[PATCH 0/5] Add support for a series of MikroTik CRS3xx switches
These patches add support for a series of MikroTik CRS3xx, 98DX3236 based switches.
Namely, support is added for: - MikroTik CRS305-1G-4S+ Bit variant - MikroTik CRS326-24G-2S+ (including the Bit variant) - MikroTik CRS328-4C-20S-4S+ (including the Bit variant)
The Bit board variant is added for each of the boards. These boards were modified to use a bigger Macronix flash.
This work is a follow-up on the previous patch, which prepared the board support for CRS3xx-98DX3236 boards.
Luka Kovacic (5): arm: mvebu: Add CRS305-1G-4S Bit board arm: mvebu: Add CRS326-24G-2S board arm: mvebu: Add CRS328-4C-20S-4S board arm: mvebu: crs3xx-98dx3236: Add a maintainer arm: mvebu: Update CRS305-1G-4S board flash layout
arch/arm/dts/Makefile | 5 + arch/arm/dts/armada-xp-crs305-1g-4s-bit.dts | 43 +++++++ arch/arm/dts/armada-xp-crs305-1g-4s.dtsi | 10 +- arch/arm/dts/armada-xp-crs326-24g-2s-bit.dts | 43 +++++++ .../dts/armada-xp-crs326-24g-2s-u-boot.dtsi | 13 +++ arch/arm/dts/armada-xp-crs326-24g-2s.dts | 17 +++ arch/arm/dts/armada-xp-crs326-24g-2s.dtsi | 110 ++++++++++++++++++ .../dts/armada-xp-crs328-4c-20s-4s-bit.dts | 43 +++++++ .../armada-xp-crs328-4c-20s-4s-u-boot.dtsi | 13 +++ arch/arm/dts/armada-xp-crs328-4c-20s-4s.dts | 17 +++ arch/arm/dts/armada-xp-crs328-4c-20s-4s.dtsi | 110 ++++++++++++++++++ board/mikrotik/crs3xx-98dx3236/MAINTAINERS | 22 ++++ configs/crs305-1g-4s-bit_defconfig | 54 +++++++++ configs/crs305-1g-4s_defconfig | 9 +- configs/crs326-24g-2s-bit_defconfig | 54 +++++++++ configs/crs326-24g-2s_defconfig | 54 +++++++++ configs/crs328-4c-20s-4s-bit_defconfig | 54 +++++++++ configs/crs328-4c-20s-4s_defconfig | 54 +++++++++ 18 files changed, 719 insertions(+), 6 deletions(-) create mode 100644 arch/arm/dts/armada-xp-crs305-1g-4s-bit.dts create mode 100644 arch/arm/dts/armada-xp-crs326-24g-2s-bit.dts create mode 100644 arch/arm/dts/armada-xp-crs326-24g-2s-u-boot.dtsi create mode 100644 arch/arm/dts/armada-xp-crs326-24g-2s.dts create mode 100644 arch/arm/dts/armada-xp-crs326-24g-2s.dtsi create mode 100644 arch/arm/dts/armada-xp-crs328-4c-20s-4s-bit.dts create mode 100644 arch/arm/dts/armada-xp-crs328-4c-20s-4s-u-boot.dtsi create mode 100644 arch/arm/dts/armada-xp-crs328-4c-20s-4s.dts create mode 100644 arch/arm/dts/armada-xp-crs328-4c-20s-4s.dtsi create mode 100644 configs/crs305-1g-4s-bit_defconfig create mode 100644 configs/crs326-24g-2s-bit_defconfig create mode 100644 configs/crs326-24g-2s_defconfig create mode 100644 configs/crs328-4c-20s-4s-bit_defconfig create mode 100644 configs/crs328-4c-20s-4s_defconfig
MikroTik CRS305-1G-4S Bit board has a switch chip with an integrated Marvell Prestera 98DX3236 CPU.
The Bit board variant is added, which has a bigger Macronix flash.
Add basic U-Boot, UART and Winbond SPI flash support.
Signed-off-by: Luka Kovacic luka.kovacic@sartura.hr Cc: Luka Perkov luka.perkov@sartura.hr Cc: Jakov Petrina jakov.petrina@sartura.hr --- arch/arm/dts/Makefile | 1 + arch/arm/dts/armada-xp-crs305-1g-4s-bit.dts | 43 ++++++++++++++++ board/mikrotik/crs3xx-98dx3236/MAINTAINERS | 3 ++ configs/crs305-1g-4s-bit_defconfig | 54 +++++++++++++++++++++ 4 files changed, 101 insertions(+) create mode 100644 arch/arm/dts/armada-xp-crs305-1g-4s-bit.dts create mode 100644 configs/crs305-1g-4s-bit_defconfig
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index cee10f533f..72e1f4fa20 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -213,6 +213,7 @@ dtb-$(CONFIG_ARCH_MVEBU) += \ armada-8040-db.dtb \ armada-8040-mcbin.dtb \ armada-xp-crs305-1g-4s.dtb \ + armada-xp-crs305-1g-4s-bit.dtb \ armada-xp-db-xc3-24g4xg.dtb \ armada-xp-gp.dtb \ armada-xp-maxbcm.dtb \ diff --git a/arch/arm/dts/armada-xp-crs305-1g-4s-bit.dts b/arch/arm/dts/armada-xp-crs305-1g-4s-bit.dts new file mode 100644 index 0000000000..059bf48aeb --- /dev/null +++ b/arch/arm/dts/armada-xp-crs305-1g-4s-bit.dts @@ -0,0 +1,43 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Device Tree file for MikroTik CRS305-1G-4S+ Bit board + * + * Copyright (C) 2020 Sartura Ltd. + * Author: Luka Kovacic luka.kovacic@sartura.hr + */ + +#include "armada-xp-crs305-1g-4s.dtsi" + +/ { + model = "MikroTik CRS305-1G-4S+ Bit"; +}; + +&spi0 { + status = "okay"; + + spi-flash@0 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "spi-flash", "jedec,spi-nor"; + reg = <0>; /* Chip select 0 */ + spi-max-frequency = <108000000>; + m25p,fast-read; + + partition@u-boot { + reg = <0x00000000 0x001f0000>; + label = "u-boot"; + }; + partition@u-boot-env { + reg = <0x001f0000 0x00010000>; + label = "u-boot-env"; + }; + partition@ubi1 { + reg = <0x00200000 0x03f00000>; + label = "ubi1"; + }; + partition@ubi2 { + reg = <0x04100000 0x03f00000>; + label = "ubi2"; + }; + }; +}; diff --git a/board/mikrotik/crs3xx-98dx3236/MAINTAINERS b/board/mikrotik/crs3xx-98dx3236/MAINTAINERS index 127e0eac60..d02584bb1d 100644 --- a/board/mikrotik/crs3xx-98dx3236/MAINTAINERS +++ b/board/mikrotik/crs3xx-98dx3236/MAINTAINERS @@ -6,6 +6,9 @@ F: include/configs/crs3xx-98dx3236.h
