 0x3C0000; " \ + "nand write.i ${loadaddr} 0xE0000 0x3C0000\0" \ + "update_rootfs_from_tftp=mw.b ${loadaddr} 0xff 0x8F20000; " \ + "tftp ${loadaddr} ${tftp}${filesys}; " \ + "nand erase 0x4A0000 0x8F20000; " \ + "nand write.i ${loadaddr} 0x4A0000 0x8F20000\0" \ + "filesys=rootfs.jffs2\0" + +/* miscellaneous commands */ +#define CONFIG_CMD_ELF + +/* Miscellaneous configurable options */ +#define CONFIG_SYS_LONGHELP /* undef to save memory */ +#define CONFIG_SYS_HUSH_PARSER /* use "hush" command parser */ +#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " +#define CONFIG_AUTO_COMPLETE +#define CONFIG_CMDLINE_EDITING +#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ +#define CONFIG_SYS_PBSIZE \ + (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT) + 16) +#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE + +#define CONFIG_CMD_MEMTEST +#define CONFIG_SYS_MEMTEST_START 0x80010000 +#define CONFIG_SYS_MEMTEST_END 0x87C00000 + +#define CONFIG_SYS_LOAD_ADDR CONFIG_LOADADDR + +/* + * Stack sizes + * The stack sizes are set up in start.S using the settings below + */ +#define CONFIG_STACKSIZE (128 * 1024) /* regular stack */ + +/* Physical memory map */ +#define CONFIG_NR_DRAM_BANKS 1 +#define PHYS_SDRAM (0x80000000) +#define PHYS_SDRAM_SIZE (256 * 1024 * 1024) + +#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM +#define CONFIG_SYS_INIT_RAM_ADDR IRAM_BASE_ADDR +#define CONFIG_SYS_INIT_RAM_SIZE IRAM_SIZE + +#define CONFIG_SYS_INIT_SP_OFFSET \ + (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) +#define CONFIG_SYS_INIT_SP_ADDR \ + (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET) + +/* FLASH and environment organization */ +#define CONFIG_SYS_NO_FLASH + +#ifdef CONFIG_ENV_IS_IN_MMC +#define CONFIG_ENV_SIZE (8 * 1024) + +#define CONFIG_ENV_OFFSET (12 * 64 * 1024) +#define CONFIG_SYS_MMC_ENV_DEV 0 +#endif + +#ifdef CONFIG_ENV_IS_IN_NAND +#define CONFIG_ENV_SECT_SIZE (128 * 1024) +#define CONFIG_ENV_SIZE (8 * 1024) +#define CONFIG_ENV_OFFSET 0x80000 +#define CONFIG_ENV_SIZE_REDUND (8 * 1024) +#define CONFIG_ENV_OFFSET_REDUND 0xA0000 +#endif + +#define CONFIG_OF_LIBFDT +#define CONFIG_CMD_BOOTZ + +#endif
- NFC (NAND FLASH)
- MMC
- I2C (only bus 2)
- I2C RTC
- I2C EEPROM
- FEC
Patch-series: 2
Signed-off-by: Albert ARIBAUD (3ADEV) albert.aribaud@3adev.fr
Applied to u-boot-imx, thanks!
Best regards, Stefano Babic
The VF610 DDRMC driver code contains settings which are board-specific. Move these out to boards so that new boards can define their own without having to modify the driver.
Stefano Babic