CRS305-1G-4S BOARD M: Luka Kovacic luka.kovacic@sartura.hr +M: Luka Perkov luka.perkov@sartura.hr S: Maintained F: configs/crs305-1g-4s_defconfig +F: configs/crs305-1g-4s-bit_defconfig F: arch/arm/dts/armada-xp-crs305-1g-4s.dts +F: arch/arm/dts/armada-xp-crs305-1g-4s-bit.dts diff --git a/configs/crs305-1g-4s-bit_defconfig b/configs/crs305-1g-4s-bit_defconfig new file mode 100644 index 0000000000..0ecf11acb2 --- /dev/null +++ b/configs/crs305-1g-4s-bit_defconfig @@ -0,0 +1,54 @@ +CONFIG_ARM=y +CONFIG_ARCH_CPU_INIT=y +CONFIG_ARCH_MVEBU=y +CONFIG_SYS_TEXT_BASE=0x00800000 +CONFIG_SYS_MALLOC_F_LEN=0x2000 +CONFIG_TARGET_CRS3XX_98DX3236=y +CONFIG_ENV_SIZE=0x10000 +CONFIG_ENV_SECT_SIZE=0x10000 +CONFIG_ENV_OFFSET=0x1F0000 +CONFIG_BOOTCOUNT_BOOTLIMIT=3 +# CONFIG_EFI_LOADER is not set +CONFIG_BUILD_TARGET="u-boot.kwb" +CONFIG_USE_PREBOOT=y +CONFIG_SYS_CONSOLE_INFO_QUIET=y +CONFIG_HUSH_PARSER=y +CONFIG_AUTOBOOT_KEYED=y +CONFIG_AUTOBOOT_PROMPT="Autoboot in %d seconds, to stop use 's' key\n" +CONFIG_AUTOBOOT_STOP_STR="s" +CONFIG_AUTOBOOT_KEYED_CTRLC=y +CONFIG_CMD_BOOTZ=y +# CONFIG_CMD_FLASH is not set +# CONFIG_CMD_I2C is not set +CONFIG_CMD_SPI=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_UBI=y +CONFIG_CMD_FS_GENERIC=y +CONFIG_CMD_MTD=y +CONFIG_CMD_MTDPARTS=y +CONFIG_DEFAULT_DEVICE_TREE="armada-xp-crs305-1g-4s-bit" +CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_BLK=y +CONFIG_BOOTCOUNT_LIMIT=y +CONFIG_BOOTCOUNT_ENV=y +# CONFIG_DM_I2C is not set +# CONFIG_SYS_I2C_MVTWSI is not set +# CONFIG_MMC is not set +CONFIG_MTD=y +CONFIG_MTD_PARTITIONS=y +CONFIG_DM_MTD=y +CONFIG_DM_SPI_FLASH=y +CONFIG_SPI_FLASH_MTD=y +CONFIG_SPI_FLASH_SFDP_SUPPORT=y +CONFIG_SPI_FLASH_BAR=y +CONFIG_SPI_FLASH_MACRONIX=y +# CONFIG_SPI_FLASH_USE_4K_SECTORS is not set +CONFIG_FIT=y +CONFIG_FIT_ENABLE_SHA256_SUPPORT=y +CONFIG_FIT_VERBOSE=y +CONFIG_FIT_BEST_MATCH=y +CONFIG_PCI=y +CONFIG_PCI_MVEBU=y +CONFIG_SYS_NS16550=y +CONFIG_KIRKWOOD_SPI=y
Thanks, Stefan
- armada-xp-crs305-1g-4s-bit.dtb \ armada-xp-db-xc3-24g4xg.dtb \ armada-xp-gp.dtb \ armada-xp-maxbcm.dtb \
- Device Tree file for MikroTik CRS305-1G-4S+ Bit board
- Copyright (C) 2020 Sartura Ltd.
- Author: Luka Kovacic luka.kovacic@sartura.hr
- model = "MikroTik CRS305-1G-4S+ Bit";
+&spi0 {
- status = "okay";
- spi-flash@0 {
#size-cells = <1>;
m25p,fast-read;
partition@u-boot {
label = "u-boot";
partition@ubi1 {
label = "ubi1";
partition@ubi2 {
label = "ubi2";
Viele Grüße, Stefan
Applied to u-boot-marvell/master
Thanks, Stefan
Thanks, Stefan
+ partition@u-boot { + reg = <0x00000000 0x001f0000>; + label = "u-boot"; + }; + partition@u-boot-env { + reg = <0x001f0000 0x00010000>; + label = "u-boot-env"; + }; + partition@ubi1 { + reg = <0x00200000 0x03f00000>; + label = "ubi1"; + }; + partition@ubi2 { + reg = <0x04100000 0x03f00000>; + label = "ubi2"; + }; + }; +}; diff --git a/board/mikrotik/crs3xx-98dx3236/MAINTAINERS b/board/mikrotik/crs3xx-98dx3236/MAINTAINERS index 127e0eac60..d02584bb1d 100644 --- a/board/mikrotik/crs3xx-98dx3236/MAINTAINERS +++ b/board/mikrotik/crs3xx-98dx3236/MAINTAINERS @@ -6,6 +6,9 @@ F: include/configs/crs3xx-98dx3236.h CRS305-1G-4S BOARD M: Luka Kovacic luka.kovacic@sartura.hr +M: Luka Perkov luka.perkov@sartura.hr S: Maintained F: configs/crs305-1g-4s_defconfig +F: configs/crs305-1g-4s-bit_defconfig F: arch/arm/dts/armada-xp-crs305-1g-4s.dts +F: arch/arm/dts/armada-xp-crs305-1g-4s-bit.dts diff --git a/configs/crs305-1g-4s-bit_defconfig b/configs/crs305-1g-4s-bit_defconfig new file mode 100644 index 0000000000..0ecf11acb2 --- /dev/null +++ b/configs/crs305-1g-4s-bit_defconfig @@ -0,0 +1,54 @@ +CONFIG_ARM=y +CONFIG_ARCH_CPU_INIT=y +CONFIG_ARCH_MVEBU=y +CONFIG_SYS_TEXT_BASE=0x00800000 +CONFIG_SYS_MALLOC_F_LEN=0x2000 +CONFIG_TARGET_CRS3XX_98DX3236=y +CONFIG_ENV_SIZE=0x10000 +CONFIG_ENV_SECT_SIZE=0x10000 +CONFIG_ENV_OFFSET=0x1F0000 +CONFIG_BOOTCOUNT_BOOTLIMIT=3 +# CONFIG_EFI_LOADER is not set +CONFIG_BUILD_TARGET="u-boot.kwb" +CONFIG_USE_PREBOOT=y +CONFIG_SYS_CONSOLE_INFO_QUIET=y +CONFIG_HUSH_PARSER=y +CONFIG_AUTOBOOT_KEYED=y +CONFIG_AUTOBOOT_PROMPT="Autoboot in %d seconds, to stop use 's' key\n" +CONFIG_AUTOBOOT_STOP_STR="s" +CONFIG_AUTOBOOT_KEYED_CTRLC=y +CONFIG_CMD_BOOTZ=y +# CONFIG_CMD_FLASH is not set +# CONFIG_CMD_I2C is not set +CONFIG_CMD_SPI=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_UBI=y +CONFIG_CMD_FS_GENERIC=y +CONFIG_CMD_MTD=y +CONFIG_CMD_MTDPARTS=y +CONFIG_DEFAULT_DEVICE_TREE="armada-xp-crs305-1g-4s-bit" +CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_BLK=y +CONFIG_BOOTCOUNT_LIMIT=y +CONFIG_BOOTCOUNT_ENV=y +# CONFIG_DM_I2C is not set +# CONFIG_SYS_I2C_MVTWSI is not set +# CONFIG_MMC is not set +CONFIG_MTD=y +CONFIG_MTD_PARTITIONS=y +CONFIG_DM_MTD=y +CONFIG_DM_SPI_FLASH=y +CONFIG_SPI_FLASH_MTD=y +CONFIG_SPI_FLASH_SFDP_SUPPORT=y +CONFIG_SPI_FLASH_BAR=y +CONFIG_SPI_FLASH_MACRONIX=y +# CONFIG_SPI_FLASH_USE_4K_SECTORS is not set +CONFIG_FIT=y +CONFIG_FIT_ENABLE_SHA256_SUPPORT=y +CONFIG_FIT_VERBOSE=y +CONFIG_FIT_BEST_MATCH=y +CONFIG_PCI=y +CONFIG_PCI_MVEBU=y +CONFIG_SYS_NS16550=y +CONFIG_KIRKWOOD_SPI=y
Viele Grüße, Stefan
Viele Grüße, Stefan
MikroTik CRS326-24G-2S board has a switch chip with an integrated Marvell Prestera 98DX3236 CPU.
This commit includes two board variants, namely the factory default one and a Bit variant. The Bit board variant has a bigger Macronix flash.
Add basic U-Boot, UART and SPI flash support.
Signed-off-by: Luka Kovacic luka.kovacic@sartura.hr Cc: Luka Perkov luka.perkov@sartura.hr Cc: Jakov Petrina jakov.petrina@sartura.hr --- arch/arm/dts/Makefile | 2 + arch/arm/dts/armada-xp-crs326-24g-2s-bit.dts | 43 +++++++ .../dts/armada-xp-crs326-24g-2s-u-boot.dtsi | 13 +++ arch/arm/dts/armada-xp-crs326-24g-2s.dts | 17 +++ arch/arm/dts/armada-xp-crs326-24g-2s.dtsi | 110 ++++++++++++++++++ board/mikrotik/crs3xx-98dx3236/MAINTAINERS | 9 ++ configs/crs326-24g-2s-bit_defconfig | 54 +++++++++ configs/crs326-24g-2s_defconfig | 54 +++++++++ 8 files changed, 302 insertions(+) create mode 100644 arch/arm/dts/armada-xp-crs326-24g-2s-bit.dts create mode 100644 arch/arm/dts/armada-xp-crs326-24g-2s-u-boot.dtsi create mode 100644 arch/arm/dts/armada-xp-crs326-24g-2s.dts create mode 100644 arch/arm/dts/armada-xp-crs326-24g-2s.dtsi create mode 100644 configs/crs326-24g-2s-bit_defconfig create mode 100644 configs/crs326-24g-2s_defconfig
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 72e1f4fa20..9f8ca61f28 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -214,6 +214,8 @@ dtb-$(CONFIG_ARCH_MVEBU) += \ armada-8040-mcbin.dtb \ armada-xp-crs305-1g-4s.dtb \ armada-xp-crs305-1g-4s-bit.dtb \ + armada-xp-crs326-24g-2s.dtb \ + armada-xp-crs326-24g-2s-bit.dtb \ armada-xp-db-xc3-24g4xg.dtb \ armada-xp-gp.dtb \ armada-xp-maxbcm.dtb \ diff --git a/arch/arm/dts/armada-xp-crs326-24g-2s-bit.dts b/arch/arm/dts/armada-xp-crs326-24g-2s-bit.dts new file mode 100644 index 0000000000..b340eedf71 --- /dev/null +++ b/arch/arm/dts/armada-xp-crs326-24g-2s-bit.dts @@ -0,0 +1,43 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Device Tree file for MikroTik CRS326-24G-2S+ Bit board + * + * Copyright (C) 2020 Sartura Ltd. + * Author: Luka Kovacic luka.kovacic@sartura.hr + */ + +#include "armada-xp-crs326-24g-2s.dtsi" + +/ { + model = "MikroTik CRS326-24G-2S+ Bit"; +}; + +&spi0 { + status = "okay"; + + spi-flash@0 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "spi-flash", "jedec,spi-nor"; + reg = <0>; /* Chip select 0 */ + spi-max-frequency = <108000000>; + m25p,fast-read; + + partition@u-boot { + reg = <0x00000000 0x001f0000>; + label = "u-boot"; + }; + partition@u-boot-env { + reg = <0x001f0000 0x00010000>; + label = "u-boot-env"; + }; + partition@ubi1 { + reg = <0x00200000 0x03f00000>; + label = "ubi1"; + }; + partition@ubi2 { + reg = <0x04100000 0x03f00000>; + label = "ubi2"; + }; + }; +}; diff --git a/arch/arm/dts/armada-xp-crs326-24g-2s-u-boot.dtsi b/arch/arm/dts/armada-xp-crs326-24g-2s-u-boot.dtsi new file mode 100644 index 0000000000..8576a02730 --- /dev/null +++ b/arch/arm/dts/armada-xp-crs326-24g-2s-u-boot.dtsi @@ -0,0 +1,13 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) + +&uart0 { + u-boot,dm-pre-reloc; +}; + +&spi0 { + u-boot,dm-pre-reloc; + + spi-flash@0 { + u-boot,dm-pre-reloc; + }; +}; diff --git a/arch/arm/dts/armada-xp-crs326-24g-2s.dts b/arch/arm/dts/armada-xp-crs326-24g-2s.dts new file mode 100644 index 0000000000..83aef43f66 --- /dev/null +++ b/arch/arm/dts/armada-xp-crs326-24g-2s.dts @@ -0,0 +1,17 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Device Tree file for MikroTik CRS326-24G-2S+ board + * + * Copyright (C) 2020 Sartura Ltd. + * Author: Luka Kovacic luka.kovacic@sartura.hr + */ + +#include "armada-xp-crs326-24g-2s.dtsi" + +/ { + model = "MikroTik CRS326-24G-2S+"; +}; + +&spi0 { + status = "okay"; +}; diff --git a/arch/arm/dts/armada-xp-crs326-24g-2s.dtsi b/arch/arm/dts/armada-xp-crs326-24g-2s.dtsi new file mode 100644 index 0000000000..e50f3ead13 --- /dev/null +++ b/arch/arm/dts/armada-xp-crs326-24g-2s.dtsi @@ -0,0 +1,110 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Device Tree file for CRS326-24G-2S board + * + * Copyright (C) 2016 Allied Telesis Labs + * Copyright (C) 2020 Sartura Ltd. + * + * Based on armada-xp-db.dts + * + * Note: this Device Tree assumes that the bootloader has remapped the + * internal registers to 0xf1000000 (instead of the default + * 0xd0000000). The 0xf1000000 is the default used by the recent, + * DT-capable, U-Boot bootloaders provided by Marvell. Some earlier + * boards were delivered with an older version of the bootloader that + * left internal registers mapped at 0xd0000000. If you are in this + * situation, you should either update your bootloader (preferred + * solution) or the below Device Tree should be adjusted. + */ + +/dts-v1/; +#include "armada-xp-98dx3236.dtsi" +#include "armada-xp-crs326-24g-2s-u-boot.dtsi" + +/ { + model = "CRS326-24G-2S+"; + compatible = "marvell,armadaxp-98dx3236", "marvell,armadaxp-mv78260", "marvell,armadaxp", "marvell,armada-370-xp"; + + chosen { + stdout-path = "serial0:115200n8"; + bootargs = "console=ttyS0,115200 earlyprintk"; + }; + + aliases { + spi0 = &spi0; + }; + + memory { + device_type = "memory"; + reg = <0 0x00000000 0 0x20000000>; /* 512 MB */ + }; +}; + +&L2 { + arm,parity-enable; + marvell,ecc-enable; +}; + +&devbus_bootcs { + status = "okay"; + + /* Device Bus parameters are required */ + + /* Read parameters */ + devbus,bus-width = <16>; + devbus,turn-off-ps = <60000>; + devbus,badr-skew-ps = <0>; + devbus,acc-first-ps = <124000>; + devbus,acc-next-ps = <248000>; + devbus,rd-setup-ps = <0>; + devbus,rd-hold-ps = <0>; + + /* Write parameters */ + devbus,sync-enable = <0>; + devbus,wr-high-ps = <60000>; + devbus,wr-low-ps = <60000>; + devbus,ale-wr-ps = <60000>; +}; + +&uart0 { + status = "okay"; +}; + +&uart1 { + status = "okay"; +}; + +&i2c0 { + clock-frequency = <100000>; + status = "okay"; +}; + +&usb0 { + status = "okay"; +}; + +&spi0 { + status = "okay"; + + spi-flash@0 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "spi-flash", "jedec,spi-nor"; + reg = <0>; /* Chip select 0 */ + spi-max-frequency = <108000000>; + m25p,fast-read; + + partition@u-boot { + reg = <0x00000000 0x001f0000>; + label = "u-boot"; + }; + partition@u-boot-env { + reg = <0x001f0000 0x00010000>; + label = "u-boot-env"; + }; + partition@ubi1 { + reg = <0x00200000 0x00e00000>; + label = "ubi1"; + }; + }; +}; diff --git a/board/mikrotik/crs3xx-98dx3236/MAINTAINERS b/board/mikrotik/crs3xx-98dx3236/MAINTAINERS index d02584bb1d..7f01f4318e 100644 --- a/board/mikrotik/crs3xx-98dx3236/MAINTAINERS +++ b/board/mikrotik/crs3xx-98dx3236/MAINTAINERS @@ -12,3 +12,12 @@ F: configs/crs305-1g-4s_defconfig F: configs/crs305-1g-4s-bit_defconfig F: arch/arm/dts/armada-xp-crs305-1g-4s.dts F: arch/arm/dts/armada-xp-crs305-1g-4s-bit.dts + +CRS326-24G-2S BOARD +M: Luka Kovacic luka.kovacic@sartura.hr +M: Luka Perkov luka.perkov@sartura.hr +S: Maintained +F: configs/crs326-24g-2s_defconfig +F: configs/crs326-24g-2s-bit_defconfig +F: arch/arm/dts/armada-xp-crs326-24g-2s.dts +F: arch/arm/dts/armada-xp-crs326-24g-2s-bit.dts diff --git a/configs/crs326-24g-2s-bit_defconfig b/configs/crs326-24g-2s-bit_defconfig new file mode 100644 index 0000000000..18f2d34453 --- /dev/null +++ b/configs/crs326-24g-2s-bit_defconfig @@ -0,0 +1,54 @@ +CONFIG_ARM=y +CONFIG_ARCH_CPU_INIT=y +CONFIG_ARCH_MVEBU=y +CONFIG_SYS_TEXT_BASE=0x00800000 +CONFIG_SYS_MALLOC_F_LEN=0x2000 +CONFIG_TARGET_CRS3XX_98DX3236=y +CONFIG_ENV_SIZE=0x10000 +CONFIG_ENV_SECT_SIZE=0x10000 +CONFIG_ENV_OFFSET=0x1F0000 +CONFIG_BOOTCOUNT_BOOTLIMIT=3 +# CONFIG_EFI_LOADER is not set +CONFIG_BUILD_TARGET="u-boot.kwb" +CONFIG_USE_PREBOOT=y +CONFIG_SYS_CONSOLE_INFO_QUIET=y +CONFIG_HUSH_PARSER=y +CONFIG_AUTOBOOT_KEYED=y +CONFIG_AUTOBOOT_PROMPT="Autoboot in %d seconds, to stop use 's' key\n" +CONFIG_AUTOBOOT_STOP_STR="s" +CONFIG_AUTOBOOT_KEYED_CTRLC=y +CONFIG_CMD_BOOTZ=y +# CONFIG_CMD_FLASH is not set +# CONFIG_CMD_I2C is not set +CONFIG_CMD_SPI=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_UBI=y +CONFIG_CMD_FS_GENERIC=y +CONFIG_CMD_MTD=y +CONFIG_CMD_MTDPARTS=y +CONFIG_DEFAULT_DEVICE_TREE="armada-xp-crs326-24g-2s-bit" +CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_BLK=y +CONFIG_BOOTCOUNT_LIMIT=y +CONFIG_BOOTCOUNT_ENV=y +# CONFIG_DM_I2C is not set +# CONFIG_SYS_I2C_MVTWSI is not set +# CONFIG_MMC is not set +CONFIG_MTD=y +CONFIG_MTD_PARTITIONS=y +CONFIG_DM_MTD=y +CONFIG_DM_SPI_FLASH=y +CONFIG_SPI_FLASH_MTD=y +CONFIG_SPI_FLASH_SFDP_SUPPORT=y +CONFIG_SPI_FLASH_BAR=y +CONFIG_SPI_FLASH_MACRONIX=y +# CONFIG_SPI_FLASH_USE_4K_SECTORS is not set +CONFIG_FIT=y +CONFIG_FIT_ENABLE_SHA256_SUPPORT=y +CONFIG_FIT_VERBOSE=y +CONFIG_FIT_BEST_MATCH=y +CONFIG_PCI=y +CONFIG_PCI_MVEBU=y +CONFIG_SYS_NS16550=y +CONFIG_KIRKWOOD_SPI=y diff --git a/configs/crs326-24g-2s_defconfig b/configs/crs326-24g-2s_defconfig new file mode 100644 index 0000000000..fec7922f4c --- /dev/null +++ b/configs/crs326-24g-2s_defconfig @@ -0,0 +1,54 @@ +CONFIG_ARM=y +CONFIG_ARCH_CPU_INIT=y +CONFIG_ARCH_MVEBU=y +CONFIG_SYS_TEXT_BASE=0x00800000 +CONFIG_SYS_MALLOC_F_LEN=0x2000 +CONFIG_TARGET_CRS3XX_98DX3236=y +CONFIG_ENV_SIZE=0x10000 +CONFIG_ENV_SECT_SIZE=0x10000 +CONFIG_ENV_OFFSET=0x1F0000 +CONFIG_BOOTCOUNT_BOOTLIMIT=3 +# CONFIG_EFI_LOADER is not set +CONFIG_BUILD_TARGET="u-boot.kwb" +CONFIG_USE_PREBOOT=y +CONFIG_SYS_CONSOLE_INFO_QUIET=y +CONFIG_HUSH_PARSER=y +CONFIG_AUTOBOOT_KEYED=y +CONFIG_AUTOBOOT_PROMPT="Autoboot in %d seconds, to stop use 's' key\n" +CONFIG_AUTOBOOT_STOP_STR="s" +CONFIG_AUTOBOOT_KEYED_CTRLC=y +CONFIG_CMD_BOOTZ=y +# CONFIG_CMD_FLASH is not set +# CONFIG_CMD_I2C is not set +CONFIG_CMD_SPI=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_UBI=y +CONFIG_CMD_FS_GENERIC=y +CONFIG_CMD_MTD=y +CONFIG_CMD_MTDPARTS=y +CONFIG_DEFAULT_DEVICE_TREE="armada-xp-crs326-24g-2s" +CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_BLK=y +CONFIG_BOOTCOUNT_LIMIT=y +CONFIG_BOOTCOUNT_ENV=y +# CONFIG_DM_I2C is not set +# CONFIG_SYS_I2C_MVTWSI is not set +# CONFIG_MMC is not set +CONFIG_MTD=y +CONFIG_MTD_PARTITIONS=y +CONFIG_DM_MTD=y +CONFIG_DM_SPI_FLASH=y +CONFIG_SPI_FLASH_MTD=y +CONFIG_SPI_FLASH_SFDP_SUPPORT=y +CONFIG_SPI_FLASH_BAR=y +CONFIG_SPI_FLASH_WINBOND=y +# CONFIG_SPI_FLASH_USE_4K_SECTORS is not set +CONFIG_FIT=y +CONFIG_FIT_ENABLE_SHA256_SUPPORT=y +CONFIG_FIT_VERBOSE=y +CONFIG_FIT_BEST_MATCH=y +CONFIG_PCI=y +CONFIG_PCI_MVEBU=y +CONFIG_SYS_NS16550=y +CONFIG_KIRKWOOD_SPI=y
Thanks, Stefan
- armada-xp-crs326-24g-2s.dtb \
- armada-xp-crs326-24g-2s-bit.dtb \ armada-xp-db-xc3-24g4xg.dtb \ armada-xp-gp.dtb \ armada-xp-maxbcm.dtb \
- Device Tree file for MikroTik CRS326-24G-2S+ Bit board
- model = "MikroTik CRS326-24G-2S+ Bit";
+&spi0 {
- status = "okay";
- spi-flash@0 {
#size-cells = <1>;
m25p,fast-read;
partition@u-boot {
label = "u-boot";
partition@ubi1 {
label = "ubi1";
partition@ubi2 {
label = "ubi2";
+&uart0 {
- u-boot,dm-pre-reloc;
+&spi0 {
- spi-flash@0 {
- Device Tree file for MikroTik CRS326-24G-2S+ board
- model = "MikroTik CRS326-24G-2S+";
+&spi0 {
- status = "okay";
- Device Tree file for CRS326-24G-2S board
- Copyright (C) 2016 Allied Telesis Labs
- Based on armada-xp-db.dts
- Note: this Device Tree assumes that the bootloader has remapped the
- internal registers to 0xf1000000 (instead of the default
- 0xd0000000). The 0xf1000000 is the default used by the recent,
- DT-capable, U-Boot bootloaders provided by Marvell. Some earlier
- boards were delivered with an older version of the bootloader that
- left internal registers mapped at 0xd0000000. If you are in this
- situation, you should either update your bootloader (preferred
- solution) or the below Device Tree should be adjusted.
- model = "CRS326-24G-2S+";
- compatible = "marvell,armadaxp-98dx3236", "marvell,armadaxp-mv78260", "marvell,armadaxp", "marvell,armada-370-xp";
- chosen {
- aliases {
spi0 = &spi0;
- memory {
+&L2 {
- arm,parity-enable;
- marvell,ecc-enable;
+&devbus_bootcs {
- status = "okay";
- /* Device Bus parameters are required */
- /* Read parameters */
- devbus,bus-width = <16>;
- devbus,turn-off-ps = <60000>;
- devbus,badr-skew-ps = <0>;
- devbus,acc-first-ps = <124000>;
- devbus,acc-next-ps = <248000>;
- devbus,rd-setup-ps = <0>;
- devbus,rd-hold-ps = <0>;
- /* Write parameters */
- devbus,sync-enable = <0>;
- devbus,wr-high-ps = <60000>;
- devbus,wr-low-ps = <60000>;
- devbus,ale-wr-ps = <60000>;
+&uart0 {
- status = "okay";
+&uart1 {
- status = "okay";
+&i2c0 {
- clock-frequency = <100000>;
- status = "okay";
+&usb0 {
- status = "okay";
+&spi0 {
- status = "okay";
- spi-flash@0 {
#size-cells = <1>;
m25p,fast-read;
partition@u-boot {
label = "u-boot";
partition@ubi1 {
label = "ubi1";
Viele Grüße, Stefan
Thanks, Stefan
Thanks, Stefan
Viele Grüße, Stefan
Viele Grüße, Stefan
MikroTik CRS328-4C-20S-4S board has a switch chip with an integrated Marvell Prestera 98DX3236 CPU.
Signed-off-by: Luka Kovacic luka.kovacic@sartura.hr Cc: Luka Perkov luka.perkov@sartura.hr Cc: Jakov Petrina jakov.petrina@sartura.hr --- arch/arm/dts/Makefile | 2 + .../dts/armada-xp-crs328-4c-20s-4s-bit.dts | 43 +++++++ .../armada-xp-crs328-4c-20s-4s-u-boot.dtsi | 13 +++ arch/arm/dts/armada-xp-crs328-4c-20s-4s.dts | 17 +++ arch/arm/dts/armada-xp-crs328-4c-20s-4s.dtsi | 110 ++++++++++++++++++ board/mikrotik/crs3xx-98dx3236/MAINTAINERS | 9 ++ configs/crs328-4c-20s-4s-bit_defconfig | 54 +++++++++ configs/crs328-4c-20s-4s_defconfig | 54 +++++++++ 8 files changed, 302 insertions(+) create mode 100644 arch/arm/dts/armada-xp-crs328-4c-20s-4s-bit.dts create mode 100644 arch/arm/dts/armada-xp-crs328-4c-20s-4s-u-boot.dtsi create mode 100644 arch/arm/dts/armada-xp-crs328-4c-20s-4s.dts create mode 100644 arch/arm/dts/armada-xp-crs328-4c-20s-4s.dtsi create mode 100644 configs/crs328-4c-20s-4s-bit_defconfig create mode 100644 configs/crs328-4c-20s-4s_defconfig
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 9f8ca61f28..deced1ad7d 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -216,6 +216,8 @@ dtb-$(CONFIG_ARCH_MVEBU) += \ armada-xp-crs305-1g-4s-bit.dtb \ armada-xp-crs326-24g-2s.dtb \ armada-xp-crs326-24g-2s-bit.dtb \ + armada-xp-crs328-4c-20s-4s.dtb \ + armada-xp-crs328-4c-20s-4s-bit.dtb \ armada-xp-db-xc3-24g4xg.dtb \ armada-xp-gp.dtb \ armada-xp-maxbcm.dtb \ diff --git a/arch/arm/dts/armada-xp-crs328-4c-20s-4s-bit.dts b/arch/arm/dts/armada-xp-crs328-4c-20s-4s-bit.dts new file mode 100644 index 0000000000..d684c895ff --- /dev/null +++ b/arch/arm/dts/armada-xp-crs328-4c-20s-4s-bit.dts @@ -0,0 +1,43 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Device Tree file for MikroTik CRS328-4C-20S-4S+ Bit board + * + * Copyright (C) 2020 Sartura Ltd. + * Author: Luka Kovacic luka.kovacic@sartura.hr + */ + +#include "armada-xp-crs328-4c-20s-4s.dtsi" + +/ { + model = "MikroTik CRS328-4C-20S-4S+ Bit"; +}; + +&spi0 { + status = "okay"; + + spi-flash@0 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "spi-flash", "jedec,spi-nor"; + reg = <0>; /* Chip select 0 */ + spi-max-frequency = <108000000>; + m25p,fast-read; + + partition@u-boot { + reg = <0x00000000 0x001f0000>; + label = "u-boot"; + }; + partition@u-boot-env { + reg = <0x001f0000 0x00010000>; + label = "u-boot-env"; + }; + partition@ubi1 { + reg = <0x00200000 0x03f00000>; + label = "ubi1"; + }; + partition@ubi2 { + reg = <0x04100000 0x03f00000>; + label = "ubi2"; + }; + }; +}; diff --git a/arch/arm/dts/armada-xp-crs328-4c-20s-4s-u-boot.dtsi b/arch/arm/dts/armada-xp-crs328-4c-20s-4s-u-boot.dtsi new file mode 100644 index 0000000000..8576a02730 --- /dev/null +++ b/arch/arm/dts/armada-xp-crs328-4c-20s-4s-u-boot.dtsi @@ -0,0 +1,13 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) + +&uart0 { + u-boot,dm-pre-reloc; +}; + +&spi0 { + u-boot,dm-pre-reloc; + + spi-flash@0 { + u-boot,dm-pre-reloc; + }; +}; diff --git a/arch/arm/dts/armada-xp-crs328-4c-20s-4s.dts b/arch/arm/dts/armada-xp-crs328-4c-20s-4s.dts new file mode 100644 index 0000000000..665757f6e1 --- /dev/null +++ b/arch/arm/dts/armada-xp-crs328-4c-20s-4s.dts @@ -0,0 +1,17 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Device Tree file for MikroTik CRS328-4C-20S-4S+ board + * + * Copyright (C) 2020 Sartura Ltd. + * Author: Luka Kovacic luka.kovacic@sartura.hr + */ + +#include "armada-xp-crs328-4c-20s-4s.dtsi" + +/ { + model = "MikroTik CRS328-4C-20S-4S+"; +}; + +&spi0 { + status = "okay"; +}; diff --git a/arch/arm/dts/armada-xp-crs328-4c-20s-4s.dtsi b/arch/arm/dts/armada-xp-crs328-4c-20s-4s.dtsi new file mode 100644 index 0000000000..daff1af2a2 --- /dev/null +++ b/arch/arm/dts/armada-xp-crs328-4c-20s-4s.dtsi @@ -0,0 +1,110 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Device Tree file for CRS328-4C-20S-4S+ board + * + * Copyright (C) 2016 Allied Telesis Labs + * Copyright (C) 2020 Sartura Ltd. + * + * Based on armada-xp-db.dts + * + * Note: this Device Tree assumes that the bootloader has remapped the + * internal registers to 0xf1000000 (instead of the default + * 0xd0000000). The 0xf1000000 is the default used by the recent, + * DT-capable, U-Boot bootloaders provided by Marvell. Some earlier + * boards were delivered with an older version of the bootloader that + * left internal registers mapped at 0xd0000000. If you are in this + * situation, you should either update your bootloader (preferred + * solution) or the below Device Tree should be adjusted. + */ + +/dts-v1/; +#include "armada-xp-98dx3236.dtsi" +#include "armada-xp-crs328-4c-20s-4s-u-boot.dtsi" + +/ { + model = "CRS328-4C-20S-4S+"; + compatible = "marvell,armadaxp-98dx3236", "marvell,armadaxp-mv78260", "marvell,armadaxp", "marvell,armada-370-xp"; + + chosen { + stdout-path = "serial0:115200n8"; + bootargs = "console=ttyS0,115200 earlyprintk"; + }; + + aliases { + spi0 = &spi0; + }; + + memory { + device_type = "memory"; + reg = <0 0x00000000 0 0x20000000>; /* 512 MB */ + }; +}; + +&L2 { + arm,parity-enable; + marvell,ecc-enable; +}; + +&devbus_bootcs { + status = "okay"; + + /* Device Bus parameters are required */ + + /* Read parameters */ + devbus,bus-width = <16>; + devbus,turn-off-ps = <60000>; + devbus,badr-skew-ps = <0>; + devbus,acc-first-ps = <124000>; + devbus,acc-next-ps = <248000>; + devbus,rd-setup-ps = <0>; + devbus,rd-hold-ps = <0>; + + /* Write parameters */ + devbus,sync-enable = <0>; + devbus,wr-high-ps = <60000>; + devbus,wr-low-ps = <60000>; + devbus,ale-wr-ps = <60000>; +}; + +&uart0 { + status = "okay"; +}; + +&uart1 { + status = "okay"; +}; + +&i2c0 { + clock-frequency = <100000>; + status = "okay"; +}; + +&usb0 { + status = "okay"; +}; + +&spi0 { + status = "okay"; + + spi-flash@0 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "spi-flash", "jedec,spi-nor"; + reg = <0>; /* Chip select 0 */ + spi-max-frequency = <108000000>; + m25p,fast-read; + + partition@u-boot { + reg = <0x00000000 0x001f0000>; + label = "u-boot"; + }; + partition@u-boot-env { + reg = <0x001f0000 0x00010000>; + label = "u-boot-env"; + }; + partition@ubi1 { + reg = <0x00200000 0x00e00000>; + label = "ubi1"; + }; + }; +}; diff --git a/board/mikrotik/crs3xx-98dx3236/MAINTAINERS b/board/mikrotik/crs3xx-98dx3236/MAINTAINERS index 7f01f4318e..e6fbf3db1c 100644 --- a/board/mikrotik/crs3xx-98dx3236/MAINTAINERS +++ b/board/mikrotik/crs3xx-98dx3236/MAINTAINERS @@ -21,3 +21,12 @@ F: configs/crs326-24g-2s_defconfig F: configs/crs326-24g-2s-bit_defconfig F: arch/arm/dts/armada-xp-crs326-24g-2s.dts F: arch/arm/dts/armada-xp-crs326-24g-2s-bit.dts + +CRS328-4C-20S-4S BOARD +M: Luka Kovacic luka.kovacic@sartura.hr +M: Luka Perkov luka.perkov@sartura.hr +S: Maintained +F: configs/crs328-4c-20s-4s_defconfig +F: configs/crs328-4c-20s-4s-bit_defconfig +F: arch/arm/dts/armada-xp-crs328-4c-20s-4s.dts +F: arch/arm/dts/armada-xp-crs328-4c-20s-4s-bit.dts diff --git a/configs/crs328-4c-20s-4s-bit_defconfig b/configs/crs328-4c-20s-4s-bit_defconfig new file mode 100644 index 0000000000..9b949e63da --- /dev/null +++ b/configs/crs328-4c-20s-4s-bit_defconfig @@ -0,0 +1,54 @@ +CONFIG_ARM=y +CONFIG_ARCH_CPU_INIT=y +CONFIG_ARCH_MVEBU=y +CONFIG_SYS_TEXT_BASE=0x00800000 +CONFIG_SYS_MALLOC_F_LEN=0x2000 +CONFIG_TARGET_CRS3XX_98DX3236=y +CONFIG_ENV_SIZE=0x10000 +CONFIG_ENV_SECT_SIZE=0x10000 +CONFIG_ENV_OFFSET=0x1F0000 +CONFIG_BOOTCOUNT_BOOTLIMIT=3 +# CONFIG_EFI_LOADER is not set +CONFIG_BUILD_TARGET="u-boot.kwb" +CONFIG_USE_PREBOOT=y +CONFIG_SYS_CONSOLE_INFO_QUIET=y +CONFIG_HUSH_PARSER=y +CONFIG_AUTOBOOT_KEYED=y +CONFIG_AUTOBOOT_PROMPT="Autoboot in %d seconds, to stop use 's' key\n" +CONFIG_AUTOBOOT_STOP_STR="s" +CONFIG_AUTOBOOT_KEYED_CTRLC=y +CONFIG_CMD_BOOTZ=y +# CONFIG_CMD_FLASH is not set +# CONFIG_CMD_I2C is not set +CONFIG_CMD_SPI=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_UBI=y +CONFIG_CMD_FS_GENERIC=y +CONFIG_CMD_MTD=y +CONFIG_CMD_MTDPARTS=y +CONFIG_DEFAULT_DEVICE_TREE="armada-xp-crs328-4c-20s-4s-bit" +CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_BLK=y +CONFIG_BOOTCOUNT_LIMIT=y +CONFIG_BOOTCOUNT_ENV=y +# CONFIG_DM_I2C is not set +# CONFIG_SYS_I2C_MVTWSI is not set +# CONFIG_MMC is not set +CONFIG_MTD=y +CONFIG_MTD_PARTITIONS=y +CONFIG_DM_MTD=y +CONFIG_DM_SPI_FLASH=y +CONFIG_SPI_FLASH_MTD=y +CONFIG_SPI_FLASH_SFDP_SUPPORT=y +CONFIG_SPI_FLASH_BAR=y +CONFIG_SPI_FLASH_MACRONIX=y +# CONFIG_SPI_FLASH_USE_4K_SECTORS is not set +CONFIG_FIT=y +CONFIG_FIT_ENABLE_SHA256_SUPPORT=y +CONFIG_FIT_VERBOSE=y +CONFIG_FIT_BEST_MATCH=y +CONFIG_PCI=y +CONFIG_PCI_MVEBU=y +CONFIG_SYS_NS16550=y +CONFIG_KIRKWOOD_SPI=y diff --git a/configs/crs328-4c-20s-4s_defconfig b/configs/crs328-4c-20s-4s_defconfig new file mode 100644 index 0000000000..33eefbd475 --- /dev/null +++ b/configs/crs328-4c-20s-4s_defconfig @@ -0,0 +1,54 @@ +CONFIG_ARM=y +CONFIG_ARCH_CPU_INIT=y +CONFIG_ARCH_MVEBU=y +CONFIG_SYS_TEXT_BASE=0x00800000 +CONFIG_SYS_MALLOC_F_LEN=0x2000 +CONFIG_TARGET_CRS3XX_98DX3236=y +CONFIG_ENV_SIZE=0x10000 +CONFIG_ENV_SECT_SIZE=0x10000 +CONFIG_ENV_OFFSET=0x1F0000 +CONFIG_BOOTCOUNT_BOOTLIMIT=3 +# CONFIG_EFI_LOADER is not set +CONFIG_BUILD_TARGET="u-boot.kwb" +CONFIG_USE_PREBOOT=y +CONFIG_SYS_CONSOLE_INFO_QUIET=y +CONFIG_HUSH_PARSER=y +CONFIG_AUTOBOOT_KEYED=y +CONFIG_AUTOBOOT_PROMPT="Autoboot in %d seconds, to stop use 's' key\n" +CONFIG_AUTOBOOT_STOP_STR="s" +CONFIG_AUTOBOOT_KEYED_CTRLC=y +CONFIG_CMD_BOOTZ=y +# CONFIG_CMD_FLASH is not set +# CONFIG_CMD_I2C is not set +CONFIG_CMD_SPI=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_UBI=y +CONFIG_CMD_FS_GENERIC=y +CONFIG_CMD_MTD=y +CONFIG_CMD_MTDPARTS=y +CONFIG_DEFAULT_DEVICE_TREE="armada-xp-crs328-4c-20s-4s" +CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_BLK=y +CONFIG_BOOTCOUNT_LIMIT=y +CONFIG_BOOTCOUNT_ENV=y +# CONFIG_DM_I2C is not set +# CONFIG_SYS_I2C_MVTWSI is not set +# CONFIG_MMC is not set +CONFIG_MTD=y +CONFIG_MTD_PARTITIONS=y +CONFIG_DM_MTD=y +CONFIG_DM_SPI_FLASH=y +CONFIG_SPI_FLASH_MTD=y +CONFIG_SPI_FLASH_SFDP_SUPPORT=y +CONFIG_SPI_FLASH_BAR=y +CONFIG_SPI_FLASH_WINBOND=y +# CONFIG_SPI_FLASH_USE_4K_SECTORS is not set +CONFIG_FIT=y +CONFIG_FIT_ENABLE_SHA256_SUPPORT=y +CONFIG_FIT_VERBOSE=y +CONFIG_FIT_BEST_MATCH=y +CONFIG_PCI=y +CONFIG_PCI_MVEBU=y +CONFIG_SYS_NS16550=y +CONFIG_KIRKWOOD_SPI=y
Thanks, Stefan
- armada-xp-crs328-4c-20s-4s.dtb \
- armada-xp-crs328-4c-20s-4s-bit.dtb \ armada-xp-db-xc3-24g4xg.dtb \ armada-xp-gp.dtb \ armada-xp-maxbcm.dtb \
- Device Tree file for MikroTik CRS328-4C-20S-4S+ Bit board
- model = "MikroTik CRS328-4C-20S-4S+ Bit";
+&spi0 {
- status = "okay";
- spi-flash@0 {
#size-cells = <1>;
m25p,fast-read;
partition@u-boot {
label = "u-boot";
partition@ubi1 {
label = "ubi1";
partition@ubi2 {
label = "ubi2";
+&uart0 {
+&spi0 {
- spi-flash@0 {
- Device Tree file for MikroTik CRS328-4C-20S-4S+ board
- model = "MikroTik CRS328-4C-20S-4S+";
+&spi0 {
- status = "okay";
- Device Tree file for CRS328-4C-20S-4S+ board
- model = "CRS328-4C-20S-4S+";
- chosen {
- aliases {
spi0 = &spi0;
- memory {
+&L2 {
+&devbus_bootcs {
- status = "okay";
+&uart0 {
- status = "okay";
+&uart1 {
- status = "okay";
+&i2c0 {
- status = "okay";
+&usb0 {
- status = "okay";
+&spi0 {
- status = "okay";
- spi-flash@0 {
#size-cells = <1>;
m25p,fast-read;
partition@u-boot {
label = "u-boot";
partition@ubi1 {
label = "ubi1";
Viele Grüße, Stefan
Thanks, Stefan
Thanks, Stefan
Viele Grüße, Stefan
Viele Grüße, Stefan
Add Luka Perkov to CRS3xx-98DX3236 MAINTAINERS.
Signed-off-by: Luka Kovacic luka.kovacic@sartura.hr Cc: Luka Perkov luka.perkov@sartura.hr Cc: Jakov Petrina jakov.petrina@sartura.hr --- board/mikrotik/crs3xx-98dx3236/MAINTAINERS | 1 + 1 file changed, 1 insertion(+)
diff --git a/board/mikrotik/crs3xx-98dx3236/MAINTAINERS b/board/mikrotik/crs3xx-98dx3236/MAINTAINERS index e6fbf3db1c..906ff98970 100644 --- a/board/mikrotik/crs3xx-98dx3236/MAINTAINERS +++ b/board/mikrotik/crs3xx-98dx3236/MAINTAINERS @@ -1,5 +1,6 @@ CRS3XX-98DX3236 BOARD M: Luka Kovacic luka.kovacic@sartura.hr +M: Luka Perkov luka.perkov@sartura.hr S: Maintained F: board/mikrotik/crs3xx-98dx3236/ F: include/configs/crs3xx-98dx3236.h
Thanks, Stefan
Viele Grüße, Stefan
Thanks, Stefan
Thanks, Stefan
Viele Grüße, Stefan
Viele Grüße, Stefan
Update the MikroTik CRS305-1G-4S flash layout to support redundant UBI partitions. Additionally enable the UBI commands in crs305-1g-4s_defconfig.
Signed-off-by: Luka Kovacic luka.kovacic@sartura.hr Cc: Luka Perkov luka.perkov@sartura.hr Cc: Jakov Petrina jakov.petrina@sartura.hr --- arch/arm/dts/armada-xp-crs305-1g-4s.dtsi | 10 +++++----- configs/crs305-1g-4s_defconfig | 9 ++++++++- 2 files changed, 13 insertions(+), 6 deletions(-)
diff --git a/arch/arm/dts/armada-xp-crs305-1g-4s.dtsi b/arch/arm/dts/armada-xp-crs305-1g-4s.dtsi index c8839eac94..1a74ecd5b5 100644 --- a/arch/arm/dts/armada-xp-crs305-1g-4s.dtsi +++ b/arch/arm/dts/armada-xp-crs305-1g-4s.dtsi @@ -95,16 +95,16 @@ m25p,fast-read;
partition@u-boot { - reg = <0x00000000 0x00080000>; + reg = <0x00000000 0x001f0000>; label = "u-boot"; }; partition@u-boot-env { - reg = <0x00080000 0x00010000>; + reg = <0x001f0000 0x00010000>; label = "u-boot-env"; }; - partition@firmware { - reg = <0x00090000 0x00f70000>; - label = "firmware"; + partition@ubi1 { + reg = <0x00200000 0x00e00000>; + label = "ubi1"; };
}; diff --git a/configs/crs305-1g-4s_defconfig b/configs/crs305-1g-4s_defconfig index a360fc5d3f..a62b14e856 100644 --- a/configs/crs305-1g-4s_defconfig +++ b/configs/crs305-1g-4s_defconfig @@ -5,14 +5,17 @@ CONFIG_SYS_TEXT_BASE=0x00800000 CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_TARGET_CRS3XX_98DX3236=y CONFIG_ENV_SIZE=0x10000 -CONFIG_ENV_OFFSET=0x80000 +CONFIG_ENV_OFFSET=0x1F0000 CONFIG_ENV_SECT_SIZE=0x10000 +CONFIG_BOOTCOUNT_BOOTLIMIT=3 CONFIG_BUILD_TARGET="u-boot.kwb" CONFIG_FIT=y +CONFIG_FIT_ENABLE_SHA256_SUPPORT=y CONFIG_FIT_VERBOSE=y CONFIG_FIT_BEST_MATCH=y CONFIG_USE_PREBOOT=y CONFIG_SYS_CONSOLE_INFO_QUIET=y +CONFIG_HUSH_PARSER=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Autoboot in %d seconds, to stop use 's' key\n" CONFIG_AUTOBOOT_STOP_STR="s" @@ -22,11 +25,15 @@ CONFIG_CMD_BOOTZ=y CONFIG_CMD_MTD=y CONFIG_CMD_SPI=y CONFIG_CMD_CACHE=y +CONFIG_CMD_UBI=y +CONFIG_CMD_FS_GENERIC=y CONFIG_CMD_MTDPARTS=y CONFIG_DEFAULT_DEVICE_TREE="armada-xp-crs305-1g-4s" CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_BLK=y +CONFIG_BOOTCOUNT_LIMIT=y +CONFIG_BOOTCOUNT_ENV=y # CONFIG_MMC is not set CONFIG_MTD=y CONFIG_DM_MTD=y
Thanks, Stefan
partition@u-boot {
}; partition@u-boot-env {reg = <0x00000000 0x001f0000>; label = "u-boot";
};reg = <0x001f0000 0x00010000>; label = "u-boot-env";
label = "firmware";
partition@ubi1 {
label = "ubi1";
Viele Grüße, Stefan
Thanks, Stefan
Thanks, Stefan
diff --git a/arch/arm/dts/armada-xp-crs305-1g-4s.dtsi b/arch/arm/dts/armada-xp-crs305-1g-4s.dtsi index c8839eac94..1a74ecd5b5 100644 --- a/arch/arm/dts/armada-xp-crs305-1g-4s.dtsi +++ b/arch/arm/dts/armada-xp-crs305-1g-4s.dtsi @@ -95,16 +95,16 @@ m25p,fast-read; partition@u-boot { - reg = <0x00000000 0x00080000>; + reg = <0x00000000 0x001f0000>; label = "u-boot"; }; partition@u-boot-env { - reg = <0x00080000 0x00010000>; + reg = <0x001f0000 0x00010000>; label = "u-boot-env"; }; - partition@firmware { - reg = <0x00090000 0x00f70000>; - label = "firmware"; + partition@ubi1 { + reg = <0x00200000 0x00e00000>; + label = "ubi1"; }; }; diff --git a/configs/crs305-1g-4s_defconfig b/configs/crs305-1g-4s_defconfig index a360fc5d3f..a62b14e856 100644 --- a/configs/crs305-1g-4s_defconfig +++ b/configs/crs305-1g-4s_defconfig @@ -5,14 +5,17 @@ CONFIG_SYS_TEXT_BASE=0x00800000 CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_TARGET_CRS3XX_98DX3236=y CONFIG_ENV_SIZE=0x10000 -CONFIG_ENV_OFFSET=0x80000 +CONFIG_ENV_OFFSET=0x1F0000 CONFIG_ENV_SECT_SIZE=0x10000 +CONFIG_BOOTCOUNT_BOOTLIMIT=3 CONFIG_BUILD_TARGET="u-boot.kwb" CONFIG_FIT=y +CONFIG_FIT_ENABLE_SHA256_SUPPORT=y CONFIG_FIT_VERBOSE=y CONFIG_FIT_BEST_MATCH=y CONFIG_USE_PREBOOT=y CONFIG_SYS_CONSOLE_INFO_QUIET=y +CONFIG_HUSH_PARSER=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Autoboot in %d seconds, to stop use 's' key\n" CONFIG_AUTOBOOT_STOP_STR="s" @@ -22,11 +25,15 @@ CONFIG_CMD_BOOTZ=y CONFIG_CMD_MTD=y CONFIG_CMD_SPI=y CONFIG_CMD_CACHE=y +CONFIG_CMD_UBI=y +CONFIG_CMD_FS_GENERIC=y CONFIG_CMD_MTDPARTS=y CONFIG_DEFAULT_DEVICE_TREE="armada-xp-crs305-1g-4s" CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_BLK=y +CONFIG_BOOTCOUNT_LIMIT=y +CONFIG_BOOTCOUNT_ENV=y # CONFIG_MMC is not set CONFIG_MTD=y CONFIG_DM_MTD=y
Viele Grüße, Stefan
Viele Grüße, Stefan
Luka Kovacic
Stefan Roese
